    • simatec
      simatec Developer Most Active @DK43 last edited by
      @dk43 ist der iobroker alleine gestartet oder musstest du händisch starten?
      DK43 1 Reply Last reply Reply Quote 0
      • DK43
        DK43 @simatec last edited by
        @simatec
        Noch vom Neustart mit dem Admin Ladebalken und dem händischen Ausführen von stopIOB.bat .
        Bin nach 20 minuten rübergewchselt zu Instanzen und da waren dann die Adapter vom alten system zu sehen.
        • simatec
          @dk43 Kannst du bitte den Restore nochmal mit der v2.5.12 testen?
          Hier sollte jetzt alles wieder funktionieren und auch das Webif für den restore sollte gehen.
          • DK43
            @simatec
            [DEBUG] [iobroker] Start ioBroker Restore ...
            [DEBUG] [iobroker] iobroker controller daemon is not running
            [DEBUG] [iobroker] host.DESKTOP-7L0AQ9E OK.
            [DEBUG] [iobroker] The current version of js-controller differs from the version in the backup.
            [DEBUG] [iobroker] The js-controller version of the backup can not be restored automatically.
            [DEBUG] [iobroker] Note, that your backup might differ in behavior due to this version change!
            [DEBUG] [iobroker] Removing current installation of iobroker.admin
            [DEBUG] [iobroker] removed 5 packages, and audited 823 packages in 5s
            [DEBUG] [iobroker] 51 packages are looking for funding
            [DEBUG] [iobroker] run `npm fund` for details
            [DEBUG] [iobroker] 32 vulnerabilities (22 moderate, 8 high, 2 critical)
            [DEBUG] [iobroker] To address issues that do not require attention, run:
            [DEBUG] [iobroker] npm audit fix
            [DEBUG] [iobroker] To address all issues (including breaking changes), run:
            [DEBUG] [iobroker] npm audit fix --force
            [DEBUG] [iobroker] Run `npm audit` for details.
            [DEBUG] [iobroker] Removing current installation of iobroker.backitup
            [DEBUG] [iobroker] removed 42 packages, and audited 781 packages in 5s
            [DEBUG] [iobroker] 50 packages are looking for funding
            [DEBUG] [iobroker] Removing current installation of iobroker.cloud
            [DEBUG] [iobroker] removed 29 packages, and audited 752 packages in 4s
            [DEBUG] [iobroker] 49 packages are looking for funding
            [DEBUG] [iobroker] 27 vulnerabilities (22 moderate, 5 high)
            [DEBUG] [iobroker] Removing current installation of iobroker.discovery
            [DEBUG] [iobroker] removed 15 packages, and audited 737 packages in 8s
            [DEBUG] [iobroker] 23 vulnerabilities (21 moderate, 2 high)
            [DEBUG] [iobroker] Removing current installation of iobroker.echarts
            [DEBUG] [iobroker] removed 5 packages, and audited 732 packages in 5s
            [DEBUG] [iobroker] Removing current installation of iobroker.heatingcontrol
            [DEBUG] [iobroker] removed 3 packages, and audited 729 packages in 5s
            [DEBUG] [iobroker] Removing current installation of iobroker.history
            [DEBUG] [iobroker] removed 1 package, and audited 728 packages in 5s
            [DEBUG] [iobroker] Removing current installation of iobroker.info
            [DEBUG] [iobroker] removed 4 packages, and audited 724 packages in 4s
            [DEBUG] [iobroker] 48 packages are looking for funding
            [DEBUG] [iobroker] Removing current installation of iobroker.iot
            [DEBUG] [iobroker] removed 119 packages, and audited 605 packages in 6s
            [DEBUG] [iobroker] 40 packages are looking for funding
            [DEBUG] [iobroker] 20 vulnerabilities (18 moderate, 2 high)
            [DEBUG] [iobroker] Removing current installation of iobroker.iqontrol
            [DEBUG] [iobroker] removed 1 package, and audited 604 packages in 4s
            [DEBUG] [iobroker] Removing current installation of iobroker.javascript
            [DEBUG] [iobroker] removed 23 packages, and audited 581 packages in 4s
            [DEBUG] [iobroker] 37 packages are looking for funding
            [DEBUG] [iobroker] Removing current installation of iobroker.mqtt
            [DEBUG] [iobroker] removed 64 packages, and audited 517 packages in 4s
            [DEBUG] [iobroker] 35 packages are looking for funding
            [DEBUG] [iobroker] Removing current installation of iobroker.pegelalarm
            [DEBUG] [iobroker] removed 2 packages, and audited 515 packages in 4s
            [DEBUG] [iobroker] Removing current installation of iobroker.simple-api
            [DEBUG] [iobroker] up to date, audited 515 packages in 3s
            [DEBUG] [iobroker] Removing current installation of iobroker.socketio
            [DEBUG] [iobroker] up to date, audited 515 packages in 4s
            [DEBUG] [iobroker] Removing current installation of iobroker.web
            [DEBUG] [iobroker] removed 120 packages, and audited 395 packages in 4s
            [DEBUG] [iobroker] 28 packages are looking for funding
            [DEBUG] [iobroker] 16 vulnerabilities (14 moderate, 2 high)
            [DEBUG] [iobroker] Removing current installation of iobroker.whatsapp-cmb
            [DEBUG] [iobroker] removed 1 package, and audited 394 packages in 5s
            [DEBUG] [iobroker] Removing current installation of iobroker.zigbee
            [DEBUG] [iobroker] removed 61 packages, and audited 333 packages in 3s
            [DEBUG] [iobroker] 13 packages are looking for funding
            [DEBUG] [iobroker] host.DESKTOP-7L0AQ9E Clear all objects and states...
            [DEBUG] [iobroker] clean 2226 objects...
            [DEBUG] [iobroker] clean 1484 states...
            [DEBUG] [iobroker] host.DESKTOP-7L0AQ9E done.
            [DEBUG] [iobroker] host.DESKTOP-7L0AQ9E Processed 0/2230 objects
            [DEBUG] [iobroker] host.DESKTOP-7L0AQ9E Processed 200/2230 objects
            [DEBUG] [iobroker] host.DESKTOP-7L0AQ9E Processed 400/2230 objects
            [DEBUG] [iobroker] host.DESKTOP-7L0AQ9E Processed 600/2230 objects
            [DEBUG] [iobroker] host.DESKTOP-7L0AQ9E Processed 800/2230 objects
            [DEBUG] [iobroker] host.DESKTOP-7L0AQ9E Processed 1000/2230 objects
            [DEBUG] [iobroker] host.DESKTOP-7L0AQ9E Processed 1200/2230 objects
            [DEBUG] [iobroker] host.DESKTOP-7L0AQ9E Processed 1400/2230 objects
            [DEBUG] [iobroker] host.DESKTOP-7L0AQ9E Processed 1600/2230 objects
            [DEBUG] [iobroker] host.DESKTOP-7L0AQ9E Processed 1800/2230 objects
            [DEBUG] [iobroker] host.DESKTOP-7L0AQ9E Processed 2000/2230 objects
            [DEBUG] [iobroker] host.DESKTOP-7L0AQ9E Processed 2200/2230 objects
            [DEBUG] [iobroker] 2230 objects restored.
