    4. Test eCharts Adapter
    • BananaJoe
      BananaJoe Most Active @BananaJoe last edited by BananaJoe
      @bananajoe ok, also wenn ich die Datenbank nach seinen Werten Frage - eine 30m zurück und 2h in die Zukunft:
      var end = Date.now();
      sendTo('influxdb.0', 'getHistory', {
          options: {
              start:      end - 1800000,
              end:        end + 7200000,
              aggregate: 'onchange',
              addId: true
      }, function (result) {
          for (var i = 0; i < result.result.length; i++) {
              console.log(result.result[i].id + ' ' + result.result[i].val + " " + new Date(result.result[i].ts).toISOString());
      Dann kommt - das hier:
      2023-02-01 19:22:39.411  - info: javascript.1 (237231) Start javascript script.js.Tests.influxdb_test1
      2023-02-01 19:22:39.431  - info: javascript.1 (237231) script.js.Tests.influxdb_test1: registered 0 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
      2023-02-01 19:22:42.930  - info: javascript.1 (237231) script.js.Tests.influxdb_test1: tuya.0.01507801e868e7553d50.3 59 2023-02-01T17:52:39.431Z
      2023-02-01 19:22:42.931  - info: javascript.1 (237231) script.js.Tests.influxdb_test1: tuya.0.01507801e868e7553d50.3 59 2023-02-01T17:55:43.486Z
      2023-02-01 19:22:42.931  - info: javascript.1 (237231) script.js.Tests.influxdb_test1: tuya.0.01507801e868e7553d50.3 58 2023-02-01T17:56:14.485Z
      2023-02-01 19:22:42.932  - info: javascript.1 (237231) script.js.Tests.influxdb_test1: tuya.0.01507801e868e7553d50.3 57 2023-02-01T17:57:26.374Z
      2023-02-01 19:22:42.932  - info: javascript.1 (237231) script.js.Tests.influxdb_test1: tuya.0.01507801e868e7553d50.3 58 2023-02-01T17:59:30.475Z
      2023-02-01 19:22:42.933  - info: javascript.1 (237231) script.js.Tests.influxdb_test1: tuya.0.01507801e868e7553d50.3 57 2023-02-01T17:59:54.184Z
      2023-02-01 19:22:42.933  - info: javascript.1 (237231) script.js.Tests.influxdb_test1: tuya.0.01507801e868e7553d50.3 58 2023-02-01T18:00:30.186Z
      2023-02-01 19:22:42.933  - info: javascript.1 (237231) script.js.Tests.influxdb_test1: tuya.0.01507801e868e7553d50.3 56 2023-02-01T18:01:30.006Z
      2023-02-01 19:22:42.933  - info: javascript.1 (237231) script.js.Tests.influxdb_test1: tuya.0.01507801e868e7553d50.3 56 2023-02-01T18:02:11.978Z
      2023-02-01 19:22:42.934  - info: javascript.1 (237231) script.js.Tests.influxdb_test1: tuya.0.01507801e868e7553d50.3 57 2023-02-01T18:02:43.916Z
      2023-02-01 19:22:42.934  - info: javascript.1 (237231) script.js.Tests.influxdb_test1: tuya.0.01507801e868e7553d50.3 57 2023-02-01T18:03:49.968Z
      2023-02-01 19:22:42.934  - info: javascript.1 (237231) script.js.Tests.influxdb_test1: tuya.0.01507801e868e7553d50.3 56 2023-02-01T18:03:57.785Z
      2023-02-01 19:22:42.934  - info: javascript.1 (237231) script.js.Tests.influxdb_test1: tuya.0.01507801e868e7553d50.3 57 2023-02-01T18:04:59.798Z
      2023-02-01 19:22:42.934  - info: javascript.1 (237231) script.js.Tests.influxdb_test1: tuya.0.01507801e868e7553d50.3 57 2023-02-01T18:05:41.657Z
      2023-02-01 19:22:42.934  - info: javascript.1 (237231) script.js.Tests.influxdb_test1: tuya.0.01507801e868e7553d50.3 56 2023-02-01T18:06:45.696Z
      2023-02-01 19:22:42.934  - info: javascript.1 (237231) script.js.Tests.influxdb_test1: tuya.0.01507801e868e7553d50.3 55 2023-02-01T18:06:55.609Z
