    4. [Neuer Adapter] EuSec
    • Longbow
      Longbow last edited by
      @longbow Welchen Teil von dem iob Log möchtes Du sehen... habe es gestern nicht mehr geschafft und von Unterwegs ging es nicht so, wie ich es wollte.
      Longbow 1 Reply Last reply Reply Quote 0
      • Longbow
        Longbow @Longbow last edited by
        @Thomas-Braun
          Thomas Braun Most Active @Longbow last edited by
          @longbow
          Alles.
          Longbow L 2 Replies Last reply Reply Quote 0
          • Longbow
            Longbow @Thomas Braun last edited by
            Bitte:-)
            Skript v.2023-01-02
            *** BASE SYSTEM ***
            Architecture:   x86_64
            Docker:         false
            Virtualization: lxc
            Distributor ID: Ubuntu
            Description:    Ubuntu 22.04.1 LTS
            Release:        22.04
            Codename:       jammy
            PRETTY_NAME="Ubuntu 22.04.1 LTS"
            NAME="Ubuntu"
            VERSION_ID="22.04"
            VERSION="22.04.1 LTS (Jammy Jellyfish)"
            VERSION_CODENAME=jammy
            ID=ubuntu
            ID_LIKE=debian
            HOME_URL="https://www.ubuntu.com/"
            SUPPORT_URL="https://help.ubuntu.com/"
            BUG_REPORT_URL="https://bugs.launchpad.net/ubuntu/"
            PRIVACY_POLICY_URL="https://www.ubuntu.com/legal/terms-and-policies/privacy-policy"
            UBUNTU_CODENAME=jammy
            Systemuptime and Load:
            06:35:50 up 1 day, 11:41,  2 users,  load average: 0.64, 0.55, 0.43
            CPU threads: 4
            *** Time and Time Zones ***
            Wed Feb  1 06:35:50 UTC 2023
            UTC +0000
            Etc/UTC
            *** X-Server-Setup ***
            X-Server:       false
            Desktop:
            Terminal:
            *** MEMORY ***
            Mem:            8.2G        3.3G        3.6G        0.0K        1.3G        4.9G
            Swap:           512M          0B        512M
            Total:          8.7G        3.3G        4.1G
                     8192 M total memory
                     3272 M used memory
                      568 M active memory
                     3792 M inactive memory
                     3584 M free memory
                        0 M buffer memory
                     1335 M swap cache
                      512 M total swap
                        0 M used swap
                      512 M free swap
            *** FILESYSTEM ***
            Filesystem                       Type   Size  Used Avail Use% Mounted on
            /dev/mapper/pve-vm--200--disk--0 ext4    20G  7.6G   11G  42% /
            none                             tmpfs  492K  4.0K  488K   1% /dev
            tmpfs                            tmpfs  7.8G     0  7.8G   0% /dev/shm
            tmpfs                            tmpfs  3.2G   96K  3.2G   1% /run
            tmpfs                            tmpfs  5.0M     0  5.0M   0% /run/lock
            Messages in dmesg:
            dmesg: read kernel buffer failed: Operation not permitted
            Show mounted filesystems (real ones only):
            TARGET SOURCE                           FSTYPE OPTIONS
            /      /dev/mapper/pve-vm--200--disk--0 ext4   rw,relatime,stripe=16
            /var:
            2.6G    /var/
            2.0G    /var/log/journal/678b65fc11864452957ca5b3828797d4
            2.0G    /var/log
            331M    /var/cache
            /opt/iobroker/backups:
            495M    /opt/iobroker/backups/
            /opt/iobroker/iobroker-data:
            583M    /opt/iobroker/iobroker-data/
            365M    /opt/iobroker/iobroker-data/files
            74M     /opt/iobroker/iobroker-data/backup-objects
            72M     /opt/iobroker/iobroker-data/files/telegram.admin
            51M     /opt/iobroker/iobroker-data/files/javascript.admin
            46M     /opt/iobroker/iobroker-data/states.jsonl
            34M     /opt/iobroker/iobroker-data/objects.jsonl
            19M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.904d455f.js.map
            15M     /opt/iobroker/iobroker-data/files/vis.0/Iobroker/vis-views.json
            15M     /opt/iobroker/iobroker-data/files/telegram.admin/rules/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_d_ts-node_modules_io-1d9f06.44fe4a3f.chunk.js.map
            *** NodeJS-Installation ***
            /usr/bin/nodejs         v16.19.0
            /root/.nvm/versions/node/v16.18.0/bin/node              v16.18.0
            /root/.nvm/versions/node/v16.18.0/bin/npm               9.4.0
            /root/.nvm/versions/node/v16.18.0/bin/npx               9.4.0
            nodejs:
              Installed: 16.19.0-deb-1nodesource1
              Candidate: 16.19.0-deb-1nodesource1
              Version table:
            *** 16.19.0-deb-1nodesource1 500
                    500 https://deb.nodesource.com/node_16.x jammy/main amd64 Packages
                    100 /var/lib/dpkg/status
                 12.22.9~dfsg-1ubuntu3 500
                    500 http://archive.ubuntu.com/ubuntu jammy/universe amd64 Packages
            *** ioBroker-Installation ***
            ioBroker Status
            Objects type: jsonl
            States  type: jsonl
            Core adapters versions
            js-controller:  4.0.24
            admin:          6.3.5
            javascript:     6.1.4
            Adapters from github:   3
            Adapter State
            + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
