    3. Einsteigerfragen
    4. (Gelöst)Aus einer Liste "Name" und Wert
      paul53 @harald07 last edited by
      @harald07 sagte: nochmal alle zusammen.
      Der Selektor für alle Zellen:
        harald07 last edited by Homoran
        @paul53 Es tut sich was.
        2023-02-13 18:08:21.581 - info: javascript.0 (5714) script.js.PV.Zellen_Paul53: ['0_userdata.0.PV.Pack_3.P3_Z01','0_userdata.0.PV.Pack_3.P3_Z02','0_userdata.0.PV.Pack_3.P3_Z03','0_userdata.0.PV.Pack_3.P3_Z04','0_userdata.0.PV.Pack_3.P3_Z05','0_userdata.0.PV.Pack_3.P3_Z06','0_userdata.0.PV.Pack_3.P3_Z07','0_userdata.0.PV.Pack_3.P3_Z08','0_userdata.0.PV.Pack_3.P3_Z09','0_userdata.0.PV.Pack_3.P3_Z10','0_userdata.0.PV.Pack_3.P3_Z11','0_userdata.0.PV.Pack_3.P3_Z12','0_userdata.0.PV.Pack_3.P3_Z13','0_userdata.0.PV.Pack_3.P3_Z14','0_userdata.0.PV.Pack_3.P3_Z15','0_userdata.0.PV.Pack_3.P3_Z16']
        2023-02-13 18:08:21.582 - info: javascript.0 (5714) script.js.PV.Zellen_Paul53: registered 0 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
        2023-02-13 18:08:32.111 - info: admin.0 (5672) <== Disconnect system.user.admin from ::ffff:192.168.20.20 javascript
          @harald07
          Log-Ausgaben bitte in Code tags (oben </>) posten!
            @paul53 Teilerfolg!
            Minimalwert und Maximalwert werden gesetzt.
            Aber nicht die Namen
            2023-02-13 18:48:03.967 - warn: javascript.0 (5714) getState "undefined" not found (3)
            2023-02-13 18:48:03.968 - warn: javascript.0 (5714) at Object. (script.js.PV.Zellen_Paul53:17:12)
            2023-02-13 18:48:03.969 - warn: javascript.0 (5714) at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1244:38)
            2023-02-13 18:48:03.969 - warn: javascript.0 (5714) at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:593:29)
            2023-02-13 18:48:03.970 - warn: javascript.0 (5714) at Immediate._onImmediate (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.js:5916:56)
            2023-02-13 18:48:03.970 - warn: javascript.0 (5714) at processImmediate (node:internal/timers:466:21)
            2023-02-13 18:48:03.970 - warn: javascript.0 (5714) script.js.PV.Zellen_Paul53: Object "undefined" does not exist
            2023-02-13 18:48:03.972 - error: javascript.0 (5714) script.js.PV.Zellen_Paul53: TypeError: Cannot read properties of null (reading 'common')
            2023-02-13 18:48:03.973 - error: javascript.0 (5714) at getName (script.js.PV.Zellen_Paul53:5:25)
            2023-02-13 18:48:03.973 - error: javascript.0 (5714) at Object. (script.js.PV.Zellen_Paul53:18:19)
            2023-02-13 18:48:03.973 - error: javascript.0 (5714) at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1244:38)
            2023-02-13 18:48:03.973 - error: javascript.0 (5714) at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:593:29)
            2023-02-13 18:48:03.973 - error: javascript.0 (5714) at Immediate. (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.js:5916:56)
            2023-02-13 18:48:03.973 - error: javascript.0 (5714) at processImmediate (node:internal/timers:466:21)
              paul53 @harald07 last edited by paul53
              @harald07
              Ändere für jeden Wert i --> für jeden Wert id. Falsch:
              Richtig:
              Die "aktualisiere"-Blöcke müssen in den Trigger unter die Schleife.
                @paul53 Die "id" habe ich durch "i" ersetzt.
