    4. npm ERR! Cannot read properties of null (reading 'parent')
    • wendy2702
      wendy2702 last edited by
      Was kommt denn dabei:
      sudo ln -s /usr/bin/node /usr/bin/nodejs &> /dev/null
      uname -m && type -P nodejs node npm npx && nodejs -v && node -v && npm -v && npx -v && iob -v && whoami && groups && echo $XDG_SESSION_TYPE && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
        backfisch88 @wendy2702 last edited by backfisch88
        aarch64
        /usr/bin/nodejs
        /usr/bin/node
        /usr/bin/npm
        /usr/bin/npx
        v16.19.0
        v16.19.0
        8.19.3
        8.19.3
        4.0.24
        pi
        pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
        tty
        /home/pi
        Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
        Hit:2 http://deb.debian.org/debian bullseye InRelease
        Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
        Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
        Get:5 https://repos.influxdata.com/debian stretch InRelease [7,021 B]
        Hit:6 https://deb.nodesource.com/node_16.x bullseye InRelease
        Err:5 https://repos.influxdata.com/debian stretch InRelease
          The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
        Fetched 7,021 B in 2s (3,346 B/s)
        Reading package lists... Done
        Building dependency tree... Done
        26 packages can be upgraded. Run 'apt list --upgradable' to see them.
        W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://repos.influxdata.com/debian stretch InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
        W: Failed to fetch https://repos.influxdata.com/debian/dists/stretch/InRelease  The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
        W: Some index files failed to download. They have been ignored, or old ones used instead.
        nodejs:
          Installed: 16.19.0-deb-1nodesource1
          Candidate: 16.19.0-deb-1nodesource1
          Version table:
         *** 16.19.0-deb-1nodesource1 500
                500 https://deb.nodesource.com/node_16.x bullseye/main arm64 Packages
                100 /var/lib/dpkg/status
             12.22.12~dfsg-1~deb11u3 500
                500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
             12.22.5~dfsg-2~11u1 500
                500 http://deb.debian.org/debian bullseye/main arm64 Packages
        wendy2702 B 2 Replies Last reply Reply Quote 0
        • wendy2702
          wendy2702 @backfisch88 last edited by
          @backfisch88 sagte in npm ERR! Cannot read properties of null (reading 'parent'):
          Hat vielleicht nicht direkt was mit deinem Problem zu tun, solltest du aber mal anpassen.
          kannst du noch die Ausgabe von
          iob diag
          zeigen
            backfisch88 @backfisch88 last edited by backfisch88
            war natürlich Käse... hier nochmal das richtige
                                 v.2023-01-02
            Operatingsystem:        Debian GNU/Linux 11 (bullseye)
            Installation:           Native
            Timezone:               Europe/Berlin
            User-ID:                1000
            X-Server:               false
            Boot Target:            multi-user.target
            Pending OS-Updates:     23
            Nodejs-Installation:    /usr/bin/nodejs         v16.19.0
                                    /usr/bin/node           v16.19.0
                                    /usr/bin/npm            8.19.3
                                    /usr/bin/npx            8.19.3
            ioBroker Core:          js-controller           4.0.24
                                    admin                   6.3.6
            Objects type: jsonl
            States  type: redis
            Status admin:
            + system.adapter.admin.0                  : admin                 : IOBroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
            Pending iob updates:    1
            Active repo(s): Beta (latest)
            Objects:                43953
            States:                 36034
            Size of iob-Database:
            42M     /opt/iobroker/iobroker-data/objects.jsonl
            44K     /opt/iobroker/iobroker-data/states.jsonl
            • Glasfaser
              Glasfaser @backfisch88 last edited by
              @backfisch88
              Mhh .. 🙄
              da stand doch vorhin mehr
              und du bist tief als BETA Tester unterwegs auch mit dem Alpha VIS 2 !?
              Mache mal :
              iobroker upload all
              npm prune
              sudo reboot
              dann
              iobroker upgrade tankerkoenig --debug
                backfisch88 @Glasfaser last edited by backfisch88
                @glasfaser ja das war der log zwischendrin war nicht fertig gelaufen. Das ist der Bericht.
                ne kein VIS2.
                Bin auch der Meinung, dass vorgestern das updaten noch ging... habe in der Zeit aber auch nichts gemacht...
                This upgrade of "tankerkoenig" will introduce the following changes:
                -> 3.3.7:
                added difference to jsonTable #116
                added a log message for the error `parameter error`
                set the name length to 34 characters
                Added verification if the api key is encrypted
                updated the Dependencies
                Would you like to upgrade tankerkoenig from @3.3.6 to @3.3.7 now? [(y)es, (n)o]: y
                Update tankerkoenig from @3.3.6 to @3.3.7
                host.IOBroker Adapter "system.adapter.tankerkoenig.0" is stopped.
                host.IOBroker Adapter "system.adapter.tankerkoenig.1" is stopped.
