    4. JavaScript
    5. Roborock Adapter tester gesucht
    • wendy2702
      wendy2702 last edited by
      @copystring sagte in Roborock Adapter tester gesucht:
      buffer@>=6.0.3
      Da habe ich ja Glueck gehabt das es die bei mir gibt:
       npm ls buffer
      [sudo] password for mi:
      iobroker.inst@2.0.3 /opt/iobroker
      +-- iobroker.modbus@5.0.11
      | `-- crc@4.1.1
      |   `-- buffer@6.0.3
      +-- iobroker.mqtt@4.0.7
      | `-- mqtt-connection@4.1.0
      |   `-- mqtt-packet@6.10.0
      |     `-- bl@4.1.0
      |       `-- buffer@5.7.1
      +-- iobroker.sayit@1.12.6
      | `-- aws-sdk@2.1071.0
      |   `-- buffer@4.9.2
      `-- iobroker.shelly@6.3.1
        `-- shelly-iot@1.1.2
          `-- coap@0.26.0
            `-- bl@5.1.0
              `-- buffer@6.0.3 deduped
        DonToben @copystring last edited by DonToben
        @copystring said in Roborock Adapter tester gesucht:
        @dontoben said in Roborock Adapter tester gesucht:
        @hunter-0 said in Roborock Adapter tester gesucht:
        @dontoben
        Ist Node v16 nicht voraussetzen? Du hast: (node: v14.18.1)
        Gleiches Problem mit Node v16.19.0
        Hier mal der Log vom installieren des Adapters. Waren das schon immer so viele Meldungen?
        $ iobroker url copystring/ioBroker.roborock --host raspberrypi --debug
        install copystring/ioBroker.roborock
        NPM version: 6.14.5
        Installing copystring/ioBroker.roborock... (System call)
        > canvas@2.11.0 install /opt/iobroker/node_modules/canvas> node-pre-gyp install --fallback-to-build --update-binary
        node-pre-gyp ERR! install response status 404 Not Found on https://github.com/Automattic/node-canvas/releases/download/v2.11.0/canvas-v2.11.0-node-v93-linux-glibc-arm.tar.gz
        node-pre-gyp WARN Pre-built binaries not installable for canvas@2.11.0 and node@16.19.0 (node-v93 ABI, glibc) (falling back to source compile with node-gyp) node-pre-gyp WARN Hit error response status 404 Not Found on https://github.com/Automattic/node-canvas/releases/download/v2.11.0/canvas-v2.11.0-node-v93-linux-glibc-arm.tar.gz
        (node:4471) [DEP0150] DeprecationWarning: Setting process.config is deprecated. In the future the property will be read-only.
        (Use `node --trace-deprecation ...` to show where the warning was created)
        make: Verzeichnis „/opt/iobroker/node_modules/canvas/build“ wird betreten
        SOLINK_MODULE(target) Release/obj.target/canvas-postbuild.node
        CXX(target) Release/obj.target/canvas/src/backend/Backend.o
        CXX(target) Release/obj.target/canvas/src/backend/ImageBackend.o
        CXX(target) Release/obj.target/canvas/src/backend/PdfBackend.o
        CXX(target) Release/obj.target/canvas/src/backend/SvgBackend.o
        CXX(target) Release/obj.target/canvas/src/bmp/BMPParser.o
        ../src/bmp/BMPParser.cc: In member function ‘void BMPParser::Parser::parse(uint8_t*, int, uint8_t*)’:../src/bmp/BMPParser.cc:186:16: warning: comparison of integer expressions of different signedness: ‘int’ and ‘unsigned int’ [-Wsign-compare] E(ptr - data > imgdOffset, "image data overlaps with another structure"); ~~~~~~~~~~~^~~~~~~~~~~~../src/bmp/BMPParser.cc:10:25: note: in definition of macro ‘E’ #define E(cond, msg) if(cond) return setErr(msg) ^~~~../src/bmp/BMPParser.cc:201:27: warning: comparison of integer expressions of different signedness: ‘uint32_t’ {aka ‘unsigned int’} and ‘int’ [-Wsign-compare] E(ptr - data + imgdSize > len, "not enough image data"); ~~~~~~~~~~~~~~~~~~~~~~^~~~~../src/bmp/BMPParser.cc:10:25: note: in definition of macro ‘E’ #define E(cond, msg) if(cond) return setErr(msg) ^~~~
        CXX(target) Release/obj.target/canvas/src/Backends.o
        CXX(target) Release/obj.target/canvas/src/Canvas.o
        CXX(target) Release/obj.target/canvas/src/CanvasGradient.o
        CXX(target) Release/obj.target/canvas/src/CanvasPattern.o
        CXX(target) Release/obj.target/canvas/src/CanvasRenderingContext2d.o
