    • JackDaniel
      JackDaniel last edited by
      Started iobroker ...
      [DEBUG] [iobroker] - host.iobroker 45332 states saved
      [DEBUG] [iobroker] - host.iobroker 35216 objects saved
      [DEBUG] [iobroker] - Backup created: /opt/iobroker/backups/iobroker_2023_02_10-08_32_53_backupiobroker.tar.gz
      [DEBUG] [iobroker] - done
      [DEBUG] [influxDB] - InfluxDB-Backup started ...
      [DEBUG] [influxDB] - Start InfluxDB Backup ...
      [DEBUG] [influxDB] - InfluxDB Backup tmp directory created
      [DEBUG] [influxDB] - Try deleting the InfluxDB tmp directory
      [DEBUG] [influxDB] - InfluxDB tmp directory was successfully deleted
      [ERROR] [influxDB] - Error: Command failed: influx backup --bucket iobroker -t influx auth list -t 1pRxyeDJKPVX_QkyLz-jiGerRGU43WBKyguqQJqTA4VVb1UmZWttZITeE5njbYQWrf5-Bd__-8u9tjQvryADPA== "/opt/iobroker/backups/influxDB_2023_02_10-08_33_06_backupiobroker"
      Error: backup path must be specified as a single positional argument
      was muss ich hier machen damit mein backup wieder funktioniert, danke im voraus
        Thomas Braun Most Active last edited by
        @jackdaniel sagte in Test Adapter ioBroker.backitup v2.5.x:
        Das mal geprüft?
        https://forum.iobroker.net/topic/57284/gelöst-backitup-error
        • JackDaniel
          JackDaniel last edited by JackDaniel
          ja das hatte ich schon gefunden, der token passt zu 100% (hab extra einen neuen erstellt)
          jackdaniel@iobroker:~$ influx auth list -t 1pRxyeDJKPVX_QkyLz-jiGerRGU43WBKyguqQJqTA4VVb1UmZWttZITeE5njbYQWrf5-Bd__-8u9tjQvryADPA==
          ID                      Description     Token        User Name        User ID                 Permissions
          0aba8d818e0ed000        iob backup      1pRxyeDJKPVX_QkyLz-jiGerRGU43WBKyguqQJqTA4VVb1UmZWttZITeE5njbYQWrf5-Bd__-8u9tjQvryADPA==        JackDaniel      0ab0654b30378000        [read:orgs/f101a4afa60bf046/annotations write:orgs/f101a4afa60bf046/annotations read:orgs/f101a4afa60bf046/authorizations write:orgs/f101a4afa60bf046/authorizations read:orgs/f101a4afa60bf046/buckets write:orgs/f101a4afa60bf046/buckets read:orgs/f101a4afa60bf046/checks write:orgs/f101a4afa60bf046/checks read:orgs/f101a4afa60bf046/dashboards write:orgs/f101a4afa60bf046/dashboards read:orgs/f101a4afa60bf046/dbrp write:orgs/f101a4afa60bf046/dbrp read:orgs/f101a4afa60bf046/documents write:orgs/f101a4afa60bf046/documents read:orgs/f101a4afa60bf046/labels write:orgs/f101a4afa60bf046/labels read:orgs/f101a4afa60bf046/notebooks write:orgs/f101a4afa60bf046/notebooks read:orgs/f101a4afa60bf046/notificationEndpoints write:orgs/f101a4afa60bf046/notificationEndpoints read:orgs/f101a4afa60bf046/notificationRules write:orgs/f101a4afa60bf046/notificationRules read:/orgs/f101a4afa60bf046 read:orgs/f101a4afa60bf046/remotes write:orgs/f101a4afa60bf046/remotes read:orgs/f101a4afa60bf046/replications write:orgs/f101a4afa60bf046/replications read:orgs/f101a4afa60bf046/scrapers write:orgs/f101a4afa60bf046/scrapers read:orgs/f101a4afa60bf046/secrets write:orgs/f101a4afa60bf046/secrets read:orgs/f101a4afa60bf046/sources write:orgs/f101a4afa60bf046/sources read:orgs/f101a4afa60bf046/tasks write:orgs/f101a4afa60bf046/tasks read:orgs/f101a4afa60bf046/telegrafs write:orgs/f101a4afa60bf046/telegrafs read:/users/0ab0654b30378000 write:/users/0ab0654b30378000 read:orgs/f101a4afa60bf046/variables write:orgs/f101a4afa60bf046/variables read:orgs/f101a4afa60bf046/views write:orgs/f101a4afa60bf046/views]
          • simatec
            simatec Developer Most Active @JackDaniel last edited by
            [ERROR] [influxDB] - Error: Command failed: influx backup --bucket iobroker -t influx auth list -t 1pRxyeDJKPVX_QkyLz-jiGerRGU43WBKyguqQJqTA4VVb1UmZWttZITeE5njbYQWrf5-Bd__-8u9tjQvryADPA== "/opt/iobroker/backups/influxDB_2023_02_10-08_33_06_backupiobroker" Error: backup path must be specified as a single positional argument
            Also das influx auth list -t hat im Token nichts zu suchen.
