    4. JavaScript
    5. Roborock Adapter tester gesucht
    • Codierknecht
      Codierknecht Developer Most Active @copystring last edited by
      @copystring
      Die 0.0.8 läuft bei mir nicht (S7+).
      Habe den Adapter komplett deinstalliert und neu installiert - keine Besserung.
      roborock.0
      	2023-02-09 19:25:41.295	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
      roborock.0
      	2023-02-09 19:25:41.294	info	terminating
      roborock.0
      	2023-02-09 19:25:41.292	error	Cannot read properties of null (reading 'val')
      roborock.0
      	2023-02-09 19:25:41.291	error	TypeError: Cannot read properties of null (reading 'val') at Roborock.onReady (/opt/iobroker/node_modules/iobroker.roborock/main.js:218:22)
      roborock.0
      	2023-02-09 19:25:41.290	error	unhandled promise rejection: Cannot read properties of null (reading 'val')
      roborock.0
      	2023-02-09 19:25:41.289	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      roborock.0
      	2023-02-09 19:25:41.240	debug	get_room_mapping
      roborock.0
      	2023-02-09 19:25:41.240	debug	getParameter: get_room_mapping
      roborock.0
      	2023-02-09 19:25:41.239	debug	getParameter: get_multi_maps_list
      roborock.0
      	2023-02-09 19:25:41.239	debug	Firmware features request
      roborock.0
      	2023-02-09 19:25:41.238	debug	getParameter: get_fw_features
      roborock.0
      	2023-02-09 19:25:41.237	debug	getParameter: get_water_box_custom_mode
      roborock.0
      	2023-02-09 19:25:41.236	debug	getParameter: get_carpet_clean_mode
      roborock.0
      	2023-02-09 19:25:41.235	debug	getParameter: get_carpet_mode
      roborock.0
      	2023-02-09 19:25:41.234	debug	getParameter: get_network_info
      roborock.0
      	2023-02-09 19:25:41.233	debug	getParameter: get_consumable
      roborock.0
      	2023-02-09 19:25:41.228	debug	getParameter: get_status
      roborock.0
      	2023-02-09 19:25:41.227	debug	Latest data requested
      roborock.0
      	2023-02-09 19:25:40.947	debug	Robot key: roborock.vacuum.a15
      roborock.0
      	2023-02-09 19:25:40.943	info	MQTT initialized
      roborock.0
      	2023-02-09 19:25:40.883	debug	RoomIDs debug: {"8432821":"XXX","8432824":"XXX","8433923":"XXX","8433929":"XXX","8472171":"XXX","8492521":"XXX","8492553":"XXX","8492561":"XXX","8492571":"XXX","8492579":"XXX","8492595":"XXX","8493021":"XXX","8493027":"XXX"}
      roborock.0
      	2023-02-09 19:25:35.688	info	starting. Version 0.0.8-alpha.0 (non-npm: copystring/ioBroker.roborock#e524b654ed95d6440242ae98fc54b0144d8aa878) in /opt/iobroker/node_modules/iobroker.roborock, node: v16.18.1, js-controller: 4.0.24
      wendy2702 copystring 2 Replies Last reply Reply Quote 0
      • wendy2702
        wendy2702 @Codierknecht last edited by
        @codierknecht Bei mir alles gut. S7+
        • copystring
          copystring @Codierknecht last edited by
          @codierknecht ich denke ich weiß was das sein kann aber kann mich aktuell nicht direkt darum kümmern da der Adapter ein massives Problem mit dem verlieren der Verbindung hat. Wenn das gelöst ist kann ich mich um dein Problem kümmern. Damit es nicht untergeht bitte ich dich ein Bug auf GitHub zu erstellen. Danke.
          • Codierknecht
            @copystring
            https://github.com/copystring/ioBroker.roborock/issues/78
            DEV2DEV-DE created this issue in copystring/ioBroker.roborock
            closed TypeError: Cannot read properties of null #78
              DonToben last edited by
              @copystring
              Grundsätzlich ändert sich der Wert mit dem Befehl, jedoch kommt im Protokoll eine Fehlermeldung.