                NPM version: 8.19.3
                Installing iobroker.tankerkoenig@3.3.7... (System call)
                npm ERR!     /home/iobroker/.npm/_logs/2023-02-13T11_50_32_017Z-debug-0.log
                upload [4] tankerkoenig.admin /opt/iobroker/node_modules/iobroker.tankerkoenig/admin/build/index.js build/index.js application/javascript
                upload [3] tankerkoenig.admin /opt/iobroker/node_modules/iobroker.tankerkoenig/admin/build/index.js.map build/index.js.map application/json
                upload [2] tankerkoenig.admin /opt/iobroker/node_modules/iobroker.tankerkoenig/admin/index_m.html index_m.html text/html
                upload [1] tankerkoenig.admin /opt/iobroker/node_modules/iobroker.tankerkoenig/admin/style.css style.css text/css
                upload [0] tankerkoenig.admin /opt/iobroker/node_modules/iobroker.tankerkoenig/admin/tankerkoenig.png tankerkoenig.png image/png
                host.IOBroker Adapter "system.adapter.tankerkoenig.0" is started
                host.IOBroker Adapter "system.adapter.tankerkoenig.1" is started
                der log
                0 verbose cli /usr/bin/node /usr/bin/npm
                1 info using npm@8.19.3
                2 info using node@v16.19.0
                3 timing npm:load:whichnode Completed in 1ms
                4 timing config:load:defaults Completed in 8ms
                5 timing config:load:file:/usr/lib/node_modules/npm/npmrc Completed in 3ms
                6 timing config:load:builtin Completed in 5ms
                7 timing config:load:cli Completed in 25ms
                8 timing config:load:env Completed in 1ms
                9 timing config:load:file:/opt/iobroker/.npmrc Completed in 31ms
                10 timing config:load:project Completed in 48ms
                11 timing config:load:file:/home/iobroker/.npmrc Completed in 1ms
                12 timing config:load:user Completed in 2ms
                13 timing config:load:file:/usr/etc/npmrc Completed in 0ms
                14 timing config:load:global Completed in 1ms
                15 timing config:load:validate Completed in 1ms
                16 timing config:load:credentials Completed in 6ms
                17 timing config:load:setEnvs Completed in 5ms
                18 timing config:load Completed in 108ms
                19 timing npm:load:configload Completed in 109ms
                20 timing npm:load:mkdirpcache Completed in 4ms
                21 timing npm:load:mkdirplogs Completed in 7ms
                22 verbose title npm install iobroker.tankerkoenig@3.3.7
                23 verbose argv "install" "--save-exact" "iobroker.tankerkoenig@3.3.7"
                24 timing npm:load:setTitle Completed in 9ms
                25 timing config:load:flatten Completed in 17ms
                26 timing npm:load:display Completed in 22ms
                27 verbose logfile logs-max:10 dir:/home/iobroker/.npm/_logs
                28 verbose logfile /home/iobroker/.npm/_logs/2023-02-13T11_50_32_017Z-debug-0.log
                29 timing npm:load:logFile Completed in 36ms
                30 timing npm:load:timers Completed in 0ms
                31 timing npm:load:configScope Completed in 0ms
                32 timing npm:load Completed in 194ms
                33 timing arborist:ctor Completed in 7ms
                34 silly logfile start cleaning logs, removing 4 files
                35 verbose shrinkwrap failed to load node_modules/.package-lock.json out of date, updated: node_modules
                36 silly logfile done cleaning log files
                37 timing idealTree Completed in 8644ms
                38 timing command:install Completed in 8682ms
                39 verbose stack TypeError: Cannot read properties of null (reading 'parent')
                39 verbose stack     at Arborist.[resolveLinks] (/usr/lib/node_modules/npm/node_modules/@npmcli/arborist/lib/arborist/load-virtual.js:229:24)
                39 verbose stack     at Arborist.[loadFromShrinkwrap] (/usr/lib/node_modules/npm/node_modules/@npmcli/arborist/lib/arborist/load-virtual.js:103:29)
                39 verbose stack     at Arborist.loadVirtual (/usr/lib/node_modules/npm/node_modules/@npmcli/arborist/lib/arborist/load-virtual.js:75:35)
                39 verbose stack     at async Arborist.buildIdealTree (/usr/lib/node_modules/npm/node_modules/@npmcli/arborist/lib/arborist/build-ideal-tree.js:208:7)
                39 verbose stack     at async Promise.all (index 1)
                39 verbose stack     at async Arborist.reify (/usr/lib/node_modules/npm/node_modules/@npmcli/arborist/lib/arborist/reify.js:154:5)
                39 verbose stack     at async Install.exec (/usr/lib/node_modules/npm/lib/commands/install.js:145:5)
                39 verbose stack     at async module.exports (/usr/lib/node_modules/npm/lib/cli.js:78:5)
                40 verbose cwd /opt/iobroker
                41 verbose Linux 5.15.84-v8+
                42 verbose node v16.19.0
                43 verbose npm  v8.19.3
                44 error Cannot read properties of null (reading 'parent')
                45 verbose exit 1
                46 timing npm Completed in 10677ms
                47 verbose unfinished npm timer reify 1676289034004
                48 verbose unfinished npm timer reify:loadTrees 1676289034023
                49 verbose unfinished npm timer idealTree:init 1676289034027
                50 verbose code 1
                51 error A complete log of this run can be found in:
                51 error     /home/iobroker/.npm/_logs/2023-02-13T11_50_32_017Z-debug-0.log
                Glasfaser 3 Replies Last reply Reply Quote 0
                • Glasfaser
                  hast du ein NodeJS upgrade mal gemacht !?
