    3. Cloud Dienste
    4. Alexa findet keine Geräte mehr
      Homoran Global Moderator Administrators @weisnix27 last edited by Homoran
      @weisnix27 sagte in Alexa findet keine Geräte mehr:
      Irgendetwas mag meine Code-Tags nicht. Sorry.
      falsch ausgeschnitten, die code-tags sind bereits im Code vorgegeben.
      ich korrigier's
        Skript v.2023-01-02
        *** BASE SYSTEM ***
        Architecture: 	x86_64
        Docker: 	false
        Virtualization: kvm
        Distributor ID:	Debian
        Description:	Debian GNU/Linux 11 (bullseye)
        Release:	11
        Codename:	bullseye
        PRETTY_NAME="Debian GNU/Linux 11 (bullseye)"
        NAME="Debian GNU/Linux"
        VERSION_ID="11"
        VERSION="11 (bullseye)"
        VERSION_CODENAME=bullseye
        ID=debian
        HOME_URL="https://www.debian.org/"
        SUPPORT_URL="https://www.debian.org/support"
        BUG_REPORT_URL="https://bugs.debian.org/"
        Systemuptime and Load:
         19:59:56 up  2:04,  2 users,  load average: 0.33, 0.29, 0.21
        CPU threads: 4
        *** Time and Time Zones ***
        Thu Feb 16 18:59:56 UTC 2023
        Thu Feb 16 19:59:56 CET 2023
        CET +0100
        Europe/Berlin
        *** User and Groups ***
        root
        /root
        root
        *** X-Server-Setup ***
        X-Server: 	false
        Desktop:
        Terminal: 	tty
        Boot Target: 	graphical.target
        *** MEMORY ***
        Mem:            3.9G        2.5G        595M        0.0K        867M        1.2G
        Swap:           2.0G          0B        2.0G
        Total:          6.0G        2.5G        2.6G
                 3931 M total memory
                 2468 M used memory
                  412 M active memory
                 2673 M inactive memory
                  595 M free memory
                  120 M buffer memory
                  746 M swap cache
                 2044 M total swap
                    0 M used swap
                 2044 M free swap
        *** FILESYSTEM ***
        udev           devtmpfs  2.0G     0  2.0G   0% /dev
        tmpfs          tmpfs     394M  480K  393M   1% /run
        /dev/sda1      ext4       30G   13G   16G  46% /
        tmpfs          tmpfs     2.0G     0  2.0G   0% /dev/shm
        tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
        tmpfs          tmpfs     394M     0  394M   0% /run/user/0
        tmpfs          tmpfs     394M     0  394M   0% /run/user/1000
        Messages in dmesg:
        [Thu Feb 16 17:55:32 2023] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
        [Thu Feb 16 17:55:33 2023] EXT4-fs (sda1): re-mounted. Opts: errors=remount-ro
        Show mounted filesystems (real ones only):
        TARGET SOURCE    FSTYPE OPTIONS
        /      /dev/sda1 ext4   rw,relatime,errors=remount-ro
        /var:
        1.6G	/var/
        889M	/var/log
        873M	/var/log/journal/7e3943c3ab17475cabd5dd17245f5d31
        417M	/var/lib
        /opt/iobroker/backups:
        1.2G	/opt/iobroker/backups/
        4.0K	/opt/iobroker/backups/redistmp
        /opt/iobroker/iobroker-data:
        990M	/opt/iobroker/iobroker-data/
        693M	/opt/iobroker/iobroker-data/files
        158M	/opt/iobroker/iobroker-data/backup-objects
        87M	/opt/iobroker/iobroker-data/files/scenes.admin/static/js
        33M	/opt/iobroker/iobroker-data/files/devices.admin/static/js/main.10538062.js.map
        23M	/opt/iobroker/iobroker-data/objects.jsonl
        22M	/opt/iobroker/iobroker-data/files/echarts/static/js/main.31d27623.js.map
        22M	/opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.31d27623.js.map
        21M	/opt/iobroker/iobroker-data/files/echarts.admin/static/js/main.861e1441.js.map
        *** NodeJS-Installation ***
        /usr/bin/nodejs 	v16.19.0
        /usr/bin/node 		v16.19.0
        /usr/bin/npm 		8.19.3
        /usr/bin/npx 		8.19.3
        nodejs:
          Installed: 16.19.0-deb-1nodesource1
          Candidate: 16.19.0-deb-1nodesource1
          Version table:
         *** 16.19.0-deb-1nodesource1 500
                500 https://deb.nodesource.com/node_16.x bullseye/main amd64 Packages
                100 /var/lib/dpkg/status
             12.22.12~dfsg-1~deb11u3 500
                500 https://deb.debian.org/debian-security bullseye-security/main amd64 Packages
             12.22.5~dfsg-2~11u1 500
                500 http://debian.inf.tu-dresden.de/debian bullseye/main amd64 Packages
                500 http://deb.debian.org/debian bullseye/main amd64 Packages
        *** ioBroker-Installation ***
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        Core adapters versions
        js-controller: 	4.0.24
        admin: 		6.3.6
