    4. Growatt exception: Error: {"result":3}
    • N
      nobbiman @wendy2702 last edited by
      @wendy2702
      Sorry, ich war an der falschen Stelle - hier nun sicher korrekt
      growatt.0
      	2023-02-02 11:41:30.658	debug	Leave growattData :170ms
      growatt.0
      	2023-02-02 11:41:30.656	info	not connected
      growatt.0
      	2023-02-02 11:41:30.655	debug	Growatt time for login : 167ms
      growatt.0
      	2023-02-02 11:41:30.654	debug	Growatt isConnected() : false
      growatt.0
      	2023-02-02 11:41:30.653	warn	Login:{}
      growatt.0
      	2023-02-02 11:41:30.495	debug	Enter lifeSignCallback 600000ms
      growatt.0
      	2023-02-02 11:41:30.494	debug	Growatt login with user and password
      growatt.0
      	2023-02-02 11:41:30.493	debug	Growatt isConnected() : false
      growatt.0
      	2023-02-02 11:41:30.490	debug	Growatt new API
      growatt.0
      	2023-02-02 11:41:30.488	debug	Enter lifeSignCallback 600000ms
      growatt.0
      	2023-02-02 11:41:30.487	debug	Enter growattData, Param: sessionHold:true
      growatt.0
      	2023-02-02 11:41:30.416	info	starting. Version 2.0.0 in /opt/iobroker/node_modules/iobroker.growatt, node: v16.19.0, js-controller: 4.0.24
      growatt.0
      	2023-02-02 11:41:29.995	debug	Plugin sentry Initialize Plugin (enabled=true)
      growatt.0
      	2023-02-02 11:41:29.893	debug	States connected to redis: 127.0.0.1:9000
      growatt.0
      	2023-02-02 11:41:29.801	debug	States create User PubSub Client
      growatt.0
      	2023-02-02 11:41:29.799	debug	States create System PubSub Client
      growatt.0
      	2023-02-02 11:41:29.774	debug	Redis States: Use Redis connection: 127.0.0.1:9000
      growatt.0
      	2023-02-02 11:41:29.725	debug	Objects connected to redis: 127.0.0.1:9001
      growatt.0
      	2023-02-02 11:41:29.717	debug	Objects client initialize lua scripts
      growatt.0
      	2023-02-02 11:41:29.633	debug	Objects create User PubSub Client
      growatt.0
      	2023-02-02 11:41:29.631	debug	Objects create System PubSub Client
      growatt.0
      	2023-02-02 11:41:29.628	debug	Objects client ready ... initialize now
      growatt.0
      	2023-02-02 11:41:29.568	debug	Redis Objects: Use Redis connection: 127.0.0.1:9001
      growatt.0
      	2023-02-02 11:41:24.945	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      growatt.0
      	2023-02-02 11:41:24.944	info	terminating
      growatt.0
      	2023-02-02 11:41:24.941	info	Got terminate signal TERMINATE_YOURSELF
      growatt.0
      	2023-02-02 11:41:02.146	info	not connected
      growatt.0
      	2023-02-02 11:41:02.145	warn	Login:{}
      • wendy2702
        wendy2702 @nobbiman last edited by
        @nobbiman sagte in Growatt exception: Error: {"result":3}:
        not connected
        Der verbindet sich nicht mit dem China Server.
        Was für eine Adresse steht denn in der Config?
        N 1 Reply Last reply Reply Quote 1
        • N
          @wendy2702
          https://server.growatt.com
          wendy2702 Thomas Braun 2 Replies Last reply Reply Quote 0
          • wendy2702
            @nobbiman und die Seite ist von iobroker erreichbar und du bist dort registriert und kannst dich anmelden?
            • N
              @wendy2702 said in Growatt exception: Error: {"result":3}:
              Was heißt "von iobroker erreichbar"?
              Bei Growatt bin ich natürlich registriert und empfange meine Infos auch über meinen Browser. Bis von ein paar Tagen war das Auslesen der Daten und die Verbindung auch gar kein Problem. Frag mich aber bitte nicht, ob ich etwas geändert hatte - ich meine nicht!
              • wendy2702
                Na von dem Rechner auf dem iobroker läuft. Kannst du da die Seite erreichen?
                nslookup server.growatt.com
                Server:         192.168.178.1
                Address:        192.168.178.1#53
                Non-authoritative answer:
                Address: 47.91.67.66
                ping 47.91.67.66
                PING 47.91.67.66 (47.91.67.66) 56(84) bytes of data.
