    4. Fehler bei Installation i2c Adapter
      Chris_B last edited by wendy2702
      Das Folgende ist jetzt direkt aus dem log-File kopiert.
      Mit dem Riesenwust ab 15:43:34.369:
      2023-02-10 15:43:21.816 - info: host.raspberrypi4-iob iobroker add i2c auto --host raspberrypi4-iob --debug
      2023-02-10 15:43:25.646 - info: host.raspberrypi4-iob iobroker NPM version: 8.11.0
      2023-02-10 15:43:25.647 - info: host.raspberrypi4-iob iobroker Installing iobroker.i2c@1.2.1... (System call)
      2023-02-10 15:43:34.351 - info: host.raspberrypi4-iob iobroker npm ERR! code 1npm ERR! path /opt/iobroker/node_modules/i2c-bus
      2023-02-10 15:43:34.369 - info: host.raspberrypi4-iob iobroker npm ERR! command failednpm ERR! command sh -c node-gyp rebuildnpm ERR! node:internal/modules/cjs/loader:936npm ERR! throw err;npm ERR! ^npm ERR! npm ERR! Error: Cannot find module 'object-assign'npm ERR! Require stack:npm ERR! - /usr/lib/node_modules/npm/node_modules/node-gyp/node_modules/gauge/render-template.jsnpm ERR! - /usr/lib/node_modules/npm/node_modules/node-gyp/node_modules/gauge/plumbing.jsnpm ERR! - /usr/lib/node_modules/npm/node_modules/node-gyp/node_modules/gauge/index.jsnpm ERR! - /usr/lib/node_modules/npm/node_modules/node-gyp/node_modules/npmlog/log.jsnpm ERR! - /usr/lib/node_modules/npm/node_modules/node-gyp/lib/node-gyp.jsnpm ERR! - /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.jsnpm ERR! at Function.Module._resolveFilename (node:internal/modules/cjs/loader:933:15)npm ERR! at Function.Module._load (node:internal/modules/cjs/loader:778:27)npm ERR! at Module.require (node:internal/modules/cjs/loader:1005:19)npm ERR! at require (node:internal/modules/cjs/helpers:102:18)npm ERR! at Object. (/usr/lib/node_modules/npm/node_modules/node-gyp/node_modules/gauge/render-template.js:4:20)npm ERR! at Module._compile (node:internal/modules/cjs/loader:1105:14)npm ERR! at Object.Module._extensions..js (node:internal/modules/cjs/loader:1159:10)npm ERR! at Module.load (node:internal/modules/cjs/loader:981:32)npm ERR! at Function.Module._load (node:internal/modules/cjs/loader:822:12)npm ERR! at Module.require (node:internal/modules/cjs/loader:1005:19) {npm ERR! code: 'MODULE_NOT_FOUND',npm ERR! requireStack: [npm ERR! '/usr/lib/node_modules/npm/node_modules/node-gyp/node_modules/gauge/render-template.js',npm ERR! '/usr/lib/node_modules/npm/node_modules/node-gyp/node_modules/gauge/plumbing.js',npm ERR! '/usr/lib/node_modules/npm/node_modules/node-gyp/node_modules/gauge/index.js',npm ERR! '/usr/lib/node_modules/npm/node_modules/node-gyp/node_modules/npmlog/log.js',npm ERR! '/usr/lib/node_modules/npm/node_modules/node-gyp/lib/node-gyp.js',npm ERR! '/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js'npm ERR! ]npm ERR! }npm ERR! A complete log of this run can be found in:npm ERR! /home/iobroker/.npm/_logs/2023-02-10T14_43_26_796Z-debug-0.log
      2023-02-10 15:43:34.402 - error: host.raspberrypi4-iob iobroker host.raspberrypi4-iob Cannot install iobroker.i2c@1.2.1: 1
      2023-02-10 15:43:35.455 - info: host.raspberrypi4-iob iobroker exit 25
      2023-02-10 16:04:16.085 - info: admin.0 (602) <== Disconnect system.user.admin from ::ffff:192.168.1.137 admin
      2023-02-10 16:05:23.668 - info: admin.0 (602) ==> Connected system.user.admin from ::ffff:192.168.1.137
      2023-02-10 16:27:06.648 - info: admin.0 (602) <== Disconnect system.user.admin from ::ffff:192.168.1.137 admin
      MOD EDIT: LOG IN CODE TAGS </> GESETZT
        Thomas Braun Most Active @Chris_B last edited by
        @chris_b sagte in Fehler bei Installation i2c Adapter:
        Node-js: Ist auf Version 16.16.0, mit dem Hinweis, dass ich auf Version 16.19.0 updaten kann. Was meinst Du mit 'prüfen'?
