    4. Stiebel-ISG - Modbus
      Thomas Braun Most Active @C.K. 0 last edited by
      @c-k-0 An felhlenden LogFiles von dir?
        Wie bekomme ich die LogFiles?
          @c-k-0
          iob logs --watch | uniq
          Dann den Adapter neustarten, Ausgaben aus der Konsole hier in CodeTags eingebettet reinkopieren.
            C.K. 0 @Thomas Braun last edited by C.K. 0
            on. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
            2022-11-07 20:04:45.830  - error: stiebel-isg.0 (3580) unhandled promise rejection: connect EHOSTUNREACH 192.168.178.32:80
            2022-11-07 20:04:45.830  - error: stiebel-isg.0 (3580) Error: connect EHOSTUNREACH 192.168.178.32:80
                at TCPConnectWrap.afterConnect [as oncomplete] (node:net:1278:16)
            2022-11-07 20:04:45.830  - error: stiebel-isg.0 (3580) Exception-Code: EHOSTUNREACH: connect EHOSTUNREACH 192.168.178.32:80
            2022-11-07 20:04:45.832  - error: stiebel-isg.0 (3580) Error: Error: connect EHOSTUNREACH 192.168.178.32:80
            2022-11-07 20:04:45.832  - error: stiebel-isg.0 (3580) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
            2022-11-07 20:04:45.833  - error: stiebel-isg.0 (3580) unhandled promise rejection: connect EHOSTUNREACH 192.168.178.32:80
            2022-11-07 20:04:45.833  - error: stiebel-isg.0 (3580) Error: connect EHOSTUNREACH 192.168.178.32:80
            2022-11-07 20:04:45.833  - error: stiebel-isg.0 (3580) Exception-Code: EHOSTUNREACH: connect EHOSTUNREACH 192.168.178.32:80
            2022-11-07 20:04:45.835  - error: stiebel-isg.0 (3580) Error: Error: connect EHOSTUNREACH 192.168.178.32:80
            2022-11-07 20:04:45.835  - error: stiebel-isg.0 (3580) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
            2022-11-07 20:04:45.836  - error: stiebel-isg.0 (3580) unhandled promise rejection: connect EHOSTUNREACH 192.168.178.32:80
            2022-11-07 20:04:45.836  - error: stiebel-isg.0 (3580) Error: connect EHOSTUNREACH 192.168.178.32:80
            2022-11-07 20:04:45.836  - error: stiebel-isg.0 (3580) Exception-Code: EHOSTUNREACH: connect EHOSTUNREACH 192.168.178.32:80
            2022-11-07 20:04:45.870  - info: stiebel-isg.0 (3580) cleaned everything up...
            2022-11-07 20:04:45.871  - info: stiebel-isg.0 (3580) terminating
            2022-11-07 20:04:45.873  - warn: stiebel-isg.0 (3580) Terminated (UNCAUGHT_EXCEPTION): Without reason
            2022-11-07 20:04:46.429  - error: host.iobroker instance system.adapter.stiebel-isg.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
            2022-11-07 20:04:46.431  - info: host.iobroker Restart adapter system.adapter.stiebel-isg.0 because enabled
            2022-11-07 20:04:46.433  - warn: host.iobroker Do not restart adapter system.adapter.stiebel-isg.0 because restart loop detected
            2022-11-07 20:04:51.105  - info: host.iobroker instance system.adapter.stiebel-isg.0 started with pid 3597
            2022-11-07 20:04:52.166  - info: admin.0 (879) <== Disconnect system.user.admin from ::ffff:192.168.178.87
            2022-11-07 20:04:53.639  - info: stiebel-isg.0 (3597) starting. Version 1.7.5 in /opt/iobroker/node_modules/iobroker.stiebel-isg, node: v16.18.1, js-controller: 4.0.23
            2022-11-07 20:04:54.915  - info: host.iobroker stopInstance system.adapter.stiebel-isg.0 (force=false, process=true)
            2022-11-07 20:04:54.927  - info: stiebel-isg.0 (3597) Got terminate signal TERMINATE_YOURSELF
            2022-11-07 20:04:54.930  - info: stiebel-isg.0 (3597) cleaned everything up...
            2022-11-07 20:04:54.932  - info: stiebel-isg.0 (3597) terminating
            2022-11-07 20:04:54.938  - info: stiebel-isg.0 (3597) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
            2022-11-07 20:04:54.968  - info: host.iobroker stopInstance system.adapter.stiebel-isg.0 send kill signal
            2022-11-07 20:04:55.541  - info: host.iobroker instance system.adapter.stiebel-isg.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
            2022-11-07 20:04:57.995  - info: host.iobroker instance system.adapter.stiebel-isg.0 started with pid 3612
            2022-11-07 20:04:59.127  - info: host.iobroker stopInstance system.adapter.stiebel-isg.0 (force=false, process=true)
            2022-11-07 20:04:59.179  - info: host.iobroker stopInstance system.adapter.stiebel-isg.0 send kill signal
            2022-11-07 20:05:00.181  - info: host.iobroker stopInstance system.adapter.stiebel-isg.0 killing pid 3612
            2022-11-07 20:05:00.421  - info: stiebel-isg.0 (3612) starting. Version 1.7.5 in /opt/iobroker/node_modules/iobroker.stiebel-isg, node: v16.18.1, js-controller: 4.0.23
            2022-11-07 20:05:00.707  - info: stiebel-isg.0 (3612) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
            2022-11-07 20:05:01.254  - info: host.iobroker instance system.adapter.stiebel-isg.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
            2022-11-07 20:05:02.209  - info: host.iobroker instance system.adapter.stiebel-isg.0 started with pid 3627
            2022-11-07 20:05:02.838  - info: host.iobroker stopInstance system.adapter.stiebel-isg.0 (force=false, process=true)
            2022-11-07 20:05:02.891  - info: host.iobroker stopInstance system.adapter.stiebel-isg.0 send kill signal
            2022-11-07 20:05:03.894  - info: host.iobroker stopInstance system.adapter.stiebel-isg.0 killing pid 3627
            2022-11-07 20:05:03.935  - warn: host.iobroker instance system.adapter.stiebel-isg.0 terminated due to SIGTERM
            2022-11-07 20:05:03.936  - info: host.iobroker instance system.adapter.stiebel-isg.0 terminated with code null ()
            2022-11-07 20:05:05.920  - info: host.iobroker instance system.adapter.stiebel-isg.0 started with pid 3634
            2022-11-07 20:05:07.702  - info: stiebel-isg.0 (3634) starting. Version 1.7.5 in /opt/iobroker/node_modules/iobroker.stiebel-isg, node: v16.18.1, js-controller: 4.0.23
            2022-11-07 20:05:08.046  - info: host.iobroker stopInstance system.adapter.stiebel-isg.0 (force=false, process=true)
            2022-11-07 20:05:08.109  - info: host.iobroker stopInstance system.adapter.stiebel-isg.0 send kill signal
            2022-11-07 20:05:08.238  - info: stiebel-isg.0 (3634) Got terminate signal TERMINATE_YOURSELF
            2022-11-07 20:05:08.243  - info: stiebel-isg.0 (3634) cleaned everything up...
            2022-11-07 20:05:08.245  - info: stiebel-isg.0 (3634) terminating
            2022-11-07 20:05:08.247  - info: stiebel-isg.0 (3634) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
            2022-11-07 20:05:08.808  - info: host.iobroker instance system.adapter.stiebel-isg.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
            2022-11-07 20:05:11.142  - info: host.iobroker instance system.adapter.stiebel-isg.0 started with pid 3649
            2022-11-07 20:05:13.388  - info: admin.0 (879) ==> Connected system.user.admin from ::ffff:192.168.178.87
            2022-11-07 20:05:13.892  - info: stiebel-isg.0 (3649) starting. Version 1.7.5 in /opt/iobroker/node_modules/iobroker.stiebel-isg, node: v16.18.1, js-controller: 4.0.23
            2022-11-07 20:05:16.561  - info: host.iobroker stopInstance system.adapter.stiebel-isg.0 (force=false, process=true)
            2022-11-07 20:05:16.572  - info: stiebel-isg.0 (3649) Got terminate signal TERMINATE_YOURSELF
            2022-11-07 20:05:16.576  - info: stiebel-isg.0 (3649) cleaned everything up...