        ../src/CanvasRenderingContext2d.cc: In member function ‘void Context2d::setTextPath(double, double)’:../src/CanvasRenderingContext2d.cc:2494:10: warning: enumeration value ‘TEXT_ALIGNMENT_LEFT’ not handled in switch [-Wswitch] switch (state->textAlignment) { ^../src/CanvasRenderingContext2d.cc:2494:10: warning: enumeration value ‘TEXT_ALIGNMENT_START’ not handled in switch [-Wswitch]
        CXX(target) Release/obj.target/canvas/src/closure.o
        CXX(target) Release/obj.target/canvas/src/color.o
        CXX(target) Release/obj.target/canvas/src/Image.o
        CXX(target) Release/obj.target/canvas/src/ImageData.o
        CXX(target) Release/obj.target/canvas/src/init.o
        CXX(target) Release/obj.target/canvas/src/register_font.o
        SOLINK_MODULE(target) Release/obj.target/canvas.node
        COPY Release/canvas.node
        make: Verzeichnis „/opt/iobroker/node_modules/canvas/build“ wird verlassen
        npm WARN crc@4.1.1 requires a peer of buffer@>=6.0.3 but none is installed. You must install peer dependencies yourself.npm WARN http-cookie-agent@4.0.2 requires a peer of tough-cookie@^4.0.0 but none is installed. You must install peer dependencies yourself.npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.3.2 (node_modules/fsevents):npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.8 (node_modules/osx-temperature-sensor):npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.8: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
        + iobroker.roborock@0.0.6-alpha.0added 45 packages from 35 contributors and updated 1 package in 346.618s
        48 packages are looking for funding run `npm fund` for details
        upload [11] roborock.admin /opt/iobroker/node_modules/iobroker.roborock/admin/i18n/de/translations.json i18n/de/translations.json application/json
        upload [10] roborock.admin /opt/iobroker/node_modules/iobroker.roborock/admin/i18n/en/translations.json i18n/en/translations.json application/json
        upload [9] roborock.admin /opt/iobroker/node_modules/iobroker.roborock/admin/i18n/es/translations.json i18n/es/translations.json application/json
        upload [6] roborock.admin /opt/iobroker/node_modules/iobroker.roborock/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
        upload [5] roborock.admin /opt/iobroker/node_modules/iobroker.roborock/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
        upload [4] roborock.admin /opt/iobroker/node_modules/iobroker.roborock/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
        upload [3] roborock.admin /opt/iobroker/node_modules/iobroker.roborock/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
        upload [0] roborock.admin /opt/iobroker/node_modules/iobroker.roborock/admin/roborock.png roborock.png image/png
        Process exited with code 0
        Ist dies das selbe Problem https://github.com/copystring/ioBroker.roborock/issues/40?
        Für die Karte wird canvas benötigt und canvas scheint es für RPi (bzw. für arm) nicht zu geben... Daher 404 beim Herunterladen von canvas. Es scheint auch keine ältere Version von canvas für den RPi (arm) zu geben.
        Vielleicht gibt es eine alternative, welche auch auf dem RPi läuft...
        @copystring
        Ja das ist issue 40.
        Ich mache dann heute mit deinen Anweisungen aus issue 40 weiter. Oder soll ich noch etwas anderes installieren?
        DonToben created this issue in copystring/ioBroker.roborock
        closed 0.0.6 Adapter startet ständig neu #40
        copystring 1 Reply Last reply Reply Quote 0
        • copystring
          copystring @DonToben last edited by
          @dontoben Siehe github.
            Hunter 0 last edited by
            Da es noch keine neue Version ist, weiß ich nicht ob es ein Issue für Github ist. Main Branch stand jetzt:
            • wendy2702
              wendy2702 @Hunter 0 last edited by wendy2702
              @hunter-0 Bitte vollständiges Log als text in Code Tags </> posten.
              Und vielleicht noch mitteilen was für ein System das ist.