        Schau in meiner Signatur.
        • wendy2702
          wendy2702 last edited by
          https://forum.iobroker.net/topic/57337/fehler-25-oder-217-bei-adapter-install-update-mit-npm8
            OK, werde ich versuchen. Melde mich wieder. Aber nicht mehr heute.
              Thomas Braun Most Active @wendy2702 last edited by
              @wendy2702
              Hier dürfte aber was anderes im Argen liegen.
              Vielleicht sieht man was beim Check auf 'senkrechte' Installation von nodejs.
              • wendy2702
                wendy2702 @Thomas Braun last edited by
                @thomas-braun sagte in Fehler bei Installation i2c Adapter:
                @wendy2702
                Vermutlich. Habe nachdem ich die Code Tags drum gebaut habe nicht mehr gesehen das man noch ewig nach rechts scrollen kann 😬
                Habe nur runter gescrollt und die „25“ gesehen.
                Vielleicht dürfen wir ja auch einen Blick hier rein werfen
                  Die ewig lange Zeile entspricht der oben genannten 'Buchstabensuppe'.
                  Hier ist das log File:
                  Vielen Dank für die Hilfe...
                    @chris_b
                    nodejs geprüft?
                    sudo ln -s /usr/bin/node /usr/bin/nodejs &> /dev/null
                    uname -m && type -P nodejs node npm npx && nodejs -v && node -v && npm -v && npx -v && iob -v && whoami && groups && echo $XDG_SESSION_TYPE && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
                    sagt?
                      @Thomas-Braun Das kommt dabei heraus (ich hoffe, ich habe das richtig gemacht, bin da nicht so fit wie ihr):
                      armv7l
                      /usr/bin/nodejs
                      /usr/bin/node
                      /usr/bin/npm
                      /usr/bin/npx
                      v16.16.0
                      v16.16.0
                      8.11.0
                      8.11.0
                      4.0.24
                      pi
                      pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c spi iobroker pijuice
                      tty
                      /home/pi
                      OK:1 http://archive.raspberrypi.org/debian buster InRelease
                      OK:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
                      OK:3 https://deb.nodesource.com/node_16.x buster InRelease
                      OK:4 https://phoscon.de/apt/deconz buster InRelease
                      Aktualisierung für 136 Pakete verfügbar. Führen Sie »apt list --upgradable« aus, um sie anzuzeigen.
                      nodejs:
                        Installiert:           16.16.0-deb-1nodesource1
                        Installationskandidat: 16.19.0-deb-1nodesource1
                        Versionstabelle:
                           16.19.0-deb-1nodesource1 500
                              500 https://deb.nodesource.com/node_16.x buster/main armhf Packages
                       *** 16.16.0-deb-1nodesource1 100
                              100 /var/lib/dpkg/status
                           10.24.0~dfsg-1~deb10u2 500
                        Thomas Braun Most Active @Chris_B last edited by Thomas Braun
                        Updaten. Jetzt und alles.
                        Und danach den buster beerdigen und bullseye installieren.
