    4. Test Adapter Device-Watcher v2.x.x GitHub/Latest
    • da_Woody
      da_Woody @Guest last edited by
      @ciddi89 nix da. ich bin mit iQontrol unterwegs.
      aber egal, in den objekten passts ja nicht.
      ich schau mir das morgen an, wo das prob ist.
      hunger und müde... 😉
        A Former User @da_Woody last edited by
        @da_woody ach mist stimmt 😄 ich vergass sorry. Kenne so gut wie keine Adapter die andere Datentypen nutzen daher muss ich mal schauen
        • da_Woody
          da_Woody @Rushmed last edited by
          @rushmed was hat das mit dem adapter zu tun?
          da gehts um divices, nicht um fehler.
            Rookie50 @Guest last edited by
            @ciddi89 hier ist der komplette DP der HM-CC-RT-DN Thermostate:
            Wie schon auf Github erwähnt, LOWBAT und LOWBAT_ALARM funktionieren nicht bei diesem Gerät. Das bekommt man aus dem DP .4.FAULT_REPORTING.
              "hm-rpc.0.XXXXXXXXXX": {
                "_id": "hm-rpc.0.XXXXXXXXXX",
                "type": "device",
                "common": {
                  "name": "Heizung Kueche",
                  "icon": "/icons/83_hm-cc-rt-dn_thumb.png"
                "native": {
                  "ADDRESS": "XXXXXXXXXX",
                  "AVAILABLE_FIRMWARE": "1.5",
                  "CHILDREN": [
                    "XXXXXXXXXX:0",
                    "XXXXXXXXXX:1",
                    "XXXXXXXXXX:2",
                    "XXXXXXXXXX:3",
                    "XXXXXXXXXX:4",
                    "XXXXXXXXXX:5",
                    "XXXXXXXXXX:6"
                  "FIRMWARE": "1.5",
                  "FLAGS": 1,
                  "INTERFACE": "CCU2GW0001",
                  "PARAMSETS": [
                    "MASTER"
                  "PARENT": "",
                  "RF_ADDRESS": 3947875,
                  "ROAMING": 0,
                  "RX_MODE": 14,
                  "TYPE": "HM-CC-RT-DN",
                  "UPDATABLE": 1,
                  "VERSION": 29
                "from": "system.adapter.hm-rega.0",
                "user": "system.user.admin",
                "ts": 1674480663048,
                "acl": {
                  "object": 1636,
                  "owner": "system.user.admin",
              "hm-rpc.0.XXXXXXXXXX.0": {
                "_id": "hm-rpc.0.XXXXXXXXXX.0",
                "type": "channel",
                "common": {
                  "name": "Heizung Kueche:0"
                "native": {
                  "ADDRESS": "XXXXXXXXXX:0",
                  "AES_ACTIVE": 0,
                  "DIRECTION": 0,
                  "FLAGS": 3,
                  "INDEX": 0,
                  "LINK_SOURCE_ROLES": "",
                  "LINK_TARGET_ROLES": "",
                  "PARAMSETS": [
                    "MASTER",
                    "VALUES"
                  "PARENT": "XXXXXXXXXX",
                  "PARENT_TYPE": "HM-CC-RT-DN",
                  "TYPE": "MAINTENANCE",
                  "VERSION": 29
                "ts": 1674480663066,
                "acl": {
                  "object": 1636,
              "hm-rpc.0.XXXXXXXXXX.0.AES_KEY": {
                "type": "state",
                "common": {
                  "name": "Heizung Kueche:0.AES_KEY",
                  "def": 0,
                  "type": "number",
                  "read": true,
                  "write": false,
                  "min": 0,
                  "max": 127,
                  "role": "value"
                "native": {
                  "DEFAULT": 0,
                  "FLAGS": 0,
                  "ID": "AES_KEY",
                  "MAX": 127,
                  "MIN": 0,
                  "OPERATIONS": 1,
                  "TAB_ORDER": 9,
                  "TYPE": "INTEGER",
                  "UNIT": ""
                "ts": 1674480663261,
                "_id": "hm-rpc.0.XXXXXXXXXX.0.AES_KEY",
                "acl": {
                  "object": 1636,
                  "state": 1636,
              "hm-rpc.0.XXXXXXXXXX.0.CONFIG_PENDING": {
                "type": "state",
                "common": {
                  "name": "Heizung Kueche:0.CONFIG_PENDING",
                  "def": false,
                  "type": "boolean",
                  "read": true,
                  "write": false,
                  "role": "indicator"
                "native": {
                  "DEFAULT": false,
                  "FLAGS": 9,
                  "ID": "CONFIG_PENDING",
                  "MAX": true,
                  "MIN": false,
                  "OPERATIONS": 5,
                  "TAB_ORDER": 2,
                  "TYPE": "BOOL",
                  "UNIT": ""
                "ts": 1674480663216,
                "_id": "hm-rpc.0.XXXXXXXXXX.0.CONFIG_PENDING",
                "acl": {
                  "object": 1636,
                  "state": 1636,
              "hm-rpc.0.XXXXXXXXXX.0.CONFIG_PENDING_ALARM": {
                "type": "state",
                "common": {
                  "name": "Heizung Kueche:0.CONFIG_PENDING_ALARM",
                  "type": "number",
                  "role": "indicator.alarm",
                  "read": true,
                  "write": true,
                  "def": 0,
                  "states": {
                    "0": "NO ALARM",
                    "1": "ALARM",
                    "2": "ACKNOWLEDGED"
                "native": {
                  "Name": "Heizung Kueche:0.CONFIG_PENDING_ALARM",
                  "TypeName": "ALARM",
                  "DP": "6279"
                "ts": 1620829176611,
                "_id": "hm-rpc.0.XXXXXXXXXX.0.CONFIG_PENDING_ALARM",
                "acl": {
                  "object": 1636,
                  "state": 1636,
              "hm-rpc.0.XXXXXXXXXX.0.DEVICE_IN_BOOTLOADER": {
                "type": "state",
                "common": {
                  "name": "Heizung Kueche:0.DEVICE_IN_BOOTLOADER",
                  "def": false,
                  "type": "boolean",
                  "read": true,
                  "write": false,
                  "role": ""
                "native": {
                  "DEFAULT": false,
                  "FLAGS": 9,
                  "ID": "DEVICE_IN_BOOTLOADER",
                  "MAX": true,
                  "MIN": false,
                  "OPERATIONS": 5,
                  "TAB_ORDER": 7,
                  "TYPE": "BOOL",
                  "UNIT": ""
                "ts": 1674480663164,
                "_id": "hm-rpc.0.XXXXXXXXXX.0.DEVICE_IN_BOOTLOADER",
                "acl": {
                  "object": 1636,
                  "state": 1636,
              "hm-rpc.0.XXXXXXXXXX.0.DEVICE_IN_BOOTLOADER_ALARM": {
                "type": "state",
                "common": {
                  "name": "Heizung Kueche:0.DEVICE_IN_BOOTLOADER_ALARM",
                  "type": "number",
                  "read": true,
                  "write": true,
                  "def": 0,
                  "states": {
                    "0": "NO ALARM",
                    "1": "ALARM",
                    "2": "ACKNOWLEDGED"
                "native": {
                  "Name": "Heizung Kueche:0.DEVICE_IN_BOOTLOADER_ALARM",
                  "DP": "6283"
                "ts": 1620829176631,
                "_id": "hm-rpc.0.XXXXXXXXXX.0.DEVICE_IN_BOOTLOADER_ALARM",