              • wendy2702
                aktualisieren sich bei euch die Objekte noch?
                Unser Sauger ist eben gefahren und ich kann keine Änderung in den Objekten feststellen.
                Batterie z.B.
                Nach knapp 45 minuten Arbeit unverändert.
                Bisschen was RAM belegt er auch:
                Und im Log passiert zum Adapter nichts mehr.
                Erst nach restart kommen die neuen Werte aber beim RAM hochzählen kann ich zugucken:
                Restart log ohne Debug:
                mirko@iobroker:~$ tail -f /opt/iobroker/log/iobroker.current.log |grep roborock
                2023-02-02 15:50:38.847  - info: host.iobroker stopInstance system.adapter.roborock.0 (force=false, process=true)
                2023-02-02 15:50:38.851  - info: roborock.0 (77838) Got terminate signal TERMINATE_YOURSELF
                2023-02-02 15:50:38.853  - info: roborock.0 (77838) terminating
                2023-02-02 15:50:38.854  - info: roborock.0 (77838) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                2023-02-02 15:50:39.007  - info: host.iobroker stopInstance system.adapter.roborock.0 send kill signal
                2023-02-02 15:50:40.012  - info: host.iobroker stopInstance system.adapter.roborock.0 killing pid 77838
                2023-02-02 15:50:40.323  - info: host.iobroker instance system.adapter.roborock.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                2023-02-02 15:50:42.148  - info: host.iobroker instance system.adapter.roborock.0 started with pid 89295
                2023-02-02 15:50:43.974  - info: roborock.0 (89295) starting. Version 0.0.6-alpha.0 (non-npm: copystring/ioBroker.roborock) in /opt/iobroker/node_modules/iobroker.roborock, node: v16.19.0, js-controller: 4.0.24
                2023-02-02 15:50:44.177  - info: roborock.0 (89295) MQTT initialized
                2023-02-02 15:51:23.345  - info: host.iobroker "system.adapter.roborock.0" disabled
                2023-02-02 15:51:23.346  - info: host.iobroker stopInstance system.adapter.roborock.0 (force=false, process=true)
                2023-02-02 15:51:23.360  - info: roborock.0 (89295) Got terminate signal TERMINATE_YOURSELF
                2023-02-02 15:51:23.364  - info: roborock.0 (89295) terminating
                2023-02-02 15:51:23.365  - info: roborock.0 (89295) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                2023-02-02 15:51:23.392  - info: host.iobroker stopInstance system.adapter.roborock.0 send kill signal
                2023-02-02 15:51:23.954  - warn: roborock.0 (89295) get state error: Connection is closed.
                2023-02-02 15:51:23.956  - error: roborock.0 (89295) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                2023-02-02 15:51:23.956  - error: roborock.0 (89295) unhandled promise rejection: DB closed
                2023-02-02 15:51:23.956  - error: roborock.0 (89295) Error: DB closed
                2023-02-02 15:51:23.956  - error: roborock.0 (89295) DB closed
                2023-02-02 15:51:24.059  - info: host.iobroker instance system.adapter.roborock.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                2023-02-02 15:52:43.193  - info: host.iobroker "system.adapter.roborock.0" enabled
                2023-02-02 15:52:43.422  - info: host.iobroker instance system.adapter.roborock.0 started with pid 89332
                2023-02-02 15:52:44.603  - info: roborock.0 (89332) starting. Version 0.0.6-alpha.0 (non-npm: copystring/ioBroker.roborock) in /opt/iobroker/node_modules/iobroker.roborock, node: v16.19.0, js-controller: 4.0.24
                2023-02-02 15:52:44.827  - info: roborock.0 (89332) MQTT initialized
                2023-02-02 15:54:25.755  - info: host.iobroker "system.adapter.roborock.0" disabled
                2023-02-02 15:54:25.756  - info: host.iobroker stopInstance system.adapter.roborock.0 (force=false, process=true)
                2023-02-02 15:54:25.769  - info: roborock.0 (89332) Got terminate signal TERMINATE_YOURSELF
                2023-02-02 15:54:25.772  - info: roborock.0 (89332) terminating
                2023-02-02 15:54:25.772  - info: roborock.0 (89332) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                2023-02-02 15:54:25.800  - info: host.iobroker stopInstance system.adapter.roborock.0 send kill signal
                2023-02-02 15:54:26.440  - warn: roborock.0 (89332) get state error: Connection is closed.