      2023-02-01 19:22:42.934  - info: javascript.1 (237231) script.js.Tests.influxdb_test1: tuya.0.01507801e868e7553d50.3 55 2023-02-01T18:07:31.487Z
      2023-02-01 19:22:42.934  - info: javascript.1 (237231) script.js.Tests.influxdb_test1: tuya.0.01507801e868e7553d50.3 55 2023-02-01T18:08:03.438Z
      2023-02-01 19:22:42.935  - info: javascript.1 (237231) script.js.Tests.influxdb_test1: tuya.0.01507801e868e7553d50.3 55 2023-02-01T18:08:37.415Z
      2023-02-01 19:22:42.935  - info: javascript.1 (237231) script.js.Tests.influxdb_test1: tuya.0.01507801e868e7553d50.3 55 2023-02-01T18:09:17.370Z
      2023-02-01 19:22:42.935  - info: javascript.1 (237231) script.js.Tests.influxdb_test1: tuya.0.01507801e868e7553d50.3 55 2023-02-01T18:09:49.319Z
      2023-02-01 19:22:42.935  - info: javascript.1 (237231) script.js.Tests.influxdb_test1: tuya.0.01507801e868e7553d50.3 55 2023-02-01T18:11:03.325Z
      2023-02-01 19:22:42.935  - info: javascript.1 (237231) script.js.Tests.influxdb_test1: tuya.0.01507801e868e7553d50.3 54 2023-02-01T18:11:27.167Z
      2023-02-01 19:22:42.935  - info: javascript.1 (237231) script.js.Tests.influxdb_test1: tuya.0.01507801e868e7553d50.3 54 2023-02-01T18:12:03.131Z
      2023-02-01 19:22:42.935  - info: javascript.1 (237231) script.js.Tests.influxdb_test1: tuya.0.01507801e868e7553d50.3 55 2023-02-01T18:12:43.039Z
      2023-02-01 19:22:42.935  - info: javascript.1 (237231) script.js.Tests.influxdb_test1: tuya.0.01507801e868e7553d50.3 54 2023-02-01T18:13:22.994Z
      2023-02-01 19:22:42.935  - info: javascript.1 (237231) script.js.Tests.influxdb_test1: tuya.0.01507801e868e7553d50.3 54 2023-02-01T18:14:35.131Z
      2023-02-01 19:22:42.936  - info: javascript.1 (237231) script.js.Tests.influxdb_test1: tuya.0.01507801e868e7553d50.3 55 2023-02-01T18:14:46.959Z
      2023-02-01 19:22:42.936  - info: javascript.1 (237231) script.js.Tests.influxdb_test1: tuya.0.01507801e868e7553d50.3 53 2023-02-01T18:15:34.822Z
      2023-02-01 19:22:42.936  - info: javascript.1 (237231) script.js.Tests.influxdb_test1: tuya.0.01507801e868e7553d50.3 53 2023-02-01T18:16:08.785Z
      2023-02-01 19:22:42.936  - info: javascript.1 (237231) script.js.Tests.influxdb_test1: tuya.0.01507801e868e7553d50.3 53 2023-02-01T18:18:09.041Z
      2023-02-01 19:22:42.936  - info: javascript.1 (237231) script.js.Tests.influxdb_test1: tuya.0.01507801e868e7553d50.3 52 2023-02-01T18:18:24.545Z
      2023-02-01 19:22:42.936  - info: javascript.1 (237231) script.js.Tests.influxdb_test1: tuya.0.01507801e868e7553d50.3 52 2023-02-01T18:21:24.840Z
      2023-02-01 19:22:42.936  - info: javascript.1 (237231) script.js.Tests.influxdb_test1: tuya.0.01507801e868e7553d50.3 53 2023-02-01T18:22:22.202Z
      2023-02-01 19:22:42.936  - info: javascript.1 (237231) script.js.Tests.influxdb_test1: tuya.0.01507801e868e7553d50.3 53 2023-02-01T20:22:39.431Z
      Also die Zeitstempel ganz hinten sind ZULU Zeit (die ja immer gleich ist) oder eine andere Zone.
      Ich habe das um 19:22 Uhr ausgeführt, in der Abfrage Werte 30 Minuten zurück (18:52 Uhr) und 2h in die Zukunft (21:22 Uhr) angefragt. Die Ausgabe ist also immer mit einer Zeit um 60 Minuten zurück (jetzt in der Winterzeit)
      Wie man sieht gibt er in der letzten Zeile einen Wert für 20:22:39 zurück (obwohl es den Wert nicht gibt). Als Wert nimmt er den letzten Wert.