              Sprich, für mich nur ein Schönheitssfehler, wollte es aber dennoch reporten.
              setState("roborock.0.Devices.5Im6TX0cm6mgxaWxHaEos7.commands.set_custom_mode"/Suction Power/, 102);
              copystring 1 Reply Last reply Reply Quote 0
              • copystring
                copystring @DonToben last edited by
                @dontoben
                @dontoben said in Roborock Adapter tester gesucht:
                @copystring
                Hm. OK. Ich weiß nicht genau warum da Suction Power steht. Wird das mit übertragen oder nur die 102?
                  DonToben @copystring last edited by DonToben
                  @copystring said in Roborock Adapter tester gesucht:
                  @dontoben
                  @copystring
                  Im Gunde wird Suction Power automatisch angezeigt, wenn ich die Object ID set_customer_mode auswähle.
                  Über blockly setze ich dann die Object ID mit Nummer 102.
                  • wendy2702
                    wendy2702 @DonToben last edited by
                    @dontoben Poste mal das Blockly, dann kann ich bei mir mal testen.
                      DonToben @wendy2702 last edited by
                      @wendy2702 said in Roborock Adapter tester gesucht:
                      Du kannst es mit dem einfachen Blockly Befehl simulieren.
                      Die Meldung kommt nur bei set_custom_mode
                        <block type="control" id="BfHB8}m`)QPw0pvFgmx$" x="88" y="163">
                          <field name="OID">roborock.0.Devices.5Im6TX0cm6mgxaWxHaEos7.commands.set_custom_mode</field>
                            <block type="math_number" id="{X9yY6f;^Ad{F!(s+B.L">
                              <field name="NUM">102</field>
                      • wendy2702
                        @dontoben sagte in Roborock Adapter tester gesucht:
                        Ist bei mir auch. Nur noch nie aufgefallen da ich kein Blockly nutze um den DP zu ändern.
                        • copystring
                          @dontoben
                          @copystring
                          Fixed in https://github.com/copystring/ioBroker.roborock/tree/testing
                          • O
                            oxident last edited by
                            Sorry wegen der vielleicht blöden Frage, aber in welcher Einheit sind denn die Aktualisierungsintervalle zu verstehen? Minuten oder Sekunden?
                            • copystring
                              copystring @oxident last edited by
                              @oxident Sekunden
                              • copystring
                                Wer mag kann das neue Feature ausprobieren. Zonenreinigung ist ab sofort in der main branch verfügbar.
                                Das war richtig viel Arbeit!!! Deshalb war es etwas ruhiger in letzter Zeit.
                                In meinen Testläufen wurde auf beiden Stockwerken alles sauber erkannt und die Zonen sauber erstellt.
                                Bei bugs bitte entsprechend ein Issue auf github öffnen. Danke!
                                M-A Hueb D 2 Replies Last reply Reply Quote 2
                                • M-A Hueb
                                  M-A Hueb @copystring last edited by M-A Hueb
                                  @copystring Hab mal geupdatet. Wenn ich die Seite direkt auf dem Server aufrufe geht es und dann funktionierts auch super.
                                  Auf anderen Endgeräten läds bei mir die Karte nicht. Firewall ist kontrolliert worden und auch testweise mal deaktiviert worden
                                  Die Base64 wird nicht richtig geladen:
                                  Der Robi ist nicht mehr sichtbar darauf.
                                  Issue ist offen:
                                  https://github.com/copystring/ioBroker.roborock/issues/85
                                  mproper23 created this issue in copystring/ioBroker.roborock
                                  closed Zonenreinigung Karte wird nicht geladen #85
                                  M-A Hueb 1 Reply Last reply Reply Quote 0
                                  • M-A Hueb
                                    M-A Hueb @M-A Hueb last edited by
                                    @m-a-hueb Hast du was an der Karte geändert? die scheint jetzt kleiner zu sein
                                      Dimi @copystring last edited by
                                      @copystring
                                      Nach löschen des Adapters und Installation der neuesten Main Version, ist bei mir der Datenpunkt "commands.load_multi_map" nicht mehr vorhanden. Dementsprechend werden auch die Datenpunkte (Räume) unter "floors" nicht erstellt. Ist das so gewollt? Wie kann ich denn die richtige Karte laden? Also von z.B Erdgeschoss auf Obergeschoss wechseln?
