    4. [Neuer Adapter] radar-trap
    • O
      oxident @Oli last edited by
      @oli Hmm, schätze, wir sitzen im selben Boot.
      Habe diverse Dinge bereits versucht und verschiedene Kombinationen durch. Bisher leider noch kein Erfolg. Habe radar-trap2 daher erstmal wieder komplett deinstalliert (dann lief's sofort wieder) und werde demnächst mal tiefer graben.
      • O
        Oli @carsten04 last edited by
        @carsten04
        das ist alles was an Fehlermeldungen im VIS Editor kommt
        VM417:410 Uncaught (in promise) SyntaxError: Expected double-quoted property name in JSON at position 247968
           at JSON.parse (<anonymous>)
           at getTranslation (info.js:13:47)
        getTranslation @ info.js:13
        await in getTranslation (async)
        (anonym) @ info.js:6
        jquery-1.11.2.min.js:4          GET http://192.168.2.120:8082/vis/adapter/rssfeed/words.js 404 (Not Found)
        send @ jquery-1.11.2.min.js:4
        ajax @ jquery-1.11.2.min.js:4
        m.<computed> @ jquery-1.11.2.min.js:4
        (anonym) @ rssfeed.js:15
        vis-editor.css:1          GET http://192.168.2.120:8082/vis/icon/dimmer.png 404 (Not Found)
        visEditInspect.js:2276 Uncaught TypeError: Cannot read properties of undefined (reading 'widgets')
           at HTMLDivElement.<anonymous> (visEditInspect.js:2276:46)
           at Function.each (jquery-1.11.2.min.js:2:2975)
           at m.fn.init.each (jquery-1.11.2.min.js:2:835)
           at Object.inspectWidgets (visEditInspect.js:2269:49)
           at vis.js:3630:29
           at r.<anonymous> (conn.js:936:45)
           at r.onack (index.js:83:1)
           at r.onpacket (index.js:83:1)
           at r.<anonymous> (index.js:83:1)
           at r.emit (index.js:83:1)
           at r.ondecoded (index.js:83:1)
           at a.<anonymous> (index.js:83:1)
           at a.add (index.js:83:1)
           at r.ondata (index.js:83:1)
           at r.onPacket (index.js:83:1)
           at r.onData (index.js:83:1)
           at ws.onmessage (index.js:83:1)
        (anonym) @ visEditInspect.js:2276
        each @ jquery-1.11.2.min.js:2
        inspectWidgets @ visEditInspect.js:2269
        (anonym) @ vis.js:3630
        (anonym) @ conn.js:936
        r.onack @ index.js:83
        r.onpacket @ index.js:83
        (anonym) @ index.js:83
        r.emit @ index.js:83
        r.ondecoded @ index.js:83
        a.add @ index.js:83
        r.ondata @ index.js:83
        r.onPacket @ index.js:83
        r.onData @ index.js:83
        ws.onmessage @ index.js:83
        Hier noch Warnungen aus dem VIS Editor
        Entwicklertools konnten Quellzuordnung nicht laden: Inhalt für http://192.168.2.120:8082/lib/js/socket.io.js.map: HTTP-Fehler: Statuscode 404, net::ERR_HTTP_RESPONSE_CODE_FAILURE konnte nicht geladen werden
        Entwicklertools konnten Quellzuordnung nicht laden: Inhalt für http://192.168.2.120:8082/vis/widgets/radar-trap2/js/mapbox/mapbox-gl-csp.js.map: HTTP-Fehler: Statuscode 404, net::ERR_HTTP_RESPONSE_CODE_FAILURE konnte nicht geladen werden
        • O
          Oli @oxident last edited by
          @oxident
          ja leider, halte mich bitte auf dem laufenden, ob du eine Lösung gefunden hast
          carsten04 1 Reply Last reply Reply Quote 0
          • carsten04
            carsten04 Developer @Oli last edited by
            @oli Läuft Dein Admin hinter einem Proxy, oder hast Du im Admin https aktiviert? Das funktioniert nämlich noch nicht.
