    4. JavaScript
    5. Roborock Adapter tester gesucht
    • M-A Hueb
      M-A Hueb last edited by M-A Hueb
      Welche Version sollte man aktuell installieren?
      A copystring 2 Replies Last reply Reply Quote 0
        Ahnungsbefreit @M-A Hueb last edited by wendy2702
        @copystring ich habe eben die aktuelle Github Version installiert, ich habe einen Robrock S5Max. Was mich irritiert hat, sind die Meldungen (uncaught exception) im Log, bevor die Credentials eingegeben wurde. Kann man das nicht abfangen?
        roborock.0
        2023-02-06 09:22:25.743	info	MQTT initialized
        roborock.0
        2023-02-06 09:22:25.574	info	starting. Version 0.0.6-alpha.0 (non-npm: copystring/ioBroker.roborock#6c70636b1999147e5bbbd770f1c5ab9bb8a0b0c0) in /opt/iobroker/node_modules/iobroker.roborock, node: v16.19.0, js-controller: 4.0.24
        host.ioBVM-test
        2023-02-06 09:22:24.938	info	instance system.adapter.roborock.0 started with pid 30624
        host.ioBVM-test
        2023-02-06 09:21:54.900	info	Restart adapter system.adapter.roborock.0 because enabled
        host.ioBVM-test
        2023-02-06 09:21:54.900	error	instance system.adapter.roborock.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
        roborock.0
        2023-02-06 09:21:54.365	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
        roborock.0
        2023-02-06 09:21:54.365	info	terminating
        roborock.0
        2023-02-06 09:21:54.364	error	Cannot read properties of null (reading 'val')
        roborock.0
        2023-02-06 09:21:54.364	error	TypeError: Cannot read properties of null (reading 'val') at Roborock.onReady (/opt/iobroker/node_modules/iobroker.roborock/main.js:220:23)
        roborock.0
        2023-02-06 09:21:54.364	error	unhandled promise rejection: Cannot read properties of null (reading 'val')
        roborock.0
        2023-02-06 09:21:54.364	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
        roborock.0
        2023-02-06 09:21:53.829	info	MQTT initialized
        roborock.0
        2023-02-06 09:21:52.729	info	starting. Version 0.0.6-alpha.0 (non-npm: copystring/ioBroker.roborock#6c70636b1999147e5bbbd770f1c5ab9bb8a0b0c0) in /opt/iobroker/node_modules/iobroker.roborock, node: v16.19.0, js-controller: 4.0.24
        host.ioBVM-test
        2023-02-06 09:21:52.067	info	instance system.adapter.roborock.0 started with pid 30609
        host.ioBVM-test
        2023-02-06 09:21:49.538	info	instance system.adapter.roborock.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
        host.ioBVM-test
        2023-02-06 09:21:49.039	info	stopInstance system.adapter.roborock.0 send kill signal
        roborock.0
        2023-02-06 09:21:49.001	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
        roborock.0
        2023-02-06 09:21:49.000	info	terminating
        roborock.0
        2023-02-06 09:21:48.999	info	Got terminate signal TERMINATE_YOURSELF
        host.ioBVM-test
        2023-02-06 09:21:48.996	info	stopInstance system.adapter.roborock.0 (force=false, process=true)
        roborock.0
        2023-02-06 09:21:14.663	error	Username or password missing!
        roborock.0
        2023-02-06 09:21:14.650	info	starting. Version 0.0.6-alpha.0 (non-npm: copystring/ioBroker.roborock#6c70636b1999147e5bbbd770f1c5ab9bb8a0b0c0) in /opt/iobroker/node_modules/iobroker.roborock, node: v16.19.0, js-controller: 4.0.24
        Dann scheint er zu laufen, ich sehe auch jede Menge relevante Daten in den Objekten wie die Historie und die Räume. Ob man darüber auch den Robi steuern kann, wie geplant, werde ich noch ausprobieren. Brauchst Du sonst noch Infos?
        MOD EDIT: LOG IN CODE TAGS </> GESETZT
          simplyclever @M-A Hueb last edited by
          @m-a-hueb Gefällt mir! Dazu bitte die Liste der unterstützten Roboter. (z.b. S6 maxV, ...).
          The following robots are supported:
          • S5 maxV
          • S6 maxV
          • Kalle Blomquist
            Kalle Blomquist @Codierknecht last edited by Kalle Blomquist
            Hi @codierknecht , kannst du das bitte kurz erklären wie du das gemacht hast. Ich bekomme es nicht hin.