                                      • O
                                        Mir fällt spontan eine Idee ein ... oder ich bin zu blöd, den entsprechenden DP zu finden:
                                        Könnte man die Info über einen leeren Wassertank eventuell auch im Objektbaum integrieren?
                                        Ich glaube, derzeit versteckt sich diese Information in irgendeinem Statusbit und ich glaube, es wäre deutlich intuitiver, wenn man das "separieren" würde 😉
                                          Hunter 0 last edited by
                                          @copystring
                                          Die Zonenreinigung mit eigenen Webinterface ist schön 🙂
                                          Ich musste den Roboter einmal starten, bis ich die Karte dort sehen konnte. Aber dann klappte es.
                                          Bei mir sehe ich den Roboter auch nicht mehr, aber da hast du ja schon geschrieben, dass du dran bist.
                                          • David G.
                                            David G. last edited by
                                            hab den jungen aber tollen Adapter auch seit heute drauf.
                                            So ganz habe ich bei den ganzen Datenpunkten noch nicht durchgeblickt. Aber kommt bestimmt noch.
                                            Allerdings habe ich nun ein Problem bekommen.
                                            Die ersten Stunden lief der Adapter stabil, jetzt möchte er nicht mehr grün werden.
                                            Habe einfach mal den Raspberry neugestartet, macht aber auch keinen Unterschied.
                                            roborock.0
                                            2023-02-19 23:37:44.922	info	terminating
                                            roborock.0
                                            2023-02-19 23:37:44.917	error	Exception-Code: EADDRINUSE: listen EADDRINUSE: address already in use :::7906
                                            roborock.0
                                            2023-02-19 23:37:44.917	error	Error: listen EADDRINUSE: address already in use :::7906 at Server.setupListenHandle [as _listen2] (node:net:1463:16) at listenInCluster (node:net:1511:12) at Server.listen (node:net:1599:7) at new WebSocketServer (/opt/iobroker/node_modules/iobroker.roborock/node_modules/ws/lib/websocket-server.js:97:20) at Roborock.startWebsocketServer (/opt/iobroker/node_modules/iobroker.roborock/main.js:295:18) at Roborock.onReady (/opt/iobroker/node_modules/iobroker.roborock/main.js:246:8)
                                            roborock.0
                                            2023-02-19 23:37:44.916	error	uncaught exception: listen EADDRINUSE: address already in use :::7906
                                            roborock.0
                                            2023-02-19 23:37:44.912	error	Exception-Code: EADDRINUSE: listen EADDRINUSE: address already in use :::6824
                                            roborock.0
                                            2023-02-19 23:37:44.911	error	Error: listen EADDRINUSE: address already in use :::6824 at Server.setupListenHandle [as _listen2] (node:net:1463:16) at listenInCluster (node:net:1511:12) at Server.listen (node:net:1599:7) at Function.listen (/opt/iobroker/node_modules/express/lib/application.js:635:24) at Roborock.startWebserver (/opt/iobroker/node_modules/iobroker.roborock/main.js:289:7) at Roborock.onReady (/opt/iobroker/node_modules/iobroker.roborock/main.js:245:8)
                                            roborock.0
                                            2023-02-19 23:37:44.909	error	uncaught exception: listen EADDRINUSE: address already in use :::6824
                                            roborock.0
                                            2023-02-19 23:37:41.703	info	MQTT initialized
                                            roborock.0
                                            2023-02-19 23:37:40.425	info	starting. Version 0.0.8-alpha.0 (non-npm: copystring/ioBroker.roborock#fe3f019a8a2856ec1d5e4be7bc9b8c1a082128df) in /opt/iobroker/node_modules/iobroker.roborock, node: v16.19.0, js-controller: 4.0.24
                                            roborock.0
                                            2023-02-19 23:27:33.327	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
                                            roborock.0
                                            2023-02-19 23:27:33.325	info	terminating
                                            766
                                            242831
