    4. [Neuer Adapter] EuSec
    • Longbow
      Longbow @Thomas Braun last edited by
      Bitte:-)
      Skript v.2023-01-02
      *** BASE SYSTEM ***
      Architecture:   x86_64
      Docker:         false
      Virtualization: lxc
      Distributor ID: Ubuntu
      Description:    Ubuntu 22.04.1 LTS
      Release:        22.04
      Codename:       jammy
      PRETTY_NAME="Ubuntu 22.04.1 LTS"
      NAME="Ubuntu"
      VERSION_ID="22.04"
      VERSION="22.04.1 LTS (Jammy Jellyfish)"
      VERSION_CODENAME=jammy
      ID=ubuntu
      ID_LIKE=debian
      HOME_URL="https://www.ubuntu.com/"
      SUPPORT_URL="https://help.ubuntu.com/"
      BUG_REPORT_URL="https://bugs.launchpad.net/ubuntu/"
      PRIVACY_POLICY_URL="https://www.ubuntu.com/legal/terms-and-policies/privacy-policy"
      UBUNTU_CODENAME=jammy
      Systemuptime and Load:
      06:35:50 up 1 day, 11:41,  2 users,  load average: 0.64, 0.55, 0.43
      CPU threads: 4
      *** Time and Time Zones ***
      Wed Feb  1 06:35:50 UTC 2023
      UTC +0000
      Etc/UTC
      *** X-Server-Setup ***
      X-Server:       false
      Desktop:
      Terminal:
      *** MEMORY ***
      Mem:            8.2G        3.3G        3.6G        0.0K        1.3G        4.9G
      Swap:           512M          0B        512M
      Total:          8.7G        3.3G        4.1G
               8192 M total memory
               3272 M used memory
                568 M active memory
               3792 M inactive memory
               3584 M free memory
                  0 M buffer memory
               1335 M swap cache
                512 M total swap
                  0 M used swap
                512 M free swap
      *** FILESYSTEM ***
      Filesystem                       Type   Size  Used Avail Use% Mounted on
      /dev/mapper/pve-vm--200--disk--0 ext4    20G  7.6G   11G  42% /
      none                             tmpfs  492K  4.0K  488K   1% /dev
      tmpfs                            tmpfs  7.8G     0  7.8G   0% /dev/shm
      tmpfs                            tmpfs  3.2G   96K  3.2G   1% /run
      tmpfs                            tmpfs  5.0M     0  5.0M   0% /run/lock
      Messages in dmesg:
      dmesg: read kernel buffer failed: Operation not permitted
      Show mounted filesystems (real ones only):
      TARGET SOURCE                           FSTYPE OPTIONS
      /      /dev/mapper/pve-vm--200--disk--0 ext4   rw,relatime,stripe=16
      /var:
      2.6G    /var/
      2.0G    /var/log/journal/678b65fc11864452957ca5b3828797d4
      2.0G    /var/log
      331M    /var/cache
      /opt/iobroker/backups:
      495M    /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      583M    /opt/iobroker/iobroker-data/
      365M    /opt/iobroker/iobroker-data/files
      74M     /opt/iobroker/iobroker-data/backup-objects
      72M     /opt/iobroker/iobroker-data/files/telegram.admin
      51M     /opt/iobroker/iobroker-data/files/javascript.admin
      46M     /opt/iobroker/iobroker-data/states.jsonl
      34M     /opt/iobroker/iobroker-data/objects.jsonl
      19M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.904d455f.js.map
      15M     /opt/iobroker/iobroker-data/files/vis.0/Iobroker/vis-views.json
      15M     /opt/iobroker/iobroker-data/files/telegram.admin/rules/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_d_ts-node_modules_io-1d9f06.44fe4a3f.chunk.js.map
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v16.19.0
      /root/.nvm/versions/node/v16.18.0/bin/node              v16.18.0
      /root/.nvm/versions/node/v16.18.0/bin/npm               9.4.0
      /root/.nvm/versions/node/v16.18.0/bin/npx               9.4.0
      nodejs:
        Installed: 16.19.0-deb-1nodesource1
        Candidate: 16.19.0-deb-1nodesource1
        Version table:
      *** 16.19.0-deb-1nodesource1 500
              500 https://deb.nodesource.com/node_16.x jammy/main amd64 Packages
              100 /var/lib/dpkg/status
           12.22.9~dfsg-1ubuntu3 500
              500 http://archive.ubuntu.com/ubuntu jammy/universe amd64 Packages
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Core adapters versions
      js-controller:  4.0.24
      admin:          6.3.5
      javascript:     6.1.4
      Adapters from github:   3
      Adapter State
      + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
        system.adapter.apple-find-me.0          : apple-find-me         : iobroker                                 - disabled
      + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
        system.adapter.birthdays.0              : birthdays             : iobroker                                 - disabled
      + system.adapter.chromecast.0             : chromecast            : iobroker                                 -  enabled
      + system.adapter.cloud.0                  : cloud                 : iobroker                                 -  enabled
        system.adapter.daswetter.0              : daswetter             : iobroker                                 -  enabled
      + system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
        system.adapter.dwd.0                    : dwd                   : iobroker                                 -  enabled