                "acl": {
                  "object": 1636,
                  "state": 1636,
              "hm-rpc.0.XXXXXXXXXX.0.INHIBIT": {
                "type": "state",
                "common": {
                  "name": "Heizung Kueche:0.INHIBIT",
                  "def": false,
                  "type": "boolean",
                  "read": true,
                  "write": true,
                  "role": "state.inhibit"
                "native": {
                  "CONTROL": "NONE",
                  "DEFAULT": false,
                  "FLAGS": 1,
                  "ID": "INHIBIT",
                  "MAX": true,
                  "MIN": false,
                  "OPERATIONS": 7,
                  "TAB_ORDER": 6,
                  "TYPE": "BOOL",
                  "UNIT": ""
                "ts": 1674480663107,
                "_id": "hm-rpc.0.XXXXXXXXXX.0.INHIBIT",
                "acl": {
                  "object": 1636,
                  "state": 1636,
              "hm-rpc.0.XXXXXXXXXX.0.LOWBAT": {
                "type": "state",
                "common": {
                  "name": "Heizung Kueche:0.LOWBAT",
                  "def": false,
                  "type": "boolean",
                  "read": true,
                  "write": false,
                  "role": "indicator.lowbat"
                "native": {
                  "DEFAULT": false,
                  "FLAGS": 9,
                  "ID": "LOWBAT",
                  "MAX": true,
                  "MIN": false,
                  "OPERATIONS": 5,
                  "TAB_ORDER": 3,
                  "TYPE": "BOOL",
                  "UNIT": ""
                "ts": 1674480663146,
                "_id": "hm-rpc.0.XXXXXXXXXX.0.LOWBAT",
                "acl": {
                  "object": 1636,
                  "state": 1636,
              "hm-rpc.0.XXXXXXXXXX.0.LOWBAT_ALARM": {
                "type": "state",
                "common": {
                  "name": "Heizung Kueche:0.LOWBAT_ALARM",
                  "type": "number",
                  "read": true,
                  "write": true,
                  "def": 0,
                  "states": {
                    "0": "NO ALARM",
                    "1": "ALARM",
                    "2": "ACKNOWLEDGED"
                "native": {
                  "Name": "Heizung Kueche:0.LOWBAT_ALARM",
                  "DP": "6288"
                "ts": 1620829176652,
                "_id": "hm-rpc.0.XXXXXXXXXX.0.LOWBAT_ALARM",
                "acl": {
                  "object": 1636,
                  "state": 1636,
              "hm-rpc.0.XXXXXXXXXX.0.RSSI_DEVICE": {
                "type": "state",
                "common": {
                  "name": "Heizung Kueche:0.RSSI_DEVICE",
                  "def": 0,
                  "type": "number",
                  "read": true,
                  "write": false,
                  "min": -2147483648,
                  "max": 128,
                  "role": "value.rssi",
                  "unit": "dBm"
                "native": {
                  "DEFAULT": 0,
                  "FLAGS": 1,
                  "ID": "RSSI_DEVICE",
                  "MAX": 2147483647,
                  "MIN": -2147483648,
                  "OPERATIONS": 5,
                  "TAB_ORDER": 4,
                  "TYPE": "INTEGER",
                  "UNIT": ""
                "ts": 1674480663271,
                "_id": "hm-rpc.0.XXXXXXXXXX.0.RSSI_DEVICE",
                "acl": {
                  "object": 1636,
                  "state": 1636,
              "hm-rpc.0.XXXXXXXXXX.0.RSSI_PEER": {
                "type": "state",
                "common": {
                  "name": "Heizung Kueche:0.RSSI_PEER",
                  "def": 0,
                  "type": "number",
                  "read": true,
                  "write": false,
                  "min": -2147483648,
                  "max": 2147483647,
                  "unit": "dBm"
                "native": {
                  "DEFAULT": 0,
                  "FLAGS": 1,
                  "ID": "RSSI_PEER",
                  "MAX": 2147483647,
                  "MIN": -2147483648,
                  "OPERATIONS": 5,
                  "TAB_ORDER": 5,
                  "TYPE": "INTEGER",
                  "UNIT": ""
                "ts": 1674480663095,
                "_id": "hm-rpc.0.XXXXXXXXXX.0.RSSI_PEER",
                "acl": {
                  "object": 1636,
                  "state": 1636,
              "hm-rpc.0.XXXXXXXXXX.0.STICKY_UNREACH": {
                "type": "state",
                "common": {
                  "name": "Heizung Kueche:0.STICKY_UNREACH",
                  "def": false,
                  "type": "boolean",
                  "read": true,
                  "write": true,
                  "role": "indicator.unreach"
                "native": {
                  "DEFAULT": false,
                  "FLAGS": 25,
                  "ID": "STICKY_UNREACH",
                  "MAX": true,
                  "MIN": false,
                  "OPERATIONS": 7,
                  "TAB_ORDER": 1,
                  "TYPE": "BOOL",
                  "UNIT": ""
                "ts": 1674480663187,
                "_id": "hm-rpc.0.XXXXXXXXXX.0.STICKY_UNREACH",
                "acl": {
                  "object": 1636,
                  "state": 1636,
              "hm-rpc.0.XXXXXXXXXX.0.STICKY_UNREACH_ALARM": {
                "type": "state",
                "common": {
                  "name": "Heizung Kueche:0.STICKY_UNREACH_ALARM",
                  "type": "number",
                  "read": true,
                  "write": true,
                  "def": 0,
                  "states": {
                    "0": "NO ALARM",
                    "1": "ALARM",
                    "2": "ACKNOWLEDGED"
                "native": {
                  "Name": "Heizung Kueche:0.STICKY_UNREACH_ALARM",
                  "DP": "6294"
                "ts": 1620829176673,
                "_id": "hm-rpc.0.XXXXXXXXXX.0.STICKY_UNREACH_ALARM",
                "acl": {
                  "object": 1636,
                  "state": 1636,
              "hm-rpc.0.XXXXXXXXXX.0.UNREACH": {
                "type": "state",
                "common": {
                  "name": "Heizung Kueche:0.UNREACH",
                  "def": false,
                  "type": "boolean",
                  "read": true,
                  "write": false,
                "native": {
                  "DEFAULT": false,
                  "FLAGS": 9,
                  "ID": "UNREACH",
                  "MAX": true,
                  "MIN": false,
                  "OPERATIONS": 5,
                  "TAB_ORDER": 0,
                  "TYPE": "BOOL",
                  "UNIT": ""
                "ts": 1674480663234,
                "_id": "hm-rpc.0.XXXXXXXXXX.0.UNREACH",
                "acl": {
                  "object": 1636,
                  "state": 1636,
              "hm-rpc.0.XXXXXXXXXX.0.UNREACH_ALARM": {
                "type": "state",
                "common": {
                  "name": "Heizung Kueche:0.UNREACH_ALARM",
                  "type": "number",
                  "read": true,
                  "write": true,
                  "def": 0,
                  "states": {
                    "0": "NO ALARM",
