    4. jarvis v3.1.x - just another remarkable vis
      johannes1702 @MCU last edited by
      @mcu Ja, mache ich nachher 🙂
        johannes1702 @MCU last edited by johannes1702
        @mcu Schau mal, passt das so?
        Formatierung geht etwas flöten, da ich es in Word erstellt habe. Kann dir auch gerne das Word senden.
        Prerequisite:
        • Running instance of Cloudflare Tunnel
        • Check this video tutorial for example: https://youtu.be/Q5dG8g4-Sx0
        • Details on authentication with Cloudflare: https://youtu.be/wdmbAo02ktQ
        • Cloudflare seems to be free, but sometimes they request to provide a payment method. I was not asked to do so, but I saw this in some tutorials.
        Setting up the access to JarVIS in Cloudflare:
        Short:
        Create two subdomains with the same name, one pointing to the Web Port and one pointing to the Web Socket Port of JarVIS. Then create an application with the same subdomain.
        Longer:
        Login to Cloudflare, go to your Zero Trust Dashboard: https://one.dash.cloudflare.com/
        Select Access – Tunnels – Configure (your Tunnel)
        Click the Public Hostname tab, then Add a public hostname
        Choose a subdomain select your domain, chose type HTTP and add the IP + Web Port (IP:PORT)
        Repeat it for the Socket Port, so make all entries exactly the same, except IP:8400
        So in the end it will look like this:
        Then click Applications in the menu, create a new Self Hosted Application, e.g. name it jarvis, Subdomain = Jarvis, select your domain. Keep path empty.
        Then add a policy (see second video for that too) and then save.
        You should then be able to open your JarVIS dashboard with an external url such as https://jarvis.example-home-domain.com. Including automatic SSL encryption and authentication based on your selection. Make sure you set up authentication!
          MCU last edited by
          @johannes1702
          Danke. 1:1 übernommen.
          https://mcuiobroker.gitbook.io/jarvis-infos/jarvis-v3/besonderheiten-v3/allgemein/browser-connections/cloudflare-tunnel-johannes1702
          Version von jarvis ist doch egal?
            @mcu Bzgl. Version weiß ich nicht. Mit der aktuellen stable aber auf jeden Fall.
              MCU @johannes1702 last edited by
              @johannes1702 v3.1.2?
                @mcu Ja, genau
                  johannes1702 @johannes1702 last edited by
                  @johannes1702 sagte in jarvis v3.1.x - just another remarkable vis
                  Wenn es jemand nachgebaut hat, freue ich mich zu erfahren, ob es bei euch geklappt hat 😊
                    Flowski last edited by Flowski
                    Hallo, habe das Problem dass ich bei nachfolgenden Buttons 2x drücken muss bevor ein Befehl vom Robbi ausgeführt wird:
                    1x drücken, es erscheint ein Kreis statt dem Logo, drücke ich erneut, wird der Befehl ausgeführt
                    jemand eine Idee? Trigger Element ist Button Action
                      MCU @Flowski last edited by
                      @flowski Als Taster einstellen. Komponenten Optionen zum IconButtonAction.
                        dering last edited by
                        ich hab Schwierigkeiten mit dem Layout.
                        Ich habe ein Tablet welches im Hochformat die Dinge anzeigen soll.
                        Die Widgets werden zu gleichen Teilen angezeigt. Ich möchte das aber anders haben:
                        Zum Beispiel Datum und Uhrzeit soll 3/4 ausfüllen. Die Temperatur 1/4.
                        Die Termine (zweiter roter Kasten) soll über die ganze breite angezeigt werden.
                        Wenn ich den Browser größer ziehe, dann werden die Verhältnisse richtig gesetzt:
                        Ich hab mit den Breakpoints rumgespielt, führt alles nicht zum Ziel.
                        Hat jemand Ideen was ich noch wie einstellen könnte?
                          MCU last edited by
                          @dering Wie sind denn de Breakpoints eingestellt?
                          Ergebnis von dem HTML?
                          https://mcuiobroker.gitbook.io/jarvis-infos/jarvis-v3/system-effektprog./bildschirmgroesse-handy-jarvis
                            marsmännchen last edited by
                            Kann mir jemand einen Tipp geben was ich mit HTMLTable falsch mache?
