    4. Cubietruck 3 nicht erreichbar nach node 14.x Löschung
      blackangel15741 @Homoran last edited by
      blackangel1508@cubietruck:~$ mount | sort
      binfmt_misc on /proc/sys/fs/binfmt_misc type binfmt_misc (rw,re
      latime)
      bpf on /sys/fs/bpf type bpf (rw,nosuid,nodev,noexec,relatime,mo
      de=700)
      cgroup2 on /sys/fs/cgroup/unified type cgroup2 (rw,nosuid,nodev
      ,noexec,relatime,nsdelegate)
      cgroup on /sys/fs/cgroup/blkio type cgroup (rw,nosuid,nodev,noe
      xec,relatime,blkio)
      cgroup on /sys/fs/cgroup/cpu,cpuacct type cgroup (rw,nosuid,nod
      ev,noexec,relatime,cpu,cpuacct)
      cgroup on /sys/fs/cgroup/cpuset type cgroup (rw,nosuid,nodev,no
      exec,relatime,cpuset)
      cgroup on /sys/fs/cgroup/devices type cgroup (rw,nosuid,nodev,n
      oexec,relatime,devices)
      cgroup on /sys/fs/cgroup/freezer type cgroup (rw,nosuid,nodev,n
      oexec,relatime,freezer)
      cgroup on /sys/fs/cgroup/memory type cgroup (rw,nosuid,nodev,no
      exec,relatime,memory)
      cgroup on /sys/fs/cgroup/net_cls,net_prio type cgroup (rw,nosui
      d,nodev,noexec,relatime,net_cls,net_prio)
      cgroup on /sys/fs/cgroup/perf_event type cgroup (rw,nosuid,node
      v,noexec,relatime,perf_event)
      cgroup on /sys/fs/cgroup/pids type cgroup (rw,nosuid,nodev,noex
      ec,relatime,pids)
      cgroup on /sys/fs/cgroup/rdma type cgroup (rw,nosuid,nodev,noex
      ec,relatime,rdma)
      cgroup on /sys/fs/cgroup/systemd type cgroup (rw,nosuid,nodev,n
      oexec,relatime,xattr,name=systemd)
      configfs on /sys/kernel/config type configfs (rw,relatime)
      debugfs on /sys/kernel/debug type debugfs (rw,relatime)
      /dev/mmcblk0p1 on / type ext4 (rw,noatime,errors=remount-ro,com
      mit=600)
      /dev/mmcblk0p1 on /var/log.hdd type ext4 (rw,noatime,errors=rem
      ount-ro,commit=600)
      devpts on /dev/pts type devpts (rw,nosuid,noexec,relatime,gid=5
      ,mode=620,ptmxmode=000)
      /dev/zram1 on /var/log type ext4 (rw,relatime,discard)
      fusectl on /sys/fs/fuse/connections type fusectl (rw,relatime)
      mqueue on /dev/mqueue type mqueue (rw,relatime)
      proc on /proc type proc (rw,nosuid,nodev,noexec,relatime)
      pstore on /sys/fs/pstore type pstore (rw,nosuid,nodev,noexec,re
      latime)
      securityfs on /sys/kernel/security type securityfs (rw,nosuid,n
      sunrpc on /run/rpc_pipefs type rpc_pipefs (rw,relatime)
      sysfs on /sys type sysfs (rw,nosuid,nodev,noexec,relatime)
      systemd-1 on /proc/sys/fs/binfmt_misc type autofs (rw,relatime,
      fd=37,pgrp=1,timeout=0,minproto=5,maxproto=5,direct)
      tmpfs on /dev/shm type tmpfs (rw,nosuid,nodev)
      tmpfs on /run/lock type tmpfs (rw,nosuid,nodev,noexec,relatime,
      size=5120k)
      tmpfs on /run type tmpfs (rw,nosuid,noexec,relatime,size=204800
      k,mode=755)
      tmpfs on /run/user/0 type tmpfs (rw,nosuid,nodev,relatime,size=
      204796k,mode=700)
      tmpfs on /run/user/1000 type tmpfs (rw,nosuid,nodev,relatime,si
      ze=204796k,mode=700,uid=1000,gid=1000)
      tmpfs on /sys/fs/cgroup type tmpfs (ro,nosuid,nodev,noexec,mode
      =755)
      tmpfs on /tmp type tmpfs (rw,nosuid,relatime)
      tracefs on /sys/kernel/debug/tracing type tracefs (rw,relatime)
      udev on /dev type devtmpfs (rw,nosuid,relatime,size=969528k,nr_
      inodes=160685,mode=755)
        blackangel15741 @Thomas Braun last edited by
        @thomas-braun sagte in Cubietruck 3 nicht erreichbar nach node 14.x Löschung:
        @blackangel15741
        sudo usermod -a -G iobroker DEINUSER
        Also jetzt die Zeile 1 zu 1 so übernehmen?
