    3. Off Topic
    4. Proxmox
    5. Proxmox / Influxdb V1 zu V2... wie?
    • MassiveAttack
      MassiveAttack @Boronsbruder last edited by
      @boronsbruder
      root@QNAP:/# influx_inspect export -database iobroker -out /tmp/test.lp -lponly
      flag provided but not defined: -lponly
      Exports TSM files into InfluxDB line protocol format.
      Boronsbruder 1 Reply Last reply Reply Quote 0
      • Boronsbruder
        Boronsbruder @MassiveAttack last edited by
        @massiveattack
        poste doch mal bitte
        influx -v
        MassiveAttack 1 Reply Last reply Reply Quote 0
        • MassiveAttack
          @boronsbruder
          root@QNAP:/# influx -v
          flag provided but not defined: -v
          Usage of influx:
            -version
                                  Display the version and exit.
            -path-prefix 'url path'
                                  Path that follows the host and port
            -host 'host name'
                                  Host to connect to.
            -port 'port #'
                                  Port to connect to.
            -socket 'unix domain socket'
                                  Unix socket to connect to.
            -database 'database name'
                                  Database to connect to the server.
            -password 'password'
                                  Password to connect to the server.  Leaving blank will prompt for password (--password '').
            -username 'username'
                                  Username to connect to the server.
            -ssl
                                  Use https for requests.
            -unsafeSsl
                                  Set this when connecting to the cluster using https and not use SSL verification.
            -execute 'command'
                                  Execute command and quit.
            -type 'influxql|flux'
                                  Type specifies the query language for executing commands or when invoking the REPL.
            -format 'json|csv|column'
                                  Format specifies the format of the server responses:  json, csv, or column.
            -precision 'rfc3339|h|m|s|ms|u|ns'
                                  Precision specifies the format of the timestamp:  rfc3339, h, m, s, ms, u or ns.
            -consistency 'any|one|quorum|all'
                                  Set write consistency level: any, one, quorum, or all
            -pretty
                                  Turns on pretty print for the json format.
            -import
                                  Import a previous database export from file
            -pps
                                  How many points per second the import will allow.  By default it is zero and will not throttle importing.
            -path
                                  Path to file to import
            -compressed
                                  Set to true if the import file is compressed
          Examples:
              # Use influx in a non-interactive mode to query the database "metrics" and pretty print json:
              $ influx -database 'metrics' -execute 'select * from cpu' -format 'json' -pretty
              # Connect to a specific database on startup and set database context:
              $ influx -database 'metrics' -host 'localhost' -port '8086'
          • Boronsbruder
            @massiveattack
            influx -version
            • MassiveAttack
              @boronsbruder
              root@QNAP:/# influx -version
              InfluxDB shell version: 1.8.0
              • Boronsbruder
                @massiveattack
                okay ist nicht zu alt...
                was sagt influx_inspect export --help
                MassiveAttack Marc Berg 2 Replies Last reply Reply Quote 0
                • MassiveAttack
                  @boronsbruder sagte in Proxmox / Influxdb V1 zu V2... wie?:
                  root@QNAP:/# influx_inspect export --help
                  Usage: influx_inspect export [flags]
                    -compress
                          Compress the output
                    -database string
                          Optional: the database to export
                    -datadir string
                          Data storage path (default "/root/.influxdb/data")
                    -end string
                          Optional: the end time to export (RFC3339 format)
                    -out string
                          Destination file to export to (default "/root/.influxdb/export")
                    -retention string
                          Optional: the retention policy to export (requires -database)
                    -start string
                          Optional: the start time to export (RFC3339 format)
                    -waldir string
                          WAL storage path (default "/root/.influxdb/wal")
                  • Marc Berg
                    Marc Berg Most Active @Boronsbruder last edited by
                    @massiveattack
                    Doch, ist zu alt
                    MassiveAttack 1 Reply Last reply Reply Quote 1
                    • MassiveAttack
                      MassiveAttack @Marc Berg last edited by
                      @marc-berg
                      d.h. ich bekomme die Daten nicht aus der v1 in die v2?
                      • Marc Berg
                        Marc Berg Most Active @MassiveAttack last edited by
                        @massiveattack sagte in Proxmox / Influxdb V1 zu V2... wie?:
                        @marc-berg
                        So, wie ich das sehe, mit dieser Methode erst nach einem Update auf mindestens 1.8.3
                        • MassiveAttack
                          @marc-berg
                          wie ich diese useability liebe 😥 😢
                          • Boronsbruder
                            Boronsbruder @MassiveAttack last edited by Boronsbruder
                            @massiveattack
                            ja, da fehlt -lponly
                            Jetzt hast du 2 Möglichkeiten...
