      ronny130286 @DaPeace last edited by ronny130286
      @Armilar @DaPeace
      mir ist bei der popupNotify auch aufgefallen.
      // Notification to screensaver
              on({ id: [screensaverNotifyHeading, screensaverNotifyText], change: 'ne', ack: false }, async (obj) => {
                  const heading = getState(screensaverNotifyHeading).val;
                  const text = getState(screensaverNotifyText).val;
                  setIfExists(config.panelSendTopic, `notify~${heading}~${text}`);
                  if (obj.id) {
                      await setStateAsync(obj.id, <iobJS.State>{ val: obj.state.val, ack: true }); // ack new value
       // popupNotify - Notification an separate Seite
              on({ id: [popupNotifyInternalName], change: 'ne' }, async () => {
                  let notification: string;
                  let v_popupNotifyHeadingColor = (getState(popupNotifyHeadingColor).val != null) ? getState(popupNotifyHeadingColor).val  : '65504'// Farbe Headline - gelb 65504
                  let v_popupNotifyButton1TextColor = (getState(popupNotifyButton1TextColor).val != null) ? getState(popupNotifyButton1TextColor).val  : '63488'// Farbe Headline - gelb 65504
                  let v_popupNotifyButton2TextColor = (getState(popupNotifyButton2TextColor).val != null) ? getState(popupNotifyButton2TextColor).val  : '2016'// Farbe Headline - gelb 65504
                  let v_popupNotifyTextColor = (getState(popupNotifyTextColor).val != null) ? getState(popupNotifyTextColor).val : '65535'// Farbe Headline - gelb 65504
                  let v_popupNotifyIconColor = (getState(popupNotifyIconColor).val != null) ? getState(popupNotifyIconColor).val  : '65535'// Farbe Headline - gelb 65504
                  let v_popupNotifyFontIdText = (getState(popupNotifyFontIdText).val != null) ? getState(popupNotifyFontIdText).val  : '1'
                  let v_popupNotifyIcon = (getState(popupNotifyIcon).val != null) ? getState(popupNotifyIcon).val : 'alert'
                  notification = 'entityUpdateDetail' + '~'
                      + getState(popupNotifyInternalName).val + '~'
                      + getState(popupNotifyHeading).val + '~'
                      + v_popupNotifyHeadingColor + '~'
                      + getState(popupNotifyButton1Text).val + '~'
                      + v_popupNotifyButton1TextColor + '~'
                      + getState(popupNotifyButton2Text).val + '~'
                      + v_popupNotifyButton2TextColor + '~'
                      + getState(popupNotifyText).val + '~'
                      + v_popupNotifyTextColor + '~'
                      + getState(popupNotifySleepTimeout).val;
                  if (getState(popupNotifyLayout).val == 2) {
                      notification = notification + '~'
                      + v_popupNotifyFontIdText + '~'
                      + Icons.GetIcon(v_popupNotifyIcon) + '~'
                      + v_popupNotifyIconColor;
                  setIfExists(config.panelSendTopic, 'pageType~popupNotify');
                  setIfExists(config.panelSendTopic, notification);
      Wenn du mehrfach nacheinander ein Ereignis hast was den gleichen InternalName verwendet (bspw. Abfall), dann erscheint die Seite nicht mehr.
      Abhilfe schafft nur wenn ne => durch any zu ersetzt
      on({ id: [popupNotifyInternalName], change: 'any' }, async () => {
      Das gleiche "Problem" hast du auch beim popupNotifyHeading und screensaverNotifyText , wenn dort immer das gleich eingetragen wird, dann erscheint es nicht mehr, auch hier muss ne durch any ersetzt werden
      on({ id: [screensaverNotifyHeading, screensaverNotifyText], change: 'any', ack: false }, async (obj) => {
      • Armilar
        Armilar Most Active Forum Testing @ronny130286 last edited by
        @ronny130286
        Kann man machen, wäre auch kein Problem...
        Würde an der Situation aber ja nichts verändern, da das Panel bei "gleichen Daten" im Fall von "ne" ja bereits die Daten anzeigt, und somit auch keine Aktionen notwendig sind.
        Sollte sich ein Wert ändern, so wird dieser auch mit "ne" überschrieben und aktualisiert.
        Mögliche Änderungen sind. Ein Text verändert sich um mindestens ein Zeichen oder der Inhalt der DP verändert sich dadurch, das es mit Klick auf den Screensaver in der bExit geleert (notify~~ ) wird.
        Armilar R 2 Replies Last reply Reply Quote 0
        • Armilar
          Armilar Most Active Forum Testing @DaPeace last edited by Armilar
          @dapeace
          Bei der Aktion hätte etwas im Panel stehen müssen.
          Wie sind deine MQTT-Einstellungen in der MQTT-Instanz? Direkte Kommunikation oder über Umwege (Mosquitto extern)
          Bei denen wurde auch eine Aktualisierung durchgeführt
          oder
          • Armilar
            Armilar Most Active Forum Testing @Armilar last edited by Armilar
            @armilar
            Interessant ist darüber hinaus natürlich der Eintrag:
            Der Hätte, sofern nicht der gleiche Inhalt bereits im DP gestanden hat, auch getriggert werden müssen.
            Für die Tests kannst du die Trigger natürlich auch auf "any" setzten. Dann werden ja alle Ereignisse mitgenommen... Auch wenn sich der Text nicht ändert.
              ronny130286 @Armilar last edited by ronny130286
              @armilar said in SONOFF NSPanel mit Lovelace UI:
              Ah ok , ich habs noch mal probiert beim Screensaver wirds geleert, bei Popup Nachricht bleibt alles drin.
