    2. English
    3. Development
    4. [Solved] CORS error when executed from configuration page
      sonusfaber last edited by sonusfaber
      I'm trying to make http requests from adapters config page (developed with react).
      Here the http options:
      const options = {
      		method: 'post',
      		body: body,
      		logger: console,
      		// mode: 'websocket',
      		headers: {
      			Connection: 'keep-alive',
      			Accept: 'text/xml',
      			Pragma: 'no-cache',
      			SOAPAction: 'http://ws01.lom.ch/soap/listDP',
      			'Cache-Control': 'no-cache',
      			'Content-Type': 'text/xml; charset=utf-8',
      			'Content-Length': body.length,
      	try {
      		const response = await client.fetch('http://192.168.1.108/ws', options);
      However I'm getting the following error message:
      The very same code works from the adapter code (main.js), without any CORS errors.
      Any ideas what I need to change when executing the code from react (adapter settings)?
        Solved it myself. The configuration page is running in the browser, the adapter code itself is not. That's a separate process.
        Btw. Is is possible to delete forum posts?
        • wendy2702
          wendy2702 @sonusfaber last edited by
          @sonusfaber only admins can delete.
          Please edit your first post and add [Solved]