            [DEBUG] [iobroker] host.DESKTOP-7L0AQ9E Processed 0/1484 states
            [DEBUG] [iobroker] host.DESKTOP-7L0AQ9E Processed 200/1484 states
            [DEBUG] [iobroker] host.DESKTOP-7L0AQ9E Processed 400/1484 states
            [DEBUG] [iobroker] host.DESKTOP-7L0AQ9E Processed 600/1484 states
            [DEBUG] [iobroker] host.DESKTOP-7L0AQ9E Processed 800/1484 states
            [DEBUG] [iobroker] host.DESKTOP-7L0AQ9E Processed 1000/1484 states
            [DEBUG] [iobroker] host.DESKTOP-7L0AQ9E Processed 1200/1484 states
            [DEBUG] [iobroker] host.DESKTOP-7L0AQ9E Processed 1400/1484 states
            [DEBUG] [iobroker] 1484 states restored.
            [DEBUG] [iobroker] host.DESKTOP-7L0AQ9E Upload user file "iqontrol.meta/userimages/usericons/90-103-41-1_219914_640x480_600x600.jpg
            [DEBUG] [iobroker] host.DESKTOP-7L0AQ9E Upload user file "iqontrol.meta/userimages/usericons/abGAS.png
            [DEBUG] [iobroker] host.DESKTOP-7L0AQ9E Upload user file "iqontrol.meta/userimages/usericons/aqara.jpg
            [DEBUG] [iobroker] host.DESKTOP-7L0AQ9E Upload user file "iqontrol.meta/userimages/usericons/automatik off.png
            [DEBUG] [iobroker] host.DESKTOP-7L0AQ9E Upload user file "iqontrol.meta/userimages/usericons/automatik on.png
            [DEBUG] [iobroker] host.DESKTOP-7L0AQ9E Upload user file "iqontrol.meta/userimages/usericons/eco off.png
            [DEBUG] [iobroker] host.DESKTOP-7L0AQ9E Upload user file "iqontrol.meta/userimages/usericons/eco.png
            [DEBUG] [iobroker] host.DESKTOP-7L0AQ9E Upload user file "iqontrol.meta/userimages/usericons/FBh.png
            [DEBUG] [iobroker] host.DESKTOP-7L0AQ9E Upload user file "iqontrol.meta/userimages/usericons/Rücklauf.png
            [DEBUG] [iobroker] host.DESKTOP-7L0AQ9E Upload user file "iqontrol.meta/userimages/usericons/Vorlauf.png
            [DEBUG] [iobroker] host.DESKTOP-7L0AQ9E Upload user file "iqontrol.meta/userimages/usericons/warmwasser.png
            [DEBUG] [iobroker] host.DESKTOP-7L0AQ9E Upload user file "iqontrol.meta/userimages/wallpaperbetter.jpg
            [DEBUG] [iobroker] Reinstalling adapter "admin" from "iobroker.admin@6.3.5"
            [DEBUG] [iobroker] added 78 packages, and audited 411 packages in 9s
            [DEBUG] [iobroker] 20 packages are looking for funding
            [DEBUG] [iobroker] Reinstalling adapter "backitup" from "iobroker.backitup@2.5.9"
            [DEBUG] [iobroker] added 71 packages, and audited 482 packages in 5s
            [DEBUG] [iobroker] 24 packages are looking for funding
            [DEBUG] [iobroker] Forced restore - executing setup ...
            [DEBUG] [iobroker] System successfully restored!
            [DEBUG] [iobroker] ioBroker Restore completed successfully
            [EXIT] 0 **** Restore completed successfully!! ****
            • simatec
              @dk43 Sieht gut aus... Startet der iobroker im Anschluss wieder neu?
              • DK43
                @simatec
                ja iobroker hat ohne Handeingriff selbständig gestartet. Zumindestens glaub ich das, weil nach ablauf der Zeit alles wie gewohnt verfügbar war
                • JB_Sullivan
                  JB_Sullivan last edited by JB_Sullivan
                  Nachdem die Tage im Latest eine BackitUp Version erschienen ist, die ein fehlerhaftes Restore unter Windows koorigieren sollte, habe ich auf meinem Testsystem mal ein Backup File mit der Adapter Version 2.5.12 eingespielt.
                  Hier das Log dazu:
                  [DEBUG] [iobroker] host.HobbyPC OK.
                  [DEBUG] [iobroker] removed 5 packages, and audited 550 packages in 7s
                  [DEBUG] [iobroker] run npm fund for details
                  [DEBUG] [iobroker] 18 vulnerabilities (16 moderate, 2 high)
                  [DEBUG] [iobroker] To address all issues possible (including breaking changes), run:
                  [DEBUG] [iobroker] Some issues need review, and may require choosing
                  [DEBUG] [iobroker] a different dependency.
                  [DEBUG] [iobroker] Run npm audit for details.
                  [DEBUG] [iobroker] removed 66 packages, and audited 484 packages in 4s
                  [DEBUG] [iobroker] removed 4 packages, and audited 480 packages in 3s
                  [DEBUG] [iobroker] 23 packages are looking for funding
                  [DEBUG] [iobroker] Removing current installation of iobroker.innogy-smarthome
                  [DEBUG] [iobroker] removed 14 packages, and audited 466 packages in 4s
                  [DEBUG] [iobroker] up to date, audited 466 packages in 3s
                  [DEBUG] [iobroker] up to date, audited 466 packages in 4s
                  [DEBUG] [iobroker] Removing current installation of iobroker.vis
                  [DEBUG] [iobroker] removed 2 packages, and audited 464 packages in 3s
                  [DEBUG] [iobroker] 17 vulnerabilities (15 moderate, 2 high)
                  [DEBUG] [iobroker] Removing current installation of iobroker.vis-2-beta
                  [DEBUG] [iobroker] removed 3 packages, and audited 461 packages in 4s
                  [DEBUG] [iobroker] Removing current installation of iobroker.vis-2-widgets-energy
                  [DEBUG] [iobroker] removed 1 package, and audited 460 packages in 3s
                  [DEBUG] [iobroker] Removing current installation of iobroker.vis-2-widgets-gauges
                  [DEBUG] [iobroker] removed 1 package, and audited 459 packages in 3s
                  [DEBUG] [iobroker] Removing current installation of iobroker.vis-2-widgets-material
                  [DEBUG] [iobroker] removed 1 package, and audited 458 packages in 3s
                  [DEBUG] [iobroker] removed 93 packages, and audited 365 packages in 4s
                  [DEBUG] [iobroker] Removing current installation of iobroker.ws
                  [DEBUG] [iobroker] removed 25 packages, and audited 340 packages in 3s
                  [DEBUG] [iobroker] 19 packages are looking for funding
                  [DEBUG] [iobroker] host.HobbyPC Clear all objects and states...
                  [DEBUG] [iobroker] clean 1195 objects...
                  [DEBUG] [iobroker] clean 989 states...
                  [DEBUG] [iobroker] host.HobbyPC done.