      + system.adapter.echarts.0                : echarts               : iobroker                                 -  enabled
      + system.adapter.email.0                  : email                 : iobroker                                 -  enabled
        system.adapter.eusec.0                  : eusec                 : iobroker                                 -  enabled
      + system.adapter.fb-checkpresence.0       : fb-checkpresence      : iobroker                                 -  enabled
        system.adapter.feiertage.0              : feiertage             : iobroker                                 -  enabled
        system.adapter.flot.0                   : flot                  : iobroker                                 -  enabled
      + system.adapter.followthesun.0           : followthesun          : iobroker                                 -  enabled
      + system.adapter.geofency.0               : geofency              : iobroker                                 -  enabled, port: 7999, bind: 0.0.0.0
      + system.adapter.history.0                : history               : iobroker                                 -  enabled
      + system.adapter.hm-rega.0                : hm-rega               : iobroker                                 -  enabled
      + system.adapter.hm-rpc.0                 : hm-rpc                : iobroker                                 -  enabled, port: 0
      + system.adapter.homeconnect.0            : homeconnect           : iobroker                                 -  enabled
        system.adapter.hue-extended.0           : hue-extended          : iobroker                                 - disabled
      + system.adapter.hue.0                    : hue                   : iobroker                                 -  enabled, port: 443
        system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
        system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: iobroker                                 -  enabled
        system.adapter.icons-material-png.0     : icons-material-png    : iobroker                                 -  enabled
        system.adapter.icons-material-svg.0     : icons-material-svg    : iobroker                                 -  enabled
        system.adapter.icons-mfd-png.0          : icons-mfd-png         : iobroker                                 -  enabled
        system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobroker                                 -  enabled
        system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : iobroker                                 -  enabled
      + system.adapter.influxdb.0               : influxdb              : iobroker                                 -  enabled, port: 8086
      + system.adapter.info.0                   : info                  : iobroker                                 -  enabled
      + system.adapter.iot.0                    : iot                   : iobroker                                 -  enabled
      + system.adapter.jarvis.0                 : jarvis                : iobroker                                 -  enabled
      + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
        system.adapter.klf200.0                 : klf200                : iobroker                                 - disabled
      + system.adapter.mihome-vacuum.0          : mihome-vacuum         : iobroker                                 -  enabled, port: 54321
        system.adapter.mobile.0                 : mobile                : iobroker                                 - disabled
      + system.adapter.modbus.0                 : modbus                : iobroker                                 -  enabled
      + system.adapter.netatmo.0                : netatmo               : iobroker                                 -  enabled
      + system.adapter.nina.0                   : nina                  : iobroker                                 -  enabled
      + system.adapter.nuki-extended.0          : nuki-extended         : iobroker                                 -  enabled
        system.adapter.openweathermap.0         : openweathermap        : iobroker                                 -  enabled
        system.adapter.operating-hours.0        : operating-hours       : iobroker                                 - disabled
        system.adapter.parcel.0                 : parcel                : iobroker                                 - disabled
        system.adapter.parser.0                 : parser                : iobroker                                 - disabled
        system.adapter.places.0                 : places                : iobroker                                 - disabled
      + system.adapter.pollenflug.0             : pollenflug            : iobroker                                 -  enabled
      + system.adapter.proxmox.0                : proxmox               : iobroker                                 -  enabled, port: 8006
      + system.adapter.pvforecast.0             : pvforecast            : iobroker                                 -  enabled
        system.adapter.rtspstream.0             : rtspstream            : iobroker                                 -  enabled
      + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1882, bind: 0.0.0.0