              system.adapter.apple-find-me.0          : apple-find-me         : iobroker                                 - disabled
            + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
              system.adapter.birthdays.0              : birthdays             : iobroker                                 - disabled
            + system.adapter.chromecast.0             : chromecast            : iobroker                                 -  enabled
            + system.adapter.cloud.0                  : cloud                 : iobroker                                 -  enabled
              system.adapter.daswetter.0              : daswetter             : iobroker                                 -  enabled
            + system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
              system.adapter.dwd.0                    : dwd                   : iobroker                                 -  enabled
            + system.adapter.echarts.0                : echarts               : iobroker                                 -  enabled
            + system.adapter.email.0                  : email                 : iobroker                                 -  enabled
              system.adapter.eusec.0                  : eusec                 : iobroker                                 -  enabled
            + system.adapter.fb-checkpresence.0       : fb-checkpresence      : iobroker                                 -  enabled
              system.adapter.feiertage.0              : feiertage             : iobroker                                 -  enabled
              system.adapter.flot.0                   : flot                  : iobroker                                 -  enabled
            + system.adapter.followthesun.0           : followthesun          : iobroker                                 -  enabled
            + system.adapter.geofency.0               : geofency              : iobroker                                 -  enabled, port: 7999, bind: 0.0.0.0
            + system.adapter.history.0                : history               : iobroker                                 -  enabled
            + system.adapter.hm-rega.0                : hm-rega               : iobroker                                 -  enabled
            + system.adapter.hm-rpc.0                 : hm-rpc                : iobroker                                 -  enabled, port: 0
            + system.adapter.homeconnect.0            : homeconnect           : iobroker                                 -  enabled
              system.adapter.hue-extended.0           : hue-extended          : iobroker                                 - disabled
            + system.adapter.hue.0                    : hue                   : iobroker                                 -  enabled, port: 443
              system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
              system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: iobroker                                 -  enabled
              system.adapter.icons-material-png.0     : icons-material-png    : iobroker                                 -  enabled
              system.adapter.icons-material-svg.0     : icons-material-svg    : iobroker                                 -  enabled
              system.adapter.icons-mfd-png.0          : icons-mfd-png         : iobroker                                 -  enabled
              system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobroker                                 -  enabled
              system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : iobroker                                 -  enabled
            + system.adapter.influxdb.0               : influxdb              : iobroker                                 -  enabled, port: 8086
            + system.adapter.info.0                   : info                  : iobroker                                 -  enabled
            + system.adapter.iot.0                    : iot                   : iobroker                                 -  enabled
            + system.adapter.jarvis.0                 : jarvis                : iobroker                                 -  enabled
            + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
              system.adapter.klf200.0                 : klf200                : iobroker                                 - disabled
            + system.adapter.mihome-vacuum.0          : mihome-vacuum         : iobroker                                 -  enabled, port: 54321
              system.adapter.mobile.0                 : mobile                : iobroker                                 - disabled
            + system.adapter.modbus.0                 : modbus                : iobroker                                 -  enabled
            + system.adapter.netatmo.0                : netatmo               : iobroker                                 -  enabled
            + system.adapter.nina.0                   : nina                  : iobroker                                 -  enabled
            + system.adapter.nuki-extended.0          : nuki-extended         : iobroker                                 -  enabled
              system.adapter.openweathermap.0         : openweathermap        : iobroker                                 -  enabled
              system.adapter.operating-hours.0        : operating-hours       : iobroker                                 - disabled
