    4. Test Adapter mihome-cloud
      DocGame last edited by
      Hallo miteinander,
      zuerst einmal vielen Dank für den Adapter. Habe ihn seit erscheinen am laufen und er ist bisher die einzige Möglichkeit z.B. meinen Ventilator anzusprechen.
      Was mit in letzter Zeit ausfällt ist, das jede Menge Fehler gelogt werden die ich nicht zuordnen kann. Wo könnten diese herkommen und besteht eine Möglichkeit diese zu beheben?
      mihome-cloud.0
      2023-01-31 23:28:41.766	warn	Error getting for DS Hobbykeller Garagentür (lumi.158d000237b9e7) with {"type":3,"accessKey":"IOS00026747c5acafc2","params":[]}
      mihome-cloud.0
      2023-01-31 23:28:40.436	warn	{"code":-8,"message":"params is invalid","result":null}
      mihome-cloud.0
      2023-01-31 23:28:40.436	warn	Error getting for Zahnbürste Heike (blt.3.1cjtnbj3s5s00) with {"type":3,"accessKey":"IOS00026747c5acafc2","params":[]}
      mihome-cloud.0
      2023-01-31 23:28:35.402	warn	{"code":-8,"message":"params is invalid","result":null}
      mihome-cloud.0
      2023-01-31 23:28:35.402	warn	Error getting for DS Hobbykeller Tür (lumi.158d000255dca9) with {"type":3,"accessKey":"IOS00026747c5acafc2","params":[]}
      mihome-cloud.0
      2023-01-31 23:28:11.538	warn	{"code":-8,"message":"params is invalid","result":null}
      mihome-cloud.0
      2023-01-31 23:28:11.538	warn	Error getting for Zahnbürste Ralf (blt.3.1bj673n2oe000) with {"type":3,"accessKey":"IOS00026747c5acafc2","params":[]}
      mihome-cloud.0
      2023-01-31 23:27:59.829	warn	{"code":-8,"message":"params is invalid","result":null}
      mihome-cloud.0
      2023-01-31 23:27:59.829	warn	Error getting for DS Garage (lumi.158d000255dcc0) with {"type":3,"accessKey":"IOS00026747c5acafc2","params":[]}
      mihome-cloud.0
      2023-01-31 23:27:52.848	warn	{"code":-8,"message":"params is invalid","result":null}
      mihome-cloud.0
      2023-01-31 23:27:52.848	warn	Error getting for ES Hobbykeller Tür (lumi.158d00028f7b25) with {"type":3,"accessKey":"IOS00026747c5acafc2","params":[]}
      mihome-cloud.0
      2023-01-31 23:17:20.558	warn	{"code":-8,"message":"get udid error=blt.3.16lecnb8c5o00","result":null}
      mihome-cloud.0
      2023-01-31 23:17:20.558	warn	Error getting Status of the device for 小猴智能激光测距仪 (blt.3.16lecnb8c5o00) with {"accessKey":"IOS00026747c5acafc2","params":{"did":"$DID","siid":7,"in":["eyJpZCI6MCwibWV0aG9kIjoiZ2V0X3Byb3AiLCJwYXJhbXMiOlsiZ2V0X3N0YXR1cyJdfQ=="],"aiid":1}}
      mihome-cloud.0
      2023-01-31 23:15:56.071	error	Error: read ETIMEDOUT at Function.AxiosError.from (/opt/iobroker/node_modules/iobroker.mihome-cloud/node_modules/axios/lib/core/AxiosError.js:89:14) at RedirectableRequest.handleRequestError (/opt/iobroker/node_modules/iobroker.mihome-cloud/node_modules/axios/lib/adapters/http.js:533:25) at RedirectableRequest.emit (node:events:513:28) at RedirectableRequest.emit (node:domain:489:12) at ClientRequest.eventHandlers.<computed> (/opt/iobroker/node_modules/follow-redirects/index.js:14:24) at ClientRequest.emit (node:events:525:35) at ClientRequest.emit (node:domain:489:12) at ClientRequest.req.emit (/opt/iobroker/node_modules/iobroker.mihome-cloud/node_modules/http-cookie-agent/dist/http/create_cookie_agent.js:84:16) at TLSSocket.socketErrorListener (node:_http_client:494:9) at TLSSocket.emit (node:events:513:28)
      mihome-cloud.0
      2023-01-31 23:15:56.070	error	Error: read ETIMEDOUT
      mihome-cloud.0
      2023-01-31 23:15:56.070	error	/v2/device/batchgetdatas
      mihome-cloud.0
      2023-01-31 23:13:40.961	error	Error: read ETIMEDOUT at Function.AxiosError.from (/opt/iobroker/node_modules/iobroker.mihome-cloud/node_modules/axios/lib/core/AxiosError.js:89:14) at RedirectableRequest.handleRequestError (/opt/iobroker/node_modules/iobroker.mihome-cloud/node_modules/axios/lib/adapters/http.js:533:25) at RedirectableRequest.emit (node:events:513:28) at RedirectableRequest.emit (node:domain:489:12) at ClientRequest.eventHandlers.<computed> (/opt/iobroker/node_modules/follow-redirects/index.js:14:24) at ClientRequest.emit (node:events:525:35) at ClientRequest.emit (node:domain:489:12) at ClientRequest.req.emit (/opt/iobroker/node_modules/iobroker.mihome-cloud/node_modules/http-cookie-agent/dist/http/create_cookie_agent.js:84:16) at TLSSocket.socketErrorListener (node:_http_client:494:9) at TLSSocket.emit (node:events:513:28)