            2022-11-07 20:05:16.577  - info: stiebel-isg.0 (3649) terminating
            2022-11-07 20:05:16.582  - info: stiebel-isg.0 (3649) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
            2022-11-07 20:05:16.614  - info: host.iobroker stopInstance system.adapter.stiebel-isg.0 send kill signal
            2022-11-07 20:05:17.152  - info: host.iobroker instance system.adapter.stiebel-isg.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
            2022-11-07 20:05:17.433  - info: admin.0 (879) <== Disconnect system.user.admin from ::ffff:192.168.178.87
            2022-11-07 20:05:19.643  - info: host.iobroker instance system.adapter.stiebel-isg.0 started with pid 3665
            2022-11-07 20:05:21.695  - info: stiebel-isg.0 (3665) starting. Version 1.7.5 in /opt/iobroker/node_modules/iobroker.stiebel-isg, node: v16.18.1, js-controller: 4.0.23
            2022-11-07 20:05:25.008  - error: stiebel-isg.0 (3665) Error: Error: connect EHOSTUNREACH 192.168.178.32:80
            2022-11-07 20:05:25.012  - error: stiebel-isg.0 (3665) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
            2022-11-07 20:05:25.012  - error: stiebel-isg.0 (3665) unhandled promise rejection: connect EHOSTUNREACH 192.168.178.32:80
            2022-11-07 20:05:25.014  - error: stiebel-isg.0 (3665) Error: connect EHOSTUNREACH 192.168.178.32:80
            2022-11-07 20:05:25.014  - error: stiebel-isg.0 (3665) Exception-Code: EHOSTUNREACH: connect EHOSTUNREACH 192.168.178.32:80
            2022-11-07 20:05:25.017  - error: stiebel-isg.0 (3665) Error: Error: connect EHOSTUNREACH 192.168.178.32:80
            2022-11-07 20:05:25.017  - error: stiebel-isg.0 (3665) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
            2022-11-07 20:05:25.018  - error: stiebel-isg.0 (3665) unhandled promise rejection: connect EHOSTUNREACH 192.168.178.32:80
            2022-11-07 20:05:25.019  - error: stiebel-isg.0 (3665) Error: connect EHOSTUNREACH 192.168.178.32:80
            2022-11-07 20:05:25.020  - error: stiebel-isg.0 (3665) Exception-Code: EHOSTUNREACH: connect EHOSTUNREACH 192.168.178.32:80
            2022-11-07 20:05:25.022  - error: stiebel-isg.0 (3665) Error: Error: connect EHOSTUNREACH 192.168.178.32:80
            2022-11-07 20:05:25.023  - error: stiebel-isg.0 (3665) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
            2022-11-07 20:05:25.024  - error: stiebel-isg.0 (3665) unhandled promise rejection: connect EHOSTUNREACH 192.168.178.32:80
            2022-11-07 20:05:25.024  - error: stiebel-isg.0 (3665) Error: connect EHOSTUNREACH 192.168.178.32:80
            2022-11-07 20:05:25.025  - error: stiebel-isg.0 (3665) Exception-Code: EHOSTUNREACH: connect EHOSTUNREACH 192.168.178.32:80
            2022-11-07 20:05:25.026  - error: stiebel-isg.0 (3665) Error: Error: connect EHOSTUNREACH 192.168.178.32:80
            2022-11-07 20:05:25.027  - error: stiebel-isg.0 (3665) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
            2022-11-07 20:05:25.027  - error: stiebel-isg.0 (3665) unhandled promise rejection: connect EHOSTUNREACH 192.168.178.32:80
            2022-11-07 20:05:25.028  - error: stiebel-isg.0 (3665) Error: connect EHOSTUNREACH 192.168.178.32:80
            2022-11-07 20:05:25.028  - error: stiebel-isg.0 (3665) Exception-Code: EHOSTUNREACH: connect EHOSTUNREACH 192.168.178.32:80
            2022-11-07 20:05:25.029  - error: stiebel-isg.0 (3665) Error: Error: connect EHOSTUNREACH 192.168.178.32:80
            2022-11-07 20:05:25.030  - error: stiebel-isg.0 (3665) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
            2022-11-07 20:05:25.031  - error: stiebel-isg.0 (3665) unhandled promise rejection: connect EHOSTUNREACH 192.168.178.32:80
            2022-11-07 20:05:25.031  - error: stiebel-isg.0 (3665) Error: connect EHOSTUNREACH 192.168.178.32:80
            2022-11-07 20:05:25.031  - error: stiebel-isg.0 (3665) Exception-Code: EHOSTUNREACH: connect EHOSTUNREACH 192.168.178.32:80
            2022-11-07 20:05:25.032  - error: stiebel-isg.0 (3665) Error: Error: connect EHOSTUNREACH 192.168.178.32:80
            2022-11-07 20:05:25.033  - error: stiebel-isg.0 (3665) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
            2022-11-07 20:05:25.033  - error: stiebel-isg.0 (3665) unhandled promise rejection: connect EHOSTUNREACH 192.168.178.32:80
            2022-11-07 20:05:25.033  - error: stiebel-isg.0 (3665) Error: connect EHOSTUNREACH 192.168.178.32:80
            2022-11-07 20:05:25.034  - error: stiebel-isg.0 (3665) Exception-Code: EHOSTUNREACH: connect EHOSTUNREACH 192.168.178.32:80
            2022-11-07 20:05:25.060  - info: stiebel-isg.0 (3665) cleaned everything up...
            2022-11-07 20:05:25.061  - info: stiebel-isg.0 (3665) terminating
            2022-11-07 20:05:25.063  - warn: stiebel-isg.0 (3665) Terminated (UNCAUGHT_EXCEPTION): Without reason
            2022-11-07 20:05:25.640  - error: host.iobroker instance system.adapter.stiebel-isg.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
            2022-11-07 20:05:25.641  - info: host.iobroker Restart adapter system.adapter.stiebel-isg.0 because enabled
            2022-11-07 20:05:55.668  - info: host.iobroker instance system.adapter.stiebel-isg.0 started with pid 3680
            2022-11-07 20:05:57.651  - info: stiebel-isg.0 (3680) starting. Version 1.7.5 in /opt/iobroker/node_modules/iobroker.stiebel-isg, node: v16.18.1, js-controller: 4.0.23
            2022-11-07 20:06:00.976  - error: stiebel-isg.0 (3680) Error: Error: connect EHOSTUNREACH 192.168.178.32:80
            2022-11-07 20:06:00.980  - error: stiebel-isg.0 (3680) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
            2022-11-07 20:06:00.980  - error: stiebel-isg.0 (3680) unhandled promise rejection: connect EHOSTUNREACH 192.168.178.32:80
            2022-11-07 20:06:00.982  - error: stiebel-isg.0 (3680) Error: connect EHOSTUNREACH 192.168.178.32:80
            2022-11-07 20:06:00.982  - error: stiebel-isg.0 (3680) Exception-Code: EHOSTUNREACH: connect EHOSTUNREACH 192.168.178.32:80
            2022-11-07 20:06:00.988  - error: stiebel-isg.0 (3680) Error: Error: connect EHOSTUNREACH 192.168.178.32:80
            2022-11-07 20:06:00.990  - error: stiebel-isg.0 (3680) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
            2022-11-07 20:06:00.991  - error: stiebel-isg.0 (3680) unhandled promise rejection: connect EHOSTUNREACH 192.168.178.32:80
            2022-11-07 20:06:00.993  - error: stiebel-isg.0 (3680) Error: connect EHOSTUNREACH 192.168.178.32:80
            2022-11-07 20:06:00.994  - error: stiebel-isg.0 (3680) Exception-Code: EHOSTUNREACH: connect EHOSTUNREACH 192.168.178.32:80
            2022-11-07 20:06:00.996  - error: stiebel-isg.0 (3680) Error: Error: connect EHOSTUNREACH 192.168.178.32:80
            2022-11-07 20:06:00.997  - error: stiebel-isg.0 (3680) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
            2022-11-07 20:06:00.998  - error: stiebel-isg.0 (3680) unhandled promise rejection: connect EHOSTUNREACH 192.168.178.32:80
            2022-11-07 20:06:00.998  - error: stiebel-isg.0 (3680) Error: connect EHOSTUNREACH 192.168.178.32:80
            2022-11-07 20:06:00.999  - error: stiebel-isg.0 (3680) Exception-Code: EHOSTUNREACH: connect EHOSTUNREACH 192.168.178.32:80
            2022-11-07 20:06:01.000  - error: stiebel-isg.0 (3680) Error: Error: connect EHOSTUNREACH 192.168.178.32:80
            2022-11-07 20:06:01.001  - error: stiebel-isg.0 (3680) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
            2022-11-07 20:06:01.001  - error: stiebel-isg.0 (3680) unhandled promise rejection: connect EHOSTUNREACH 192.168.178.32:80
            2022-11-07 20:06:01.002  - error: stiebel-isg.0 (3680) Error: connect EHOSTUNREACH 192.168.178.32:80
            2022-11-07 20:06:01.003  - error: stiebel-isg.0 (3680) Exception-Code: EHOSTUNREACH: connect EHOSTUNREACH 192.168.178.32:80
            2022-11-07 20:06:01.005  - error: stiebel-isg.0 (3680) Error: Error: connect EHOSTUNREACH 192.168.178.32:80
            2022-11-07 20:06:01.006  - error: stiebel-isg.0 (3680) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
            2022-11-07 20:06:01.007  - error: stiebel-isg.0 (3680) unhandled promise rejection: connect EHOSTUNREACH 192.168.178.32:80
            2022-11-07 20:06:01.007  - error: stiebel-isg.0 (3680) Error: connect EHOSTUNREACH 192.168.178.32:80
            2022-11-07 20:06:01.008  - error: stiebel-isg.0 (3680) Exception-Code: EHOSTUNREACH: connect EHOSTUNREACH 192.168.178.32:80
            2022-11-07 20:06:01.010  - error: stiebel-isg.0 (3680) Error: Error: connect EHOSTUNREACH 192.168.178.32:80
            2022-11-07 20:06:01.012  - error: stiebel-isg.0 (3680) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
            2022-11-07 20:06:01.012  - error: stiebel-isg.0 (3680) unhandled promise rejection: connect EHOSTUNREACH 192.168.178.32:80
            2022-11-07 20:06:01.013  - error: stiebel-isg.0 (3680) Error: connect EHOSTUNREACH 192.168.178.32:80
            2022-11-07 20:06:01.014  - error: stiebel-isg.0 (3680) Exception-Code: EHOSTUNREACH: connect EHOSTUNREACH 192.168.178.32:80
            2022-11-07 20:06:01.018  - info: stiebel-isg.0 (3680) cleaned everything up...
