    4. [Neuer Adapter] radar-trap
    • carsten04
      carsten04 Developer @Oli last edited by carsten04
      @oli Dann mach mal folgendes: restart der Instanz. Wenn alles richtig läuft, dann bekommst Du bei der Eingabe von Start und Ziel direkt Vorschläge angezeigt, so wie hier. Wichtig: Du musst den richtigen Vorschlag mit RETURN übernehmen.
      • O
        Oli @carsten04 last edited by Oli
        @carsten04
        das klappt leider auch nicht, da kommen keine Vorschläge
        jetzt kamen mehr Fehler
        VM6944:410 Uncaught (in promise) SyntaxError: Expected double-quoted property name in JSON at position 247968
           at JSON.parse (<anonymous>)
           at getTranslation (info.js:13:47)
        getTranslation @ info.js:13
        await in getTranslation (async)
        (anonym) @ info.js:6
        jquery-1.11.2.min.js:4          GET http://192.168.2.120:8082/vis/adapter/rssfeed/words.js 404 (Not Found)
        send @ jquery-1.11.2.min.js:4
        ajax @ jquery-1.11.2.min.js:4
        m.<computed> @ jquery-1.11.2.min.js:4
        (anonym) @ rssfeed.js:15
        vis-editor.css:1          GET http://192.168.2.120:8082/vis/icon/dimmer.png 404 (Not Found)
        trycatch.ts:281          GET http://192.168.2.120:3040/socket.io/?EIO=3&transport=polling&t=OOo98Rv net::ERR_CONNECTION_REFUSED
        (anonym) @ trycatch.ts:281
        (anonym) @ instrument.ts:309
        i.create @ index.js:83
        i @ index.js:83
        o.request @ index.js:83
        o.doPoll @ index.js:83
        r.poll @ index.js:83
        r.doOpen @ index.js:83
        r.open @ index.js:83
        r @ index.js:83
        r @ index.js:83
        r.open.r.connect @ index.js:83
        (anonym) @ index.js:83
        sentryWrapped @ helpers.ts:87
        setTimeout (async)
        (anonym) @ trycatch.ts:119
        r.reconnect @ index.js:83
        r.onclose @ index.js:83
        r.emit @ index.js:83
        r.onClose @ index.js:83
        ws.onclose @ index.js:83
        trycatch.ts:281          GET http://192.168.2.120:3040/socket.io/?EIO=3&transport=polling&t=OOo99fy net::ERR_CONNECTION_REFUSED
        i @ index.js:83
        r @ index.js:83
        r @ index.js:83
        setTimeout (async)
        r.onError @ index.js:83
        i.onError @ index.js:83
        setTimeout (async)
        hasXDR.e.onreadystatechange @ index.js:83
        XMLHttpRequest.send (async)
        i @ index.js:83
        r @ index.js:83
        r @ index.js:83
        setTimeout (async)
        trycatch.ts:281          GET http://192.168.2.120:3040/socket.io/?EIO=3&transport=polling&t=OOo9AeS net::ERR_CONNECTION_REFUSED
        i @ index.js:83
        r @ index.js:83
        r @ index.js:83
        setTimeout (async)
        setTimeout (async)
        i @ index.js:83
        r @ index.js:83
        r @ index.js:83
        setTimeout (async)
        setTimeout (async)
        i @ index.js:83
        r @ index.js:83
        r @ index.js:83
        setTimeout (async)
        trycatch.ts:281          GET http://192.168.2.120:3040/socket.io/?EIO=3&transport=polling&t=OOo9oC2 net::ERR_CONNECTION_REFUSED
        i @ index.js:83
        r @ index.js:83
        r @ index.js:83
        setTimeout (async)
        visEditInspect.js:2276 Uncaught TypeError: Cannot read properties of undefined (reading 'widgets')
           at HTMLDivElement.<anonymous> (visEditInspect.js:2276:46)
           at Function.each (jquery-1.11.2.min.js:2:2975)
           at m.fn.init.each (jquery-1.11.2.min.js:2:835)
           at Object.inspectWidgets (visEditInspect.js:2269:49)
           at vis.js:3630:29
           at r.<anonymous> (conn.js:936:45)
           at r.onack (index.js:83:1)
           at r.onpacket (index.js:83:1)
           at r.<anonymous> (index.js:83:1)
           at r.emit (index.js:83:1)
           at r.ondecoded (index.js:83:1)
           at a.<anonymous> (index.js:83:1)
           at a.add (index.js:83:1)
           at r.ondata (index.js:83:1)
           at r.onPacket (index.js:83:1)
           at r.onData (index.js:83:1)
           at ws.onmessage (index.js:83:1)
        (anonym) @ visEditInspect.js:2276
        each @ jquery-1.11.2.min.js:2
        inspectWidgets @ visEditInspect.js:2269
        (anonym) @ vis.js:3630
        (anonym) @ conn.js:936
        r.onack @ index.js:83
        r.onpacket @ index.js:83
        r.ondecoded @ index.js:83
        a.add @ index.js:83
        r.ondata @ index.js:83
        r.onPacket @ index.js:83
        r.onData @ index.js:83
        ws.onmessage @ index.js:83
        Bin, jetzt mal unterwegs.
        carsten04 1 Reply Last reply Reply Quote 0
        • carsten04
          @oli Mhm, das ist alles sehr merkwürdig. Hast Du den feathers-Port eventuell schon anderweitig vergeben? Kannst Du einmal bei geöffneter dev-Konsole die Instanz neu starten und schauen, ob da irgendetwas kommt?