      • joergeli
        joergeli @BananaJoe last edited by
        @bananajoe
        Ich gebe auch mal meinen Senf dazu:
        Ich logge hier die PV-Leistung und den PV-Tagesertrag als Wochenansicht nur mit dem history-Adapter, also kpl. ohne DB.
        Wie man am PV-Tagesertrag (rot) erkennen kann, wird die Linie vom letzten Tageswert bis zum ersten Wert am nächsten morgen durchgezogen.
        Bei der PV-Leistung (grün) fällt es nicht so auf, da die Leistung ja gegen Abend fast bis auf 0 abfällt.
        Ich hätte es auch lieber gehabt, wenn die Linie nur bis zum letzten Tageswert gehen würde und dann steil senkrecht bis auf 0 abfallen würde.
        Habe mir dann gedacht, mogelste nach dem letzten Tageswert (per Script) einfach einen 0-Wert dazu.
        Nur woher soll das entspr. Script wissen, wann der letzte Tageswert geschrieben wurde (evtl. Sonnenuntergang + ca. 30 Min?)
        Selbst wenn es funktionieren würde, wäre das aber auch ein Hinzumogeln von real nicht existierenden Datenpunkten.
        Die Linie hört mit dem history-Adapter im Tagesverlauf beim letzten Tageswert auf (soweit OK), allerdings wird sie dann am nächsten Morgen mit dem ersten Tageswert waagerecht verlängert, um dann steil abzufallen.
        Wie soll eCharts also verfahren?
        • Eine diagonal abfallende Line vom letzten Tageswert bis zum ersten Tageswert ziehen?
        • Einen 0-Wert gleich nach dem letzten Tageswert hinzumogeln ( nur wann war der letzte Tageswert?)
        • Um Mitternacht einen zusätzlichen 0-Wert schreiben und dann wieder eine diagonal abfallende Linie ?
        • Die Linie "spitten", also nach dem letzten Tageswert einfach aufhören und am nächsten morgen wieder neu beginnen? (dann ist es aber keine durchgehende Linie mehr)
        Ehrlich gesagt, weiß ich es auch nicht.
        IMHO hat es aber wohl weniger mit den Datenbank-Typen zu tun, lasse mich aber gerne eines besseren belehren.
        RK62 BananaJoe 2 Replies Last reply Reply Quote 0
        • RK62
          RK62 @joergeli last edited by
          @joergeli Das geht doch mit dem Diagrammtyp „Schritte beim Start“:
          joergeli 1 Reply Last reply Reply Quote 0
          • BananaJoe
            BananaJoe Most Active @joergeli last edited by BananaJoe
            @joergeli ich finde das schon schwierig da du in deinem Diagramm zwei Einheiten - W und kWh - mischt. 2. ist ja schon ein zeitbasierter Wert, da ist die durchgezogene Line sogar nicht falsch. 🙂
            Zwischendurch eine 0 zu schreiben wäre auch nicht richtig 🙂
            Ich nutze halt schon lange 00:00 bis 24:00 Uhr Ansichten auf denen der Tag langsam in verschiedenen Kurven eingezeichnet wird. Man kann quasi die Tageszeit daran ablesen weit die Linien schon sind.
            Ich habe mich lange gegen Grafana gestreubt, fand es aber für einen mobilen Zugriff auf meine Solardaten zumindest einen Versuch wert.
            In Grafana die SQL-Daten auszuwerten fand ich grausig da die Daten immer in 2 Tabellen gespeichert werden.
            Die InfluxDB Anbindung erlaubt das direkte Auswählen der Datenpunkte (und ich lernte mal ein neues Datenbanksystem kennen).
            Ich schau mal morgen nach einer anderen Lösung - ich meine heute darüber gestolpert zu sein das es bei MySQL/MariaDB auch so etwas wie Views gibt - ich nenne das mal "virtuelle" Tabellen die aus Daten anderer Tabellen bestehen. Eventuell kann man daraus etwas bauen. Ich finde den eCharts Adapert nämlich klasse - weil es damit schön einfach ist.
            Eventuell logge ich dann einfach doppelt ... in SQL und InfluxDB ... die VM liegt auf einer NVMe und es scheint schnell genug dafür zu sein
            • joergeli
              joergeli @RK62 last edited by
              @rk62 sagte in Test eCharts Adapter:
              Hmmm, bei mir nicht.
