      Dieter Kurz @Armilar last edited by
      @armilar sagte in SONOFF NSPanel mit Lovelace UI:
      @dieter-kurz
      sofern diese im Sonosadapter eine IP haben, ja
      Zu den Warnungen im Log kann ich erst etwas sagen, wenn du es sendest 😉
      Kleiner Hinweis, in den MRIcons (Script-Config) sind auch Relays mit MQTT-Parametern
      Hier mein Log
      2023-02-04 15:56:00.476 - info: javascript.0 (327597) Stop script script.js.NSPanels.NSPanel_1_3_9_0
      2023-02-04 15:56:00.579 - info: javascript.0 (327597) script.js.NSPanels.NSPanel_1_3_9_0: compiling TypeScript source...
      2023-02-04 15:56:01.888 - info: javascript.0 (327597) script.js.NSPanels.NSPanel_1_3_9_0: source code did not change, using cached compilation result...
      2023-02-04 15:56:02.006 - info: javascript.0 (327597) script.js.NSPanels.NSPanel_1_3_9_0: Wetter-Alias für accuweather.0. existiert bereits
      2023-02-04 15:56:02.097 - warn: javascript.0 (327597) getState "mqtt.0.SmartHome.tele.NSPanel_1.INFO2" not found (3)
      2023-02-04 15:56:02.101 - warn: javascript.0 (327597) at get_current_tasmota_ip_address (script.js.NSPanels.NSPanel_1_3_9_0:2792:34)
      2023-02-04 15:56:02.101 - warn: javascript.0 (327597) at get_tasmota_status0 (script.js.NSPanels.NSPanel_1_3_9_0:2899:42)
      2023-02-04 15:56:02.101 - warn: javascript.0 (327597) at script.js.NSPanels.NSPanel_1_3_9_0:2480:1
      2023-02-04 15:56:02.101 - warn: javascript.0 (327597) script.js.NSPanels.NSPanel_1_3_9_0: function get_current_tasmota_ip_address: Cannot read properties of null (reading 'Info2')
      2023-02-04 15:56:02.105 - warn: javascript.0 (327597) script.js.NSPanels.NSPanel_1_3_9_0: function check_updates: Cannot read properties of null (reading 'split')
      2023-02-04 15:56:02.106 - info: javascript.0 (327597) script.js.NSPanels.NSPanel_1_3_9_0: registered 31 subscriptions, 7 schedules, 0 messages, 0 logs and 0 file subscriptions
      2023-02-04 15:56:02.137 - error: javascript.0 (327597) Request error: Error: getaddrinfo ENOTFOUND undefined
      2023-02-04 15:56:02.514 - info: javascript.0 (327597) script.js.NSPanels.NSPanel_1_3_9_0: Desired TFT Firmware: 49 / v3.9.0
      2023-02-04 15:56:02.515 - info: javascript.0 (327597) script.js.NSPanels.NSPanel_1_3_9_0: Installed TFT Firmware: 49 / v3.9.0
      2023-02-04 15:56:02.602 - warn: javascript.0 (327597) script.js.NSPanels.NSPanel_1_3_9_0: get_tasmota_status0Unexpected token u in JSON at position 0
      2023-02-04 15:56:02.632 - warn: javascript.0 (327597) getState "mqtt.0.SmartHome.tele.NSPanel_1.INFO2" not found (3)
      2023-02-04 15:56:02.633 - warn: javascript.0 (327597) at get_current_tasmota_ip_address (script.js.NSPanels.NSPanel_1_3_9_0:2792:34)
      2023-02-04 15:56:02.634 - warn: javascript.0 (327597) at script.js.NSPanels.NSPanel_1_3_9_0:2764:99
      2023-02-04 15:56:02.634 - warn: javascript.0 (327597) at step (script.js.NSPanels.NSPanel_1_3_9_0:33:23)
      2023-02-04 15:56:02.635 - warn: javascript.0 (327597) at Object.next (script.js.NSPanels.NSPanel_1_3_9_0:14:53)
      2023-02-04 15:56:02.636 - warn: javascript.0 (327597) at fulfilled (script.js.NSPanels.NSPanel_1_3_9_0:5:58)
