    4. Test Adapter Midea Dimstal Klimaanlagen v0.0.x
    • Matzebhv
      Matzebhv @BananaJoe last edited by
      @bananajoe Das mit der Krücke mache ich derzeit tatsächlich genau so, lesend benutze ich den Adapter und zum steuern den Skill mit dem Alexa-Adapter. Ist blöd, geht ja aber derzeit nicht anders.
      @tomtom Könnte man nicht midea-beautifull-air forken und dann fixen? Auf der Shell funktioniert die Steuerung der Anlage ja schon. Es werden zwar Fehler geworfen, das Gerät reagiert aber.
      iobroker@iOBroker:~$ midea-beautiful-air-cli set --ip 192.168.178.87 --token  --key  --running 0
      WARNING:midea_beautiful.lan:Error getting device capabilities for sn=000000P0000000Q104D6F458******** id=14293651167**** address=192.168.1***** version=3, cause Unable to send data after 3 retries, last error timed out for 000000P0000000Q104D6F458******** (14293651167****)
      Traceback (most recent call last):
        File "/home/iobroker/.local/lib/python3.9/site-packages/midea_beautiful/lan.py", line 809, in identify
          responses = self._status(cmd, cloud if use_cloud else None)
        File "/home/iobroker/.local/lib/python3.9/site-packages/midea_beautiful/lan.py", line 540, in _status
          responses = self.appliance_send(data)
        File "/home/iobroker/.local/lib/python3.9/site-packages/midea_beautiful/lan.py", line 685, in appliance_send
          return self._appliance_send_8370(data)
        File "/home/iobroker/.local/lib/python3.9/site-packages/midea_beautiful/lan.py", line 590, in _appliance_send_8370
          if packets := self._retry_send(original_data, response_buf):
        File "/home/iobroker/.local/lib/python3.9/site-packages/midea_beautiful/lan.py", line 670, in _retry_send
          packets = self.appliance_send(data)
        File "/home/iobroker/.local/lib/python3.9/site-packages/midea_beautiful/lan.py", line 675, in _retry_send
          raise MideaNetworkError(
      midea_beautiful.exceptions.MideaNetworkError: Unable to send data after 3 retries, last error timed out for 000000P0000000Q104D6F458******** (14293651167****)
      id 000000P0000000Q104
        id      = 1429365
        addr    = 192.168.178.87
        s/n     = 000000P0000000Q10
        model   = Air conditioner
        ssid    = net_ac_7F5E
        online  = True
        name    = 14293651
        running = False
        target  = 21.0
        indoor  = 24.4
        outdoor = 5.3
        fan     = 102
        mode    = 4
        purify  = False
        eco     = False
        sleep   = False
        F       = False
        error   = 0
        supports= {'eco': 1, 'mode': 1, 'fan_swing': 1, 'electricity': 0, 'strong_fan': 1, 'fan_speed': 1, 'temperature0': 32, 'temperature1': 60, 'temperature2': 32, 'temperature3': 60, 'temperature4': 32, 'temperature5': 60, 'temperature6': 0}
        version = 3
      • draexler
        draexler @Matzebhv last edited by
        @matzebhv sagte in Test Adapter Midea Dimstal Klimaanlagen v0.0.x:
        Das Homebidge Plugin funktioniert mit den neuen Geräten leider auch nicht, hier kannst du genau wie bei dem Adapter nur lesen aber nicht steuern.
        Wie ich oben schon geschrieben habe funktioniert es mit dem MDDF-20DEN7-WF bei mir mit dem HAM Adapter und dem PlugIn wunderbar... Außer die Füllstandanzeige 😉
        clfberlin 1 Reply Last reply Reply Quote 0
          toralt @tombox last edited by
          @tombox gibts bezüglich der LAN Integration schon irgendwelche news? Bisher macht Dein Adapter eigentlich keine Probleme, bin auch sehr zufrieden. Aber LAN Steuerung wäre natürlich schon sehr nice 🤘
          T H 2 Replies Last reply Reply Quote 0
            tombox @toralt last edited by
            @toralt Tja warte ab ob die Homebridge Anbindung ausgebaut wird oder die von hass.io leichter zu nutzen ist. aber ohne gerät ist es zu schwer das einzubauen
              Hc-Yami @toralt last edited by
              @toralt hab mittlerweile Homeassistant laufen und die Klima dann über den ioBroker Adapter angebunden. Apollon gibt sich wirklich Mühe, zumindest mein Gerät, vernünftig einzubinden.
