    3. Einsteigerfragen
    4. Einbindung von Geräten
    5. Adapter für Ecoflow Einbindung
      mattenausohz last edited by mattenausohz
      Hallo! Ich bekomme neuerdings folgendes, ca. 10 Sekunden nach dem "subscribe" der Topics:
      Disconnected from mqtt.ecoflow.com: undefined
      Log:
      mqtt.1
      2023-02-06 11:08:59.891 info Disconnected from mqtt.ecoflow.com: undefined
      mqtt.1
      2023-02-06 11:08:49.506 info All states published
      mqtt.1
      2023-02-06 11:08:49.495 info Subscribe on "/app/15707484745384XXXXX/R331ZEB4ZE8XXXXX/thing/property/get"
      mqtt.1
      2023-02-06 11:08:49.494 info Subscribe on "/app/15707484745384XXXXX/R331ZEB4ZE8XXXX/thing/property/set"
      mqtt.1
      2023-02-06 11:08:49.493 info Subscribe on "/app/device/property/R331ZEB4ZEXXXXX"
      mqtt.1
      2023-02-06 11:08:49.492 info Subscribe on "#"
      mqtt.1
      2023-02-06 11:08:49.491 info Connected to mqtt.ecoflow.com
      mqtt.1
      2023-02-06 11:08:49.038 info Reconnected to mqtt.ecoflow.com
      mqtt.1
      2023-02-06 11:08:39.038 info Disconnected from mqtt.ecoflow.com: undefined
      mqtt.1
      2023-02-06 11:08:28.608 info All states published
      mqtt.1
      2023-02-06 11:08:28.580 info Subscribe on "/app/1570748474538XXXXX/R331ZEB4ZEXXXXX/thing/property/get"
      mqtt.1
      2023-02-06 11:08:28.579 info Subscribe on "/app/1570748474538XXXXX/R331ZEB4ZEXXXXX/thing/property/set"
      mqtt.1
      2023-02-06 11:08:28.577 info Subscribe on "/app/device/property/R331ZEB4ZE8XXXXX"
      mqtt.1
      2023-02-06 11:08:28.572 info Subscribe on "#"
      mqtt.1
      2023-02-06 11:08:28.569 info Connected to mqtt.ecoflow.com
      mqtt.1
      2023-02-06 11:08:27.931 info Try to connect to mqtts://mqtt.ecoflow.com:8883 with clientId=mqtt.mqtt.1and credentials app-632768efb1f54b13a8c719ed98xxxxx:*******************
      mqtt.1
      2023-02-06 11:08:27.363 info starting. Version 4.0.7 in /opt/iobroker/node_modules/iobroker.mqtt, node: v18.6.0, js-controller: 4.0.24
      Kann mir jemand etwas dazu sagen?
      Matthias
      G Ivan Andric 2 Replies Last reply Reply Quote 0
        g.polat @mattenausohz last edited by
        @mattenausohz sagte in Adapter für Ecoflow Einbindung:
        Log:
        mqtt.1
        mqtt.1
        mqtt.1
        mqtt.1
        mqtt.1
        mqtt.1
        mqtt.1
        mqtt.1
        mqtt.1
        mqtt.1
        mqtt.1
        mqtt.1
        mqtt.1
        mqtt.1
        mqtt.1
        mqtt.1
        mqtt.1
        Matthias
        Konntest Du das Problem lösen, habe das gleiche Problem hier 😞
        M haus-automatisierung 2 Replies Last reply Reply Quote 0
          mattenausohz @g.polat last edited by
          @g-polat Hallo! Nein, es hat sich niemand dazu gemeldet leider.
          • haus-automatisierung
            haus-automatisierung Developer Most Active @g.polat last edited by
            @g-polat Ich würde mal das Subscribe für die Wildcard # rausnehmen.
            Generell habe ich mich jetzt recht lange mit der River 2 Pro beschäftigt und nutze diese z.B. zum Überschuss-Laden der PV-Anlage (zu einem Teil). Alle Details habe ich hier dokumentiert:
            https://haus-automatisierung.com/hardware/2023/02/13/ecoflow-river-2-usv-batteriespeicher.html
              g.polat @haus-automatisierung last edited by
              @haus-automatisierung sagte in Adapter für Ecoflow Einbindung:
              welche Wildecard meinst Du?
              GP
                @g-polat sagte in Adapter für Ecoflow Einbindung:
                Diese:
                mqtt.1
                Aber war ja nicht dein Log.
                Hier noch meine Einstellungen
                • Ivan Andric
                  Ivan Andric @mattenausohz last edited by Ivan Andric
                  @mattenausohz
                  Ich habe das identische Verhalten. Habe mich jetzt mit dem MQTT Explorer statt dem ioBroker verbunden und der meldet auch "Disconnected from server". Es scheint wohl an ecoflow zu liegen.