      2023-02-04 15:56:02.636 - warn: javascript.0 (327597) at runMicrotasks ()
      2023-02-04 15:56:02.636 - warn: javascript.0 (327597) at runNextTicks (node:internal/process/task_queues:61:5)
      2023-02-04 15:56:02.637 - warn: javascript.0 (327597) at processImmediate (node:internal/timers:437:9)
      2023-02-04 15:56:02.637 - warn: javascript.0 (327597) script.js.NSPanels.NSPanel_1_3_9_0: function get_current_tasmota_ip_address: Cannot read properties of null (reading 'Info2')
      2023-02-04 15:56:02.756 - info: javascript.0 (327597) State value to set for "0_userdata.0.NSPanel.NSPanel_1.NSPanel_ipAddress" has to be type "string" but received type "object"
      2023-02-04 15:56:03.065 - warn: javascript.0 (327597) getState "mqtt.0.SmartHome.tele.NSPanel_1.INFO2" not found (3)
      2023-02-04 15:56:03.066 - warn: javascript.0 (327597) at get_current_tasmota_ip_address (script.js.NSPanels.NSPanel_1_3_9_0:2792:34)
      2023-02-04 15:56:03.067 - warn: javascript.0 (327597) at get_current_berry_driver_version (script.js.NSPanels.NSPanel_1_3_9_0:2852:42)
      2023-02-04 15:56:03.067 - warn: javascript.0 (327597) at script.js.NSPanels.NSPanel_1_3_9_0:2775:21
      2023-02-04 15:56:03.067 - warn: javascript.0 (327597) at step (script.js.NSPanels.NSPanel_1_3_9_0:33:23)
      2023-02-04 15:56:03.067 - warn: javascript.0 (327597) at Object.next (script.js.NSPanels.NSPanel_1_3_9_0:14:53)
      2023-02-04 15:56:03.067 - warn: javascript.0 (327597) at fulfilled (script.js.NSPanels.NSPanel_1_3_9_0:5:58)
      2023-02-04 15:56:03.067 - warn: javascript.0 (327597) at runMicrotasks ()
      2023-02-04 15:56:03.067 - warn: javascript.0 (327597) at processTicksAndRejections (node:internal/process/task_queues:96:5)
      2023-02-04 15:56:03.068 - warn: javascript.0 (327597) at runNextTicks (node:internal/process/task_queues:65:3)
      2023-02-04 15:56:03.068 - warn: javascript.0 (327597) at processImmediate (node:internal/timers:437:9)
      2023-02-04 15:56:03.068 - warn: javascript.0 (327597) script.js.NSPanels.NSPanel_1_3_9_0: function get_current_tasmota_ip_address: Cannot read properties of null (reading 'Info2')
      2023-02-04 15:56:03.094 - error: javascript.0 (327597) Request error: Error: getaddrinfo ENOTFOUND undefined
      2023-02-04 15:56:03.101 - warn: javascript.0 (327597) script.js.NSPanels.NSPanel_1_3_9_0: get_current_berry_driver_version: Unexpected token u in JSON at position 0
        TT-Tom @Dieter Kurz last edited by TT-Tom
        @dieter-kurz
        Du hast noch Fehler in der Config. Der MQTT Pfad stimmt eventuell nicht. Welche Version vom Script nutz du den jetzt für das Panel. Zeige bitte mal auch den Teil der Config aus dem Script. We.che Tasmota Version läuft auf dem Panel?
          Dieter Kurz @TT-Tom last edited by
          @tt-tom sagte in SONOFF NSPanel mit Lovelace UI:
          @dieter-kurz
          Du hast noch Fehler in der Config. Den MQTT Pfad stimmt nicht. Welche Version vom Script nutz du den jetzt für das Panel. Zeige bitte mal auch den Teil der Config aus dem Script
          Erstmal DANKE für Deine Hilfe!