              • clfberlin
                clfberlin @draexler last edited by
                @draexler
                Na, dann bin ich ja genau richtig in dem Thread. Mein (Comfee) MDDF-20DEN7-WF Luftentfeuchter kommt morgen. Helft bitte nochmal einem alten Mann über die Straße: Welche App nehme ich denn am besten als Ausgangsbasis? NetHome? MSmartHome? Merci und Grüße, clfberlin
                • BananaJoe
                  BananaJoe Most Active @clfberlin last edited by
                  @clfberlin NetHome Plus
                  clfberlin 1 Reply Last reply Reply Quote 2
                    toralt @Hc-Yami last edited by
                    @hc-yami Danke für den Tipp, habe ich installiert. Läuft auch, aber zum Glück muss ich damit nichts machen. Finde HA schrecklich. Ich verstehe gar nichts 😄
                    Aber wie gesagt, durchreichen in den ioBroker funktioniert, Verbindung scheint auch stabil. Ich werde das mal testen.
                    Danke!
                    • clfberlin
                      clfberlin @BananaJoe last edited by clfberlin
                      @bananajoe
                      Hui, die NetHome Plus Übersetzungen sind ja ganz großes Kino. Nicht nur die Interpretation von Begriffen, auch die Nutzerführung ist eine kleine Rätselaufgabe. 😁
                      Eingerichtet ist ein Comfee MDDF-20DEN7-WF. Ich habe mal beides ausprobiert.
                      Der Midea-Adapter (0.0.7) legt bei mir Objekte an. Unter control sind die Werte [null]
                      Unter general sind Werte wie id und sn befüllt, andere wie activeStatus hingegen nicht.
                      Unter status wieder alles [null]
                      Den HAM-Adapter nutze ich schon für ewelink. Wenn es erstmal läuft, ist es ok. Ein Problem bei mir: Installiere ich über die Adapter-Konfiguration homebridge-midea-air@1.7.0, kann ich hinterher keine Konfiguration aufrufen. Er rödelt und rödelt, öffnet aber nix. Das scheint bei mir ein generelles Problem zu sein.
                      Installiere ich über den Homebridge-Bereich, bietet er mir bei der Suche midea air bis 1.5.2. Das kann ich installieren und auf 1.7.3 updaten. Das Ergebnis sind dann zwei Objektordner ham.0.Entfeuchter_8558.000000BC (mit Werten für Klimatisierung) und ham.0.Entfeuchter_8558.000000BD (mit Werten für Trocknung). Die Werte darin haben aber nichts mit dem tatsächlichen Zustand zu tun. Und steuern kann ich dort auch nichts.
                      Bevor ich hier weiter teste: Es war die Rede von 1.7.0. Ist diese Version zwingend für das Funktionieren? Oder geht es generell mit 1.7.0+ (also ab der Version)?
                      Merci, clfberlin
                      • clfberlin
                        clfberlin @clfberlin last edited by
                        Ergänzung: Ah, ne... Das hängt etwas vom Modus ab. In "Smart" gibt er keine aktuellen Werte aus. Ansonsten schon, allerdings nicht ganz zuverlässig, Wasserstand überhaupt nicht und steuern lässt sich auch nichts. Gerade Wasserstand wäre für mich eine interessante Info. Naja, mal schauen.
                        • clfberlin
                          Und noch eine Sache beim HAM-Adapter.
                          Es ist "interval": 30 eingestellt. Aber in den Logs fließen sekündlich Abfragen ein. 🤔
                            mike2712 last edited by mike2712
                            [gelöst] Hallo, ich habe jetzt auf die Version 0.0.1 hochgerüstet, jetzt wird der Adapter selbst nicht mehr grün, mit den Meldungen kann ich nichts anfangen, was habe ich falsch gemacht?
                            Warum auch immer, nach einigen Neustarts funktioniert es nun.
                            midea.0
                            2023-02-03 11:40:40.319	error	SyntaxError: Unexpected token F in JSON at position 445 at JSON.parse (<anonymous>) at Midea.getDeviceList (/opt/iobroker/node_modules/iobroker.midea/main.js:113:30) at processTicksAndRejections (node:internal/process/task_queues:96:5) at Midea.onReady (/opt/iobroker/node_modules/iobroker.midea/main.js:76:5)
                            midea.0
                            2023-02-03 11:40:40.314	error	SyntaxError: Unexpected token F in JSON at position 445
                            midea.0
                            2023-02-03 11:40:31.092	error	*** PY *** Python Error Call to 'connect_to_cloud' failed:> const cloud = await this.midea_beautiful.connect_to_cloud$({ at Midea.login (/opt/iobroker/node_modules/iobroker.midea/main.js:87:21) at Midea.onReady (/opt/iobroker/node_modules/iobroker.midea/main.js:75:18)... across the bridge ...> cloud.authenticate() at connect_to_cloud (/opt/iobroker/.local/lib/python3.9/site-packages/midea_beautiful/__init__.py:87)> self._get_region() at authenticate (/opt/iobroker/.local/lib/python3.9/site-packages/midea_beautiful/cloud.py:388)> response = self.api_request( at _get_region (/opt/iobroker/.local/lib/python3.9/site-packages/midea_beautiful/cloud.py:371)> self.handle_api_error(int(payload[error_code_tag]), payload["msg"]) at api_request (/opt/iobroker/.local/lib/python3.9/site-packages/midea_beautiful/cloud.py:302)> handler() at handle_api_error (/opt/iobroker/.local/lib/python3.9/site-packages/midea_beautiful/cloud.py:645)> raise CloudError(error, message) at cloud_error (/opt/iobroker/.local/lib/python3.9/site-packages/midea_beautiful/cloud.py:630)*** JS *** midea_beautiful.exceptions.CloudError: Midea cloud API error: user route does not exist (10004)
                            • clfberlin
                              clfberlin @mike2712 last edited by
                              @mike2712
                              Oh, ok. @Thomas-Braun schrieb mal:
                              Genau genommen ist 0.0.7 die 'aktuelle' Version, die 0.1.0 aus git ist nur eine Alpha zum herumbasteln.