            Da hast du sicher copy & paste gemacht
            JackDaniel 1 Reply Last reply Reply Quote 0
            • JackDaniel
              JackDaniel @simatec last edited by
              @simatec sagte in Test Adapter ioBroker.backitup v2.5.x:
              sorry aber das ist die ausgabe wenn ich im admin ein backup manuell starte
              was meinst du mit "sicher mit c&p gemacht" ?
              Thomas Braun simatec 2 Replies Last reply Reply Quote 0
                Thomas Braun Most Active @JackDaniel last edited by
                @jackdaniel
                Zeig mal die Seite mit den Einstellungen in Backitup.
                • simatec
                  @jackdaniel
                  Du hast in der Config von Backitup folgenden Inhalt als Token gespeichert.
                  Ändere das bitte mit dem reinen Token:
                  • JackDaniel
                    erledigt, nun bekomme ich wieder das
                    [DEBUG] [iobroker] - host.iobroker 45451 states saved
                    [DEBUG] [iobroker] - host.iobroker 35356 objects saved
                    [DEBUG] [iobroker] - Backup created: /opt/iobroker/backups/iobroker_2023_02_10-13_11_48_backupiobroker.tar.gz
                    [ERROR] [influxDB] - Error: Command failed: influx backup --bucket iobroker -t 1pRxyeDJKPVX_QkyLz-jiGerRGU43WBKyguqQJqTA4VVb1UmZWttZITeE5njbYQWrf5-Bd__-8u9tjQvryADPA== "/opt/iobroker/backups/influxDB_2023_02_10-13_12_02_backupiobroker"
                    2023/02/10 13:12:02 INFO: Downloading metadata snapshot
                    Error: failed to backup metadata: failed to download metadata snapshot: 401 Unauthorized: read:authorizations is unauthorized
                    • simatec
                      @jackdaniel Dann ist es wohl kein Admin Token...
                      • simatec
                        @jackdaniel Lese dir mal das hier durch ...
                        https://forum.iobroker.net/post/929325
                        • JackDaniel
                          hmm da kann man(n) eigentlich nicht viel falsch machen ...
                          • JackDaniel
                            mach ich morgen, hab heute leider keine zeit 😞
                            • simatec
                              @jackdaniel
                              Mit welchem User bist du eingeloggt?
                              Lies da mal in der Doku. Denke der Token muss definitiv mit dem Admin Account erstellt werden.
                              Hier gab es dazu auch einen Thread
                              • simatec
                                simatec Developer Most Active last edited by simatec
                                Ab sofort steht auf Github und in kürze auch im latest die Version 2.6.0 zum testen bereit.
                                Changelog
                                2.6.0 (2023-02-16)
                                • (simatec) Onedrive-Api added
                                • (simatec) Matrix Messenger added
                                • (simatec) TLS for FTP added
                                • (simatec) Tab Extra-Settings added
                                • (simatec) Node-Red Backup added
                                • (simatec) SQLLite Backup added
                                • (simatec) Zigbee2MQTT Backup added
                                • (simatec) Local-Storage check added
                                • (simatec) System-Message added
                                • (simatec) Jarvis Backup updated
                                • (simatec) many small Fixes
                                J 1 Reply Last reply Reply Quote 2
                                  jay-jey @simatec last edited by
                                  @simatec Hallo ich wollte jetzt mal das Backup auf Onedrive testen. Aber ich bekomme dabei einen immer einen Fehler. Irgendwas wird getan, weil im Onedrive werden Dateien angelegt aber nur kleine mit 8KB
                                  hier mal das Ende vom Log:
                                  [DEBUG] [grafana] - found Dashboard: heizung
                                  [DEBUG] [grafana] - start Grafana backup compress ...