                  • Ivan Andric
                    Ivan Andric last edited by
                    Wird die user-id hier mit "app-xxx" eingetragen?
                    /app/<userid>/R6XXXXXXXXXXXXXXX/thing/property/set
                    Ich habe es mit und ohne versucht, sehe aber keine Nachrichten wenn ich etwas mit der APP ändere.
                    (DELTA 2 und Android-App)
                      Maxtor62 last edited by Maxtor62
                      Same here,
                      (Delta Max und iOS)
                        haus-automatisierung Developer Most Active @Ivan Andric last edited by
                        @ivan-andric Läuft der EcoFlow denn durch und ist weiterhin per Wlan verbunden? Ich habe das seit Wochen laufen und keinen einzigen Verbindungsabbruch.
                          haus-automatisierung Developer Most Active @Maxtor62 last edited by
                          @maxtor62 Lustigerweise wurde ich nun auch rausgeworfen, nachdem ich meine Config hier geteilt habe.
                          Wichtiger Hinweis: Bitte denkt euch eine eigene, eindeutige Client-ID aus! Nicht aus irgendwelchen Screenshots hier abschreiben.
                          Der MQTT-Broker schließt wahrscheinlich die Verbindung zu bestehenden Clients mit der gleichen ID, wenn sich jemand mit der gleichen verbindet!! Die müssen eindeutig sein.
                          M C 2 Replies Last reply Reply Quote 0
                            Maxtor62 @haus-automatisierung last edited by Maxtor62
                            zwischenzeitlich hat es es mal funktioniert (gestern), jetzt habe ich eine neue Firmware drauf, jetzt geht im Moment nix. Die ändern die API wie manche Leute die Unterwäsche😊 😊
                            Mal weiter probieren.
                              firebowl last edited by firebowl
                              Ok das mit der ID erklärt das disconnecten und die ständigen mqtt Anfragen am DNS Server. 😅
                              Hat jemand das ganze mit ner Delta 2 zum laufen bekommen?
                              Ich kann mit @haus-automatisierung Script zwar die Werte abfragen und auch teilweise ändern aber scheinbar kann die Delta 2 kein pausieren beim Laden und weniger als 100Watt gehen auch nicht. Somit klappt das Überschussladen leider nicht. 😭
                                chka @haus-automatisierung last edited by
                                Was verstehst du unter client id? bei mir bricht die verbindung auch dauernd ab und wird neu aufgebaut.
                                ich habe in allen Skripten und im Adapter immer meine eigenen userID tokens usw genommen.
                                bei mir wird unter Objekte leider auch kein Eintrag gesetzt
                                  firebowl @chka last edited by
                                  @chka sagte in Adapter für Ecoflow Einbindung:
                                  Im MQTT Adapter gibts ein Feld für Client ID. Ist per default glaub leer. Da denkst dir was aus und trägst es ein, dann sollte es keine disconnects mehr geben.
                                    chka @firebowl last edited by
                                    @firebowl top danke jetzt setzt er auch die eintrage DANKE
                                      Loxoner86 last edited by
                                      Einfach cool was hier bisher möglich gemacht wurde um die Ecoflow per ioBroker zu steuern. Ich habe die Daten nun im ioBroker und kann zum Beispiel die Ladung pausieren, drosseln etc.
                                      Jedoch kriege ich es nicht hin den AC Out (Schuko) zu schalten hat jemand einen Tip für mich ?
                                      Zusätzlich möchte ich wissen ob es bei verbundener Einspeisung der Ecoflow (230V AC) möglich ist per Software die Entladung zu erzwingen ohne mittels myStrom oder Shelly die Einspeisung physisch zu trennen ?
                                      C 1 Reply Last reply Reply Quote 1
                                        chka @Loxoner86 last edited by
                                        @loxoner86
                                        abgebildet wird er über inv.cfgAcEnabled, wie man den schaltet bin ich noch am versuchen
                                          Der Hinweis mit der Client-ID war Goldrichtig, jetzt funzt es auch bei mir, vielen Dank.
                                          Kann bitte nochmal jemand für dummy's erklären wie wie genau die Schaltbefehle abgesetzt werden. Am besten mit einem Beispiel. Besten Dank.
                                            Es wird ein JSON-String auf dem entsprechenden Topic gepublished. Wie genau der Playload aussehen muss, findet man am besten raus, wenn man das /set topic abonniert und dann guckt, was die App macht.
                                            Genauer als hier kann ich es auch nicht erklären: https://www.youtube.com/watch?v=ezn0NDc9GAY
                                            212
                                            60335