                                Thomas Braun Most Active @clfberlin last edited by
                                @clfberlin @mike2712
                                midea
                                github:	0.1.0
                                latest:	0.0.7 for 20 months
                                stable:	0.0.7 for 20 months
                                  maxpd last edited by
                                  wisst ihr ob auch so eine Dimstal integriert werden kann?
                                  https://www.amazon.de/Klimaanlage-Klimagerät-Kupferleitungen-Heizfunktion-Energieklasse/dp/B0B13N3JWN/ref=sr_1_8?__mk_de_DE=ÅMÅŽÕÑ&crid=3LUXNRKJK3GWF&keywords=klimaanlage%2Bdaikin%2Bsplit&qid=1677183593&sprefix=klimaanlage%2Bdaiking%2Bspli%2Caps%2C332&sr=8-8&th=1
                                  • BananaJoe
                                    BananaJoe Most Active @maxpd last edited by
                                    @maxpd alle Dimstal mit WLAN sollten gehen. Mit den zuvor beschriebenen Einschränkungen (Werte abgreifen geht super, Steuerung klappt nicht bei allen, dann aber über Umwege.
                                    Ich habe den Alexa-Skill installiert und darüber klappt das Super (ein/aus, Wunschtemperatur setzen, heizen, kühlen etc.), die Fernbedienung nutze ich eigentlich nie.
                                    M M 2 Replies Last reply Reply Quote 0
                                      maxpd @BananaJoe last edited by
                                      @bananajoe dabei ist gerade das Schreiben das wichtige 😄
                                      Alexa habe ich nicht und Sprachsteuerung strebe ich nicht an. Soll komplett autark gesteuert über Sensoren agieren. Wie finde ich vor dem Kauf heraus ob das klappt?
                                      • BananaJoe
                                        @maxpd sagte in Test Adapter Midea Dimstal Klimaanlagen v0.0.x:
                                        Gar nicht 🙂 Ein Restrisiko bleibt immer.
                                        Aber die von mir beschriebene Methode im Post https://forum.iobroker.net/post/915989 sollte auf jeden Fall funktionieren.
                                        Du nimmst dann den Adapter um die Werte zu erhalten,
                                        und wenn du einen Steuerbefehl senden willst musst du das halt über einen Scriptaufruf machen.
                                        Eventuell funktioniert irgendwann auch wieder die normale Methode.
                                        Ich habe die Klimaanlage erst seit 2 Monaten - aber viel mehr als ein und aus sowie Temperatur setzen mache ich nicht.
                                        Und - steuern solltest du die auch eher im 15 bis 30 Minuten intervall, also nicht ständig ein- und ausschalten. Die Anlage macht das schon, Wunschtemperatur setzen, einschalten, maximal ob noch ob diese Klimatisieren (also Heizen und Kühlen) oder nur Heizen soll.
                                        Klar wenn die heizt sind das bei mir 2kW (mit 2 Innengeräten). Wenn die Temperatur gehalten wird aber viel weniger (um die 100W?)
                                        M R 2 Replies Last reply Reply Quote 1
                                          maxpd @BananaJoe last edited by maxpd
                                          @bananajoe Danke für deinen sehr hilfreichen Input!
                                          Bei dem verlinkten Gerät könnte man zusätzlich als Idee noch die Reinigung in regelmäßigen Abständen steuern.
                                          • BananaJoe
                                            @maxpd zum Steuern gäbe es übrigens einen Plan B: Per Infrarot.
                                            Ich habe bei einen Infrarotsender auf Tasmotabasis im Wohnzimmer hängen, der kann auch Befehle an die Klimanlage senden. (Ich sag nicht das das erlernen der Codes einfach ist, aber machbar)
                                            Im Dimstal Shop verkaufen die selber ein Broadlink-Teil dafür (Das würde ich bitte nicht kaufen)
                                            Bin mir nicht ganz sicher bei der von dir verlinkten Anlage wegen der "Follow me" Funktion. Wobei da nicht einmal eine Fernbedienung abgebildet ist ... dann ist auch keine dabei. Wobei die Funktion braucht meine ich die Fernbedienung, schließlich wird dieser "gefolgt"
                                            dimstal midea nethome nethome plus
                                            65
                                            368
                                            82766