              system.adapter.parcel.0                 : parcel                : iobroker                                 - disabled
              system.adapter.parser.0                 : parser                : iobroker                                 - disabled
              system.adapter.places.0                 : places                : iobroker                                 - disabled
            + system.adapter.pollenflug.0             : pollenflug            : iobroker                                 -  enabled
            + system.adapter.proxmox.0                : proxmox               : iobroker                                 -  enabled, port: 8006
            + system.adapter.pvforecast.0             : pvforecast            : iobroker                                 -  enabled
              system.adapter.rtspstream.0             : rtspstream            : iobroker                                 -  enabled
            + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1882, bind: 0.0.0.0
            + system.adapter.smartgarden.0            : smartgarden           : iobroker                                 -  enabled
            + system.adapter.smartthings.0            : smartthings           : iobroker                                 -  enabled
            + system.adapter.sonos.0                  : sonos                 : iobroker                                 -  enabled
            + system.adapter.synology.0               : synology              : iobroker                                 -  enabled, port: 5000
            + system.adapter.synology.1               : synology              : iobroker                                 -  enabled, port: 5000
            + system.adapter.tankerkoenig.0           : tankerkoenig          : iobroker                                 -  enabled
              system.adapter.telegram.0               : telegram              : iobroker                                 - disabled, port: 8443, bind: 0.0.0.0
            + system.adapter.tr-064.0                 : tr-064                : iobroker                                 -  enabled
            + system.adapter.tr-064.1                 : tr-064                : iobroker                                 -  enabled
            + system.adapter.trashschedule.0          : trashschedule         : iobroker                                 -  enabled
            + system.adapter.tuya.0                   : tuya                  : iobroker                                 -  enabled
              system.adapter.unifi.0                  : unifi                 : iobroker                                 - disabled
            + system.adapter.upnp.0                   : upnp                  : iobroker                                 -  enabled
              system.adapter.vis-bars.0               : vis-bars              : iobroker                                 -  enabled
              system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : iobroker                                 -  enabled
              system.adapter.vis-colorpicker.0        : vis-colorpicker       : iobroker                                 -  enabled
              system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : iobroker                                 -  enabled
              system.adapter.vis-google-fonts.0       : vis-google-fonts      : iobroker                                 -  enabled
              system.adapter.vis-history.0            : vis-history           : iobroker                                 -  enabled
              system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 -  enabled
              system.adapter.vis-icontwo.0            : vis-icontwo           : iobroker                                 -  enabled
            + system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker                                 -  enabled
              system.adapter.vis-material-advanced.0  : vis-material-advanced : iobroker                                 -  enabled
              system.adapter.vis-rgraph.0             : vis-rgraph            : iobroker                                 -  enabled
              system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 -  enabled
              system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
            + system.adapter.vw-connect.0             : vw-connect            : iobroker                                 -  enabled
            + system.adapter.vw-connect.1             : vw-connect            : iobroker                                 -  enabled
              system.adapter.weatherunderground.0     : weatherunderground    : iobroker                                 -  enabled
            + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
            + system.adapter.wolf-smartset.0          : wolf-smartset         : iobroker                                 -  enabled
            + system.adapter.wolf.0                   : wolf                  : iobroker                                 -  enabled, port: 12004, bind: 192.168.178.200
              system.adapter.youtube.0                : youtube               : iobroker                                 - disabled
              system.adapter.yr.0                     : yr                    : iobroker                                 -  enabled
            + instance is alive
            ioBroker-Repositories
            Active repo(s): stable
            Installed ioBroker-Instances