      + system.adapter.smartgarden.0            : smartgarden           : iobroker                                 -  enabled
      + system.adapter.smartthings.0            : smartthings           : iobroker                                 -  enabled
      + system.adapter.sonos.0                  : sonos                 : iobroker                                 -  enabled
      + system.adapter.synology.0               : synology              : iobroker                                 -  enabled, port: 5000
      + system.adapter.synology.1               : synology              : iobroker                                 -  enabled, port: 5000
      + system.adapter.tankerkoenig.0           : tankerkoenig          : iobroker                                 -  enabled
        system.adapter.telegram.0               : telegram              : iobroker                                 - disabled, port: 8443, bind: 0.0.0.0
      + system.adapter.tr-064.0                 : tr-064                : iobroker                                 -  enabled
      + system.adapter.tr-064.1                 : tr-064                : iobroker                                 -  enabled
      + system.adapter.trashschedule.0          : trashschedule         : iobroker                                 -  enabled
      + system.adapter.tuya.0                   : tuya                  : iobroker                                 -  enabled
        system.adapter.unifi.0                  : unifi                 : iobroker                                 - disabled
      + system.adapter.upnp.0                   : upnp                  : iobroker                                 -  enabled
        system.adapter.vis-bars.0               : vis-bars              : iobroker                                 -  enabled
        system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : iobroker                                 -  enabled
        system.adapter.vis-colorpicker.0        : vis-colorpicker       : iobroker                                 -  enabled
        system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : iobroker                                 -  enabled
        system.adapter.vis-google-fonts.0       : vis-google-fonts      : iobroker                                 -  enabled
        system.adapter.vis-history.0            : vis-history           : iobroker                                 -  enabled
        system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 -  enabled
        system.adapter.vis-icontwo.0            : vis-icontwo           : iobroker                                 -  enabled
      + system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker                                 -  enabled
        system.adapter.vis-material-advanced.0  : vis-material-advanced : iobroker                                 -  enabled
        system.adapter.vis-rgraph.0             : vis-rgraph            : iobroker                                 -  enabled
        system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 -  enabled
        system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
      + system.adapter.vw-connect.0             : vw-connect            : iobroker                                 -  enabled
      + system.adapter.vw-connect.1             : vw-connect            : iobroker                                 -  enabled
        system.adapter.weatherunderground.0     : weatherunderground    : iobroker                                 -  enabled
      + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      + system.adapter.wolf-smartset.0          : wolf-smartset         : iobroker                                 -  enabled
      + system.adapter.wolf.0                   : wolf                  : iobroker                                 -  enabled, port: 12004, bind: 192.168.178.200
        system.adapter.youtube.0                : youtube               : iobroker                                 - disabled
        system.adapter.yr.0                     : yr                    : iobroker                                 -  enabled
      + instance is alive
      ioBroker-Repositories
      Active repo(s): stable
      Installed ioBroker-Instances
      Used repository: stable
      Adapter    "admin"        : 6.3.5    , installed 6.3.5
      Adapter    "alpha-ess"    : 0.2.0    , installed 0.2.0
      Adapter    "apple-find-me": 0.0.14   , installed 0.0.14
      Adapter    "backitup"     : 2.5.10   , installed 2.5.10
      Adapter    "birthdays"    : 2.2.0    , installed 2.2.0
      Adapter    "chromecast"   : 2.3.1    , installed 2.3.1
      Adapter    "cloud"        : 4.3.0    , installed 4.3.0
      Adapter    "daswetter"    : 3.1.4    , installed 3.1.4
      Adapter    "device-reminder": 1.2.9  , installed 1.2.9
      Adapter    "discovery"    : 3.1.0    , installed 3.1.0
      Adapter    "dwd"          : 2.8.3    , installed 2.8.3
      Adapter    "echarts"      : 1.0.12   , installed 1.0.12
      Adapter    "email"        : 1.1.4    , installed 1.1.4
      Adapter    "eusec"        : 0.9.9    , installed 0.9.9
      Adapter    "fb-checkpresence": 1.1.20, installed 1.1.20
      Adapter    "feiertage"    : 1.1.0    , installed 1.1.0
