Growatt exception: Error: {"result":3}
@nobbiman
Ja, bei mir ist die allerdings leer.
Warum läuft denn bei dir der Service nicht?
Sollte eigentlich so aussehen:Last login: Wed Feb 1 15:51:10 2023 from 100.75.198.95 echad@chet:~ $ systemctl status systemd-timesyncd.service ● systemd-timesyncd.service - Network Time Synchronization Loaded: loaded (/lib/systemd/system/systemd-timesyncd.ser> Active: active (running) since Thu 2023-01-26 19:00:34 CE> Docs: man:systemd-timesyncd.service(8) Main PID: 362 (systemd-timesyn) Status: "Initial synchronization to time server [2a03:400> Tasks: 2 (limit: 9037) CPU: 1.605s CGroup: /system.slice/systemd-timesyncd.service └─362 /lib/systemd/systemd-timesyncd Jan 26 19:00:34 chet systemd[1]: Starting Network Time Synchro>Jan 26 19:00:34 chet systemd[1]: Started Network Time Synchron>Jan 26 19:01:19 chet systemd-timesyncd[362]: Initial synchroni>lines 1-14/14 (END)
@thomas-braun Wenn ich das wüsste, muss mich aber für heute aus dem Forum ausklinken - morgen mehr! Danke bis hier hin!
sudo apt update Hit:1 http://deb.debian.org/debian bullseye InRelease Get:2 http://deb.debian.org/debian bullseye-updates InRelease [44.1 kB] Get:3 http://security.debian.org/debian-security bullseye-security InRelease [48.4 kB] Get:4 http://ftp.debian.org/debian bullseye-backports InRelease [49.0 kB] Hit:5 http://archive.raspberrypi.org/debian bullseye InRelease Hit:6 https://deb.nodesource.com/node_16.x bullseye InRelease Hit:7 https://www.debmatic.de/debmatic stable InRelease Reading package lists... Done E: Release file for http://deb.debian.org/debian/dists/bullseye-updates/InRelease is not valid yet (invalid for another 2min 50s). Updates for this repository will not be applied. E: Release file for http://ftp.debian.org/debian/dists/bullseye-backports/InRelease is not valid yet (invalid for another 2min 50s). Updates for this repository will not be applied.
pi@iobroker-pi:~ $ sudo systemctl enable systemd-timesyncd.service Failed to enable unit: Unit file systemd-timesyncd.service does not exist.
Könnte diese Meldung auf die Spur führen? In welches Verzeichnis gehört die Datei und welchen Inhalt hat sie, bzw kann sie automatisch installiert werden?
@nobbiman sagte in Growatt exception: Error: {"result":3}:
Ist das entsprechende Paket nicht installiert?
Das ist eigentlich immer vorinstalliert.sudo apt update apt policy systemd-timesyncd
@thomas-braun said in Growatt exception: Error: {"result":3}:
pi@iobroker-pi:~ $ sudo apt update Hit:1 http://deb.debian.org/debian bullseye InRelease Get:2 http://deb.debian.org/debian bullseye-updates InRelease [44.1 kB] Get:3 http://security.debian.org/debian-security bullseye-security InRelease [48 .4 kB] Get:4 http://ftp.debian.org/debian bullseye-backports InRelease [49.0 kB] Hit:5 https://deb.nodesource.com/node_16.x bullseye InRelease Hit:6 http://archive.raspberrypi.org/debian bullseye InRelease Hit:7 https://www.debmatic.de/debmatic stable InRelease Get:8 http://security.debian.org/debian-security bullseye-security/main Sources [183 kB] Get:9 http://security.debian.org/debian-security bullseye-security/main armhf Pa ckages [217 kB] Get:10 http://security.debian.org/debian-security bullseye-security/main Transla tion-en [145 kB] Get:11 http://ftp.debian.org/debian bullseye-backports/main armhf Packages [379 kB] Get:12 http://ftp.debian.org/debian bullseye-backports/main Translation-en [322 kB] Fetched 1,388 kB in 2s (601 kB/s) Reading package lists... Done Building dependency tree... Done Reading state information... Done All packages are up to date. pi@iobroker-pi:~ $ apt policy systemd-timesyncd systemd-timesyncd: Installed: (none) Candidate: 247.3-7+deb11u1 Version table: 252.4-1~bpo11+1 100 100 http://ftp.debian.org/debian bullseye-backports/main armhf Packages 247.3-7+deb11u1 500 500 http://deb.debian.org/debian bullseye/main armhf Packages
Nicht installiert...
sudo apt install systemd-timesyncd
Und wo kommen die backports her? Schmeiß das Repository dazu raus.
kein Ahnung wo die herkommen wenn nicht von der Version buster.
Keine Ahnung aber auch, wie ich sie deinstallieren kann. -
Vermutlich steht die Quelle in der
/etc/apt/sources.list
drin.
Meine schaut z. B. so aus:deb http://deb.debian.org/debian bullseye main contrib non-free deb http://security.debian.org/debian-security bullseye-security main contrib non-free deb http://deb.debian.org/debian bullseye-updates main contrib non-free # deb http://deb.debian.org/debian bullseye-backports main contrib non-free # Uncomment deb-src lines below then 'apt-get update' to enable 'apt-get source' #deb-src http://deb.debian.org/debian bullseye main contrib non-free #deb-src http://security.debian.org/debian-security bullseye-security main contrib non-free #deb-src http://deb.debian.org/debian bullseye-updates main contrib non-free #deb-src http://deb.debian.org/debian bullseye-backports main contrib non-free
Man beachte Zeile 4.