            • O
              @carsten04
              mein ioBroker läuft als Docker auf einer Qnap, mit Proxy kenne ich mich nicht aus, also gehe ich davon aus, dass dies nicht der Fall ist. Hier mal meine Admin Adapter Einstellungen
              • carsten04
                @oli Kannst Du bitte mal neu von GitHub installieren und vorher alles sauber deinstallieren. Es fehlten die map-Dateien und es kann sein, dass es daran gelegen hat. Danke!
                • O
                  @carsten04
                  Was verstehst du unter alles deinstallieren?
                  Bis jetzt bin ich immer auf die Adapter ansichten und habe dort den Adapter deinstalliert
                  • carsten04
                    @oli Ja genau. Du kannst auch noch vorher die Instanz löschen. Wichtig ist, dass im Objektbaum alles weg ist.
                    • O
                      @carsten04
                      habe jetzt den Adapter neu installiert, aber leider bringt er mir immer noch Verbindungsfehler im VIS Editor
                      Fehlermeldung
                      VM6944:410 Uncaught (in promise) SyntaxError: Expected double-quoted property name in JSON at position 247968
                      Warnmeldung
                      Einstellungen Web-Adapter
                      Schade finde den Adapter echt genial von den Infos
                      • carsten04
                        carsten04 Developer @Oli last edited by carsten04
                        @oli Klappt denn das Anlegen von Routen und die Kartendarstellung im Adapter-Admin fehlerfrei? Eigentlich ist meine Umgebung fast identisch zu Deiner, außer dass mein Docker-Container auf einer Synology läuft. Die Fehlermeldungen die bei Dir kommen haben auch keinen Bezug zum Adapter (z.B. dimmer.png oder words.js), da ist noch irgendetwas anderes nicht ok. Hast Du in Deiner VIS noch etwas anderes am Start?
                        • O
                          @carsten04
                          Nein, habe gerade festgestellt, dass ich keine Routen speichern kann, dass Speichersympol wird nicht grün
                          • carsten04
                            @oli Dann mach mal folgendes: restart der Instanz. Wenn alles richtig läuft, dann bekommst Du bei der Eingabe von Start und Ziel direkt Vorschläge angezeigt, so wie hier. Wichtig: Du musst den richtigen Vorschlag mit RETURN übernehmen.
                            • O
                              Oli @carsten04 last edited by Oli
                              @carsten04
                              das klappt leider auch nicht, da kommen keine Vorschläge
                              jetzt kamen mehr Fehler
                              trycatch.ts:281          GET http://192.168.2.120:3040/socket.io/?EIO=3&transport=polling&t=OOo98Rv net::ERR_CONNECTION_REFUSED
                              (anonym) @ trycatch.ts:281
                              (anonym) @ instrument.ts:309
                              i.create @ index.js:83
                              i @ index.js:83
                              o.request @ index.js:83
                              o.doPoll @ index.js:83
                              r.poll @ index.js:83
                              r.doOpen @ index.js:83
                              r.open @ index.js:83
                              r @ index.js:83
                              r @ index.js:83
                              r.open.r.connect @ index.js:83
                              sentryWrapped @ helpers.ts:87
                              setTimeout (async)
                              (anonym) @ trycatch.ts:119
                              r.reconnect @ index.js:83
                              r.onclose @ index.js:83
                              r.onClose @ index.js:83
                              ws.onclose @ index.js:83
                              trycatch.ts:281          GET http://192.168.2.120:3040/socket.io/?EIO=3&transport=polling&t=OOo99fy net::ERR_CONNECTION_REFUSED
                              i @ index.js:83
                              r @ index.js:83
                              r @ index.js:83
                              setTimeout (async)
                              r.onError @ index.js:83
                              i.onError @ index.js:83
                              setTimeout (async)
                              hasXDR.e.onreadystatechange @ index.js:83
                              XMLHttpRequest.send (async)
                              i @ index.js:83
                              r @ index.js:83
                              r @ index.js:83
                              setTimeout (async)
                              trycatch.ts:281          GET http://192.168.2.120:3040/socket.io/?EIO=3&transport=polling&t=OOo9AeS net::ERR_CONNECTION_REFUSED
                              i @ index.js:83
                              r @ index.js:83
                              r @ index.js:83
                              setTimeout (async)
                              setTimeout (async)
                              i @ index.js:83
                              r @ index.js:83
                              r @ index.js:83
                              setTimeout (async)
                              setTimeout (async)
                              i @ index.js:83
                              r @ index.js:83
                              r @ index.js:83
                              setTimeout (async)
                              trycatch.ts:281          GET http://192.168.2.120:3040/socket.io/?EIO=3&transport=polling&t=OOo9oC2 net::ERR_CONNECTION_REFUSED
                              i @ index.js:83
                              r @ index.js:83
                              r @ index.js:83
                              setTimeout (async)
                                 at vis.js:3630:29
                              a.add @ index.js:83
                              Bin, jetzt mal unterwegs.