                2023-02-02 15:54:26.441  - error: roborock.0 (89332) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                2023-02-02 15:54:26.441  - error: roborock.0 (89332) unhandled promise rejection: DB closed
                2023-02-02 15:54:26.442  - error: roborock.0 (89332) Error: DB closed
                2023-02-02 15:54:26.442  - error: roborock.0 (89332) DB closed
                2023-02-02 15:54:26.533  - info: host.iobroker instance system.adapter.roborock.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                @copystring : soll ich ein Issue aufmachen?
                Desweiteren, kann man es vielleicht so machen das die Karte nur aktualisiert wird wenn das Kerlchen fährt?
                • copystring
                  copystring @wendy2702 last edited by copystring
                  @wendy2702 Ja bitte ein Issue öffnen. Es scheint so zu sein, dass viel RAM belegt wird wenn unbekannte Befehle oder Statusnachrichten vorliegen. Siehe https://github.com/copystring/ioBroker.roborock/issues/34 und https://github.com/copystring/ioBroker.roborock/issues/49
                  Für solche Probleme brauche ich Tester da ich den passenden Saugroboter nicht habe. Hier z.B. den Roborock S7 MaxV (Ultra). Für den Roboter kann https://github.com/copystring/ioBroker.roborock/compare/update_robot_attributes getestet werden.
                  mproper23 created this issue in copystring/ioBroker.roborock
                  closed Unsupported attribute #34
                  closed extreme RAM Usage #49
                  • wendy2702
                    wendy2702 @copystring last edited by
                    Ich habe mich an das Issue dran gehangen, oder wolltest du zwingend ein neues?
                    Für das Map Update neues Issue:
                    https://github.com/copystring/ioBroker.roborock/issues/50
                    wendy2702 created this issue in copystring/ioBroker.roborock
                    closed Anpassung Kartenupdate #50
                    • copystring
                      @wendy2702 Ist schon ok so.
                      M-A Hueb 1 Reply Last reply Reply Quote 0
                      • M-A Hueb
                        M-A Hueb @copystring last edited by M-A Hueb
                        Hab mir jetzt mal Seq installiert, dann kann man besser das Log ziehen.
                        Seq
                        Gibts auch nen Adapter dazu
                          simplyclever @M-A Hueb last edited by
                          @m-a-hueb Die Funktion suche ich auch. Aktuell lade ich den Log runter und (Linux/Mac) führe dann dieses Kommando in einer Shell aus:
                          grep ": roborock" log.txt | sed 's/Name1/Kind1/' | sed 's/Name2/Kind2/' > robolog.txt
                          Das grep filtert die roborock Eintröge aus dem Log, die beiden sed ersetzen die realen Namen meiner Kinder (die Räume sind so benannt) durch KindX..
                          • M-A Hueb
                            M-A Hueb @simplyclever last edited by
                            @simplyclever Danke aber bin unter Windows unterwegs. Mit dem Seq Tool ist das recht easy jetzt
                            • wendy2702
                              Log in Notepad++ geht auch
                              • M-A Hueb
                                M-A Hueb @wendy2702 last edited by
                                @wendy2702 Wie meinst du?
                                • wendy2702
                                  wendy2702 @M-A Hueb last edited by
                                  @m-a-hueb Das Log kann man auch in Notepad++ öffnen und einfach nach Roborock filtern. bzw. suchen.
                                  Dann erhält man auch eine Ausgabe in der nur die Daten vom Roborock Adapter stehen.
                                  Könnte dann z.B. so aus sehen mit FTP Plugin rechts auf iobroker und dort direkt das log anklicken. Dann mit STRG+F im Beispiel nach allen "ical.2" einträgen in der offenen Datei gesucht. Ergebnis dann unten.
                                    Das ist der aktuelle Main Branch, soll ich ein Issue auf machen?