                        https://forum.iobroker.net/topic/47213/upgrade-von-debian-10-buster-auf-11-bullseye
                          Sorry Thomas. Bitte ein bisschen ausführlicher - bin da nicht so drin.
                          Ich muss nodejs von 16.16.0 auf 16.19.0 updaten und das wars?
                          Und danke für den weiteren Link.
                          Wieso lohnt sich das? ein Link würde mir da auch helfen.
                            und das wars?
                            Nein, dein komplettes Betriebssystem ist versumpft.
                            Das muss sich nicht 'lohnen', weil dein Release abgekündigt ist und nicht mehr gepflegt wird. Daher stellt sich die Frage erst gar nicht.
                            Siehe auch hier:
                            https://wiki.debian.org/DebianReleases
                              Ich habe nun node.js und NPM auf die neuste Version gezogen:
                              node.js auf V16.19.0, NPM auf V8.19.3.
                              iobroker fix auch ausgeführt, alles ohne Probleme.
                              Trotzdem lässt sich der i2c Adapter nicht installieren, die gleichen Fehlermeldungen erscheinen.
                              Ich überlege die nächsten Schritte. Evtl. bei Gelegenheit System neu aufsetzen (bullseye)...
                              • wendy2702
                                wendy2702 @Chris_B last edited by
                                @chris_b
                                iob stop
                                iob fix
                                iob start
                                iob diag
                                Ausgaben bitte vollständig hier posten.
                                  Chris_B @wendy2702 last edited by Chris_B
                                  @wendy2702
                                  here it is:
                                  Skript v.2023-01-02
                                  *** BASE SYSTEM ***
                                  Model           : Raspberry Pi 4 Model B Rev 1.5
                                  Architecture:   armv7l
                                  Docker:         false
                                  Virtualization: none
                                  Distributor ID: Raspbian
                                  Description:    Raspbian GNU/Linux 10 (buster)
                                  Release:        10
                                  Codename:       buster
                                  PRETTY_NAME="Raspbian GNU/Linux 10 (buster)"
                                  NAME="Raspbian GNU/Linux"
                                  VERSION_ID="10"
                                  VERSION="10 (buster)"
                                  VERSION_CODENAME=buster
                                  ID=raspbian
                                  ID_LIKE=debian
                                  HOME_URL="http://www.raspbian.org/"
                                  SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
                                  BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
                                  Systemuptime and Load:
                                   18:03:09 up 40 min,  1 user,  load average: 1.54, 1.01, 0.64
                                  CPU threads: 4
                                  *** Time and Time Zones ***
                                  Sat Feb 11 17:03:09 UTC 2023
                                  Sat Feb 11 18:03:09 CET 2023
                                  CET +0100
                                  Europe/Zurich
                                  *** User and Groups ***
                                  pi
                                  /home/pi
                                  *** X-Server-Setup ***
                                  X-Server:       false
                                  Desktop:
                                  Terminal:       tty
                                  *** MEMORY ***
                                  Mem:           3.8G        980M        2.3G         24M        560M        2.9G
                                  Swap:           99M          0B         99M
                                  Total:         3.9G        980M        2.4G
                                           3838 M total memory
                                            980 M used memory
                                            335 M active memory
                                           1046 M inactive memory
                                           2297 M free memory
                                            127 M buffer memory
                                            433 M swap cache
                                             99 M total swap
                                              0 M used swap
                                             99 M free swap
                                  *** FILESYSTEM ***
                                  /dev/root      ext4       15G  4.6G  9.2G  34% /
                                  devtmpfs       devtmpfs  1.8G     0  1.8G   0% /dev