      mihome-cloud.0
      2023-01-31 23:13:40.907	error	Error: read ETIMEDOUT
      mihome-cloud.0
      2023-01-31 23:13:40.907	error	/v2/device/batchgetdatas
      mihome-cloud.0
      2023-01-31 23:10:26.361	warn	{"code":-8,"message":"params is invalid","result":null}
        tombox @DocGame last edited by
        @docgame klar kannst du nochmal die letzte Version von github installieren um sicher zugehen das der Fehler noch kommt
          DocGame @tombox last edited by
          @tombox Hab nochmals die letzte Github-Version installiert (war aber eh drauf). Leider das gleiche Bild. Adapter ist grün, die Werte kommen rein aber der Log läuft voll...
          mihome-cloud.0
          2023-01-31 23:58:37.710	warn	{"code":-8,"message":"params is invalid","result":null}
          mihome-cloud.0
          2023-01-31 23:58:37.710	warn	Error getting for DS Hobbykeller Garagentür (lumi.158d000237b9e7) with {"type":3,"accessKey":"IOS00026747c5acafc2","params":[]}
          mihome-cloud.0
          2023-01-31 23:58:36.759	warn	{"code":-8,"message":"params is invalid","result":null}
          mihome-cloud.0
          2023-01-31 23:58:36.759	warn	Error getting for Zahnbürste Heike (blt.3.1cjtnbj3s5s00) with {"type":3,"accessKey":"IOS00026747c5acafc2","params":[]}
          mihome-cloud.0
          2023-01-31 23:58:32.283	warn	{"code":-8,"message":"params is invalid","result":null}
          mihome-cloud.0
          2023-01-31 23:58:32.283	warn	Error getting for DS Hobbykeller Tür (lumi.158d000255dca9) with {"type":3,"accessKey":"IOS00026747c5acafc2","params":[]}
          mihome-cloud.0
          2023-01-31 23:58:09.965	warn	{"code":-8,"message":"params is invalid","result":null}
          mihome-cloud.0
          2023-01-31 23:58:09.965	warn	Error getting for Zahnbürste Ralf (blt.3.1bj673n2oe000) with {"type":3,"accessKey":"IOS00026747c5acafc2","params":[]}
          mihome-cloud.0
          2023-01-31 23:57:59.217	warn	{"code":-8,"message":"params is invalid","result":null}
          mihome-cloud.0
          2023-01-31 23:57:59.217	warn	Error getting for DS Garage (lumi.158d000255dcc0) with {"type":3,"accessKey":"IOS00026747c5acafc2","params":[]}
          mihome-cloud.0
          2023-01-31 23:57:52.582	warn	{"code":-8,"message":"params is invalid","result":null}
          mihome-cloud.0
          2023-01-31 23:57:52.582	warn	Error getting for ES Hobbykeller Tür (lumi.158d00028f7b25) with {"type":3,"accessKey":"IOS00026747c5acafc2","params":[]}
          host.iobroker
          2023-01-31 23:53:54.017	info	iobroker exit 0
          host.iobroker
          2023-01-31 23:53:52.947	info	iobroker upload [0] mihome-cloud.admin /opt/iobroker/node_modules/iobroker.mihome-cloud/admin/mihome-cloud.png mihome-cloud.png image/png
          host.iobroker
          2023-01-31 23:53:52.875	info	iobroker upload [1] mihome-cloud.admin /opt/iobroker/node_modules/iobroker.mihome-cloud/admin/jsonConfig.json jsonConfig.json application/json
          host.iobroker
          2023-01-31 23:53:52.816	info	iobroker up to date in 5s199 packages are looking for funding run `npm fund` for details
          host.iobroker
          2023-01-31 23:53:47.878	info	iobroker Installing TA2k/ioBroker.mihome-cloud#efa0d46b2b1c6e1bf061ed247cb37408d2c67ac7... (System call)
          host.iobroker
          2023-01-31 23:53:47.877	info	iobroker NPM version: 8.19.2
          host.iobroker
          2023-01-31 23:53:47.661	info	iobroker install TA2k/ioBroker.mihome-cloud#efa0d46b2b1c6e1bf061ed247cb37408d2c67ac7
          host.iobroker
          2023-01-31 23:53:45.852	info	iobroker url https://github.com/TA2k/ioBroker.mihome-cloud.git --host iobroker --debug
            DocGame @tombox last edited by DocGame
            @tombox Ich habe ja meine meisten Zigbee Geräte am Zigbeeadapter. Einige Gerätegruppen sind mir aber an meinen insgesamt 5 Mi-Hubs lieber.
