    4. Adapter "smartmeter"
      apollon77 @Thomas P 0 last edited by
      @thomas-p-0 bitte Screenshot der konfig und vollständiges debug log posten nichts weglassen wie oben (da hast du am Anfang was nicht dabei)
        Thomas P 0 @apollon77 last edited by
        @apollon77
        Hallo Apollon,
        2023-02-04 19:45:51.562  - info: host.zaehlerpi stopInstance system.adapter.smartmeter.0 (force=false, process=true)
        2023-02-04 19:45:51.574  - info: smartmeter.0 (3434) Got terminate signal TERMINATE_YOURSELF
        2023-02-04 19:45:51.578  - debug: smartmeter.0 (3434) STOP
        2023-02-04 19:45:51.580  - debug: smartmeter.0 (3434) CLEAR MESSAGE TIMEOUT TIMER
        2023-02-04 19:45:51.582  - info: smartmeter.0 (3434) terminating
        2023-02-04 19:45:51.585  - debug: smartmeter.0 (3434) Plugin sentry destroyed
        2023-02-04 19:45:51.586  - info: smartmeter.0 (3434) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
        2023-02-04 19:45:51.613  - info: host.zaehlerpi stopInstance system.adapter.smartmeter.0 send kill signal
        2023-02-04 19:45:52.177  - info: host.zaehlerpi instance system.adapter.smartmeter.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
        2023-02-04 19:45:54.674  - info: host.zaehlerpi instance system.adapter.smartmeter.0 started with pid 5793
        2023-02-04 19:45:58.307  - debug: smartmeter.0 (5793) Redis Objects: Use Redis connection: 127.0.0.1:9001
        2023-02-04 19:45:58.446  - debug: smartmeter.0 (5793) Objects client ready ... initialize now
        2023-02-04 19:45:58.454  - debug: smartmeter.0 (5793) Objects create System PubSub Client
        2023-02-04 19:45:58.459  - debug: smartmeter.0 (5793) Objects create User PubSub Client
        2023-02-04 19:45:58.550  - debug: smartmeter.0 (5793) Objects client initialize lua scripts
        2023-02-04 19:45:58.577  - debug: smartmeter.0 (5793) Objects connected to redis: 127.0.0.1:9001
        2023-02-04 19:45:58.628  - debug: smartmeter.0 (5793) Redis States: Use Redis connection: 127.0.0.1:9000
        2023-02-04 19:45:58.649  - debug: smartmeter.0 (5793) States create System PubSub Client
        2023-02-04 19:45:58.654  - debug: smartmeter.0 (5793) States create User PubSub Client
        2023-02-04 19:45:58.681  - debug: smartmeter.0 (5793) States connected to redis: 127.0.0.1:9000
        2023-02-04 19:45:58.744  - debug: smartmeter.0 (5793) Plugin sentry Initialize Plugin (enabled=true)
        2023-02-04 19:45:59.335  - info: smartmeter.0 (5793) starting. Version 3.3.4 in /opt/iobroker/node_modules/iobroker.smartmeter, node: v16.19.0, js-controller: 4.0.24
        2023-02-04 19:45:59.403  - debug: smartmeter.0 (5793) SmartmeterObis options: {"debug":2,"protocol":"D0Protocol","transport":"SerialRequestResponseTransport","requestInterval":"300","anotherQueryDelay":"1000","transportSerialPort":"/dev/serial/by-id/usb-Silicon_Labs_CP2102_USB_to_UART_Bridge_Controller_0041-if00-port0","transportSerialBaudrate":null,"transportSerialMessageTimeout":null,"protocolD0WakeupCharacters":0,"protocolD0DeviceAddress":"66002067","obisFallbackMedium":1}
        2023-02-04 19:45:59.411  - debug: smartmeter.0 (5793) CREATE SERIALPORT: 300 7 1 even
        2023-02-04 19:45:59.431  - debug: smartmeter.0 (5793) SERIALPORT OPEN
        2023-02-04 19:45:59.470  - debug: smartmeter.0 (5793) SERIALPORT RESET BAUDRATE TO 300
        2023-02-04 19:45:59.479  - debug: smartmeter.0 (5793) INITIAL MESSAGES TO SEND: 2
        2023-02-04 19:45:59.482  - debug: smartmeter.0 (5793) CURRENT PROCESS STEP 0 IN GETNEXTMESSAGE
        2023-02-04 19:45:59.484  - debug: smartmeter.0 (5793) TO SEND 2:
        2023-02-04 19:45:59.485  - debug: smartmeter.0 (5793) CURRENT PROCESS STEP 1 IN GETNEXTMESSAGE
        2023-02-04 19:45:59.487  - debug: smartmeter.0 (5793) TO SEND 1: /?66002067!