                                  tmpfs          tmpfs     1.9G     0  1.9G   0% /dev/shm
                                  tmpfs          tmpfs     1.9G   25M  1.9G   2% /run
                                  tmpfs          tmpfs     1.9G     0  1.9G   0% /sys/fs/cgroup
                                  /dev/mmcblk0p1 vfat      253M   49M  204M  20% /boot
                                  tmpfs          tmpfs     384M     0  384M   0% /run/user/1000
                                  Messages in dmesg:
                                  [Sat Feb 11 17:22:11 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=E4:5F:01:A8:12:03 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyAMA0,115200 console=tty1 root=PARTUUID=cd3e8f54-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
                                  [Sat Feb 11 17:22:13 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
                                  [Sat Feb 11 17:22:13 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
                                  [Sat Feb 11 17:22:16 2023] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
                                  Show mounted filesystems (real ones only):
                                  TARGET        SOURCE         FSTYPE OPTIONS
                                  /             /dev/mmcblk0p2 ext4   rw,noatime
                                  |-/sys/fs/bpf none           bpf    rw,nosuid,nodev,noexec,relatime,mode=700
                                  `-/boot       /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                                  /var:
                                  502M    /var/
                                  294M    /var/cache
                                  288M    /var/cache/apt
                                  229M    /var/cache/apt/archives
                                  92M     /var/lib
                                  /opt/iobroker/backups:
                                  21M     /opt/iobroker/backups/
                                  /opt/iobroker/iobroker-data:
                                  222M    /opt/iobroker/iobroker-data/
                                  105M    /opt/iobroker/iobroker-data/files
                                  94M     /opt/iobroker/iobroker-data/backup-objects
                                  51M     /opt/iobroker/iobroker-data/files/javascript.admin
                                  32M     /opt/iobroker/iobroker-data/files/javascript.admin/static/js
                                  7.6M    /opt/iobroker/iobroker-data/objects.jsonl
                                  6.9M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/610.de0231c9.chunk.js.map
                                  6.3M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map
                                  6.2M    /opt/iobroker/iobroker-data/objects.json.migrated
                                  6.2M    /opt/iobroker/iobroker-data/objects.json.bak.migrated
                                  *** NodeJS-Installation ***
                                  /usr/bin/nodejs         v16.19.0
                                  /usr/bin/node           v16.19.0
                                  /usr/bin/npm            8.19.3
                                  /usr/bin/npx            8.19.3
                                  nodejs:
                                    Installed: 16.19.0-deb-1nodesource1
                                    Candidate: 16.19.0-deb-1nodesource1
                                    Version table:
                                   *** 16.19.0-deb-1nodesource1 500
                                  *** ioBroker-Installation ***
                                  ioBroker Status
                                  Objects type: jsonl
                                  States  type: jsonl
                                  Core adapters versions
                                  js-controller:  4.0.24
                                  admin:          6.3.5
                                  javascript:     6.1.4
                                  Adapters from github:   0
                                  Adapter State
                                  + system.adapter.admin.0                  : admin                 : raspberrypi4-iob                         -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
                                  + system.adapter.backitup.0               : backitup              : raspberrypi4-iob                         -  enabled
                                  + system.adapter.cloud.0                  : cloud                 : raspberrypi4-iob                         -  enabled
                                  + system.adapter.denon.0                  : denon                 : raspberrypi4-iob                         -  enabled
                                  + system.adapter.denon.1                  : denon                 : raspberrypi4-iob                         -  enabled
                                  + system.adapter.discovery.0              : discovery             : raspberrypi4-iob                         -  enabled