                            Ich habe von einem Script für Lichtüberwachung:
                            <table style='width:100%; border-collapse: collapse; border: 0px solid black;'><caption><div style='height: 20px; padding-top: 0px; padding-bottom: 5px; font-size:1.4em; font-weight: bold;'>Lichterstatus</div></caption><thead><tr><th width='100%' style='text-align:center; height: 20px; padding-bottom: 5px;'><img width=25px height=25px style= vertical-align:-5px src=img/bulb_on.png >Badezimmer 1<br><img width=25px height=25px style= vertical-align:-5px src=img/bulb_on.png >Küche 1<br><img width=25px height=25px style= vertical-align:-5px src=img/bulb_on.png >Korridor 1<br><img width=25px height=25px style= vertical-align:-5px src=img/bulb_on.png >ZoeBuero 1<br><img width=25px height=25px style= vertical-align:-5px src=img/bulb_on.png >ZoeSchlaf 1</th></tr></thead><tbody></tbody></table><div style='height: 100%; overflow-y:auto; overflow-x:hidden;'><table style='width:100%; border-collapse: collapse;'><thead><tr><th width='40px' style='text-align:left;'</th><th width='20px' style='text-align:center;'></th><th style='text-align:left;'></th></tr></thead><tbody><tr><td style='border: 1px solid black; background-color:green;'><img height=40px src='/icons-mfd-svg/light_light.svg'></td><td style='border: 1px solid black; padding-left: 10px; padding-right: 10px; font-size:1.1em; font-weight: bold; text-align:center; background-color:green;'>0</td><td style='border: 1px solid black; padding-left: 10px; padding-right: 10px; font-size:1.1em; font-weight: bold; background-color:green;'>Ankleide<br><div style='font-size:0.7em; font-weight:normal;'>ausgeschaltet: 17:03:09 05.02.2023</div></td></tr><tr><td style='border: 1px solid black; background-color:red;'><img height=40px src='/icons-mfd-svg/light_light_dim_100.svg'></td><td style='border: 1px solid black; padding-left: 10px; padding-right: 10px; font-size:1.1em; font-weight: bold; text-align:center;background-color:red;'>1</td><td style='border: 1px solid black; padding-left: 10px; padding-right: 10px; font-size:1.1em; font-weight: bold; background-color:red;'>Badezimmer<br><div style='font-size:0.8em; font-weight:bold;'>eingeschaltet: 16:52:49 05.02.2023</div></td></tr><tr><td style='border: 1px solid black; background-color:green;'><img height=40px src='/icons-mfd-svg/light_light.svg'></td><td style='border: 1px solid black; padding-left: 10px; padding-right: 10px; font-size:1.1em; font-weight: bold; text-align:center; background-color:green;'>0</td><td style='border: 1px solid black; padding-left: 10px; padding-right: 10px; font-size:1.1em; font-weight: bold; background-color:green;'>Office<br><div style='font-size:0.7em; font-weight:normal;'>ausgeschaltet: 16:55:55 05.02.2023</div></td></tr><tr><td style='border: 1px solid black; background-color:green;'><img height=40px src='/icons-mfd-svg/light_light.svg'></td><td style='border: 1px solid black; padding-left: 10px; padding-right: 10px; font-size:1.1em; font-weight: bold; text-align:center; background-color:green;'>0</td><td style='border: 1px solid black; padding-left: 10px; padding-right: 10px; font-size:1.1em; font-weight: bold; background-color:green;'>Eingang<br><div style='font-size:0.7em; font-weight:normal;'>ausgeschaltet: 22:53:19 04.02.2023</div></td></tr><tr><td style='border: 1px solid black; background-color:green;'><img height=40px src='/icons-mfd-svg/light_light.svg'></td><td style='border: 1px solid black; padding-left: 10px; padding-right: 10px; font-size:1.1em; font-weight: bold; text-align:center; background-color:green;'>0</td><td style='border: 1px solid black; padding-left: 10px; padding-right: 10px; font-size:1.1em; font-weight: bold; background-color:green;'>Essbereich<br><div style='font-size:0.7em; font-weight:normal;'>ausgeschaltet: 17:32:06 12.01.2023</div></td></tr><tr><td style='border: 1px solid black; background-color:red;'><img height=40px src='/icons-mfd-svg/light_light_dim_100.svg'></td><td style='border: 1px solid black; padding-left: 10px; padding-right: 10px; font-size:1.1em; font-weight: bold; text-align:center;background-color:red;'>1</td><td style='border: 1px solid black; padding-left: 10px; padding-right: 10px; font-size:1.1em; font-weight: bold; background-color:red;'>Küche<br><div style='font-size:0.8em; font-weight:bold;'>eingeschaltet: 16:31:21 05.02.2023</div></td></tr><tr><td style='border: 1px solid black; background-color:red;'><img height=40px src='/icons-mfd-svg/light_light_dim_100.svg'></td><td style='border: 1px solid black; padding-left: 10px; padding-right: 10px; font-size:1.1em; font-weight: bold; text-align:center;background-color:red;'>1</td><td style='border: 1px solid black; padding-left: 10px; padding-right: 10px; font-size:1.1em; font-weight: bold; background-color:red;'>Korridor<br><div style='font-size:0.8em; font-weight:bold;'>eingeschaltet: 16:46:37 05.02.2023</div></td></tr><tr><td style='border: 1px solid black; background-color:green;'><img height=40px src='/icons-mfd-svg/light_light.svg'></td><td style='border: 1px solid black; padding-left: 