        2023-02-04 19:45:59.519  - debug: smartmeter.0 (5793) connected set to false
        2023-02-04 19:45:59.896  - debug: smartmeter.0 (5793) DONE SEND 1
        2023-02-04 19:45:59.958  - debug: smartmeter.0 (5793) NEW DATA
        2023-02-04 19:45:59.963  - debug: smartmeter.0 (5793) CURRENT PROCESS STEP 2 IN CHECKMESSAGE
        2023-02-04 19:45:59.964  - debug: smartmeter.0 (5793) MATCH-RESULT SIGNON: "/" -> null
        2023-02-04 19:45:59.988  - debug: smartmeter.0 (5793) NEW DATA
        2023-02-04 19:45:59.990  - debug: smartmeter.0 (5793) CURRENT PROCESS STEP 2 IN CHECKMESSAGE
        2023-02-04 19:45:59.992  - debug: smartmeter.0 (5793) MATCH-RESULT SIGNON: "/B" -> null
        2023-02-04 19:46:00.022  - debug: smartmeter.0 (5793) NEW DATA
        2023-02-04 19:46:00.024  - debug: smartmeter.0 (5793) CURRENT PROCESS STEP 2 IN CHECKMESSAGE
        2023-02-04 19:46:00.025  - debug: smartmeter.0 (5793) MATCH-RESULT SIGNON: "/BY" -> null
        2023-02-04 19:46:00.055  - debug: smartmeter.0 (5793) NEW DATA
        2023-02-04 19:46:00.057  - debug: smartmeter.0 (5793) CURRENT PROCESS STEP 2 IN CHECKMESSAGE
        2023-02-04 19:46:00.058  - debug: smartmeter.0 (5793) MATCH-RESULT SIGNON: "/BYL" -> null
        2023-02-04 19:46:00.089  - debug: smartmeter.0 (5793) NEW DATA
        2023-02-04 19:46:00.091  - debug: smartmeter.0 (5793) CURRENT PROCESS STEP 2 IN CHECKMESSAGE
        2023-02-04 19:46:00.093  - debug: smartmeter.0 (5793) MATCH-RESULT SIGNON: "/BYL6" -> null
        2023-02-04 19:46:00.122  - debug: smartmeter.0 (5793) NEW DATA
        2023-02-04 19:46:00.124  - debug: smartmeter.0 (5793) CURRENT PROCESS STEP 2 IN CHECKMESSAGE
        2023-02-04 19:46:00.126  - debug: smartmeter.0 (5793) MATCH-RESULT SIGNON: "/BYL6<" -> null
        2023-02-04 19:46:00.150  - debug: smartmeter.0 (5793) DONE SEND 0
        2023-02-04 19:46:00.154  - debug: smartmeter.0 (5793) SET MESSAGE TIMEOUT TIMER2: 120000
        2023-02-04 19:46:00.177  - debug: smartmeter.0 (5793) NEW DATA
        2023-02-04 19:46:00.179  - debug: smartmeter.0 (5793) CURRENT PROCESS STEP 2 IN CHECKMESSAGE
        2023-02-04 19:46:00.181  - debug: smartmeter.0 (5793) MATCH-RESULT SIGNON: "/BYL6<1" -> null
        2023-02-04 19:46:00.192  - debug: smartmeter.0 (5793) NEW DATA
        2023-02-04 19:46:00.194  - debug: smartmeter.0 (5793) CURRENT PROCESS STEP 2 IN CHECKMESSAGE
        2023-02-04 19:46:00.195  - debug: smartmeter.0 (5793) MATCH-RESULT SIGNON: "/BYL6<1>" -> null
        2023-02-04 19:46:00.222  - debug: smartmeter.0 (5793) NEW DATA
