    3. Einsteigerfragen
    4. Einbindung von Geräten
    5. CC2652RB Zigbee Confiiguration Error
      RcTomcat @arteck last edited by
      @arteck Firmware sollte die neuste verfügbare sein soweit ich das nachvollziehen kann
        arteck Developer Most Active @RcTomcat last edited by arteck
        @rctomcat den plug hab ich auch...
        zeigmal die ersten 10 zeilen nach adapter start..
          @arteck das sieht so aus:
          zigbee.1
          	2023-01-23 10:54:09.005	error	DeviceConfigure:Failed to DeviceConfigure.configure 0x60a423fffe61de63 TS0121 (Error: Bind 0x60a423fffe61de63/1 genOnOff from '0x00124b001936a498/1' failed (AREQ - ZDO - bindRsp after 10000ms) at Timeout._onTimeout (/opt/iobroker/node_modules/zigbee-herdsman/src/utils/waitress.ts:64:35) at listOnTimeout (node:internal/timers:564:17) at processTimers (node:internal/timers:507:7))
          zigbee.1
          	2023-01-23 10:53:58.845	info	Zigbee started
          zigbee.1
          	2023-01-23 10:53:58.841	info	0x00158d000278d8fc (addr 41493): MFKZQ01LM - Xiaomi Mi/Aqara smart home cube (EndDevice)
          zigbee.1
          	2023-01-23 10:53:58.806	info	0x60a423fffe61de63 (addr 23258): TS0121_plug - TuYa 10A UK or 16A EU smart plug (Unknown)
          zigbee.1
          	2023-01-23 10:53:58.789	info	Configuring 0x60a423fffe61de63 TS0121
          zigbee.1
          	2023-01-23 10:53:58.697	info	Currently 2 devices are joined:
          zigbee.1
          	2023-01-23 10:53:58.674	info	--> transmitPower : normal
          zigbee.1
          	2023-01-23 10:53:58.612	info	Unable to disable LED, unsupported function.
          zigbee.1
          	2023-01-23 10:53:58.597	info	Coordinator firmware version: {"type":"zStack3x0","meta":{"transportrev":2,"product":1,"majorrel":2,"minorrel":7,"maintrel":1,"revision":20220219}}
          zigbee.1
          	2023-01-23 10:53:47.595	info	Installed Version: ioBroker/ioBroker.zigbee
          zigbee.1
          	2023-01-23 10:53:45.297	info	Starting Zigbee npm ...
          zigbee.1
          	2023-01-23 10:53:44.873	info	starting. Version 1.8.10 (non-npm: ioBroker/ioBroker.zigbee) in /opt/iobroker/node_modules/iobroker.zigbee, node: v18.8.0, js-controller: 4.0.23
          host.raspberrypi
          	2023-01-23 10:53:23.930	info	instance system.adapter.zigbee.1 started with pid 16659
          host.raspberrypi
          	2023-01-23 10:53:22.092	info	instance system.adapter.zigbee.1 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
          host.raspberrypi
          	2023-01-23 10:53:20.702	info	stopInstance system.adapter.zigbee.1 killing pid 21317
          zigbee.1
          	2023-01-23 10:53:20.201	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
          arteck Thomas Braun 2 Replies Last reply Reply Quote 0
            @rctomcat sagte in CC2652RB Zigbee Confiiguration Error:
            das ist nicht die GIT Version.. die da gezogen wird
            nochmal installiere die GIT version https://github.com/ioBroker/ioBroker.zigbee/wiki/GIT-install
              Thomas Braun Most Active @RcTomcat last edited by Thomas Braun
              node: v18.8.0
              Ist nicht die derzeitig empfohlene nodejs-Version.
              Und wenn es schon warum auch immer 18 sein muss:
              18.13.0 ist da aktueller Stand.
                @arteck ist nach wie vor das selbe Thema:
                zigbee.1
                	2023-01-23 16:06:06.479	error	DeviceConfigure:Failed to DeviceConfigure.configure 0x60a423fffe61de63 TS0121 (Error: Bind 0x60a423fffe61de63/1 genOnOff from '0x00124b001936a498/1' failed (AREQ - ZDO - bindRsp after 10000ms) at Timeout._onTimeout (/opt/iobroker/node_modules/zigbee-herdsman/src/utils/waitress.ts:64:35) at listOnTimeout (node:internal/timers:564:17) at processTimers (node:internal/timers:507:7))
                zigbee.1
                	2023-01-23 16:05:56.294	info	Zigbee started
                zigbee.1
                	2023-01-23 16:05:56.289	info	0x00158d000278d8fc (addr 41493): MFKZQ01LM - Xiaomi Mi/Aqara smart home cube (EndDevice)
                zigbee.1
                	2023-01-23 16:05:56.252	info	0x60a423fffe61de63 (addr 23258): TS0121_plug - TuYa 10A UK or 16A EU smart plug (Unknown)
                zigbee.1
                	2023-01-23 16:05:56.235	info	Configuring 0x60a423fffe61de63 TS0121
                zigbee.1
                	2023-01-23 16:05:56.131	info	Currently 2 devices are joined:
                zigbee.1
                	2023-01-23 16:05:56.102	info	--> transmitPower : normal
                zigbee.1
                	2023-01-23 16:05:56.029	info	Unable to disable LED, unsupported function.
                zigbee.1
                	2023-01-23 16:05:56.012	info	Coordinator firmware version: {"type":"zStack3x0","meta":{"transportrev":2,"product":1,"majorrel":2,"minorrel":7,"maintrel":1,"revision":20220219}}
                zigbee.1
                	2023-01-23 16:05:44.890	info	Installed Version: ioBroker/ioBroker.zigbee#050a845a81c8162245e962a9cf1fb0817392dea0
                Ich hatte zwischendurch den Adapter nochmals gelöscht und regulär neu installiert, daher war das wieder die Nicht-Git Version
                @Thomas-Braun das Problem besteht sowohl mit nodejs 16 als auch 18
                starting. Version 1.8.10 (non-npm: ioBroker/ioBroker.zigbee#050a845a81c8162245e962a9cf1fb0817392dea0) in /opt/iobroker/node_modules/iobroker.zigbee, node: v16.19.0, js-controller: 4.0.23
                  @rctomcat an node liegts es nicht
                  da funktioniert die konfiguration nicht.. warum auch immer
                    @arteck so scheint es ^^.
                    Wenn keiner mehr eine Idee hat werde ich eben leider beim CC2531 bleiben (zumindest was die beiden Steckdosen angeht)
                      @arteck also das Problem besteht scheinbar auch bei einer TS011F_plug_1 Steckdose.
                      Selbes Spiel: Am alten Zigbee Stick klappt alles, am neuen Device Configure failed
                      	DeviceConfigure:Failed to DeviceConfigure.configure 0xa4c13815a387d1a7 TS011F (Error: Read 0xa4c13815a387d1a7/1 genBasic(["manufacturerName","zclVersion","appVersion","modelId","powerSource",65534], {"sendWhen":"immediate","timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":true,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null,"writeUndiv":false}) failed (Timeout - 37808 - 1 - 17 - 0 - 1 after 10000ms) at Timeout._onTimeout (/opt/iobroker/node_modules/zigbee-herdsman/src/utils/waitress.ts:64:35) at listOnTimeout (node:internal/timers:559:17) at processTimers (node:internal/timers:502:7))
                        @rctomcat aktualisiere mal den adapter von GIT... da gabs ein Problem mit den tuya gedönz
                        1585