                                    2023-02-04 15:43:18.241 - info: host.pIOBroker "system.adapter.roborock.0" enabled
                                    2023-02-04 15:43:18.283 - info: host.pIOBroker instance system.adapter.roborock.0 started with pid 285887
                                    2023-02-04 15:43:18.728 - debug: roborock.0 (285887) Redis Objects: Use Redis connection: 0.0.0.0:9001
                                    2023-02-04 15:43:18.745 - debug: roborock.0 (285887) Objects client ready ... initialize now
                                    2023-02-04 15:43:18.746 - debug: roborock.0 (285887) Objects create System PubSub Client
                                    2023-02-04 15:43:18.746 - debug: roborock.0 (285887) Objects create User PubSub Client
                                    2023-02-04 15:43:18.771 - debug: roborock.0 (285887) Objects client initialize lua scripts
                                    2023-02-04 15:43:18.774 - debug: roborock.0 (285887) Objects connected to redis: 0.0.0.0:9001
                                    2023-02-04 15:43:18.788 - debug: roborock.0 (285887) Redis States: Use Redis connection: 0.0.0.0:9000
                                    2023-02-04 15:43:18.797 - debug: roborock.0 (285887) States create System PubSub Client
                                    2023-02-04 15:43:18.797 - debug: roborock.0 (285887) States create User PubSub Client
                                    2023-02-04 15:43:18.856 - debug: roborock.0 (285887) States connected to redis: 0.0.0.0:9000
                                    2023-02-04 15:43:18.936 - info: roborock.0 (285887) starting. Version 0.0.6-alpha.0 (non-npm: copystring/ioBroker.roborock#681304095ec6fa6391041cb23d70c746ec79c93e) in /opt/iobroker/node_modules/iobroker.roborock, node: v16.19.0, js-controller: 4.0.24
                                    2023-02-04 15:43:19.338 - error: roborock.0 (285887) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                    2023-02-04 15:43:19.339 - error: roborock.0 (285887) unhandled promise rejection: Cannot set properties of undefined (setting 'Authorization')
                                    2023-02-04 15:43:19.339 - error: roborock.0 (285887) TypeError: Cannot set properties of undefined (setting 'Authorization')
                                    at /opt/iobroker/node_modules/iobroker.roborock/main.js:133:43
                                    at async Roborock.onReady (/opt/iobroker/node_modules/iobroker.roborock/main.js:160:15)
                                    2023-02-04 15:43:19.339 - error: roborock.0 (285887) Cannot set properties of undefined (setting 'Authorization')
                                    2023-02-04 15:43:19.340 - info: roborock.0 (285887) terminating
                                    2023-02-04 15:43:19.341 - warn: roborock.0 (285887) Terminated (UNCAUGHT_EXCEPTION): Without reason
                                    2023-02-04 15:43:19.881 - error: host.pIOBroker instance system.adapter.roborock.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                                    2023-02-04 15:43:19.881 - info: host.pIOBroker Restart adapter system.adapter.roborock.0 because enabled
                                    2023-02-04 15:43:19.881 - warn: host.pIOBroker Do not restart adapter system.adapter.roborock.0 because restart loop detected
                                    • copystring
                                      copystring @Hunter 0 last edited by
                                      @hunter-0 Bitte hier mit einklinken: https://github.com/copystring/ioBroker.roborock/issues/57
                                      inidona created this issue in copystring/ioBroker.roborock
                                      closed Adaper crashes after start #57
                                      • O
                                        oxident @copystring last edited by
                                        Ich hab mal eine blöde Frage zur Kartendarstellung.
                                        Derzeit habe ich sie als einfaches Image-Element im Vis dargestellt. Quelle ist der Datenpunkt der Map.
                                        Das klappt auch super, aber die Skalierung ist natürlich Käse. Da ich versuche, es responsive zu gestalten, dachte ich, ein simples Setzen der Breite auf "calc (100% - 50px)" würde funktionieren. Die Karte bleibt aber viel zu breit.
                                        Die "Strecken"-Eigenschaft vom Image-Widget bringt es zwar auf die richtige Breite, aber natürlich nicht proportional.
                                        Habt ihr einen Tipp für mich?
                                          joerg0085 last edited by
                                          Hallo zusammen, ich hatte den Adapter letzte Woche "eigentlich" schon am laufen.
                                          Nach dem letzten Update auf die aktuelle GIT Version wird er nur einmal kurz Grün, in der Roborock app bekomme mich auch eine Push Notification dass jemand anderes sich eingeloggt hat.
                                          Ohne Zugangsdaten bleibt der Adapter auch Grün
                                          Könnt ihr was mit der Log Meldung anfangen?
                                          JS NPM ..alles aktuell
                                            Das wird gerade gefixt. Siehe
                                            https://github.com/copystring/ioBroker.roborock/tree/catch_errors_on_initialization
                                            766
                                            242758