            2022-11-07 20:06:01.019  - info: stiebel-isg.0 (3680) terminating
            2022-11-07 20:06:01.021  - warn: stiebel-isg.0 (3680) Terminated (UNCAUGHT_EXCEPTION): Without reason
            2022-11-07 20:06:01.611  - error: host.iobroker instance system.adapter.stiebel-isg.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
            2022-11-07 20:06:01.612  - info: host.iobroker Restart adapter system.adapter.stiebel-isg.0 because enabled
            2022-11-07 20:06:29.794  - info: host.iobroker instance system.adapter.stiebel-isg.0 started with pid 3703
            2022-11-07 20:06:32.229  - info: stiebel-isg.0 (3703) starting. Version 1.7.5 in /opt/iobroker/node_modules/iobroker.stiebel-isg, node: v16.18.1, js-controller: 4.0.23
            2022-11-07 20:06:35.536  - error: stiebel-isg.0 (3703) Error: Error: connect EHOSTUNREACH 192.168.178.32:80
            2022-11-07 20:06:35.540  - error: stiebel-isg.0 (3703) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
            2022-11-07 20:06:35.540  - error: stiebel-isg.0 (3703) unhandled promise rejection: connect EHOSTUNREACH 192.168.178.32:80
            2022-11-07 20:06:35.542  - error: stiebel-isg.0 (3703) Error: connect EHOSTUNREACH 192.168.178.32:80
            2022-11-07 20:06:35.542  - error: stiebel-isg.0 (3703) Exception-Code: EHOSTUNREACH: connect EHOSTUNREACH 192.168.178.32:80
            2022-11-07 20:06:35.550  - error: stiebel-isg.0 (3703) Error: Error: connect EHOSTUNREACH 192.168.178.32:80
            2022-11-07 20:06:35.551  - error: stiebel-isg.0 (3703) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
            2022-11-07 20:06:35.553  - error: stiebel-isg.0 (3703) unhandled promise rejection: connect EHOSTUNREACH 192.168.178.32:80
            2022-11-07 20:06:35.554  - error: stiebel-isg.0 (3703) Error: connect EHOSTUNREACH 192.168.178.32:80
            2022-11-07 20:06:35.555  - error: stiebel-isg.0 (3703) Exception-Code: EHOSTUNREACH: connect EHOSTUNREACH 192.168.178.32:80
            2022-11-07 20:06:35.557  - error: stiebel-isg.0 (3703) Error: Error: connect EHOSTUNREACH 192.168.178.32:80
            2022-11-07 20:06:35.558  - error: stiebel-isg.0 (3703) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
            2022-11-07 20:06:35.559  - error: stiebel-isg.0 (3703) unhandled promise rejection: connect EHOSTUNREACH 192.168.178.32:80
            2022-11-07 20:06:35.559  - error: stiebel-isg.0 (3703) Error: connect EHOSTUNREACH 192.168.178.32:80
            2022-11-07 20:06:35.560  - error: stiebel-isg.0 (3703) Exception-Code: EHOSTUNREACH: connect EHOSTUNREACH 192.168.178.32:80
            2022-11-07 20:06:35.561  - error: stiebel-isg.0 (3703) Error: Error: connect EHOSTUNREACH 192.168.178.32:80
            2022-11-07 20:06:35.562  - error: stiebel-isg.0 (3703) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
            2022-11-07 20:06:35.562  - error: stiebel-isg.0 (3703) unhandled promise rejection: connect EHOSTUNREACH 192.168.178.32:80
            2022-11-07 20:06:35.563  - error: stiebel-isg.0 (3703) Error: connect EHOSTUNREACH 192.168.178.32:80
            2022-11-07 20:06:35.563  - error: stiebel-isg.0 (3703) Exception-Code: EHOSTUNREACH: connect EHOSTUNREACH 192.168.178.32:80
            2022-11-07 20:06:35.565  - error: stiebel-isg.0 (3703) Error: Error: connect EHOSTUNREACH 192.168.178.32:80
            2022-11-07 20:06:35.565  - error: stiebel-isg.0 (3703) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
            2022-11-07 20:06:35.566  - error: stiebel-isg.0 (3703) unhandled promise rejection: connect EHOSTUNREACH 192.168.178.32:80
            2022-11-07 20:06:35.566  - error: stiebel-isg.0 (3703) Error: connect EHOSTUNREACH 192.168.178.32:80
            2022-11-07 20:06:35.566  - error: stiebel-isg.0 (3703) Exception-Code: EHOSTUNREACH: connect EHOSTUNREACH 192.168.178.32:80
            2022-11-07 20:06:35.567  - error: stiebel-isg.0 (3703) Error: Error: connect EHOSTUNREACH 192.168.178.32:80
            2022-11-07 20:06:35.568  - error: stiebel-isg.0 (3703) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
            2022-11-07 20:06:35.568  - error: stiebel-isg.0 (3703) unhandled promise rejection: connect EHOSTUNREACH 192.168.178.32:80
            2022-11-07 20:06:35.569  - error: stiebel-isg.0 (3703) Error: connect EHOSTUNREACH 192.168.178.32:80
            2022-11-07 20:06:35.569  - error: stiebel-isg.0 (3703) Exception-Code: EHOSTUNREACH: connect EHOSTUNREACH 192.168.178.32:80
            2022-11-07 20:06:35.572  - info: stiebel-isg.0 (3703) cleaned everything up...
            2022-11-07 20:06:35.573  - info: stiebel-isg.0 (3703) terminating
            2022-11-07 20:06:35.574  - warn: stiebel-isg.0 (3703) Terminated (UNCAUGHT_EXCEPTION): Without reason
            2022-11-07 20:06:36.125  - error: host.iobroker instance system.adapter.stiebel-isg.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
            2022-11-07 20:06:36.126  - info: host.iobroker Restart adapter system.adapter.stiebel-isg.0 because enabled
            2022-11-07 20:06:36.126  - warn: host.iobroker Do not restart adapter system.adapter.stiebel-isg.0 because restart loop detected
            2022-11-07 20:07:09.584  - info: host.iobroker "system.adapter.stiebel-isg.0" disabled
            2022-11-07 20:07:13.747  - info: host.iobroker "system.adapter.stiebel-isg.0" enabled
            2022-11-07 20:07:13.826  - info: host.iobroker instance system.adapter.stiebel-isg.0 started with pid 3720
            2022-11-07 20:07:16.686  - info: stiebel-isg.0 (3720) starting. Version 1.7.5 in /opt/iobroker/node_modules/iobroker.stiebel-isg, node: v16.18.1, js-controller: 4.0.23
            2022-11-07 20:07:20.083  - error: stiebel-isg.0 (3720) Error: Error: connect EHOSTUNREACH 192.168.178.32:80
            2022-11-07 20:07:20.088  - error: stiebel-isg.0 (3720) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
            2022-11-07 20:07:20.089  - error: stiebel-isg.0 (3720) unhandled promise rejection: connect EHOSTUNREACH 192.168.178.32:80
            2022-11-07 20:07:20.091  - error: stiebel-isg.0 (3720) Error: connect EHOSTUNREACH 192.168.178.32:80
            2022-11-07 20:07:20.092  - error: stiebel-isg.0 (3720) Exception-Code: EHOSTUNREACH: connect EHOSTUNREACH 192.168.178.32:80
            2022-11-07 20:07:20.095  - error: stiebel-isg.0 (3720) Error: Error: connect EHOSTUNREACH 192.168.178.32:80
            2022-11-07 20:07:20.096  - error: stiebel-isg.0 (3720) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
            2022-11-07 20:07:20.098  - error: stiebel-isg.0 (3720) unhandled promise rejection: connect EHOSTUNREACH 192.168.178.32:80
            2022-11-07 20:07:20.099  - error: stiebel-isg.0 (3720) Error: connect EHOSTUNREACH 192.168.178.32:80
            2022-11-07 20:07:20.100  - error: stiebel-isg.0 (3720) Exception-Code: EHOSTUNREACH: connect EHOSTUNREACH 192.168.178.32:80
            2022-11-07 20:07:20.103  - error: stiebel-isg.0 (3720) Error: Error: connect EHOSTUNREACH 192.168.178.32:80
            2022-11-07 20:07:20.105  - error: stiebel-isg.0 (3720) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
            2022-11-07 20:07:20.105  - error: stiebel-isg.0 (3720) unhandled promise rejection: connect EHOSTUNREACH 192.168.178.32:80
            2022-11-07 20:07:20.106  - error: stiebel-isg.0 (3720) Error: connect EHOSTUNREACH 192.168.178.32:80
            2022-11-07 20:07:20.107  - error: stiebel-isg.0 (3720) Exception-Code: EHOSTUNREACH: connect EHOSTUNREACH 192.168.178.32:80
            2022-11-07 20:07:20.109  - error: stiebel-isg.0 (3720) Error: Error: connect EHOSTUNREACH 192.168.178.32:80
            2022-11-07 20:07:20.111  - error: stiebel-isg.0 (3720) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
            2022-11-07 20:07:20.111  - error: stiebel-isg.0 (3720) unhandled promise rejection: connect EHOSTUNREACH 192.168.178.32:80
            2022-11-07 20:07:20.112  - error: stiebel-isg.0 (3720) Error: connect EHOSTUNREACH 192.168.178.32:80
            2022-11-07 20:07:20.113  - error: stiebel-isg.0 (3720) Exception-Code: EHOSTUNREACH: connect EHOSTUNREACH 192.168.178.32:80
            2022-11-07 20:07:20.114  - error: stiebel-isg.0 (3720) Error: Error: connect EHOSTUNREACH 192.168.178.32:80
            2022-11-07 20:07:20.115  - error: stiebel-isg.0 (3720) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
            2022-11-07 20:07:20.116  - error: stiebel-isg.0 (3720) unhandled promise rejection: connect EHOSTUNREACH 192.168.178.32:80
            2022-11-07 20:07:20.116  - error: stiebel-isg.0 (3720) Error: connect EHOSTUNREACH 192.168.178.32:80
            2022-11-07 20:07:20.117  - error: stiebel-isg.0 (3720) Exception-Code: EHOSTUNREACH: connect EHOSTUNREACH 192.168.178.32:80
            2022-11-07 20:07:20.118  - error: stiebel-isg.0 (3720) Error: Error: connect EHOSTUNREACH 192.168.178.32:80
            2022-11-07 20:07:20.119  - error: stiebel-isg.0 (3720) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
            2022-11-07 20:07:20.120  - error: stiebel-isg.0 (3720) unhandled promise rejection: connect EHOSTUNREACH 192.168.178.32:80
            2022-11-07 20:07:20.120  - error: stiebel-isg.0 (3720) Error: connect EHOSTUNREACH 192.168.178.32:80
            2022-11-07 20:07:20.121  - error: stiebel-isg.0 (3720) Exception-Code: EHOSTUNREACH: connect EHOSTUNREACH 192.168.178.32:80
            2022-11-07 20:07:20.147  - info: stiebel-isg.0 (3720) cleaned everything up...
