    5. Skripte stoppen nicht
      blackvento @wendy2702 last edited by wendy2702
      @wendy2702
      Ich habe alle Skripte gestoppt, LOG Datei gelöscht, Instanzen aus gemacht und wieder an gemacht. Folgende Info kam dann bei LOG.
      shelly.0	2023-02-04 14:23:53.534	info	(1628) Shelly device 192.168.178.131 (shelly1pm / shelly1pm-E8DB84D2FFC7 / SHSW-PM#E8DB84D2FFC7#1) with CoAP connected!
      shelly.0	2023-02-04 14:23:51.497	info	(1628) Shelly device 192.168.178.110 (shelly1 / shelly1-8CAAB5552D39 / SHSW-1#8CAAB5552D39#1) with CoAP connected!
      shelly.0	2023-02-04 14:23:51.363	info	(1628) Shelly device 192.168.178.120 (shellyuni / shellyuni-E8DB84D657FC / SHUNI-1#E8DB84D657FC#1) with CoAP connected!
      shelly.0	2023-02-04 14:23:51.153	info	(1628) Shelly device 192.168.178.111 (shelly1 / shelly1-483FDA91B357 / SHSW-1#483FDA91B357#1) with CoAP connected!
      shelly.0	2023-02-04 14:23:50.790	info	(1628) Shelly device 192.168.178.101 (shellyswitch25 / shellyswitch25-84CCA8A721B7 / SHSW-25#84CCA8A721B7#1) with CoAP connected!
      shelly.0	2023-02-04 14:23:50.538	info	(1628) Shelly device 192.168.178.102 (shellyswitch25 / shellyswitch25-483FDA8DB6B4 / SHSW-25#483FDA8DB6B4#1) with CoAP connected!
      shelly.0	2023-02-04 14:23:39.112	info	(1628) Shelly device 192.168.178.103 (shellyswitch25 / shellyswitch25-8CAAB561E454 / SHSW-25#8CAAB561E454#1) with CoAP connected!
      shelly.0	2023-02-04 14:23:38.829	info	(1628) Shelly device 192.168.178.104 (shellyswitch25 / shellyswitch25-483FDA8D2315 / SHSW-25#483FDA8D2315#1) with CoAP connected!
      shelly.0	2023-02-04 14:23:38.345	info	(1628) Shelly device 192.168.178.130 (shelly1pm / shelly1pm-E8DB84D7ED0A / SHSW-PM#E8DB84D7ED0A#1) with CoAP connected!
      shelly.0	2023-02-04 14:23:36.590	info	(1628) Listening for Shelly packets in the network
      shelly.0	2023-02-04 14:23:35.251	info	(1628) Starting Shelly adapter in CoAP modus.
      shelly.0	2023-02-04 14:23:34.180	info	(1628) Polltime of the shelly devices: 5 sec.
      shelly.0	2023-02-04 14:23:34.153	info	(1628) Starting Adapter shelly.0 in version 4.0.6
      shelly.0	2023-02-04 14:23:33.279	info	(1628) starting. Version 4.0.6 in /opt/iobroker/node_modules/iobroker.shelly, node: v12.20.1, js-controller: 3.2.16
      telegram.0	2023-02-04 14:23:31.459	info	(1621) starting. Version 1.8.0 in /opt/iobroker/node_modules/iobroker.telegram, node: v12.20.1, js-controller: 3.2.16
      host.raspberrypi	2023-02-04 14:22:59.232	info	instance system.adapter.shelly.0 started with pid 1628
      host.raspberrypi	2023-02-04 14:22:58.894	info	"system.adapter.shelly.0" enabled
      host.raspberrypi	2023-02-04 14:22:58.307	info	instance system.adapter.telegram.0 started with pid 1621
      host.raspberrypi	2023-02-04 14:22:57.922	info	"system.adapter.telegram.0" enabled
      host.raspberrypi	2023-02-04 14:22:56.950	info	instance system.adapter.telegram.0 terminated with code 0 (NO_ERROR)
      host.raspberrypi	2023-02-04 14:22:56.292	info	stopInstance system.adapter.telegram.0 killing pid 1529
      telegram.0	2023-02-04 14:22:55.701	info	(1529) Terminated (NO_ERROR): Without reason
      telegram.0	2023-02-04 14:22:55.689	info	(1529) terminating
      host.raspberrypi	2023-02-04 14:22:55.257	info	stopInstance system.adapter.telegram.0 send kill signal
      telegram.0	2023-02-04 14:22:55.249	info	(1529) Got terminate signal TERMINATE_YOURSELF
      host.raspberrypi	2023-02-04 14:22:55.169	info	stopInstance system.adapter.telegram.0 (force=false, process=true)
      host.raspberrypi	2023-02-04 14:22:55.154	info	"system.adapter.telegram.0" disabled
      telegram.0	2023-02-04 14:22:55.104	info	(1529) Adapter is disabled => stop
      host.raspberrypi	2023-02-04 14:22:52.685	info	instance system.adapter.shelly.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      shelly.0	2023-02-04 14:22:52.458	error	(1522) Error in function httpIoBrokerState for state SHSW-25#483FDA8D2315#1.Relay0.ChannelName and request{"url":"http://192.168.178.104/settings/relay/0","timeout":5000} for 192.168.178.104 (shellys
      shelly.0	2023-02-04 14:22:52.384	warn	(1522) get state error: Connection is closed.
      shelly.0	2023-02-04 14:22:51.764	info	(1522) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      shelly.0	2023-02-04 14:22:51.755	info	(1522) terminating
      shelly.0	2023-02-04 14:22:51.750	info	(1522) Closing Adapter
      shelly.0	2023-02-04 14:22:51.659	info	(1522) Got terminate signal TERMINATE_YOURSELF
      host.raspberrypi	2023-02-04 14:22:51.671	info	stopInstance system.adapter.shelly.0 send kill signal
      host.raspberrypi	2023-02-04 14:22:51.581	info	stopInstance system.adapter.shelly.0 (force=false, process=true)
      host.raspberrypi	2023-02-04 14:22:51.566	info	"system.adapter.shelly.0" disabled
      host.raspberrypi	2023-02-04 14:21:28.094	error	cannot get getHostInfo: timeout
      blackvento
      Mod EDIT: LOG in CODE TAGS </> GEPACKT
      • wendy2702
        wendy2702 @blackvento last edited by
        @blackvento sagte in Skripte stoppen nicht:
        Ich denke das geht nicht?