            "Ich habe die Base64-Daten des Image hier decodieren lassen und das HTML-Widget auf die passende Größe eingestellt:
            https://base64.guru/converter/decode/image "
            Gruß und Danke
            • Codierknecht
              Codierknecht Developer Most Active @Kalle Blomquist last edited by Codierknecht
              @kalle-blomquist
              Hier (im Objektbaum) kopieren:
              Und dann hier einfügen und Knöpchen drücken:
              Liefert auch die exakten Abmessungen:
                brasax last edited by brasax
                Adapter läuft auch bei mir. "Suction Power" lässt sich per Script ändern mit Zahlen, heißt 106 z.b. benutzerdefiniert oder 101 für leise - brauchts kein "send to"- command wie beim MiHome-Vacuum. Coole Sache.
                EDIT: Habe einen S6MaxV
                • copystring
                  copystring @M-A Hueb last edited by
                  @m-a-hueb said in Roborock Adapter tester gesucht:
                  Aktuell einfach die direkt aus der main branch.
                  • M-A Hueb
                    Ists angedacht die Kamera des S7 MaxV Ultra auch nutzbar zu machen?
                    Camera_Status gibts ja
                    D copystring 2 Replies Last reply Reply Quote 0
                      Dimi @M-A Hueb last edited by
                      ich habe den S6 MaxV. Habt ihr die Datenpunkte für die Wartung noch? In den ersten Versionen des Adapters hatte ich unter cleaninInfo auch die % Anzeige für den Filter die Seitenbürste und die Hauptbüste. Diese Werte sind nicht mehr da. Es gab auch einen Punkt ob der Sauger Online oder Offline ist. Dies könnte unter deviceStatus gestanden haben. Der ist jetzt auch nicht mehr da. Ich habe die aktuelle Main 0.0.7 installiert.
                      • wendy2702
                        wendy2702 @Dimi last edited by wendy2702
                        @dimi Stoppe mal Instanz, lösche alle Roborock Objekte und starte die instanz neu.
                        • copystring
                          Was macht man mit der Kamera denn? Das Bild anrufen?
                          M-A Hueb 1 Reply Last reply Reply Quote 0
                            Dimi @wendy2702 last edited by
                            @wendy2702
                            Hat nichts gebracht. Es sieht bei mir so aus. Da waren früher noch andere Werte wie 126 127 usw. Da standen die Wartungswerte drin.
                            • wendy2702
                              @dimi Wird denn dein Sauger richtig identifiziert? Sieht man im Debug log.
                              Sonst solltest du ein Issue auf Github öffnen mit Debug Logs.
                              • M-A Hueb
                                M-A Hueb @copystring last edited by M-A Hueb
                                @copystring Man kann in der App die Kamera anschalten und im Weiteren auch quasi "telefonieren"
                                Kamera aus: roborock.0.Devices.5jvoTYPcMgvzBKdzXt0fqC.deviceStatus.camera_status mit Wert 3495
                                ändert sich aber nicht wenn man die Kamera aktiviert.
                                Schau ich an der falschen Stelle?
                                copystring 1 Reply Last reply Reply Quote 0
                                • copystring
                                  An sich habe ich nichts dagegen dies zu implementieren aber ich habe keinen mit Kamera und wüsste auch gar nicht wie ich das implementieren könnte auch wenn ich einen hätte. Ich bräuchte also Hilfe von jemanden der einen passenden Roboter hat und sowas programmieren kann
                                    @wendy2702
                                    Also wenn es der Eintrag Robot key ist, sollte er richtig erkannt worden sein.
                                      Dimi last edited by
                                      @copystring
                                      Hier mal mein Debug Log. Wenn ich ein Issue auf Github eröffnen soll / muss, bitte bescheid geben. Muss mich dort erstmal registrieren.
                                      Es ging hier um fehlende Werte wie z.B. % Anzeige für den Filter die Seitenbürste und die Hauptbüste oder aber auch ob der Sauger online/offline ist. Diese Werte hat der Adapter in einer deiner ersten Versionen angezeigt. Oder wurde es jetzt genrell wieder entfernt? Sauger wird wohl richtig erkannt, in meinem Fall S6 MaxV.