        javascript: 	6.1.4
        Adapters from github: 	0
        Adapter State
        + system.adapter.accuweather.0            : accuweather           : iobr                                     -  enabled
        + system.adapter.admin.0                  : admin                 : iobr                                     -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
        + system.adapter.alexa2.0                 : alexa2                : iobr                                     -  enabled
          system.adapter.alias-manager.0          : alias-manager         : iobr                                     -  enabled
        + system.adapter.backitup.0               : backitup              : iobr                                     -  enabled
          system.adapter.blink4home.0             : blink4home            : iobr                                     - disabled
        + system.adapter.cloud.0                  : cloud                 : iobr                                     -  enabled
        + system.adapter.device-watcher.0         : device-watcher        : iobr                                     -  enabled
          system.adapter.devices.0                : devices               : iobr                                     -  enabled
        + system.adapter.discovery.0              : discovery             : iobr                                     -  enabled
        + system.adapter.echarts.0                : echarts               : iobr                                     -  enabled
        + system.adapter.fb-checkpresence.0       : fb-checkpresence      : iobr                                     -  enabled
          system.adapter.flot.0                   : flot                  : iobr                                     -  enabled
        + system.adapter.fritzdect.0              : fritzdect             : iobr                                     -  enabled
        + system.adapter.heatingcontrol.0         : heatingcontrol        : iobr                                     -  enabled
        + system.adapter.history.0                : history               : iobr                                     -  enabled
        + system.adapter.ical.0                   : ical                  : iobr                                     -  enabled
          system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: iobr                                     -  enabled
          system.adapter.icons-fatcow-hosting.0   : icons-fatcow-hosting  : iobr                                     -  enabled
          system.adapter.icons-icons8.0           : icons-icons8          : iobr                                     -  enabled
          system.adapter.icons-mfd-png.0          : icons-mfd-png         : iobr                                     -  enabled
          system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobr                                     -  enabled
          system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: iobr                                     -  enabled
          system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : iobr                                     -  enabled
        + system.adapter.info.0                   : info                  : iobr                                     -  enabled
        + system.adapter.iot.0                    : iot                   : iobr                                     -  enabled
        + system.adapter.javascript.0             : javascript            : iobr                                     -  enabled
        + system.adapter.lightcontrol.0           : lightcontrol          : iobr                                     -  enabled
        + system.adapter.mihome-vacuum.0          : mihome-vacuum         : iobr                                     -  enabled, port: 54321
        + system.adapter.mqtt.0                   : mqtt                  : iobr                                     -  enabled, port: 1888, bind: 192.168.178.200
          system.adapter.net-tools.0              : net-tools             : iobr                                     - disabled
        + system.adapter.ping.0                   : ping                  : iobr                                     -  enabled
        + system.adapter.proxmox.0                : proxmox               : iobr                                     -  enabled, port: 8006
        + system.adapter.sayit.0                  : sayit                 : iobr                                     -  enabled
        + system.adapter.scenes.0                 : scenes                : iobr                                     -  enabled
        + system.adapter.shelly.0                 : shelly                : iobr                                     -  enabled, port: 1500, bind: 0.0.0.0