                64 bytes from 47.91.67.66: icmp_seq=1 ttl=87 time=17.0 ms
                64 bytes from 47.91.67.66: icmp_seq=2 ttl=87 time=15.8 ms
                  Thomas Braun Most Active @nobbiman last edited by
                  @nobbiman
                  Sonderzeichen im Passwort? Stell das mal auf was einfacheres nur aus Buchstaben und Ziffern um.
                  N 2 Replies Last reply Reply Quote 0
                  • N
                    nobbiman @Thomas Braun last edited by
                    Nein, keine Sonderzeichen, nur Klein- und Großbuchstaben und Zahlen
                    pi@iobroker-pi:~ $ nslookup server.growatt.com
                    -bash: nslookup: command not found
                    • N
                      nobbiman @Thomas Braun last edited by nobbiman
                      Nach Installation von nslookup:
                      Server:         192.168.2.1
                      Address:        192.168.2.1#53
                      pi@iobroker-pi:~ $ ping 47.91.67.66
                      64 bytes from 47.91.67.66: icmp_seq=1 ttl=95 time=12.9 ms
                      64 bytes from 47.91.67.66: icmp_seq=2 ttl=95 time=11.4 ms
                      64 bytes from 47.91.67.66: icmp_seq=3 ttl=95 time=12.4 ms
                      64 bytes from 47.91.67.66: icmp_seq=4 ttl=95 time=11.3 ms
                      Fehler aber auch noch Host-Neustart immer noch da! Auch nach Deinstallation des Adapters und Instanz , Neustart und Neuinstallation nicht!
                      $ iobroker add growatt auto --host iobroker-pi --debug
                      NPM version: 8.19.3Installing iobroker.growatt@2.0.0... (System call)
                      npm WARN deprecated querystring@0.2.0: The querystring API is considered Legacy. new code should use the URLSearchParams API instead.
                      added 9 packages in 14s88 packages are looking for funding run `npm fund` for details
                      host.iobroker-pi install adapter growatt
                      upload [4] growatt.admin /opt/iobroker/node_modules/iobroker.growatt/admin/glogo.png glogo.png image/png
                      upload [3] growatt.admin /opt/iobroker/node_modules/iobroker.growatt/admin/growatt.png growatt.png image/png
                      upload [2] growatt.admin /opt/iobroker/node_modules/iobroker.growatt/admin/index_m.html index_m.html text/html
                      upload [1] growatt.admin /opt/iobroker/node_modules/iobroker.growatt/admin/style.css style.css text/css
                      upload [0] growatt.admin /opt/iobroker/node_modules/iobroker.growatt/admin/words.js words.js application/javascript
                      host.iobroker-pi object system.adapter.growatt.0.compactMode created
                      host.iobroker-pi object system.adapter.growatt.0.cpu created
                      host.iobroker-pi object system.adapter.growatt.0.cputime created
                      host.iobroker-pi object system.adapter.growatt.0.memHeapUsed created
                      host.iobroker-pi object system.adapter.growatt.0.memHeapTotal created
                      host.iobroker-pi object system.adapter.growatt.0.memRss created
                      host.iobroker-pi object system.adapter.growatt.0.uptime created
                      host.iobroker-pi object system.adapter.growatt.0.inputCount created
                      host.iobroker-pi object system.adapter.growatt.0.outputCount created
                      host.iobroker-pi object system.adapter.growatt.0.eventLoopLag created
                      host.iobroker-pi object system.adapter.growatt.0.sigKill created
                      host.iobroker-pi object system.adapter.growatt.0.logLevel created
                      host.iobroker-pi object growatt.0.info created
                      host.iobroker-pi object growatt.0.info.connection created
                      host.iobroker-pi Set default value of growatt.0.info.connection: false
                      host.iobroker-pi object system.adapter.growatt.0 created
                      Process exited with code 0
                      • wendy2702
                        @nobbiman Dann muss ich ehrlich sagen gehen mir die Ideen aus warum der Adapter sich nicht verbindet.
                        Mach dazu am besten ein Issue auf Github auf, dann bekommt der Entwickler das mit und kann vielleicht helfen.
                        • N
                          @wendy2702
                          Ja, das ist vielleicht der richtige Weg. Danke bis hier hin, ich werde danach hoffentlich hier in diesem Thread Positives berichten können.
                          • wendy2702
                            @nobbiman Gibt noch eines was man machen kann. Ein TCP dump auf dem Netzwerk IF und dann mal mit Wireshark schauen.
