History Adapter läßt sich nicht installieren
pi@raspberrypi:~ $ iob upgrade javascript --debug This upgrade of "javascript" will introduce the following changes: ========================================================================== -> 6.1.4: Corrected small error in rules Tried to fix debug mode -> 6.1.3: Prevent adapter crash when script could not be compiled -> 6.1.2: Added ukrainian translation -> 6.1.0: Add a configurable check for number of setStates per Minute to prevent scripts f rom taking down ioBroker. Default are 1000 setState per minute. Only stops if th e number is reached 2 minutes in a row! Add createAlias method to create aliases for states Add setStateDelayed to selector Add options to exec command Fix issues with cancelling schedules when stopping scripts Corrected debug mode ========================================================================== Would you like to upgrade javascript from @6.0.3 to @6.1.4 now? [(y)es, (n)o]: y Update javascript from @6.0.3 to @6.1.4 NPM version: 8.19.3 Installing iobroker.javascript@6.1.4... (System call) npm ERR! code ENOTEMPTY npm ERR! syscall rename npm ERR! path /opt/iobroker/node_modules/iobroker.javascript npm ERR! dest /opt/iobroker/node_modules/.iobroker.javascript-5NZ432mn npm ERR! errno -39 npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/iobr oker.javascript' -> '/opt/iobroker/node_modules/.iobroker.javascript-5NZ432mn' npm ERR! A complete log of this run can be found in: npm ERR! /home/iobroker/.npm/_logs/2023-02-05T19_03_34_717Z-debug-0.log host.raspberrypi Cannot install iobroker.javascript@6.1.4: 217 pi@raspberrypi:~ $ -
@bastel2021 sagte in History Adapter läßt sich nicht installieren:
nochmal:
for i in $(find /opt/iobroker/node_modules -type d -iname ".*-????????" ! -iname ".local-chromium"); do rm -rf ${i%%/}; done -
@glasfaser
Siehe Terminalpi@raspberrypi:~ $ for i in $(find /opt/iobroker/node_modules -type d -iname ".*-????????" ! -iname ".local-chromium"); do rm -rf ${i%%/}; done pi@raspberrypi:~ $ ^C pi@raspberrypi:~ $ iob upgrade javascript --debug This upgrade of "javascript" will introduce the following changes: ========================================================================== -> 6.1.4: Corrected small error in rules Tried to fix debug mode -> 6.1.3: Prevent adapter crash when script could not be compiled -> 6.1.2: Added ukrainian translation -> 6.1.0: Add a configurable check for number of setStates per Minute to prevent scripts from taking down ioBroker. Default are 1000 set State per minute. Only stops if the number is reached 2 minutes in a row! Add createAlias method to create aliases for states Add setStateDelayed to selector Add options to exec command Fix issues with cancelling schedules when stopping scripts Corrected debug mode ========================================================================== Would you like to upgrade javascript from @6.0.3 to @6.1.4 now? [(y)es, (n)o]: y Update javascript from @6.0.3 to @6.1.4 NPM version: 8.19.3 Installing iobroker.javascript@6.1.4... (System call) ^C pi@raspberrypi:~ $ -
sehe kein Fehler .. sollte jetzt die aktuelle 6.1.4 sein
pi@raspberrypi:/opt/iobroker $ npm ls iobroker.inst@3.0.0 /opt/iobroker ├── iobroker.admin@6.3.5 ├── iobroker.backitup@2.5.10 ├── iobroker.discovery@3.1.0 ├── iobroker.flot@1.11.0 ├── iobroker.history@2.2.4 ├── iobroker.javascript@6.0.3 ├── iobroker.js-controller@4.0.23 ├── iobroker.mqtt@4.0.7 ├── iobroker.node-red@4.0.0 ├── iobroker.pushover@3.0.3 ├── iobroker.sonoff@2.5.1 ├── iobroker.web@4.3.0 └── iobroker.zigbee@1.8.10 pi@raspberrypi:/opt/iobroker $ -
pi@raspberrypi:/opt/iobroker $ iob list adapters system.adapter.admin : admin - v6.3.5 system.adapter.backitup : backitup - v2.5.10 system.adapter.discovery : discovery - v3.1.0 system.adapter.flot : flot - v1.11.0 system.adapter.history : history - v2.2.4 system.adapter.javascript : javascript - v6.0.3 system.adapter.mqtt : mqtt - v4.0.7 system.adapter.node-red : node-red - v4.0.0 system.adapter.pushover : pushover - v3.0.3 system.adapter.sonoff : sonoff - v2.5.1 system.adapter.web : web - v4.3.0 system.adapter.zigbee : zigbee - v1.8.10 pi@raspberrypi:/opt/iobroker $ -
@glasfaser
nach Rebootpi@raspberrypi:~ $ iob list adapters system.adapter.admin : admin - v6.3.5 system.adapter.backitup : backitup - v2.5.10 system.adapter.discovery : discovery - v3.1.0 system.adapter.flot : flot - v1.11.0 system.adapter.history : history - v2.2.4 system.adapter.javascript : javascript - v6.0.3 system.adapter.mqtt : mqtt - v4.0.7 system.adapter.node-red : node-red - v4.0.0 system.adapter.pushover : pushover - v3.0.3 system.adapter.sonoff : sonoff - v2.5.1 system.adapter.web : web - v4.3.0 system.adapter.zigbee : zigbee - v1.8.10 pi@raspberrypi:~ $ -
pi@raspberrypi:~ $ iobroker stop pi@raspberrypi:~ $ rm /opt/iobroker/package* pi@raspberrypi:~ $ iobroker start pi@raspberrypi:~ $ iob list adapters system.adapter.admin : admin - v6.3.5 system.adapter.backitup : backitup - v2.5.10 system.adapter.discovery : discovery - v3.1.0 system.adapter.flot : flot - v1.11.0 system.adapter.history : history - v2.2.4 system.adapter.javascript : javascript - v6.0.3 system.adapter.mqtt : mqtt - v4.0.7 system.adapter.node-red : node-red - v4.0.0 system.adapter.pushover : pushover - v3.0.3 system.adapter.sonoff : sonoff - v2.5.1 system.adapter.web : web - v4.3.0 system.adapter.zigbee : zigbee - v1.8.10 pi@raspberrypi:~ $ -
^C
ist das überhaupt durchgelaufen?
@crunchip
erst hatte ich gedacht das das System sich aufgehangen hat.
Nach "Installing iobroker.javascript@6.1.4... (System call)" kam lange Zeit nichts mehr.
Was das ^C zu bedeuten hat...? -
Bitte nochmal die Befehle oben .....
habe ich gemacht!
System hat sich aufgehangen (Terminal Fenster ohne Reaktion)
IOBroker über Admin nicht mehr erreichbarWerde den RPI neustarten
@bastel2021 bitte immer alle Konsolen Einý und Ausgaben als Text in code-tags posten!
https://forum.iobroker.net/topic/51555/hinweise-für-gute-forenbeiträge/1 -
@glasfaser
nach Neustartpi@raspberrypi:~ $ iob list adapters node:internal/modules/cjs/loader:998 throw err; ^ Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js' at Function.Module._resolveFilename (node:internal/modules/cjs/loader:995:15) at Function.Module._load (node:internal/modules/cjs/loader:841:27) at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:81:12) at node:internal/main/run_main_module:22:47 { code: 'MODULE_NOT_FOUND', requireStack: [] } pi@raspberrypi:~ $ -
cd /opt/iobroker sudo -H -u iobroker npm install iobroker.js-controller iobroker restart
