    3. Entwicklung
    4. lgtv Adapter zur Steuerung von LG WebOS SmartTVs
      roesthod @sigi234 last edited by
      @sigi234 Hallo, Ich habe genau das gleich Problem. Das Errorlog sieht wie folgt aus:
      2023-01-28 13:56:39.791 - debug: lgtv.0 (1414) Redis Objects: Use Redis connection: 127.0.0.1:9001
      2023-01-28 13:56:39.841 - debug: lgtv.0 (1414) Objects client ready ... initialize now
      2023-01-28 13:56:39.842 - debug: lgtv.0 (1414) Objects create System PubSub Client
      2023-01-28 13:56:39.842 - debug: lgtv.0 (1414) Objects create User PubSub Client
      2023-01-28 13:56:39.958 - debug: lgtv.0 (1414) Objects client initialize lua scripts
      2023-01-28 13:56:39.963 - debug: lgtv.0 (1414) Objects connected to redis: 127.0.0.1:9001
      2023-01-28 13:56:39.964 - silly: lgtv.0 (1414) redis psubscribe cfg.o.system.user.*
      2023-01-28 13:56:40.001 - silly: lgtv.0 (1414) redis psubscribe cfg.o.enum.*
      2023-01-28 13:56:40.004 - silly: lgtv.0 (1414) objectDB connected
      2023-01-28 13:56:40.005 - debug: lgtv.0 (1414) Redis States: Use Redis connection: 127.0.0.1:9000
      2023-01-28 13:56:40.033 - debug: lgtv.0 (1414) States create System PubSub Client
      2023-01-28 13:56:40.034 - debug: lgtv.0 (1414) States create User PubSub Client
      2023-01-28 13:56:40.090 - debug: lgtv.0 (1414) States connected to redis: 127.0.0.1:9000
      2023-01-28 13:56:40.090 - silly: lgtv.0 (1414) statesDB connected
      2023-01-28 13:56:40.474 - info: lgtv.0 (1414) starting. Version 1.1.10 in /opt/iobroker/node_modules/iobroker.lgtv, node: v16.14.0, js-controller: 4.0.23
      2023-01-28 13:56:40.496 - info: lgtv.0 (1414) Ready. Configured WebOS TV IP: 192.168.1.236
      2023-01-28 13:56:40.497 - debug: lgtv.0 (1414) adapter.config = {"ip":"192.168.1.236","mac":"XX:XX:XX:XX:37:6B","timeout":"5000","reconnect":"5000","power":true,"healthIntervall":""}
      2023-01-28 13:56:40.508 - silly: lgtv.0 (1414) States system redis pmessage system.adapter.lgtv.0.logLevel/system.adapter.lgtv.0.logLevel:{"val":"silly","ack":true,"ts":1674910600499,"q":0,"from":"system.adapter.lgtv.0","lc":1674910600499}
      2023-01-28 13:56:40.516 - debug: lgtv.0 (1414) Connecting to WebOS TV: ws://192.168.1.236:3000
      2023-01-28 13:56:40.523 - debug: lgtv.0 (1414) Error on connecting or sending command to WebOS TV: Error: socket hang up
      2023-01-28 13:56:45.523 - debug: lgtv.0 (1414) Connecting to WebOS TV: ws://192.168.1.236:3000
      2023-01-28 13:56:45.526 - debug: lgtv.0 (1414) Error on connecting or sending command to WebOS TV: Error: read ECONNRESET
      Thomas Braun sigi234 2 Replies Last reply Reply Quote 0
        Thomas Braun Most Active @roesthod last edited by
        @roesthod sagte in lgtv Adapter zur Steuerung von LG WebOS SmartTVs:
        Vom konkreten Problem abgesehen:
        Halt die Kiste auf Stand.
          sigi234 Forum Testing Most Active @roesthod last edited by
          @roesthod
          IP Richtig? Kannst du den TV via Ping erreichen?
            @sigi234 IP ist richtig und ich habe das System jetzt auf den aktuellen Stand gebracht.
              roesthod @roesthod last edited by
              @roesthod Ich habe übrigends zwei von den LG's und beide mit dem identischen Fehlerbild...
                sigi234 Forum Testing Most Active @roesthod last edited by sigi234
                Alle mit WLAN verbunden?
                Hatte auch Probleme, mit LAN hat es dann mal nach 20 versuchen funktioniert.
                https://github.com/SebastianSchultz/ioBroker.lgtv/issues/123
                  dirkhe Developer @sigi234 last edited by
                  @sigi234 Da s sieht wirklich so aus, als wenn der Adapter angepasst werden muss. Ist halt auch schwierig rauszubekommen, welcher TV dann ws und welcher wss braucht. Zur Not müsste man es einstellbar machen..
                    roesthod @dirkhe last edited by
                    @dirkhe TV's sind über LAN eingebunden...
                      dirkhe Developer @roesthod last edited by
                      @roesthod das hat mit wlan und lan wahrscheinlich nicht viel zu tun, eher das die mi der neueren firmware ein anderen websocket nutzen, wie in dem issue auf github beschrieben
                        michael_4358 @dirkhe last edited by
                        @dirkhe said in lgtv Adapter zur Steuerung von LG WebOS SmartTVs:
                        Meinst du das die .js gelöscht werden muss❓
                        Konnte das wer das Problem schon lösen?