            2022-11-07 20:07:20.149  - info: stiebel-isg.0 (3720) terminating
            2022-11-07 20:07:20.151  - warn: stiebel-isg.0 (3720) Terminated (UNCAUGHT_EXCEPTION): Without reason
            2022-11-07 20:07:20.732  - error: host.iobroker instance system.adapter.stiebel-isg.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
            2022-11-07 20:07:20.733  - info: host.iobroker Restart adapter system.adapter.stiebel-isg.0 because enabled
            2022-11-07 20:07:50.760  - info: host.iobroker instance system.adapter.stiebel-isg.0 started with pid 3737
            2022-11-07 20:07:52.537  - info: stiebel-isg.0 (3737) starting. Version 1.7.5 in /opt/iobroker/node_modules/iobroker.stiebel-isg, node: v16.18.1, js-controller: 4.0.23
            2022-11-07 20:07:55.856  - error: stiebel-isg.0 (3737) Error: Error: connect EHOSTUNREACH 192.168.178.32:80
            2022-11-07 20:07:55.860  - error: stiebel-isg.0 (3737) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
            2022-11-07 20:07:55.860  - error: stiebel-isg.0 (3737) unhandled promise rejection: connect EHOSTUNREACH 192.168.178.32:80
            2022-11-07 20:07:55.862  - error: stiebel-isg.0 (3737) Error: connect EHOSTUNREACH 192.168.178.32:80
            2022-11-07 20:07:55.862  - error: stiebel-isg.0 (3737) Exception-Code: EHOSTUNREACH: connect EHOSTUNREACH 192.168.178.32:80
            2022-11-07 20:07:55.864  - error: stiebel-isg.0 (3737) Error: Error: connect EHOSTUNREACH 192.168.178.32:80
            2022-11-07 20:07:55.865  - error: stiebel-isg.0 (3737) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
            2022-11-07 20:07:55.867  - error: stiebel-isg.0 (3737) unhandled promise rejection: connect EHOSTUNREACH 192.168.178.32:80
            2022-11-07 20:07:55.867  - error: stiebel-isg.0 (3737) Error: connect EHOSTUNREACH 192.168.178.32:80
            2022-11-07 20:07:55.868  - error: stiebel-isg.0 (3737) Exception-Code: EHOSTUNREACH: connect EHOSTUNREACH 192.168.178.32:80
            2022-11-07 20:07:55.871  - error: stiebel-isg.0 (3737) Error: Error: connect EHOSTUNREACH 192.168.178.32:80
            2022-11-07 20:07:55.872  - error: stiebel-isg.0 (3737) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
            2022-11-07 20:07:55.873  - error: stiebel-isg.0 (3737) unhandled promise rejection: connect EHOSTUNREACH 192.168.178.32:80
            2022-11-07 20:07:55.873  - error: stiebel-isg.0 (3737) Error: connect EHOSTUNREACH 192.168.178.32:80
            2022-11-07 20:07:55.874  - error: stiebel-isg.0 (3737) Exception-Code: EHOSTUNREACH: connect EHOSTUNREACH 192.168.178.32:80
            2022-11-07 20:07:55.875  - error: stiebel-isg.0 (3737) Error: Error: connect EHOSTUNREACH 192.168.178.32:80
            2022-11-07 20:07:55.876  - error: stiebel-isg.0 (3737) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
            2022-11-07 20:07:55.876  - error: stiebel-isg.0 (3737) unhandled promise rejection: connect EHOSTUNREACH 192.168.178.32:80
            2022-11-07 20:07:55.877  - error: stiebel-isg.0 (3737) Error: connect EHOSTUNREACH 192.168.178.32:80
            2022-11-07 20:07:55.878  - error: stiebel-isg.0 (3737) Exception-Code: EHOSTUNREACH: connect EHOSTUNREACH 192.168.178.32:80
            2022-11-07 20:07:55.879  - error: stiebel-isg.0 (3737) Error: Error: connect EHOSTUNREACH 192.168.178.32:80
            2022-11-07 20:07:55.880  - error: stiebel-isg.0 (3737) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
            2022-11-07 20:07:55.880  - error: stiebel-isg.0 (3737) unhandled promise rejection: connect EHOSTUNREACH 192.168.178.32:80
            2022-11-07 20:07:55.881  - error: stiebel-isg.0 (3737) Error: connect EHOSTUNREACH 192.168.178.32:80
            2022-11-07 20:07:55.881  - error: stiebel-isg.0 (3737) Exception-Code: EHOSTUNREACH: connect EHOSTUNREACH 192.168.178.32:80
            2022-11-07 20:07:55.883  - error: stiebel-isg.0 (3737) Error: Error: connect EHOSTUNREACH 192.168.178.32:80
            2022-11-07 20:07:55.883  - error: stiebel-isg.0 (3737) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
            2022-11-07 20:07:55.883  - error: stiebel-isg.0 (3737) unhandled promise rejection: connect EHOSTUNREACH 192.168.178.32:80
            2022-11-07 20:07:55.884  - error: stiebel-isg.0 (3737) Error: connect EHOSTUNREACH 192.168.178.32:80
            2022-11-07 20:07:55.884  - error: stiebel-isg.0 (3737) Exception-Code: EHOSTUNREACH: connect EHOSTUNREACH 192.168.178.32:80
            2022-11-07 20:07:55.909  - info: stiebel-isg.0 (3737) cleaned everything up...
            2022-11-07 20:07:55.910  - info: stiebel-isg.0 (3737) terminating
            2022-11-07 20:07:55.912  - warn: stiebel-isg.0 (3737) Terminated (UNCAUGHT_EXCEPTION): Without reason
            2022-11-07 20:07:56.465  - error: host.iobroker instance system.adapter.stiebel-isg.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
            2022-11-07 20:07:56.466  - info: host.iobroker Restart adapter system.adapter.stiebel-isg.0 because enabled
            2022-11-07 20:08:26.494  - info: host.iobroker instance system.adapter.stiebel-isg.0 started with pid 3754
            2022-11-07 20:08:28.587  - info: stiebel-isg.0 (3754) starting. Version 1.7.5 in /opt/iobroker/node_modules/iobroker.stiebel-isg, node: v16.18.1, js-controller: 4.0.23
            2022-11-07 20:08:31.952  - error: stiebel-isg.0 (3754) Error: Error: connect EHOSTUNREACH 192.168.178.32:80
            2022-11-07 20:08:31.956  - error: stiebel-isg.0 (3754) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
            2022-11-07 20:08:31.956  - error: stiebel-isg.0 (3754) unhandled promise rejection: connect EHOSTUNREACH 192.168.178.32:80
            2022-11-07 20:08:31.958  - error: stiebel-isg.0 (3754) Error: connect EHOSTUNREACH 192.168.178.32:80
            2022-11-07 20:08:31.958  - error: stiebel-isg.0 (3754) Exception-Code: EHOSTUNREACH: connect EHOSTUNREACH 192.168.178.32:80
            2022-11-07 20:08:31.960  - error: stiebel-isg.0 (3754) Error: Error: connect EHOSTUNREACH 192.168.178.32:80
            2022-11-07 20:08:31.961  - error: stiebel-isg.0 (3754) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
            2022-11-07 20:08:31.962  - error: stiebel-isg.0 (3754) unhandled promise rejection: connect EHOSTUNREACH 192.168.178.32:80
            2022-11-07 20:08:31.963  - error: stiebel-isg.0 (3754) Error: connect EHOSTUNREACH 192.168.178.32:80
            2022-11-07 20:08:31.964  - error: stiebel-isg.0 (3754) Exception-Code: EHOSTUNREACH: connect EHOSTUNREACH 192.168.178.32:80
            2022-11-07 20:08:31.966  - error: stiebel-isg.0 (3754) Error: Error: connect EHOSTUNREACH 192.168.178.32:80
            2022-11-07 20:08:31.967  - error: stiebel-isg.0 (3754) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
            2022-11-07 20:08:31.968  - error: stiebel-isg.0 (3754) unhandled promise rejection: connect EHOSTUNREACH 192.168.178.32:80
            2022-11-07 20:08:31.968  - error: stiebel-isg.0 (3754) Error: connect EHOSTUNREACH 192.168.178.32:80
            2022-11-07 20:08:31.969  - error: stiebel-isg.0 (3754) Exception-Code: EHOSTUNREACH: connect EHOSTUNREACH 192.168.178.32:80
            2022-11-07 20:08:31.970  - error: stiebel-isg.0 (3754) Error: Error: connect EHOSTUNREACH 192.168.178.32:80
            2022-11-07 20:08:31.971  - error: stiebel-isg.0 (3754) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
            2022-11-07 20:08:31.971  - error: stiebel-isg.0 (3754) unhandled promise rejection: connect EHOSTUNREACH 192.168.178.32:80
            2022-11-07 20:08:31.972  - error: stiebel-isg.0 (3754) Error: connect EHOSTUNREACH 192.168.178.32:80
            2022-11-07 20:08:31.972  - error: stiebel-isg.0 (3754) Exception-Code: EHOSTUNREACH: connect EHOSTUNREACH 192.168.178.32:80
            2022-11-07 20:08:31.973  - error: stiebel-isg.0 (3754) Error: Error: connect EHOSTUNREACH 192.168.178.32:80
            2022-11-07 20:08:31.974  - error: stiebel-isg.0 (3754) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
            2022-11-07 20:08:31.974  - error: stiebel-isg.0 (3754) unhandled promise rejection: connect EHOSTUNREACH 192.168.178.32:80
            2022-11-07 20:08:31.975  - error: stiebel-isg.0 (3754) Error: connect EHOSTUNREACH 192.168.178.32:80
            2022-11-07 20:08:31.975  - error: stiebel-isg.0 (3754) Exception-Code: EHOSTUNREACH: connect EHOSTUNREACH 192.168.178.32:80
            2022-11-07 20:08:31.976  - error: stiebel-isg.0 (3754) Error: Error: connect EHOSTUNREACH 192.168.178.32:80
            2022-11-07 20:08:31.977  - error: stiebel-isg.0 (3754) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
            2022-11-07 20:08:31.977  - error: stiebel-isg.0 (3754) unhandled promise rejection: connect EHOSTUNREACH 192.168.178.32:80
            2022-11-07 20:08:31.977  - error: stiebel-isg.0 (3754) Error: connect EHOSTUNREACH 192.168.178.32:80
            2022-11-07 20:08:31.978  - error: stiebel-isg.0 (3754) Exception-Code: EHOSTUNREACH: connect EHOSTUNREACH 192.168.178.32:80
            2022-11-07 20:08:32.007  - info: stiebel-isg.0 (3754) cleaned everything up...