                    "1": "ALARM",
                    "2": "ACKNOWLEDGED"
                "native": {
                  "Name": "Heizung Kueche:0.UNREACH_ALARM",
                  "DP": "6298"
                "ts": 1620829176692,
                "_id": "hm-rpc.0.XXXXXXXXXX.0.UNREACH_ALARM",
                "acl": {
                  "object": 1636,
                  "state": 1636,
              "hm-rpc.0.XXXXXXXXXX.0.UPDATE_PENDING": {
                "type": "state",
                "common": {
                  "name": "Heizung Kueche:0.UPDATE_PENDING",
                  "def": false,
                  "type": "boolean",
                  "read": true,
                  "write": false,
                  "role": "indicator"
                "native": {
                  "DEFAULT": false,
                  "FLAGS": 9,
                  "ID": "UPDATE_PENDING",
                  "MAX": true,
                  "MIN": false,
                  "OPERATIONS": 5,
                  "TAB_ORDER": 8,
                  "TYPE": "BOOL",
                  "UNIT": ""
                "ts": 1674480663123,
                "_id": "hm-rpc.0.XXXXXXXXXX.0.UPDATE_PENDING",
                "acl": {
                  "object": 1636,
                  "state": 1636,
              "hm-rpc.0.XXXXXXXXXX.0.UPDATE_PENDING_ALARM": {
                "type": "state",
                "common": {
                  "name": "Heizung Kueche:0.UPDATE_PENDING_ALARM",
                  "type": "number",
                  "read": true,
                  "write": true,
                  "def": 0,
                  "states": {
                    "0": "NO ALARM",
                    "1": "ALARM",
                    "2": "ACKNOWLEDGED"
                "native": {
                  "Name": "Heizung Kueche:0.UPDATE_PENDING_ALARM",
                  "DP": "6302"
                "ts": 1620829176714,
                "_id": "hm-rpc.0.XXXXXXXXXX.0.UPDATE_PENDING_ALARM",
                "acl": {
                  "object": 1636,
                  "state": 1636,
              "hm-rpc.0.XXXXXXXXXX.1": {
                "_id": "hm-rpc.0.XXXXXXXXXX.1",
                "type": "channel",
                "common": {
                  "name": "Heizung Kueche: Temperatursensor"
                "native": {
                  "ADDRESS": "XXXXXXXXXX:1",
                  "AES_ACTIVE": 0,
                  "DIRECTION": 2,
                  "FLAGS": 1,
                  "INDEX": 1,
                  "LINK_TARGET_ROLES": "WEATHER_T WEATHER_TH",
                  "PARAMSETS": [
                    "LINK",
                    "VALUES"
                  "TYPE": "WEATHER_RECEIVER",
                  "VERSION": 29
                "ts": 1674480663287,
                "acl": {
                  "object": 1636,
              "hm-rpc.0.XXXXXXXXXX.2": {
                "_id": "hm-rpc.0.XXXXXXXXXX.2",
                "type": "channel",
                "common": {
                  "name": "Heizung Kueche: Wandthermostat"
                "native": {
                  "ADDRESS": "XXXXXXXXXX:2",
                  "AES_ACTIVE": 0,
                  "DIRECTION": 2,
                  "FLAGS": 1,
                  "INDEX": 2,
                  "LINK_TARGET_ROLES": "THERMALCONTROL_TC",
                  "PARAMSETS": [
                    "LINK",
                    "VALUES"
                  "TYPE": "CLIMATECONTROL_RECEIVER",
                  "VERSION": 29
                "ts": 1674480663298,
                "acl": {
                  "object": 1636,
              "hm-rpc.0.XXXXXXXXXX.3": {
                "_id": "hm-rpc.0.XXXXXXXXXX.3",
                "type": "channel",
                "common": {
                  "name": "Heizung Kueche: Fensterkontakt"
                "native": {
                  "ADDRESS": "XXXXXXXXXX:3",
                  "AES_ACTIVE": 0,
                  "DIRECTION": 2,
                  "FLAGS": 1,
                  "INDEX": 3,
                  "LINK_TARGET_ROLES": "WCS_TIPTRONIC_SENSOR WINDOW_SWITCH_RECEIVER WINDOW_SWITCH_RECEIVER_V2",
                  "PARAMSETS": [
                    "LINK",
                    "MASTER",
                    "VALUES"
                  "TYPE": "WINDOW_SWITCH_RECEIVER",
                  "VERSION": 29
                "ts": 1674480663309,
                "acl": {
                  "object": 1636,
              "hm-rpc.0.XXXXXXXXXX.4": {
                "_id": "hm-rpc.0.XXXXXXXXXX.4",
                "type": "channel",
                "common": {
                  "name": "Heizung Kueche: Sender",
                  "enums": [
                      "_id": "enum.functions.HM-Heizung",
                      "common": {
                        "name": "HM-Heizung",
                        "smartName": false
                      "native": {
                        "Name": "HM-Heizung",
                        "TypeName": "ENUM",
                        "EnumInfo": "Heizung"
                      "type": "enum"
                      "_id": "enum.rooms.HM-Kueche",
                      "common": {
                        "name": "HM-Kueche",
                        "desc": "",
                        "smartName": false
                      "native": {
                        "Name": "HM-Kueche",
                        "TypeName": "ENUM",
                        "EnumInfo": ""
                      "type": "enum"
                "native": {
                  "ADDRESS": "XXXXXXXXXX:4",
                  "AES_ACTIVE": 0,
                  "DIRECTION": 1,
                  "FLAGS": 1,
                  "INDEX": 4,
                  "LINK_SOURCE_ROLES": "CLIMATECONTROL_RT",
                  "PARAMSETS": [
                    "LINK",
                    "VALUES"
                  "TYPE": "CLIMATECONTROL_RT_TRANSCEIVER",
                  "VERSION": 29
                "ts": 1674480663320,
                "acl": {
                  "object": 1636,
              "hm-rpc.0.XXXXXXXXXX.4.ACTUAL_TEMPERATURE": {
                "type": "state",
                "common": {
                  "name": "Heizung Kueche: Sender.ACTUAL_TEMPERATURE",
                  "def": 0,
                  "type": "number",
                  "read": true,
                  "write": false,
                  "min": -10,
                  "max": 56,
                  "unit": "°C",
                  "role": "value.temperature"
                "native": {
                  "CONTROL": "HEATING_CONTROL.TEMPERATURE",
                  "DEFAULT": 0,
                  "FLAGS": 1,
                  "ID": "ACTUAL_TEMPERATURE",
                  "MAX": 56,
                  "MIN": -10,
                  "OPERATIONS": 5,
                  "TAB_ORDER": 5,
                  "TYPE": "FLOAT",
                  "UNIT": "�C"
                "ts": 1674480663842,
                "_id": "hm-rpc.0.XXXXXXXXXX.4.ACTUAL_TEMPERATURE",
                "acl": {
                  "object": 1636,
                  "state": 1636,
              "hm-rpc.0.XXXXXXXXXX.4.AUTO_MODE": {
                "type": "state",
                "common": {
                  "name": "Heizung Kueche: Sender.AUTO_MODE",
                  "def": false,
                  "type": "boolean",
                  "read": false,
                  "write": true,
                  "role": "button"