                            Zuerst rausfinden wie das IF heisst:
                            ip a
                            Dann kommt z.B. so was:
                            2: eth0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UP group default qlen 1000
                                link/ether b8:27:eb:b9:82:51 brd ff:ff:ff:ff:ff:ff
                                inet 192.168.178.17/24 brd 192.168.178.255 scope global dynamic noprefixroute eth0
                            Das Interface heisst dann "eth0"
                            Tcpdump dann so:
                            sudo tcpdump -i eth0 -s 65535 -w growatt.pcapng
                            File wird in dem Ordner gespeichert in dem man den Befehl ausführt.
                            Vom Pi runterladen und mit Wireshark anschauen.
                            Wenn du für den Zeitraum des Tests alle anderen Adapter stoppst ist das Ergebnis übersichtlicher.
                            • N
                              Wireshark
                              Ach du droßer Gott, da muss ich erst einmal schauen, was Wireshark ist und wie das funktioniert - bin bislang eher der Windows-User. Aber ich mache mich mal dran, wird sicher aber ein wenig dauern.
                              • N
                                @wendy2702
                                Das fängt erst einmal nicht erfolgsversprechend an!
                                pi@iobroker-pi:~ $ ip a
                                1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
                                    link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
                                    inet 127.0.0.1/8 scope host lo
                                       valid_lft forever preferred_lft forever
                                    inet6 ::1/128 scope host
                                2: eth0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc mq state DOWN group default qlen 1000
                                    link/ether e4:5f:01:a4:ad:f2 brd ff:ff:ff:ff:ff:ff
                                3: wlan0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UP group default qlen 1000
                                    link/ether e4:5f:01:a4:ad:f3 brd ff:ff:ff:ff:ff:ff
                                    inet 192.168.2.157/24 brd 192.168.2.255 scope global dynamic noprefixroute wlan0
                                       valid_lft 858018sec preferred_lft 750018sec
                                    inet6 fd00::e7b7:5373:8d3d:9248/64 scope global dynamic mngtmpaddr noprefixroute
                                       valid_lft 7198sec preferred_lft 3598sec
                                    inet6 fe80::c7b6:c7b1:7ac7:17a4/64 scope link
                                pi@iobroker-pi:~ $ sudo tcpdump -i eth0 -s 65535 -w growatt.pcapng
                                sudo: tcpdump: command not found
                                wendy2702 2 Replies Last reply Reply Quote 0
                                • wendy2702
                                  wlan0
                                  OK.
                                  Dein PI ist über WLAN angebunden. Hoffentlich ist das nicht schon die Ursache allen übels.
                                  Kannst du den zum testen mal per Netzwerkkabel anschließen? Ist sowieso die bessere Lösung für einen Server.
                                  Der Befehl wäre dann dieser:
                                  sudo tcpdump -i wlan0 -s 65535 -w growatt.pcapng
                                  Wireshark ist unter anderem auch für Windows verfügbar
                                  • N
                                    nobbiman @wendy2702 last edited by nobbiman
                                    Diesen Befehl verstehe ich nicht! Ich habe ein Netzwerkkabel angeschlossen und überwache 'wlan0'?
                                    Nach EIngabe des o.g. Befehls hängt der RasPi!
                                    pi@iobroker-pi:~ $ sudo tcpdump -i wlan0 -s 65535 -w growatt.pcapng
                                    tcpdump: listening on wlan0, link-type EN10MB (Ethernet), snapshot length 65535 bytes
                                    Was muss ich tun, damit ein Ergebnis in die Datei geschrieben wird oder verstehe ich nur Bahnhof?
                                    Übrigens klappte das zuvor auch über WLAN! Entfernung zum Router ca. 2m!
                                    • wendy2702
                                      Der Befehl monitored den Netzwerk Verkehr auf dem Interface "WLAN0" und schreibt die vollständige ausgabe in ein File namens: "growatt.pcapng"
                                      Der PI hängt nicht, du musst das loggen mit "strg+C" beenden.
                                        Das kann aber eigentlich nicht sein, das Netzwerkkabel-Interface eth0 ist nämlich DOWN:
                                        Dafür funkt da ein Interface namens wlan0 durch die Gegend.
                                        • N
                                          @thomas-braun said in Growatt exception: Error: {"result":3}:
                                          Muss ich im RasPi WLAN abschalten?
                                          • wendy2702
                                            @nobbiman Nur wenn das Netzwerkkabel funktioniert.
                                            Tut es derzeit aber nicht
                                            3802
