    • wendy2702
      @armilar Danke. Das hat erstmal funktioniert.
      Allerdings bekomme ich im log des Scripts diese Meldungen wenn der Screensaver aktiv wird:
      18:26:00.792	info	javascript.1 (77070) script.js.common.NSPanel.NSPanel_Dev: HandleScreensaverStatusIcons: Cannot read properties of null (reading 'toFixed')
      18:26:19.879	warn	javascript.1 (77070) at HandleScreensaverStatusIcons (script.js.common.NSPanel.NSPanel_Dev:7473:39)
      18:26:19.880	warn	javascript.1 (77070) at HandleScreensaverUpdate (script.js.common.NSPanel.NSPanel_Dev:7393:13)
      18:26:19.880	warn	javascript.1 (77070) at HandleScreensaver (script.js.common.NSPanel.NSPanel_Dev:7268:5)
      18:26:19.880	warn	javascript.1 (77070) at HandleMessage (script.js.common.NSPanel.NSPanel_Dev:3467:21)
      18:26:19.880	warn	javascript.1 (77070) at Object.<anonymous> (script.js.common.NSPanel.NSPanel_Dev:3401:25)
      18:26:19.880	warn	javascript.1 (77070) at step (script.js.common.NSPanel.NSPanel_Dev:33:23)
      18:26:19.880	warn	javascript.1 (77070) at Object.next (script.js.common.NSPanel.NSPanel_Dev:14:53)
      18:26:19.880	warn	javascript.1 (77070) at script.js.common.NSPanel.NSPanel_Dev:8:71
      18:26:19.880	warn	javascript.1 (77070) at __awaiter (script.js.common.NSPanel.NSPanel_Dev:4:12)
      18:26:19.880	warn	javascript.1 (77070) at Object.<anonymous> (script.js.common.NSPanel.NSPanel_Dev:3393:12)
      18:26:19.880	info	javascript.1 (77070) script.js.common.NSPanel.NSPanel_Dev: HandleScreensaverStatusIcons: Cannot read properties of null (reading 'toFixed')
      18:26:20.837	warn	javascript.1 (77070) at HandleScreensaverStatusIcons (script.js.common.NSPanel.NSPanel_Dev:7473:39)
      18:26:20.837	warn	javascript.1 (77070) at HandleScreensaverUpdate (script.js.common.NSPanel.NSPanel_Dev:7393:13)
      18:26:20.837	warn	javascript.1 (77070) at Object.<anonymous> (script.js.common.NSPanel.NSPanel_Dev:3389:9)
      18:26:20.838	info	javascript.1 (77070) script.js.common.NSPanel.NSPanel_Dev: HandleScreensaverStatusIcons: Cannot read properties of null (reading 'toFixed')
      18:26:22.221	warn	javascript.1 (77070) at HandleScreensaverStatusIcons (script.js.common.NSPanel.NSPanel_Dev:7473:39)
      18:26:22.221	warn	javascript.1 (77070) at HandleScreensaverUpdate (script.js.common.NSPanel.NSPanel_Dev:7393:13)
      18:26:22.221	warn	javascript.1 (77070) at Object.<anonymous> (script.js.common.NSPanel.NSPanel_Dev:3389:9)
      18:26:22.221	info	javascript.1 (77070) script.js.common.NSPanel.NSPanel_Dev: HandleScreensaverStatusIcons: Cannot read properties of null (reading 'toFixed')
      18:26:23.604	warn	javascript.1 (77070) at HandleScreensaverStatusIcons (script.js.common.NSPanel.NSPanel_Dev:7473:39)
      18:26:23.604	warn	javascript.1 (77070) at HandleScreensaverUpdate (script.js.common.NSPanel.NSPanel_Dev:7393:13)
      18:26:23.604	warn	javascript.1 (77070) at Object.<anonymous> (script.js.common.NSPanel.NSPanel_Dev:3389:9)
      18:26:23.605	info	javascript.1 (77070) script.js.common.NSPanel.NSPanel_Dev: HandleScreensaverStatusIcons: Cannot read properties of null (reading 'toFixed')
      18:26:24.889	warn	javascript.1 (77070) at HandleScreensaverStatusIcons (script.js.common.NSPanel.NSPanel_Dev:7473:39)
      18:26:24.889	warn	javascript.1 (77070) at HandleScreensaverUpdate (script.js.common.NSPanel.NSPanel_Dev:7393:13)
      18:26:24.889	warn	javascript.1 (77070) at Object.<anonymous> (script.js.common.NSPanel.NSPanel_Dev:3389:9)
      18:26:24.889	info	javascript.1 (77070) script.js.common.NSPanel.NSPanel_Dev: HandleScreensaverStatusIcons: Cannot read properties of null (reading 'toFixed')
      18:26:25.534	info	javascript.1 (77070) Stop script script.js.common.NSPanel.NSPanel_Dev
      Ich habe das Script vom richtigen Panel nur in eine neue Instanz kopiert und die Datenpunkte angepasst. Habe ich dabei noch etwas vergessen?