                            1. Eine für dein Betriebsystem passende influx_inspect finden
                            oder
                            Einen Texteditor benutzen um den Header (die ersten paar Zeile mit #)
                            # INFLUXDB EXPORT: 2023-01-01T01:59:59+01:00 - 2262-04-12T00:47:16+01:00
                            # DDL
                            CREATE DATABASE iobroker WITH NAME autogen
                            # DML
                            # CONTEXT-DATABASE:iobroker
                            # CONTEXT-RETENTION-POLICY:autogen
                            # writing tsm data
                            0_userdata.0.Wetter.Mittel.1 ack=false 1672617060016000000
                            entfernen und dann importieren. Vorher natürlich entpacken.
                            Der Editor muss aber die riesige Datei verkraften und linux-kompatibles Format benutzen. Nicht dass Windows-Sonderzeichen für Zeilenumbrüche usw. Probleme machen.
                            Boronsbruder Marc Berg 2 Replies Last reply Reply Quote 1
                            • Boronsbruder
                              Boronsbruder @Boronsbruder last edited by
                              ich benutze hier auf Windows Notepad++
                              • Marc Berg
                                Marc Berg Most Active @Boronsbruder last edited by Marc Berg
                                Hier https://dl.influxdata.com/influxdb/releases/influxdb-1.8.10_linux_amd64.tar.gz
                                wäre eine aktuellere influx_inspect enthalten. Aber ob die mit der 1.8.0 DB läuft?
                                • Boronsbruder
                                  Boronsbruder @Marc Berg last edited by Boronsbruder
                                  @marc-berg
                                  ich würde erst die variante mit Zeilen entfernen versuchen 😉
                                  z.B. entpacken und
                                  sed '/^[#]/d' DATEINAME > NEUER_DATEINAME
                                  (entfernt alle Zeilen beginnend mit # und schreibt das Resultat in eine neue Datei)
                                  danach mit
                                  gzip NEUER_DATEINAME
                                  wieder packen
                                  • Marc Berg
                                    Was ich nicht verstehe ist: Wenn diese Zeile hier angemeckert wird
                                    Error: failed to write data: 400 Bad Request: unable to parse 'CREATE DATABASE iobroker WITH NAME autogen': invalid field format
                                    und vor dieser Zeile kein "#" steht, was bringt das denn?
                                    • Boronsbruder
                                      @marc-berg
                                      Hast natürlich recht...
                                      Copy und paste...
                                      EDIT
                                      besser noch
                                      sed -e '/^[#]/d' -e '/^CREATE/d' DATEINAME > NEUER_DATEINAME
                                      Sonst kann es passieren, dass er Zeilen mit löscht, die CREATE irgendwo im TEXT haben.
                                      Hier wird nur gelöscht nur wenn die Zeichen am Anfang sind...
                                      • MassiveAttack
                                        MassiveAttack @Boronsbruder last edited by MassiveAttack
                                        @boronsbruder
                                        ich bekomme jetzt ein permission denied, ich hab keine lust mehr
                                        unexpected error writing points to database: mkdir /var: permission denied / "unexpected error writing points to database: mkdir /var: permission denied""
                                        im Verzeichnis /var habe ich schon chmod 777 gesetzt, bringt nix
                                        Boronsbruder Marc Berg 2 Replies Last reply Reply Quote 0
                                        • Boronsbruder
                                          @massiveattack
                                          langsam...
                                          nicht unbedacht irgenwelche Berechtigungen verbiegen...
                                          Was löst den Fehler aus....
                                          Mit welchem Benutzer?
                                          Ist influxv2 sauber installiert?
                                          • MassiveAttack
                                            @boronsbruder
                                            influx write -b iobroker -o universe -t KUArezBLNDbZWty0PcwTbD0rme4qIR2JZ0sffRAU8mcT2eXMB12jp6-aTRiH0Gtw0UsY4aEr1U3JXMiYWFTlWg== -f export
                                            root
                                            ja
                                            Diese v2 DB dient mir grad mal als Testobjekt, da verbiege ich alles wenn notwendig 😉
                                            221
                                            32828