      Adapter    "flot"         : 1.11.0   , installed 1.11.0
      Adapter    "followthesun" : 0.4.0    , installed 0.4.0
      Adapter    "geofency"     : 1.2.4    , installed 1.2.4
      Adapter    "hid-community": 0.3.0    , installed 0.3.0
      Adapter    "history"      : 2.2.4    , installed 2.2.4
      Adapter    "hm-rega"      : 3.0.40   , installed 3.0.40
      Adapter    "hm-rpc"       : 1.15.16  , installed 1.15.16
      Adapter    "homeconnect"  : 1.1.1    , installed 1.1.1
      Adapter    "hue"          : 3.7.1    , installed 3.7.1
      Adapter    "hue-extended" : 2.0.0    , installed 2.0.0
      Adapter    "ical"         : 1.13.2   , installed 1.13.2
      Adapter    "icons-material-svg": 0.1.0, installed 0.1.0
      Adapter    "icons-mfd-png": 1.1.0    , installed 1.1.0
      Adapter    "influxdb"     : 3.2.0    , installed 3.2.0
      Adapter    "info"         : 1.9.19   , installed 1.9.19
      Adapter    "iot"          : 1.14.2   , installed 1.14.2
      Adapter    "jarvis"       : 3.1.2    , installed 3.1.2
      Adapter    "javascript"   : 6.1.4    , installed 6.1.4
      Controller "js-controller": 4.0.24   , installed 4.0.24
      Adapter    "klf200"       : 1.0.1    , installed 1.0.1
      Adapter    "mclighting"   : 0.1.2    , installed 0.1.2
      Adapter    "mihome"       : 1.4.0    , installed 1.4.0
      Adapter    "mihome-vacuum": 3.8.8    , installed 3.8.8
      Adapter    "mobile"       : 1.0.1    , installed 1.0.1
      Adapter    "modbus"       : 5.0.11   , installed 5.0.11
      Adapter    "netatmo"      : 2.0.5    , installed 2.0.5
      Adapter    "nina"         : 0.0.25   , installed 0.0.25
      Adapter    "nuki-extended": 2.3.1    , installed 2.3.1
      Adapter    "openweathermap": 0.3.3   , installed 0.3.3
      Adapter    "operating-hours": 0.0.19 , installed 0.0.19
      Adapter    "parcel"       : 0.0.23   , installed 0.0.23
      Adapter    "parser"       : 1.1.8    , installed 1.1.8
      Adapter    "places"       : 1.1.2    , installed 1.1.2
      Adapter    "pollenflug"   : 1.0.6    , installed 1.0.6
      Adapter    "proxmox"      : 1.3.4    , installed 1.3.4
      Adapter    "pvforecast"   : 2.3.0    , installed 2.3.0
      Adapter    "shelly"       : 6.3.1    , installed 6.3.1
      Adapter    "smartgarden"  : 2.0.0    , installed 2.0.0
      Adapter    "smartthings"  : 0.0.4    , installed 0.0.4
      Adapter    "sonos"        : 2.2.3    , installed 2.2.3
      Adapter    "synology"     : 2.1.13   , installed 2.1.13
      Adapter    "tankerkoenig" : 3.3.6    , installed 3.3.6
      Adapter    "telegram"     : 1.15.2   , installed 1.15.2
      Adapter    "tr-064"       : 4.2.17   , installed 4.2.17
      Adapter    "trashschedule": 2.2.0    , installed 2.2.0
      Adapter    "tuya"         : 3.13.1   , installed 3.13.1
      Adapter    "tvprogram"    : 1.1.2    , installed 1.1.2
      Adapter    "unifi"        : 0.5.10   , installed 0.5.10
      Adapter    "upnp"         : 1.0.21   , installed 1.0.21
      Adapter    "vis"          : 1.4.15   , installed 1.4.15
      Adapter    "vis-colorpicker": 1.2.0  , installed 1.2.0
      Adapter    "vis-hqwidgets": 1.3.0    , installed 1.3.0
      Adapter    "vis-icontwo"  : 0.90.0   , installed 0.90.0
      Adapter    "vis-inventwo" : 3.3.1    , installed 3.3.1
      Adapter    "vis-material-advanced": 1.7.2, installed 1.7.2
      Adapter    "vw-connect"   : 0.0.56   , installed 0.0.56
      Adapter    "weatherunderground": 3.4.2, installed 3.4.2
      Adapter    "wolf"         : 1.5.0    , installed 1.5.0
      Adapter    "wolf-smartset": 1.0.0    , installed 1.0.0
      Adapter    "youtube"      : 4.1.0    , installed 4.1.0
      Adapter    "yr"           : 5.3.0    , installed 5.3.0
      Objects and States
      Objects:        51213
      States:         41765
      Hit:1 https://deb.nodesource.com/node_16.x jammy InRelease
        Thomas Braun Most Active @Longbow last edited by
        @longbow
        Zeitzone setzen und nodejs gescheit installieren.
        Longbow 1 Reply Last reply Reply Quote 0
        • Longbow
          wie mache ich das bitte, bin neu Neuling auf dem Gebiet ioborker...
            Thomas Braun Most Active @Longbow last edited by Thomas Braun
            @longbow
            Das hat mit iobroker nix zu tun, das hat damit zu tun wie du deinen Container administrierst. Mit den Dingern hab ich aber nix mit am Hut.
            Schau in die Anleitung, vielleicht steht da was drin:
            https://www.iobroker.net/#de/documentation/install/proxmox.md
            Zur NodeJS-Installation:
            Wo stand denn, das man nodejs als root per nvm installiert?
            Das ist nämlich Murks.
            • Longbow
              wie kann ich das mit dem nodejs beheben? Oder ist es besser das man Iobroker neu installiert?
                @longbow sagte in [Neuer Adapter] EuSec:
                Schau in meiner Signatur, da wird das mit den falschen Pfaden bei nodejs erklärt.
                  lustig29 @Thomas Braun last edited by
                  @thomas-braun Kannst du mir auch bei meinem Problem vom Post weiter oben helfen?
                    Thomas Braun Most Active @lustig29 last edited by
                    @lustig29
                    Bei welchem?