                "native": {
                  "CONTROL": "HEATING_CONTROL.AUTO",
                  "DEFAULT": false,
                  "FLAGS": 1,
                  "ID": "AUTO_MODE",
                  "MAX": true,
                  "MIN": false,
                  "OPERATIONS": 2,
                  "TAB_ORDER": 7,
                  "TYPE": "ACTION",
                  "UNIT": ""
                "ts": 1674480663445,
                "_id": "hm-rpc.0.XXXXXXXXXX.4.AUTO_MODE",
                "acl": {
                  "object": 1636,
                  "state": 1636,
              "hm-rpc.0.XXXXXXXXXX.4.BATTERY_STATE": {
                "type": "state",
                "common": {
                  "name": "Heizung Kueche: Sender.BATTERY_STATE",
                  "def": 0,
                  "type": "number",
                  "read": true,
                  "write": false,
                  "min": 1.5,
                  "max": 4.6,
                  "unit": "V",
                  "role": "value.voltage"
                "native": {
                  "CONTROL": "NONE",
                  "DEFAULT": 0,
                  "FLAGS": 1,
                  "ID": "BATTERY_STATE",
                  "MAX": 4.6,
                  "MIN": 1.5,
                  "OPERATIONS": 5,
                  "TAB_ORDER": 2,
                  "TYPE": "FLOAT",
                  "UNIT": "V"
                "ts": 1674480664303,
                "_id": "hm-rpc.0.XXXXXXXXXX.4.BATTERY_STATE",
                "acl": {
                  "object": 1636,
                  "state": 1636,
              "hm-rpc.0.XXXXXXXXXX.4.BOOST_MODE": {
                "type": "state",
                "common": {
                  "name": "Heizung Kueche: Sender.BOOST_MODE",
                  "def": false,
                  "type": "boolean",
                  "read": false,
                  "write": true,
                  "role": "switch.mode.boost"
                "native": {
                  "CONTROL": "HEATING_CONTROL.BOOST",
                  "DEFAULT": false,
                  "FLAGS": 1,
                  "ID": "BOOST_MODE",
                  "MAX": true,
                  "MIN": false,
                  "OPERATIONS": 2,
                  "TAB_ORDER": 9,
                  "TYPE": "ACTION",
                  "UNIT": ""
                "ts": 1674480663418,
                "_id": "hm-rpc.0.XXXXXXXXXX.4.BOOST_MODE",
                "acl": {
                  "object": 1636,
                  "state": 1636,
              "hm-rpc.0.XXXXXXXXXX.4.BOOST_STATE": {
                "type": "state",
                "common": {
                  "name": "Heizung Kueche: Sender.BOOST_STATE",
                  "def": 0,
                  "type": "number",
                  "read": true,
                  "write": false,
                  "min": 0,
                  "max": 30,
                  "unit": "min",
                  "role": "level.boost"
                "native": {
                  "CONTROL": "NONE",
                  "DEFAULT": 0,
                  "FLAGS": 1,
                  "ID": "BOOST_STATE",
                  "MAX": 30,
                  "MIN": 0,
                  "OPERATIONS": 5,
                  "TAB_ORDER": 4,
                  "TYPE": "INTEGER",
                  "UNIT": "min"
                "ts": 1674480663826,
                "_id": "hm-rpc.0.XXXXXXXXXX.4.BOOST_STATE",
                "acl": {
                  "object": 1636,
                  "state": 1636,
              "hm-rpc.0.XXXXXXXXXX.4.COMFORT_MODE": {
                "type": "state",
                "common": {
                  "name": "Heizung Kueche: Sender.COMFORT_MODE",
                  "def": false,
                  "type": "boolean",
                  "read": false,
                  "write": true,
                  "role": "button"
                "native": {
                  "CONTROL": "HEATING_CONTROL.COMFORT",
                  "DEFAULT": false,
                  "FLAGS": 1,
                  "ID": "COMFORT_MODE",
                  "MAX": true,
                  "MIN": false,
                  "OPERATIONS": 2,
                  "TAB_ORDER": 10,
                  "TYPE": "ACTION",
                  "UNIT": ""
                "ts": 1674480663695,
                "_id": "hm-rpc.0.XXXXXXXXXX.4.COMFORT_MODE",
                "acl": {
                  "object": 1636,
                  "state": 1636,
              "hm-rpc.0.XXXXXXXXXX.4.CONTROL_MODE": {
                "type": "state",
                "common": {
                  "name": "Heizung Kueche: Sender.CONTROL_MODE",
                  "def": 0,
                  "type": "number",
                  "read": true,
                  "write": false,
                  "min": 0,
                  "max": 3,
                  "states": {
                    "0": "AUTO-MODE",
                    "1": "MANU-MODE",
                    "2": "PARTY-MODE",
                    "3": "BOOST-MODE"
                  "role": "indicator"
                "native": {
                  "CONTROL": "HEATING_CONTROL.CONTROL_MODE",
                  "DEFAULT": 0,
                  "FLAGS": 1,
                  "ID": "CONTROL_MODE",
                  "MAX": 3,
                  "MIN": 0,
                  "OPERATIONS": 5,
                  "TAB_ORDER": 0,
                  "TYPE": "ENUM",
                  "UNIT": "",
                  "VALUE_LIST": [
                    "AUTO-MODE",
                    "MANU-MODE",
                    "PARTY-MODE",
                    "BOOST-MODE"
                "ts": 1674480663482,
                "_id": "hm-rpc.0.XXXXXXXXXX.4.CONTROL_MODE",
                "acl": {
                  "object": 1636,
                  "state": 1636,
              "hm-rpc.0.XXXXXXXXXX.4.FAULT_REPORTING": {
                "type": "state",
                "common": {
                  "name": "Heizung Kueche: Sender.FAULT_REPORTING",
                  "def": 0,
                  "type": "number",
                  "read": true,
                  "write": false,
                  "min": 0,
                  "max": 7,
                  "states": {
                    "0": "NO_FAULT",
                    "1": "VALVE_TIGHT",
                    "2": "ADJUSTING_RANGE_TOO_LARGE",
                    "3": "ADJUSTING_RANGE_TOO_SMALL",
                    "4": "COMMUNICATION_ERROR",
                    "5": "",
                    "6": "LOWBAT",
                    "7": "VALVE_ERROR_POSITION"
                  "role": "indicator"
                "native": {
                  "CONTROL": "NONE",
                  "DEFAULT": 0,
                  "FLAGS": 9,
                  "ID": "FAULT_REPORTING",
                  "MAX": 7,
                  "MIN": 0,
                  "OPERATIONS": 5,
                  "TAB_ORDER": 1,
                  "TYPE": "ENUM",
                  "UNIT": "",
                  "VALUE_LIST": [
                    "NO_FAULT",
                    "VALVE_TIGHT",
                    "LOWBAT",
                "ts": 1674480663643,
                "_id": "hm-rpc.0.XXXXXXXXXX.4.FAULT_REPORTING",
                "acl": {
                  "object": 1636,
                  "state": 1636,
              "hm-rpc.0.XXXXXXXXXX.4.FAULT_REPORTING-1_ALARM": {
                "type": "state",