                                  [DEBUG] [grafana] - Backup created: /opt/iobroker/backups/grafana_2023_02_24-07_32_50_backupiobroker.tar.gz
                                  [DEBUG] [grafana] - Try deleting the Grafana tmp directory: "/opt/iobroker/backups/grafana_tmp"
                                  [DEBUG] [grafana] - Grafana tmp directory "/opt/iobroker/backups/grafana_tmp" successfully deleted
                                  [DEBUG] [grafana] - done
                                  [DEBUG] [onedrive] - Onedrive: Copy iobroker_2023_02_24-07_31_49_backupiobroker.tar.gz...
                                  [ERROR] [onedrive] - upload Onedrive: {"name":"HTTPError","code":"ERR_NON_2XX_3XX_RESPONSE","timings":{"start":1677220377193,"socket":1677220377194,"lookup":1677220377206,"connect":1677220377228,"secureConnect":1677220377280,"upload":1677220401641,"response":1677220402872,"end":1677220402876,"phases":{"wait":1,"dns":12,"tcp":22,"tls":52,"request":24361,"firstByte":1231,"download":4,"total":25683}}}
                                  [DEBUG] [onedrive] - Onedrive: Copy influxDB_2023_02_24-07_32_21_backupiobroker.tar.gz...
                                  [ERROR] [onedrive] - upload Onedrive: {"name":"HTTPError","code":"ERR_NON_2XX_3XX_RESPONSE","timings":{"start":1677220402896,"socket":1677220402897,"lookup":1677220402909,"connect":1677220402931,"secureConnect":1677220402984,"upload":1677220440784,"response":1677220445642,"end":1677220445647,"phases":{"wait":1,"dns":12,"tcp":22,"tls":53,"request":37800,"firstByte":4858,"download":5,"total":42751}}}
                                  [DEBUG] [onedrive] - Onedrive: Copy zigbee.0_2023_02_24-07_32_49_backupiobroker.tar.gz...
                                  [DEBUG] [onedrive] - zigbee.0_2023_02_24-07_32_49_backupiobroker.tar.gz with Id: 8EAB853A46DB9335!145904 saved on Onedrive
                                  [DEBUG] [onedrive] - Onedrive: Copy zigbee.1_2023_02_24-07_32_49_backupiobroker.tar.gz...
                                  [DEBUG] [onedrive] - zigbee.1_2023_02_24-07_32_49_backupiobroker.tar.gz with Id: 8EAB853A46DB9335!145905 saved on Onedrive
                                  [DEBUG] [onedrive] - Onedrive: Copy zigbee.2_2023_02_24-07_32_49_backupiobroker.tar.gz...
                                  [DEBUG] [onedrive] - zigbee.2_2023_02_24-07_32_49_backupiobroker.tar.gz with Id: 8EAB853A46DB9335!145906 saved on Onedrive
                                  [DEBUG] [onedrive] - Onedrive: Copy grafana_2023_02_24-07_32_50_backupiobroker.tar.gz...
                                  [DEBUG] [onedrive] - grafana_2023_02_24-07_32_50_backupiobroker.tar.gz with Id: 8EAB853A46DB9335!145907 saved on Onedrive
                                  [DEBUG] [onedrive] - done
                                  [ERROR] [clean] - Backup files not deleted from /opt/iobroker/backups because some errors.
                                  [DEBUG] [clean] - done
                                  [DEBUG] [historyHTML] - new history html values created
                                  [DEBUG] [historyHTML] - done
                                  [DEBUG] [historyJSON] - new history json values created
                                  [DEBUG] [historyJSON] - done
                                  [EXIT] 0
                                  • simatec
                                    simatec Developer Most Active @jay-jey last edited by
                                    @jay-jey Wie groß sind denn deinen Backup Files für iobroker und Influx?
                                      @simatec Hallo, danke für die promte Antwort. So schnell hab ich nicht damit gerechnet, daher jetzt erst: Also das Iobroker ist 113mb und Influx ist 180mb
                                      • simatec
                                        @jay-jey Speicherplatz in der Onedrive ist genug vorhanden?
                                        Ich schaue mir das mal an, ob es in der Onedrive Api da Begrenzungen gibt. Mir ist erstmal nichts bekannt.
                                          @simatec Ja noch mehr als 600Gb. 218ea906-219d-4f3c-a1ea-03d7a09b521b-grafik.png
                                          • simatec
                                            simatec Developer Most Active @jay-jey last edited by simatec
                                            @jay-jey Teste mal bitte die v.2.6.4.
                                            Dort habe ich umgestellt auf eine Upload-Session.
                                            Sollte damit auch möglich sein, größere Files hochzuladen
                                            170
                                            2780
                                            2363872