        + system.adapter.shelly.1                 : shelly                : iobr                                     -  enabled, port: 1885, bind: 0.0.0.0
        + system.adapter.sonoff.0                 : sonoff                : iobr                                     -  enabled, port: 1500, bind: 0.0.0.0
        + system.adapter.sourceanalytix.0         : sourceanalytix        : iobr                                     -  enabled
        + system.adapter.spotify-premium.0        : spotify-premium       : iobr                                     -  enabled
          system.adapter.telegram.0               : telegram              : iobr                                     - disabled, port: 8443, bind: 0.0.0.0
        + system.adapter.trashschedule.0          : trashschedule         : iobr                                     -  enabled
          system.adapter.vis-bars.0               : vis-bars              : iobr                                     -  enabled
          system.adapter.vis-colorpicker.0        : vis-colorpicker       : iobr                                     -  enabled
          system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : iobr                                     -  enabled
          system.adapter.vis-google-fonts.0       : vis-google-fonts      : iobr                                     -  enabled
          system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobr                                     -  enabled
          system.adapter.vis-icontwo.0            : vis-icontwo           : iobr                                     -  enabled
        + system.adapter.vis-inventwo.0           : vis-inventwo          : iobr                                     -  enabled
          system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iobr                                     -  enabled
          system.adapter.vis-map.0                : vis-map               : iobr                                     -  enabled
          system.adapter.vis-players.0            : vis-players           : iobr                                     -  enabled
          system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobr                                     -  enabled
          system.adapter.vis-weather.0            : vis-weather           : iobr                                     -  enabled
          system.adapter.vis.0                    : vis                   : iobr                                     -  enabled
        + system.adapter.vw-connect.0             : vw-connect            : iobr                                     -  enabled
          system.adapter.weatherunderground.0     : weatherunderground    : iobr                                     -  enabled
        + system.adapter.web.0                    : web                   : iobr                                     -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
        + system.adapter.zigbee.0                 : zigbee                : iobr                                     -  enabled, port: tcp://192.168.178.220:4401
        + instance is alive
        ioBroker-Repositories
        Active repo(s): beta
        Installed ioBroker-Instances
        Used repository: beta
        Adapter    "accuweather"  : 1.2.4    , installed 1.2.4
        Adapter    "admin"        : 6.3.6    , installed 6.3.6
        Adapter    "alexa2"       : 3.23.2   , installed 3.23.2
        Adapter    "backitup"     : 2.6.0    , installed 2.6.0
        Adapter    "blink4home"   : 0.1.1    , installed 0.1.1
        Adapter    "cloud"        : 4.3.1    , installed 4.3.1
        Adapter    "device-watcher": 2.6.0   , installed 2.6.0
        Adapter    "devices"      : 1.1.2    , installed 1.1.2
        Adapter    "discovery"    : 3.1.0    , installed 3.1.0
        Adapter    "echarts"      : 1.4.4    , installed 1.4.4
        Adapter    "fb-checkpresence": 1.1.25, installed 1.1.25
        Adapter    "fritzdect"    : 2.3.1    , installed 2.3.1
        Adapter    "heatingcontrol": 2.10.6  , installed 2.10.6
        Adapter    "history"      : 2.2.4    , installed 2.2.4
        Adapter    "ical"         : 1.13.2   , installed 1.13.2
        Adapter    "icons-mfd-png": 1.1.0    , installed 1.1.0
        Adapter    "icons-open-icon-library-png": 0.1.2, installed 0.1.3
        Adapter    "info"         : 1.9.26   , installed 1.9.26
        Adapter    "iot"          : 1.14.3   , installed 1.14.3
        Adapter    "javascript"   : 6.1.4    , installed 6.1.4
        Controller "js-controller": 4.0.24   , installed 4.0.24
        Adapter    "lightcontrol" : 0.1.3    , installed 0.1.3
        Adapter    "mihome-vacuum": 3.9.5    , installed 3.9.5
