    3. Einsteigerfragen
    4. Installation
    5. History Adapter läßt sich nicht installieren
      Thomas Braun Most Active @Bastel2021 last edited by
      @bastel2021 sagte in History Adapter läßt sich nicht installieren:
      Nur bei dem Javascript-Adapter gibt es Probleme: ERROR: Process exited with code 25
      Dann installier den mit --debug Option.
        Bastel2021 @Thomas Braun last edited by
        also du meinst im Terminal?
        Und wenn ja, wie muss ich dann eine Aktualisierung durchführen?
        • Glasfaser
          Glasfaser @Bastel2021 last edited by Glasfaser
          @bastel2021
          in der Konsole mit :
          iob upgrade javascript --debug
          dann die Ausgabe hier posten
            Bastel2021 @Glasfaser last edited by
            @glasfaser
            pi@raspberrypi:~ $ iob upgrade javascript --debug
            This upgrade of "javascript" will introduce the following changes:
            -> 6.1.4:
            Corrected small error in rules
            Tried to fix debug mode
            -> 6.1.3:
            Prevent adapter crash when script could not be compiled
            -> 6.1.2:
            Added ukrainian translation
            -> 6.1.0:
            Add a configurable check for number of setStates per Minute to prevent scripts f                                              rom taking down ioBroker. Default are 1000 setState per minute. Only stops if th                                              e number is reached 2 minutes in a row!
            Add createAlias method to create aliases for states
            Add setStateDelayed to selector
            Add options to exec command
            Fix issues with cancelling schedules when stopping scripts
            Corrected debug mode
            Would you like to upgrade javascript from @6.0.3 to @6.1.4 now? [(y)es, (n)o]: y
            Update javascript from @6.0.3 to @6.1.4
            NPM version: 8.19.3
            Installing iobroker.javascript@6.1.4... (System call)
            npm ERR! code ENOTEMPTY
            npm ERR! syscall rename
            npm ERR! path /opt/iobroker/node_modules/iobroker.javascript
            npm ERR! dest /opt/iobroker/node_modules/.iobroker.javascript-5NZ432mn
            npm ERR! errno -39
            npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/iobr                                              oker.javascript' -> '/opt/iobroker/node_modules/.iobroker.javascript-5NZ432mn'
            npm ERR!     /home/iobroker/.npm/_logs/2023-02-05T19_03_34_717Z-debug-0.log
            host.raspberrypi Cannot install iobroker.javascript@6.1.4: 217
            pi@raspberrypi:~ $
            • Glasfaser
              nochmal:
              for i in $(find /opt/iobroker/node_modules -type d -iname ".*-????????" ! -iname ".local-chromium"); do rm -rf ${i%%/}; done
                @glasfaser
                Siehe Terminal
                pi@raspberrypi:~ $ for i in $(find /opt/iobroker/node_modules -type d -iname ".*-????????" ! -iname ".local-chromium"); do rm                         -rf ${i%%/}; done
                pi@raspberrypi:~ $ ^C
                -> 6.1.4:
                -> 6.1.3:
                -> 6.1.2:
                -> 6.1.0:
                Add a configurable check for number of setStates per Minute to prevent scripts from taking down ioBroker. Default are 1000 set                        State per minute. Only stops if the number is reached 2 minutes in a row!
                NPM version: 8.19.3
                ^C
                pi@raspberrypi:~ $
                Glasfaser crunchip 2 Replies Last reply Reply Quote 0
                • Glasfaser
                  @bastel2021
                  sehe kein Fehler .. sollte jetzt die aktuelle 6.1.4 sein
                    @glasfaser
                    pi@raspberrypi:/opt/iobroker $ npm ls
                    iobroker.inst@3.0.0 /opt/iobroker
                    ├── iobroker.admin@6.3.5
                    ├── iobroker.backitup@2.5.10
                    ├── iobroker.discovery@3.1.0
                    ├── iobroker.flot@1.11.0
                    ├── iobroker.history@2.2.4
                    ├── iobroker.javascript@6.0.3
                    ├── iobroker.js-controller@4.0.23
                    ├── iobroker.mqtt@4.0.7
                    ├── iobroker.node-red@4.0.0
                    ├── iobroker.pushover@3.0.3
                    ├── iobroker.sonoff@2.5.1
                    ├── iobroker.web@4.3.0
                    └── iobroker.zigbee@1.8.10
                    • Glasfaser
                      @bastel2021
                      iob list adapters
                      sagt
                        @glasfaser
                        pi@raspberrypi:/opt/iobroker $ iob list adapters
                        system.adapter.admin                   : admin          - v6.3.5
                        system.adapter.backitup                : backitup       - v2.5.10
                        system.adapter.discovery               : discovery      - v3.1.0
                        system.adapter.flot                    : flot           - v1.11.0
                        system.adapter.history                 : history        - v2.2.4
                        system.adapter.javascript              : javascript     - v6.0.3
                        system.adapter.mqtt                    : mqtt           - v4.0.7
                        system.adapter.node-red                : node-red       - v4.0.0
                        system.adapter.pushover                : pushover       - v3.0.3
                        system.adapter.sonoff                  : sonoff         - v2.5.1
                        system.adapter.web                     : web            - v4.3.0
                        system.adapter.zigbee                  : zigbee         - v1.8.10
                        • Glasfaser
                          @bastel2021
                          Mache mal ein
                          sudo reboot
                            @glasfaser
                            nach Reboot
                            pi@raspberrypi:~ $ iob list adapters
                            pi@raspberrypi:~ $
                            • Glasfaser
                              @bastel2021
                              iobroker stop
                              rm /opt/iobroker/package*
                              iobroker start
                              iob list adapters
                                @glasfaser
                                pi@raspberrypi:~ $ iobroker stop
                                pi@raspberrypi:~ $ rm /opt/iobroker/package*
                                pi@raspberrypi:~ $ iobroker start
                                pi@raspberrypi:~ $
                                  crunchip Forum Testing Most Active @Bastel2021 last edited by
                                  ^C
                                  ist das überhaupt durchgelaufen?
                                  • Glasfaser
                                    @bastel2021
                                    iob list instances
                                    EDIT :
                                    iob list adapters
                                      Bastel2021 @crunchip last edited by
                                      @crunchip
                                      erst hatte ich gedacht das das System sich aufgehangen hat.
                                      Nach "Installing iobroker.javascript@6.1.4... (System call)" kam lange Zeit nichts mehr.
                                      Was das ^C zu bedeuten hat...?
                                      • Glasfaser
                                        @bastel2021
                                        Bitte nochmal die Befehle oben .....
                                          @glasfaser
                                          habe ich gemacht!
                                          System hat sich aufgehangen (Terminal Fenster ohne Reaktion)
                                          IOBroker über Admin nicht mehr erreichbar
                                          Werde den RPI neustarten
                                            @bastel2021 bitte immer alle Konsolen Einý und Ausgaben als Text in code-tags posten!
                                            2988