10px; padding-right: 10px; font-size:1.1em; font-weight: bold; text-align:center; background-color:green;'>0</td><td style='border: 1px solid black; padding-left: 10px; padding-right: 10px; font-size:1.1em; font-weight: bold; background-color:green;'>Schlafzimmer<br><div style='font-size:0.7em; font-weight:normal;'>ausgeschaltet: 23:42:36 04.02.2023</div></td></tr><tr><td style='border: 1px solid black; background-color:green;'><img height=40px src='/icons-mfd-svg/light_light.svg'></td><td style='border: 1px solid black; padding-left: 10px; padding-right: 10px; font-size:1.1em; font-weight: bold; text-align:center; background-color:green;'>0</td><td style='border: 1px solid black; padding-left: 10px; padding-right: 10px; font-size:1.1em; font-weight: bold; background-color:green;'>Speis<br><div style='font-size:0.7em; font-weight:normal;'>ausgeschaltet: 14:32:39 05.02.2023</div></td></tr><tr><td style='border: 1px solid black; background-color:green;'><img height=40px src='/icons-mfd-svg/light_light.svg'></td><td style='border: 1px solid black; padding-left: 10px; padding-right: 10px; font-size:1.1em; font-weight: bold; text-align:center; background-color:green;'>0</td><td style='border: 1px solid black; padding-left: 10px; padding-right: 10px; font-size:1.1em; font-weight: bold; background-color:green;'>Vorraum<br><div style='font-size:0.7em; font-weight:normal;'>ausgeschaltet: 23:39:12 04.02.2023</div></td></tr><tr><td style='border: 1px solid black; background-color:green;'><img height=40px src='/icons-mfd-svg/light_light.svg'></td><td style='border: 1px solid black; padding-left: 10px; padding-right: 10px; font-size:1.1em; font-weight: bold; text-align:center; background-color:green;'>0</td><td style='border: 1px solid black; padding-left: 10px; padding-right: 10px; font-size:1.1em; font-weight: bold; background-color:green;'>Waschraum<br><div style='font-size:0.7em; font-weight:normal;'>ausgeschaltet: 15:41:38 05.02.2023</div></td></tr><tr><td style='border: 1px solid black; background-color:green;'><img height=40px src='/icons-mfd-svg/light_light.svg'></td><td style='border: 1px solid black; padding-left: 10px; padding-right: 10px; font-size:1.1em; font-weight: bold; text-align:center; background-color:green;'>0</td><td style='border: 1px solid black; padding-left: 10px; padding-right: 10px; font-size:1.1em; font-weight: bold; background-color:green;'>WC<br><div style='font-size:0.7em; font-weight:normal;'>ausgeschaltet: 14:50:16 05.02.2023</div></td></tr><tr><td style='border: 1px solid black; background-color:green;'><img height=40px src='/icons-mfd-svg/light_light.svg'></td><td style='border: 1px solid black; padding-left: 10px; padding-right: 10px; font-size:1.1em; font-weight: bold; text-align:center; background-color:green;'>0</td><td style='border: 1px solid black; padding-left: 10px; padding-right: 10px; font-size:1.1em; font-weight: bold; background-color:green;'>Wohnzimmer<br><div style='font-size:0.7em; font-weight:normal;'>ausgeschaltet: 17:45:52 04.02.2023</div></td></tr><tr><td style='border: 1px solid black; background-color:green;'><img height=40px src='/icons-mfd-svg/light_light.svg'></td><td style='border: 1px solid black; padding-left: 10px; padding-right: 10px; font-size:1.1em; font-weight: bold; text-align:center; background-color:green;'>0</td><td style='border: 1px solid black; padding-left: 10px; padding-right: 10px; font-size:1.1em; font-weight: bold; background-color:green;'>Yogaraum<br><div style='font-size:0.7em; font-weight:normal;'>ausgeschaltet: 17:03:12 05.02.2023</div></td></tr><tr><td style='border: 1px solid black; background-color:red;'><img height=40px src='/icons-mfd-svg/light_light_dim_100.svg'></td><td style='border: 1px solid black; padding-left: 10px; padding-right: 10px; font-size:1.1em; font-weight: bold; text-align:center;background-color:red;'>1</td><td style='border: 1px solid black; padding-left: 10px; padding-right: 10px; font-size:1.1em; font-weight: bold; background-color:red;'>ZoeBuero<br><div style='font-size:0.8em; font-weight:bold;'>eingeschaltet: 16:40:30 05.02.2023</div></td></tr><tr><td style='border: 1px solid black; background-color:red;'><img height=40px src='/icons-mfd-svg/light_light_dim_100.svg'></td><td style='border: 1px solid black; padding-left: 10px; padding-right: 10px; font-size:1.1em; font-weight: bold; text-align:center;background-color:red;'>1</td><td style='border: 1px solid black; padding-left: 10px; padding-right: 10px; font-size:1.1em; font-weight: bold; background-color:red;'>ZoeSchlaf<br><div style='font-size:0.8em; font-weight:bold;'>eingeschaltet: 16:36:11 05.02.2023</div></td></tr></tbody></table></div>
                            Dann erstelle ich ein Gerät - > Sonstiges mit dem Datenpunkt "html" worin der Datenpunkt von IoBroker eingetragen ist:
                            Dann ein Widget "HTMLTable":
                            Dieses Widget füge ich im Layout ein,
                            ich sehe aber nur:
                            Kann es vielleicht daran liegen das die HTML Tabelle mit "</div> endet?