      EDIT:
      Ich sehe gerade das ich zumindest eine der Zeilen auch beim echten Panel bekomme:
      17:50:10.133	info	javascript.0 (77055) script.js.common.NSPanel.NSPANEL_1_3_9_0: HandleScreensaverStatusIcons: Cannot read properties of null (reading 'toFixed')
      17:50:11.508	info	javascript.0 (77055) script.js.common.NSPanel.NSPANEL_1_3_9_0: HandleScreensaverStatusIcons: Cannot read properties of null (reading 'toFixed')
      17:50:12.814	info	javascript.0 (77055) script.js.common.NSPanel.NSPANEL_1_3_9_0: HandleScreensaverStatusIcons: Cannot read properties of null (reading 'toFixed')
      17:50:14.128	info	javascript.0 (77055) script.js.common.NSPanel.NSPANEL_1_3_9_0: HandleScreensaverStatusIcons: Cannot read properties of null (reading 'toFixed')
      17:50:15.499	info	javascript.0 (77055) script.js.common.NSPanel.NSPANEL_1_3_9_0: HandleScreensaverStatusIcons: Cannot read properties of null (reading 'toFixed')
      17:50:16.847	info	javascript.0 (77055) script.js.common.NSPanel.NSPANEL_1_3_9_0: HandleScreensaverStatusIcons: Cannot read properties of null (reading 'toFixed')
      17:50:18.158	info	javascript.0 (77055) script.js.common.NSPanel.NSPANEL_1_3_9_0: HandleScreensaverStatusIcons: Cannot read properties of null (reading 'toFixed')
      17:50:19.496	info	javascript.0 (77055) script.js.common.NSPanel.NSPANEL_1_3_9_0: HandleScreensaverStatusIcons: Cannot read properties of null (reading 'toFixed')
      17:50:20.821	info	javascript.0 (77055) script.js.common.NSPanel.NSPANEL_1_3_9_0: HandleScreensaverStatusIcons: Cannot read properties of null (reading 'toFixed')
      17:50:22.215	info	javascript.0 (77055) script.js.common.NSPanel.NSPANEL_1_3_9_0: HandleScreensaverStatusIcons: Cannot read properties of null (reading 'toFixed')
      17:50:23.472	info	javascript.0 (77055) script.js.common.NSPanel.NSPANEL_1_3_9_0: HandleScreensaverStatusIcons: Cannot read properties of null (reading 'toFixed')
      17:50:24.777	info	javascript.0 (77055) script.js.common.NSPanel.NSPANEL_1_3_9_0: HandleScreensaverStatusIcons: Cannot read properties of null (reading 'toFixed')
      17:50:26.102	info	javascript.0 (77055) script.js.common.NSPanel.NSPANEL_1_3_9_0: HandleScreensaverStatusIcons: Cannot read properties of null (reading 'toFixed')
      17:50:27.441	info	javascript.0 (77055) script.js.common.NSPanel.NSPANEL_1_3_9_0: HandleScreensaverStatusIcons: Cannot read properties of null (reading 'toFixed')
      17:50:28.764	info	javascript.0 (77055) script.js.common.NSPanel.NSPANEL_1_3_9_0: HandleScreensaverStatusIcons: Cannot read properties of null (reading 'toFixed')
      17:50:30.010	info	javascript.0 (77055) script.js.common.NSPanel.NSPANEL_1_3_9_0: HandleScreensaverStatusIcons: Cannot read properties of null (reading 'toFixed')
      17:50:30.070	info	javascript.0 (77055) script.js.common.NSPanel.NSPANEL_1_3_9_0: HandleScreensaverStatusIcons: Cannot read properties of null (reading 'toFixed')
      17:50:31.407	info	javascript.0 (77055) script.js.common.NSPanel.NSPANEL_1_3_9_0: HandleScreensaverStatusIcons: Cannot read properties of null (reading 'toFixed')
      17:50:32.723	info	javascript.0 (77055) script.js.common.NSPanel.NSPANEL_1_3_9_0: HandleScreensaverStatusIcons: Cannot read properties of null (reading 'toFixed')
      17:50:34.062	info	javascript.0 (77055) script.js.common.NSPanel.NSPANEL_1_3_9_0: HandleScreensaverStatusIcons: Cannot read properties of null (reading 'toFixed')
      17:50:35.376	info	javascript.0 (77055) script.js.common.NSPanel.NSPANEL_1_3_9_0: HandleScreensaverStatusIcons: Cannot read properties of null (reading 'toFixed')
      • Armilar
        Armilar Most Active Forum Testing @wendy2702 last edited by Armilar
        @wendy2702
        Ja, du hast vergessen, dass das NSPanel als Emulator keine Relais hat 😉
        Kannst entweder die MRIcons auf null setzten, oder auf das andere NSPanel
        wendy2702 1 Reply Last reply Reply Quote 1
        • wendy2702
          wendy2702 @Armilar last edited by
          @armilar Hm,
          habe das Script ja wie geschrieben 1zu1 kopiert und an der stelle nichts geändert. Für dass DEV sieht das so aus:
          Ich denke du meinst die beiden markierten Einträge, oder?
