    4. ZigBee neue Version 1.7.x
      Aragon @arteck last edited by Aragon
      @arteck es ist schon wieder passiert, ohne dass ich den Zigbee Adapter neu Gestartet habe.
      Bin heute von der Arbeit gekommen und es Leuchteten mal wieder bei vier Rollladenschaltern die Koppel LED´s dauerhaft.
      so sehen meine Rollladenschalter eigentlich aus.
      Bei dem Obersten Taster leuchtet dann die LED Dauerhaft.
      zigbee.0
      	2023-01-25 20:16:32.114	warn	This object will not be created in future versions. Please report this to the developer.
      zigbee.0
      	2023-01-25 20:16:32.114	warn	Object zigbee.0.xxxxxxxxxxxxxx.backlight_mode is invalid: obj.common.states has an invalid type! Expected "object", received "string"
      zigbee.0
      	2023-01-25 20:16:32.113	warn	This object will not be created in future versions. Please report this to the developer.
      zigbee.0
      	2023-01-25 20:16:32.112	warn	Object zigbee.0.xxxxxxxxxxxxxx.moving is invalid: obj.common.states has an invalid type! Expected "object", received "string"
      zigbee.0
      	2023-01-25 20:16:32.108	warn	This object will not be created in future versions. Please report this to the developer.
      zigbee.0
      	2023-01-25 20:16:32.107	warn	Object zigbee.0.xxxxxxxxxxxxxx.state is invalid: obj.common.states has an invalid type! Expected "object", received "string"
      zigbee.0
      	2023-01-25 20:16:32.066	warn	This object will not be created in future versions. Please report this to the developer.
      zigbee.0
      	2023-01-25 20:16:32.065	warn	Object xxxxxxxxxxxxxx.backlight_mode is invalid: obj.common.states has an invalid type! Expected "object", received "string"
      zigbee.0
      	2023-01-25 20:16:32.065	warn	This object will not be created in future versions. Please report this to the developer.
      zigbee.0
      	2023-01-25 20:16:32.064	warn	Object xxxxxxxxxxxxxx.moving is invalid: obj.common.states has an invalid type! Expected "object", received "string"
      zigbee.0
      	2023-01-25 20:16:32.064	warn	This object will not be created in future versions. Please report this to the developer.
      zigbee.0
      	2023-01-25 20:16:32.063	warn	Object xxxxxxxxxxxxxx.state is invalid: obj.common.states has an invalid type! Expected "object", received "string"
      zigbee.0
      	2023-01-25 20:16:32.011	warn	Device 'xxxxxxxxxxxxxx' announced itself
      Das wird mir im Protokoll nach dem erneuten Koppeln Angezeigt.
      • nukleuz
        nukleuz last edited by
        wie kann ich meine Messsteckdosen zurücksetzen (Verbrauchswerte)?
        Gibt es hier im Adapter so etwas wie eine DEV-Console?
        Hier der Auszug von Z2M:
        https://www.zigbee2mqtt.io/devices/TS011F_plug_3.html#reset-energy
        Reset energy
        To reset "Sum of consumed energy", use the Dev console and execute: Endpoint: 1 Cluster: 0x00 Command: 0 Payload: (don't change this)
        Next time the plug gets polled, "Sum of consumed energy" will start from zero again
        Danke für Info hierzu...
        nukleuz 1 Reply Last reply Reply Quote 0
        • nukleuz
          nukleuz @nukleuz last edited by
          @nukleuz
          Mal wieder... Wer lesen kann und so...
          Mit dem zweiten Anlauf hat es dann auch funktioniert - Instanz-Einstellungen-Entwickler:
          Danke! 🙂
            rotamint last edited by rotamint
            Guten Morgen zusammen, bekomme folgende Fehlermeldung (V1.8.10 / Conbee2 V0-0.38.120.0. / rev 0x26780700):
            zigbee.0
            	2023-01-31 07:32:37.321	warn	This object will not be created in future versions. Please report this to the developer.
            zigbee.0
            	2023-01-31 07:32:37.320	warn	Object 54ef44100064fdf6.reset_nopresence_status is invalid: obj.common.states has an invalid type! Expected "object", received "string"
            So sieht der Datenpunkt aus (ist aber dann "ohne Funktion":
            Der Datenpunkt mit Funktion (aber dann auch mit o. g. Fehlermeldung, leider aber auch nur bis zum nächsten Adapter-Neustart):
            Kann ich den Wert "Reset:Reset" irgendwie "dauerhaft" speichern?