              Linie:
              Schritte beim Start:
              Hier ist lediglich die steigende Flanke mehr "treppenförmig", oder sollte ich das mal mit "Schritte beim Start" ein paar Tage laufen lassen? - Ich versuche es mal.
              • joergeli
                joergeli @BananaJoe last edited by joergeli
                @bananajoe
                Nö, hat m.E. nichts mit den zwei Einheiten zu tun.
                In der Tagesansicht ( 00:00 bis 24:00 Uhr ) passt es ja:
                eCharts-Tagesansicht.jpg Screenshot ca. 23:30 Uhr
                Nur in der Wochenansicht wird die rote Linie waagerecht bis zum nächsten Morgen durchgezogen. Wobei es in diesem Screenshot bis zum heutigen Tag passt, das "Durchziehen" erfolgt dann erst morgen früh.
                eCharts - Wochenansicht.jpgScreenshot ebenfalls ca. 23:30 Uhr
                Evtl. hat aber @rk62 Recht und die Umstellung auf "Schritte beim Start" bringt Abhilfe - ich teste das mal ein paar Tage.
                SQL und InfluxDB möchte ich nicht, weil die VIS meines Raspi4 (4GByte) nach der Einrichtung des Logging (div. Shellys, history-Adapter, Sourcanalytics und eCharts) schon jetzt merklich langsamer geworden ist.
                BananaJoe RK62 2 Replies Last reply Reply Quote 0
                • BananaJoe
                  @joergeli sagte in Test eCharts Adapter:
                  Ich hoffe die Daten liegen auf einer (USB-)Festplatte und nicht auf der Speicherkarte des Raspi
                  • joergeli
                    @bananajoe sagte in Test eCharts Adapter:
                    Leider doch.
                    Ich hatte aber nach jetzt ca. 4 Jahren Betrieb von ioBroker ( Logging seit Aug. 2022) noch nie einen Ausfall der SD-Karte, toi, toi, toi.
                    Sicherheitshalber ziehe ich aber ca. alle 3 Wochen ein Komplett-Image der Karte auf mein NAS (ioBroker-Backup natürlich häufiger, aber weil noch andere Sachen auf dem Raspi laufen, halt zusätzlich das Komplett-Image).
                    • RK62
                      @joergeli Loggst Du die Werte regelmässig? Ich lasse nur bei Änderungen Historywerte schreibenf. Ggf. liegt es daran.
                      • joergeli
                        joergeli @RK62 last edited by joergeli
                        @rk62
                        Ja, ich logge ebenfalls nur bei Änderung des Wertes.
                        Wie gesagt, umstellen auf "Schritte beim Start" hat nichts gebracht.
                        Letztendlich ist es aber nicht so schlimm, zwischenzeitlich habe ich mich an die Darstellung mit der durchgezogenen Linie gewöhnt. 😑
                        • BananaJoe
                          Zum InfluxDB "Problem": Nach diversen Test meine ich das der Fehler eher bei InfluxDB-Adapter zu suchen ist und habe dort einen Issue erzeugt: https://github.com/ioBroker/ioBroker.influxdb/issues/322
                          Ich habe auch lange danach gegoogelt ob es eventuell ein Feature von InfluxDB ist oder ob man das von Datenbankseite irgendwie beeinflussen kann. Aber irgendwie finde ich dabei nicht die perfekten Suchbegriffe ...
                          BernhardLinz created this issue in ioBroker/ioBroker.influxdb
                          open QUERY: falscher zusätzlicher Datenpunkt in der Zukunft #322
                          • BananaJoe
                            Und noch ein Nachtrag von mir:
                            Eigentlich habe ich bisher nur den SQL-Adapter mit MySQL/MariaDB genutzt. Das ich zusätzlich InfluxDB installiert habe war nur um Grafana zu nutzen.
                            Und Grafana wollte ich nur ausprobieren um auch von Unterwegs aus mal einen Blick auf meine Solarproduktion werfen zu können.
                            Also viel Aufwand um dann 4 Zahlen und Kurven auf dem Handy zu haben.
                            Direkt den MySQL in Grafana abzufragen ist ... mühsam, bei InfluxDB kann man einfach direkt die Datenquelle auswählen, bei MySQL werden die Datenpunktnamen und die Werte in 2 verschiedenen Tabellen gespeichert.