          Für das echte Panel sieht das so aus:
          Oder meinst du noch einen anderen Eintrag?
          • Armilar
            @wendy2702
            Könntest du mir auch jeweils einen Verbindungsstring geben? Z.B. den für den CustomSend. Macht es dann einfacher zu raten, ob dein MQTT-String so ist wie meiner oder ob da Abweichungen sind 😉
            Und ja, das sind die beiden Übeltäter 😊
            • wendy2702
              @armilar Sorry, dauert was.
              Nachdem ich den Rechner aus gemacht hatte und den ESP dadurch natürlich Stromlos bekomme ich es jetzt überhaupt nicht mehr zum laufen. Auch die WLAN Verbindung zum ESP bricht ständig ab. Da ich neu im ESP Thema bin muss ich da erstmal probieren.
              • Armilar
                @wendy2702
                Lasse dir Zeit...
                • wendy2702
                  @armilar Ich hoffe du meinst das aus CustomSend:
                  weatherUpdate~~~~19017~~1 °C~~~~65168~Leistung~1090 W~~~~34351~Wind~3.3km/h~~~~26095~UV~0~~~~64750~Luft~93%~
                  Bei dem echten Panel sieht das so aus:
                  statusUpdate~~17299~梅20.4°~65504~~~
                  Ich habe diese zwei Unterschiede im Script: Links echtes Panel, Rechts Emulator
                  Hier habe ich lediglich den Namen in der Anzeige geändert:
                  • Armilar
                    @wendy2702
                    Ich meinte tatsächlich die Infos aus dem mittleren Screenshot. Also alles da...
                    Das DEV-Emu-Panel dürfte keine Analog Temperatur bekommen, da es keinen Temperatursensor hat. Also funktioniert die Suche vom
                    NSPanel_Path + 'Sensor.ANALOG.Temperature'
                    nicht. Trage bitte in den Datenpunkt unter Objekte des DEV-Panels mal eine fiktive Temperatur (z.B. 22,1) ein.
                    • wendy2702
                      @armilar OK.
                      Teste ich morgen früh.
                      Danke abermals für deine schnelle Hilfe.
                      Habe ich das in der Anleitung eigentlich überlesen?
                      Armilar 1 Reply Last reply Reply Quote 1
                      • Armilar
                        @wendy2702
                        Hat sich viel getan in der Zwischenzeit. Und der 2. Datenpunkt in den MRIcons ist neu... Wird also nicht explizit drin stehen.
                        Fakt ist: der EMU-ESP32 hat keine Relais und keine Sensoren. Bis auf die ESP-Temperatur mit
                        setOption146 1
                        Demnach bleibt die Temperatur im Datenpunkt auch ungefüllt. Wenn du jetzt auf den Datenpunkt zugreifst und mit toFixed() eine Nachkommastelle mitgibst, dann hast du 2 Fehler auf einmal.
                        1. Der Datenpunkt ist null
                        2. Die Nachommastelle von null ist nicht da
                        Also: einmal unter:
                        0_userdate.0.NSPanel.Dev.Sensor.ANALOG.Temperature
                        irgendeine Zahl für irgendeine Sensortemperatur reinschreiben und der Spuk sollte ein Ende haben.