            Was kann ich gegen die Fehlermeldung machen?
            Danke für Eure Hilfe!
            LG S.
              arteck Developer Most Active @rotamint last edited by
              @rotamint zeigmal die info kachel von dem Gerät
                rotamint @arteck last edited by
                @arteck Meinst Du das?
                arteck 2 Replies Last reply Reply Quote 0
                  arteck Developer Most Active @rotamint last edited by arteck
                  @rotamint ahh das ist der neue FP1..
                  ist ein Fehler im converter.. https://github.com/Koenkk/zigbee2mqtt/issues/16433
                  arteck created this issue in Koenkk/zigbee2mqtt
                  closed state from rtczcgq11lm is wrong #16433
                    @arteck Danke für's Annehmen meines Problems... Fehler im Converter... D. h. ? Auf's nächste Update warten?
                    Dankeschön! LG. S.
                      @rotamint erstmal abwarten was die sagen
                        @rotamint so wir sind weiter
                        ich brauche die shepherd.db aus dem zigbee_0 Ordner
                        ich muss mir das bei mir anschauen.. da setzten wir was falsch um..
                          maxpd last edited by maxpd
                          ich wollte bei meinem Aqara Vibrationssensor die Empfindlichkeit anpassen gemäß: https://www.smarthomejetzt.de/empfindlichkeit-des-lumi-vibration-vibrationssensor-von-aqara-am-zigbee-stick-cc2531-einstellen/
                          Allerdings erhalte ich nur die Fehlermeldung: unknown attribute.
                          Das Attribut findet sich auch nicht über die Dropdownliste. Trotzdem kommt ein OK vom Adapter zurück.
                            @arteck Danke Arthur. Ich habe sie eben "gesichert", bin jetzt aber unschlüssig auf welchem Wege ich sie dir zukommen lassen kann? Hier öffentlich Posten fand ich jetzt aufgrund der Adressen eher sub-optimal, wie siehst Du das? Danke. LG S.
                            Edit: Datei zu Arthur geschickt.
                              maxpd @maxpd last edited by maxpd
                              @maxpd
                              Gegebenenfalls über den Datenpunkt Sensitivity, den man einstellen kann.
                                haumichel last edited by
                                ich habe heute auf die Version 1.8.10 aktualisiert. Seit dem kann ich bei 4 Ikea Strahlern, die ich in einer Gruppe zusammengefasst habe, die Lichtfarbe nicht mehr einstellen.
                                Ist da evtl. schon etwas bekannt?
                                Zusätzlich ist mir aufgefallen, dass der Status der Config immer auf false steht, obwohl die Config anscheinend funktioniert.
                                zigbee.0
                                	2023-03-14 17:30:07.027	info	DeviceConfigure successful 0x94deb8fffecaf033 TRADFRI bulb GU10 CWS 345lm
                                zigbee.0
                                	2023-03-14 17:30:06.871	info	Configuring 0x94deb8fffecaf033 TRADFRI bulb GU10 CWS 345lm
                                Vielen Dank
                                  haumichel @haumichel last edited by
                                  @haumichel
                                  Hat sich erledigt. Nach ca. 2 Stunden war auch die Möglichkeit zur Einstellung der Farbe wieder vorhanden.
                                  • David G.
                                    David G. last edited by
                                    Weiter oben habe ich den Fehler schonmal gefunden.
                                    Dort wurde es auf Osram geschoben.
                                    Bei mir betrifft es Ikea Birnen. Hat bisher immer geklappt.
                                    zigbee.0
                                    2023-03-17 19:03:02.144	error	Update of '0x60a423fffef0ff05' failed (No new image available)
                                    Adapter ist in der 1.8.10 installiert
                                      Rushmed Most Active @David G. last edited by Rushmed
                                      @david-g Das kann ich bestätigen. Habe die selbe Adapterversion. Diverse Updates werden angeboten aber können wegen o.g. Fehlermeldung nicht durchgeführt werden. Betrifft bei mir aktuell Ikea, Hue und (noname Aliexpress) Steckdoesen die ich früher schon über den Adapter aktualisieren konnte.
