    4. Growatt exception: Error: {"result":3}
    • N
      nobbiman @Thomas Braun last edited by
      sudo apt update
      Hit:1 http://deb.debian.org/debian bullseye InRelease
      Get:2 http://deb.debian.org/debian bullseye-updates InRelease [44.1 kB]
      Get:3 http://security.debian.org/debian-security bullseye-security InRelease [48.4 kB]
      Get:4 http://ftp.debian.org/debian bullseye-backports InRelease [49.0 kB]
      Hit:5 http://archive.raspberrypi.org/debian bullseye InRelease
      Hit:6 https://deb.nodesource.com/node_16.x bullseye InRelease
      Hit:7 https://www.debmatic.de/debmatic stable InRelease
      Reading package lists... Done
      E: Release file for http://deb.debian.org/debian/dists/bullseye-updates/InRelease is not valid yet (invalid for another 2min 50s). Updates for this repository will not be applied.
      E: Release file for http://ftp.debian.org/debian/dists/bullseye-backports/InRelease is not valid yet (invalid for another 2min 50s). Updates for this repository will not be applied.
      • N
        pi@iobroker-pi:~ $ sudo systemctl enable systemd-timesyncd.service
        Failed to enable unit: Unit file systemd-timesyncd.service does not exist.
        Könnte diese Meldung auf die Spur führen? In welches Verzeichnis gehört die Datei und welchen Inhalt hat sie, bzw kann sie automatisch installiert werden?
          Thomas Braun Most Active @nobbiman last edited by
          @nobbiman sagte in Growatt exception: Error: {"result":3}:
          Ist das entsprechende Paket nicht installiert?
          Das ist eigentlich immer vorinstalliert.
          sudo apt update
          apt policy systemd-timesyncd
          • N
            @thomas-braun said in Growatt exception: Error: {"result":3}:
            pi@iobroker-pi:~ $ sudo apt update
            Get:3 http://security.debian.org/debian-security bullseye-security InRelease [48               .4 kB]
            Hit:5 https://deb.nodesource.com/node_16.x bullseye InRelease
            Hit:6 http://archive.raspberrypi.org/debian bullseye InRelease
            Get:8 http://security.debian.org/debian-security bullseye-security/main Sources                [183 kB]
            Get:9 http://security.debian.org/debian-security bullseye-security/main armhf Pa               ckages [217 kB]
            Get:10 http://security.debian.org/debian-security bullseye-security/main Transla               tion-en [145 kB]
            Get:11 http://ftp.debian.org/debian bullseye-backports/main armhf Packages [379                kB]
            Get:12 http://ftp.debian.org/debian bullseye-backports/main Translation-en [322                kB]
            Fetched 1,388 kB in 2s (601 kB/s)
            Building dependency tree... Done
            All packages are up to date.
            pi@iobroker-pi:~ $ apt policy systemd-timesyncd
            systemd-timesyncd:
              Installed: (none)
              Candidate: 247.3-7+deb11u1
              Version table:
                 252.4-1~bpo11+1 100
                    100 http://ftp.debian.org/debian bullseye-backports/main armhf Packages
                 247.3-7+deb11u1 500
                    500 http://deb.debian.org/debian bullseye/main armhf Packages
              Thomas Braun Most Active @nobbiman last edited by Thomas Braun
              @nobbiman
              Nicht installiert...
              sudo apt install systemd-timesyncd
              Und wo kommen die backports her? Schmeiß das Repository dazu raus.
              • N
                nobbiman @Thomas Braun last edited by nobbiman
                kein Ahnung wo die herkommen wenn nicht von der Version buster.
                Keine Ahnung aber auch, wie ich sie deinstallieren kann.
                  @nobbiman
                  Vermutlich steht die Quelle in der
                  /etc/apt/sources.list
                  drin.