                      @thomas-braun Seit geraumer Zeit läuft der Adapter nicht mehr richtig. Die Verbindung wird immer wieder getrennt und wieder hergestellt. Hatte sowas schon mal jemand?
                      eusec.0
                      2023-01-29 11:24:22.280	info	Connected to station T8010P23220312FE on host 192.168.0.70 and port 22316
                      eusec.0
                      2023-01-29 11:24:17.255	info	Disconnected from station T8010P23220312FE
                        Thomas Braun Most Active @lustig29 last edited by Thomas Braun
                        @lustig29 sagte in [Neuer Adapter] EuSec:
                        Nein. Keine Ahnung.
                        Ist halt auch was dünn, so'n Zweizeiler.
                        • Longbow
                          guten Morgen, habe es alles gemacht wie es dort beschrieben ist, eine Abhilfe hat es leider nicht gebracht.
                          Hab ein neues System nach den Anleitungen gemacht.
                          Habe es mit auch alles angeschaut mit Nodejs, aber ich bekomme nur Fehlermeldungen. Der Adpater bleibt ohne Daten und Verbindung rot
                          Debian GNU/Linux 11 iobroker-Test tty1
                          iobroker-Test login: root
                          Password:
                          Linux iobroker-Test 5.15.30-2-pve #1 SMP PVE 5.15.30-3 (Fri, 22 Apr 2022 18:08:27 +0200) x86_64
                          The programs included with the Debian GNU/Linux system are free software;
                          the exact distribution terms for each program are described in the
                          individual files in /usr/share/doc/*/copyright.
                          Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
                          permitted by applicable law.
                          Last login: Thu Feb  2 08:28:34 CET 2023 on tty1
                          root@iobroker-Test:~# apt install sudo curl
                          Reading package lists... Done
                          Building dependency tree... Done
                          The following additional packages will be installed:
                            libcurl4
                          The following NEW packages will be installed:
                            curl libcurl4 sudo
                          0 upgraded, 3 newly installed, 0 to remove and 0 not upgraded.
                          Need to get 1673 kB of archives.
                          After this operation, 5895 kB of additional disk space will be used.
                          Do you want to continue? [Y/n] y
                          Err:1 http://deb.debian.org/debian bullseye/main amd64 libcurl4 amd64 7.74.0-1.3+deb11u3
                            Temporary failure resolving 'deb.debian.org'
                          Err:2 http://deb.debian.org/debian bullseye/main amd64 curl amd64 7.74.0-1.3+deb11u3
                          Err:3 http://deb.debian.org/debian bullseye/main amd64 sudo amd64 1.9.5p2-3
                          E: Failed to fetch http://deb.debian.org/debian/pool/main/c/curl/libcurl4_7.74.0-1.3%2bdeb11u3_amd64.deb  Temporary failure resolving 'deb.debian.org'
                          E: Failed to fetch http://deb.debian.org/debian/pool/main/c/curl/curl_7.74.0-1.3%2bdeb11u3_amd64.deb  Temporary failure resolving 'deb.debian.org'
                          E: Failed to fetch http://deb.debian.org/debian/pool/main/s/sudo/sudo_1.9.5p2-3_amd64.deb  Temporary failure resolving 'deb.debian.org'
                          E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
                          root@iobroker-Test:~# curl libcurl4 sudo
                          -bash: curl: command not found
                          root@iobroker-Test:~# apt install curl
                            libcurl4
                            curl libcurl4
                          0 upgraded, 2 newly installed, 0 to remove and 0 not upgraded.
                          Need to get 615 kB of archives.
                          After this operation, 1196 kB of additional disk space will be used.
                            sudo
                          0 upgraded, 1 newly installed, 0 to remove and 0 not upgraded.
                          Need to get 1059 kB of archives.
                          After this operation, 4699 kB of additional disk space will be used.
                          Err:1 http://deb.debian.org/debian bullseye/main amd64 sudo amd64 1.9.5p2-3
                          root@iobroker-Test:~# apt-get update
                          Err:1 http://deb.debian.org/debian bullseye InRelease
                          Err:2 http://security.debian.org bullseye-security InRelease
                            Temporary failure resolving 'security.debian.org'
                          Err:3 http://deb.debian.org/debian bullseye-updates InRelease
                          W: Failed to fetch http://deb.debian.org/debian/dists/bullseye/InRelease  Temporary failure resolving 'deb.debian.org'
                          W: Failed to fetch http://deb.debian.org/debian/dists/bullseye-updates/InRelease  Temporary failure resolving 'deb.debian.org'
                          W: Failed to fetch http://security.debian.org/dists/bullseye-security/InRelease  Temporary failure resolving 'security.debian.org'
                          W: Some index files failed to download. They have been ignored, or old ones used instead.