        2023-02-04 19:46:00.224  - debug: smartmeter.0 (5793) CURRENT PROCESS STEP 2 IN CHECKMESSAGE
        2023-02-04 19:46:00.225  - debug: smartmeter.0 (5793) MATCH-RESULT SIGNON: "/BYL6<1>B" -> null
        2023-02-04 19:46:00.256  - debug: smartmeter.0 (5793) NEW DATA
        2023-02-04 19:46:00.257  - debug: smartmeter.0 (5793) CURRENT PROCESS STEP 2 IN CHECKMESSAGE
        2023-02-04 19:46:00.258  - debug: smartmeter.0 (5793) MATCH-RESULT SIGNON: "/BYL6<1>BY" -> null
        2023-02-04 19:46:00.288  - debug: smartmeter.0 (5793) NEW DATA
        2023-02-04 19:46:00.289  - debug: smartmeter.0 (5793) CURRENT PROCESS STEP 2 IN CHECKMESSAGE
        2023-02-04 19:46:00.290  - debug: smartmeter.0 (5793) MATCH-RESULT SIGNON: "/BYL6<1>BYL" -> null
        2023-02-04 19:46:00.322  - debug: smartmeter.0 (5793) NEW DATA
        2023-02-04 19:46:00.323  - debug: smartmeter.0 (5793) CURRENT PROCESS STEP 2 IN CHECKMESSAGE
        2023-02-04 19:46:00.324  - debug: smartmeter.0 (5793) MATCH-RESULT SIGNON: "/BYL6<1>BYL-" -> null
        2023-02-04 19:46:00.355  - debug: smartmeter.0 (5793) NEW DATA
        2023-02-04 19:46:00.356  - debug: smartmeter.0 (5793) CURRENT PROCESS STEP 2 IN CHECKMESSAGE
        2023-02-04 19:46:00.357  - debug: smartmeter.0 (5793) MATCH-RESULT SIGNON: "/BYL6<1>BYL-C" -> null
        2023-02-04 19:46:00.388  - debug: smartmeter.0 (5793) NEW DATA
        2023-02-04 19:46:00.390  - debug: smartmeter.0 (5793) CURRENT PROCESS STEP 2 IN CHECKMESSAGE
        2023-02-04 19:46:00.391  - debug: smartmeter.0 (5793) MATCH-RESULT SIGNON: "/BYL6<1>BYL-CR" -> null
        2023-02-04 19:46:00.423  - debug: smartmeter.0 (5793) NEW DATA
        2023-02-04 19:46:00.424  - debug: smartmeter.0 (5793) CURRENT PROCESS STEP 2 IN CHECKMESSAGE
        2023-02-04 19:46:00.425  - debug: smartmeter.0 (5793) MATCH-RESULT SIGNON: "/BYL6<1>BYL-CRH" -> null
        2023-02-04 19:46:00.455  - debug: smartmeter.0 (5793) NEW DATA
        2023-02-04 19:46:00.456  - debug: smartmeter.0 (5793) CURRENT PROCESS STEP 2 IN CHECKMESSAGE
        2023-02-04 19:46:00.457  - debug: smartmeter.0 (5793) MATCH-RESULT SIGNON: "/BYL6<1>BYL-CRH-" -> null
        2023-02-04 19:46:00.489  - debug: smartmeter.0 (5793) NEW DATA
        2023-02-04 19:46:00.490  - debug: smartmeter.0 (5793) CURRENT PROCESS STEP 2 IN CHECKMESSAGE
        2023-02-04 19:46:00.491  - debug: smartmeter.0 (5793) MATCH-RESULT SIGNON: "/BYL6<1>BYL-CRH-B" -> null
        2023-02-04 19:46:00.521  - debug: smartmeter.0 (5793) NEW DATA
        2023-02-04 19:46:00.523  - debug: smartmeter.0 (5793) CURRENT PROCESS STEP 2 IN CHECKMESSAGE