            Used repository: stable
            Adapter    "admin"        : 6.3.5    , installed 6.3.5
            Adapter    "alpha-ess"    : 0.2.0    , installed 0.2.0
            Adapter    "apple-find-me": 0.0.14   , installed 0.0.14
            Adapter    "backitup"     : 2.5.10   , installed 2.5.10
            Adapter    "birthdays"    : 2.2.0    , installed 2.2.0
            Adapter    "chromecast"   : 2.3.1    , installed 2.3.1
            Adapter    "cloud"        : 4.3.0    , installed 4.3.0
            Adapter    "daswetter"    : 3.1.4    , installed 3.1.4
            Adapter    "device-reminder": 1.2.9  , installed 1.2.9
            Adapter    "discovery"    : 3.1.0    , installed 3.1.0
            Adapter    "dwd"          : 2.8.3    , installed 2.8.3
            Adapter    "echarts"      : 1.0.12   , installed 1.0.12
            Adapter    "email"        : 1.1.4    , installed 1.1.4
            Adapter    "eusec"        : 0.9.9    , installed 0.9.9
            Adapter    "fb-checkpresence": 1.1.20, installed 1.1.20
            Adapter    "feiertage"    : 1.1.0    , installed 1.1.0
            Adapter    "flot"         : 1.11.0   , installed 1.11.0
            Adapter    "followthesun" : 0.4.0    , installed 0.4.0
            Adapter    "geofency"     : 1.2.4    , installed 1.2.4
            Adapter    "hid-community": 0.3.0    , installed 0.3.0
            Adapter    "history"      : 2.2.4    , installed 2.2.4
            Adapter    "hm-rega"      : 3.0.40   , installed 3.0.40
            Adapter    "hm-rpc"       : 1.15.16  , installed 1.15.16
            Adapter    "homeconnect"  : 1.1.1    , installed 1.1.1
            Adapter    "hue"          : 3.7.1    , installed 3.7.1
            Adapter    "hue-extended" : 2.0.0    , installed 2.0.0
            Adapter    "ical"         : 1.13.2   , installed 1.13.2
            Adapter    "icons-material-svg": 0.1.0, installed 0.1.0
            Adapter    "icons-mfd-png": 1.1.0    , installed 1.1.0
            Adapter    "influxdb"     : 3.2.0    , installed 3.2.0
            Adapter    "info"         : 1.9.19   , installed 1.9.19
            Adapter    "iot"          : 1.14.2   , installed 1.14.2
            Adapter    "jarvis"       : 3.1.2    , installed 3.1.2
            Adapter    "javascript"   : 6.1.4    , installed 6.1.4
            Controller "js-controller": 4.0.24   , installed 4.0.24
            Adapter    "klf200"       : 1.0.1    , installed 1.0.1
            Adapter    "mclighting"   : 0.1.2    , installed 0.1.2
            Adapter    "mihome"       : 1.4.0    , installed 1.4.0
            Adapter    "mihome-vacuum": 3.8.8    , installed 3.8.8
            Adapter    "mobile"       : 1.0.1    , installed 1.0.1
            Adapter    "modbus"       : 5.0.11   , installed 5.0.11
            Adapter    "netatmo"      : 2.0.5    , installed 2.0.5
            Adapter    "nina"         : 0.0.25   , installed 0.0.25
            Adapter    "nuki-extended": 2.3.1    , installed 2.3.1
            Adapter    "openweathermap": 0.3.3   , installed 0.3.3
            Adapter    "operating-hours": 0.0.19 , installed 0.0.19
            Adapter    "parcel"       : 0.0.23   , installed 0.0.23
            Adapter    "parser"       : 1.1.8    , installed 1.1.8
            Adapter    "places"       : 1.1.2    , installed 1.1.2
            Adapter    "pollenflug"   : 1.0.6    , installed 1.0.6
            Adapter    "proxmox"      : 1.3.4    , installed 1.3.4
            Adapter    "pvforecast"   : 2.3.0    , installed 2.3.0
            Adapter    "shelly"       : 6.3.1    , installed 6.3.1
            Adapter    "smartgarden"  : 2.0.0    , installed 2.0.0
            Adapter    "smartthings"  : 0.0.4    , installed 0.0.4
            Adapter    "sonos"        : 2.2.3    , installed 2.2.3
            Adapter    "synology"     : 2.1.13   , installed 2.1.13
            Adapter    "tankerkoenig" : 3.3.6    , installed 3.3.6
            Adapter    "telegram"     : 1.15.2   , installed 1.15.2
            Adapter    "tr-064"       : 4.2.17   , installed 4.2.17
            Adapter    "trashschedule": 2.2.0    , installed 2.2.0
            Adapter    "tuya"         : 3.13.1   , installed 3.13.1
            Adapter    "tvprogram"    : 1.1.2    , installed 1.1.2
            Adapter    "unifi"        : 0.5.10   , installed 0.5.10
            Adapter    "upnp"         : 1.0.21   , installed 1.0.21
            Adapter    "vis"          : 1.4.15   , installed 1.4.15
            Adapter    "vis-colorpicker": 1.2.0  , installed 1.2.0
            Adapter    "vis-hqwidgets": 1.3.0    , installed 1.3.0
            Adapter    "vis-icontwo"  : 0.90.0   , installed 0.90.0
            Adapter    "vis-inventwo" : 3.3.1    , installed 3.3.1
            Adapter    "vis-material-advanced": 1.7.2, installed 1.7.2
            Adapter    "vw-connect"   : 0.0.56   , installed 0.0.56
            Adapter    "weatherunderground": 3.4.2, installed 3.4.2
            Adapter    "wolf"         : 1.5.0    , installed 1.5.0
            Adapter    "wolf-smartset": 1.0.0    , installed 1.0.0
            Adapter    "youtube"      : 4.1.0    , installed 4.1.0
            Adapter    "yr"           : 5.3.0    , installed 5.3.0
            Objects and States
            Objects:        51213
            States:         41765
            Hit:1 https://deb.nodesource.com/node_16.x jammy InRelease
              @longbow
              Zeitzone setzen und nodejs gescheit installieren.
