    3. Off Topic
    4. Proxmox
    5. Proxmox / Influxdb V1 zu V2... wie?
    • MassiveAttack
      MassiveAttack @Boronsbruder last edited by
      @boronsbruder
      root@QNAP:/# influx -v
      flag provided but not defined: -v
      Usage of influx:
        -version
                              Display the version and exit.
        -path-prefix 'url path'
                              Path that follows the host and port
        -host 'host name'
                              Host to connect to.
        -port 'port #'
                              Port to connect to.
        -socket 'unix domain socket'
                              Unix socket to connect to.
        -database 'database name'
                              Database to connect to the server.
        -password 'password'
                              Password to connect to the server.  Leaving blank will prompt for password (--password '').
        -username 'username'
                              Username to connect to the server.
        -ssl
                              Use https for requests.
        -unsafeSsl
                              Set this when connecting to the cluster using https and not use SSL verification.
        -execute 'command'
                              Execute command and quit.
        -type 'influxql|flux'
                              Type specifies the query language for executing commands or when invoking the REPL.
        -format 'json|csv|column'
                              Format specifies the format of the server responses:  json, csv, or column.
        -precision 'rfc3339|h|m|s|ms|u|ns'
                              Precision specifies the format of the timestamp:  rfc3339, h, m, s, ms, u or ns.
        -consistency 'any|one|quorum|all'
                              Set write consistency level: any, one, quorum, or all
        -pretty
                              Turns on pretty print for the json format.
        -import
                              Import a previous database export from file
        -pps
                              How many points per second the import will allow.  By default it is zero and will not throttle importing.
        -path
                              Path to file to import
        -compressed
                              Set to true if the import file is compressed
      Examples:
          # Use influx in a non-interactive mode to query the database "metrics" and pretty print json:
          $ influx -database 'metrics' -execute 'select * from cpu' -format 'json' -pretty
          # Connect to a specific database on startup and set database context:
          $ influx -database 'metrics' -host 'localhost' -port '8086'
      Boronsbruder 1 Reply Last reply Reply Quote 0
      • Boronsbruder
        Boronsbruder @MassiveAttack last edited by
        @massiveattack
        influx -version
        MassiveAttack 1 Reply Last reply Reply Quote 0
        • MassiveAttack
          @boronsbruder
          root@QNAP:/# influx -version
          InfluxDB shell version: 1.8.0
          • Boronsbruder
            @massiveattack
            okay ist nicht zu alt...
            was sagt influx_inspect export --help
            MassiveAttack Marc Berg 2 Replies Last reply Reply Quote 0
            • MassiveAttack
              @boronsbruder sagte in Proxmox / Influxdb V1 zu V2... wie?:
              root@QNAP:/# influx_inspect export --help
              Exports TSM files into InfluxDB line protocol format.
              Usage: influx_inspect export [flags]
                -compress
                      Compress the output
                -database string
                      Optional: the database to export
                -datadir string
                      Data storage path (default "/root/.influxdb/data")
                -end string
                      Optional: the end time to export (RFC3339 format)
                -out string
                      Destination file to export to (default "/root/.influxdb/export")
                -retention string
                      Optional: the retention policy to export (requires -database)
                -start string
                      Optional: the start time to export (RFC3339 format)
                -waldir string
                      WAL storage path (default "/root/.influxdb/wal")
              • Marc Berg
                Marc Berg Most Active @Boronsbruder last edited by
                @massiveattack
                Doch, ist zu alt
                MassiveAttack 1 Reply Last reply Reply Quote 1
                • MassiveAttack
                  MassiveAttack @Marc Berg last edited by
                  @marc-berg
                  d.h. ich bekomme die Daten nicht aus der v1 in die v2?
                  • Marc Berg
                    Marc Berg Most Active @MassiveAttack last edited by
                    @massiveattack sagte in Proxmox / Influxdb V1 zu V2... wie?:
                    @marc-berg
                    So, wie ich das sehe, mit dieser Methode erst nach einem Update auf mindestens 1.8.3
                    • MassiveAttack
                      @marc-berg
                      wie ich diese useability liebe 😥 😢
                      • Boronsbruder
                        Boronsbruder @MassiveAttack last edited by Boronsbruder
                        @massiveattack
                        ja, da fehlt -lponly
                        Jetzt hast du 2 Möglichkeiten...
