    3. Einsteigerfragen
    4. Installation
    5. History Adapter läßt sich nicht installieren
      Bastel2021 @Thomas Braun last edited by
      also du meinst im Terminal?
      Und wenn ja, wie muss ich dann eine Aktualisierung durchführen?
      • Glasfaser
        Glasfaser @Bastel2021 last edited by Glasfaser
        @bastel2021
        in der Konsole mit :
        iob upgrade javascript --debug
        dann die Ausgabe hier posten
          Bastel2021 @Glasfaser last edited by
          @glasfaser
          pi@raspberrypi:~ $ iob upgrade javascript --debug
          This upgrade of "javascript" will introduce the following changes:
          -> 6.1.4:
          Corrected small error in rules
          Tried to fix debug mode
          -> 6.1.3:
          Prevent adapter crash when script could not be compiled
          -> 6.1.2:
          Added ukrainian translation
          -> 6.1.0:
          Add a configurable check for number of setStates per Minute to prevent scripts f                                              rom taking down ioBroker. Default are 1000 setState per minute. Only stops if th                                              e number is reached 2 minutes in a row!
          Add createAlias method to create aliases for states
          Add setStateDelayed to selector
          Add options to exec command
          Fix issues with cancelling schedules when stopping scripts
          Corrected debug mode
          Would you like to upgrade javascript from @6.0.3 to @6.1.4 now? [(y)es, (n)o]: y
          Update javascript from @6.0.3 to @6.1.4
          NPM version: 8.19.3
          Installing iobroker.javascript@6.1.4... (System call)
          npm ERR! code ENOTEMPTY
          npm ERR! syscall rename
          npm ERR! path /opt/iobroker/node_modules/iobroker.javascript
          npm ERR! dest /opt/iobroker/node_modules/.iobroker.javascript-5NZ432mn
          npm ERR! errno -39
          npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/iobr                                              oker.javascript' -> '/opt/iobroker/node_modules/.iobroker.javascript-5NZ432mn'
          npm ERR!     /home/iobroker/.npm/_logs/2023-02-05T19_03_34_717Z-debug-0.log
          host.raspberrypi Cannot install iobroker.javascript@6.1.4: 217
          pi@raspberrypi:~ $
          • Glasfaser
            @bastel2021 sagte in History Adapter läßt sich nicht installieren:
            nochmal:
            for i in $(find /opt/iobroker/node_modules -type d -iname ".*-????????" ! -iname ".local-chromium"); do rm -rf ${i%%/}; done
              @glasfaser
              Siehe Terminal
              pi@raspberrypi:~ $ for i in $(find /opt/iobroker/node_modules -type d -iname ".*-????????" ! -iname ".local-chromium"); do rm                         -rf ${i%%/}; done
              pi@raspberrypi:~ $ ^C
              -> 6.1.4:
              -> 6.1.3:
              -> 6.1.2:
              -> 6.1.0:
              Add a configurable check for number of setStates per Minute to prevent scripts from taking down ioBroker. Default are 1000 set                        State per minute. Only stops if the number is reached 2 minutes in a row!
              NPM version: 8.19.3
              ^C
              pi@raspberrypi:~ $
              Glasfaser crunchip 2 Replies Last reply Reply Quote 0
              • Glasfaser
                @bastel2021
                sehe kein Fehler .. sollte jetzt die aktuelle 6.1.4 sein
                  @glasfaser
                  pi@raspberrypi:/opt/iobroker $ npm ls
                  iobroker.inst@3.0.0 /opt/iobroker
                  ├── iobroker.admin@6.3.5
                  ├── iobroker.backitup@2.5.10
                  ├── iobroker.discovery@3.1.0
                  ├── iobroker.flot@1.11.0
                  ├── iobroker.history@2.2.4
                  ├── iobroker.javascript@6.0.3
                  ├── iobroker.js-controller@4.0.23
                  ├── iobroker.mqtt@4.0.7
                  ├── iobroker.node-red@4.0.0
                  ├── iobroker.pushover@3.0.3
                  ├── iobroker.sonoff@2.5.1
                  ├── iobroker.web@4.3.0
                  └── iobroker.zigbee@1.8.10
                  • Glasfaser
                    @bastel2021
                    iob list adapters
                    sagt
                      @glasfaser
                      pi@raspberrypi:/opt/iobroker $ iob list adapters
                      system.adapter.admin                   : admin          - v6.3.5
                      system.adapter.backitup                : backitup       - v2.5.10
                      system.adapter.discovery               : discovery      - v3.1.0
                      system.adapter.flot                    : flot           - v1.11.0
                      system.adapter.history                 : history        - v2.2.4
                      system.adapter.javascript              : javascript     - v6.0.3
                      system.adapter.mqtt                    : mqtt           - v4.0.7
                      system.adapter.node-red                : node-red       - v4.0.0
                      system.adapter.pushover                : pushover       - v3.0.3
                      system.adapter.sonoff                  : sonoff         - v2.5.1
                      system.adapter.web                     : web            - v4.3.0
                      system.adapter.zigbee                  : zigbee         - v1.8.10
                      • Glasfaser
                        @bastel2021
                        Mache mal ein
                        sudo reboot
                          @glasfaser
                          nach Reboot
                          pi@raspberrypi:~ $ iob list adapters
                          pi@raspberrypi:~ $
                          • Glasfaser
                            @bastel2021
                            iobroker stop
                            rm /opt/iobroker/package*
                            iobroker start
                            iob list adapters
                              @glasfaser
                              pi@raspberrypi:~ $ iobroker stop
                              pi@raspberrypi:~ $ rm /opt/iobroker/package*
                              pi@raspberrypi:~ $ iobroker start
                              pi@raspberrypi:~ $
                                crunchip Forum Testing Most Active @Bastel2021 last edited by
                                ^C
                                ist das überhaupt durchgelaufen?
                                • Glasfaser
                                  @bastel2021
                                  iob list instances
                                  EDIT :
                                  iob list adapters
                                    Bastel2021 @crunchip last edited by
                                    @crunchip
                                    erst hatte ich gedacht das das System sich aufgehangen hat.
                                    Nach "Installing iobroker.javascript@6.1.4... (System call)" kam lange Zeit nichts mehr.
                                    Was das ^C zu bedeuten hat...?
                                    • Glasfaser
                                      @bastel2021
                                      Bitte nochmal die Befehle oben .....
                                        @glasfaser
                                        habe ich gemacht!
                                        System hat sich aufgehangen (Terminal Fenster ohne Reaktion)
                                        IOBroker über Admin nicht mehr erreichbar
                                        Werde den RPI neustarten
                                          @bastel2021 bitte immer alle Konsolen Einý und Ausgaben als Text in code-tags posten!
                                            @glasfaser
                                            nach Neustart
                                            node:internal/modules/cjs/loader:998
                                              throw err;
                                            Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
                                                at Function.Module._resolveFilename (node:internal/modules/cjs/loader:995:15)
                                                at Function.Module._load (node:internal/modules/cjs/loader:841:27)
                                                at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:81:12)
                                                at node:internal/main/run_main_module:22:47 {
                                              code: 'MODULE_NOT_FOUND',
                                              requireStack: []
                                            pi@raspberrypi:~ $
                                            Glasfaser Homoran 2 Replies Last reply Reply Quote 0
                                            2988