                          root@iobroker-Test:~# apt update && apt upgrade
                          All packages are up to date.
                          Calculating upgrade... Done
                          0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
                          Longbow Thomas Braun 2 Replies Last reply Reply Quote 0
                          • Longbow
                            Longbow @Longbow last edited by
                            @Thomas-Braun
                            das war bei mir mit dem Befehl cd /opt/iobroker
                            npm ls | grep -E 'github|ERR'
                            cliffkirchhof@iobroker:/opt/iobroker$ npm ls | grep -E 'github|ERR'
                            +-- eufy-security-client@2.4.0 (git+ssh://git@github.com/bropat/eufy-security-client.git#7fc2a45a75ee1bf69ced36d351d1ec6d623896f6)
                            +-- iobroker.klf200@1.0.1 (git+ssh://git@github.com/MiSchroe/ioBroker.klf200.git#c0799c01cca44762617b9fa5e709d60a83a80f24)
                            +-- iobroker.rtspstream@0.0.4 (git+ssh://git@github.com/dbweb-ch/ioBroker.rtspstream.git#adff9611d3ab1871cd94d2e779b9fd4fcc937353)e_text
                              Dein Netzwerk ist kaputt.
                              Und du möchstest nicht als root herumhampeln.
                              • Longbow
                                sorry, ich verstehe es leider nicht ganz, was ist kaputt der iobroker läuft, bis auf den Adapter EuSec.
                                Thomas Braun L 2 Replies Last reply Reply Quote 0
                                  @longbow
                                  Der Server deb.debian.org kann nicht erreicht werden. Warum auch immer. Vermutlich ein Knoten in deinem Netzwerk.
                                    locito09 @Longbow last edited by
                                    @longbow
                                    Eusec hat bekanntlich Probleme mit jpeg download und disconnected, schaue auf github und /oder weiter oben lesen.
                                    Es gibt noch keine Lösung die mir bekannt ist
                                    Für nächste mal Informiere dich was für Issues offen sind für den Adapter, und bitte ein paar post weiter oben lesen, das Problem ist bekannt
                                    • Longbow
                                      @Thomas-Braun
                                      Danke für den Tipp, habe es neu gemacht, hatte ein IP Adressen Fehler.
                                      Aber jetzt geht der Adapter immer noch nicht.
                                      Skript v.2023-01-02
                                      *** BASE SYSTEM ***
                                      Docker:         false
                                      Virtualization: lxc
                                      Distributor ID: Debian
                                      Description:    Debian GNU/Linux 11 (bullseye)
                                      Release:        11
                                      Codename:       bullseye
                                      PRETTY_NAME="Debian GNU/Linux 11 (bullseye)"
                                      NAME="Debian GNU/Linux"
                                      VERSION_ID="11"
                                      VERSION="11 (bullseye)"
                                      VERSION_CODENAME=bullseye
                                      ID=debian
                                      HOME_URL="https://www.debian.org/"
                                      SUPPORT_URL="https://www.debian.org/support"
                                      BUG_REPORT_URL="https://bugs.debian.org/"
                                       19:36:02 up 11 min,  1 user,  load average: 0.33, 0.42, 0.48
                                      CPU threads: 4
                                      Thu Feb  2 18:36:02 UTC 2023
                                      Thu Feb  2 19:36:02 CET 2023
                                      CET +0100
                                      Europe/Berlin
                                      *** User and Groups ***
                                      cliffkirchhof
                                      /home/cliffkirchhof
                                      cliffkirchhof sudo iobroker
                                      X-Server:       false
                                      Desktop:
                                      Terminal:
                                      *** MEMORY ***
                                      Mem:            8.1G        492M        7.1G        0.0K        552M        7.6G
                                      Swap:           8.1G          0B        8.1G
                                      Total:           16G        492M         15G
                                               8096 M total memory
                                                492 M used memory
                                                313 M active memory
                                                665 M inactive memory
                                               7050 M free memory
                                                  0 M buffer memory
                                                552 M swap cache
                                               8096 M total swap
                                                  0 M used swap
                                               8096 M free swap
                                      *** FILESYSTEM ***
                                      /dev/mapper/pve-vm--210--disk--0 ext4       20G  2.2G   17G  12% /
                                      udev                             devtmpfs  7.8G     0  7.8G   0% /dev/tty
                                      Messages in dmesg:
                                      /      /dev/mapper/pve-vm--210--disk--0 ext4   rw,relatime,stripe=16
                                      /var:
                                      382M    /var/
                                      222M    /var/cache
                                      218M    /var/cache/apt
                                      151M    /var/cache/apt/archives
                                      135M    /var/lib
                                      4.0K    /opt/iobroker/backups/
                                      93M     /opt/iobroker/iobroker-data/
                                      86M     /opt/iobroker/iobroker-data/files
                                      32M     /opt/iobroker/iobroker-data/files/javascript.admin/static/js
                                      6.9M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/610.de0231c9.chunk.js.map
                                      6.3M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map
                                      6.0M    /opt/iobroker/iobroker-data/objects.jsonl
                                      4.9M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/848.7424922d.chunk.js.map
                                      4.6M    /opt/iobroker/iobroker-data/files/javascript.admin/vs/language/typescript/tsWorker.js
                                      /usr/bin/node           v16.19.0
                                      /usr/bin/npm            8.19.3
                                      /usr/bin/npx            8.19.3
                                      nodejs:
                                        Version table:
                                              500 https://deb.nodesource.com/node_16.x bullseye/main amd64 Packages
                                           12.22.12~dfsg-1~deb11u3 500