            Z.B. ist die Temperaturabfrage per Alexa über Xiaomi-Skill wesentlich besser als über den iOB-Skill. Meine Rauchmelder habe ich auch drin, da ich dann über App-Routinen Alarm auf allen Hubs geben kann.
            Diese Geräte erscheinen aber auch nicht in den Logs. Es sind nur Tasten (DS = Doppelschalter, ES=Einzelschalter) und die BT-Zahnbürsten die Fehler bringen.
            Die Taster könnte ich an den Zigbee-Adapter anlernen(Was aber an der Ursache nichts ändert)....Die BT-Geräte haben vielleicht keine Verbindung mit meinem Handy und bringen dadurch Fehler?
            Eine weitere Fehlermeldung kommt zu den im letzten Post gemeldeten auch immer:
            mihome-cloud.0  2023-02-01 08:30:25.830	error	Error: read ETIMEDOUT at Function.AxiosError.from (/opt/iobroker/node_modules/iobroker.mihome-cloud/node_modules/axios/lib/core/AxiosError.js:89:14) at RedirectableRequest.handleRequestError (/opt/iobroker/node_modules/iobroker.mihome-cloud/node_modules/axios/lib/adapters/http.js:533:25) at RedirectableRequest.emit (node:events:513:28) at RedirectableRequest.emit (node:domain:489:12) at ClientRequest.eventHandlers.<computed> (/opt/iobroker/node_modules/follow-redirects/index.js:14:24) at ClientRequest.emit (node:events:525:35) at ClientRequest.emit (node:domain:489:12) at ClientRequest.req.emit (/opt/iobroker/node_modules/iobroker.mihome-cloud/node_modules/http-cookie-agent/dist/http/create_cookie_agent.js:84:16) at TLSSocket.socketErrorListener (node:_http_client:494:9) at TLSSocket.emit (node:events:513:28)
            mihome-cloud.0   2023-02-01 08:30:25.830	error	/miotspec/prop/get
              @docgame ich habe dir eine pn geschrieben
                @tombox Vielen Dank für die neue Version. Die Fehler sind deutlich weniger geworden. Jetzt sind es eigentlich nur noch 2 Arten von Fehlern
                1. (Seltener)
                mihome-cloud.0
                2023-02-03 22:44:27.559	error	TypeError: service.properties is not iterable at MihomeCloud.extractRemotesFromSpec (/opt/iobroker/node_modules/iobroker.mihome-cloud/main.js:491:40) at /opt/iobroker/node_modules/iobroker.mihome-cloud/main.js:271:15 at MihomeCloud.getDeviceList (/opt/iobroker/node_modules/iobroker.mihome-cloud/main.js:207:5) at MihomeCloud.onReady (/opt/iobroker/node_modules/iobroker.mihome-cloud/main.js:96:7)
                mihome-cloud.0
                1. alle 10 Minuten:
                mihome-cloud.0
                2023-02-04 00:22:40.287	warn	{"code":-8,"message":"get udid error=blt.3.16lecnb8c5o00","result":null}
                mihome-cloud.0
                2023-02-04 00:22:40.287	warn	Error getting Status of the device for 小猴智能激光测距仪 (blt.3.16lecnb8c5o00) with {"accessKey":"IOS00026747c5acafc2","params":{"did":"$DID","siid":7,"in":["eyJpZCI6MCwibWV0aG9kIjoiZ2V0X3Byb3AiLCJwYXJhbXMiOlsiZ2V0X3N0YXR1cyJdfQ=="],"aiid":1}}
                Das ist aber ein Laser Messgerät zur Raumvermessung und sendet die Daten nur per Blutooth wenn es eingeschaltet ist die Werte.