        2023-02-04 19:46:00.524  - debug: smartmeter.0 (5793) MATCH-RESULT SIGNON: "/BYL6<1>BYL-CRH-BT" -> null
        2023-02-04 19:46:00.556  - debug: smartmeter.0 (5793) NEW DATA
        2023-02-04 19:46:00.558  - debug: smartmeter.0 (5793) CURRENT PROCESS STEP 2 IN CHECKMESSAGE
        2023-02-04 19:46:00.559  - debug: smartmeter.0 (5793) MATCH-RESULT SIGNON: "/BYL6<1>BYL-CRH-BTK" -> null
        2023-02-04 19:46:00.588  - debug: smartmeter.0 (5793) NEW DATA
        2023-02-04 19:46:00.589  - debug: smartmeter.0 (5793) CURRENT PROCESS STEP 2 IN CHECKMESSAGE
        2023-02-04 19:46:00.590  - debug: smartmeter.0 (5793) MATCH-RESULT SIGNON: "/BYL6<1>BYL-CRH-BTK3" -> null
        2023-02-04 19:46:00.622  - debug: smartmeter.0 (5793) NEW DATA
        2023-02-04 19:46:00.623  - debug: smartmeter.0 (5793) CURRENT PROCESS STEP 2 IN CHECKMESSAGE
        2023-02-04 19:46:00.624  - debug: smartmeter.0 (5793) MATCH-RESULT SIGNON: "/BYL6<1>BYL-CRH-BTK30" -> null
        2023-02-04 19:46:00.654  - debug: smartmeter.0 (5793) NEW DATA
        2023-02-04 19:46:00.657  - debug: smartmeter.0 (5793) CURRENT PROCESS STEP 2 IN CHECKMESSAGE
        2023-02-04 19:46:00.658  - debug: smartmeter.0 (5793) MATCH-RESULT SIGNON: "/BYL6<1>BYL-CRH-BTK30-" -> null
        2023-02-04 19:46:00.688  - debug: smartmeter.0 (5793) NEW DATA
        2023-02-04 19:46:00.690  - debug: smartmeter.0 (5793) CURRENT PROCESS STEP 2 IN CHECKMESSAGE
        2023-02-04 19:46:00.691  - debug: smartmeter.0 (5793) MATCH-RESULT SIGNON: "/BYL6<1>BYL-CRH-BTK30-R" -> null
        2023-02-04 19:46:00.722  - debug: smartmeter.0 (5793) NEW DATA
        2023-02-04 19:46:00.723  - debug: smartmeter.0 (5793) CURRENT PROCESS STEP 2 IN CHECKMESSAGE
        2023-02-04 19:46:00.725  - debug: smartmeter.0 (5793) MATCH-RESULT SIGNON: "/BYL6<1>BYL-CRH-BTK30-R1" -> null
        2023-02-04 19:46:00.755  - debug: smartmeter.0 (5793) NEW DATA
        2023-02-04 19:46:00.756  - debug: smartmeter.0 (5793) CURRENT PROCESS STEP 2 IN CHECKMESSAGE
        2023-02-04 19:46:00.757  - debug: smartmeter.0 (5793) MATCH-RESULT SIGNON: "/BYL6<1>BYL-CRH-BTK30-R1\r" -> null
        2023-02-04 19:46:00.789  - debug: smartmeter.0 (5793) NEW DATA
        2023-02-04 19:46:00.790  - debug: smartmeter.0 (5793) CURRENT PROCESS STEP 2 IN CHECKMESSAGE
        2023-02-04 19:46:00.791  - debug: smartmeter.0 (5793) MATCH-RESULT SIGNON: "/BYL6<1>BYL-CRH-BTK30-R1\r\n" -> null
        2023-02-04 19:48:00.159  - debug: smartmeter.0 (5793) MESSAGE TIMEOUT TRIGGERED
        2023-02-04 19:48:00.162  - debug: smartmeter.0 (5793) Error: No or too long answer from Serial Device after last request.