            2022-11-07 20:08:32.008  - info: stiebel-isg.0 (3754) terminating
            2022-11-07 20:08:32.010  - warn: stiebel-isg.0 (3754) Terminated (UNCAUGHT_EXCEPTION): Without reason
            2022-11-07 20:08:32.563  - error: host.iobroker instance system.adapter.stiebel-isg.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
            2022-11-07 20:08:32.563  - info: host.iobroker Restart adapter system.adapter.stiebel-isg.0 because enabled
            2022-11-07 20:08:32.563  - warn: host.iobroker Do not restart adapter system.adapter.stiebel-isg.0 because restart loop detected
            2022-11-07 20:14:25.441  - info: host.iobroker "system.adapter.stiebel-isg.0" disabled
            2022-11-07 21:07:22.839  - info: host.iobroker "system.adapter.modbus.0" enabled
            2022-11-07 21:07:22.913  - info: host.iobroker instance system.adapter.modbus.0 started with pid 4344
            2022-11-07 21:07:25.163  - info: modbus.0 (4344) starting. Version 5.0.5 in /opt/iobroker/node_modules/iobroker.modbus, node: v16.18.1, js-controller: 4.0.23
            2022-11-07 21:07:25.757  - info: modbus.0 (4344) Connected to slave 192.168.178.32
            2022-11-07 21:07:25.762  - info: modbus.0 (4344) Disconnected from slave 192.168.178.32
            2022-11-07 21:07:54.300  - info: admin.0 (879) ==> Connected system.user.admin from ::ffff:192.168.178.87
            2022-11-07 21:08:22.891  - info: host.iobroker stopInstance system.adapter.modbus.0 (force=false, process=true)
            2022-11-07 21:08:22.902  - info: modbus.0 (4344) Got terminate signal TERMINATE_YOURSELF
            2022-11-07 21:08:22.909  - info: modbus.0 (4344) terminating
            2022-11-07 21:08:22.914  - info: modbus.0 (4344) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
            2022-11-07 21:08:22.943  - info: host.iobroker stopInstance system.adapter.modbus.0 send kill signal
            2022-11-07 21:08:23.480  - info: host.iobroker instance system.adapter.modbus.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
            2022-11-07 21:08:24.061  - info: admin.0 (879) <== Disconnect system.user.admin from ::ffff:192.168.178.87 modbus
            2022-11-07 21:08:25.981  - info: host.iobroker instance system.adapter.modbus.0 started with pid 4368
            2022-11-07 21:08:27.988  - info: modbus.0 (4368) starting. Version 5.0.5 in /opt/iobroker/node_modules/iobroker.modbus, node: v16.18.1, js-controller: 4.0.23
            2022-11-07 21:08:28.494  - info: modbus.0 (4368) Connected to slave 192.168.178.32
            2022-11-07 21:08:28.499  - info: modbus.0 (4368) Disconnected from slave 192.168.178.32
            2022-11-07 21:08:33.925  - info: admin.0 (879) ==> Connected system.user.admin from ::ffff:192.168.178.87
            2022-11-07 21:09:46.963  - error: modbus.0 (4368) Socket Error
            2022-11-07 21:09:46.965  - error: modbus.0 (4368) Client in error state.
            2022-11-07 21:09:46.966  - warn: modbus.0 (4368) On error: {"errno":-113,"code":"EHOSTUNREACH","syscall":"connect","address":"192.168.178.32","port":502}
            2022-11-07 21:10:28.479  - info: admin.0 (879) <== Disconnect system.user.admin from ::ffff:192.168.178.87 modbus
            2022-11-07 21:10:33.742  - info: host.iobroker stopInstance system.adapter.modbus.0 (force=false, process=true)
            2022-11-07 21:10:33.759  - info: modbus.0 (4368) Got terminate signal TERMINATE_YOURSELF
            2022-11-07 21:10:33.765  - info: modbus.0 (4368) terminating
            2022-11-07 21:10:33.775  - info: modbus.0 (4368) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
            2022-11-07 21:10:33.800  - info: host.iobroker stopInstance system.adapter.modbus.0 send kill signal
            2022-11-07 21:10:34.344  - info: host.iobroker instance system.adapter.modbus.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
            2022-11-07 21:10:36.832  - info: host.iobroker instance system.adapter.modbus.0 started with pid 4765
            2022-11-07 21:10:38.404  - info: modbus.0 (4765) starting. Version 5.0.5 in /opt/iobroker/node_modules/iobroker.modbus, node: v16.18.1, js-controller: 4.0.23
            2022-11-07 21:10:41.844  - error: modbus.0 (4765) Socket Error
            2022-11-07 21:10:41.846  - error: modbus.0 (4765) Client in error state.
            2022-11-07 21:10:41.848  - warn: modbus.0 (4765) On error: {"errno":-113,"code":"EHOSTUNREACH","syscall":"connect","address":"192.168.178.32","port":502}
            2022-11-07 21:10:46.954  - info: admin.0 (879) ==> Connected system.user.admin from ::ffff:192.168.178.87
            2022-11-07 21:11:02.473  - info: host.iobroker stopInstance system.adapter.modbus.0 (force=false, process=true)
            2022-11-07 21:11:02.485  - info: modbus.0 (4765) Got terminate signal TERMINATE_YOURSELF
            2022-11-07 21:11:02.497  - info: modbus.0 (4765) terminating
            2022-11-07 21:11:02.507  - info: modbus.0 (4765) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
            2022-11-07 21:11:02.522  - info: host.iobroker stopInstance system.adapter.modbus.0 send kill signal
            2022-11-07 21:11:03.076  - info: host.iobroker instance system.adapter.modbus.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
            2022-11-07 21:11:03.598  - info: admin.0 (879) <== Disconnect system.user.admin from ::ffff:192.168.178.87 modbus
            2022-11-07 21:11:05.563  - info: host.iobroker instance system.adapter.modbus.0 started with pid 4891
            2022-11-07 21:11:07.587  - info: modbus.0 (4891) starting. Version 5.0.5 in /opt/iobroker/node_modules/iobroker.modbus, node: v16.18.1, js-controller: 4.0.23
            2022-11-07 21:11:11.026  - error: modbus.0 (4891) Socket Error
            2022-11-07 21:11:11.027  - error: modbus.0 (4891) Client in error state.
            2022-11-07 21:11:11.029  - warn: modbus.0 (4891) On error: {"errno":-113,"code":"EHOSTUNREACH","syscall":"connect","address":"192.168.178.32","port":502}
            2022-11-07 21:11:16.553  - info: host.iobroker "system.adapter.stiebel-isg.0" enabled
            2022-11-07 21:11:16.619  - info: host.iobroker instance system.adapter.stiebel-isg.0 started with pid 4929
            2022-11-07 21:11:19.251  - info: stiebel-isg.0 (4929) starting. Version 1.7.5 in /opt/iobroker/node_modules/iobroker.stiebel-isg, node: v16.18.1, js-controller: 4.0.23
            2022-11-07 21:11:22.609  - error: stiebel-isg.0 (4929) Error: Error: connect EHOSTUNREACH 192.168.178.32:80
            2022-11-07 21:11:22.615  - error: stiebel-isg.0 (4929) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
            2022-11-07 21:11:22.616  - error: stiebel-isg.0 (4929) unhandled promise rejection: connect EHOSTUNREACH 192.168.178.32:80
            2022-11-07 21:11:22.618  - error: stiebel-isg.0 (4929) Error: connect EHOSTUNREACH 192.168.178.32:80
            2022-11-07 21:11:22.619  - error: stiebel-isg.0 (4929) Exception-Code: EHOSTUNREACH: connect EHOSTUNREACH 192.168.178.32:80
            2022-11-07 21:11:22.622  - error: stiebel-isg.0 (4929) Error: Error: connect EHOSTUNREACH 192.168.178.32:80
            2022-11-07 21:11:22.623  - error: stiebel-isg.0 (4929) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
            2022-11-07 21:11:22.624  - error: stiebel-isg.0 (4929) unhandled promise rejection: connect EHOSTUNREACH 192.168.178.32:80
            2022-11-07 21:11:22.625  - error: stiebel-isg.0 (4929) Error: connect EHOSTUNREACH 192.168.178.32:80
            2022-11-07 21:11:22.626  - error: stiebel-isg.0 (4929) Exception-Code: EHOSTUNREACH: connect EHOSTUNREACH 192.168.178.32:80
            2022-11-07 21:11:22.628  - error: stiebel-isg.0 (4929) Error: Error: connect EHOSTUNREACH 192.168.178.32:80
            2022-11-07 21:11:22.629  - error: stiebel-isg.0 (4929) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
            2022-11-07 21:11:22.630  - error: stiebel-isg.0 (4929) unhandled promise rejection: connect EHOSTUNREACH 192.168.178.32:80
            2022-11-07 21:11:22.630  - error: stiebel-isg.0 (4929) Error: connect EHOSTUNREACH 192.168.178.32:80
            2022-11-07 21:11:22.631  - error: stiebel-isg.0 (4929) Exception-Code: EHOSTUNREACH: connect EHOSTUNREACH 192.168.178.32:80
            2022-11-07 21:11:22.632  - error: stiebel-isg.0 (4929) Error: Error: connect EHOSTUNREACH 192.168.178.32:80
            2022-11-07 21:11:22.633  - error: stiebel-isg.0 (4929) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
            2022-11-07 21:11:22.633  - error: stiebel-isg.0 (4929) unhandled promise rejection: connect EHOSTUNREACH 192.168.178.32:80
            2022-11-07 21:11:22.634  - error: stiebel-isg.0 (4929) Error: connect EHOSTUNREACH 192.168.178.32:80
            2022-11-07 21:11:22.634  - error: stiebel-isg.0 (4929) Exception-Code: EHOSTUNREACH: connect EHOSTUNREACH 192.168.178.32:80
            2022-11-07 21:11:22.636  - error: stiebel-isg.0 (4929) Error: Error: connect EHOSTUNREACH 192.168.178.32:80
            2022-11-07 21:11:22.636  - error: stiebel-isg.0 (4929) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
            2022-11-07 21:11:22.637  - error: stiebel-isg.0 (4929) unhandled promise rejection: connect EHOSTUNREACH 192.168.178.32:80
            2022-11-07 21:11:22.637  - error: stiebel-isg.0 (4929) Error: connect EHOSTUNREACH 192.168.178.32:80
            2022-11-07 21:11:22.637  - error: stiebel-isg.0 (4929) Exception-Code: EHOSTUNREACH: connect EHOSTUNREACH 192.168.178.32:80
            2022-11-07 21:11:22.638  - error: stiebel-isg.0 (4929) Error: Error: connect EHOSTUNREACH 192.168.178.32:80
            2022-11-07 21:11:22.639  - error: stiebel-isg.0 (4929) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
            2022-11-07 21:11:22.639  - error: stiebel-isg.0 (4929) unhandled promise rejection: connect EHOSTUNREACH 192.168.178.32:80
            2022-11-07 21:11:22.640  - error: stiebel-isg.0 (4929) Error: connect EHOSTUNREACH 192.168.178.32:80
            2022-11-07 21:11:22.640  - error: stiebel-isg.0 (4929) Exception-Code: EHOSTUNREACH: connect EHOSTUNREACH 192.168.178.32:80
            2022-11-07 21:11:22.660  - info: stiebel-isg.0 (4929) cleaned everything up...