                "common": {
                  "name": "Heizung Kueche: Sender.FAULT_REPORTING-1_ALARM",
                  "type": "number",
                  "read": true,
                  "write": true,
                  "def": 0,
                  "states": {
                    "0": "NO ALARM",
                    "1": "ALARM",
                    "2": "ACKNOWLEDGED"
                "native": {
                  "Name": "Heizung Kueche: Sender.FAULT_REPORTING-1_ALARM",
                  "DP": "6317"
                "ts": 1620829176731,
                "_id": "hm-rpc.0.XXXXXXXXXX.4.FAULT_REPORTING-1_ALARM",
                "acl": {
                  "object": 1636,
                  "state": 1636,
              "hm-rpc.0.XXXXXXXXXX.4.FAULT_REPORTING-2_ALARM": {
                "type": "state",
                "common": {
                  "name": "Heizung Kueche: Sender.FAULT_REPORTING-2_ALARM",
                  "type": "number",
                  "read": true,
                  "write": true,
                  "def": 0,
                  "states": {
                    "0": "NO ALARM",
                    "1": "ALARM",
                    "2": "ACKNOWLEDGED"
                "native": {
                  "Name": "Heizung Kueche: Sender.FAULT_REPORTING-2_ALARM",
                  "DP": "6320"
                "ts": 1620829176747,
                "_id": "hm-rpc.0.XXXXXXXXXX.4.FAULT_REPORTING-2_ALARM",
                "acl": {
                  "object": 1636,
                  "state": 1636,
              "hm-rpc.0.XXXXXXXXXX.4.FAULT_REPORTING-3_ALARM": {
                "type": "state",
                "common": {
                  "name": "Heizung Kueche: Sender.FAULT_REPORTING-3_ALARM",
                  "type": "number",
                  "read": true,
                  "write": true,
                  "def": 0,
                  "states": {
                    "0": "NO ALARM",
                    "1": "ALARM",
                    "2": "ACKNOWLEDGED"
                "native": {
                  "Name": "Heizung Kueche: Sender.FAULT_REPORTING-3_ALARM",
                  "DP": "6323"
                "ts": 1620829176759,
                "_id": "hm-rpc.0.XXXXXXXXXX.4.FAULT_REPORTING-3_ALARM",
                "acl": {
                  "object": 1636,
                  "state": 1636,
              "hm-rpc.0.XXXXXXXXXX.4.FAULT_REPORTING-4_ALARM": {
                "type": "state",
                "common": {
                  "name": "Heizung Kueche: Sender.FAULT_REPORTING-4_ALARM",
                  "type": "number",
                  "read": true,
                  "write": true,
                  "def": 0,
                  "states": {
                    "0": "NO ALARM",
                    "1": "ALARM",
                    "2": "ACKNOWLEDGED"
                "native": {
                  "Name": "Heizung Kueche: Sender.FAULT_REPORTING-4_ALARM",
                  "DP": "6326"
                "ts": 1620829176775,
                "_id": "hm-rpc.0.XXXXXXXXXX.4.FAULT_REPORTING-4_ALARM",
                "acl": {
                  "object": 1636,
                  "state": 1636,
              "hm-rpc.0.XXXXXXXXXX.4.FAULT_REPORTING-5_ALARM": {
                "type": "state",
                "common": {
                  "name": "Heizung Kueche: Sender.FAULT_REPORTING-5_ALARM",
                  "type": "number",
                  "read": true,
                  "write": true,
                  "def": 0,
                  "states": {
                    "0": "NO ALARM",
                    "1": "ALARM",
                    "2": "ACKNOWLEDGED"
                "native": {
                  "Name": "Heizung Kueche: Sender.FAULT_REPORTING-5_ALARM",
                  "DP": "6329"
                "ts": 1620829176794,
                "_id": "hm-rpc.0.XXXXXXXXXX.4.FAULT_REPORTING-5_ALARM",
                "acl": {
                  "object": 1636,
                  "state": 1636,
              "hm-rpc.0.XXXXXXXXXX.4.FAULT_REPORTING-6_ALARM": {
                "type": "state",
                "common": {
                  "name": "Heizung Kueche: Sender.FAULT_REPORTING-6_ALARM",
                  "type": "number",
                  "read": true,
                  "write": true,
                  "def": 0,
                  "states": {
                    "0": "NO ALARM",
                    "1": "ALARM",
                    "2": "ACKNOWLEDGED"
                "native": {
                  "Name": "Heizung Kueche: Sender.FAULT_REPORTING-6_ALARM",
                  "DP": "6332"
                "ts": 1620829176812,
                "_id": "hm-rpc.0.XXXXXXXXXX.4.FAULT_REPORTING-6_ALARM",
                "acl": {
                  "object": 1636,
                  "state": 1636,
              "hm-rpc.0.XXXXXXXXXX.4.FAULT_REPORTING-7_ALARM": {
                "type": "state",
                "common": {
                  "name": "Heizung Kueche: Sender.FAULT_REPORTING-7_ALARM",
                  "type": "number",
                  "read": true,
                  "write": true,
                  "def": 0,
                  "states": {
                    "0": "NO ALARM",
                    "1": "ALARM",
                    "2": "ACKNOWLEDGED"
                "native": {
                  "Name": "Heizung Kueche: Sender.FAULT_REPORTING-7_ALARM",
                  "DP": "6335"
                "ts": 1620829176832,
                "_id": "hm-rpc.0.XXXXXXXXXX.4.FAULT_REPORTING-7_ALARM",
                "acl": {
                  "object": 1636,
                  "state": 1636,
              "hm-rpc.0.XXXXXXXXXX.4.LOWERING_MODE": {
                "type": "state",
                "common": {
                  "name": "Heizung Kueche: Sender.LOWERING_MODE",
                  "def": false,
                  "type": "boolean",
                  "read": false,
                  "write": true,
                  "role": "button"
                "native": {
                  "CONTROL": "HEATING_CONTROL.LOWERING",
                  "DEFAULT": false,
                  "FLAGS": 1,
                  "ID": "LOWERING_MODE",
                  "MAX": true,
                  "MIN": false,
                  "OPERATIONS": 2,
                  "TAB_ORDER": 11,
                  "TYPE": "ACTION",
                  "UNIT": ""
                "ts": 1674480663669,
                "_id": "hm-rpc.0.XXXXXXXXXX.4.LOWERING_MODE",
                "acl": {
                  "object": 1636,
                  "state": 1636,
              "hm-rpc.0.XXXXXXXXXX.4.MANU_MODE": {
                "type": "state",
                "common": {
                  "name": "Heizung Kueche: Sender.MANU_MODE",
                  "def": 20,
                  "type": "number",
                  "read": false,
                  "write": true,
                  "min": 4.5,
                  "max": 30.5,
                  "unit": "°C",
                  "role": "level.temperature"
                "native": {
                  "CONTROL": "HEATING_CONTROL.MANU",
                  "DEFAULT": 20,
                  "FLAGS": 1,
                  "ID": "MANU_MODE",
                  "MAX": 30.5,
                  "MIN": 4.5,
                  "OPERATIONS": 2,
                  "TAB_ORDER": 8,
                  "TYPE": "FLOAT",
                  "UNIT": "�C"