                              • carsten04
                                @oli Mhm, das ist alles sehr merkwürdig. Hast Du den feathers-Port eventuell schon anderweitig vergeben? Kannst Du einmal bei geöffneter dev-Konsole die Instanz neu starten und schauen, ob da irgendetwas kommt?
                                • O
                                  @carsten04
                                  Fehlermeldungen aus der Instanz
                                  websocket.js:124 WebSocket connection to 'ws://192.168.2.120:3040/socket.io/?EIO=3&transport=websocket' failed:
                                  Pc.doOpen @ websocket.js:124
                                  Kf.open @ transport.js:84
                                  cn.open @ socket.js:250
                                  cn @ socket.js:122
                                  cn @ socket.js:28
                                  Pn.open.Pn.connect @ manager.js:226
                                  (anonym) @ manager.js:544
                                  cn @ socket.js:122
                                  cn @ socket.js:28
                                  browser-layer.js:92          GET https://api.mapbox.com/geocoding/v5/mapbox.places/xxxxxxxxxxxxxxxxxxxxxxxxxxxxx.json?language=de&types=address%2Cpoi&limit=1&access_token=XXXXXXXXXXXXXXXXXXXXXXXXXXXXAvM61g 401 (Unauthorized)
                                  (anonym) @ browser-layer.js:92
                                  zje @ browser-layer.js:38
                                  (anonym) @ browser-layer.js:116
                                  Promise.then (async)
                                  LVt @ browser-layer.js:114
                                  Hy.send @ mapi-request.js:160
                                  (anonym) @ RouteGeocoderField.tsx:62
                                  S2t @ react-dom.production.min.js:262
                                  jn.unstable_runWithPriority @ scheduler.production.min.js:18
                                  i_ @ react-dom.production.min.js:122
                                  My @ react-dom.production.min.js:261
                                  IK @ react-dom.production.min.js:243
                                  (anonym) @ react-dom.production.min.js:123
                                  cEe @ react-dom.production.min.js:123
                                  jf @ react-dom.production.min.js:122
                                  x2t @ react-dom.production.min.js:244
                                  GK @ react-dom.production.min.js:292
                                  HK @ react-dom.production.min.js:49
                                  QRt @ react-dom.production.min.js:50
                                  tEe @ react-dom.production.min.js:105
                                  QK @ react-dom.production.min.js:75
                                  JK @ react-dom.production.min.js:74
                                  ESe @ react-dom.production.min.js:292
                                  gkt @ react-dom.production.min.js:73
                                  index_m.html:1 Uncaught (in promise) RVt {message: 'Not Authorized - Invalid Token', type: 'HttpError', statusCode: 401, request: Hy, body: {…}}
                                  (anonym) @ RouteGeocoderField.tsx:63
                                  • carsten04
                                    @oli Das hilft mir schon mal weiter. Danke Dir.
                                    • O
                                      @carsten04
                                      gerne
                                      • carsten04
                                        @oli Hinweis: Dein Token ist definitiv ungültig. Das müsstest Du mal checken. Der Rest könnten Folgefehler seien. Am Besten Du erstellst Dir ein neues Token und nutzt nicht den Default public token. Wenn der Token korrekt ist, kannst Du auf jeden Fall im Tab KARTEN schon einmal eine Karte ohne Route sehen.
                                        • O
                                          Also bei mir tritt das VIS-Problem ja auch auf, nutze aber weder Docker noch Proxy. Die Routenerstellung funktioniert jedoch und der Feathers-Port ist verfügbar.
                                          • carsten04
                                            carsten04 Developer @oxident last edited by
                                            @oxident Du siehst dann im Admin unter Karten auch die eingegebenen Routen und die Hindernisse, richtig?
                                            31.7k
                                            79.8k
                                            251
                                            26460