                  Meine schaut z. B. so aus:
                  deb http://deb.debian.org/debian bullseye main contrib non-free
                  deb http://security.debian.org/debian-security bullseye-security main contrib non-free
                  deb http://deb.debian.org/debian bullseye-updates main contrib non-free
                  # deb http://deb.debian.org/debian bullseye-backports main contrib non-free
                  # Uncomment deb-src lines below then 'apt-get update' to enable 'apt-get source'
                  #deb-src http://deb.debian.org/debian bullseye main contrib non-free
                  #deb-src http://security.debian.org/debian-security bullseye-security main contrib non-free
                  #deb-src http://deb.debian.org/debian bullseye-updates main contrib non-free
                  #deb-src http://deb.debian.org/debian bullseye-backports main contrib non-free
                  Man beachte Zeile 4.
                  • N
                    #deb http://raspbian.raspberrypi.org/raspbian/ bullseye main contrib non-free rpi
                    # Uncomment line below then 'apt-get update' to enable 'apt-get source'
                    #deb-src http://raspbian.raspberrypi.org/raspbian/ bullseye main contrib non-free rpi
                    deb http://deb.debian.org/debian/ bullseye main contrib non-free
                    deb-src http://deb.debian.org/debian/ bullseye-updates main contrib non-free
                    deb http://ftp.debian.org/debian bullseye-backports main contrib non-free
                    Und welche müssen raus?
                      @nobbiman
                      Übernimm einfach die Datei so wie die bei mir aussieht.
                      • N
                        Puuhhh, das war jetzt schon mal erfolgreich!
                        Leider will aber der Growatt-Adaper auch nach einem Neustart des ioBrokers immer noch nicht!
                        Auch nach Deinstallieren des Growatt-Adapters/-Instanz, Reboot des Hosts, und Neuinstallation Adapter/Instanz !!
                        growatt.0
                        	2023-02-02 10:35:14.614	error	Growatt exception: Error: {"result":3}
                        growatt.0
                        	2023-02-02 10:35:12.908	info	starting. Version 2.0.0 in /opt/iobroker/node_modules/iobroker.growatt, node: v16.19.0, js-controller: 4.0.24
                        • wendy2702
                          wendy2702 last edited by
                          2.0.0
                          Kannst du das loggen mal auf Debug stellen und den kompletten output vom Adapterstart hier posten.
                          • N
                            nobbiman @wendy2702 last edited by
                            @wendy2702
                            Da ist leider nicht viel zu sehen!
                            growatt.0
                            	2023-02-02 11:37:01.734	info	not connected
                            growatt.0
                            	2023-02-02 11:37:01.733	warn	Login:{}
                            growatt.0
                            	2023-02-02 11:35:01.681	info	not connected
                            growatt.0
                            	2023-02-02 11:35:01.680	warn	Login:{}
                            growatt.0
                            	2023-02-02 11:33:01.539	info	not connected
                            growatt.0
                            	2023-02-02 11:33:01.538	warn	Login:{}
                            growatt.0
                            	2023-02-02 11:31:01.477	info	not connected
                            growatt.0
                            	2023-02-02 11:31:01.476	warn	Login:{}
                            growatt.0
                            	2023-02-02 11:29:01.148	info	not connected
                            growatt.0
                            	2023-02-02 11:29:01.147	warn	Login:{}
                            growatt.0
                            	2023-02-02 11:27:01.074	info	not connected
                            growatt.0
                            	2023-02-02 11:27:01.073	warn	Login:{}
                            growatt.0
                            	2023-02-02 11:25:01.007	info	not connecte
                            • wendy2702
                              wendy2702 @nobbiman last edited by
                              @nobbiman Steht auch nicht auf Debug.
                              Beispiel:
                                Thomas Braun Most Active last edited by
                                Das heißt die Zeit tickt jetzt richtig?
                                • N
                                  Ja, Danke noch einmal, du hast mich gut durch das Problem geführt - ich merke immer mehr, dass ich tiefer einsteigen müsste.