        2023-02-04 19:48:00.167  - warn: smartmeter.0 (5793) No or too long answer from Serial Device after last request.
        2023-02-04 19:48:00.169  - debug: smartmeter.0 (5793) Error: No or too long answer from Serial Device after last request.
        2023-02-04 19:48:00.170  - debug: smartmeter.0 (5793) Transport Reset!! Restart = true
        2023-02-04 19:48:00.173  - debug: smartmeter.0 (5793) STOP
        2023-02-04 19:48:00.174  - debug: smartmeter.0 (5793) CLEAR MESSAGE TIMEOUT TIMER
        2023-02-04 19:48:00.190  - debug: smartmeter.0 (5793) SERIALPORT CLOSE
        2023-02-04 19:48:00.192  - debug: smartmeter.0 (5793) SERIALPORT REMOVE LISTENERS
        2023-02-04 19:48:00.198  - debug: smartmeter.0 (5793) CURRENT SIGNON MESSAGE COUNTER 1 OF 1
        2023-02-04 19:48:00.200  - debug: smartmeter.0 (5793) DELETE rest of data (0) because new Message start with a new Request Message
        2023-02-04 19:48:00.201  - debug: smartmeter.0 (5793) SCHEDULE NEXT RUN IN 300000s
        Das ist ein ganzer Abfragezyklus. Ich habe den Adapter eu gestartet, um die Abfrage auszulösen.
        MfG
        Thomas Pfaffinger
          apollon77 @Thomas P 0 last edited by apollon77
          @thomas-p-0 warum ist bei Modus override ein C drin? Der Grund ist aktuell das er die signon Nachricht nicht erkennt. Daher geht’s nicht weiter. Mein Tipp liegt an den < Bzw >. Muss schauen was die specs sagen aber solche Zeichen wären mir an sich neu. Dann müsste ich das einbauen. Wenn die Kinderbibel Bett sind schaue ich mal.
          Edit aaahhhhhhh tja die signon ist zu lang formal … um ein Zeichen zu lang.
          https://github.com/Apollon77/smartmeter-obis/blob/master/lib/protocols/D0Protocol.js Hier zeile 9 das 4,22 heißt „nach dem / kommen vor dem Zeilenende 4 bis 22 Zeichen“. Dein Zähler senden …. Trommelwirbel …. 23 (wenn ich mich nicht verzählt hab) kannst das file mal suchen und nen 23 reinschreiben anstelle der 22. wenn’s dann weitergeht ist’s das. Dann bitte github issue Anlegen. Muss ich wohl das Limit ändern. Hachja. Standards und die Hersteller …
            Thomas P 0 @apollon77 last edited by Thomas P 0
            @apollon77 said in Adapter "smartmeter":
            D0Protocol.js
            Guten Morgen Appollon,
            ja das war es. Jetzt funktioniert es. Vielen Dank. Kann man dir irgendwie ein Dankeschön zukommen lassen?
            In meinen Spec stehen übrigens 32 Zeichen. Welche ist denn nun richtig? 🙂
            iec62056-21_en
            Und ja, das ist der Grund, warum ich in der IT arbeite. Ein Zeichen und schon geht es
            MfG
            Thomas Pfaffinger
            P.S.: Issue ist angelegt. Ich hoffe, das ich das richtig gemacht habe. Ist mein erster
            apollon77 2 Replies Last reply Reply Quote 0
              @thomas-p-0 na dann lese ich mal deine specs ;-)) vllt gabs ein Update.
              Zum „zukommen lassen“ ist Link in meinem footer hier im Forum Oder auch im github bei den Adaptern Seite und oben unter „Sponsor“ als begriff. Danke.