          Hier meine Config:
          export const config: Config = {
          panelRecvTopic: 'mqtt.0.SmartHome.tele.NSPanel_1.RESULT', // Bitte anpassen
          panelSendTopic: 'mqtt.0.SmartHome.cmnd.NSPanel_1.CustomSend', // Bitte anpassen
          // 4 kleine Icons im Screensaver
          // Mit 3.9.0 neue Parameter - Bitte anpassen - siehe auch Wiki
          firstScreensaverEntity:   { ScreensaverEntity: 'accuweather.0.Hourly.h0.PrecipitationProbability',
                                      ScreensaverEntityFactor: 1,                                 //New
                                      ScreensaverEntityDecimalPlaces: 0,                          //New
                                      ScreensaverEntityIcon: 'weather-pouring',
                                      ScreensaverEntityText: 'Regen',
                                      ScreensaverEntityUnitText: '%',
                                      ScreensaverEntityIconColor: {'val_min': 0, 'val_max': 100}
          secondScreensaverEntity:  { ScreensaverEntity: 'parser.0.windSpeed',
                                      ScreensaverEntityFactor: (1000/1000),                       //New
                                      ScreensaverEntityDecimalPlaces: 1,                          //New
                                      ScreensaverEntityIcon: 'weather-windy',
                                      ScreensaverEntityText: "Wind",
                                      ScreensaverEntityUnitText: 'km/h',
                                      ScreensaverEntityIconColor: {'val_min': 0, 'val_max': 120}
          thirdScreensaverEntity:   { ScreensaverEntity: 'hm-rpc.0.LEQ0227831.1.TEMPERATURE',
                                      ScreensaverEntityIcon: 'home-thermometer-outline',
                                      ScreensaverEntityText: 'Innen',
                                      ScreensaverEntityUnitText: '°C',
                                      ScreensaverEntityIconColor: {'val_min': 0, 'val_max': 40, 'val_best': 22 }
          fourthScreensaverEntity:  { ScreensaverEntity: 'parser.0.outHumidity',
                                      ScreensaverEntityIcon: 'water-percent',
                                      ScreensaverEntityText: 'Luft',
                                      ScreensaverEntityIconColor: {'val_min': 0, 'val_max': 100, 'val_best': 65}
          // Indikator Icons im oberen Teil des Screensavers
          mrIcon1ScreensaverEntity: { ScreensaverEntity: 'mqtt.0.SmartHome.stat.NSPanel_1.POWER1',
                                      ScreensaverEntityIconOn: 'lightbulb',                           //Rename
                                      ScreensaverEntityIconOff: null,
                                      ScreensaverEntityValue: null,                                   //New
                                      ScreensaverEntityValueDecimalPlace : 0,                         //New
                                      ScreensaverEntityValueUnit: null,                               //New
                                      ScreensaverEntityOnColor: On,
                                      ScreensaverEntityOffColor: HMIOff },
          mrIcon2ScreensaverEntity: { ScreensaverEntity: 'mqtt.0.SmartHome.stat.NSPanel_1.POWER2',
                                      ScreensaverEntityIconOn: 'heat-wave',
                                      ScreensaverEntityValue: NSPanel_Path + 'Sensor.ANALOG.Temperature',
                                      ScreensaverEntityValueDecimalPlace : 1,
                                      ScreensaverEntityValueUnit: '°',
                                      ScreensaverEntityOnColor: MSRed,
                                      ScreensaverEntityOffColor: Yellow },
          weatherEntity: 'alias.0.Wetter.Pliezhausen',    // Dieser Alias wird automatisch für den gewählten Wetter erstellt und kann entsprechend angepasst werden
          defaultOffColor: Off,               // Default-Farbe für Off-Zustände
          defaultOnColor: On,                 // Default-Farbe für On-Zustände
          defaultColor: Off,
          defaultBackgroundColor: HMIDark,    // Default-Hintergrundfarbe HMIDark oder Black
          // Mit 3.9.0 in Datenpunkte verschoben. Auch über Service Pages konfigurierbar
              //alternativeScreensaverLayout: false,
              //autoWeatherColorScreensaverLayout: true,
              //timeoutScreensaver: 10,
              //screenSaverDoubleClick: true,
              //temperatureUnit: '°C',
              //locale: 'de-DE',
          pages: [
                  Licht1,
                  Sonos,
                  NSPanel_Service         //Auto-Alias Service Page