          • O
            @carsten04
            Fehlermeldungen aus der Instanz
            websocket.js:124 WebSocket connection to 'ws://192.168.2.120:3040/socket.io/?EIO=3&transport=websocket' failed:
            Pc.doOpen @ websocket.js:124
            Kf.open @ transport.js:84
            cn.open @ socket.js:250
            cn @ socket.js:122
            cn @ socket.js:28
            Pn.open.Pn.connect @ manager.js:226
            (anonym) @ manager.js:544
            cn @ socket.js:122
            cn @ socket.js:28
            browser-layer.js:92          GET https://api.mapbox.com/geocoding/v5/mapbox.places/xxxxxxxxxxxxxxxxxxxxxxxxxxxxx.json?language=de&types=address%2Cpoi&limit=1&access_token=XXXXXXXXXXXXXXXXXXXXXXXXXXXXAvM61g 401 (Unauthorized)
            (anonym) @ browser-layer.js:92
            zje @ browser-layer.js:38
            (anonym) @ browser-layer.js:116
            Promise.then (async)
            LVt @ browser-layer.js:114
            Hy.send @ mapi-request.js:160
            (anonym) @ RouteGeocoderField.tsx:62
            S2t @ react-dom.production.min.js:262
            jn.unstable_runWithPriority @ scheduler.production.min.js:18
            i_ @ react-dom.production.min.js:122
            My @ react-dom.production.min.js:261
            IK @ react-dom.production.min.js:243
            (anonym) @ react-dom.production.min.js:123
            cEe @ react-dom.production.min.js:123
            jf @ react-dom.production.min.js:122
            x2t @ react-dom.production.min.js:244
            GK @ react-dom.production.min.js:292
            HK @ react-dom.production.min.js:49
            QRt @ react-dom.production.min.js:50
            tEe @ react-dom.production.min.js:105
            QK @ react-dom.production.min.js:75
            JK @ react-dom.production.min.js:74
            ESe @ react-dom.production.min.js:292
            gkt @ react-dom.production.min.js:73
            index_m.html:1 Uncaught (in promise) RVt {message: 'Not Authorized - Invalid Token', type: 'HttpError', statusCode: 401, request: Hy, body: {…}}
            (anonym) @ RouteGeocoderField.tsx:63
            • carsten04
              @oli Das hilft mir schon mal weiter. Danke Dir.
              • O
                @carsten04
                gerne
                • carsten04
                  @oli Hinweis: Dein Token ist definitiv ungültig. Das müsstest Du mal checken. Der Rest könnten Folgefehler seien. Am Besten Du erstellst Dir ein neues Token und nutzt nicht den Default public token. Wenn der Token korrekt ist, kannst Du auf jeden Fall im Tab KARTEN schon einmal eine Karte ohne Route sehen.
                  • O
                    oxident last edited by
                    Also bei mir tritt das VIS-Problem ja auch auf, nutze aber weder Docker noch Proxy. Die Routenerstellung funktioniert jedoch und der Feathers-Port ist verfügbar.
                    • carsten04
                      carsten04 Developer @oxident last edited by
                      @oxident Du siehst dann im Admin unter Karten auch die eingegebenen Routen und die Hindernisse, richtig?
                      • O
                        oxident @carsten04 last edited by
                        @carsten04 Ja, soweit alles ok!
                        • carsten04
                          @oxident Kannst Du mal bitte bei offener Dev-Konsole die VIS-Runtime mit F5 aktualisieren und vorher ein map-Widget auf die view ziehen und die Ausgabe (also nach Aktualisierung mit F5) dann hier posten.
                          • O
                            @carsten04
                            es wird immer kurioser, Routen kann ich jetzt anlegen, allerdings nur mit folgender Web Adapter Einstellungen
                            Mit allen anderen Einstellungen funktioniert es nicht!!!!!