                              MCU @marsmännchen last edited by
                              @marsmännchen Zeig malndas Script. Und ja vermutlich liegt es am </div>.
                                marsmännchen @MCU last edited by marsmännchen
                                @mcu
                                Ok, aber zum Script kann ich dir nur sagen, das ist von einem anderen User, ich hab es nur minimal angepasst:
                                //der-eine 05.06.2020
                                //Ursprüngliches Skript: https://github.com/Pittini/iobroker-Fensterauswertung
                                //Das folgende Skript wurde zum zählen von eingeschaltenen Lichtern umgeschrieben.
                                // V1.2.3 vom 1.4.2020
                                //Script um eingeschaltene Lichter pro Raum und insgesamt zu zählen. Legt pro Raum zwei Datenpunkte an, sowie zwei Datenpunkte fürs gesamte.
                                //Möglichkeit eine Ansage nach x Minuten einmalig oder zyklisch bis Fensterschließung anzugeben
                                //Dynamische erzeugung einer HTML Übersichtstabelle
                                //WICHTIG!!!
                                //Vorraussetzungen: Den Geräten müssen Räume zugewiesen sein, sowie die Funktion "Verschluss" für jeden entsprechenden Datenpunkt zugewiesen sein.
                                //Grundeinstellungen
                                const logging = false; //Erweiterte Logs ausgeben?
                                const praefix = "0_userdata.0.Lichtueberwachung."; //Grundpfad für Script DPs
                                const ZeitBisNachricht = 300000 // 300000 ms = 5 Minuten
                                const RepeatInfoMsg = true; // Legt fest ob Ansage einmalig oder zyklisch
                                const InfoMsgAktiv = true; // Legt fest ob eine Infonachricht nach x Minuten ausgegeben werden soll
                                const WelcheFunktionVerwenden = "actualLevel"; // Legt fest nach welchem Begriff in Funktionen gesucht wird.
                                const UseTelegram = false; // Sollen Nachrichten via Telegram gesendet werden?
                                const UseAlexa = false; // Sollen Nachrichten via Alexa ausgegeben werden?
                                const AlexaId = ""; // Die Alexa Seriennummer
                                const UseMail = false; //Nachricht via Mail versenden
                                const UseSay = false; // Sollen Nachrichten via Say ausgegeben werden? Authorenfunktion, sollte deaktiviert werden.
                                const UseEventLog = false; // Sollen Nachrichten ins Eventlog geschreiben werden? Authorenfunktion, sollte deaktiviert werden.
                                const AlsoMsgLightOnOff = false; //Soll auch das erstmalige einschalten, sowie das ausschalten gemeldet werden?
                                const LightsOnListSeparator = "<br>"; //Trennzeichen für die Textausgabe der eingeschaltenen Lichter pro Raum
                                const LightIsOnWhen = ["true", "ein", "on","100"]; // Hier können eigene States für ein angegeben werden, immer !!! in Kleinschreibung
                                const LightIsOffWhen = ["false", "off", "0"]; // können eigene States für aus angegeben werden, immer !!! in Kleinschreibung
                                //Einstellungen zur Tabellenausgabe
                                const LightsOnImg = "/icons-mfd-svg/light_light_dim_100.svg"; //Icon eingeschaltenes Licht
                                const LightOffImg = "/icons-mfd-svg/light_light.svg"; // Icon für ausgeschaltenes Licht
                                const LightsOnColor = "red"; // Farbe für eingeschaltenes Licht
                                const LightsOffColor = "green"; // Farbe für ausgeschaltenes Licht
                                const HeadlessTable = false; // Tabelle mit oder ohne Kopf darstellen
                                const TableDateFormat = "SS:mm:ss TT.MM.JJJJ"; //Zeit- & Datums- formatierung für Tabelle. Übersicht der Kürzel hier: https://github.com/ioBroker/ioBroker.javascript/blob/master/docs/en/javascript.md#formatdate
                                //Ab hier nix mehr ändern!