                  [DEBUG] [iobroker] host.HobbyPC Processed 0/27363 objects
                  [DEBUG] [iobroker] host.HobbyPC Processed 200/27363 objects
                  [DEBUG] [iobroker] host.HobbyPC Processed 400/27363 objects
                  [DEBUG] [iobroker] host.HobbyPC Processed 600/27363 objects
                  [DEBUG] [iobroker] host.HobbyPC Processed 800/27363 objects
                  [DEBUG] [iobroker] host.HobbyPC Processed 1000/27363 objects
                  [DEBUG] [iobroker] host.HobbyPC Processed 1200/27363 objects
                  [DEBUG] [iobroker] host.HobbyPC Processed 1400/27363 objects
                  [DEBUG] [iobroker] host.HobbyPC Processed 1600/27363 objects
                  [DEBUG] [iobroker] host.HobbyPC Processed 1800/27363 objects
                  [DEBUG] [iobroker] host.HobbyPC Processed 2000/27363 objects
                  [DEBUG] [iobroker] host.HobbyPC Processed 2200/27363 objects
                  [DEBUG] [iobroker] host.HobbyPC Processed 2400/27363 objects
                  [DEBUG] [iobroker] host.HobbyPC Processed 2600/27363 objects
                  [DEBUG] [iobroker] host.HobbyPC Processed 2800/27363 objects
                  [DEBUG] [iobroker] host.HobbyPC Processed 3000/27363 objects
                  [DEBUG] [iobroker] host.HobbyPC Processed 3200/27363 objects
                  [DEBUG] [iobroker] host.HobbyPC Processed 3400/27363 objects
                  [DEBUG] [iobroker] host.HobbyPC Processed 3600/27363 objects
                  [DEBUG] [iobroker] host.HobbyPC Processed 3800/27363 objects
                  [DEBUG] [iobroker] host.HobbyPC Processed 4000/27363 objects
                  [DEBUG] [iobroker] host.HobbyPC Processed 4200/27363 objects
                  [DEBUG] [iobroker] host.HobbyPC Processed 4400/27363 objects
                  [DEBUG] [iobroker] host.HobbyPC Processed 4600/27363 objects
                  [DEBUG] [iobroker] host.HobbyPC Processed 4800/27363 objects
                  [DEBUG] [iobroker] host.HobbyPC Processed 5000/27363 objects
                  [DEBUG] [iobroker] host.HobbyPC Processed 5200/27363 objects
                  [DEBUG] [iobroker] host.HobbyPC Processed 5400/27363 objects
                  [DEBUG] [iobroker] host.HobbyPC Processed 5600/27363 objects
                  [DEBUG] [iobroker] host.HobbyPC Processed 5800/27363 objects
                  [DEBUG] [iobroker] host.HobbyPC Processed 6000/27363 objects
                  [DEBUG] [iobroker] host.HobbyPC Processed 6200/27363 objects
                  [DEBUG] [iobroker] host.HobbyPC Processed 6400/27363 objects
                  [DEBUG] [iobroker] host.HobbyPC Processed 6600/27363 objects
                  [DEBUG] [iobroker] host.HobbyPC Processed 6800/27363 objects
                  [DEBUG] [iobroker] host.HobbyPC Processed 7000/27363 objects
                  [DEBUG] [iobroker] host.HobbyPC Processed 7200/27363 objects
                  [DEBUG] [iobroker] host.HobbyPC Processed 7400/27363 objects
                  [DEBUG] [iobroker] host.HobbyPC Processed 7600/27363 objects
                  [DEBUG] [iobroker] host.HobbyPC Processed 7800/27363 objects
                  [DEBUG] [iobroker] host.HobbyPC Processed 8000/27363 objects
                  [DEBUG] [iobroker] host.HobbyPC Processed 8200/27363 objects
                  [DEBUG] [iobroker] host.HobbyPC Processed 8400/27363 objects
                  [DEBUG] [iobroker] host.HobbyPC Processed 8600/27363 objects
                  [DEBUG] [iobroker] host.HobbyPC Processed 8800/27363 objects
                  [DEBUG] [iobroker] host.HobbyPC Processed 9000/27363 objects
                  [DEBUG] [iobroker] host.HobbyPC Processed 9200/27363 objects
                  [DEBUG] [iobroker] host.HobbyPC Processed 9400/27363 objects
                  [DEBUG] [iobroker] host.HobbyPC Processed 9600/27363 objects
                  [DEBUG] [iobroker] host.HobbyPC Processed 9800/27363 objects
                  [DEBUG] [iobroker] host.HobbyPC Processed 10000/27363 objects
                  [DEBUG] [iobroker] host.HobbyPC Processed 10200/27363 objects
                  [DEBUG] [iobroker] host.HobbyPC Processed 10400/27363 objects
                  [DEBUG] [iobroker] host.HobbyPC Processed 10600/27363 objects
                  [DEBUG] [iobroker] host.HobbyPC Processed 10800/27363 objects
                  [DEBUG] [iobroker] host.HobbyPC Processed 11000/27363 objects
                  [DEBUG] [iobroker] host.HobbyPC Processed 11200/27363 objects
                  [DEBUG] [iobroker] host.HobbyPC Processed 11400/27363 objects
                  [DEBUG] [iobroker] host.HobbyPC Processed 11600/27363 objects
                  [DEBUG] [iobroker] host.HobbyPC Processed 11800/27363 objects
                  [DEBUG] [iobroker] host.HobbyPC Processed 12000/27363 objects
                  [DEBUG] [iobroker] host.HobbyPC Processed 12200/27363 objects
                  [DEBUG] [iobroker] host.HobbyPC Processed 12400/27363 objects
                  [DEBUG] [iobroker] host.HobbyPC Processed 12600/27363 objects
                  [DEBUG] [iobroker] host.HobbyPC Processed 12800/27363 objects
                  [DEBUG] [iobroker] host.HobbyPC Processed 13000/27363 objects
                  [DEBUG] [iobroker] host.HobbyPC Processed 13200/27363 objects
                  [DEBUG] [iobroker] host.HobbyPC Processed 13400/27363 objects
                  [DEBUG] [iobroker] host.HobbyPC Processed 13600/27363 objects
                  [DEBUG] [iobroker] host.HobbyPC Processed 13800/27363 objects
                  [DEBUG] [iobroker] host.HobbyPC Processed 14000/27363 objects
                  [DEBUG] [iobroker] host.HobbyPC Processed 14200/27363 objects
                  [DEBUG] [iobroker] host.HobbyPC Processed 14400/27363 objects
                  [DEBUG] [iobroker] host.HobbyPC Processed 14600/27363 objects
                  [DEBUG] [iobroker] host.HobbyPC Processed 14800/27363 objects
                  [DEBUG] [iobroker] host.HobbyPC Processed 15000/27363 objects
                  [DEBUG] [iobroker] host.HobbyPC Processed 15200/27363 objects
                  [DEBUG] [iobroker] host.HobbyPC Processed 15400/27363 objects
                  [DEBUG] [iobroker] host.HobbyPC Processed 15600/27363 objects
                  [DEBUG] [iobroker] host.HobbyPC Processed 15800/27363 objects
                  [DEBUG] [iobroker] host.HobbyPC Processed 16000/27363 objects
                  [DEBUG] [iobroker] host.HobbyPC Processed 16200/27363 objects
                  [DEBUG] [iobroker] host.HobbyPC Processed 16400/27363 objects
                  [DEBUG] [iobroker] host.HobbyPC Processed 16600/27363 objects
                  [DEBUG] [iobroker] host.HobbyPC Processed 16800/27363 objects
                  [DEBUG] [iobroker] host.HobbyPC Processed 17000/27363 objects
                  [DEBUG] [iobroker] host.HobbyPC Processed 17200/27363 objects
                  [DEBUG] [iobroker] host.HobbyPC Processed 17400/27363 objects