              • Longbow
                wie mache ich das bitte, bin neu Neuling auf dem Gebiet ioborker...
                  Thomas Braun Most Active @Longbow last edited by Thomas Braun
                  @longbow
                  Das hat mit iobroker nix zu tun, das hat damit zu tun wie du deinen Container administrierst. Mit den Dingern hab ich aber nix mit am Hut.
                  Schau in die Anleitung, vielleicht steht da was drin:
                  https://www.iobroker.net/#de/documentation/install/proxmox.md
                  Zur NodeJS-Installation:
                  Wo stand denn, das man nodejs als root per nvm installiert?
                  Das ist nämlich Murks.
                  • Longbow
                    wie kann ich das mit dem nodejs beheben? Oder ist es besser das man Iobroker neu installiert?
                      @longbow sagte in [Neuer Adapter] EuSec:
                      Schau in meiner Signatur, da wird das mit den falschen Pfaden bei nodejs erklärt.
                        lustig29 @Thomas Braun last edited by
                        @thomas-braun Kannst du mir auch bei meinem Problem vom Post weiter oben helfen?
                          Thomas Braun Most Active @lustig29 last edited by
                          @lustig29
                          Bei welchem?
                            @thomas-braun Seit geraumer Zeit läuft der Adapter nicht mehr richtig. Die Verbindung wird immer wieder getrennt und wieder hergestellt. Hatte sowas schon mal jemand?
                            eusec.0
                            2023-01-29 11:24:22.280	info	Connected to station T8010P23220312FE on host 192.168.0.70 and port 22316
                            eusec.0
                            2023-01-29 11:24:17.255	info	Disconnected from station T8010P23220312FE
                              Thomas Braun Most Active @lustig29 last edited by Thomas Braun
                              @lustig29 sagte in [Neuer Adapter] EuSec:
                              Nein. Keine Ahnung.
                              Ist halt auch was dünn, so'n Zweizeiler.
                              • Longbow
                                guten Morgen, habe es alles gemacht wie es dort beschrieben ist, eine Abhilfe hat es leider nicht gebracht.
                                Hab ein neues System nach den Anleitungen gemacht.
                                Habe es mit auch alles angeschaut mit Nodejs, aber ich bekomme nur Fehlermeldungen. Der Adpater bleibt ohne Daten und Verbindung rot
                                Debian GNU/Linux 11 iobroker-Test tty1
                                iobroker-Test login: root
                                Password:
                                Linux iobroker-Test 5.15.30-2-pve #1 SMP PVE 5.15.30-3 (Fri, 22 Apr 2022 18:08:27 +0200) x86_64
                                The programs included with the Debian GNU/Linux system are free software;
                                the exact distribution terms for each program are described in the
                                individual files in /usr/share/doc/*/copyright.
                                Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
                                permitted by applicable law.
                                Last login: Thu Feb  2 08:28:34 CET 2023 on tty1
                                root@iobroker-Test:~# apt install sudo curl
                                Reading package lists... Done
                                Building dependency tree... Done
                                The following additional packages will be installed:
                                  libcurl4
                                The following NEW packages will be installed:
                                  curl libcurl4 sudo
                                0 upgraded, 3 newly installed, 0 to remove and 0 not upgraded.
                                Need to get 1673 kB of archives.
                                After this operation, 5895 kB of additional disk space will be used.
                                Do you want to continue? [Y/n] y
                                Err:1 http://deb.debian.org/debian bullseye/main amd64 libcurl4 amd64 7.74.0-1.3+deb11u3
                                  Temporary failure resolving 'deb.debian.org'
                                Err:2 http://deb.debian.org/debian bullseye/main amd64 curl amd64 7.74.0-1.3+deb11u3
                                Err:3 http://deb.debian.org/debian bullseye/main amd64 sudo amd64 1.9.5p2-3
                                E: Failed to fetch http://deb.debian.org/debian/pool/main/c/curl/libcurl4_7.74.0-1.3%2bdeb11u3_amd64.deb  Temporary failure resolving 'deb.debian.org'
                                E: Failed to fetch http://deb.debian.org/debian/pool/main/c/curl/curl_7.74.0-1.3%2bdeb11u3_amd64.deb  Temporary failure resolving 'deb.debian.org'
                                E: Failed to fetch http://deb.debian.org/debian/pool/main/s/sudo/sudo_1.9.5p2-3_amd64.deb  Temporary failure resolving 'deb.debian.org'
                                E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
                                root@iobroker-Test:~# curl libcurl4 sudo
                                -bash: curl: command not found
                                root@iobroker-Test:~# apt install curl
                                  libcurl4
                                  curl libcurl4
                                0 upgraded, 2 newly installed, 0 to remove and 0 not upgraded.