                                let LightOnCount = 0; // Gesamtzahl der eingeschaltenen Lichter
                                const RoomLightsOnCount = []; // Array für eingeschaltene Lichter pro Raum
                                let RoomsWithLightsOn = "";
                                const LightsOnMsgHandler = []; // Objektarray für timeouts pro Raum
                                const Sensor = []; //Sensoren als Array anlegen
                                const SensorVal = [];//Sensorwerte als Array anlegen
                                const SensorOldVal = []; //Alte Sensorwerte als Array ablegen
                                const Laufzeit = []; //Timer Laufzeit pro Fenster
                                const RoomList = []; // Raumlisten Array
                                const RoomStateTimeStamp = [];
                                let z = 0; //Zähler
                                let DpCount = 0; //Zähler
                                const States = []; // Array mit anzulegenden Datenpunkten
                                let Funktionen = getEnums('functions');
                                for (let x in Funktionen) {        // loop ueber alle Functions
                                    let Funktion = Funktionen[x].name;
                                    if (Funktion == undefined) {
                                        log("Keine Funktion gefunden");
                                    else {
                                        if (typeof Funktion == 'object') Funktion = Funktion.de;
                                        let members = Funktionen[x].members;
                                        if (Funktion == WelcheFunktionVerwenden) { //Wenn Function ist Licht
                                            for (let y in members) { // Loop über alle Licht Members
                                                Sensor[y] = members[y];
                                                let room = getObject(Sensor[y], 'rooms').enumNames[0];
                                                if (typeof room == 'object') room = room.de;
                                                //Datenpunkte pro Raum vorbereiten
                                                States[DpCount] = { id: praefix + room + ".RoomLightsOnCount", initial: 0, forceCreation: false, common: { read: true, write: true, name: "Anzahl der eingeschaltenen Lichter im Raum", type: "number", def: 0 } };
                                                DpCount++;
                                                States[DpCount] = { id: praefix + room + ".IsOn", initial: false, forceCreation: false, common: { read: true, write: true, name: "Licht eingeschaltet?", type: "boolean", role: "state", def: false } }; //
                                                DpCount++;
                                                //log(Funktion + ': ' + room);
                                                if (RoomList.indexOf(room) == -1) { //Raumliste ohne Raumduplikate erzeugen
                                                    RoomList[z] = room;
                                                    if (logging) log("Raum " + z + " = " + RoomList[z]);
                                                    z++;
                                                RoomLightsOnCount[y] = 0; // Array mit 0 initialisieren
                                                Laufzeit[y] = 0; // Array mit 0 initialisieren
                                //Struktur anlegen in js.0 um Sollwert und Summenergebniss zu speichern
                                //Generische Datenpunkte vorbereiten
                                States[DpCount] = { id: praefix + "AllLightsOff", initial: true, forceCreation: false, common: { read: true, write: true, name: "Licht aus?", type: "boolean", role: "state", def: true } }; //
                                DpCount++;
                                States[DpCount] = { id: praefix + "LightsOn", initial: 0, forceCreation: false, common: { read: true, write: true, name: "Anzahl der eingeschaltenen Lichter", type: "number", def: 0 } };
                                DpCount++;
                                States[DpCount] = { id: praefix + "RoomsWithLightsOn", initial: "Lichter in allen Räumen ausgeschalten.", forceCreation: false, common: { read: true, write: true, name: "In welchen Räumen sind Lichter eingeschalten?", type: "string", def: "Lichter in allen Räumen ausgeschalten" } };
                                DpCount++;
                                States[DpCount] = { id: praefix + "OverviewTable", initial: "", forceCreation: false, common: { read: true, write: true, name: "Übersicht aller Räume und eingeschaltener Lichter", type: "string", def: "" } };
                                //Alle States anlegen, Main aufrufen wenn fertig
                                let numStates = States.length;
                                States.forEach(function (state) {
                                    createState(state.id, state.initial, state.forceCreation, state.common, function () {
                                        numStates--;
                                        if (numStates === 0) {
                                            if (logging) log("CreateStates fertig!");
                                            main();
                                function main() {
                                    for (let x = 0; x < Sensor.length; x++) {
                                        //setTimeout(function () { // Timeout setzt refresh status wieder zurück
                                        SensorVal[x] = String(getState(Sensor[x]).val).toLowerCase(); // Wert von Sensor in Schleife einlesen
                                        SimplyfyLightStates(x);
                                        // }, x * 100);
                                    CreateTrigger();
                                    CheckAllLights(); //Bei Scriptstart alle Lichter einlesen
                                    CreateOverviewTable()
                                function Meldung(msg) {
                                    if (UseSay) Say(msg);
                                    if (UseTelegram) {