                "ts": 1674480663974,
                "_id": "hm-rpc.0.XXXXXXXXXX.4.MANU_MODE",
                "acl": {
                  "object": 1636,
                  "state": 1636,
              "hm-rpc.0.XXXXXXXXXX.4.PARTY_MODE_SUBMIT": {
                "type": "state",
                "common": {
                  "name": "Heizung Kueche: Sender.PARTY_MODE_SUBMIT",
                  "def": "",
                  "type": "string",
                  "read": false,
                  "write": true,
                  "role": ""
                "native": {
                  "CONTROL": "NONE",
                  "DEFAULT": "",
                  "FLAGS": 1,
                  "ID": "PARTY_MODE_SUBMIT",
                  "MAX": "",
                  "MIN": "",
                  "OPERATIONS": 2,
                  "TAB_ORDER": 12,
                  "TYPE": "STRING",
                  "UNIT": ""
                "ts": 1674480663913,
                "_id": "hm-rpc.0.XXXXXXXXXX.4.PARTY_MODE_SUBMIT",
                "acl": {
                  "object": 1636,
                  "state": 1636,
              "hm-rpc.0.XXXXXXXXXX.4.PARTY_START_DAY": {
                "type": "state",
                "common": {
                  "name": "Heizung Kueche: Sender.PARTY_START_DAY",
                  "def": 1,
                  "type": "number",
                  "read": true,
                  "write": true,
                  "min": 1,
                  "max": 31,
                  "unit": "day",
                  "role": ""
                "native": {
                  "CONTROL": "HEATING_CONTROL.PARTY_START_DAY",
                  "DEFAULT": 1,
                  "FLAGS": 1,
                  "ID": "PARTY_START_DAY",
                  "MAX": 31,
                  "MIN": 1,
                  "OPERATIONS": 3,
                  "TAB_ORDER": 15,
                  "TYPE": "INTEGER",
                  "UNIT": "day"
                "ts": 1674480664201,
                "_id": "hm-rpc.0.XXXXXXXXXX.4.PARTY_START_DAY",
                "acl": {
                  "object": 1636,
                  "state": 1636,
              "hm-rpc.0.XXXXXXXXXX.4.PARTY_START_MONTH": {
                "type": "state",
                "common": {
                  "name": "Heizung Kueche: Sender.PARTY_START_MONTH",
                  "def": 1,
                  "type": "number",
                  "read": true,
                  "write": true,
                  "min": 1,
                  "max": 12,
                  "unit": "month",
                  "role": ""
                "native": {
                  "CONTROL": "HEATING_CONTROL.PARTY_START_MONTH",
                  "DEFAULT": 1,
                  "FLAGS": 1,
                  "ID": "PARTY_START_MONTH",
                  "MAX": 12,
                  "MIN": 1,
                  "OPERATIONS": 3,
                  "TAB_ORDER": 16,
                  "TYPE": "INTEGER",
                  "UNIT": "month"
                "ts": 1674480664109,
                "_id": "hm-rpc.0.XXXXXXXXXX.4.PARTY_START_MONTH",
                "acl": {
                  "object": 1636,
                  "state": 1636,
              "hm-rpc.0.XXXXXXXXXX.4.PARTY_START_TIME": {
                "type": "state",
                "common": {
                  "name": "Heizung Kueche: Sender.PARTY_START_TIME",
                  "def": 0,
                  "type": "number",
                  "read": true,
                  "write": true,
                  "min": 0,
                  "max": 1410,
                  "unit": "minutes",
                  "role": ""
                "native": {
                  "CONTROL": "HEATING_CONTROL.PARTY_START_TIME",
                  "DEFAULT": 0,
                  "FLAGS": 1,
                  "ID": "PARTY_START_TIME",
                  "MAX": 1410,
                  "MIN": 0,
                  "OPERATIONS": 3,
                  "TAB_ORDER": 14,
                  "TYPE": "INTEGER",
                  "UNIT": "minutes"
                "ts": 1674480663503,
                "_id": "hm-rpc.0.XXXXXXXXXX.4.PARTY_START_TIME",
                "acl": {
                  "object": 1636,
                  "state": 1636,
              "hm-rpc.0.XXXXXXXXXX.4.PARTY_START_YEAR": {
                "type": "state",
                "common": {
                  "name": "Heizung Kueche: Sender.PARTY_START_YEAR",
                  "def": 12,
                  "type": "number",
                  "read": true,
                  "write": true,
                  "min": 0,
                  "max": 99,
                  "unit": "year",
                  "role": ""
                "native": {
                  "CONTROL": "HEATING_CONTROL.PARTY_START_YEAR",
                  "DEFAULT": 12,
                  "FLAGS": 1,
                  "ID": "PARTY_START_YEAR",
                  "MAX": 99,
                  "MIN": 0,
                  "OPERATIONS": 3,
                  "TAB_ORDER": 17,
                  "TYPE": "INTEGER",
                  "UNIT": "year"
                "ts": 1674480664026,
                "_id": "hm-rpc.0.XXXXXXXXXX.4.PARTY_START_YEAR",
                "acl": {
                  "object": 1636,
                  "state": 1636,
              "hm-rpc.0.XXXXXXXXXX.4.PARTY_STOP_DAY": {
                "type": "state",
                "common": {
                  "name": "Heizung Kueche: Sender.PARTY_STOP_DAY",
                  "def": 1,
                  "type": "number",
                  "read": true,
                  "write": true,
                  "min": 1,
                  "max": 31,
                  "unit": "day",
                  "role": ""
                "native": {
                  "CONTROL": "HEATING_CONTROL.PARTY_STOP_DAY",
                  "DEFAULT": 1,
                  "FLAGS": 1,
                  "ID": "PARTY_STOP_DAY",
                  "MAX": 31,
                  "MIN": 1,
                  "OPERATIONS": 3,
                  "TAB_ORDER": 19,
                  "TYPE": "INTEGER",
                  "UNIT": "day"
                "ts": 1674480663598,
                "_id": "hm-rpc.0.XXXXXXXXXX.4.PARTY_STOP_DAY",
                "acl": {
                  "object": 1636,
                  "state": 1636,
              "hm-rpc.0.XXXXXXXXXX.4.PARTY_STOP_MONTH": {
                "type": "state",
                "common": {
                  "name": "Heizung Kueche: Sender.PARTY_STOP_MONTH",
                  "def": 1,
                  "type": "number",
                  "read": true,
                  "write": true,
                  "min": 1,
                  "max": 12,
                  "unit": "month",
                  "role": ""
                "native": {
                  "CONTROL": "HEATING_CONTROL.PARTY_STOP_MONTH",
                  "DEFAULT": 1,
                  "FLAGS": 1,
                  "ID": "PARTY_STOP_MONTH",
                  "MAX": 12,
                  "MIN": 1,
                  "OPERATIONS": 3,
                  "TAB_ORDER": 20,
                  "TYPE": "INTEGER",
                  "UNIT": "month"
                "ts": 1674480663563,
                "_id": "hm-rpc.0.XXXXXXXXXX.4.PARTY_STOP_MONTH",
                "acl": {
                  "object": 1636,
                  "state": 1636,
              "hm-rpc.0.XXXXXXXXXX.4.PARTY_STOP_TIME": {