                                    system.adapter.flot.0                   : flot                  : raspberrypi4-iob                         - disabled
                                  + system.adapter.heos.0                   : heos                  : raspberrypi4-iob                         -  enabled
                                  + system.adapter.history.0                : history               : raspberrypi4-iob                         -  enabled
                                  + system.adapter.hue.0                    : hue                   : raspberrypi4-iob                         -  enabled, port: 80
                                  + system.adapter.hue.1                    : hue                   : raspberrypi4-iob                         -  enabled, port: 80
                                  + system.adapter.info.0                   : info                  : raspberrypi4-iob                         -  enabled
                                  + system.adapter.javascript.0             : javascript            : raspberrypi4-iob                         -  enabled
                                  + system.adapter.netatmo.0                : netatmo               : raspberrypi4-iob                         -  enabled
                                  + system.adapter.ping.0                   : ping                  : raspberrypi4-iob                         -  enabled
                                  + system.adapter.rpi2.0                   : rpi2                  : raspberrypi4-iob                         -  enabled
                                  + system.adapter.simple-api.0             : simple-api            : raspberrypi4-iob                         -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
                                  + system.adapter.socketio.0               : socketio              : raspberrypi4-iob                         -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
                                    system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi4-iob                         - disabled
                                    system.adapter.vis.0                    : vis                   : raspberrypi4-iob                         -  enabled
                                  + system.adapter.web.0                    : web                   : raspberrypi4-iob                         -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                                  + system.adapter.yahka.0                  : yahka                 : raspberrypi4-iob                         -  enabled
                                  + instance is alive
                                  ioBroker-Repositories
                                  Active repo(s): stable
                                  Installed ioBroker-Instances
                                  Used repository: stable
                                  Adapter    "admin"        : 6.3.5    , installed 6.3.5
                                  Adapter    "backitup"     : 2.5.12   , installed 2.5.12
                                  Adapter    "cloud"        : 4.3.0    , installed 4.3.0
                                  Adapter    "denon"        : 1.13.4   , installed 1.13.4
                                  Adapter    "discovery"    : 3.1.0    , installed 3.1.0
                                  Adapter    "email"        : 1.1.4    , installed 1.1.4
                                  Adapter    "flot"         : 1.11.0   , installed 1.11.0
                                  Adapter    "heos"         : 1.10.0   , installed 1.10.0
                                  Adapter    "history"      : 2.2.4    , installed 2.2.4
                                  Adapter    "homekit-controller": 0.5.1, installed 0.5.1
                                  Adapter    "hue"          : 3.7.1    , installed 3.7.1
                                  Adapter    "info"         : 1.9.19   , installed 1.9.19
                                  Adapter    "javascript"   : 6.1.4    , installed 6.1.4
                                  Controller "js-controller": 4.0.24   , installed 4.0.24
                                  Adapter    "netatmo"      : 2.0.5    , installed 2.0.5
                                  Adapter    "ping"         : 1.5.3    , installed 1.5.3
                                  Adapter    "vis"          : 1.4.15   , installed 1.4.15
                                  Adapter    "vis-hqwidgets": 1.3.0    , installed 1.3.0
                                  Adapter    "yahka"        : 0.13.1   , installed 0.13.1
                                  Objects and States
                                  Objects:        3093
                                  States:         2599
                                  Hit:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
                                  Hit:2 https://phoscon.de/apt/deconz buster InRelease
                                  Hit:3 https://deb.nodesource.com/node_16.x buster InRelease
                                  Hit:4 http://archive.raspberrypi.org/debian buster InRelease
                                  Reading package lists...