#deb http://raspbian.raspberrypi.org/raspbian/ bullseye main contrib non-free rpi # Uncomment line below then 'apt-get update' to enable 'apt-get source' #deb-src http://raspbian.raspberrypi.org/raspbian/ bullseye main contrib non-free rpi deb http://deb.debian.org/debian/ bullseye main contrib non-free deb-src http://deb.debian.org/debian/ bullseye-updates main contrib non-free deb http://security.debian.org/debian-security bullseye-security main deb-src http://security.debian.org/debian-security bullseye-security main deb http://ftp.debian.org/debian bullseye-backports main contrib non-free
Und welche müssen raus?
Übernimm einfach die Datei so wie die bei mir aussieht.
Puuhhh, das war jetzt schon mal erfolgreich!
Leider will aber der Growatt-Adaper auch nach einem Neustart des ioBrokers immer noch nicht!
Auch nach Deinstallieren des Growatt-Adapters/-Instanz, Reboot des Hosts, und Neuinstallation Adapter/Instanz !!growatt.0 2023-02-02 10:35:14.614 error Growatt exception: Error: {"result":3} growatt.0 2023-02-02 10:35:12.908 info starting. Version 2.0.0 in /opt/iobroker/node_modules/iobroker.growatt, node: v16.19.0, js-controller: 4.0.24
2.0.0
Kannst du das loggen mal auf Debug stellen und den kompletten output vom Adapterstart hier posten.
@wendy2702
Da ist leider nicht viel zu sehen!growatt.0 2023-02-02 11:37:01.734 info not connected growatt.0 2023-02-02 11:37:01.733 warn Login:{} growatt.0 2023-02-02 11:35:01.681 info not connected growatt.0 2023-02-02 11:35:01.680 warn Login:{} growatt.0 2023-02-02 11:33:01.539 info not connected growatt.0 2023-02-02 11:33:01.538 warn Login:{} growatt.0 2023-02-02 11:31:01.477 info not connected growatt.0 2023-02-02 11:31:01.476 warn Login:{} growatt.0 2023-02-02 11:29:01.148 info not connected growatt.0 2023-02-02 11:29:01.147 warn Login:{} growatt.0 2023-02-02 11:27:01.074 info not connected growatt.0 2023-02-02 11:27:01.073 warn Login:{} growatt.0 2023-02-02 11:25:01.007 info not connecte
Das heißt die Zeit tickt jetzt richtig?
Ja, Danke noch einmal, du hast mich gut durch das Problem geführt - ich merke immer mehr, dass ich tiefer einsteigen müsste. -
@wendy2702
Sorry, ich war an der falschen Stelle - hier nun sicher korrektgrowatt.0 2023-02-02 11:41:30.658 debug Leave growattData :170ms growatt.0 2023-02-02 11:41:30.656 info not connected growatt.0 2023-02-02 11:41:30.655 debug Growatt time for login : 167ms growatt.0 2023-02-02 11:41:30.654 debug Growatt isConnected() : false growatt.0 2023-02-02 11:41:30.653 warn Login:{} growatt.0 2023-02-02 11:41:30.495 debug Enter lifeSignCallback 600000ms growatt.0 2023-02-02 11:41:30.494 debug Growatt login with user and password growatt.0 2023-02-02 11:41:30.493 debug Growatt isConnected() : false growatt.0 2023-02-02 11:41:30.490 debug Growatt new API growatt.0 2023-02-02 11:41:30.488 debug Enter lifeSignCallback 600000ms growatt.0 2023-02-02 11:41:30.487 debug Enter growattData, Param: sessionHold:true growatt.0 2023-02-02 11:41:30.416 info starting. Version 2.0.0 in /opt/iobroker/node_modules/iobroker.growatt, node: v16.19.0, js-controller: 4.0.24 growatt.0 2023-02-02 11:41:29.995 debug Plugin sentry Initialize Plugin (enabled=true) growatt.0 2023-02-02 11:41:29.893 debug States connected to redis: 127.0.0.1:9000 growatt.0 2023-02-02 11:41:29.801 debug States create User PubSub Client growatt.0 2023-02-02 11:41:29.799 debug States create System PubSub Client growatt.0 2023-02-02 11:41:29.774 debug Redis States: Use Redis connection: 127.0.0.1:9000 growatt.0 2023-02-02 11:41:29.725 debug Objects connected to redis: 127.0.0.1:9001 growatt.0 2023-02-02 11:41:29.717 debug Objects client initialize lua scripts growatt.0 2023-02-02 11:41:29.633 debug Objects create User PubSub Client growatt.0 2023-02-02 11:41:29.631 debug Objects create System PubSub Client growatt.0 2023-02-02 11:41:29.628 debug Objects client ready ... initialize now growatt.0 2023-02-02 11:41:29.568 debug Redis Objects: Use Redis connection: 127.0.0.1:9001 growatt.0 2023-02-02 11:41:24.945 info Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason growatt.0 2023-02-02 11:41:24.944 info terminating growatt.0 2023-02-02 11:41:24.941 info Got terminate signal TERMINATE_YOURSELF growatt.0 2023-02-02 11:41:02.146 info not connected growatt.0 2023-02-02 11:41:02.145 warn Login:{}
not connected
Der verbindet sich nicht mit dem China Server.
Was für eine Adresse steht denn in der Config?