                Kann man das nicht ändern dait nur die Online "false" Meldung kommt aber nicht ständig die Errormeldung? Ist aber ein Luxusproblem 🙂
                  @docgame habe die Meldung angepasst. sollte nur noch eine Warnung bei Adapter start kommen
                  • Christoph1337
                    Christoph1337 last edited by
                    @tombox vielen Dank für die Entwicklung von diesem Adapter! Endlich kann ich wenigstens rudimentär meinen Dreame steuern!!
                    Seit Ewigkeiten hatte ich die Idee, dass es toll wäre meinen Robi alle X Tage zu einer bestimmten Position zu fahren und dann zu stoppen und zu warten. Hintergrund: So steht der kleine direkt in der Küche neben dem Mülleimer zum entleeren. So kann man es kaum vergessen und kann ihn danach zurückschicken. Meinst du das wird irgendwann mal möglich sein? In meinen Augen wäre das ein absolutes Killerfeature für alle ohne Absaugstation.
                      tombox @Christoph1337 last edited by
                      @christoph1337 sollte rein theoretisch gehen
                      mihome-cloud.0.10xxx.remote.start-point-clean-ii
                      damit die Koordinaten setzen
                      im format von
                      mihome-cloud.0.103xxxxx.remote.target-point
                      und dann irgendwann
                      mihome-cloud.0.103xxx.remote.pause-point-clean auf 0 oder [0] setzen
                      Christoph1337 1 Reply Last reply Reply Quote 1
                      • Christoph1337
                        Christoph1337 @tombox last edited by
                        @tombox
                        Leider liefert mir der Adapter für den Dreame noch nicht diese Daten:
                        Ich hatte dir das Gerät auch mal freigegeben um zu testen. Vielleicht kommt das ja nochmal als Feature hinzu 😃
                          @christoph1337 point cleaning wird aber in der app unterstützt? Wie sieht es aus mit dem position Endpunkt kann man da was übergeben
                          Christoph1337 1 Reply Last reply Reply Quote 0
                          • Christoph1337
                            @tombox Ja das geht in der App. Dort kann ich irgendwo ein kleines Quadrat ziehen und dieser Bereich wird gereinigt. Wo finde ich die von dir genannten DPs? Im Screenshot kannst du alle Remote DPs sehen.
                              @christoph1337 Das ist dann eher eine zone Reinigung. remote.position sehe ich da auch
                              • Christoph1337
                                @tombox
                                Position habe ich. Allerdings ist das ein boolean.
                                Wenn ich den auf true setze sagt er "der saugroboter befindet sich hier".
                                Kannst du vielleicht mal auf den dir freigegebenen Robi direkt drauf gucken?
                                • Olli_M
                                  Olli_M @tombox last edited by
                                  @tombox said in Test Adapter mihome-cloud:
                                  [1673811309]
                                  Hi Tombox,
                                  ich bekomme leider die räume nicht mehr rein 😕
                                  Map ID stimmt aber:
                                  An die erstellten Automationen in der App kommt man nicht? dass man die einfach abgreift?
                                    tombox @Olli_M last edited by
                                    @olli_m mihome-cloud.0.id.status.cur-map-id ist auch 309 am ende
                                    Olli_M 1 Reply Last reply Reply Quote 0
                                    • Olli_M
                                      @tombox
                                      ja ist sie 🙂
                                        mellus @tombox last edited by
                                        @tombox Erst einmal ein Riesendankeschön für diesen Adapter, der mir Daten aus meiner Ferienwohnung liefert.
                                        Alle Temperatur-, Druck und Feuchtigkeitsänderungen werden korrekt dargestellt.
                                        Allein der Status des Magnetsensors für Türen und Fenster zeigt kein Ergebnis bei einer Änderung. Ist Dir dieses Problem bekannt und kannst Du es eventuell noch fixen?
                                          tombox @mellus last edited by tombox
                                          @mellus Also bei BLE oder zigbee Geräten bin ich unsicher ob das funktioniert
                                          M K 2 Replies Last reply Reply Quote 1
                                            @tombox Alle Sensoren aind von Xiaomi, sowohl Temperatursensoren als auch Türkontakte. in der Xiaomi HomeApp wird alles korrekt erfasst.
                                            225
                                            37558