                                  • N
                                    @wendy2702
                                    Sorry, ich war an der falschen Stelle - hier nun sicher korrekt
                                    growatt.0
                                    	2023-02-02 11:41:30.658	debug	Leave growattData :170ms
                                    growatt.0
                                    	2023-02-02 11:41:30.656	info	not connected
                                    growatt.0
                                    	2023-02-02 11:41:30.655	debug	Growatt time for login : 167ms
                                    growatt.0
                                    	2023-02-02 11:41:30.654	debug	Growatt isConnected() : false
                                    growatt.0
                                    	2023-02-02 11:41:30.653	warn	Login:{}
                                    growatt.0
                                    	2023-02-02 11:41:30.495	debug	Enter lifeSignCallback 600000ms
                                    growatt.0
                                    	2023-02-02 11:41:30.494	debug	Growatt login with user and password
                                    growatt.0
                                    	2023-02-02 11:41:30.493	debug	Growatt isConnected() : false
                                    growatt.0
                                    	2023-02-02 11:41:30.490	debug	Growatt new API
                                    growatt.0
                                    	2023-02-02 11:41:30.488	debug	Enter lifeSignCallback 600000ms
                                    growatt.0
                                    	2023-02-02 11:41:30.487	debug	Enter growattData, Param: sessionHold:true
                                    growatt.0
                                    	2023-02-02 11:41:30.416	info	starting. Version 2.0.0 in /opt/iobroker/node_modules/iobroker.growatt, node: v16.19.0, js-controller: 4.0.24
                                    growatt.0
                                    	2023-02-02 11:41:29.995	debug	Plugin sentry Initialize Plugin (enabled=true)
                                    growatt.0
                                    	2023-02-02 11:41:29.893	debug	States connected to redis: 127.0.0.1:9000
                                    growatt.0
                                    	2023-02-02 11:41:29.801	debug	States create User PubSub Client
                                    growatt.0
                                    	2023-02-02 11:41:29.799	debug	States create System PubSub Client
                                    growatt.0
                                    	2023-02-02 11:41:29.774	debug	Redis States: Use Redis connection: 127.0.0.1:9000
                                    growatt.0
                                    	2023-02-02 11:41:29.725	debug	Objects connected to redis: 127.0.0.1:9001
                                    growatt.0
                                    	2023-02-02 11:41:29.717	debug	Objects client initialize lua scripts
                                    growatt.0
                                    	2023-02-02 11:41:29.633	debug	Objects create User PubSub Client
                                    growatt.0
                                    	2023-02-02 11:41:29.631	debug	Objects create System PubSub Client
                                    growatt.0
                                    	2023-02-02 11:41:29.628	debug	Objects client ready ... initialize now
                                    growatt.0
                                    	2023-02-02 11:41:29.568	debug	Redis Objects: Use Redis connection: 127.0.0.1:9001
                                    growatt.0
                                    	2023-02-02 11:41:24.945	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                    growatt.0
                                    	2023-02-02 11:41:24.944	info	terminating
                                    growatt.0
                                    	2023-02-02 11:41:24.941	info	Got terminate signal TERMINATE_YOURSELF
                                    growatt.0
                                    	2023-02-02 11:41:02.146	info	not connected
                                    growatt.0
                                    	2023-02-02 11:41:02.145	warn	Login:{}
                                    • wendy2702
                                      not connected
                                      Der verbindet sich nicht mit dem China Server.
                                      Was für eine Adresse steht denn in der Config?
                                      N 1 Reply Last reply Reply Quote 1
                                      • N
                                        @wendy2702
                                        https://server.growatt.com
                                        wendy2702 Thomas Braun 2 Replies Last reply Reply Quote 0
                                        • wendy2702
                                          @nobbiman und die Seite ist von iobroker erreichbar und du bist dort registriert und kannst dich anmelden?
                                          • N
                                            @wendy2702 said in Growatt exception: Error: {"result":3}:
                                            Was heißt "von iobroker erreichbar"?
                                            Bei Growatt bin ich natürlich registriert und empfange meine Infos auch über meinen Browser. Bis von ein paar Tagen war das Auslesen der Daten und die Verbindung auch gar kein Problem. Frag mich aber bitte nicht, ob ich etwas geändert hatte - ich meine nicht!
                                            3802