        Sorry, kann dir gerade nicht folgen aber was willst du uns denn jetzt mit dem Log Zeigen?
        Das LOg bitte beim nächsten mal in Code Tags packen. Dieser Button "</>"
          @wendy2702
          "Was kommt im log wenn du stoppst?" war deine Frage . Deswegen habe ich den LOP nach dem Neustart ausgedruckt. Ich kann weder programmieren noch einen LOP lesen.
          "Ich denke das geht nicht?" Die Skripte laufen seit Jahren wunderbar aber die laufen auch weiter wenn ich die stoppe und im Skript angezeigt wird "Skript läuft nicht"
          " Code Tags packen. Dieser Button "</>" sorry, kannte ich nicht.
          Ich werde die Skripte löschen die ich vorübergehend nicht gebrauche.
          Nicht die feine Lösung aber eine andere habe ich jetzt nicht.
          Danke für deine Bemühung.
          • wendy2702
            Im Log sehe ich keinen Script stop. Nur einen Neustart vom Shelly Adapter.
            Kannst du von dem Script das du gestoppt hast mal einen Screenshot zeigen.
            Nicht löschen. Stoppen und ioBroker oder besser den kompletten Rechner mal neu starten.
              @wendy2702 wenn ich den Blockly so speichere
              und das Telegram Objekt so einstelle
              bekomme ich den Text angezeigt, kann aber den Skript nicht stoppen.
              Position der Schalusie WZ-Straße=>87%
              bekomme ich den Text zwei mal gesendet ohne % Angabe und kann den Skript stoppen.
              Ich hoffe das ich den Screenshot richtig eingefügt habe.
              crunchip bahnuhr 2 Replies Last reply Reply Quote 0
                crunchip Forum Testing Most Active @blackvento last edited by crunchip
                das eine ist per script und das andere ist direkt in den Objekten, das hast du aktiv, deswegen kommen auch Nachrichten, unabhängig vom blockly
                entweder oder, aber nicht beides
                denn das eine hat mit dem anderen nichts zu tun
                • bahnuhr
                  bahnuhr Forum Testing Most Active @blackvento last edited by
                  Schalusie
                  schreibt man dies jetzt so ?
                  oder ist das Phantasie
                    blackvento @crunchip last edited by blackvento
                    @crunchip
                    am liebsten wäre mir mit Blockly aber nur einmal die Nachricht und mit % Angabe.
                      @blackvento und was genau soll das blockly machen, nur den Positionsstand per telegram senden?
                        blackvento @bahnuhr last edited by
                        @bahnuhr
                        deine Frage hilft mir zwar nicht weiter aber ja, man kann
                        Schalusie
                        schreiben oder
                        Jalousie
                        was dir besser gefällt.
                        • bahnuhr
                          @bahnuhr
                          Schalusie
                          schreiben oder
                          Jalousie
                          lt. google nicht:a3466152-e4b8-4f96-928a-313223f377a7-image.png
                          Und weil dies so furchtbar aussieht, ist das für mich eher abschreckend überhaupt zu antworten oder den thread zu lesen.
                            @crunchip den Text
                            Position der Schalusie WZ-Straße XX%
                            bahnuhr crunchip 2 Replies Last reply Reply Quote 0
                            • bahnuhr
                              @crunchip den Text
                              und so wie du es schreibst schon mal gar nicht:
                              aber egal, beides ist falsch.
                              Und wie gesagt, ich lese nicht weiter; schreckt mich eher ab.
                                B 3 Replies Last reply Reply Quote 1
                                  @bahnuhr ich habe das Blockly geändert von Schalusie auf Jalousie.
                                  Es läuft aber noch immer nicht richtig. Hast du noch so einen wertvollen Tip?
                                    @crunchip werde ich testen und melde mich noch mal.
                                      @crunchip funktioniert, ich danke dir vielmals.
                                        @crunchip schade, doch noch nicht ganz.
                                        Alle Positionen werden gemeldet.
                                        Nur bei 0% kommt keine Nachricht.
                                        Abgefragt wird bei Objekt ID Position "shelly.0.SHSW-25#8CAAB561E454#1.Shutter.Position"
                                        Dort habe ich unter ALLGEMEIN den minimaler Wert von 0 auf -1 gestellt. Das hat auch nichts gebracht. Was kann ich noch probieren?
                                          warum verstellst du da etwas?
                                          was heisst, es kommt keine Nachricht bei 0?
                                          es wird gesendet sobald sich der DP ändert, dabei is es doch egal welcher Wert
                                          was zeigt denn Position als Wert, wenn der Rollo zu ist?
                                            @crunchip Position zeigt als Wert 0% an und Telegram sendet keine Nachricht. Stoppe ich bei 1% zeigt Telegram 1% an. Bei 0% bleibt das Handy stumm.
                                            crunchip 1 Reply Last reply Reply Quote -1
                                            1066