                                      2023-02-07 15:50:16.731 - debug: roborock.0 (15234) Redis Objects: Use Redis connection: 127.0.0.1:9001
                                      2023-02-07 15:50:16.793 - debug: roborock.0 (15234) Objects client ready ... initialize now
                                      2023-02-07 15:50:16.796 - debug: roborock.0 (15234) Objects create System PubSub Client
                                      2023-02-07 15:50:16.797 - debug: roborock.0 (15234) Objects create User PubSub Client
                                      2023-02-07 15:50:16.857 - debug: roborock.0 (15234) Objects client initialize lua scripts
                                      2023-02-07 15:50:16.865 - debug: roborock.0 (15234) Objects connected to redis: 127.0.0.1:9001
                                      2023-02-07 15:50:16.905 - debug: roborock.0 (15234) Redis States: Use Redis connection: 127.0.0.1:9000
                                      2023-02-07 15:50:16.924 - debug: roborock.0 (15234) States create System PubSub Client
                                      2023-02-07 15:50:16.926 - debug: roborock.0 (15234) States create User PubSub Client
                                      2023-02-07 15:50:17.011 - debug: roborock.0 (15234) States connected to redis: 127.0.0.1:9000
                                      2023-02-07 15:50:17.264 - info: roborock.0 (15234) starting. Version 0.0.7-alpha.0 (non-npm: copystring/ioBroker.roborock#XXX) in /opt/iobroker/node_modules/iobroker.roborock, node: v16.19.0, js-controller: 4.0.24
                                      2023-02-07 15:50:17.522 - debug: roborock.0 (15234) RoomIDs debug: {"4517900":"Küche","4524358":"Kinderzimmer","4524368":"Schlafzimmer","4524483":"Bad","4524523":"Flur","4526290":"Gäste WC","4526403":"Wohnzimmer","4527411":"Heizraum"}
                                      2023-02-07 15:50:17.598 - info: roborock.0 (15234) MQTT initialized
                                      2023-02-07 15:50:17.634 - debug: roborock.0 (15234) Products: object
                                      2023-02-07 15:50:17.635 - debug: roborock.0 (15234) Products: object
                                      2023-02-07 15:50:17.636 - debug: roborock.0 (15234) Robot key: roborock.vacuum.a10
                                      2023-02-07 15:50:18.001 - debug: roborock.0 (15234) Latest data requested
                                      2023-02-07 15:50:18.002 - debug: roborock.0 (15234) getParameter: get_status
                                      2023-02-07 15:50:18.007 - debug: roborock.0 (15234) getParameter: get_water_box_custom_mode
                                      2023-02-07 15:50:18.008 - debug: roborock.0 (15234) getParameter: get_consumable
                                      2023-02-07 15:50:18.010 - debug: roborock.0 (15234) getParameter: get_network_info
                                      2023-02-07 15:50:18.013 - debug: roborock.0 (15234) getParameter: get_carpet_mode
                                      2023-02-07 15:50:18.014 - debug: roborock.0 (15234) getParameter: get_carpet_clean_mode
                                      2023-02-07 15:50:18.016 - debug: roborock.0 (15234) getParameter: get_fw_features
                                      2023-02-07 15:50:18.016 - debug: roborock.0 (15234) Firmware features request
                                      2023-02-07 15:50:18.017 - debug: roborock.0 (15234) getParameter: get_multi_maps_list
                                      2023-02-07 15:50:18.019 - debug: roborock.0 (15234) getParameter: get_room_mapping
                                      2023-02-07 15:50:18.019 - debug: roborock.0 (15234) get_room_mapping
                                      2023-02-07 15:50:18.136 - debug: roborock.0 (15234) dps debug: {"id":3,"result":[{"main_brush_work_time":6845,"side_brush_work_time":6845,"filter_work_time":6845,"filter_element_work_time":0,"sensor_dirty_time":6790}]}
                                      2023-02-07 15:50:18.143 - debug: roborock.0 (15234) dps debug: {"id":1,"result":[{"msg_ver":2,"msg_seq":1067,"state":2,"battery":37,"clean_time":417,"clean_area":4067500,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_status":3,"water_box_status":0,"fan_power":106,"dnd_enabled":0,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":204,"distance_off":0,"water_box_carriage_status":0,"mop_forbidden_enable":0,"camera_status":3493,"is_exploring":0,"home_sec_status":0,"home_sec_enable_password":0,"adbumper_status":[0,0,0]}]}
                                      2023-02-07 15:50:18.144 - debug: roborock.0 (15234) get_status: {"msg_ver":2,"msg_seq":1067,"state":2,"battery":37,"clean_time":417,"clean_area":4067500,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_status":3,"water_box_status":0,"fan_power":106,"dnd_enabled":0,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":204,"distance_off":0,"water_box_carriage_status":0,"mop_forbidden_enable":0,"camera_status":3493,"is_exploring":0,"home_sec_status":0,"home_sec_enable_password":0,"adbumper_status":[0,0,0]}