                        1. Eine für dein Betriebsystem passende influx_inspect finden
                        oder
                        Einen Texteditor benutzen um den Header (die ersten paar Zeile mit #)
                        # INFLUXDB EXPORT: 2023-01-01T01:59:59+01:00 - 2262-04-12T00:47:16+01:00
                        # DDL
                        CREATE DATABASE iobroker WITH NAME autogen
                        # DML
                        # CONTEXT-DATABASE:iobroker
                        # CONTEXT-RETENTION-POLICY:autogen
                        # writing tsm data
                        0_userdata.0.Wetter.Mittel.1 ack=false 1672617060016000000
                        entfernen und dann importieren. Vorher natürlich entpacken.
                        Der Editor muss aber die riesige Datei verkraften und linux-kompatibles Format benutzen. Nicht dass Windows-Sonderzeichen für Zeilenumbrüche usw. Probleme machen.
                        Boronsbruder Marc Berg 2 Replies Last reply Reply Quote 1
                        • Boronsbruder
                          Boronsbruder @Boronsbruder last edited by
                          ich benutze hier auf Windows Notepad++
                          • Marc Berg
                            Marc Berg Most Active @Boronsbruder last edited by Marc Berg
                            Hier https://dl.influxdata.com/influxdb/releases/influxdb-1.8.10_linux_amd64.tar.gz
                            wäre eine aktuellere influx_inspect enthalten. Aber ob die mit der 1.8.0 DB läuft?
                            • Boronsbruder
                              Boronsbruder @Marc Berg last edited by Boronsbruder
                              @marc-berg
                              ich würde erst die variante mit Zeilen entfernen versuchen 😉
                              z.B. entpacken und
                              sed '/^[#]/d' DATEINAME > NEUER_DATEINAME
                              (entfernt alle Zeilen beginnend mit # und schreibt das Resultat in eine neue Datei)
                              danach mit
                              gzip NEUER_DATEINAME
                              wieder packen
                              • Marc Berg
                                Was ich nicht verstehe ist: Wenn diese Zeile hier angemeckert wird
                                Error: failed to write data: 400 Bad Request: unable to parse 'CREATE DATABASE iobroker WITH NAME autogen': invalid field format
                                und vor dieser Zeile kein "#" steht, was bringt das denn?
                                • Boronsbruder
                                  @marc-berg
                                  Hast natürlich recht...
                                  Copy und paste...
                                  EDIT
                                  besser noch
                                  sed -e '/^[#]/d' -e '/^CREATE/d' DATEINAME > NEUER_DATEINAME
                                  Sonst kann es passieren, dass er Zeilen mit löscht, die CREATE irgendwo im TEXT haben.
                                  Hier wird nur gelöscht nur wenn die Zeichen am Anfang sind...
                                  • MassiveAttack
                                    MassiveAttack @Boronsbruder last edited by MassiveAttack
                                    @boronsbruder
                                    ich bekomme jetzt ein permission denied, ich hab keine lust mehr
                                    unexpected error writing points to database: mkdir /var: permission denied / "unexpected error writing points to database: mkdir /var: permission denied""
                                    im Verzeichnis /var habe ich schon chmod 777 gesetzt, bringt nix
                                    Boronsbruder Marc Berg 2 Replies Last reply Reply Quote 0
                                    • Boronsbruder
                                      @massiveattack
                                      langsam...
                                      nicht unbedacht irgenwelche Berechtigungen verbiegen...
                                      Was löst den Fehler aus....
                                      Mit welchem Benutzer?
                                      Ist influxv2 sauber installiert?
                                      • MassiveAttack
                                        @boronsbruder
                                        influx write -b iobroker -o universe -t KUArezBLNDbZWty0PcwTbD0rme4qIR2JZ0sffRAU8mcT2eXMB12jp6-aTRiH0Gtw0UsY4aEr1U3JXMiYWFTlWg== -f export
                                        root
                                        ja
                                        Diese v2 DB dient mir grad mal als Testobjekt, da verbiege ich alles wenn notwendig 😉
                                        • Marc Berg
                                          @boronsbruder
                                          Ich denke mal, die V2 Installation ist völlig schief. Das kam mir mit den fehlenden Configs/Profilen schon seltsam vor. Auch wenn's nervt, fang nochmal neu an.
                                          • MassiveAttack
                                            @marc-berg
                                            vermutlich hast du recht, vielleicht habe ich morgen wieder muse 😉
                                            ginge eine datenmigration via csv auch? zumindest könnte man den import mit dem webui machen
                                            221
                                            33658