                                Need to get 615 kB of archives.
                                After this operation, 1196 kB of additional disk space will be used.
                                  sudo
                                0 upgraded, 1 newly installed, 0 to remove and 0 not upgraded.
                                Need to get 1059 kB of archives.
                                After this operation, 4699 kB of additional disk space will be used.
                                Err:1 http://deb.debian.org/debian bullseye/main amd64 sudo amd64 1.9.5p2-3
                                root@iobroker-Test:~# apt-get update
                                Err:1 http://deb.debian.org/debian bullseye InRelease
                                Err:2 http://security.debian.org bullseye-security InRelease
                                  Temporary failure resolving 'security.debian.org'
                                Err:3 http://deb.debian.org/debian bullseye-updates InRelease
                                W: Failed to fetch http://deb.debian.org/debian/dists/bullseye/InRelease  Temporary failure resolving 'deb.debian.org'
                                W: Failed to fetch http://deb.debian.org/debian/dists/bullseye-updates/InRelease  Temporary failure resolving 'deb.debian.org'
                                W: Failed to fetch http://security.debian.org/dists/bullseye-security/InRelease  Temporary failure resolving 'security.debian.org'
                                W: Some index files failed to download. They have been ignored, or old ones used instead.
                                root@iobroker-Test:~# apt update && apt upgrade
                                All packages are up to date.
                                Calculating upgrade... Done
                                0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
                                Longbow Thomas Braun 2 Replies Last reply Reply Quote 0
                                • Longbow
                                  @Thomas-Braun
                                  das war bei mir mit dem Befehl cd /opt/iobroker
                                  npm ls | grep -E 'github|ERR'
                                  cliffkirchhof@iobroker:/opt/iobroker$ npm ls | grep -E 'github|ERR'
                                  +-- eufy-security-client@2.4.0 (git+ssh://git@github.com/bropat/eufy-security-client.git#7fc2a45a75ee1bf69ced36d351d1ec6d623896f6)
                                  +-- iobroker.klf200@1.0.1 (git+ssh://git@github.com/MiSchroe/ioBroker.klf200.git#c0799c01cca44762617b9fa5e709d60a83a80f24)
                                  +-- iobroker.rtspstream@0.0.4 (git+ssh://git@github.com/dbweb-ch/ioBroker.rtspstream.git#adff9611d3ab1871cd94d2e779b9fd4fcc937353)e_text
                                    Dein Netzwerk ist kaputt.
                                    Und du möchstest nicht als root herumhampeln.
                                    • Longbow
                                      sorry, ich verstehe es leider nicht ganz, was ist kaputt der iobroker läuft, bis auf den Adapter EuSec.
                                      Thomas Braun L 2 Replies Last reply Reply Quote 0
                                        @longbow
                                        Der Server deb.debian.org kann nicht erreicht werden. Warum auch immer. Vermutlich ein Knoten in deinem Netzwerk.
                                          locito09 @Longbow last edited by
                                          @longbow
                                          Eusec hat bekanntlich Probleme mit jpeg download und disconnected, schaue auf github und /oder weiter oben lesen.
                                          Es gibt noch keine Lösung die mir bekannt ist
                                          Für nächste mal Informiere dich was für Issues offen sind für den Adapter, und bitte ein paar post weiter oben lesen, das Problem ist bekannt
                                          • Longbow
                                            @Thomas-Braun
                                            Danke für den Tipp, habe es neu gemacht, hatte ein IP Adressen Fehler.
                                            Aber jetzt geht der Adapter immer noch nicht.