            2022-11-07 21:11:22.661  - info: stiebel-isg.0 (4929) terminating
            2022-11-07 21:11:22.663  - warn: stiebel-isg.0 (4929) Terminated (UNCAUGHT_EXCEPTION): Without reason
            2022-11-07 21:11:23.216  - error: host.iobroker instance system.adapter.stiebel-isg.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
            2022-11-07 21:11:23.217  - info: host.iobroker Restart adapter system.adapter.stiebel-isg.0 because enabled
            2022-11-07 21:11:53.264  - info: host.iobroker instance system.adapter.stiebel-isg.0 started with pid 5077
            2022-11-07 21:11:55.741  - info: stiebel-isg.0 (5077) starting. Version 1.7.5 in /opt/iobroker/node_modules/iobroker.stiebel-isg, node: v16.18.1, js-controller: 4.0.23
            2022-11-07 21:11:59.040  - error: stiebel-isg.0 (5077) Error: Error: connect EHOSTUNREACH 192.168.178.32:80
            2022-11-07 21:11:59.049  - error: stiebel-isg.0 (5077) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
            2022-11-07 21:11:59.051  - error: stiebel-isg.0 (5077) unhandled promise rejection: connect EHOSTUNREACH 192.168.178.32:80
            2022-11-07 21:11:59.058  - error: stiebel-isg.0 (5077) Error: connect EHOSTUNREACH 192.168.178.32:80
            2022-11-07 21:11:59.060  - error: stiebel-isg.0 (5077) Exception-Code: EHOSTUNREACH: connect EHOSTUNREACH 192.168.178.32:80
            2022-11-07 21:11:59.063  - error: stiebel-isg.0 (5077) Error: Error: connect EHOSTUNREACH 192.168.178.32:80
            2022-11-07 21:11:59.064  - error: stiebel-isg.0 (5077) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
            2022-11-07 21:11:59.066  - error: stiebel-isg.0 (5077) unhandled promise rejection: connect EHOSTUNREACH 192.168.178.32:80
            2022-11-07 21:11:59.068  - error: stiebel-isg.0 (5077) Error: connect EHOSTUNREACH 192.168.178.32:80
            2022-11-07 21:11:59.071  - error: stiebel-isg.0 (5077) Exception-Code: EHOSTUNREACH: connect EHOSTUNREACH 192.168.178.32:80
            2022-11-07 21:11:59.076  - error: stiebel-isg.0 (5077) Error: Error: connect EHOSTUNREACH 192.168.178.32:80
            2022-11-07 21:11:59.078  - error: stiebel-isg.0 (5077) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
            2022-11-07 21:11:59.079  - error: stiebel-isg.0 (5077) unhandled promise rejection: connect EHOSTUNREACH 192.168.178.32:80
            2022-11-07 21:11:59.082  - error: stiebel-isg.0 (5077) Error: connect EHOSTUNREACH 192.168.178.32:80
            2022-11-07 21:11:59.083  - error: stiebel-isg.0 (5077) Exception-Code: EHOSTUNREACH: connect EHOSTUNREACH 192.168.178.32:80
            2022-11-07 21:11:59.130  - error: stiebel-isg.0 (5077) Error: Error: connect EHOSTUNREACH 192.168.178.32:80
            2022-11-07 21:11:59.132  - error: stiebel-isg.0 (5077) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
            2022-11-07 21:11:59.133  - error: stiebel-isg.0 (5077) unhandled promise rejection: connect EHOSTUNREACH 192.168.178.32:80
            2022-11-07 21:11:59.135  - error: stiebel-isg.0 (5077) Error: connect EHOSTUNREACH 192.168.178.32:80
            2022-11-07 21:11:59.137  - error: stiebel-isg.0 (5077) Exception-Code: EHOSTUNREACH: connect EHOSTUNREACH 192.168.178.32:80
            2022-11-07 21:11:59.141  - error: stiebel-isg.0 (5077) Error: Error: connect EHOSTUNREACH 192.168.178.32:80
            2022-11-07 21:11:59.142  - error: stiebel-isg.0 (5077) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
            2022-11-07 21:11:59.143  - error: stiebel-isg.0 (5077) unhandled promise rejection: connect EHOSTUNREACH 192.168.178.32:80
            2022-11-07 21:11:59.144  - error: stiebel-isg.0 (5077) Error: connect EHOSTUNREACH 192.168.178.32:80
            2022-11-07 21:11:59.145  - error: stiebel-isg.0 (5077) Exception-Code: EHOSTUNREACH: connect EHOSTUNREACH 192.168.178.32:80
            2022-11-07 21:11:59.148  - error: stiebel-isg.0 (5077) Error: Error: connect EHOSTUNREACH 192.168.178.32:80
            2022-11-07 21:11:59.150  - error: stiebel-isg.0 (5077) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
            2022-11-07 21:11:59.152  - error: stiebel-isg.0 (5077) unhandled promise rejection: connect EHOSTUNREACH 192.168.178.32:80
            2022-11-07 21:11:59.153  - error: stiebel-isg.0 (5077) Error: connect EHOSTUNREACH 192.168.178.32:80
            2022-11-07 21:11:59.154  - error: stiebel-isg.0 (5077) Exception-Code: EHOSTUNREACH: connect EHOSTUNREACH 192.168.178.32:80
            2022-11-07 21:11:59.160  - info: stiebel-isg.0 (5077) cleaned everything up...
            2022-11-07 21:11:59.161  - info: stiebel-isg.0 (5077) terminating
            2022-11-07 21:11:59.164  - warn: stiebel-isg.0 (5077) Terminated (UNCAUGHT_EXCEPTION): Without reason
            2022-11-07 21:11:59.738  - error: host.iobroker instance system.adapter.stiebel-isg.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
            2022-11-07 21:11:59.739  - info: host.iobroker Restart adapter system.adapter.stiebel-isg.0 because enabled
            2022-11-07 21:12:15.089  - error: modbus.0 (4891) Socket Error
            2022-11-07 21:12:15.092  - error: modbus.0 (4891) Client in error state.
            2022-11-07 21:12:15.093  - warn: modbus.0 (4891) On error: {"errno":-113,"code":"EHOSTUNREACH","syscall":"connect","address":"192.168.178.32","port":502}
            2022-11-07 21:12:15.595  - info: host.iobroker "system.adapter.stiebel-isg.0" disabled
            2022-11-07 21:12:21.794  - info: admin.0 (879) ==> Connected system.user.admin from ::ffff:192.168.178.87
            2022-11-07 21:12:31.654  - error: stiebel-isg.0 (5206) adapter disabled
            2022-11-07 21:12:31.711  - warn: stiebel-isg.0 (5206) Terminated (NO_ADAPTER_CONFIG_FOUND): Without reason
            2022-11-07 21:12:32.267  - error: host.iobroker instance system.adapter.stiebel-isg.0 terminated with code 3 (NO_ADAPTER_CONFIG_FOUND)
            2022-11-07 21:12:32.268  - info: host.iobroker Do not restart adapter system.adapter.stiebel-isg.0 because disabled or deleted
            2022-11-07 21:13:00.436  - info: host.iobroker stopInstance system.adapter.modbus.0 (force=false, process=true)
            2022-11-07 21:13:00.456  - info: modbus.0 (4891) Got terminate signal TERMINATE_YOURSELF
            2022-11-07 21:13:00.461  - info: modbus.0 (4891) terminating
            2022-11-07 21:13:00.467  - info: modbus.0 (4891) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
            2022-11-07 21:13:00.534  - info: host.iobroker stopInstance system.adapter.modbus.0 send kill signal
            2022-11-07 21:13:01.047  - info: host.iobroker instance system.adapter.modbus.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
            2022-11-07 21:13:01.740  - info: admin.0 (879) <== Disconnect system.user.admin from ::ffff:192.168.178.87 modbus
            2022-11-07 21:13:03.664  - info: host.iobroker instance system.adapter.modbus.0 started with pid 5319
            2022-11-07 21:13:05.682  - info: modbus.0 (5319) starting. Version 5.0.5 in /opt/iobroker/node_modules/iobroker.modbus, node: v16.18.1, js-controller: 4.0.23
            2022-11-07 21:13:09.266  - error: modbus.0 (5319) Socket Error
            2022-11-07 21:13:09.268  - error: modbus.0 (5319) Client in error state.
            2022-11-07 21:13:09.270  - warn: modbus.0 (5319) On error: {"errno":-113,"code":"EHOSTUNREACH","syscall":"connect","address":"192.168.178.32","port":502}
            2022-11-07 21:14:13.331  - error: modbus.0 (5319) Socket Error
            2022-11-07 21:14:13.333  - error: modbus.0 (5319) Client in error state.