              Armilar 1 Reply Last reply Reply Quote 1
                DaPeace @Armilar last edited by
                @armilar
                So schauen die MQTT-Einstellungen aus. Das läuft direkt über ioB. Mosquitto hab ich zwar auch am Laufen aber nur weil ich zu Faul bin alles umzustellen.
                Die Datenpunkte habe ich vorher leer gemacht und dann das Skript erst laufen lassen per Cron das auch wirklich was passiert und ich es sehe. Das das Löschen der DP funktioniert hatte ich dir ja im Eingangspost schon bestätigt.
                Ob beim Manuellen Eintrag was passiert kann ich erst am Nachmittag sagen.. Bin noch Brötchen verdienen..
                • Armilar
                  Armilar Most Active Forum Testing last edited by
                  @dapeace
                  Na dann noch viel Spaß bei der Arbeit und bis später 😊
                  • Armilar
                    Armilar Most Active Forum Testing @ronny130286 last edited by Armilar
                    @ronny130286
                    Ja, bei der popUpNotify könnte ein "any" rein. Ich habe die jetzt mal angepasst. Schaden kann es definitiv nicht...
                      @armilar Soll ich bei mir das Skript auch mal mit anpassen und die ne auf any nehmen und probieren? Müsste ich ja auch in den logs schon sehen ob mein Müllscript das mag.
                      • Armilar
                        @dapeace
                        Ja, ändere das mal ab. Und verwende in deinem Müllskript mal "steuere" statt "aktualisiere".
                          @armilar Interessant.. jetzt hab ich die 2 Punkte auf any geändert und das Blocky auf "steuere" und jetzt hab ich plötzlich auch ZWEI Notify-Einträge direkt hintereinander mit dem selben 2notify~GelberSack,Restmüll~13.02.2023"im CustomSend.
                          Bin gespannt ob das auch angezeigt wird. Ich logge mal noch den Result mit und schaue mal ob das Panel auch reagiert aber ich gehe mal stark davon aus.
                          • Armilar
                            Armilar Most Active Forum Testing last edited by Armilar
                            @dapeace
                            Ich gehe da mal von aus. Wenn du den "aktualisiere" verwendest, was ja im Prinzip ein Adapter in einem 2. Schritt erledigt, dann weiß der Script-Trigger oder alternativ ein Adapter ja nicht, dass da noch etwas zu tun ist. Also nur "aktualisiere" verwenden, wenn mit dem Eintrag "nichts" mehr passieren soll...
                            D Armilar 2 Replies Last reply Reply Quote 0
                              @armilar Ich kann mal Vollzug vermelden. Jetzt funktioniert es wie es soll. Danke für die Hilfe!
                              • Armilar
                                @dapeace
                                Ja perfekt. Dachte schon es wäre was schlimmes 😉
                                Ggfs. auch mal in anderen Skripten überprüfen, ob da der falsche Baustein verwendet wurde... 😊
                                  michael_4358 last edited by
                                  hallo zusammen
                                  kann ich mit dem Panel auch eine Seite für den repetier server einrichten❓
                                  also eine Seite dir mir Daten des drucks anzeigt❓
                                  bin leider nicht so Sattelfest im Thema repetier...
                                  ggf könnt ihr ne denk Hilfe geben❓❓❓
                                  • Armilar
                                    Armilar Most Active Forum Testing @michael_4358 last edited by Armilar
                                    @michael_4358
                                    kann ich mit dem Panel auch eine Seite für den repetier server einrichten?
                                    Was liefert der denn für Daten und welche sollen angezeigt werden?
                                    Gibt es eine Übersicht an relevanten Datenpunkten?
                                      michael_4358 @Armilar last edited by
                                      @michael_4358
                                      mir würde reichen online /offline
                                      status des drucks in Prozent
                                      restzeit
                                      • Armilar
                                        @michael_4358
                                        okay - und in welchen Datenpunkten sind dann die Infos über online (true/false) und die Restzeit und Fortschritt?
                                        Das sind ja irgendwie die falschen im Bild 😉
                                          @michael_4358
                                          Oje… du hast recht 👨‍⚖️ das is wenn man an zwei Systemen zeitgleich ackert…
                                          Aber es sind im Prinzip die gleichen datenpunkte..
                                            mschmidt last edited by mschmidt
                                            Re: SONOFF NSPanel mit Lovelace UI
                                            ich habe mich in den letzten Tagen durch das Wiki und die Installationsanleitung gekämpft und habe mein erstes NSPanel schon in Benutzung. Hat soweit alles ganz gut funktioniert ( Danke an alle die diese Anleitung unterstützt haben) Ich habe nun ein Punkt wo ich selbst keine Idee mehr habe. Es geht um die Implementierung der Seite des Abfallkalenders. Ich bekomme es nicht hin die Farbe der Icons entsprechend des Blocklys anzuzeigen. Alle Icons sind in schwarz dargestellt. So wie ich das verstehe werden in dem Blockly die Farben in Color Datenpunkt gesetzt. Dort stehen sie bei mir jedoch nicht.
                                            Hat jemand vielleicht einen Hinweis für mich woran das liegen kann?
                                            Danke!
                                            Oh Mist eigentlich sollte das in den Thread "SONOFF NSPanel mit Lovelace UI" Kann ich das irgendwie verschieben?
                                            Homoran Armilar 2 Replies Last reply Reply Quote 0
                                            lovelace ui nspanel sonoff
                                            270
                                            7690
                                            6527519