                                  Pending Updates: 0
                                  *** Listening Ports ***
                                  tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          17590      585/sshd
                                  tcp        0      0 127.0.0.1:43801         0.0.0.0:*               LISTEN      1001       191843     21588/io.yahka.0
                                  tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       187068     20468/iobroker.js-c
                                  tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       187061     20468/iobroker.js-c
                                  tcp6       0      0 :::8081                 :::*                    LISTEN      1001       189559     20489/io.admin.0
                                  tcp6       0      0 :::8082                 :::*                    LISTEN      1001       191294     21389/io.web.0
                                  tcp6       0      0 :::8084                 :::*                    LISTEN      1001       191171     21098/io.socketio.0
                                  tcp6       0      0 :::22                   :::*                    LISTEN      0          17592      585/sshd
                                  tcp6       0      0 :::8087                 :::*                    LISTEN      1001       190525     20863/io.simple-api
                                  tcp6       0      0 :::34381                :::*                    LISTEN      1001       193677     21588/io.yahka.0
                                  udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          16640      573/dhcpcd
                                  udp        0      0 0.0.0.0:42135           0.0.0.0:*                           1001       188978     20815/io.heos.0
                                  udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       193678     21588/io.yahka.0
                                  udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        12814      377/avahi-daemon: r
                                  udp        0      0 0.0.0.0:41800           0.0.0.0:*                           108        12816      377/avahi-daemon: r
                                  udp6       0      0 :::38941                :::*                                108        12817      377/avahi-daemon: r
                                  udp6       0      0 :::546                  :::*                                0          16653      573/dhcpcd
                                  udp6       0      0 :::5353                 :::*                                108        12815      377/avahi-daemon: r
                                  2023-02-11 18:02:07.466  - info: cloud.0 (20724) Trying to connect as system.user.admin to cloud
                                  2023-02-11 18:02:07.601  - info: cloud.0 (20724) Connection changed: connect
                                  2023-02-11 18:02:08.580  - info: vis.0 (21336) starting. Version 1.4.15 in /opt/iobroker/node_modules/iobroker.vis, node: v16.19.0, js-controller: 4.0.24
                                  2023-02-11 18:02:08.791  - info: vis.0 (21336) vis license is OK.
                                  2023-02-11 18:02:09.456  - info: vis.0 (21336) Terminated (NO_ERROR): Without reason
                                  2023-02-11 18:02:10.134  - info: host.raspberrypi4-iob instance system.adapter.vis.0 terminated while should be started once
                                  2023-02-11 18:02:10.923  - info: host.raspberrypi4-iob instance system.adapter.web.0 started with pid 21389
                                  2023-02-11 18:02:14.861  - info: host.raspberrypi4-iob instance system.adapter.yahka.0 started with pid 21588
                                  2023-02-11 18:02:17.276  - info: yahka.0 (21588) starting. Version 0.13.1 in /opt/iobroker/node_modules/iobroker.yahka, node: v16.19.0, js-controller: 4.0.24
                                  2023-02-11 18:02:17.314  - info: yahka.0 (21588) adapter ready, checking config
                                  2023-02-11 18:02:17.329  - info: yahka.0 (21588) adding Wasser Höfli 1A with UUID: 10c354a6-9830-470f-9a77-a332861ef8a9
                                  2023-02-11 18:02:17.342  - info: yahka.0 (21588) adding Wasser Höfli 2A with UUID: e801a2ae-6c62-44d0-870f-a7a316e4a4b6
                                  2023-02-11 18:02:17.346  - info: yahka.0 (21588) adding Wasser Garten 3A with UUID: e7a975c7-14b7-4db6-93c9-a5c06b0f0906
                                  2023-02-11 18:02:17.350  - info: yahka.0 (21588) adding Wasser Garten 4A with UUID: b19d1566-51f7-4dbf-a436-f10b00d4d3bf
                                  2023-02-11 18:02:17.354  - info: yahka.0 (21588) adding Wasser Garten 5A with UUID: cfba9462-495d-445e-bdaf-92d89e5d323c
                                  2023-02-11 18:02:17.358  - info: yahka.0 (21588) adding Wasser Feedback 1 with UUID: 80efd4c4-8f76-48b0-b794-663ac97d7d2a
                                  2023-02-11 18:02:17.362  - info: yahka.0 (21588) adding Wasser Feedback 2 with UUID: c7c1a3fe-b438-43eb-a479-bbda51d1d6c8
                                  2023-02-11 18:02:17.366  - info: yahka.0 (21588) adding Wasser Feedback 3 with UUID: 3270564c-f984-4208-88ed-bcafad48b3e3
                                  2023-02-11 18:02:17.370  - info: yahka.0 (21588) adding Wasser Feedback 4 with UUID: 94316748-7b8a-456d-9813-e1529df2ff42