                  [DEBUG] [iobroker] host.HobbyPC Processed 17600/27363 objects
                  [DEBUG] [iobroker] host.HobbyPC Processed 17800/27363 objects
                  [DEBUG] [iobroker] host.HobbyPC Processed 18000/27363 objects
                  [DEBUG] [iobroker] host.HobbyPC Processed 18200/27363 objects
                  [DEBUG] [iobroker] host.HobbyPC Processed 18400/27363 objects
                  [DEBUG] [iobroker] host.HobbyPC Processed 18600/27363 objects
                  [DEBUG] [iobroker] host.HobbyPC Processed 18800/27363 objects
                  [DEBUG] [iobroker] host.HobbyPC Processed 19000/27363 objects
                  [DEBUG] [iobroker] host.HobbyPC Processed 19200/27363 objects
                  [DEBUG] [iobroker] host.HobbyPC Processed 19400/27363 objects
                  [DEBUG] [iobroker] host.HobbyPC Processed 19600/27363 objects
                  [DEBUG] [iobroker] host.HobbyPC Processed 19800/27363 objects
                  [DEBUG] [iobroker] host.HobbyPC Processed 20000/27363 objects
                  [DEBUG] [iobroker] host.HobbyPC Processed 20200/27363 objects
                  [DEBUG] [iobroker] host.HobbyPC Processed 20400/27363 objects
                  [DEBUG] [iobroker] host.HobbyPC Processed 20600/27363 objects
                  [DEBUG] [iobroker] host.HobbyPC Processed 20800/27363 objects
                  [DEBUG] [iobroker] host.HobbyPC Processed 21000/27363 objects
                  [DEBUG] [iobroker] host.HobbyPC Processed 21200/27363 objects
                  [DEBUG] [iobroker] host.HobbyPC Processed 21400/27363 objects
                  [DEBUG] [iobroker] host.HobbyPC Processed 21600/27363 objects
                  [DEBUG] [iobroker] host.HobbyPC Processed 21800/27363 objects
                  [DEBUG] [iobroker] host.HobbyPC Processed 22000/27363 objects
                  [DEBUG] [iobroker] host.HobbyPC Processed 22200/27363 objects
                  [DEBUG] [iobroker] host.HobbyPC Processed 22400/27363 objects
                  [DEBUG] [iobroker] host.HobbyPC Processed 22600/27363 objects
                  [DEBUG] [iobroker] host.HobbyPC Processed 22800/27363 objects
                  [DEBUG] [iobroker] host.HobbyPC Processed 23000/27363 objects
                  [DEBUG] [iobroker] host.HobbyPC Processed 23200/27363 objects
                  [DEBUG] [iobroker] host.HobbyPC Processed 23400/27363 objects
                  [DEBUG] [iobroker] host.HobbyPC Processed 23600/27363 objects
                  [DEBUG] [iobroker] host.HobbyPC Processed 23800/27363 objects
                  [DEBUG] [iobroker] host.HobbyPC Processed 24000/27363 objects
                  [DEBUG] [iobroker] host.HobbyPC Processed 24200/27363 objects
                  [DEBUG] [iobroker] host.HobbyPC Processed 24400/27363 objects
                  [DEBUG] [iobroker] host.HobbyPC Processed 24600/27363 objects
                  [DEBUG] [iobroker] host.HobbyPC Processed 24800/27363 objects
                  [DEBUG] [iobroker] host.HobbyPC Processed 25000/27363 objects
                  [DEBUG] [iobroker] host.HobbyPC Processed 25200/27363 objects
                  [DEBUG] [iobroker] host.HobbyPC Processed 25400/27363 objects
                  [DEBUG] [iobroker] host.HobbyPC Processed 25600/27363 objects
                  [DEBUG] [iobroker] host.HobbyPC Processed 25800/27363 objects
                  [DEBUG] [iobroker] host.HobbyPC Processed 26000/27363 objects
                  [DEBUG] [iobroker] host.HobbyPC Processed 26200/27363 objects
                  [DEBUG] [iobroker] host.HobbyPC Processed 26400/27363 objects
                  [DEBUG] [iobroker] host.HobbyPC Processed 26600/27363 objects
                  [DEBUG] [iobroker] host.HobbyPC Processed 26800/27363 objects
                  [DEBUG] [iobroker] host.HobbyPC Processed 27000/27363 objects
                  [DEBUG] [iobroker] host.HobbyPC Processed 27200/27363 objects
                  [DEBUG] [iobroker] 27363 objects restored.
                  [DEBUG] [iobroker] host.HobbyPC Processed 0/25250 states
                  [DEBUG] [iobroker] host.HobbyPC Processed 200/25250 states
                  [DEBUG] [iobroker] host.HobbyPC Processed 400/25250 states
                  [DEBUG] [iobroker] host.HobbyPC Processed 600/25250 states
                  [DEBUG] [iobroker] host.HobbyPC Processed 800/25250 states
                  [DEBUG] [iobroker] host.HobbyPC Processed 1000/25250 states
                  [DEBUG] [iobroker] host.HobbyPC Processed 1200/25250 states
                  [DEBUG] [iobroker] host.HobbyPC Processed 1400/25250 states
                  [DEBUG] [iobroker] host.HobbyPC Processed 1600/25250 states
                  [DEBUG] [iobroker] host.HobbyPC Processed 1800/25250 states
                  [DEBUG] [iobroker] host.HobbyPC Processed 2000/25250 states
                  [DEBUG] [iobroker] host.HobbyPC Processed 2200/25250 states
                  [DEBUG] [iobroker] host.HobbyPC Processed 2400/25250 states
                  [DEBUG] [iobroker] host.HobbyPC Processed 2600/25250 states
                  [DEBUG] [iobroker] host.HobbyPC Processed 2800/25250 states
                  [DEBUG] [iobroker] host.HobbyPC Processed 3000/25250 states
                  [DEBUG] [iobroker] host.HobbyPC Processed 3200/25250 states
                  [DEBUG] [iobroker] host.HobbyPC Processed 3400/25250 states
                  [DEBUG] [iobroker] host.HobbyPC Processed 3600/25250 states
                  [DEBUG] [iobroker] host.HobbyPC Processed 3800/25250 states
                  [DEBUG] [iobroker] host.HobbyPC Processed 4000/25250 states
                  [DEBUG] [iobroker] host.HobbyPC Processed 4200/25250 states
                  [DEBUG] [iobroker] host.HobbyPC Processed 4400/25250 states
                  [DEBUG] [iobroker] host.HobbyPC Processed 4600/25250 states
                  [DEBUG] [iobroker] host.HobbyPC Processed 4800/25250 states
                  [DEBUG] [iobroker] host.HobbyPC Processed 5000/25250 states
                  [DEBUG] [iobroker] host.HobbyPC Processed 5200/25250 states
                  [DEBUG] [iobroker] host.HobbyPC Processed 5400/25250 states
                  [DEBUG] [iobroker] host.HobbyPC Processed 5600/25250 states
                  [DEBUG] [iobroker] host.HobbyPC Processed 5800/25250 states
                  [DEBUG] [iobroker] host.HobbyPC Processed 6000/25250 states
                  [DEBUG] [iobroker] host.HobbyPC Processed 6200/25250 states
                  [DEBUG] [iobroker] host.HobbyPC Processed 6400/25250 states
                  [DEBUG] [iobroker] host.HobbyPC Processed 6600/25250 states
                  [DEBUG] [iobroker] host.HobbyPC Processed 6800/25250 states
                  [DEBUG] [iobroker] host.HobbyPC Processed 7000/25250 states
                  [DEBUG] [iobroker] host.HobbyPC Processed 7200/25250 states
                  [DEBUG] [iobroker] host.HobbyPC Processed 7400/25250 states
                  [DEBUG] [iobroker] host.HobbyPC Processed 7600/25250 states