                                        sendTo("telegram.0", "send", {
                                            text: msg
                                    if (UseAlexa) {
                                        if (AlexaId != "") setState("alexa2.0.Echo-Devices." + AlexaId + ".Commands.announcement"/*announcement*/, msg);
                                    if (UseMail) {
                                        sendTo("email", msg);
                                    if (logging) log("Msg= " + msg);
                                function CreateOverviewTable() { //  Erzeugt tabellarische Übersicht als HTML Tabelle
                                    //Tabellenüberschrift und Head
                                    let OverviewTable = "";
                                    if (!HeadlessTable) {
                                        OverviewTable = "<table style='width:100%; border-collapse: collapse; border: 0px solid black;'><caption><div style='height: 20px; padding-top: 0px; padding-bottom: 5px; font-size:1.4em; font-weight: bold;'>Lichterstatus</div></caption>";
                                        OverviewTable = OverviewTable + "<thead><tr><th width='100%' style='text-align:center; height: 20px; padding-bottom: 5px;'>" + RoomsWithLightsOn + "</th></tr></thead><tbody></tbody></table>";
                                    //Tabelle der Raumdetails
                                    OverviewTable = OverviewTable + "<div style='height: 100%; overflow-y:auto; overflow-x:hidden;'><table style='width:100%; border-collapse: collapse;'>";
                                    OverviewTable = OverviewTable + "<thead><tr><th width='40px' style='text-align:left;'</th><th width='20px' style='text-align:center;'></th><th style='text-align:left;'></th></tr></thead><tbody>";
                                    for (let x = 0; x < RoomList.length; x++) { //Alle Räume durchgehen
                                        if (RoomLightsOnCount[x] > 0) { // Räume mit eingeschaltenen Lichtern
                                            RoomStateTimeStamp[x] = formatDate(getDateObject(getState(praefix + RoomList[x] + ".IsOn").lc), TableDateFormat);
                                            OverviewTable = OverviewTable + "<tr><td style='border: 1px solid black; background-color:" + LightsOnColor + ";'><img height=40px src='" + LightsOnImg + "'></td>"
                                            OverviewTable = OverviewTable + "<td style='border: 1px solid black; padding-left: 10px; padding-right: 10px; font-size:1.1em; font-weight: bold; text-align:center;background-color:" + LightsOnColor + ";'>" + RoomLightsOnCount[x] + "</td>"
                                            OverviewTable = OverviewTable + "<td style='border: 1px solid black; padding-left: 10px; padding-right: 10px; font-size:1.1em; font-weight: bold; background-color:" + LightsOnColor + ";'>" + RoomList[x] + "<br><div style='font-size:0.8em; font-weight:bold;'>eingeschaltet: " + RoomStateTimeStamp[x] + "</div></td></tr>"
                                        else { // Ausgeschaltene Räume
                                            OverviewTable = OverviewTable + "<tr><td style='border: 1px solid black; background-color:" + LightsOffColor + ";'><img height=40px src='" + LightOffImg + "'></td>"
                                            OverviewTable = OverviewTable + "<td style='border: 1px solid black; padding-left: 10px; padding-right: 10px; font-size:1.1em; font-weight: bold; text-align:center; background-color:" + LightsOffColor + ";'>" + RoomLightsOnCount[x] + "</td>"
                                            OverviewTable = OverviewTable + "<td style='border: 1px solid black; padding-left: 10px; padding-right: 10px; font-size:1.1em; font-weight: bold; background-color:" + LightsOffColor + ";'>" + RoomList[x] + "<br><div style='font-size:0.7em; font-weight:normal;'>ausgeschaltet: " + RoomStateTimeStamp[x] + "</div></td></tr>"
                                    OverviewTable = OverviewTable + "</tbody></table></div>";
                                    setState(praefix + "OverviewTable", OverviewTable);
                                    //log(OverviewTable);
                                function CreateRoomsWithLightsOnList() { //Erzeugt Textliste mit Räumen welche eingeschaltene Lichter haben
                                    RoomsWithLightsOn = ""; //Liste Initialisieren
                                        if (RoomLightsOnCount[x] > 0) { // Nur Räume mit eingeschaltenen Lichtern berücksichtigen
                                            if (RoomLightsOnCount[x] == 1) { //Wenn 1 Licht ein, Singular Schreibweise
                                                RoomsWithLightsOn = RoomsWithLightsOn +"<img width=25px height=25px style= vertical-align:-5px src=img/bulb_on.png >"+ RoomList[x] + " "  + RoomLightsOnCount[x] + LightsOnListSeparator;
                                            else { //ansonsten Plural Schreibweise
                                    RoomsWithLightsOn = RoomsWithLightsOn.substr(0, RoomsWithLightsOn.length - LightsOnListSeparator.length); //letzten <br> Umbruch wieder entfernen
                                    if (RoomsWithLightsOn == "") {
                                        RoomsWithLightsOn = "<img width=25px height=25px style= vertical-align:-5px src=img/bulb_off.png >"+ "Alle Lichter ausgeschalten";
                                    setState(praefix + "RoomsWithLightsOn", RoomsWithLightsOn);
                                    if (logging) log(RoomsWithLightsOn);
                                function GetRoom(x) { // Liefert den Raum von Sensor x
                                    if (logging) log("Reaching GetRoom x=" + x)
                                    let room = getObject(Sensor[x], 'rooms').enumNames[0];
                                    if (room == undefined) {
                                        log("Kein Raum definiert bei Sensor " + Sensor[x], 'error');
                                        return "Kein Raum definiert";
                                    return room;
                                function CheckLight(x) { //Für einzelnes Licht. Via Trigger angesteuert.