                @thomas-p-0 ich gehe davon aus das mit der Änderung bei dir erstmal alles tut? Oder geht noch irgendetwas nicht?
                  @apollon77
                  Allo Apollon,
                  nein, soweit alles perfekt.
                  MfG
                  Thomas Pfaffinger
                    @thomas-p-0 Ok, dann Todo liste 🙂
                      mirko3107 last edited by
                      ich habe in meinem Zählerschrank einen "Sagemcom Smarty BZ-Plus" verbaut, einen Zweirichtungszähler.
                      Aus diesem hatte ich gehofft, die Werte für den aktuellen Verbauch sowie für die einzelnen Phasen per D0
                      auslesen zu können.
                      Hab einen USB-IR-Lesekopf an einem Raspberry und einer kleinen Iobroker-Installation als Slave.
                      Mein erster Erfolg war ein Auslesen per SML, aber da kam nur der aktuelle Verbrauch und ein paar Zählerstände.
                      Hab dann D0 versucht, da spuckt er mir aber nur Zählerstände aus für jeden Monat des vergangenen Jahres,
                      keine aktuellen Verbräuche.
                      Hat noch jemand diesen Zähler erfolgreich auslesen können?
                      Handbuch1
                      Handbuch2
                      Meine Settings:
                      Mirko
                      Homoran wendy2702 2 Replies Last reply Reply Quote 0
                        Homoran Global Moderator Administrators @mirko3107 last edited by
                        @mirko3107 sagte in Adapter "smartmeter":
                        das ist dann der richtige Weg gewesen.
                        Meht gibt es meistens nicht.
                        • wendy2702
                          wendy2702 @mirko3107 last edited by
                          @mirko3107 Im Handbuch 1 Seite 16/17 steht doch genau welche Daten man mit welchem Protokoll abfragen kann.
                          Mehr geht halt nicht.
                            Wenn ich im Handbuch2 auf Seite 77 lese, hatte ich mir mehr Werte erhofft, aber wenn nicht mehr kommt, nutzt
                            mir das alles nix.
                            wendy2702 Homoran 2 Replies Last reply Reply Quote 0
                            • wendy2702
                              @mirko3107 Hast du PIN, Passwort 1 oder 2 ?
                              Ist das eine Handbuch vom Versorger und das andere vom Hersteller?
                              Nicht alles was der Hersteller theoretisch kann wird auch vom Versorger „gekauft“ bzw. An den Endkunden weitergegeben. Bist hier nicht der erste der so etwas hat.
                              Welche Werte benötigst du denn?
                                was kommt denn?
                                kann alles und nichts bedeuten.
                                  mirko3107 last edited by mirko3107
                                  PIN hatte ich bekommen, hab die Abfrage deaktiviert.
                                  Mir geht es um den aktuellen Gesamtverbrauch und die Verbräuche auf L1, L2, L3, mehr nicht.
                                  Im Iobroker seh ich jede Menge Zählerstände, aber keine Momentanverbräuche. Pro Abfrage kommen laut
                                  Log 137Werte.
                                    mirko3107 @wendy2702 last edited by
                                    @wendy2702 sagte in Adapter "smartmeter":
                                    das sind welche die im Netz verfügbar sind, wenn man nach der Gerätebezeichnung googelt.
                                      hast du auch INF auf on gestellt?
                                      Log 137Werte.
                                      dann besteht Hoffnung, dass du einen spendablen Versorger hast.
                                      klapp mal die Ordner auf
                                        Inf ist auf On.
                                        • wendy2702
                                          @mirko3107 Wenn jetzt bei den 173 Werten die Verbräuche der einzelnen Phasen fehlen wird es wohl keine Möglichkeit geben. Sollte Strom und Spannung (die ist eigentlich relativ klar) angezeigt werden muss man rechnen.
                                            Homoran Global Moderator Administrators @mirko3107 last edited by Homoran
                                            @mirko3107 hast du eine Wert für 1-0:16_7_0__255 ?
                                            3625
                                            2289842