                                            Skript v.2023-01-02
                                            *** BASE SYSTEM ***
                                            Docker:         false
                                            Virtualization: lxc
                                            Distributor ID: Debian
                                            Description:    Debian GNU/Linux 11 (bullseye)
                                            Release:        11
                                            Codename:       bullseye
                                            PRETTY_NAME="Debian GNU/Linux 11 (bullseye)"
                                            NAME="Debian GNU/Linux"
                                            VERSION_ID="11"
                                            VERSION="11 (bullseye)"
                                            VERSION_CODENAME=bullseye
                                            ID=debian
                                            HOME_URL="https://www.debian.org/"
                                            SUPPORT_URL="https://www.debian.org/support"
                                            BUG_REPORT_URL="https://bugs.debian.org/"
                                             19:36:02 up 11 min,  1 user,  load average: 0.33, 0.42, 0.48
                                            CPU threads: 4
                                            Thu Feb  2 18:36:02 UTC 2023
                                            Thu Feb  2 19:36:02 CET 2023
                                            CET +0100
                                            Europe/Berlin
                                            *** User and Groups ***
                                            cliffkirchhof
                                            /home/cliffkirchhof
                                            cliffkirchhof sudo iobroker
                                            X-Server:       false
                                            Desktop:
                                            Terminal:
                                            *** MEMORY ***
                                            Mem:            8.1G        492M        7.1G        0.0K        552M        7.6G
                                            Swap:           8.1G          0B        8.1G
                                            Total:           16G        492M         15G
                                                     8096 M total memory
                                                      492 M used memory
                                                      313 M active memory
                                                      665 M inactive memory
                                                     7050 M free memory
                                                        0 M buffer memory
                                                      552 M swap cache
                                                     8096 M total swap
                                                        0 M used swap
                                                     8096 M free swap
                                            *** FILESYSTEM ***
                                            /dev/mapper/pve-vm--210--disk--0 ext4       20G  2.2G   17G  12% /
                                            udev                             devtmpfs  7.8G     0  7.8G   0% /dev/tty
                                            Messages in dmesg:
                                            /      /dev/mapper/pve-vm--210--disk--0 ext4   rw,relatime,stripe=16
                                            /var:
                                            382M    /var/
                                            222M    /var/cache
                                            218M    /var/cache/apt
                                            151M    /var/cache/apt/archives
                                            135M    /var/lib
                                            4.0K    /opt/iobroker/backups/
                                            93M     /opt/iobroker/iobroker-data/
                                            86M     /opt/iobroker/iobroker-data/files
                                            32M     /opt/iobroker/iobroker-data/files/javascript.admin/static/js
                                            6.9M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/610.de0231c9.chunk.js.map
                                            6.3M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map
                                            6.0M    /opt/iobroker/iobroker-data/objects.jsonl
                                            4.9M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/848.7424922d.chunk.js.map
                                            4.6M    /opt/iobroker/iobroker-data/files/javascript.admin/vs/language/typescript/tsWorker.js
                                            /usr/bin/node           v16.19.0
                                            /usr/bin/npm            8.19.3
                                            /usr/bin/npx            8.19.3
                                            nodejs:
                                              Version table:
                                                    500 https://deb.nodesource.com/node_16.x bullseye/main amd64 Packages
                                                 12.22.12~dfsg-1~deb11u3 500
                                                    500 http://security.debian.org bullseye-security/main amd64 Packages
                                                 12.22.5~dfsg-2~11u1 500
                                                    500 http://deb.debian.org/debian bullseye/main amd64 Packages
                                            ioBroker Status
                                            Objects type: jsonl
                                            States  type: jsonl
                                            admin:          6.3.5
                                            javascript:     6.1.4
                                            Adapters from github:   1
                                            Adapter State
                                            + system.adapter.admin.0                  : admin                 : iobroker-Final                           -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                                            + system.adapter.backitup.0               : backitup              : iobroker-Final                           -  enabled
                                            + system.adapter.chromecast.0             : chromecast            : iobroker-Final                           -  enabled
                                              system.adapter.cloud.0                  : cloud                 : iobroker-Final                           - disabled
                                            + system.adapter.discovery.0              : discovery             : iobroker-Final                           -  enabled
                                            + system.adapter.history.0                : history               : iobroker-Final                           -  enabled
                                              system.adapter.hue-extended.0           : hue-extended          : iobroker-Final                           - disabled
                                              system.adapter.hue.0                    : hue                   : iobroker-Final                           - disabled, port: 443
                                            + system.adapter.javascript.0             : javascript            : iobroker-Final                           -  enabled
                                              system.adapter.sonos.0                  : sonos                 : iobroker-Final                           - disabled
                                              system.adapter.synology.0               : synology              : iobroker-Final                           - disabled, port: 5000