                  [DEBUG] [iobroker] host.HobbyPC Processed 7800/25250 states
                  [DEBUG] [iobroker] host.HobbyPC Processed 8000/25250 states
                  [DEBUG] [iobroker] host.HobbyPC Processed 8200/25250 states
                  [DEBUG] [iobroker] host.HobbyPC Processed 8400/25250 states
                  [DEBUG] [iobroker] host.HobbyPC Processed 8600/25250 states
                  [DEBUG] [iobroker] host.HobbyPC Processed 8800/25250 states
                  [DEBUG] [iobroker] host.HobbyPC Processed 9000/25250 states
                  [DEBUG] [iobroker] host.HobbyPC Processed 9200/25250 states
                  [DEBUG] [iobroker] host.HobbyPC Processed 9400/25250 states
                  [DEBUG] [iobroker] host.HobbyPC Processed 9600/25250 states
                  [DEBUG] [iobroker] host.HobbyPC Processed 9800/25250 states
                  [DEBUG] [iobroker] host.HobbyPC Processed 10000/25250 states
                  [DEBUG] [iobroker] host.HobbyPC Processed 10200/25250 states
                  [DEBUG] [iobroker] host.HobbyPC Processed 10400/25250 states
                  [DEBUG] [iobroker] host.HobbyPC Processed 10600/25250 states
                  [DEBUG] [iobroker] host.HobbyPC Processed 10800/25250 states
                  [DEBUG] [iobroker] host.HobbyPC Processed 11000/25250 states
                  [DEBUG] [iobroker] host.HobbyPC Processed 11200/25250 states
                  [DEBUG] [iobroker] host.HobbyPC Processed 11400/25250 states
                  [DEBUG] [iobroker] host.HobbyPC Processed 11600/25250 states
                  [DEBUG] [iobroker] host.HobbyPC Processed 11800/25250 states
                  [DEBUG] [iobroker] host.HobbyPC Processed 12000/25250 states
                  [DEBUG] [iobroker] host.HobbyPC Processed 12200/25250 states
                  [DEBUG] [iobroker] host.HobbyPC Processed 12400/25250 states
                  [DEBUG] [iobroker] host.HobbyPC Processed 12600/25250 states
                  [DEBUG] [iobroker] host.HobbyPC Processed 12800/25250 states
                  [DEBUG] [iobroker] host.HobbyPC Processed 13000/25250 states
                  [DEBUG] [iobroker] host.HobbyPC Processed 13200/25250 states
                  [DEBUG] [iobroker] host.HobbyPC Processed 13400/25250 states
                  [DEBUG] [iobroker] host.HobbyPC Processed 13600/25250 states
                  [DEBUG] [iobroker] host.HobbyPC Processed 13800/25250 states
                  [DEBUG] [iobroker] host.HobbyPC Processed 14000/25250 states
                  [DEBUG] [iobroker] host.HobbyPC Processed 14200/25250 states
                  [DEBUG] [iobroker] host.HobbyPC Processed 14400/25250 states
                  [DEBUG] [iobroker] host.HobbyPC Processed 14600/25250 states
                  [DEBUG] [iobroker] host.HobbyPC Processed 14800/25250 states
                  [DEBUG] [iobroker] host.HobbyPC Processed 15000/25250 states
                  [DEBUG] [iobroker] host.HobbyPC Processed 15200/25250 states
                  [DEBUG] [iobroker] host.HobbyPC Processed 15400/25250 states
                  [DEBUG] [iobroker] host.HobbyPC Processed 15600/25250 states
                  [DEBUG] [iobroker] host.HobbyPC Processed 15800/25250 states
                  [DEBUG] [iobroker] host.HobbyPC Processed 16000/25250 states
                  [DEBUG] [iobroker] host.HobbyPC Processed 16200/25250 states
                  [DEBUG] [iobroker] host.HobbyPC Processed 16400/25250 states
                  [DEBUG] [iobroker] host.HobbyPC Processed 16600/25250 states
                  [DEBUG] [iobroker] host.HobbyPC Processed 16800/25250 states
                  [DEBUG] [iobroker] host.HobbyPC Processed 17000/25250 states
                  [DEBUG] [iobroker] host.HobbyPC Processed 17200/25250 states
                  [DEBUG] [iobroker] host.HobbyPC Processed 17400/25250 states
                  [DEBUG] [iobroker] host.HobbyPC Processed 17600/25250 states
                  [DEBUG] [iobroker] host.HobbyPC Processed 17800/25250 states
                  [DEBUG] [iobroker] host.HobbyPC Processed 18000/25250 states
                  [DEBUG] [iobroker] host.HobbyPC Processed 18200/25250 states
                  [DEBUG] [iobroker] host.HobbyPC Processed 18400/25250 states
                  [DEBUG] [iobroker] host.HobbyPC Processed 18600/25250 states
                  [DEBUG] [iobroker] host.HobbyPC Processed 18800/25250 states
                  [DEBUG] [iobroker] host.HobbyPC Processed 19000/25250 states
                  [DEBUG] [iobroker] host.HobbyPC Processed 19200/25250 states
                  [DEBUG] [iobroker] host.HobbyPC Processed 19400/25250 states
                  [DEBUG] [iobroker] host.HobbyPC Processed 19600/25250 states
                  [DEBUG] [iobroker] host.HobbyPC Processed 19800/25250 states
                  [DEBUG] [iobroker] host.HobbyPC Processed 20000/25250 states
                  [DEBUG] [iobroker] host.HobbyPC Processed 20200/25250 states
                  [DEBUG] [iobroker] host.HobbyPC Processed 20400/25250 states
                  [DEBUG] [iobroker] host.HobbyPC Processed 20600/25250 states
                  [DEBUG] [iobroker] host.HobbyPC Processed 20800/25250 states
                  [DEBUG] [iobroker] host.HobbyPC Processed 21000/25250 states
                  [DEBUG] [iobroker] host.HobbyPC Processed 21200/25250 states
                  [DEBUG] [iobroker] host.HobbyPC Processed 21400/25250 states
                  [DEBUG] [iobroker] host.HobbyPC Processed 21600/25250 states
                  [DEBUG] [iobroker] host.HobbyPC Processed 21800/25250 states
                  [DEBUG] [iobroker] host.HobbyPC Processed 22000/25250 states
                  [DEBUG] [iobroker] host.HobbyPC Processed 22200/25250 states
                  [DEBUG] [iobroker] host.HobbyPC Processed 22400/25250 states
                  [DEBUG] [iobroker] host.HobbyPC Processed 22600/25250 states
                  [DEBUG] [iobroker] host.HobbyPC Processed 22800/25250 states
                  [DEBUG] [iobroker] host.HobbyPC Processed 23000/25250 states
                  [DEBUG] [iobroker] host.HobbyPC Processed 23200/25250 states
                  [DEBUG] [iobroker] host.HobbyPC Processed 23400/25250 states
                  [DEBUG] [iobroker] host.HobbyPC Processed 23600/25250 states
                  [DEBUG] [iobroker] host.HobbyPC Processed 23800/25250 states
                  [DEBUG] [iobroker] host.HobbyPC Processed 24000/25250 states
                  [DEBUG] [iobroker] host.HobbyPC Processed 24200/25250 states
                  [DEBUG] [iobroker] host.HobbyPC Processed 24400/25250 states
                  [DEBUG] [iobroker] host.HobbyPC Processed 24600/25250 states
                  [DEBUG] [iobroker] host.HobbyPC Processed 24800/25250 states
                  [DEBUG] [iobroker] host.HobbyPC Processed 25000/25250 states
                  [DEBUG] [iobroker] host.HobbyPC Processed 25200/25250 states
                  [DEBUG] [iobroker] 25250 states restored.