                                              500 http://security.debian.org bullseye-security/main amd64 Packages
                                           12.22.5~dfsg-2~11u1 500
                                              500 http://deb.debian.org/debian bullseye/main amd64 Packages
                                      ioBroker Status
                                      Objects type: jsonl
                                      States  type: jsonl
                                      admin:          6.3.5
                                      javascript:     6.1.4
                                      Adapters from github:   1
                                      Adapter State
                                      + system.adapter.admin.0                  : admin                 : iobroker-Final                           -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                                      + system.adapter.backitup.0               : backitup              : iobroker-Final                           -  enabled
                                      + system.adapter.chromecast.0             : chromecast            : iobroker-Final                           -  enabled
                                        system.adapter.cloud.0                  : cloud                 : iobroker-Final                           - disabled
                                      + system.adapter.discovery.0              : discovery             : iobroker-Final                           -  enabled
                                      + system.adapter.history.0                : history               : iobroker-Final                           -  enabled
                                        system.adapter.hue-extended.0           : hue-extended          : iobroker-Final                           - disabled
                                        system.adapter.hue.0                    : hue                   : iobroker-Final                           - disabled, port: 443
                                      + system.adapter.javascript.0             : javascript            : iobroker-Final                           -  enabled
                                        system.adapter.sonos.0                  : sonos                 : iobroker-Final                           - disabled
                                        system.adapter.synology.0               : synology              : iobroker-Final                           - disabled, port: 5000
                                        system.adapter.synology.1               : synology              : iobroker-Final                           - disabled, port: 5000
                                        system.adapter.vis.0                    : vis                   : iobroker-Final                           -  enabled
                                      + system.adapter.web.0                    : web                   : iobroker-Final                           -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                                      + instance is alive
                                      Objects and States
                                      Objects:        545
                                      States:         464
                                      Hit:1 http://security.debian.org bullseye-security InRelease
                                      Hit:2 https://deb.nodesource.com/node_16.x bullseye InRelease
                                      Hit:3 http://deb.debian.org/debian bullseye InRelease
                                      Hit:4 http://deb.debian.org/debian bullseye-updates InRelease
                                      Pending Updates: 0
                                      *** Listening Ports ***
                                      tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          235092916  1/init
                                      tcp        0      0 0.0.0.0:5355            0.0.0.0:*               LISTEN      104        235093971  116/systemd-resolve
                                      tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          235095151  306/master
                                      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       235094725  127/iobroker.js-con
                                      tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      104        235093977  116/systemd-resolve
                                      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       235094718  127/iobroker.js-con
                                      tcp6       0      0 :::22                   :::*                    LISTEN      0          235095055  1/init
                                      tcp6       0      0 :::111                  :::*                    LISTEN      0          235092918  1/init
                                      tcp6       0      0 :::5355                 :::*                    LISTEN      104        235093974  116/systemd-resolve
                                      tcp6       0      0 :::8082                 :::*                    LISTEN      1001       235126555  2911/io.web.0
                                      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       235112750  1107/io.admin.0
                                      tcp6       0      0 ::1:25                  :::*                    LISTEN      0          235095152  306/master
                                      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       235096031  453/io.chromecast.0
                                      udp        0      0 0.0.0.0:5355            0.0.0.0:*                           104        235093970  116/systemd-resolve
                                      udp        0      0 127.0.0.53:53           0.0.0.0:*                           104        235093976  116/systemd-resolve
                                      udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          235092917  1/init
                                      udp6       0      0 :::5355                 :::*                                104        235093973  116/systemd-resolve
                                      udp6       0      0 :::111                  :::*                                0          235092919  1/init
                                      2023-02-02 19:31:22.989  - info: web.0 (2911) socket.io server listening on port 8082
                                      2023-02-02 19:31:22.998  - info: web.0 (2911) Connect extension "eusec/build/lib/web.js"
                                      2023-02-02 19:31:23.000  - info: web.0 (2911) http server listening on port 8082
                                      2023-02-02 19:34:25.199  - info: host.iobroker-Final iobroker del eusec.0 --debug
                                      2023-02-02 19:34:25.796  - info: host.iobroker-Final iobroker Delete instance "eusec.0"
                                      2023-02-02 19:34:25.805  - info: host.iobroker-Final iobroker host.iobroker-Final Counted 1 instances of eusec.0
                                      2023-02-02 19:34:25.812  - info: host.iobroker-Final iobroker host.iobroker-Final Counted 14 states of system.adapter.eusec.0
                                      2023-02-02 19:34:25.817  - info: host.iobroker-Final iobroker host.iobroker-Final Counted 3 states (system.adapter.eusec.0.*) from states
                                      2023-02-02 19:34:25.943  - info: host.iobroker-Final iobroker host.iobroker-Final Deleting 15 object(s).