                                    let TempRoom = GetRoom(x); //Raum des aktuellen Sensors bestimmen
                                    let TempRoomIndex = RoomList.indexOf(TempRoom); // Raumlistenindex für aktuellen Raum bestimmen
                                    if (logging) log("reaching CheckLight, SensorVal[" + x + "]=" + SensorVal[x] + " SensorOldVal=" + SensorOldVal[x] + " TempRoom=" + TempRoom)
                                    if (SensorVal[x] == "on" && SensorOldVal[x] != "on") { //Licht war ausgeschalten und wurde eingeschalten
                                        LightOnCount++;
                                        RoomLightsOnCount[TempRoomIndex]++;
                                        if (logging) log("RoomLightsOnCount für " + TempRoom + "=" + RoomLightsOnCount[TempRoomIndex]);
                                        setState(praefix + "AllLightsOff", false);
                                        setState(praefix + TempRoom + ".IsOn", true);
                                        setState(praefix + "LightsOn", LightOnCount);
                                        setState(praefix + TempRoom + ".RoomLightsOnCount", RoomLightsOnCount[TempRoomIndex]);
                                        if (logging) log(TempRoom + " Licht eingeschalten");
                                        if (AlsoMsgLightOnOff) Meldung(TempRoom + " Licht eingeschaltet!");
                                        if (UseEventLog == true) WriteEventLog(TempRoom + " Licht eingeschaltet!");
                                        if (RoomLightsOnCount[TempRoomIndex] == 1) {
                                            Laufzeit[TempRoomIndex] = 0;
                                            if (InfoMsgAktiv == true) {
                                                if (RepeatInfoMsg == true) { // Wenn Intervallmeldung eingestellt Interval starten und Dauer bei Ansage aufaddieren
                                                    if (logging) log("Setting Interval to Room:" + TempRoom);
                                                    LightsOnMsgHandler[TempRoomIndex] = setInterval(function () {
                                                        Laufzeit[TempRoomIndex] = Laufzeit[TempRoomIndex] + ZeitBisNachricht;
                                                        Meldung(TempRoom + "licht seit " + (Laufzeit[TempRoomIndex] / 1000 / 60).toFixed(1) + " Minuten eingeschalten!");
                                                    }, ZeitBisNachricht);
                                                else { // Wenn einmalige Meldung eingestellt
                                                    if (logging) log("Setting Timeout to Room:" + TempRoom);
                                                    LightsOnMsgHandler[TempRoomIndex] = setTimeout(function () {
                                                        Meldung(TempRoom + "licht seit " + (ZeitBisNachricht / 1000 / 60).toFixed(1) + " Minuten eingeschalten!");
                                    else if (SensorVal[x] == "off") {
                                        if (LightOnCount > 0) LightOnCount--;
                                        if (RoomLightsOnCount[TempRoomIndex] > 0) RoomLightsOnCount[TempRoomIndex]--;
                                        log(TempRoom + " Licht ausgeschalten.");
                                        if (AlsoMsgLightOnOff) Meldung(TempRoom + " Licht ausgeschaltet!");
                                        if (UseEventLog == true) WriteEventLog(TempRoom + " Licht ausgeschaltet!");
                                        if (RoomLightsOnCount[TempRoomIndex] == 0) {
                                            setState(praefix + TempRoom + ".IsOn", false);
                                                if (logging) log("reaching clearInterval - [x] = " + [x] + " TempRoomIndex= " + TempRoomIndex);
                                                clearInterval(LightsOnMsgHandler[TempRoomIndex]);
                                            else {
                                                if (logging) log("reaching clearTimeout");
                                                clearTimeout(LightsOnMsgHandler[TempRoomIndex]);
                                        if (LightOnCount == 0) { //Wenn kein Licht mehr eingeschalten
                                            setState(praefix + "AllLightsOff", true);
                                            log("Alle Lichter ausgeschalten.");
                                    if (logging) log("Eingeschaltene Lichter gesamt= " + LightOnCount);
                                    CreateRoomsWithLightsOnList();
                                    CreateOverviewTable();
                                function CheckAllLights() { //Prüft bei Programmstart alle Lichter
                                    for (let x = 0; x < Sensor.length; x++) { //Alle Sensoren durchlaufen
                                        if (SensorVal[x] == "on") { //Licht ist eingeschalten
                                            LightOnCount = LightOnCount + 1;
                                            RoomLightsOnCount[TempRoomIndex] = RoomLightsOnCount[TempRoomIndex] + 1;
                                            if (logging) log("Temproom= " + TempRoom + " TempRoomIndex= " + RoomList.indexOf(TempRoom) + "  RoomLightsOnCount= " + RoomLightsOnCount[TempRoomIndex]);
                                            if (InfoMsgAktiv == true && RoomLightsOnCount[RoomList.indexOf(TempRoom)] == 1) {
                                                    if (logging) log("Setting Interval at initialization to Room: " + TempRoom);
                                                        Meldung(TempRoom + "licht seit " + Laufzeit[TempRoomIndex] / 1000 / 60 + " Minuten eingeschalten!");
                                                else {
                                                    if (logging) log("Setting Timeout at initialization to Room: " + TempRoom);
                                                    LightsOnMsgHandler[TempRoomIndex] = setTimeout(function () { // Wenn einmalige Meldung eingestellt
                                                        Meldung(TempRoom + "licht seit " + ZeitBisNachricht / 1000 / 60 + " Minuten eingeschalten!");
                                            if (logging) log(TempRoom + " Licht = eingeschalten");
                                            //RoomLightsOnCount[TempRoomIndex] = getState(praefix + TempRoom + ".RoomLightsOnCount").val - 1;