            2022-11-07 21:14:13.334  - warn: modbus.0 (5319) On error: {"errno":-113,"code":"EHOSTUNREACH","syscall":"connect","address":"192.168.178.32","port":502}
            2022-11-07 21:15:14.347  - error: modbus.0 (5319) Socket Error
            2022-11-07 21:15:14.348  - error: modbus.0 (5319) Client in error state.
            2022-11-07 21:15:14.349  - warn: modbus.0 (5319) On error: {"errno":-111,"code":"ECONNREFUSED","syscall":"connect","address":"192.168.178.32","port":502}
            2022-11-07 21:16:15.353  - info: modbus.0 (5319) Connected to slave 192.168.178.32
            2022-11-07 21:16:15.356  - info: modbus.0 (5319) Disconnected from slave 192.168.178.32
            2022-11-07 21:17:05.456  - info: admin.0 (879) <== Disconnect system.user.admin from ::ffff:192.168.178.87 admin
            2022-11-07 21:17:15.365  - info: modbus.0 (5319) Connected to slave 192.168.178.32
            2022-11-07 21:17:15.367  - info: modbus.0 (5319) Disconnected from slave 192.168.178.32
            2022-11-07 21:18:15.385  - info: modbus.0 (5319) Connected to slave 192.168.178.32
            2022-11-07 21:18:15.386  - info: modbus.0 (5319) Disconnected from slave 192.168.178.32
            2022-11-07 21:19:15.394  - info: modbus.0 (5319) Connected to slave 192.168.178.32
            2022-11-07 21:19:15.396  - info: modbus.0 (5319) Disconnected from slave 192.168.178.32
            2022-11-07 21:20:15.404  - info: modbus.0 (5319) Connected to slave 192.168.178.32
            2022-11-07 21:20:15.405  - info: modbus.0 (5319) Disconnected from slave 192.168.178.32
            2022-11-07 21:21:15.416  - info: modbus.0 (5319) Connected to slave 192.168.178.32
            2022-11-07 21:21:15.418  - info: modbus.0 (5319) Disconnected from slave 192.168.178.32
            2022-11-07 21:22:15.428  - info: modbus.0 (5319) Connected to slave 192.168.178.32
            2022-11-07 21:22:15.430  - info: modbus.0 (5319) Disconnected from slave 192.168.178.32
            2022-11-07 21:23:15.438  - info: modbus.0 (5319) Connected to slave 192.168.178.32
            2022-11-07 21:23:15.440  - info: modbus.0 (5319) Disconnected from slave 192.168.178.32
            2022-11-07 21:24:15.450  - info: modbus.0 (5319) Connected to slave 192.168.178.32
            2022-11-07 21:24:15.452  - info: modbus.0 (5319) Disconnected from slave 192.168.178.32
            2022-11-07 21:25:15.462  - info: modbus.0 (5319) Connected to slave 192.168.178.32
            2022-11-07 21:25:15.464  - info: modbus.0 (5319) Disconnected from slave 192.168.178.32
            2022-11-07 21:26:15.472  - info: modbus.0 (5319) Connected to slave 192.168.178.32
            2022-11-07 21:26:15.474  - info: modbus.0 (5319) Disconnected from slave 192.168.178.32
            2022-11-07 21:27:15.478  - info: modbus.0 (5319) Connected to slave 192.168.178.32
            2022-11-07 21:27:15.480  - info: modbus.0 (5319) Disconnected from slave 192.168.178.32
            2022-11-07 21:28:15.488  - info: modbus.0 (5319) Connected to slave 192.168.178.32
            2022-11-07 21:28:15.489  - info: modbus.0 (5319) Disconnected from slave 192.168.178.32
            2022-11-07 21:29:15.498  - info: modbus.0 (5319) Connected to slave 192.168.178.32
            2022-11-07 21:29:15.500  - info: modbus.0 (5319) Disconnected from slave 192.168.178.32
            2022-11-07 21:30:15.508  - info: modbus.0 (5319) Connected to slave 192.168.178.32
            2022-11-07 21:30:15.510  - info: modbus.0 (5319) Disconnected from slave 192.168.178.32
            2022-11-07 21:31:15.521  - info: modbus.0 (5319) Connected to slave 192.168.178.32
            2022-11-07 21:31:15.527  - info: modbus.0 (5319) Disconnected from slave 192.168.178.32
              @c-k-0
              Bitte in CodeTags einbetten.
                @c-k-0 sagte in Stiebel-ISG - Modbus:
                Schaut für mich nach grundsätzlichem Problem im Netzwerk aus. Der Dienst kann nicht erreicht werden.
                unltdnetworx 1 Reply Last reply Reply Quote 0
                • unltdnetworx
                  unltdnetworx Developer @Thomas Braun last edited by
                  Exakt. Das ISG scheint weder über die Weboberfläche, noch über Modbus erreichbar zu sein.
                  • Q
                    Qlink @JB_Mystery last edited by
                    @jb_mystery said in Stiebel-ISG - Modbus:
                    @jojo182
                    Ich dachte ich schreibe auch mal meine Regelung.
                    Evtl. gibt das dem ein oder anderen ja Anregungen es für sich modifiziert anzuwenden. Viel Spaß damit.
                    Habe Heiz-und Warmwasserbetrieb optimiert auf Eigenverbrauch. Meine Werte sind nicht für alle was, da ich ein hochgedämmtes Haus habe und nur alleine lebe. Als Heizungstyp habe ich eine LWZ304Sol, wobei ich die Solarunterstützung nicht habe. Wollte den ganzen Platz lieber für die PV verwenden.
                    Regelwerte:
                    • Hysterese 1 (Wert für Solarunterstützung, bei mir nicht vorhanden)
                    • Hysterese 2 (Wert für Wärmepumpe)
                    • Asymmetrie (Die Hysteresen über Sollwert werden durch diesen Parameter geteilt)
                    • Fusspunkt (benutzt um Heizkurve nach oben zu schieben; Sollwerterhöhung)
                    • Max Pumpenzyklen (benutzt, um eine Heizungsbedarfsprüfung zu erzwingen Bsp.: 24h*60min/288Zyklen = alle 5 min Prüfen)
                    • Warmwassertemperatur
                    • Warmwasserhysterese
                    • Lüftungsstufe
                    Bei Sonnenstart (Heizung freigeben):
                    • Hysterese 1 - 2
                    • Hysterese 2 - 2
                    • Asymmetrie - 1
                    • Fusspunkt - 1,5
                      => Einschalten bei 2K unter Solltemperatur und Ausschalten bei 1K über.
                    5 min vor Sonnenpeak (Prüfe auf Heizbedarf, dass Verdichter an bleibt nach WW):
                    • Hysterese 1 - 1,5
                    • Hysterese 2 - 1,5
                    • Asymmetrie - 1
                    • Fusspunkt - 2
                    • Max Pumpenzyklen - 288
                      => Einschalten bei 1,5K unter Solltemperatur und Ausschalten bei 1,5K über. Zudem Heizkurve um 0,5°C angehoben. Prüfe alle 5 min auf Heizbedarf.
                    Sonnenpeak (Prüfe auf Warmwasserbedarf):
                    • Hysterese 1 - 2
                    • Hysterese 2 - 2
                    • Asymmetrie - 1
                    • Fusspunkt - 1,5
                    • Max Pumpenzyklen - 36
                    • Warmwassertemperatur - 42 oder 45, wenn PV größer 70%
                    • Warmwasserhysterese - 2,5
                      => Standardwerte wieder herstellen und Warmwasserbereitung freigeben.
                    17:00 Uhr (Warmwasser AUS):
                    • Warmwassertemperatur - 37
                    • Warmwasserhysterese - 7
                      => Standardwerte Warmwasserbereitung herstellen.
                      00:00 Uhr (Heizung AUS):
                      Außentemperatur > 0°C
                    • Hysterese 1 - 8
                    • Hysterese 2 - 8
                    • Asymmetrie - 4
                    • Fusspunkt - 1,5
                    Außentemperatur > -3°C
                    • Hysterese 1 - 6
                    • Hysterese 2 - 6
                    • Asymmetrie - 3
                    • Fusspunkt - 1,5
                    Außentemperatur <= -3°C
                    • Hysterese 1 - 3,5
                    • Hysterese 2 - 3,5
                    • Asymmetrie - 2
                    • Fusspunkt - 1,5
                      => Abhängig der Außentemperatur die Schwellwerte anpassen. Bsp.: Bei >0°C Einschalten bei 8K unter Solltemperatur und Ausschalten bei 2K über.
                    Hintergründe:
                    • Eigenverbrauch optimieren.
                    • Bin kalt Duscher, deswegen Warmwasser so gering.
                    • Warmwasserbereitung nach Peak bis ca. PV zu gering.
                    • Wenn PV >70% dann Warmwasser erhöhen.
                    • Wenn Warmwasser doch zu kalt dann richtig hochheizen.
                    • Heizung nachts ausschalten abhängig der Außentemperatur
                    • Wenn Heizung nachts doch an, dann richtig hochheizen
                    • Vor Warmwasserbereitung Heizbedarf prüfen, um Verdichterstarts zu reduzieren.
                    • Lüftungsstufe 1, wenn Verdichter AN (bessere Leistungszahl Wärmepumpe)
                    @jojo182
                    Regelwerte:
                    • Lüftungsstufe
                    • Hysterese 1 - 2
                    • Hysterese 2 - 2
                    • Asymmetrie - 1
                    • Fusspunkt - 1,5
                    • Hysterese 1 - 1,5
                    • Hysterese 2 - 1,5
                    • Asymmetrie - 1
                    • Fusspunkt - 2
                    • Hysterese 1 - 2
                    • Hysterese 2 - 2
                    • Asymmetrie - 1
                    • Fusspunkt - 1,5
                    • Hysterese 1 - 8
                    • Hysterese 2 - 8
                    • Asymmetrie - 4
                    • Fusspunkt - 1,5
                    • Hysterese 1 - 6
                    • Hysterese 2 - 6
                    • Asymmetrie - 3
                    • Fusspunkt - 1,5
                    • Hysterese 1 - 3,5
                    • Hysterese 2 - 3,5
                    • Asymmetrie - 2
                    • Fusspunkt - 1,5
                    Hintergründe:
                    Hast du das mit Blockly umgesetzt ?
