    4. Ecovacs Deebot Adapter: Informationen und Praxistipps
      broady @mrbungle64 last edited by
      @mrbungle64 Danke, das hat erstmal geklappt. Datenpunkte und Karten sind jetzt vorhanden. Bekomme allerdings im Log die folgenden Fehlermeldungen:
      ecovacs-deebot.0
      	2023-01-30 18:19:11.684	warn	Error message received: The module '/opt/iobroker/node_modules/canvas/build/Release/canvas.node'was compiled against a different Node.js version usingNODE_MODULE_VERSION 108. This version of Node.js requiresNODE_MODULE_VERSION 93. Please try re-compiling or re-installingthe module (for instance, using `npm rebuild` or `npm install`).
      ecovacs-deebot.0
      	2023-01-30 18:19:11.670	warn	Error message received: The module '/opt/iobroker/node_modules/canvas/build/Release/canvas.node'was compiled against a different Node.js version usingNODE_MODULE_VERSION 108. This version of Node.js requiresNODE_MODULE_VERSION 93. Please try re-compiling or re-installingthe module (for instance, using `npm rebuild` or `npm install`).
      ecovacs-deebot.0
      	2023-01-30 18:19:11.658	warn	Error message received: The module '/opt/iobroker/node_modules/canvas/build/Release/canvas.node'was compiled against a different Node.js version usingNODE_MODULE_VERSION 108. This version of Node.js requiresNODE_MODULE_VERSION 93. Please try re-compiling or re-installingthe module (for instance, using `npm rebuild` or `npm install`).
      ecovacs-deebot.0
      	2023-01-30 18:19:11.626	warn	Error message received: The module '/opt/iobroker/node_modules/canvas/build/Release/canvas.node'was compiled against a different Node.js version usingNODE_MODULE_VERSION 108. This version of Node.js requiresNODE_MODULE_VERSION 93. Please try re-compiling or re-installingthe module (for instance, using `npm rebuild` or `npm install`).
      ecovacs-deebot.0
      	2023-01-30 18:18:17.596	warn	Error message received: The module '/opt/iobroker/node_modules/canvas/build/Release/canvas.node'was compiled against a different Node.js version usingNODE_MODULE_VERSION 108. This version of Node.js requiresNODE_MODULE_VERSION 93. Please try re-compiling or re-installingthe module (for instance, using `npm rebuild` or `npm install`).
      ecovacs-deebot.0
      	2023-01-30 18:18:17.579	warn	Error message received: The module '/opt/iobroker/node_modules/canvas/build/Release/canvas.node'was compiled against a different Node.js version usingNODE_MODULE_VERSION 108. This version of Node.js requiresNODE_MODULE_VERSION 93. Please try re-compiling or re-installingthe module (for instance, using `npm rebuild` or `npm install`).
      ecovacs-deebot.0
      	2023-01-30 18:18:17.572	warn	Error message received: The module '/opt/iobroker/node_modules/canvas/build/Release/canvas.node'was compiled against a different Node.js version usingNODE_MODULE_VERSION 108. This version of Node.js requiresNODE_MODULE_VERSION 93. Please try re-compiling or re-installingthe module (for instance, using `npm rebuild` or `npm install`).
      ecovacs-deebot.0
      	2023-01-30 18:18:17.563	warn	Error message received: The module '/opt/iobroker/node_modules/canvas/build/Release/canvas.node'was compiled against a different Node.js version usingNODE_MODULE_VERSION 108. This version of Node.js requiresNODE_MODULE_VERSION 93. Please try re-compiling or re-installingthe module (for instance, using `npm rebuild` or `npm install`).
      mrbungle64 1 Reply Last reply Reply Quote 0
      • mrbungle64
        mrbungle64 Developer @broady last edited by
        @broady sagte in Ecovacs Deebot Adapter: Informationen und Praxistipps:
        https://github.com/mrbungle64/ioBroker.ecovacs-deebot/wiki/FAQ#nodejs-upgrade
          @mrbungle64 Danke, das hat geklappt.
            @mrbungle64 Wie lassen sich die % Werte für Filter und Bürsten unter "ecovacs-deebot.0.consumable" zurücksetzen? Gibt es da einen Datenpunkt?
            • mrbungle64
              Ja, das ist aber für den Deebot OZMO 905 noch nicht freigeben.
              Soll ich das mal tun? Dann müsstest du mir aber bitte Feedback geben, ob die Funktion bei deinem Gerät funktioniert hat 🙂
                @mrbungle64 Das wäre super. Ich gebe dann Rückmeldung. Ich bin gerade dabei eine VIS zu bauen.
                • mrbungle64
                  Ok, ich habe gerade die 1.4.12-alpha.18 released und die Änderung noch mit aufgenommen.
