    4. Test Adapter eufy Home Robovac
      tombox @emptykai last edited by
      @emptykai Ja dann muss er ja schon beim adapter start ein Fehler wegen der ip zeigen
        emptykai @tombox last edited by
        @tombox habe den Adapter mal neugestartet
        euhome.0
        	6654	2023-02-10 11:01:14.675	info	Device: Sauger (bfee2150a08c0ff746anta)
        euhome.0
        	6654	2023-02-10 11:01:14.675	info	Found 1 devices
        euhome.0
        	6654	2023-02-10 11:00:52.793	info	Login successful
        euhome.0
        	6654	2023-02-10 11:00:51.864	info	Login to Eufy Home
        euhome.0
        	6654	2023-02-10 11:00:51.844	info	starting. Version 0.0.3 (non-npm: TA2k/ioBroker.euhome#f94964ce32a8d0ef5e388462990840bafa67cc27) in /opt/iobroker/node_modules/iobroker.euhome, node: v14.20.0, js-controller: 4.0.23
        host.iobroker-iobroker1
        		2023-02-10 11:00:50.729	info	instance system.adapter.euhome.0 started with pid 6654
        		2023-02-10 11:00:50.666	info	"system.adapter.euhome.0" enabled
        		2023-02-10 11:00:49.655	info	instance system.adapter.euhome.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
        		2023-02-10 11:00:49.158	info	stopInstance system.adapter.euhome.0 send kill signal
        euhome.0
        	6331	2023-02-10 11:00:49.120	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
        euhome.0
        	6331	2023-02-10 11:00:49.120	info	terminating
        euhome.0
        	6331	2023-02-10 11:00:49.118	info	Got terminate signal TERMINATE_YOURSELF
        		2023-02-10 11:00:49.114	info	stopInstance system.adapter.euhome.0 (force=false, process=true)
        wenn ich dann nochaml den status ändere von work_mode dann kommt das hier:
        euhome.0
        	6654	2023-02-10 11:01:15.335	error	No IP found for bfee2150a08c0ff746anta cannot send command
        euhome.0
        	6654	2023-02-10 11:01:15.205	error	Failed to find to device please close the app or check your network. Please allow port 6667 and 6666 via UDP from the device IP to 255.255.255.255. Error: bind EADDRINUSE 0.0.0.0:6666
        euhome.0
        	6654	2023-02-10 11:01:15.204	error	Error All! Error: bind EADDRINUSE 0.0.0.0:6666
          @emptykai Irgendwas blockiert port 6666 hast du den tuya adapter am laufen? Vielleicht mal iobroker neustarten
          E 2 Replies Last reply Reply Quote 0
            @tombox habs gesehen gerade.. Ja habe Tuya laufen - aber die ports sind freigeschaltet .. ich starte mal neu und schaue dann nochaml
              @tombox trotz neustart, gleicher Port Fehler.. wodran kann das liegen?
              Die ports sind frei
              Thomas Braun T 2 Replies Last reply Reply Quote 0
                Thomas Braun Most Active @emptykai last edited by Thomas Braun
                @emptykai sagte in Test Adapter eufy Home Robovac:
                Die ports sind frei
                sudo netstat -tulpen
                anschauen.
                Alternativ
                sudo ss -tulpe
                  @emptykai Mal den tuya adapter abschalten und euhome neustarten ob es dann geht
                    emptykai @Thomas Braun last edited by
                    @thomas-braun was bewirkt das?
                      emptykai @tombox last edited by emptykai
                      @tombox Hey, ja dann funktioniert es (Y) - aber stoppen kann ich nicht mehr?
                        was bewirkt das?
                        Dein Computer explodiert und die Katze stirbt...
                        Es werden die verwendeten Sockets / Ports aufgelistet.
                          @emptykai Ok ich werde noch einbauen das man manuell eine IP setzen kann
                            @tombox okay, aber aktuell kann ich den sauger nicht stoppen, korrekt?
                              @emptykai Entweder GO_HOME oder PLAYPAUSE
                                @tombox klasse, klappt 🙂
                                  madman1602 last edited by
                                  Hey , das ist ja ganz hervorragend , dass du diesen Adapter in Angriff genommen hast. War einwandfrei zu installieren und hat meinen Eufy auch tadellos gefunden.
                                  Ich scheine aber das gleiche Problem mit dem Tuya Adapter zu haben wenn der auch läuft.