                          dirkhe Developer @michael_4358 last edited by
                          @michael_4358 Schau mal in der oben verlinkten issue, da steht am Ende ein workaround drin, bis zur neuen Version
                            Das meinte ich 😃 gut wenn es funzt
                              liv-in-sky last edited by
                              @dirkhe
                              also ist es im moment nicht ratsam, dem update auf dem lg zuzustimmen ? und lieber warten, bis eine neue adapter version kommt
                              • Nashra
                                Nashra Most Active Forum Testing @liv-in-sky last edited by
                                @liv-in-sky sagte in lgtv Adapter zur Steuerung von LG WebOS SmartTVs:
                                @dirkhe
                                Tja, nur wenn man einen neuen LG gekauft hat (gestern) mit aktuellstem WebOS will gar nichts mehr 😞
                                Also den workearound durchgeführt und dann klappt es auch teilweise mit dem Neuen.
                                Einige Funktionen wollen zwar nicht bei mir, wie Lautstärke z.B., aber die Sender lassen
                                sich schon mal umschalten.
                                  liv-in-sky @Nashra last edited by
                                  @nashra
                                  hoffentlich wird der adapter weiter gepflegt - nutze die tv steuerung doch öfters
                                  bis jetzt habe ich das update nicht durchgeführt - den workaround muss ich mehr erstmal durchlesen
                                    A Former User @liv-in-sky last edited by
                                    @liv-in-sky
                                    hab auf Github gesehen, dass @foxriver76 ihn geforked hat, denke wenn er dazu kommt, gibt's n Release.. aber zur Zeit stehen ja wichtigere Tasks an..
                                    T 1 Reply Last reply Reply Quote 2
                                      tltm_smarthome @Guest last edited by tltm_smarthome
                                      Also ich werd da grad etwas ungeduldig.
                                      Open Source hängt leider immer an Personen die das in der Freizeit machen.
                                      Der Workaround auf Git ist gelinde gesagt "lästig" will nicht händisch Files austauschen.
                                      Wäre echt nett wenn Sebastian den Fix von Foxriver (jscontroller) und den von Setfire (SSL) integrieren würde und ein release rausgibt um es wieder zum laufen zu bekommen.
                                      Mag nicht darauf warten, dass er auch Zeit hat die neuen Funktionen einzubauen und erst dann ein neues Release zu veröffentlichen.
                                      ? arteck 2 Replies Last reply Reply Quote 0
                                        A Former User @tltm_smarthome last edited by
                                        @tltm_smarthome
                                        Auf was willst du nicht warten? Verstehe das nicht.. der Adapter laeuft unter js-controller 5.x, und man kann seine LG's damit steuern..
                                        irgendwelche Dateien tauschen muss man schon lange nicht mehr..
                                        Ansonsten, mach n Fork und entwickele selbst, Open Source hängt von der Zusammenarbeit aller ab, nicht von einem alleine! Meinst du, Commerz fixt Fehler schneller? Alter.. da biste aber ganz schön Naiv..
                                        Schau auf Git ..hier ganz runter scrollen, das ist da, wo die Maus aufhört.. 🙂
                                          1. Nicht jeder der OpenSource nützt ist gleich ein Entwickler (auch wenn ichs mal im Studium hatte)
                                          2. Mir scheint, es trotzdem, dass noch kein neuer Adapter veröffentlicht wurde (also Installation im Expertenmodus direkt von GIT)
                                          3. "runter scrollen ..." Genau diese schnippischen Antworten in der OpenSource Community sind immer sehr hilfreich!
                                          BTW überleg mit tatsächlich auf ein Kommerzielles Produkt umzusteigen; Da gibt es vl. nicht so oft neue Features, aber Fixes sind schneller, die wollen ja das ihr Produkt weiter gekauft wird.
                                          liv-in-sky amg_666 2 Replies Last reply Reply Quote 0
                                            liv-in-sky @tltm_smarthome last edited by liv-in-sky
                                            @tltm_smarthome sagte in lgtv Adapter zur Steuerung von LG WebOS SmartTVs:
                                            steht dir frei, dass zu tun - kannst uns dann ja mitteilen, welch große auswahl du hast, einen lg tv einzubinden bei den kommerz. alternativen
                                            @ilovegym sagte in lgtv Adapter zur Steuerung von LG WebOS SmartTVs:
                                            nur zum verständnis - ist der 5er kontroller pflicht ?
                                            1.0k
                                            lgtv
                                            113
                                            861
                                            312173