                            Nun habe ich doch eine elegante Lösung für mich gefunden - mit Grafana und MySQL.
                            Die Lösung: https://forum.iobroker.net/topic/23033/aufruf-modifikation-simpleapi-adapter-iobroker-als-datenquelle-für-grafana
                            Den simpleAPI-Adapter hatte ich ich eh schon installiert, in den Adaptereinstellungen habe ich folgendes gesetzt:
                            in Grafana habe ich das SimpleJSON Plugin installiert:
                            und die Datenquelle wie folgt konfiguriert:
                            Nun kann ich alle Datenpunkte mit aktivierter SQL-Aufzeichnung einfach auswählen:
                            So kann ich weiter den SQL-Adapter wie gewohnt nutzen, habe in eCharts nicht das Problem mit der Linie des letzten Wertes und kann trotzdem Grafana nutzen.
                            Mein Grafana ist über ein Subdomain und Apache Reverse Proxy per https von außen erreichbar.
                            Ich nutze unter Android die App Viewer4Grafana um mein Dashboard für die Solaranlage zu sehen.
                              Matis @BananaJoe last edited by
                              echart 1.3.0. verteilt die Legend oben auf gesamter Länge und nicht mehr an der Seite und zeigt keinerlei Kurven mehr an. Bin wieder auf 1.2.1
                              • BananaJoe
                                1.3.0 zeigt bei mir gar nichts an außer der Legende, bin auch wieder zurück auf 1.2.1
                                  A Former User @BananaJoe last edited by
                                  @bananajoe @Matis
                                  es gibt ne 1.3.1.. aber die Bars finde ich nicht.. im Chrome zeigt er mir nix an, im Firefox gehts.. hmpf.
                                  • David G.
                                    David G. @Guest last edited by David G.
                                    Bin grad auf die 1.3.1
                                    Finde die Bars sehr sehr cool.
                                    Vermisse nur eine eigene Y-Achse, die bekomme ich nicht hin.
                                    Schaffe nur so:
                                    und so
                                    Am liebsten wäre mir Variante 2 mir einer Y-Achse links und rechts (m3 und €).
                                    Variante 1 kommt, wenn ich für den zweiten Datenpunkt eine eigene Y Wähle.
                                    EDIT
                                    Dass mit der Legende was nicht passt kann ich bestätigen, steht immer oben in der Mitte und die Farbe der Schrift/Hintergrund wird nicht übernommen.
                                    • David G.
                                      Habe mal eine ganz allgemeine Frage, die ich aber jetzt hier stelle, da es für mich um diesen Adapter geht.
                                      Ich habe die aktuelle git Version installiert. Also keine Stable.
                                      Mache ich da bei Fehlern/Bugs ein Issue auf git auf oder sagt man sich, die Version ist noch nicht fertig und man lässt den Dev erstmal machen bevor man anfängt mit verschiedensten Dingen die evtl einfach noch nicht implementiert sind?
                                      Da hab ich seit der 1.3 einige, besonders in Zusammenhang mit den Bars.
                                      M Homoran 2 Replies Last reply Reply Quote 0
                                        Matis @David G. last edited by
                                        Mit 1.3.4 ist das Diagramm wieder da und wird auch richtig dargestellt, links ist auch der Platz für die Legende, die wird aber immer noch oben waagrecht über alles drübergeschrieben. Das klappt also noch nicht.
                                          Homoran Global Moderator Administrators @David G. last edited by
                                          @david-g sagte in Test eCharts Adapter:
                                          ja! und zwar do detailliert wie möglich, damit der Dev es möglichst nachvollziehen kann und den möglichen Bug behebt.
                                          cash 1 Reply Last reply Reply Quote -1
                                          • cash
                                            cash Most Active @Homoran last edited by
                                            hab da nochmal kurz eine Frage da ich mal wieder einen neuen Chart erstellt habe. Bei mir sind die Hilfslinien der x und y-Achse jeweils gestrichelt. Ich hätte diese Hilfslinien gerne durchgezogen. Ich finde aber nicht die Option dazu? Vermutlich blind. 🙂
                                            In welchen Reiter finde ich die Einstellung unter welchen Punkt. Gefühlt habe ich jedes Feld geklickt ohne Erfolg
                                            echarts
                                            105
                                            652
                                            168352