                    @mrbungle64 Ich habe den 1.4.12-alpha.18 installiert. Die Funktion für das Zurücksetzen der % Werte für Bürsten und Filter für den DEEBOT OZMO 905 fuktioniert problemlos.
                      sigi234 Forum Testing Most Active @mrbungle64 last edited by
                      @mrbungle64
                      die Voreinstellungen im Adapter holt er sich von der App? (Vorauswahl verwenden)
                      • mrbungle64
                        mrbungle64 Developer @sigi234 last edited by
                        @sigi234 sagte in Ecovacs Deebot Adapter: Informationen und Praxistipps:
                        @mrbungle64
                        Nein, das sind ja weitgehend Einstellungen die sich direkt auf Funktionen im Adapter beziehen.
                        Die Vorauswahl kommt zum aus einem Dictionary aus der Library und zusätzlich aus einem weiteren Dictionary im Adapter. Dort sind versch. Eigenschaften und (Standard-)Freigaben für die einzelnen Modelle und deren Varianten festgehalten. Die Deebot API liefert diese Informationen leider nicht (nach aktuellen Stand).
                        Das ist alles ein bisschen undurchsichtig mit der "Vorauswahl", aber es sind halt auch recht viele Modelle-Varianten von Ecovacs und yeedi. Leider habe ich es auch noch nicht implementiert, dass in den Einstellungen schon das konkrete Modell berücksichtigt wird.
                          @mrbungle64
                          N8 bekommen , verbunden und läuft.
                          Installierte Version:
                          1.4.12
                          Sind ja eine Menge DP. Teste jetzt mal. Er lädt gerade auf, dann mache ich meine erste Kartierung.
                            sigi234 Forum Testing Most Active @mrbungle64 last edited by sigi234
                            @mrbungle64
                            wenn ich die Objekte von den SpotAreas lösche, werden die wieder erstellt?
                            Durch das erstellen der Maps sind die durcheinander, jetzt habe ich eine funktionierende Map erstellt .
                            Eine Live Karte gibt es noch nicht?
                            • mrbungle64
                              @mrbungle64
                              Ja, die werden wieder neu erstellt. Damit es direkt gemacht wird starte einfach die Adapter Instanz danach neu.
                              Nein, leider noch nicht. Ich hoffe, dass ich dafür in nicht allzu ferner Zukunft mal die Zeit finde 😉
                                @mrbungle64 sagte in Ecovacs Deebot Adapter: Informationen und Praxistipps:
                                Super, kann man dir einen Kaffee ausgeben? Sehe keinen spenden Button.
                                • mrbungle64
                                  Aktuell (noch) nicht. Aber danke trotzdem für die Bereitschaft mir einen Kaffee ausgeben 🙂
                                    Bitte sehr,es wird schon:
                                    Screenshot (5304).png Screenshot (5303).png Screenshot (5302).pngScreenshot (5306).pngScreenshot (5390).png
                                      Langer @mrbungle64 last edited by
                                      @mrbungle64
                                      Als erstes Danke für Deine Arbeit, auch ich würde Dir gerne einen Kaffee spendieren.
                                      Gestern ist unser neuer "DEEBOT X1 OMNI " angekommen, solltest Du Daten oder sonstiges brauchen bitte melden.
                                      MfG
                                      Wastl
                                      • mrbungle64
                                        mrbungle64 Developer @Langer last edited by
                                        @langer sagte in Ecovacs Deebot Adapter: Informationen und Praxistipps:
                                        @mrbungle64
                                        Hallo Wastl,
                                        danke für das Angebot - inzwischen habe ich auch einen DEEBOT X1 (Turbo).
                                        Wenn Du möchtest kannst du direkt die aktuelle Alpha von GitHub installieren - da sind nun einige Datenpunkte für den X1 hinzugekommen 🙂
                                        MfG
                                        Wastl
                                        • mrbungle64
                                          mrbungle64 Developer @mrbungle64 last edited by mrbungle64
                                          Ab der Version 1.4.13-alpha.11 habe ich außerdem eine andere URL für die Deebot API in Verwendung.
                                          Die scheint deutlich stabiler zu sein als die bisher verwendete.
                                          Wer also noch die "Request failed with status code 502/504" Warnungen im Log hat, kann auch gerne mal die aktuelle Alpha ausprobieren 🙂
                                            @mrbungle64
                                            kann man beib DP :
                                            ecovacs-deebot.0.cleaninglog.last20Logs
                                            noch den Namen der Spot Area einbauen? (ecovacs-deebot.0.map.990111999.spotAreas.2.spotAreaName)
                                            1.0k
                                            deebot ecovacs ecovacs-deebot adapter how-to howto staubsaugerroboter vacuum
                                            28
                                            171
                                            28978