                                        mirko3107 last edited by mirko3107
                                        gibt es irgendwelche bekannten Probleme zwischen Ledvance-LEDs, Aqara-Sensoren und Tradfri-Repeatern?
                                        Hab einen CC2652P mit Firmware vom 26.12.22, an den ich alles anlernen konnte. Aber nach ein paar Stunden sind alle
                                        Aqara-Sensoren nicht mehr aktiv.
                                        Heute morgen kommt das im Log:
                                        zigbee.0 2023-03-26 10:21:22.509	debug	DeviceAvailability:Non-pingable device 0x00158d0003217295 lumi.weather was last seen '46258.094' seconds ago.
                                        zigbee.0 2023-03-26 10:21:22.506	debug	DeviceAvailability:Non-pingable device 0x00158d0002ad8f67 lumi.sensor_switch.aq3 was last seen '1638.633' seconds ago.
                                        zigbee.0 2023-03-26 10:21:22.502	debug	DeviceAvailability:Non-pingable device 0x00158d0004448d07 lumi.sensor_magnet.aq2 was last seen '48966.097' seconds ago.
                                        zigbee.0 2023-03-26 10:21:22.498	debug	DeviceAvailability:Non-pingable device 0x00158d00041cbb3e lumi.sensor_magnet.aq2 was last seen '2104.881' seconds ago.
                                        zigbee.0 2023-03-26 10:21:22.495	debug	DeviceAvailability:Non-pingable device 0x00158d0004448ccd lumi.sensor_magnet.aq2 was last seen '35402.185' seconds ago.
                                        zigbee.0 2023-03-26 10:21:22.491	debug	DeviceAvailability:Non-pingable device 0x00158d0004448be7 lumi.sensor_magnet.aq2 was last seen '38934.898' seconds ago.
                                        zigbee.0 2023-03-26 10:21:22.489	debug	DeviceAvailability:Non-pingable device 0x00158d00032c2ad0 lumi.sensor_motion.aq2 was last seen '30499.902' seconds ago.
                                        zigbee.0 2023-03-26 10:21:22.485	debug	DeviceAvailability:Non-pingable device 0x00158d000317587d lumi.remote.b186acn01 was last seen '370.746' seconds ago.
                                        zigbee.0 2023-03-26 10:21:22.482	debug	DeviceAvailability:Non-pingable device 0x00158d000346825d lumi.sensor_magnet.aq2 was last seen '845.898' seconds ago.
                                        zigbee.0 2023-03-26 10:21:22.480	debug	DeviceAvailability:Non-pingable device 0x00158d0003042ed0 lumi.remote.b186acn01 was last seen '37995.113' seconds ago.
                                        zigbee.0 2023-03-26 10:21:22.477	debug	DeviceAvailability:Non-pingable device 0x00158d00044583c7 lumi.sensor_magnet.aq2 was last seen '2736.814' seconds ago.
                                        zigbee.0 2023-03-26 10:21:22.475	debug	DeviceAvailability:Non-pingable device 0x00158d00036b1b6f lumi.weather was last seen '40451.71' seconds ago.
                                        Kanal läuft auf 16, weil 11 voll war.
                                        Gibts da nen Trick?
                                        Neuschwansteini 1 Reply Last reply Reply Quote 0
                                        • Neuschwansteini
                                          Neuschwansteini @mirko3107 last edited by
                                          @mirko3107
                                          wenn ich den Namen Ledvance und Zigbee hoere, dann stellen sich die Nackenhaare...
                                          gibt wohl irgendwo, dass das funktioniert, aber aus dem Forum hier und meine eigene Erfahrung sagt, Ledvance gibst du wieder zurueck oder verkaufst den Kram, ist sowas von unzuverlaessig...
                                          Hatte ne Lampe und n paar Steckdosen, waren unbrauchbar und gingen nach ein paar Tagen wieder zurueck.
                                            die Ledvance-LEDs waren nie unzuverlässig, der Aqara-Kram verschwindet, wenn er im selben Netz wie die Ledvance schwebt.
                                            Hab die Systeme jetzt durch einen zweiten CC2531 getrennt, die Ledvance beim CC2652P und der Aqara-Kram beim CC2531.
                                            Bis jetzt läufts.
                                            Neuschwansteini arteck 2 Replies Last reply Reply Quote 0
                                            31.7k
                                            79.8k
                                            1.7 backup icons zigbee
                                            40
                                            217
                                            24768