                                  2023-02-11 18:02:17.375  - info: yahka.0 (21588) adding Wasser Feedback 5 with UUID: 192619c5-90be-4580-8af2-9cdd5282fc7a
                                  2023-02-11 18:02:17.379  - info: yahka.0 (21588) adding Wasser Feedback 6 with UUID: 442ced11-b93a-4a60-9eaf-d6b789ce2e54
                                  2023-02-11 18:02:17.382  - info: yahka.0 (21588) adding Wasser Garten 6A with UUID: 5356872a-1195-47ad-a30c-62d253157baf
                                  2023-02-11 18:02:17.386  - info: yahka.0 (21588) adding Motion Cat1 with UUID: 01ba38ce-6b34-4467-8989-7af6f0774eeb
                                  2023-02-11 18:02:17.389  - info: yahka.0 (21588) adding Motion Cat2 with UUID: 9122c6a7-6598-4298-84f5-ecc8c2598e8d
                                  2023-02-11 18:02:17.392  - info: yahka.0 (21588) publishing bridge Yahka-0 on 0.0.0.0 using ciao
                                  und Teil2:
                                                       v.2023-01-02
                                  Operatingsystem:        Raspbian GNU/Linux 10 (buster)
                                  Installation:           Native
                                  Timezone:               Europe/Zurich
                                  User-ID:                1000
                                  X-Server:               false
                                  Boot Target:            graphical.target
                                  Pending OS-Updates:     0
                                  Nodejs-Installation:    /usr/bin/nodejs         v16.19.0
                                                          /usr/bin/npm            8.19.3
                                                          /usr/bin/npx            8.19.3
                                  ioBroker Core:          js-controller           4.0.24
                                                          admin                   6.3.5
                                  Objects type: jsonl
                                  States  type: jsonl
                                  Status admin:
                                  Pending iob updates:    0
                                  Objects:                3093
                                  States:                 2599
                                  Size of iob-Database:
                                  1.8M    /opt/iobroker/iobroker-data/states.jsonl
                                  684K    /opt/iobroker/iobroker-data/states.json.migrated
                                  684K    /opt/iobroker/iobroker-data/states.json.bak.migrated
                                  • wendy2702
                                    @chris_b Log vom fixer ?
                                      @wendy2702 Sorry muss jetzt weg, liefere ich später nach. fixer läuft aus meiner Sicht problemlos durch. Ich poste es später nochmals.
                                      wendy2702 Thomas Braun 2 Replies Last reply Reply Quote 0
                                      • wendy2702
                                        @chris_b Kein Stress bin auch gleich weg
                                          @chris_b
                                          Bring dein System auf Debian11/Bullseye.
                                            @wendy2702 Hier nun das log vom fixer (aber da sehe ich auch keine wesentliche Info, die auf ein potentielles Problem hindeutet):
                                            library: loaded
                                            Library version=2022-12-09
                                                Welcome to the ioBroker installation fixer!
                                                Script version: 2022-12-22
                                                You might need to enter your password a couple of times.
                                                Installing prerequisites (1/4)
                                            Holen:1 http://raspbian.raspberrypi.org/raspbian buster InRelease [15.0 kB]
                                            OK:2 http://archive.raspberrypi.org/debian buster InRelease
                                            Es wurden 15.0 kB in 1 s geholt (10.2 kB/s).
                                            Installed gcc-c++
                                                Checking ioBroker user and directory permissions (2/4)
                                            Created /etc/sudoers.d/iobroker
                                            Fixing directory permissions...
                                                Database maintenance (3/4)
                                            Checking for uncompressed JSONL databases... This might take a while!
                                            Compressing /opt/iobroker/iobroker-data/states.jsonl
                                            Compressing /opt/iobroker/iobroker-data/objects.jsonl
                                            Compressed 2 JSONL files. Done
                                                Checking autostart (4/4)
                                            Enabling autostart...
                                            Autostart enabled!
                                                Your installation was fixed successfully
                                                Run iobroker start to start ioBroker again!
                                            1.0k
                                            3386