                "type": "state",
                "common": {
                  "name": "Heizung Kueche: Sender.PARTY_STOP_TIME",
                  "def": 0,
                  "type": "number",
                  "read": true,
                  "write": true,
                  "min": 0,
                  "max": 1410,
                  "unit": "minutes",
                  "role": ""
                "native": {
                  "CONTROL": "HEATING_CONTROL.PARTY_STOP_TIME",
                  "DEFAULT": 0,
                  "FLAGS": 1,
                  "ID": "PARTY_STOP_TIME",
                  "MAX": 1410,
                  "MIN": 0,
                  "OPERATIONS": 3,
                  "TAB_ORDER": 18,
                  "TYPE": "INTEGER",
                  "UNIT": "minutes"
                "ts": 1674480663535,
                "_id": "hm-rpc.0.XXXXXXXXXX.4.PARTY_STOP_TIME",
                "acl": {
                  "object": 1636,
                  "state": 1636,
              "hm-rpc.0.XXXXXXXXXX.4.PARTY_STOP_YEAR": {
                "type": "state",
                "common": {
                  "name": "Heizung Kueche: Sender.PARTY_STOP_YEAR",
                  "def": 12,
                  "type": "number",
                  "read": true,
                  "write": true,
                  "min": 0,
                  "max": 99,
                  "unit": "year",
                  "role": ""
                "native": {
                  "CONTROL": "HEATING_CONTROL.PARTY_STOP_YEAR",
                  "DEFAULT": 12,
                  "FLAGS": 1,
                  "ID": "PARTY_STOP_YEAR",
                  "MAX": 99,
                  "MIN": 0,
                  "OPERATIONS": 3,
                  "TAB_ORDER": 21,
                  "TYPE": "INTEGER",
                  "UNIT": "year"
                "ts": 1674480663620,
                "_id": "hm-rpc.0.XXXXXXXXXX.4.PARTY_STOP_YEAR",
                "acl": {
                  "object": 1636,
                  "state": 1636,
              "hm-rpc.0.XXXXXXXXXX.4.PARTY_TEMPERATURE": {
                "type": "state",
                "common": {
                  "name": "Heizung Kueche: Sender.PARTY_TEMPERATURE",
                  "def": 20,
                  "type": "number",
                  "read": true,
                  "write": true,
                  "min": 5,
                  "max": 30,
                  "unit": "°C",
                  "role": ""
                "native": {
                  "CONTROL": "HEATING_CONTROL.PARTY_TEMP",
                  "DEFAULT": 20,
                  "FLAGS": 1,
                  "ID": "PARTY_TEMPERATURE",
                  "MAX": 30,
                  "MIN": 5,
                  "OPERATIONS": 3,
                  "TAB_ORDER": 13,
                  "TYPE": "FLOAT",
                  "UNIT": "�C"
                "ts": 1674480663958,
                "_id": "hm-rpc.0.XXXXXXXXXX.4.PARTY_TEMPERATURE",
                "acl": {
                  "object": 1636,
                  "state": 1636,
              "hm-rpc.0.XXXXXXXXXX.4.SET_TEMPERATURE": {
                "type": "state",
                "common": {
                  "name": "Heizung Kueche: Sender.SET_TEMPERATURE",
                  "def": 20,
                  "type": "number",
                  "read": true,
                  "write": true,
                  "min": 4.5,
                  "max": 30.5,
                  "unit": "°C",
                "native": {
                  "CONTROL": "HEATING_CONTROL.SETPOINT",
                  "DEFAULT": 20,
                  "FLAGS": 1,
                  "ID": "SET_TEMPERATURE",
                  "MAX": 30.5,
                  "MIN": 4.5,
                  "OPERATIONS": 7,
                  "TAB_ORDER": 6,
                  "TYPE": "FLOAT",
                  "UNIT": "�C"
                "ts": 1674480663340,
                "_id": "hm-rpc.0.XXXXXXXXXX.4.SET_TEMPERATURE",
                "acl": {
                  "object": 1636,
                  "state": 1636,
              "hm-rpc.0.XXXXXXXXXX.4.VALVE_STATE": {
                "type": "state",
                "common": {
                  "name": "Heizung Kueche: Sender.VALVE_STATE",
                  "def": 0,
                  "type": "number",
                  "read": true,
                  "write": false,
                  "min": 0,
                  "max": 99,
                  "unit": "%",
                  "role": "value.valve"
                "native": {
                  "CONTROL": "NONE",
                  "DEFAULT": 0,
                  "FLAGS": 1,
                  "ID": "VALVE_STATE",
                  "MAX": 99,
                  "MIN": 0,
                  "OPERATIONS": 5,
                  "TAB_ORDER": 3,
                  "TYPE": "INTEGER",
                  "UNIT": "%"
                "ts": 1674480664118,
                "_id": "hm-rpc.0.XXXXXXXXXX.4.VALVE_STATE",
                "acl": {
                  "object": 1636,
                  "state": 1636,
              "hm-rpc.0.XXXXXXXXXX.5": {
                "_id": "hm-rpc.0.XXXXXXXXXX.5",
                "type": "channel",
                "common": {
                  "name": "Heizung Kueche: Empfaenger"
                "native": {
                  "ADDRESS": "XXXXXXXXXX:5",
                  "AES_ACTIVE": 0,
                  "DIRECTION": 2,
                  "FLAGS": 1,
                  "INDEX": 5,
                  "LINK_TARGET_ROLES": "CLIMATECONTROL_RT",
                  "PARAMSETS": [
                    "LINK",
                    "MASTER",
                    "VALUES"
                  "TYPE": "CLIMATECONTROL_RT_RECEIVER",
                  "VERSION": 29
                "ts": 1674480664379,
                "acl": {
                  "object": 1636,
              "hm-rpc.0.XXXXXXXXXX.6": {
                "_id": "hm-rpc.0.XXXXXXXXXX.6",
                "type": "channel",
                "common": {
                  "name": "Heizung Kueche: Tasten"
                "native": {
                  "ADDRESS": "XXXXXXXXXX:6",
                  "AES_ACTIVE": 0,
                  "DIRECTION": 2,
                  "FLAGS": 1,
                  "INDEX": 6,
                  "LINK_TARGET_ROLES": "REMOTECONTROL_RECEIVER",
                  "PARAMSETS": [
                    "LINK",
                    "MASTER",
                    "VALUES"
                  "TYPE": "REMOTECONTROL_RECEIVER",
                  "VERSION": 29
                "ts": 1674480664403,
                "acl": {
                  "object": 1636,
              A Former User @Rookie50 last edited by
              @rookie50 in GitHub melden reicht. macht das ganze Übersichtlicher 😉 Ich weiss über die Besonderheit von den Thermostat bescheid, mit lowbat hat aber noch keiner gemeldet. Daher danke für die Information und ich werde es sobald wie möglich mit aufnehmen. 🙂
              R 2 Replies Last reply Reply Quote 1
                @ciddi89 said in Test Adapter Device-Watcher v2.x.x GitHub/Latest:
                ich habe keine vernüftige Darstellung bei Github für den JSON output gefunden. Deswegen habe ich es hier gepostet 😉
                  @rookie50 sagte in Test Adapter Device-Watcher v2.x.x GitHub/Latest:
                  Moin,
                  hier, wie auch bei Github, kannst Du die Markdown Tags nutzen.