                            Dann bekomme ich aber folgende Fehlermeldungen im VIS Editor
                            VM2282:410 Uncaught (in promise) SyntaxError: Expected double-quoted property name in JSON at position 247968
                            index.js:83          GET http://192.168.2.120:8082/socket.io/?key=nokey&EIO=3&transport=polling&t=OOy4utq 404 (Not Found)
                            i @ index.js:83
                            r @ index.js:83
                            r @ index.js:83
                            r @ index.js:83
                            r @ index.js:83
                            r @ index.js:83
                            init @ conn.js:266
                            main @ vis.js:3649
                            (anonym) @ vis.js:3935
                            j @ jquery-1.11.2.min.js:2
                            fireWith @ jquery-1.11.2.min.js:2
                            ready @ jquery-1.11.2.min.js:2
                            J @ jquery-1.11.2.min.js:2
                            index.js:83          GET http://192.168.2.120:8082/socket.io/?key=nokey&EIO=3&transport=polling&t=OOy4xWa 404 (Not Found)
                            i @ index.js:83
                            r @ index.js:83
                            r @ index.js:83
                            (anonym) @ conn.js:158
                            setInterval (async)
                            reconnect @ conn.js:156
                            (anonym) @ conn.js:363
                            r.emitAll @ index.js:83
                            setTimeout (async)
                            i @ index.js:83
                            r @ index.js:83
                            r @ index.js:83
                            r @ index.js:83
                            r @ index.js:83
                            r @ index.js:83
                            init @ conn.js:266
                            main @ vis.js:3649
                            index.js:83          GET http://192.168.2.120:8082/socket.io/?key=nokey&EIO=3&transport=polling&t=OOy4zyr 404 (Not Found)
                            i @ index.js:83
                            r @ index.js:83
                            r @ index.js:83
                            setInterval (async)
                            setTimeout (async)
                            i @ index.js:83
                            r @ index.js:83
                            r @ index.js:83
                            r @ index.js:83
                            r @ index.js:83
                            r @ index.js:83
                            init @ conn.js:266
                            main @ vis.js:3649
                            index.js:83          GET http://192.168.2.120:8082/socket.io/?key=nokey&EIO=3&transport=polling&t=OOy50P5 404 (Not Found)
                            i @ index.js:83
                            r @ index.js:83
                            r @ index.js:83
                            setInterval (async)
                            setTimeout (async)
                            i @ index.js:83
                            r @ index.js:83
                            r @ index.js:83
                            r @ index.js:83
                            r @ index.js:83
                            r @ index.js:83
                            init @ conn.js:266
                            main @ vis.js:3649
                            Mit dieser Web Adapter Einstellung, kann ich keine Routen speichern und bekomme unten angehängte Fehlermeldungen
                            VM106:410 Uncaught (in promise) SyntaxError: Expected double-quoted property name in JSON at position 247968
                               at vis.js:3630:29
                            a.add @ index.js:83
                            • carsten04
                              @oli Ich kümmere mich morgen darum, hab aber jetzt eine Idee woran es liegen könnte. Dein Token war ungültig, richtig?
                              • O
                                @carsten04
                                Ja, habe mir einen neuen geholt
                                • carsten04
                                  @oli @oxident Es gibt eine aktualisierte v1.0 auf GitHub. Bitte noch einmal neu installieren und vorher die Instanz und den Adapter sauber löschen. Ich habe an der socket-Konfiguration für den Adapter noch ein paar Änderungen vorgenommen und hoffe, dass es auch mit der VIS v1.4.15 jetzt läuft.
                                  O O 2 Replies Last reply Reply Quote 0
                                  • O
                                    @carsten04
                                    erstmal vielen Dank für deine Arbeit, die du hier investierst.
                                    Mit der neuen Version kann ich Routen anlegen, der Verbindungsfehler in der VIS ist weg, allerdings wir mir im Widget nichts angezeigt.
                                    Fehlermeldungen aus der Konsole:
                                    VM4404:410 Uncaught (in promise) SyntaxError: Expected double-quoted property name in JSON at position 247968
                                    radar-trap2.js:174 Uncaught TypeError: io is not a function
                                        at radar-trap2.js:174:15
                                        at SocketClient.findAnswer (socket.io.js:294:20)
                                        at socket.onmessage (socket.io.js:202:22)
                                    (anonym) @ radar-trap2.js:174
                                    SocketClient.findAnswer @ socket.io.js:294
                                    socket.onmessage @ socket.io.js:202
                                    radar-trap2.js:803 Uncaught (in promise) TypeError: Cannot read properties of null (reading 'get')
                                        at Object.initAsync (radar-trap2.js:803:20)
                                        at radar-trap2.js:776:42
                                        at sentryWrapped (helpers.ts:87:17)
                                    initAsync @ radar-trap2.js:803
                                    (anonym) @ radar-trap2.js:776
                                    • O
                                      @carsten04 Sorry, bei mir sieht's leider ganz anders aus. Mit der neuen Version (nur installiert, keine Instanz angelegt) startet VIS überhaupt nicht mehr.
                                      Habe dazu ein Issue angelegt...
                                      https://github.com/Steiger04/ioBroker.radar-trap2/issues/1
                                      • O
                                        Oli @oxident last edited by
                                        @oxident
                                        welche Einstellungen hast du im Web Adapter?
                                        • O
                                          oxident @Oli last edited by
                                          @oli Eigentlich ganz normal:
                                          Version ist 5.4.3
                                          • O
                                            @oxident
                                            versuche es mal, wenn bei "Reine Web-Sockets (iobroker.ws) verwenden" ein Haken drin ist, so funktioniert es bei mir
                                            31.7k
                                            79.8k
                                            251
                                            26465