                        • wendy2702
                          wendy2702 @Armilar last edited by wendy2702
                          @armilar ok.
                          Wie geschrieben mache ich morgen früh.
                          Habe die Anleitung so oft gelesen das ich schon sorge hatte ich habe das überlesen.
                          EDIT: Object angelegt, Wert eingetragen und ruhe ist im Log.
                          DANKE!
                          • Armilar
                            @wendy2702 sagte in SONOFF NSPanel mit Lovelace UI:
                            So habe die Wiki für den Emulator mal kurz an den aktuellen Stand angepasst.
                            • Gargano
                              Gargano @Armilar last edited by
                              @armilar sagte in SONOFF NSPanel mit Lovelace UI:
                              Fehlermeldung im Editor:
                              Error:Invalid number of arguments:qrcode m1.x,m1.y,200,defaultBcoColor,65535,-1,vaQR.txt( Double click to jump to code)
                              Error:Invalid number of arguments:qrcode m0.x,m0.y,200,defaultBcoColor,65535,-1,vaQR.txt( Double click to jump to code)
                              Error:Compile failed! 2 Errors, 1 Warnings,
                              Kommt vom letzten Update des Nextion Editor's
                              https://nextion.tech/download/nextion-setup-v1-63-3.exe
                              https://nextion.tech/download/nextion-setup-v1-63-3.zip
                              Installiert mal die Version... Die aber dann nicht uppen...
                              Wie ist denn dann die Syntax mit der aktuellen Version des Nextion Editor's ?
                              Armilar J 2 Replies Last reply Reply Quote 0
                              • Armilar
                                Armilar Most Active Forum Testing @Gargano last edited by
                                @gargano
                                Es gibt keine Syntax für einen Bug im Nextion Editor...
                                Deinstallieren und die 1.63.3 installieren.
                                  joBr99 @Gargano last edited by
                                  @gargano
                                  qrcode 8,m1.x,m1.y,200,defaultBcoColor,65535,-1,vaQR.txt
                                  qrcode 8,m0.x,m0.y,200,defaultBcoColor,65535,-1,vaQR.txt
                                  Diese Änderung ist seitens Nextion aber nirgends dokumentiert und da neue Editor Versionen in der Vergangenheit lustige Seiteneffekte hatten werde ich mit dem Update von dem Editor noch etwas warten, die Version .1 mit Bugfixes kam ja auch schon, erstmal abwarten, was da sonst noch so kommt.
                                  • N
                                    niiccooo1 last edited by
                                    Hallo Zusammen,
                                    ich bin gerade dabei meine Aliase etwas aufzuräumen. Dabei möchte ich die NSPanel Aliase in eine höhere Ebene bringen.
                                    Da die notwenidgen Aliase selbstständig angelegt werden, habe ich einfach nur den Alias Pfad geändert.
                                    Jedoch werden nicht Aliase automatisch angelegt. Anbei zwei Bilder:
                                    Alter Pfad
                                    Neuer Pfad
                                    Als Beispiel hier der Alias Config. Es wird nur ein Bruchteil von dem angelegt was vorher da war.
                                    Woran liegt das?
                                    Skriptversion 3.9.0.2
                                    VG
                                    Nico
                                    ravenst0ne 1 Reply Last reply Reply Quote 0
                                    • ravenst0ne
                                      ravenst0ne @niiccooo1 last edited by
                                      @niiccooo1 Lösche mal die entsprechenden Datenpunkte unter 0_userdata. Im Skript wird oftmals abgefragt ob userdata existiert, falls nein wird der Datenpunkt dort erzeugt und anschließend das Alias angelegt.
                                      N 1 Reply Last reply Reply Quote 1
                                      • V
                                        Venice last edited by Venice
                                        Hallo zusammen, ich komme leider nicht weiter .
                                        Aktuell sieht mein Screensaver so aus und ich weiß leider nicht warum?
                                        • ravenst0ne
                                          ravenst0ne @Venice last edited by
                                          @venice Sieht aus, als ob die verwendete Skriptversion und TFT Firmware nicht zusammenpasst. Kannst du mal deine verwendeten Versionen posten?
                                          • V
                                            Venice @ravenst0ne last edited by
                                            @ravenst0ne Super Danke dir es hat geklappt.👍
                                            lovelace ui nspanel sonoff
                                            270
                                            7695
                                            6529282