                                      2023-02-07 15:50:18.158 - debug: roborock.0 (15234) dps debug: {"id":2,"result":{"water_box_mode":204,"distance_off":0}}
                                      2023-02-07 15:50:18.161 - debug: roborock.0 (15234) dps debug: {"id":6,"result":[{"enable":1,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}]}
                                      2023-02-07 15:50:18.164 - debug: roborock.0 (15234) dps debug: {"id":5,"result":[6790,89875000,7,[1675435485,1675432687,1675432062,1675431695,1675428300,1674831164,1674814175]]}
                                      2023-02-07 15:50:18.173 - debug: roborock.0 (15234) dps debug: {"id":9,"result":[{"max_multi_map":4,"max_bak_map":0,"multi_map_count":2,"map_info":[{"mapFlag":0,"add_time":1675776481,"length":11,"name":"Erdgeschoss","bak_maps":[]},{"mapFlag":1,"add_time":1675432520,"length":12,"name":"Obergeschoss","bak_maps":[]}]}]}
                                      2023-02-07 15:50:18.175 - debug: roborock.0 (15234) dps debug: {"id":4,"result":{"ssid":"XXX","ip":"XXX","mac":"XXX","bssid":"XXX","rssi":-39}}
                                      2023-02-07 15:50:18.195 - debug: roborock.0 (15234) dps debug: {"id":8,"result":[111,112,113,114,115,116,117,118,119,120,121,122,123,124,125]}
                                      2023-02-07 15:50:18.197 - debug: roborock.0 (15234) dps debug: {"id":10,"result":[[16,"4526290"],[17,"4526403"],[18,"4517900"],[19,"4524523"]]}
                                      2023-02-07 15:50:18.198 - debug: roborock.0 (15234) get_room_mapping: [[16,"4526290"],[17,"4526403"],[18,"4517900"],[19,"4524523"]]
                                      2023-02-07 15:50:18.199 - debug: roborock.0 (15234) dps debug: {"id":7,"result":"unknown_method"}
                                      2023-02-07 15:50:18.230 - debug: roborock.0 (15234) dps debug: {"id":11,"result":[[1675435485,1675435902,417,4067500,0,1,2,3,56]]}
                                      2023-02-07 15:50:18.231 - debug: roborock.0 (15234) Cleaning record: [1675435485,1675435902,417,4067500,0,1,2,3,56]
                                      2023-02-07 15:50:18.234 - debug: roborock.0 (15234) dps debug: {"id":17,"result":[[1674814175,1674816263,2088,31017500,0,1,2,1,52]]}
                                      2023-02-07 15:50:18.235 - debug: roborock.0 (15234) Cleaning record: [1674814175,1674816263,2088,31017500,0,1,2,1,52]
                                      2023-02-07 15:50:18.238 - debug: roborock.0 (15234) dps debug: {"id":13,"result":[[1675432062,1675432458,349,9370000,0,0,2,3,60]]}
                                      2023-02-07 15:50:18.239 - debug: roborock.0 (15234) Cleaning record: [1675432062,1675432458,349,9370000,0,0,2,3,60]
                                      2023-02-07 15:50:18.241 - debug: roborock.0 (15234) dps debug: {"id":12,"result":[[1675432687,1675433573,886,7895000,0,1,2,3,56]]}
                                      2023-02-07 15:50:18.242 - debug: roborock.0 (15234) Cleaning record: [1675432687,1675433573,886,7895000,0,1,2,3,56]
                                      2023-02-07 15:50:18.244 - debug: roborock.0 (15234) dps debug: {"id":16,"result":[[1674831164,1674832940,1762,25457500,0,1,2,1,52]]}
                                      2023-02-07 15:50:18.244 - debug: roborock.0 (15234) Cleaning record: [1674831164,1674832940,1762,25457500,0,1,2,1,52]
                                      2023-02-07 15:50:18.272 - debug: roborock.0 (15234) dps debug: {"id":14,"result":[[1675431695,1675431752,19,227500,0,0,2,3,43]]}
                                      2023-02-07 15:50:18.273 - debug: roborock.0 (15234) Cleaning record: [1675431695,1675431752,19,227500,0,0,2,3,43]
                                      2023-02-07 15:50:18.276 - debug: roborock.0 (15234) dps debug: {"id":15,"result":[[1675428300,1675429570,1269,11840000,0,1,2,3,56]]}
                                      2023-02-07 15:50:18.277 - debug: roborock.0 (15234) Cleaning record: [1675428300,1675429570,1269,11840000,0,1,2,3,56]
                                        DonToben last edited by
                                        Wird die Mehrfachreinigung vom Adapter schon unterstützt?
                                        • copystring
                                          copystring @Dimi last edited by
                                          @dimi danke für das Log. Ich bitte dich ein issue zu öffnen.
                                          • copystring
                                            copystring @DonToben last edited by
                                            @dontoben said in Roborock Adapter tester gesucht:
                                            Aktuell nicht. Magst du auf GitHub ein Feature request erstellen?
                                            1.0k
                                            766
                                            242724