                2023-02-13 18:53:40.162 - warn: javascript.0 (5714) getState "undefined" not found (3)
                2023-02-13 18:53:40.163 - warn: javascript.0 (5714) at Object. (script.js.PV.Zellen_Paul53:17:12)
                2023-02-13 18:53:40.164 - warn: javascript.0 (5714) at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1244:38)
                2023-02-13 18:53:40.164 - warn: javascript.0 (5714) at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:593:29)
                2023-02-13 18:53:40.164 - warn: javascript.0 (5714) at Immediate._onImmediate (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.js:5916:56)
                2023-02-13 18:53:40.164 - warn: javascript.0 (5714) at processImmediate (node:internal/timers:466:21)
                2023-02-13 18:53:40.164 - warn: javascript.0 (5714) script.js.PV.Zellen_Paul53: Object "undefined" does not exist
                2023-02-13 18:53:40.166 - error: javascript.0 (5714) script.js.PV.Zellen_Paul53: TypeError: Cannot read properties of null (reading 'common')
                2023-02-13 18:53:40.167 - error: javascript.0 (5714) at getName (script.js.PV.Zellen_Paul53:5:25)
                2023-02-13 18:53:40.167 - error: javascript.0 (5714) at Object. (script.js.PV.Zellen_Paul53:18:19)
                2023-02-13 18:53:40.168 - error: javascript.0 (5714) at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1244:38)
                2023-02-13 18:53:40.168 - error: javascript.0 (5714) at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:593:29)
                2023-02-13 18:53:40.168 - error: javascript.0 (5714) at Immediate. (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.js:5916:56)
                2023-02-13 18:53:40.168 - error: javascript.0 (5714) at processImmediate (node:internal/timers:466:21)
                2023-02-13 18:53:40.755 - info: javascript.0 (5714) Stop script script.js.PV.Zellen_Paul53
                2023-02-13 18:54:32.898 - info: javascript.0 (5714) Stop script script.js.PV.Zellen_Paul53
                2023-02-13 18:54:34.810 - info: javascript.0 (5714) Start javascript script.js.PV.Zellen_Paul53
                2023-02-13 18:54:34.818 - info: javascript.0 (5714) script.js.PV.Zellen_Paul53: registered 16 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
                2023-02-13 18:54:34.830 - info: javascript.0 (5714) State value to set for "0_userdata.0.PV.Pack_3.P3_Minimum" has to be type "number" but received type "object"
                2023-02-13 18:54:34.831 - info: javascript.0 (5714) State value to set for "0_userdata.0.PV.Pack_3.P3_Name_Min" has to be type "string" but received type "object"
                2023-02-13 18:54:34.831 - info: javascript.0 (5714) State value to set for "0_userdata.0.PV.Pack_3.P3_Maximum" has to be type "number" but received type "object"
                2023-02-13 18:54:34.831 - info: javascript.0 (5714) State value to set for "0_userdata.0.PV.Pack_3.P3_Name_Max" has to be type "string" but received type "object"
                2023-02-13 18:54:43.842 - info: admin.0 (5672) <== Disconnect system.user.admin from ::ffff:192.168.20.20 javascript
                  @harald07 sagte: Die "id" habe ich durch "i" ersetzt.
                  Wo? Umgekehrt wird ein Schuh draus (s.o.).
                    harald07 last edited by harald07
                    @paul53 Du bist der Beste.
                    Vielen, vielen Dank!!!!
                      Am Design muss ich noch ein wenig feilen!
                        apollon77 @Codierknecht last edited by
                        @codierknecht Da ich nicht der Blockly experte bin schreibts doch bitte selbst rein wenn Ihr es hier schon rausarbeitet 🙂
                          @Paul53 ich habe die Packs 2 – 5 (für Pack 1 bekomme ich heute einen weiteren esp32) am Laufen. Schon bei den einzelnen Packs bekam ich den Fehler: „is calling setState more than 1000 times per minute! Stopping Script now! Please check your script!“. Ich bin dann hergegangen und habe in den Sendern (esp32), dass Sendeintervall von 1Sek auf 3Sek angehoben. Damit ist der Fehler nicht mehr aufgetreten.
                          Wenn ich jetzt versuche das Script für alle Zellen laufen zu lassen ist der Fehler wieder da, was ja verständlich ist, da es mit allen Packs dann 80 Zellen anstatt 16 Zellen sind. Ich weiß nicht wie hoch ich das Sendeintervall anheben müsste, das es auch mit allen Zellen funktioniert. Ich habe schon versucht den Trigger in einen weiteren „Zeitplan“ Trigger zu setzen, was aber nichts am Fehler ändert.
                          Vielleicht hast Du eine Idee das Problem zu beheben?
                          Vielen Dank!
                          Harald
                            apollon77 @harald07 last edited by apollon77
                            @harald07 Naja mal langsam und einen Schritt zurück ...
                            Das ist ein Sicherheitsfeasture um zu verhindenr das Skripte durch bugs oder unabsichtliches "schlechtes Codeing" amok laufen und das ganze system runterziehen. Weil das hatten wir und dann wurde aufwändig nach Fehlern gesucht überall anders nur nicht da wo es entstanden ist 😉
                            Wenn Du einen validen Fall hast das du so viele Daten in kurzer Zeit setzen willst/musst und dein System das auch abkann ohne zusammenzubrechen ja dann erhöhe das Limit in den Einstellungen der Instanz auf einen Wert der für Dich Sinn macht. Da ist keine Notwendigkeit jetzt aufwändig Verzögerungen oder sonstwas einzubauen.
                              @apollon77 Vielen Dank für die Erklärung. Ich glaube ich bin auf einem guten Weg. Etwas länger drüber nachdenken hilft. Ich bin jetzt hergegangen und habe die Aufgabe halbiert und lasse dafür 2 Skripte laufen. Einmal die minimum Spannung und die entsprechende Zelle. Und einmal die maximum Spannung und die entsprechende Zelle.
                              Es scheint so, dass das Problem damit behoben ist.
                              VG
                              Harald
                              Update: Zu früh gefreut, der Fehler ist gerade wieder für beide Scripts aufgetaucht.😠
                              Ich werde jetzt versuchen die Aufgabe nochmals zu halbieren.
                              1202