                                            if (RoomLightsOnCount[TempRoomIndex] < 0) RoomLightsOnCount[TempRoomIndex] = 0;
                                            //log(TempRoom + " Fenster = geschlossen.");
                                function SimplyfyLightStates(x) { //Die verschiedenen Gerätestates zu on oder off vereinfachen
                                    //log("Sensor "+Sensor[x]+" mit Wert "+ SensorVal[x]+ " hat Typ " + typeof(SensorVal[x] ));
                                    if (LightIsOnWhen.indexOf(SensorVal[x]) != -1) { // Suche in Lichtereinnarray, wenn gefunden, Status auf on setzen
                                        SensorVal[x] = "on";
                                    else if (LightIsOffWhen.indexOf(SensorVal[x]) != -1) { // Suche in Lichterausarray, wenn gefunden, Status auf off setzen
                                        SensorVal[x] = "off";
                                    if (SensorVal[x] != "on" && SensorVal[x] != "off") { // Suche in Lichtereinarray und Lichterausarray, wenn nirgends gefunden, Status auf closed setzen und Logwarnung ausgeben
                                        log("Unknown Lightstate " + SensorVal[x] + " detected at " + Sensor[x] + ", please check your configuration", "warn");
                                        SensorVal[x] = "unknown";
                                    if (LightIsOnWhen.indexOf(SensorOldVal[x]) != -1) {
                                        SensorOldVal[x] = "on";
                                    else if (LightIsOffWhen.indexOf(SensorOldVal[x]) != -1) {
                                        SensorOldVal[x] = "off";
                                function CreateTrigger() {
                                    //Trigger für Sensoren erzeugen
                                        on(Sensor[x], function (dp) { //Trigger in Schleife erstellen
                                            if (logging) log("Trigger= " + x + " Wert= " + dp.state.val + " Alter Wert= " + dp.oldState.val);
                                            if (dp.channelId.search(praefix) == -1) { //Ausschliessen dass das Scriptverzeichnis zum Triggern verwendet wird
                                                SensorVal[x] = String(dp.state.val).toLowerCase(); // Alles in String und Kleinschreibweise wandeln
                                                SensorOldVal[x] = String(dp.oldState.val).toLowerCase(); // Alles in String und Kleinschreibweise wandeln
                                                CheckLight(x);
                                            else {
                                                log("Fehler, Datenpunkt im Scriptverzeichnis als Trigger definiert", "error");
                                    onStop(function () { //Bei Scriptende alle Timer löschen
                                        for (let x = 1; x < Sensor.length; x++) {
                                            if (RoomLightsOnCount[x] == 0) {
                                                    clearInterval(LightsOnMsgHandler[x]);
                                                else {
                                                    clearTimeout(LightsOnMsgHandler[x]);
                                    }, 100);
                                edit:
                                Ich denke mir gerade ich sollte es für Jarvis irgendwie anders angehen.
                                Dafür ist das Script vermutlich ein bisschen zu viel des guten. Bei Vis habe ich mir daraus folgendes gebastelt.
                                Da brauche ich keinen HTMLTable.
                                Dominik F. M 2 Replies Last reply Reply Quote 0
                                • Dominik F.
                                  Dominik F. @marsmännchen last edited by
                                  @marsmännchen
                                  Du könntest ein anderes Skript dafür nutzen, sieht dann so in Jarvis aus:
                                    marsmännchen @Dominik F. last edited by
                                    @dominik-f
                                    würde ich gerne versuchen.
                                    Ich durchforste gerade das Forum.
                                    Weißt du noch woher du das hast?
                                    Dominik F. 1 Reply Last reply Reply Quote 0
                                    • Dominik F.
                                      @marsmännchen
                                      https://forum.iobroker.net/topic/40424/alexa-ansagen-i-telegram-i-email-i-alias-i-visu-i-html
                                      Bei der Tabelle musst du allerdings eines beachten:
                                      die Schriftgrößen sind bei der HTML in "em" . Das führt dazu, dass es in JArvis sehr klein dargestellt wird. Ich hab mir das Skript vorher in den Texteditor kopiert und das durch "px" ersetzt. Die Schriftgröße kannst du dir dann nachher in den Objekten anpassen wie du es für gut empfindest.
                                        @dominik-f
                                        Danke, genau dort bin ich gerade angekommen.
                                        Muss nur diese ganzen Benachrichtigungen und Alexa Sachen "überlesen"
                                          marsmännchen @marsmännchen last edited by
                                          Nein auch zu kompliziert wenn man kein Programmierer ist. Noch dazu bekomme ich meine Lichter per Modbus mit dem Wert 0 für aus und 100 für ein.
                                          • Dominik F.
                                            Dominik F. @marsmännchen last edited by Dominik F.
                                            @marsmännchen
                                            Da du ja eh Aliase nutzen kannst/sollst kannst du dir die so einstellen, dass du bei 0 ein false hast und bei 100 ein true.
                                            Da ich selbst kein Programmierer bin kann ich dir sagen, dass es durchaus machbar ist auch ohne große Programmierkenntnisse.
                                            Aber gut. Ich kenne das Skript was du für Lichter nutzt. Das sollte sich in Jarvis darstellen lassen, zumindest in einem Pop Up. Hast du das schon mal versucht?
                                            Pack den Datenpunkt mal in eine ganz normale Statelist rein. Wenn du dann drauf klickst, sollte die Tabelle sichtbar sein
                                            1.0k
                                            92
                                            1843
                                            706782