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "mihome-vacuum.0.userfiles//actualMap.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis/css/vis-common-user.css
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/daswetter/icons/wetter/1.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/daswetter/icons/wetter/10.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/daswetter/icons/wetter/11.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/daswetter/icons/wetter/12.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/daswetter/icons/wetter/13.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/daswetter/icons/wetter/14.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/daswetter/icons/wetter/15.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/daswetter/icons/wetter/16.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/daswetter/icons/wetter/17.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/daswetter/icons/wetter/18.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/daswetter/icons/wetter/19.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/daswetter/icons/wetter/2.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/daswetter/icons/wetter/20.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/daswetter/icons/wetter/3.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/daswetter/icons/wetter/4.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/daswetter/icons/wetter/5.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/daswetter/icons/wetter/6.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/daswetter/icons/wetter/7.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/daswetter/icons/wetter/8.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/daswetter/icons/wetter/9.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/daswetter/icons/windrose/g_rose000.gif
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/daswetter/icons/windrose/images 2.gif
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/1.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/11a.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/1553382003575-grünbeck2.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/2.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/2020-05-31 07_18_47-Rasensprenger Stock-Vektoren und -Grafiken - iStock.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/3.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/3D-Drucker.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/3dprinter.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/4.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/48394-skoda_standard_simple_black.jpg
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/5.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/6.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/617a.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/820a.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/871a.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/ac.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/achtung.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/Akku.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/alexa.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/alles_OK_trans.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/ampel1.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/audio_ff.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/audio_pause.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/audio_play.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/audio_repeat.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/audio_rew.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/audio_shuffle.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/audio_volume_high.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/audio_volume_low.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/audio_volume_mute.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/batterie_best1.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/Battery_-01.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/Battery_-02.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/Battery_-03.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/Battery_-04.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/Battery_-05.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/Battery_-06.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/Battery_-07.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/behaelter.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/BWM.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/cam.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/closed-filled-rectangular-door.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/coffee-machine.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/colorpicker.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/control_arrow_down.svg
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/control_arrow_downward.svg
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/control_building_control.svg
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/control_building_empty.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/control_cancel.svg
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/Disco.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/discoveryLogo1.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/DOT_Matrix.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/EasyMeter-Logo.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/EasyMeter-Logo2.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/EasyMeter.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/EasyMeter3.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/Eauto.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/Eauto2.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/Eauto2_1.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/Eauto3.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/Eauto4.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/eautoblitz.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/eBike.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/eisregen.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/electrical-threshold1.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/elektro.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/ElliOil.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/energie/2021.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/energie/2022.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/energy-meter.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/entriegelt.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/enyaq/assistance.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/enyaq/batterie.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/enyaq/body.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/enyaq/body_sunroof.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/enyaq/bremsen.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/enyaq/comfort.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/enyaq/door_front_left_closed_window_closed.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/enyaq/door_front_left_open_window_closed.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/enyaq/door_front_left_open_window_open.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/enyaq/door_front_right_closed_window_closed.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/enyaq/door_front_right_open_window_closed.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/enyaq/door_front_right_open_window_open.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/enyaq/door_rear_left_closed_window_closed.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/enyaq/door_rear_left_closed_window_open.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/enyaq/door_rear_left_open_window_closed.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/enyaq/door_rear_left_open_window_open.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/enyaq/door_rear_right_closed_window_close.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/enyaq/door_rear_right_open_window_closed.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/enyaq/door_rear_right_open_window_open.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/enyaq/engine_electric.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/enyaq/hood_open.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/enyaq/kofferraum_offen.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/enyaq/lights.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/enyaq/lights_left_on.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/enyaq/lights_right_on.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/enyaq/login-background.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/enyaq/nodata.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/enyaq/nodefect.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/enyaq/sonstiges.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/enyaq/status-ok.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/enyaq/sunroof_open.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/enyaq/tooltip.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/Enyaq2.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/Enyaq3.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/Enyaq4.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/fan3.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/Fire.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/frau.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/Friteuse.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/Fronius Logo.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/fronius.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/Frontscheibe.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/Frontscheibe_rot.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/fts_door.svg
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/fts_door_open.svg
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/fts_door_tilt.svg
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/fts_window_1w.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/fts_window_1w_open.svg
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/g6b_1.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/g6b_2.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/gabionenzaun1.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/garden.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/geoeffnet.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/geschirrspueler.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/gruenbeckww.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/heater3_white.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/Heckscheibe.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/Heckscheibe_rot.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/Home.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/icons8-garage-geschlossen-80.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/icons8-garage-offen-80.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/ic_add_circle_outline_white_48dp.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/ic_local_gas_station_white_48dp.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/ic_remove_circle_outline_white_48dp.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/images 2.gif
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/info_w.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/IoBroker.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/it_fax.svg
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/it_nas.svg
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/it_net.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/it_radio.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/it_remote.svg
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/it_telephone.svg
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/it_television.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/kabine.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/kabine_red.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/Kalender.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/Kanne.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/Kerze.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/Kerze_an.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/Kerze_aus.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/Klingel2.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/Klingel3.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/kugaicon.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/küche_w.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/Laterne2.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/Laterne_an.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/Laterne_aus.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/Laterne_Timer.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/light_ball.svg
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/light_dinner_table.svg
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/light_floor_lamp.svg
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/light_kitchen_hood.svg
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/light_led_stripe.svg
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/light_light_dim_00.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/Light_off.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/Light_on.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/light_stairs.svg