                                  Gibt es da einen Workaround o.Ä. um die Port Problematik zu beheben oder kannst du eine Möglichkeit schaffen den Port zu wechseln ?! Vielen Dank für die Arbeit 👍
                                  Gruß mad
                                    theRay2K @tombox last edited by
                                    @tombox Guten Abend, vielen Dank für deinen Adapter! Ich habe diesen Adapter inzwischen seit einigen Wochen in Nutzung und bin super zufrieden. Leider habe ich seit etwa 2-3 Tagen erhebliche Probleme mit dem Adapter. Ich kriege fast minütlich im Protokoll den Error:
                                    2023-07-17 20:43:14.889 - error: euhome.0 (694904) Error! Error: Error from socket: read ECONNRESET
                                    2023-07-17 20:43:44.944 - error: euhome.0 (694904) Error! Error: Error from socket: read ECONNRESET
                                    2023-07-17 20:44:14.960 - error: euhome.0 (694904) Error! Error: Error from socket: read ECONNRESET
                                    2023-07-17 20:44:44.986 - error: euhome.0 (694904) Error! Error: Error from socket: read ECONNRESET
                                    2023-07-17 20:45:15.549 - error: euhome.0 (694904) Error! Error: Error from socket: read ECONNRESET
                                    2023-07-17 20:45:45.760 - error: euhome.0 (694904) Error! Error: Error from socket: read ECONNRESET
                                    2023-07-17 20:46:15.835 - error: euhome.0 (694904) Error! Error: Error from socket: read ECONNRESET
                                    2023-07-17 20:46:45.890 - error: euhome.0 (694904) Error! Error: Error from socket: read ECONNRESET
                                    2023-07-17 20:47:16.671 - error: euhome.0 (694904) Error! Error: Error from socket: read ECONNRESET
                                    2023-07-17 20:47:46.963 - error: euhome.0 (694904) Error! Error: Error from socket: read ECONNRESET
                                    2023-07-17 20:48:17.133 - error: euhome.0 (694904) Error! Error: Error from socket: read ECONNRESET
                                    2023-07-17 20:48:47.194 - error: euhome.0 (694904) Error! Error: Error from socket: read ECONNRESET
                                    2023-07-17 20:49:17.252 - error: euhome.0 (694904) Error! Error: Error from socket: read ECONNRESET
                                    2023-07-17 20:49:47.270 - error: euhome.0 (694904) Error! Error: Error from socket: read ECONNRESET
                                    2023-07-17 20:50:17.289 - error: euhome.0 (694904) Error! Error: Error from socket: read ECONNRESET
                                    2023-07-17 20:50:47.307 - error: euhome.0 (694904) Error! Error: Error from socket: read ECONNRESET
                                    2023-07-17 20:51:17.339 - error: euhome.0 (694904) Error! Error: Error from socket: read ECONNRESET
                                    2023-07-17 20:51:47.359 - error: euhome.0 (694904) Error! Error: Error from socket: read ECONNRESET
                                    2023-07-17 20:52:17.374 - error: euhome.0 (694904) Error! Error: Error from socket: read ECONNRESET
                                    2023-07-17 20:52:47.401 - error: euhome.0 (694904) Error! Error: Error from socket: read ECONNRESET
                                    2023-07-17 20:53:17.422 - error: euhome.0 (694904) Error! Error: Error from socket: read ECONNRESET
                                    Ist das Problem bekannt und gibt es dazu Abhilfe?
                                    • DJMarc75
                                      DJMarc75 @theRay2K last edited by
                                      @theray2k sagte in Test Adapter eufy Home Robovac:
                                      und was hast Du an Deinem System "seit etwa 2-3 Tagen" geändert?
                                        theRay2K @DJMarc75 last edited by
                                        @djmarc75 Das einzige was geändert wurde, dass ein Script den Saugrobotor 1x täglich startet sobald das Haus verlassen wurde. Ich hatte das Problem aber auch zwischendurch schon ein paar mal bevor ich etwas hinzugefügt habe, aber nicht in dem Ausmaß wie inzwischen. Sonst hatte ich dieses Problem vereinzelnd im Log stehen. Ein Neustart des Adapters hat dann aber Abhilfe für etwa 1 Woche geschaffen. Nur ist dieses Problem inzwischen etwa jeden morgen, was natürlich relativ nervenaufreibend ist, wenn jeden morgen der Adapter neu gestartet werden muss. Zum Abgleich füge ich einfach mal das Script hinzu, welches über Blockly hinzugefügt wurde:
                                        var T_C3_A4gliche_Reinigung, heute_gereinigt, Kurzes_verlassen;
                                        T_C3_A4gliche_Reinigung = schedule('{"time":{"exactTime":true,"start":"23:59"},"period":{"days":1}}', async () => {
                                          heute_gereinigt = false;
                                        on({ id: '0_userdata.0.Alarmanlage_S/US' /* Alarmanlage S/US */, change: 'ne'  }, async (obj) => {
                                          let value = obj.state.val;
                                          if (getState('0_userdata.0.Alarmanlage_S/US').val == true && heute_gereinigt == false) {
                                            Kurzes_verlassen = setTimeout(async () => {
                                              Kurzes_verlassen = null;
                                              heute_gereinigt = true;
                                              setStateDelayed('0_userdata.0.Robovac-State', true, true, parseInt(((0) || '').toString(), 10), false);
                                              (() => { if (Kurzes_verlassen) { clearTimeout(Kurzes_verlassen); Kurzes_verlassen = null; }})();
                                            }, 900000);
                                          } else {
                                            setStateDelayed('0_userdata.0.Robovac-State', false, true, parseInt(((0) || '').toString(), 10), false);
                                          Chris982 last edited by
                                          Guten Morgen,
                                          hat schon jemand den Eufy RoboVac X9 Pro am laufen? Habe ihn zwar in Euhome drin, finde keinen Datenpunkt um die Reinigung starten zu könnnen.
                                          • Smilie108
                                            Smilie108 last edited by
                                            Hi
                                            Erstmal vielen Dank an den Adapter.
                                            Wollte mal fragen ob es eine lösung wegen der tuya und eufy port schwierigkeiten gibt ? wenn ich tuya deaktiviere dann bekommt eufy die ports wenn ich tuya dann wieder aktiviere sind beide tot 😉
                                            Danke im voraus
                                            31.7k
                                            79.8k
                                            142
                                            13649