          @homoran sagte in Cubietruck 3 nicht erreichbar nach node 14.x Löschung:
          @blackangel15741 sagte in Cubietruck 3 nicht erreichbar nach node 14.x Löschung:
          komme mit der Festplatte nicht weiter siehe auch weiter oben
          was ist dabei rausgekommen?
          Hast du jetzt wieder ein laufendes System und die drei genannten Partitionen sind da gar nicht gemountet oder wie?
          mount | sort
          sagt?
          ich hab die Antworten dazu irgendwie übersehen.
          Also ich hatte noch ein Programm x-plore auf dem Handy und konnte damit zugreifen.
          Es ist eine ssd Platte mit 120 GB
          in sda1, sda2, sda3
          Über das Programm finde ich das unter dev/ disk
          Aber da wird nichts weiter angezeigt was ich jetzt kopieren könnte, sichern könnte.
          Bei der Einrichtung wollte ich jetzt zwar die Festplatte installieren also system nach sata und boot von sd aber da wird ja dann die Platte gelöscht oder? Oder nur die Partition sda1?
          Homoran B 2 Replies Last reply Reply Quote 0
            Homoran Global Moderator Administrators @blackangel15741 last edited by
            wollte ich
            warum machst du nicht erst wonach man fragt?
            Wenn erst alles kaputt ist, kann hier keiner mehr helfen!
            mount | sort
            sagt?
              blackangel15741 @blackangel15741 last edited by
              Ich möchte mich mal allgemein hier bedanken bei allen, die Ihre Zeit opfern um anderen hier unter die Arme zu greifen.
                @blackangel15741 bitte führe doch einfach mal den Befehl mount | sort in der Konsole aus ind poste die Ausgabe.
                Dann und nur dann kann man dir weiterhelfen (hoffentlich)
                  Thomas Braun Most Active @blackangel15741 last edited by Thomas Braun
                  @blackangel15741
                  sudo mount /dev/sda1 /mnt
                  Danach ist der Inhalt der Partition unter /mnt zu finden.
                    @homoran Hallo.....mount | sort hatte ich schon durchgeführt und mehrfach hier eigentlich reingestellt
                      @thomas-braun ist das jetzt 1:1 so zu übernehmen?
                        Homoran Global Moderator Administrators @blackangel15741 last edited by Homoran
                        wenn ja, dann sorry dass ich es nicht gefunden habe!
                        Aber deswegen hatte ich ja zweimal nachgefragt wo es zu finden sei.
                        EDIT: JETZT HAB ICH ES!
                        Aber die Platte ist nicht dabei. Dann bitte mounten
                          Mount | sort
                          de=700)
                          xec,relatime,blkio)
                          ec,relatime,pids)
                          ec,relatime,rdma)
                          mit=600)
                          ount-ro,commit=600)
                          latime)
                          fd=42,pgrp=1,timeout=0,minproto=5,maxproto=5,direct)
                          size=5120k)
                          k,mode=755)
                          204796k,mode=700)
                          =755)
                          blackangel1508@cubietruck:~$��������������������������������������������������������
                            @blackangel15741
                            danke!
                            siehe edit
                              @blackangel15741
                              DEINUSER ist natürlich durch den username zu ersetzen. Vermutlich bei dir durch blackangel1508
                                @thomas-braun Dankeschön
                                Welchen usernamen ich vorher hatte weiß ich nicht genau ....den namen blackangel1508 hatte ich mir hier bei der Neuinstallation angelegt.
                                  @homoran das mit dem mounten klappt nicht....der sagt....Befehl nicht gefunden
                                    @blackangel15741
                                    Habt ihr eigentlich keine Vornamen? Die eignen sich nämlich hervorragend als user names. Vergisst man auch in der Regel nicht.
                                      @blackangel15741
                                        wie genau sieht das aus?
                                        Ein- und Ausgabe bitte in code-tags posten
                                          @homoran hatte den Befehl "mount" vergessen
                                          Also habe jetzt Zugriff auf die Platte und habe mir aus sda1 das Backup auf den Laptob gezogen "backupiobroker.tar.gz"
                                          5,9 MB
                                          Ist da jetzt alles an Einstellungen gesichert auch vis. Projekte und eigene scripte?
                                          Soll ich jetzt die Platte installieren mit boot sd und system nach sata also sda1 ?
                                          Bleibt mir dann sda2 sda3 erhalten?
                                          Wenn jetzt alle iobroker daten auf der sda1 vorliegen kann man das jetzt reaktivieren oder ist das nicht möglich weil alles überschrieben wird, weil ja beim installieren "system nach sda1" die Platte gelöscht wird?
                                          Hoffe ich konnte mich verständlich erklären.
                                            Nicht so ganz...
                                            Was liegt denn auf /dev/sda2 und /dev/sda3 drauf?
                                            Wenn du jetzt ein Backup hast ist doch alles gut. System frisch von Grundauf neuinstallieren, ohne Rücksicht auf (durch Backup nicht vorhandene) Verluste und das Backup in den frischen ioBroker einspielen.
                                            9569