                                              system.adapter.synology.1               : synology              : iobroker-Final                           - disabled, port: 5000
                                              system.adapter.vis.0                    : vis                   : iobroker-Final                           -  enabled
                                            + system.adapter.web.0                    : web                   : iobroker-Final                           -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                                            + instance is alive
                                            Objects and States
                                            Objects:        545
                                            States:         464
                                            Hit:1 http://security.debian.org bullseye-security InRelease
                                            Hit:2 https://deb.nodesource.com/node_16.x bullseye InRelease
                                            Hit:3 http://deb.debian.org/debian bullseye InRelease
                                            Hit:4 http://deb.debian.org/debian bullseye-updates InRelease
                                            Pending Updates: 0
                                            *** Listening Ports ***
                                            tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          235092916  1/init
                                            tcp        0      0 0.0.0.0:5355            0.0.0.0:*               LISTEN      104        235093971  116/systemd-resolve
                                            tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          235095151  306/master
                                            tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       235094725  127/iobroker.js-con
                                            tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      104        235093977  116/systemd-resolve
                                            tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       235094718  127/iobroker.js-con
                                            tcp6       0      0 :::22                   :::*                    LISTEN      0          235095055  1/init
                                            tcp6       0      0 :::111                  :::*                    LISTEN      0          235092918  1/init
                                            tcp6       0      0 :::5355                 :::*                    LISTEN      104        235093974  116/systemd-resolve
                                            tcp6       0      0 :::8082                 :::*                    LISTEN      1001       235126555  2911/io.web.0
                                            tcp6       0      0 :::8081                 :::*                    LISTEN      1001       235112750  1107/io.admin.0
                                            tcp6       0      0 ::1:25                  :::*                    LISTEN      0          235095152  306/master
                                            udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       235096031  453/io.chromecast.0
                                            udp        0      0 0.0.0.0:5355            0.0.0.0:*                           104        235093970  116/systemd-resolve
                                            udp        0      0 127.0.0.53:53           0.0.0.0:*                           104        235093976  116/systemd-resolve
                                            udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          235092917  1/init
                                            udp6       0      0 :::5355                 :::*                                104        235093973  116/systemd-resolve
                                            udp6       0      0 :::111                  :::*                                0          235092919  1/init
                                            2023-02-02 19:31:22.989  - info: web.0 (2911) socket.io server listening on port 8082
                                            2023-02-02 19:31:22.998  - info: web.0 (2911) Connect extension "eusec/build/lib/web.js"
                                            2023-02-02 19:31:23.000  - info: web.0 (2911) http server listening on port 8082
                                            2023-02-02 19:34:25.199  - info: host.iobroker-Final iobroker del eusec.0 --debug
                                            2023-02-02 19:34:25.796  - info: host.iobroker-Final iobroker Delete instance "eusec.0"
                                            2023-02-02 19:34:25.805  - info: host.iobroker-Final iobroker host.iobroker-Final Counted 1 instances of eusec.0
                                            2023-02-02 19:34:25.812  - info: host.iobroker-Final iobroker host.iobroker-Final Counted 14 states of system.adapter.eusec.0
                                            2023-02-02 19:34:25.817  - info: host.iobroker-Final iobroker host.iobroker-Final Counted 3 states (system.adapter.eusec.0.*) from states
                                            2023-02-02 19:34:25.943  - info: host.iobroker-Final iobroker host.iobroker-Final Deleting 15 object(s).
                                            2023-02-02 19:34:25.981  - info: host.iobroker-Final object deleted system.adapter.eusec.0
                                            2023-02-02 19:34:25.982  - info: host.iobroker-Final iobroker host.iobroker-Final Deleting 3 state(s).
                                            2023-02-02 19:34:26.997  - info: host.iobroker-Final iobroker exit 0
                                            2023-02-02 19:35:24.489  - info: host.iobroker-Final iobroker del eusec --debug
                                            2023-02-02 19:35:25.022  - info: host.iobroker-Final iobroker Delete adapter "eusec"
                                            2023-02-02 19:35:25.040  - info: host.iobroker-Final iobroker host.iobroker-Final Counted 2 meta of eusec
                                            2023-02-02 19:35:25.042  - info: host.iobroker-Final iobroker host.iobroker-Final Counted 1 adapter for eusec
                                            2023-02-02 19:35:25.054  - info: host.iobroker-Final iobroker host.iobroker-Final Counted 1 states (system.adapter.eusec.*) from states
                                            2023-02-02 19:35:25.213  - info: host.iobroker-Final iobroker host.iobroker-Final file eusec.admin deleted
                                            2023-02-02 19:35:25.217  - info: host.iobroker-Final iobroker host.iobroker-Final object eusec deleted
                                            2023-02-02 19:35:25.221  - info: host.iobroker-Final iobroker host.iobroker-Final object eusec.admin deleted
                                            2023-02-02 19:35:25.221  - info: host.iobroker-Final iobroker host.iobroker-Final Deleting 3 object(s).
                                            2023-02-02 19:35:25.227  - info: host.iobroker-Final iobroker host.iobroker-Final Deleting 1 state(s).
                                            2023-02-02 19:35:28.863  - info: host.iobroker-Final iobroker removed 884 packages, and changed 1 package in 3s
                                            2023-02-02 19:35:28.863  - info: host.iobroker-Final iobroker 66 packages are looking for funding  run `npm fund` for details
                                            2023-02-02 19:35:29.892  - info: host.iobroker-Final iobroker exit 0```
                                            code_text
                                            adapter cameras doorbell eufy eufycam security
                                            160
                                            1173
                                            458026