                    Falls ja, könntest du dein Blockly teilen ?
                    Beste Grüße
                      JB_Mystery @Qlink last edited by
                      @qlink
                      Ich habe alles mit JavaScript geschrieben. Denke es bringt dann auch nicht direkt was, wenn ich da Schnipsel reinstelle. Es muss ja immer alles angepasst werden an die Gegebenheiten der jeweiligen Hardware. Hoffe das reicht als Info. Die Modbus Parameter kann man ja dann selbst zu den Ereignissen modifizieren.
                        Android51 last edited by
                        ich stehe kurz vor der Inbetriebnahme eines SMA Wechselrichters und betreibe parallel ein ISG Web (v. 12.2.0) an meiner Wärmepumpe. Da ich mich inzwischen gedanklich von dem Erwerb der EMI-Erweiterung verabschiedet habe und mich erst einmal mit SG Ready versuchen möchte, frage ich mich nun, wie das ISG Web und der Wechselrichter kommunizieren. Bei der EMI-Schnittstelle wäre das über das Heimnetz (LAN) gegangen. Funktioniert das bei SG Ready auch? Oder muss ich noch eine Modbus-Verkabelung zwischen ISG und Wechselrichter herstellen? Oder noch was anderes?
                        Bin für jeden Tipp dankbar! 🙂
                        • unltdnetworx
                          unltdnetworx Developer @Android51 last edited by
                          @android51
                          Hi, also Modbus läuft grundsätzlich auch über LAN und beide Geräte brauchen dafür eine Verbindung mit dem Heimnetz. Das ISG verfügt eigentlich nur über einen Wert 0/1 für Energiemanagement. Wenn dieser Wert auf 1 steht, werden die Werte für Warmwasser und Heizung auf selbst definierbare Werte gesetzt (normalerweise erhöht). Bei Wert 0 werden wieder die Standardwerte eingestellt.
                          Je nachdem welche Werte eingestellt wurden, springt dann die Heizung an. Das ist alles, was hier als "smart" bezeichnet wird.
                          0/1 werden bei mir mittels ioBroker gesteuert, indem die Einspeisung meiner PV-Anlage ermittelt wird.
                            Android51 @unltdnetworx last edited by
                            @unltdnetworx
                            Danke für die Rückmeldung bzw. Erklärung.
                            Mein ISG Web hängt logischerweise bereits im Heimnetz und der Wechselrichter wird ebenfalls per LAN eingebunden. Dann sollte der Kommunikationsweg ja gegeben sein. Kann die Kommunikation nicht direkt zwischen Wechselrichter und ISG stattfinden? Kann man die Geräte nicht verknüpfen?
                            Ich habe auch einen ioBroker in Betrieb. Im Zweifel müsste ich es auch darüber realisieren.
                            Ich dachte, die Geräte kommunizieren untereinander...
                              berlinerbolle @Android51 last edited by berlinerbolle
                              @android51 said in Stiebel-ISG - Modbus:
                              Das machen Sie auch - wenn man EMI nutzt. Deine Antwort klingt eigentlich so, als ob EMI das Bessere für dich wäre (und da gibt es dann auch nicht nur 0 und 1, sondern eine feinere Abstufung).
                              Und wenn Du Geräte mit SG Ready direkt verknüpfen willst, geht das bei entsprechenden Voraussetzungen auch (Stichwort ISG Plus und eine SG Ready kompatible Wärmepumpe mit dafür vorhandenem Eingang).
                              Per Modbus TCP (wie im Falle des ISG Web) ist das Ganze sehr viel unabhängiger von irgendwelchen spezifischen Implementierungen und setzt auf Standards auf. Aber natürlich kann dein Wechselrichter nicht wissen, hinter welchem Modbus Register der Wärmepumpe sich der SG Ready Schalter verbirgt, oder wann er den überhaupt auslösen soll. Deshalb musst/kanst du das (zum Beispiel über ioBroker) selbst ansteuern, was dir dann auch alle Freiheiten lässt. Willst Du es so dass es einfach ohne Zusatzsoftware/Hardware funktioniert ohne dass Du etwas tun musst, brauchst Du die EMI Variante und einen Installateur der das alles für dich in Betrieb nimmt.
                                Android51 @berlinerbolle last edited by
                                @berlinerbolle
                                Mein Problem ist, dass ich parallel noch eine Solarthermie auf dem Dach betreibe und ich gelesen habe, dass das EMI dies nicht berücksichtigen kann. Zudem habe ich im Allgemeinen viel mehr Schlechtes als Gutes über die EMI Schnittstelle gelesen (Stichwort: Taktung der Wärmepumpe usw.) Ich schließe die EMI Schnittstelle für mich auch nicht gänzlich aus. Ich werde nur erst einmal den Weg über sg ready versuchen und mich da reinfuchsen.
                                Vielleicht muss ich das eine oder andere nochmal nachfragen.
                                  tippy88 last edited by
                                  dank der zur Verfügung gestellten Informationen und Beispiele von @unltdnetworx habe ich mir die die letzten Tage den ISG Adapter und Modbus im iobroker eingestellt. Meine WP ist eine Tecalor TTL 7.6 ACS mit dem ISG web.
                                  Funktioniert soweit tadellos und auch die Schaltung mit PV Überschuss und SG Ready Eingang passt.
                                  Die einzige Frage die ich mir stelle, warum schaltet das ISG selbständig ständig zwischen Betriebszustand 1 und 2? Ich logge den Datenpunkt und muss feststellen, nachdem ich den Eingang 1 auf 0 gesetzt habe, wechselt das ISG kurz in Betiebszustand 4 und schaltet dann in 2. Seither wechselt es ständig zwischen 1 und 2. Hat jemand eine Erklärung oder kann selbiges feststellen?
                                  Gemäß Anleitung muss für Betiebszustand 1 eigentlich der SG Ready Eingang 2 geschaltet sein und Eingang 1 nicht, aber Eingang 2 fasse ich überhaupt nicht an.
                                  Tobi
                                  • unltdnetworx
                                    unltdnetworx Developer @tippy88 last edited by unltdnetworx
                                    @tippy88
                                    Also ich beschalte nur den Eingang 1 und bei mir springen die Werte nur zwischen Betriebsstatus 2 und 3 hin und her.
                                    Hast du vllt. irgendein Skript am Laufen? Weil es ja unterschiedlich lange dauert, bis der Betriebsstatus wechselt. Status 1 wäre ja der Bereitschaftsmodus, das dürfte ja nie der Fall sein.
                                      tippy88 @unltdnetworx last edited by
                                      @unltdnetworx said in Stiebel-ISG - Modbus:
                                      Ich auch nur.
                                      Nur das Skript zum Überschuss heizen. Wenn die Änderung durch ein Skript getriggert wird, dann würde ich dass ja in der histroy von den Eingängen 1 oder 2 sehen, aber da gab es lediglich eine einzige Änderung als ich zum ersten Mal Eingang 1 geschalten und abgeschalten habe.
                                      Hier, letzte Änderung der SG-Ready Eingänge vor 2 Tagen
                                      Allein heute hat sich der Betriebszustand schon dutzende Male geändert zwischen 1 und 2, aber die 1 bleibt immer nur für 1s drin, verstehe ich nicht 🤷‍♂️
                                      Heizung läuft ansonsten komplett normal, von diesen Wechseln merkt man nichts, sie schaltet nicht aus oder so...
                                      K Q 2 Replies Last reply Reply Quote 0
                                        @unltdnetworx
                                        vielen Dank für deinen Blog, leider kann ich die Kommentarfunktion nicht nutzen. Beim Absenden erhalte ich immer einen Fehler.
                                        Ich erhalte beim Starten des java-scripts "modify-objects" immer Fehlermeldungen. Kannst du mir weiterhelfen, woran es liegen könnte?
                                        Ich habe die var modbus.instanz auf 0 geändert, weil es meine einzige ist. Kann es daran liegen, dass ich inzwischen den Modbus-Adapter in Version 5.0.11 installiert habe. Oder liegt es daran, dass ich nicht alle Modbus Adressen importiert habe, sondern nur die, die ich für mich als notwendig erachte. Heizungstyp ist mit wpm-system auch richtig gewählt.
                                        17:34:39.222 error javascript.0 (1486) script.js.Modbus_ISG_Modified_Objects: TypeError: Cannot read property 'common' of null
                                        17:34:39.222 error javascript.0 (1486) at modifyDP (script.js.Modbus_ISG_Modified_Objects:7:17)
                                        17:34:39.222 error javascript.0 (1486) at script.js.Modbus_ISG_Modified_Objects:18:1
                                        17:34:39.223 error javascript.0 (1486) at script.js.Modbus_ISG_Modified_Objects:51:3
                                        • unltdnetworx
                                          @android51
                                          Fehler in dem Skript können dadurch auftauchen, dass es manche Datenpunkte bei dir nicht gibt. Darauf deutet auch die Meldung mit "null" hin. Das Skript muss ohnehin nur einmal laufen.
                                          Schau mal in den Datenpunkten nach, ob es dort im Objektebaum nun Dropdowns für die Werte gibt. Z.B.: bei "modbus.1.holdingRegisters.41001_Betriebsart" (bei deiner Heizung vllt. auch anders benannt). Dort sollte dann "Automatikbetrieb(11)" statt dem Wert "11" stehen.
                                          Wenn das so ist, dann hat alles funktioniert und das Skript kann gestoppt werden.
                                            Android51 last edited by Android51
                                            @unltdnetworx
                                            es hat jetzt offenbar funktioniert. Aber die Betriebsart wird weiterhin bei mir mit 3, anstatt Komfortbetrieb.
                                            41520_Reset wurde auch nicht modifiziert.
                                            81.1k
                                            modbus stiebel-isg
                                            35
                                            486
                                            116387
