    4. Test Adapter Device-Watcher v2.x.x GitHub/Latest
    • nik82
      nik82 Most Active @Guest last edited by
      @dp20eic
      Nein, Homematic Geräte haben nur eine Volt Anzeige, habe nur geradacht, dass über die verschiedenen Volt die % umgerechnet wird.
        A Former User @nik82 last edited by
        @nik82 das stimmt, leider hat Homematic nur Volt Angaben. Eine Umrechnung wäre auch viel zu aufwendig und ungenau wenn das Gerät das nativ nicht liefert.
          Kueppert last edited by
          anscheinend habe nur ich das Problem mit den Massen-Meldungen seit dem Update:
          device-watcher.0 2023-02-09 12:12:16.255	warn	State "device-watcher.0.adapterAndInstances.countInstancesError" has no existing object, this might lead to an error in future versions
          device-watcher.0 2023-02-09 12:12:16.241	warn	State "device-watcher.0.adapterAndInstances.listInstancesError" has no existing object, this might lead to an error in future versions
          device-watcher.0 2023-02-09 12:12:16.220	warn	State "device-watcher.0.adapterAndInstances.countDeactivatedInstances" has no existing object, this might lead to an error in future versions
          device-watcher.0 2023-02-09 12:12:16.173	warn	State "device-watcher.0.adapterAndInstances.listDeactivatedInstances" has no existing object, this might lead to an error in future versions
          device-watcher.0 2023-02-09 12:12:16.156	warn	State "device-watcher.0.adapterAndInstances.listAllInstances" has no existing object, this might lead to an error in future versions
          device-watcher.0 2023-02-09 12:12:16.135	warn	State "device-watcher.0.adapterAndInstances.countDeactivatedInstances" has no existing object, this might lead to an error in future versions
          device-watcher.0 2023-02-09 12:12:16.098	warn	State "device-watcher.0.adapterAndInstances.countAllInstances" has no existing object, this might lead to an error in future versions
          Ich habe schon den Objektbaum gelöscht und die Konfig vom Adapter neu gespeichert...
            A Former User @Kueppert last edited by
            @kueppert ja scheint so. Eigentlich reicht bei sowas Instanz stoppen, Ordner löschen, Instanz Neustarten dann baut er die Struktur neu auf. Welche Version ist es denn? Ist Instanz Listen erstellen aktiviert? Adapter schon mal komplett gelöscht und neu installiert? Aktuellste und stabilste Version auf npm ist 2.6.0
            K 2 Replies Last reply Reply Quote 0
              Kueppert @Guest last edited by
              @ciddi89 danke für die Rückmeldung.
              Instanz-Listen ist deaktiviert
              Version installiert ist die 2.6.0
              Adapter gestoppt - Objekt-Tree gelöscht - Instanz gestartet hab ich schon probiert.
              Ich exportiere heute mal die Einstellungen und installiere den Adapter neu.
                @ciddi89 hab noch nicht neu installiert, sondenr einfach "Instanzen beobachten" aktiviert. Seitdem keine Fehlermeldungen mehr...
                • David G.
                  David G. last edited by
                  So langsam kann der Adapter hier so viel, dass ich doch überlege meine eigenen Skripte (teilweise) in den Ruhestand zu schicken.
                  Allerdings habe ich noch 2-3 Fragen:
                  • Ist es möglich den Mqtt Adapter mit aufnehmen?
                  • Ist der LOWBAT Datenpunkt in der listAll-json sinnig zu integrieren? Dann lassen sich die Volt was besser auswerten.
                  • Ist es möglich in der listAll-json die Instanz der Geräte aufzunehmen? zB zigbee.0. Hab da eine Idee, wie man das schön in den Tabellen verwenden kann.
                    @kueppert ja du bist doch nicht der einzige. Werde nachher mal air Fehlersuche gehen. Gestern konnte ich es noch nicht reproduzieren 🤷‍♂️
                      A Former User @David G. last edited by
                      @david-g
                      Zu 1: jein. Ist halt schwierig weil jedes Gerät eine eigene Struktur hat und die Datenpunkte meist unterschiedlich heißen. Das einzige was man machen kann ist jeden Dienst für sich dann zu intrigieren so wie ich es bisher mit den Nuki lock und zigbee2mqtt gemacht hab. Außer jemand hat eine bessere Idee das zu vereinfachen. 🙂
                      Zu 2: Die listAll soll eine Übersicht aller Geräte sein egal wie die Batteriestände/Link quality und Status ist.
                      Zu 3: kann man. Intern ist die Instanz eh schon in der raw Liste gespeichert. Brauch es also nur noch abrufen. Aber werden die Listen dadurch nicht zu breit? Ist die Instanz eines Gerätes für den enduser wichtig zu wissen?
                      David G. W 2 Replies Last reply Reply Quote 0
                      • David G.
                        David G. @Guest last edited by David G.
                        @ciddi89 sagte in Test Adapter Device-Watcher v2.x.x GitHub/Latest:
                        Ich nutze mqtt hier für: https://github.com/jomjol/AI-on-the-edge-device
                        Sieht bei den Objekten Folgendermaßen aus:
                        In meiner geplanten Tabelle würde ich die Akkustände gerne farbig anpassen. Grün zu rot. Die Volt sind eben bei jedem Gerät anders (oder?, jenachdem welche Batterien) und nicht pauschal umsetzbar. Bei LOWBAT true und false könnte man einfach rot und grün nehmen.