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/lowbattery.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/Luftreiniger_OFF.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/Luftreiniger_ON.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/Mail-closed.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/Mail-open.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/mann.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/markise rein.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/markise.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/measure_battery_0.svg
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/measure_battery_100.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/measure_battery_100.svg
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/measure_battery_25.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/measure_battery_25.svg
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/measure_battery_50.svg
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/measure_battery_75.svg
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/measure_photovoltaic_inst.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/measure_photovoltaic_inst.svg
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/Night.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/noun_socket_1135198.svg
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/OFF.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/Office.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/ON.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/Online.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/opened-filled-door.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/openWB+.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/outdoor-swimming-pool.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/outdoor-swimming-pool_wh.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/Paket.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/PC_Windows.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/plug.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/plug_red.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/power-line-with-four-insulators.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/Power.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/Power_socket_icon.svg
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/pv-anlage.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/pv2.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/pv_tanke.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/Rasensprenger.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/Rasensprenger4.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/raspberry.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/Robbikabel_6.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/roomba.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/roomba312.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/Rund_holiday_user8.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/Rund_Variable_user8.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/sani_cogeneration.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/sani_heating.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/sani_heating.svg
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/scene_bath.svg
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/scene_childs_room.svg
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/scene_cinema.svg
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/scene_garden.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/scene_kitchen_sink.svg
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/scene_living.svg
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/scene_livingroom.svg
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/scene_pool.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/scene_sleeping_alternat.svg
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/schloss_lock.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/schloss_lock_green.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/schloss_lock_wh.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/schloss_open_red.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/schloss_unlock.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/schloss_unlock_wh.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/schreibtischlampe.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/Shelly_2.5.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/Shelly_25.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/Shelly_Kueche.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/sitzheizung.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/sitzheizung_rot.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/skoda weiß1.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/skoda_logo.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/SmartMeter_001.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/Smoke.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/socket.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/solar-power-links.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/solar-power-rechts.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/sos.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/spotify.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/Springbrunnen.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/Spülmaschine.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/stadwerkePeine.jpg
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/steckdose.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/strom.svg
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/Suche.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/suncloud.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/Tannenbaum.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/TasmoAdmin.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/Tee.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/Tee2.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/temp2.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/Temperatur.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/Temperatur2.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/Temperatur3.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/temp_temperature.svg
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/temp_temperature_max.svg
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/temp_temperature_min.svg
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/temp_windchill.svg
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/text_max.svg
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/text_min.svg
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/timer.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/time_automatic.svg
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/time_manual_mode.svg
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/Tradfri Fernbedienung.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/trash.svg
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/trendicon.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/Trockner.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/tuerklingel.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/tuer_offen.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/tuer_offen_trans.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/typ2_green.jpg
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/typ2_green.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/typ2_red.jpg
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/typ2_red.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/typ2_white.jpg
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/typ2_white.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/ventilator.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/verschlossen.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/wall-e.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/wallbox.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/Wandlampen_an.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/Wandlampen_aus.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/waschmaschine.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/waterfall.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/weather_barometric_pressure.svg
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/weather_cloudy.svg
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/weather_cloudy_light.svg
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/weather_frost.svg
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/weather_humidity.svg
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/weather_rain.svg
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/weather_sunrise.svg
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/weather_wind_directions_e.svg
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/weather_wind_speed.svg
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/weather_wind_speed_bft.svg
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/weihnachtsbaum.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/window_closed.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/window_open.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/Zaehler1.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/icons/Zaehlergruen.png
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/Pool/Filter.svg
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/Pool/Heizung.svg
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/Pool/Pumpe.svg
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/Pool/Schieber_horizontal.svg
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/Pool/Schieber_vertikal.svg
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/vis-user.css
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0/main/vis-views.json
                  [DEBUG] [iobroker] host.HobbyPC Upload user file "vis.0//materialdesign.sentry
                  [DEBUG] [iobroker] added 75 packages, and audited 415 packages in 1m
                  [DEBUG] [iobroker] Reinstalling adapter "backitup" from "iobroker.backitup@2.5.12"
                  [DEBUG] [iobroker] added 71 packages, and audited 486 packages in 21s
                  [DEBUG] [iobroker] 27 packages are looking for funding
                  [EXIT] 0
                  Bis dahin sah es soweit gut aus. Dann kam jedoch etwas was mir vor ein paar Wochen bei einem Restore auch unter Linux passiert ist. Das Restore, welches von meinem Produktiv System stammt, wurde nicht an den neuen Host Namen angepasst. Folglich war der Admin nicht mehr erreichbar.
                  Ich habe dem Admin dann den Port 8089 verpasst und ich hatte wieder Zugriff - jedoch war die Position für den Hostnamen Leer. Ich bin dann wieder zurück auf 8081 und hatte eine weitere Admin Instanz, dieses mal aber mit dem Hostnamen des Restore System.
                  Wenn ich das letztes mal richtig verstanden haben, sollte der Hostname aber im Rahmen des Restore, auf den Namen des lokalen Systems angepasst werden - Richtig?
                  Jetzt ist das bei mir schon das zweite mal passiert - einmal unter Linux, einmal unter Windows. Wo könnte das Problem liegen?
                  C:\ioBroker>iobroker list instances
                    system.adapter.admin.0                  : admin                 : HobbyPC                                  -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                  + system.adapter.admin.2                  : admin                 : GLT(GLT)                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                  So, ich habe die Admin Instanzen jetzt mit einem iobroker host this gerade gezogen und habe gerade noch einmal ein erneutes Restore mit der gleichen Datei angestoßen. Mal schauen was jetzt passiert.
                  Das Log File ist schonmal wieder gleich - würde es hier ja posten, aber dann hat der Beitrag die 10.000 Zeichen Grenze überschritten.
                  Jetzt lassen wir mal die Adapter aktualisieren und gucken ob dieses mal der Hostname auf das Lokale System geändert wird.
                  • JB_Sullivan
                    JB_Sullivan @JB_Sullivan last edited by JB_Sullivan
                    So jetzt haben wir es wieder - das Restore hängt seit einer 1/4 Stunde an dieser Position fest - sorry, aber ich kann nur einen Screenshot posten, weil die "markieren" Funktion des Konsolen Fenster ebenfalls eingefroren ist.
                    Breche ich an dieser Stelle ab, habe ich vermutlich wieder das Hostnamen Problem. Das heißt für mich, das dass Backup, welches via BackitUp von meinem Produktivsystem erstellt wurde, irgend eine Besonderheit haben muss, was einen ordnungsgemäßen Restore nicht zuläßt - egal auf welcher Installation (Windows oder Linux) ich ioB aufgesetzt habe.
                    Genauso ist es - nach Abbruch kein Admin Zugriff mehr. Mit iobroker host this kommt man wieder auf den Admin drauf, wo nur 3 Adapter installiert sind, aber alle Instanz Namen in "grau" dort stehen.
                    Nach kuzer Zeit kann man im Konsolen Fenster mit iobroker logs --watch sehen, das dass Restore, bzw. der Download der Adapter fortgesetzt wird.
                    • simatec
                      simatec Developer Most Active @JB_Sullivan last edited by
                      @jb_sullivan
                      Ist doch normal, wenn sich der Hostname ändert.
                      Und das erst alle Adapter installieren ist auch logisch.
                      Was das hängen bleiben angeht, versuche mal den Restore über die CLI. Ist zwar der komplett identische Prozess, aber eventuell bekommt man da mehr an Fehlern angezeigt.
                      Sonst mal mit der Fehlermeldung mit der er hängen bleibt ein Issue im js-controller aufmachen
                      • JackDaniel
                        JackDaniel last edited by
                        Started iobroker ...