                  Beispiele:
                  Um z.B. eine Headline zu schreiben kannst Du einfach # vor den Text setzen , bei ## ist es eine Unterüberschrift usw. bis ######
                  Heading level 1
                  Heading level 2
                  Wenn Du etwas hervorheben möchtest, dann kannst Du das mit **wort** oder _wort_
                  I just love bold text
                  I also love kursive
                  Wenn man source code einfügen möchte, dann klappt das mit ```source```
                      "type": "device",
                      "common": {
                  Markdown Cheat Sheet
                  VG
                  Bernd
                    ChrisXY last edited by
                    huhu, habe aktuell das problem das meine ESPHOME als Offline angezeigt werden. Obwohl online True steht.
                      A Former User @ChrisXY last edited by
                      @chrisxy was für eine offline Zeit steht denn unter Experten Einstellungen?
                      • nik82
                        nik82 Most Active last edited by
                        echt super Adapter.
                        Hätte nur eine kleine Frage: Wie kann ich statt der Batterieanzeige in V, die Prozentzahl anzeigen lassen?
                        Also wieviel Prozent die Batterie noch hat?
                        Habe im Adapter das schon aktiviert, aber hat nichts gebracht:
                        Zeigt mir immer noch die Volt an:
                        Danke im Voraus.
                          arteck Developer Most Active @nik82 last edited by arteck
                          @nik82
                          klugscheiss modus an
                          lesen bildet sagt man doch oder...
                          also lies nochmal.. was steht da zu % was wird da konvertiert ?? und nochmal was hast du aktiviert ??
                          klugscheiss modus aus
                          • nik82
                            @arteck
                            Ja da hast du Recht, wenn ich das so lese, sollte man den eigentlich deaktivieren wenn man die % will, dass ist ja als Standard bei der Erstinstallation auch eingestellt.
                            Nur leider kommt bei mir trotzdem keine % Zahl bei Batterie, egal ob ich den Haken drin oder raus habe🤔
                            Hab ihn jetzt mal wieder raus:
                            Leider immer noch Volt:
                            arteck ? 2 Replies Last reply Reply Quote 0
                              @nik82 sagte in Test Adapter Device-Watcher v2.x.x GitHub/Latest:
                              ach komm.. du liest es 2 mal und ...
                              da steht
                              Wert der Signalstärke
                              nix Batterie
                              nik82 1 Reply Last reply Reply Quote 1
                              • nik82
                                nik82 Most Active @arteck last edited by
                                @arteck
                                Oh mann, sorry, das war doof 😞
                                Ich hab mich nur leiten lassen von dem Screenshot auf Github:
                                Also dann gehe ich davon aus, dass die Batterieanzeige in % bei Homematic Geräten nicht geht.
                                Danke für deinen "Stuppser"👍
                                  A Former User @nik82 last edited by
                                  Moin,
                                  @arteck
                                  Da steht nur etwas über Signalstärke, nichts über Batterien.
                                  Ich habe keine Homatic Geräte, aber haben die in den Objekten denn einen State, der die Batterie in % angibt?
                                  Hier mal ein Beispiel für Zigbee
                                  VG
                                  Bernd
                                  • nik82
                                    nik82 Most Active @Guest last edited by
                                    @dp20eic
                                    Nein, Homematic Geräte haben nur eine Volt Anzeige, habe nur geradacht, dass über die verschiedenen Volt die % umgerechnet wird.
                                      @nik82 das stimmt, leider hat Homematic nur Volt Angaben. Eine Umrechnung wäre auch viel zu aufwendig und ungenau wenn das Gerät das nativ nicht liefert.
                                        Kueppert last edited by
                                        anscheinend habe nur ich das Problem mit den Massen-Meldungen seit dem Update:
                                        device-watcher.0 2023-02-09 12:12:16.255	warn	State "device-watcher.0.adapterAndInstances.countInstancesError" has no existing object, this might lead to an error in future versions
                                        device-watcher.0 2023-02-09 12:12:16.241	warn	State "device-watcher.0.adapterAndInstances.listInstancesError" has no existing object, this might lead to an error in future versions
                                        device-watcher.0 2023-02-09 12:12:16.220	warn	State "device-watcher.0.adapterAndInstances.countDeactivatedInstances" has no existing object, this might lead to an error in future versions
                                        device-watcher.0 2023-02-09 12:12:16.173	warn	State "device-watcher.0.adapterAndInstances.listDeactivatedInstances" has no existing object, this might lead to an error in future versions
                                        device-watcher.0 2023-02-09 12:12:16.156	warn	State "device-watcher.0.adapterAndInstances.listAllInstances" has no existing object, this might lead to an error in future versions
                                        device-watcher.0 2023-02-09 12:12:16.135	warn	State "device-watcher.0.adapterAndInstances.countDeactivatedInstances" has no existing object, this might lead to an error in future versions
                                        device-watcher.0 2023-02-09 12:12:16.098	warn	State "device-watcher.0.adapterAndInstances.countAllInstances" has no existing object, this might lead to an error in future versions
                                        Ich habe schon den Objektbaum gelöscht und die Konfig vom Adapter neu gespeichert...
                                          A Former User @Kueppert last edited by
                                          @kueppert ja scheint so. Eigentlich reicht bei sowas Instanz stoppen, Ordner löschen, Instanz Neustarten dann baut er die Struktur neu auf. Welche Version ist es denn? Ist Instanz Listen erstellen aktiviert? Adapter schon mal komplett gelöscht und neu installiert? Aktuellste und stabilste Version auf npm ist 2.6.0
                                          K 2 Replies Last reply Reply Quote 0
                                            Kueppert @Guest last edited by
                                            @ciddi89 danke für die Rückmeldung.
                                            Instanz-Listen ist deaktiviert
                                            Version installiert ist die 2.6.0
                                            Adapter gestoppt - Objekt-Tree gelöscht - Instanz gestartet hab ich schon probiert.
                                            Ich exportiere heute mal die Einstellungen und installiere den Adapter neu.
                                            1462
                                            500541