          subPages: [
                      NSPanel_Infos,                          //Auto-Alias Service Page
                          NSPanel_Wifi_Info_1,                //Auto-Alias Service Page
                          NSPanel_Wifi_Info_2,                //Auto-Alias Service Page
                          NSPanel_Sensoren,                   //Auto-Alias Service Page
                          NSPanel_Hardware,                   //Auto-Alias Service Page
                      NSPanel_Einstellungen,                  //Auto-Alias Service Page
                          NSPanel_Screensaver,                //Auto-Alias Service Page
                              NSPanel_ScreensaverDimmode,     //Auto-Alias Service Page
                              NSPanel_ScreensaverOther,       //Auto-Alias Service Page
                              NSPanel_Weather,                //Auto-Alias Service Page
                              NSPanel_Dateformat,             //Auto-Alias Service Page
                              NSPanel_Indicators,             //Auto-Alias Service Page
                              NSPanel_Relays,                 //Auto-Alias Service Page
                      NSPanel_Firmware,                       //Auto-Alias Service Page
                          NSPanel_FirmwareTasmota,            //Auto-Alias Service Page
                          NSPanel_FirmwareBerry,              //Auto-Alias Service Page
                          NSPanel_FirmwareNextion,            //Auto-Alias Service Page
          button1Page: null,   //Beispiel-Seite auf Button 1, wenn Rule2 definiert - Wenn nicht definiert --> button1Page: null,
          button2Page: null    //Beispiel-Seite auf Button 2, wenn Rule2 definiert - Wenn nicht definiert --> button1Page: null,
          T Armilar 2 Replies Last reply Reply Quote 0
          • Armilar
            Armilar Most Active Forum Testing @Gargano last edited by
            @gargano
            ist schon fertig... kommt mit der 4.0.0
            Gargano 1 Reply Last reply Reply Quote 0
              @dieter-kurz
              Kannst du mal die Tasmota Version senden.
                @tt-tom Ist die 12.3.1
                • Gargano
                  Gargano @Armilar last edited by
                  @armilar Danke . Ist ja wie Weihnachten und Ostern zusammen 😊
                    @dieter-kurz
                    sieht das bei dir auch so aus?
                    • Armilar
                      Armilar Most Active Forum Testing @Dieter Kurz last edited by
                      @dieter-kurz
                      Du sprichst von einem 2. Panel
                      Kannst du kurz einen Auszug aus den Objekten des MQTT-Adapter machen, aus denen die Pfade der beiden Panels hervorgehen?
                      Ich sehe hier im Log irgendwie so etwas:
                      mqtt.0.SmartHome.tele.NSPanel_1.INFO2 (Sollte es nicht ein anderes Panel sein?)
                      Also Prefix entweder vorne oder hinten. Aber nicht in der Mitte... Das unterstützt selbst Tasmota nur mit wiederwillen.
                      Also einmal den Auszug von beiden Panels aus Tasmota und die MQTT-Objekte. Sonst kommen wir ins schleudern.
                        @tt-tom INFO1, INFO2 und INFO3 fehlen, allerdings bei beiden Panels ..
                            @dieter-kurz
                            dann zeige mal deine MQTT einstellungen von Tasmota.
                                @dieter-kurz deine Tasmota MQTT Config passt nicht, bei beiden Panel
                                  @dieter-kurz sagte in SONOFF NSPanel mit Lovelace UI:
                                  Heir musst du Topic und prefix tauschen
                                    @tt-tom Was passt nicht?
                                      TT-Tom @TT-Tom last edited by
                                      Hier musst du Topic und prefix tauschen bei Full topic
                                        der Full topic, zeige bitte auch mal das andere Panel
                                        • Armilar
                                          @dieter-kurz
                                          Ich dachte, dass das erste Panel bereits lief. Das holt sich aber die IP aus INFO2. Ansonsten hätte es nie laufen können...
                                            TT-Tom @Armilar last edited by
                                            @armilar dort ist ja noch die Version 3.6.0 drauf, vielleicht des wegen
                                            lovelace ui nspanel sonoff
                                            270
                                            7695
                                            6530714