                  versuche mal :
                  cd /opt/iobroker/node_modules
                  npm install --omit=dev
                  sudo reboot
                  Ich habe keine Ahnung was das ist 'parent' , auf was es sich bezieht ...
                    @glasfaser
                    npm ERR!     /home/iobroker/.npm/_logs/2023-02-13T12_02_04_657Z-debug-0.log
                    😐 das ist gut
                    • Glasfaser
                      dann ...
                      rm /opt/iobroker/node_modules/.package-lock.json
                      rm /opt/iobroker/node_modules/iobroker.javascript/node_modules/.package-lock.json
                      rm /opt/iobroker/package-lock.json
                      iob rebuild
                      B Thomas Braun 2 Replies Last reply Reply Quote 1
                      • wendy2702
                        2023-02-13T12_02_04
                        Mal so zwischendurch gefragt:
                        Stimmen deine Zeiteinstellungen?
                          @wendy2702 ja stimmen 🙂
                          • wendy2702
                            @backfisch88 Wieso dann im log eine Stunde hinter der Zeit oder steht der nicht in Deutschland bzw. in der gleichen Zeitzone?
                              @glasfaser also das läuft durch.... und der
                              scheint auch zu klappen... aus Interesse... was war es jetzt? 😄
                                @wendy2702 said in npm ERR! Cannot read properties of null (reading 'parent'):
                                das ist ne >hervorragende Frage... kann das eventuell mit der Sommer /Winterzeit zusammen hängen?
                                pi@IOBroker:~ $ date
                                Mon 13 Feb 13:17:47 CET 2023
                                  Thomas Braun Most Active @Glasfaser last edited by
                                  @glasfaser
                                  Ich überlege, ob die vier Zeilen nicht auch was für den iob fix wären.
                                  Hat bei mir gestern in etwas anderem Zusammenhang auch geholfen.
                                  Glasfaser 2 Replies Last reply Reply Quote 1
                                  • Glasfaser
                                    Glasfaser @Thomas Braun last edited by
                                    @thomas-braun sagte in npm ERR! Cannot read properties of null (reading 'parent'):
                                    Ja ... ich weiß ...
                                    Bei Github war ich auch kurz dabei nur konnte ich diesen ( Fehler ) nicht simulieren
                                    • Glasfaser
                                      @Thomas-Braun
                                      Man sollte beobachten , bzw. ist mir schon öfters auch schon aufgefallen , das diese Meldung bei vielen erscheint !?
                                        @glasfaser sagte in npm ERR! Cannot read properties of null (reading 'parent'):
                                        Ja, das Format hat sich bei aktuelleren npm-Versionen geändert. Sollte eigentlich automatisch umgestellt werden, funktioniert aber offenbar nicht immer einwandfrei. Mit frischen package*-Files geht es dann.
                                          backfisch88 @Thomas Braun last edited by
                                          @Glasfaser
                                          @glasfaser
                                          der Adapter ist jetzt geupdated.. Hab mal zum test einfach n neuen Adapter installiert... das dauert ewig und es geht nix voran
                                          dann kommt irgendwann
                                          npm WARN skipping integrity check for git dependency ssh://git@github.com/Newan/ioBroker.yahoo-stock-market.git
                                          npm WARN skipping integrity check for git dependency ssh://git@github.com/Steiger04/ioBroker.radar-trap2.git
                                          npm WARN skipping integrity check for git dependency ssh://git@github.com/excal-foley/ioBroker.blockly-plus.git
                                          sind alles Adapter aus github (nicht in der offiziellen list)
                                          das geht dann aber irgendwann und dann kommt bei jedem update aber wieder der gleiche Fehler
                                          Glasfaser 2 Replies Last reply Reply Quote 0
                                          • Glasfaser
                                            Glasfaser @Thomas Braun last edited by Glasfaser
                                            Dann wäre es ein Vorschlag ... den man eventuell mit umsetzen sollte !
                                            2900