                        [DEBUG] [iobroker] - host.iobroker 45332 states saved
                        [DEBUG] [iobroker] - host.iobroker 35216 objects saved
                        [DEBUG] [iobroker] - Backup created: /opt/iobroker/backups/iobroker_2023_02_10-08_32_53_backupiobroker.tar.gz
                        [DEBUG] [iobroker] - done
                        [DEBUG] [influxDB] - InfluxDB-Backup started ...
                        [DEBUG] [influxDB] - Start InfluxDB Backup ...
                        [DEBUG] [influxDB] - InfluxDB Backup tmp directory created
                        [DEBUG] [influxDB] - Try deleting the InfluxDB tmp directory
                        [DEBUG] [influxDB] - InfluxDB tmp directory was successfully deleted
                        [ERROR] [influxDB] - Error: Command failed: influx backup --bucket iobroker -t influx auth list -t 1pRxyeDJKPVX_QkyLz-jiGerRGU43WBKyguqQJqTA4VVb1UmZWttZITeE5njbYQWrf5-Bd__-8u9tjQvryADPA== "/opt/iobroker/backups/influxDB_2023_02_10-08_33_06_backupiobroker"
                        Error: backup path must be specified as a single positional argument
                        was muss ich hier machen damit mein backup wieder funktioniert, danke im voraus
                          Thomas Braun Most Active last edited by
                          @jackdaniel sagte in Test Adapter ioBroker.backitup v2.5.x:
                          Das mal geprüft?
                          https://forum.iobroker.net/topic/57284/gelöst-backitup-error
                          • JackDaniel
                            JackDaniel last edited by JackDaniel
                            ja das hatte ich schon gefunden, der token passt zu 100% (hab extra einen neuen erstellt)
                            jackdaniel@iobroker:~$ influx auth list -t 1pRxyeDJKPVX_QkyLz-jiGerRGU43WBKyguqQJqTA4VVb1UmZWttZITeE5njbYQWrf5-Bd__-8u9tjQvryADPA==
                            ID                      Description     Token        User Name        User ID                 Permissions
                            0aba8d818e0ed000        iob backup      1pRxyeDJKPVX_QkyLz-jiGerRGU43WBKyguqQJqTA4VVb1UmZWttZITeE5njbYQWrf5-Bd__-8u9tjQvryADPA==        JackDaniel      0ab0654b30378000        [read:orgs/f101a4afa60bf046/annotations write:orgs/f101a4afa60bf046/annotations read:orgs/f101a4afa60bf046/authorizations write:orgs/f101a4afa60bf046/authorizations read:orgs/f101a4afa60bf046/buckets write:orgs/f101a4afa60bf046/buckets read:orgs/f101a4afa60bf046/checks write:orgs/f101a4afa60bf046/checks read:orgs/f101a4afa60bf046/dashboards write:orgs/f101a4afa60bf046/dashboards read:orgs/f101a4afa60bf046/dbrp write:orgs/f101a4afa60bf046/dbrp read:orgs/f101a4afa60bf046/documents write:orgs/f101a4afa60bf046/documents read:orgs/f101a4afa60bf046/labels write:orgs/f101a4afa60bf046/labels read:orgs/f101a4afa60bf046/notebooks write:orgs/f101a4afa60bf046/notebooks read:orgs/f101a4afa60bf046/notificationEndpoints write:orgs/f101a4afa60bf046/notificationEndpoints read:orgs/f101a4afa60bf046/notificationRules write:orgs/f101a4afa60bf046/notificationRules read:/orgs/f101a4afa60bf046 read:orgs/f101a4afa60bf046/remotes write:orgs/f101a4afa60bf046/remotes read:orgs/f101a4afa60bf046/replications write:orgs/f101a4afa60bf046/replications read:orgs/f101a4afa60bf046/scrapers write:orgs/f101a4afa60bf046/scrapers read:orgs/f101a4afa60bf046/secrets write:orgs/f101a4afa60bf046/secrets read:orgs/f101a4afa60bf046/sources write:orgs/f101a4afa60bf046/sources read:orgs/f101a4afa60bf046/tasks write:orgs/f101a4afa60bf046/tasks read:orgs/f101a4afa60bf046/telegrafs write:orgs/f101a4afa60bf046/telegrafs read:/users/0ab0654b30378000 write:/users/0ab0654b30378000 read:orgs/f101a4afa60bf046/variables write:orgs/f101a4afa60bf046/variables read:orgs/f101a4afa60bf046/views write:orgs/f101a4afa60bf046/views]
                            • simatec
                              simatec Developer Most Active @JackDaniel last edited by
                              [ERROR] [influxDB] - Error: Command failed: influx backup --bucket iobroker -t influx auth list -t 1pRxyeDJKPVX_QkyLz-jiGerRGU43WBKyguqQJqTA4VVb1UmZWttZITeE5njbYQWrf5-Bd__-8u9tjQvryADPA== "/opt/iobroker/backups/influxDB_2023_02_10-08_33_06_backupiobroker" Error: backup path must be specified as a single positional argument
                              Also das influx auth list -t hat im Token nichts zu suchen.
                              Da hast du sicher copy & paste gemacht
                              JackDaniel 1 Reply Last reply Reply Quote 0
                              • JackDaniel
                                JackDaniel @simatec last edited by
                                @simatec sagte in Test Adapter ioBroker.backitup v2.5.x:
                                sorry aber das ist die ausgabe wenn ich im admin ein backup manuell starte
                                was meinst du mit "sicher mit c&p gemacht" ?
                                Thomas Braun simatec 2 Replies Last reply Reply Quote 0
                                  Thomas Braun Most Active @JackDaniel last edited by
                                  @jackdaniel
                                  Zeig mal die Seite mit den Einstellungen in Backitup.
                                  • simatec
                                    @jackdaniel
                                    Du hast in der Config von Backitup folgenden Inhalt als Token gespeichert.
                                    Ändere das bitte mit dem reinen Token:
                                    • JackDaniel
                                      erledigt, nun bekomme ich wieder das
                                      [DEBUG] [iobroker] - host.iobroker 45451 states saved
                                      [DEBUG] [iobroker] - host.iobroker 35356 objects saved
                                      [DEBUG] [iobroker] - Backup created: /opt/iobroker/backups/iobroker_2023_02_10-13_11_48_backupiobroker.tar.gz
                                      [ERROR] [influxDB] - Error: Command failed: influx backup --bucket iobroker -t 1pRxyeDJKPVX_QkyLz-jiGerRGU43WBKyguqQJqTA4VVb1UmZWttZITeE5njbYQWrf5-Bd__-8u9tjQvryADPA== "/opt/iobroker/backups/influxDB_2023_02_10-13_12_02_backupiobroker"
                                      2023/02/10 13:12:02 INFO: Downloading metadata snapshot
                                      Error: failed to backup metadata: failed to download metadata snapshot: 401 Unauthorized: read:authorizations is unauthorized
                                      • simatec
                                        @jackdaniel Dann ist es wohl kein Admin Token...
                                        • simatec
                                          @jackdaniel Lese dir mal das hier durch ...
                                          https://forum.iobroker.net/post/929325
                                          • JackDaniel
                                            hmm da kann man(n) eigentlich nicht viel falsch machen ...
                                            1.0k
                                            170
                                            2780
                                            2386116