                        Ich plane eine html Tabelle mit Blockly zu erstellen (mit 2-3 auswählbaren Ansichten). Anhand der Instanz kann man bei den Überschriften schön die Icons des Adapters abgreifen.
                        Die Tabelle wird hier selbstverständlich bereitgestellt ^^.
                        EDIT
                        Evtl könnte man ja eine listAll_raw oder so erstellen wo alle möglichen Infos zu den Geräten drinnen sind um diese mit eigenen Skripten zu verarbeiten.
                        Könnte dann zb die Instanz mit rein und zusätzlich ein boolischer Wert für die Batterie für Homatic (ggf auch für Geräte die % ausgeben mit definierbaren Schwllenwert in den Settings) und was einem noch so einfällt aber für eine normale Tabelle zu aufgeblasen wäre.
                          @david-g Werde mal gucken ob ich das mit dem mqtt mit reinbekomme. 🙂
                          Aah nun verstehe ich, ja das ist dann schwer zu definieren. Ich denke ein Object mit einer rawListe wäre erstmal ein Kompromiss. Das könnte man so machen. Damit die Standard Liste nicht zu sehr aufgeblasen wird. Viele wissen nicht wie man in einer Vis einzelne spalten usw. Ausblenden kann(falls es teilweise überhaupt möglich ist) daher möchte ich es den Enduser nicht all zu schwer machen.
                          Eigentlich spiele ich auch schon länger mit den Gedanken eine Auswahl zu erstellen wo der User selbst auswählen kann was in welcher Liste angezeigt werden soll. Aaaber ob sich der Aufwand lohnt ist eine andere Sache.
                          David G. da_Woody 2 Replies Last reply Reply Quote 0
                          • David G.
                            Vielen Dank
                            Cool, dann warte ich mal Geduld bis die raw Liste irgendwann kommt, ist ja denke keine Prio A Sache.
                            Bisher bin ich ja scheinbar der einzige mit dem Bedarf an so vielen Infos 😅
                            Wenn es dann so weit ist lege ich los ^^.
                            • da_Woody
                              da_Woody @Guest last edited by
                              bitte nicht vergessen, daß nicht jeder vis nutzt! ok, ich kann auch in iQontrol spalten ausblenden, ob das in anderen visus funzt?
                              • D3ltoroxp
                                D3ltoroxp last edited by
                                gibt es die Möglichkeit, die Liste absteigend anzeigen zu lassen, also die mit den meisten Tagen nach hinten und an erster stelle die als neustes verschwunden sind ? Grad die die lange nicht da sind, sind für den Poolbereich.
                                  Wildbill @Guest last edited by Wildbill
                                  @david-g
                                  Wäre es eine Idee, so ähnlich wie die Blacklist eben eine Whitelist mit aufzunehmen, in der man beliebige Datenpunkte aus der ganzen Objektstruktur auswählen kann, um diese zu überwachen? Eventuell mit einem selbst einzugebendem Sollzustand, bei dessen Eintreten dann eben Batterie leer oder nicht erreichbar angezeigt wird. So könnte jeder für sich selbst weitere Geräte/datenpunkte tracken, die eben nicht in einem der üblichen Adapter stecken, die Dein Adapter eh schon kennt und auswertet.
                                  Gruss, Jürgen
                                    A Former User @da_Woody last edited by
                                    @da_woody ja in Grafana geht das auch. Und ich glaube Jarvis auch. Naja trotzdem, die Standard Listen werde ich aus dem Grund nicht anfassen. Aber für welche die mehr wollen die bekommen eine raw Liste wo alle Daten drin stehen und dann kann jeder für sich die Listen so aufbauen und filtern wie einem lustig ist.
                                      A Former User @D3ltoroxp last edited by
                                      @d3ltoroxp hmm die meisten Visus können das so. Welche nutzt du genau?
                                      @Wildbill da ist was in der mache was das betrifft. Aber leider spielt die jsonconfig noch nicht so ganz mit und ich warte darauf das es gelöst wird. Schau hier: https://github.com/ciddi89/ioBroker.device-watcher/issues/84
                                      Scrounger created this issue in ciddi89/ioBroker.device-watcher
                                      open Feature: own structured devices #84
                                      D3ltoroxp 1 Reply Last reply Reply Quote 1
                                      • D3ltoroxp
                                        D3ltoroxp @Guest last edited by
                                        @ciddi89 ich nutze die Standard VIS und die Liste ist von Scrounger, also Material Design Widgets.
                                          @d3ltoroxp dann frag mal @Scrounger ob das Widget bzw. Vis seitig änderbar ist. Ich kann da leider nix zu sagen 😧
                                            A Former User @David G. last edited by A Former User
                                            @david-g kannst du damit was anfangen? (beachte nicht die Werte, das ist nur das Testsystem) =D
                                            Device:"BU_Licht"
                                            Adapter:"Zigbee2MQTT"
                                            Instance:"0_userdata.0"
                                            Instance connected:true
                                            isBatteryDevice:true
                                            Battery:"20%"
                                            isLowBat:true
                                            Signal strength:"69%"
                                            Last contact:"42 Tagen"
                                            Update Available:" - "
                                            Status:"Online"
                                            vielleicht könnte man die HTML Liste dann auch native in den Adapter implementieren? Eine listAllHTML fehlt noch. 😉
                                            1462
                                            500525