                                      2023-02-02 19:34:25.981  - info: host.iobroker-Final object deleted system.adapter.eusec.0
                                      2023-02-02 19:34:25.982  - info: host.iobroker-Final iobroker host.iobroker-Final Deleting 3 state(s).
                                      2023-02-02 19:34:26.997  - info: host.iobroker-Final iobroker exit 0
                                      2023-02-02 19:35:24.489  - info: host.iobroker-Final iobroker del eusec --debug
                                      2023-02-02 19:35:25.022  - info: host.iobroker-Final iobroker Delete adapter "eusec"
                                      2023-02-02 19:35:25.040  - info: host.iobroker-Final iobroker host.iobroker-Final Counted 2 meta of eusec
                                      2023-02-02 19:35:25.042  - info: host.iobroker-Final iobroker host.iobroker-Final Counted 1 adapter for eusec
                                      2023-02-02 19:35:25.054  - info: host.iobroker-Final iobroker host.iobroker-Final Counted 1 states (system.adapter.eusec.*) from states
                                      2023-02-02 19:35:25.213  - info: host.iobroker-Final iobroker host.iobroker-Final file eusec.admin deleted
                                      2023-02-02 19:35:25.217  - info: host.iobroker-Final iobroker host.iobroker-Final object eusec deleted
                                      2023-02-02 19:35:25.221  - info: host.iobroker-Final iobroker host.iobroker-Final object eusec.admin deleted
                                      2023-02-02 19:35:25.221  - info: host.iobroker-Final iobroker host.iobroker-Final Deleting 3 object(s).
                                      2023-02-02 19:35:25.227  - info: host.iobroker-Final iobroker host.iobroker-Final Deleting 1 state(s).
                                      2023-02-02 19:35:28.863  - info: host.iobroker-Final iobroker removed 884 packages, and changed 1 package in 3s
                                      2023-02-02 19:35:28.863  - info: host.iobroker-Final iobroker 66 packages are looking for funding  run `npm fund` for details
                                      2023-02-02 19:35:29.892  - info: host.iobroker-Final iobroker exit 0```
                                      code_text
                                      • Longbow
                                        Gibt es was neues, der Adapter bleibt rot, wie schon berichtet. der neu aufgesetzte ioborker läuft super.
                                          @longbow
                                          Hier nix neues. Bei dir?
                                          • Fabio
                                            Fabio @bropat last edited by Fabio
                                            @bropat falls jemand von euch die neue Homebase drei hat von Eufy, der könnte wenn er mag, seine Haustüre mit der Gesichtserkennung die die Homebase liefert öffnen.
                                            der Kamera, die an der Homebase 3 hängt Person name der dann aktualisiert wird wenn eine bekannte Person erkannt wird, zum Beipiel über ein kleines Blockly die Haustüre aufschließen zum Beispiel mit dem Nukischloss.
                                            Vorraussetzung ist das ihr bekannte Gesichter in der Eufy App hinzufügen müßt, plus der Namensvergabe. Das Eufy System lernt immer mehr dazu und um so mehr Bilder ihr von euch oder Partner etc. in der Homebase sprich App freigebt um so schneller arbeitet es.
                                            Bei mir läuft das schon seit drei Wochen mehr oder weniger perfeckt. Das Problem ist wenn die Kameras die Person nicht beim ersten mal erkannt hat passiert natürlich bis zur nächsten Erkennung nix und ihr steht dann wie der Och·se vor der Tür. 😊
                                            Wollte es euch nur mal mitteilen Spass mach das schon. 😉
                                            Ihr braucht aber auf jeden Fall die neue Homebase, die alten Kameras zum Beispiel C2 Doorbell etc. laufen auch mit ihr, müssen aber an die neue Homebase angelernt werden und natürlich ein Smartes Türschloss.
                                            Fabio
                                            adapter cameras doorbell eufy eufycam security
                                            160
                                            1173
                                            457962