        Adapter    "mqtt"         : 4.0.7    , installed 4.0.7
        Adapter    "ping"         : 1.5.3    , installed 1.5.3
        Adapter    "proxmox"      : 1.3.5    , installed 1.3.5
        Adapter    "sayit"        : 1.12.6   , installed 1.12.6
        Adapter    "shelly"       : 6.4.0    , installed 6.4.0
        Adapter    "socketio"     : 6.3.3    , installed 6.3.3
        Adapter    "sonoff"       : 2.5.1    , installed 2.5.1
        Adapter    "sourceanalytix": 0.4.14  , installed 0.4.14
        Adapter    "spotify-premium": 1.2.2  , installed 1.2.2
        Adapter    "telegram"     : 1.15.2   , installed 1.15.2
        Adapter    "trashschedule": 2.2.0    , installed 2.2.0
        Adapter    "vis"          : 1.4.16   , installed 1.4.16
        Adapter    "vis-colorpicker": 1.2.0  , installed 1.2.0
        Adapter    "vis-hqwidgets": 1.3.1    , installed 1.3.1
        Adapter    "vis-icontwo"  : 0.90.0   , installed 0.90.0
        Adapter    "vis-map"      : 1.0.4    , installed 1.0.4
        Adapter    "vis-material" : 0.1.3    , installed 0.1.3
        Adapter    "vis-material-advanced": 1.7.2, installed 1.7.2
        Adapter    "vis-weather"  : 2.5.6    , installed 2.5.6
        Adapter    "vw-connect"   : 0.0.56   , installed 0.0.56
        Adapter    "weatherunderground": 3.4.2, installed 3.4.2
        Adapter    "web"          : 5.5.0    , installed 5.5.0
        Adapter    "ws"           : 2.3.5    , installed 2.3.5
        Adapter    "zigbee"       : 1.8.10   , installed 1.8.10
        Objects and States
        Objects: 	12397
        States: 	10682
        Hit:1 http://deb.debian.org/debian bullseye InRelease
        Hit:2 http://deb.debian.org/debian bullseye-updates InRelease
        Hit:3 http://deb.debian.org/debian bullseye-backports InRelease
        Hit:4 http://debian.inf.tu-dresden.de/debian bullseye InRelease
        Hit:5 https://deb.nodesource.com/node_16.x bullseye InRelease
        Hit:6 http://debian.inf.tu-dresden.de/debian bullseye-updates InRelease
        Hit:7 https://deb.debian.org/debian-security bullseye-security InRelease
        Reading package lists...
        Pending Updates: 0
        *** Listening Ports ***
        tcp        0      0 0.0.0.0:1500            0.0.0.0:*               LISTEN      1001       14397      672/io.sonoff.0
        tcp        0      0 0.0.0.0:1885            0.0.0.0:*               LISTEN      1001       15927      802/io.shelly.1
        tcp        0      0 192.168.178.200:1888    0.0.0.0:*               LISTEN      1001       15768      772/io.mqtt.0
        tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       12916      363/iobroker.js-con
        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       13815      363/iobroker.js-con
        tcp        0      0 127.0.0.1:3306          0.0.0.0:*               LISTEN      106        13544      447/mariadbd
        tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          11479      1/init
        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          13536      458/sshd: /usr/sbin
        tcp6       0      0 :::111                  :::*                    LISTEN      0          9687       1/init
        tcp6       0      0 :::8081                 :::*                    LISTEN      1001       12983      531/io.admin.0
        tcp6       0      0 :::8082                 :::*                    LISTEN      1001       17731      1236/io.web.0
        tcp6       0      0 :::22                   :::*                    LISTEN      0          13538      458/sshd: /usr/sbin
        udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          11480      1/init
        udp        0      0 0.0.0.0:53421           0.0.0.0:*                           1001       14772      739/io.mihome-vacuu
        udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       13286      653/io.shelly.0
        udp6       0      0 :::111                  :::*                                0          9690       1/init
        2023-02-16 19:47:56.012  - warn: sonoff.0 (672) Client [shellyplug-s-9DD255]  has invalid password(2703) or username(SH)
        2023-02-16 19:48:52.953  - warn: sonoff.0 (672) Client [shellyplug-s-9DD255]  has invalid password(2703) or username(SH)
        2023-02-16 19:49:52.617  - warn: sonoff.0 (672) Client [shellyplug-s-9DD255]  has invalid password(2703) or username(SH)
        2023-02-16 19:50:51.334  - warn: sonoff.0 (672) Client [shellyplug-s-9DD255]  has invalid password(2703) or username(SH)
        2023-02-16 19:51:56.964  - warn: sonoff.0 (672) Client [shellyplug-s-9DD255]  has invalid password(2703) or username(SH)
        2023-02-16 19:53:00.790  - warn: sonoff.0 (672) Client [shellyplug-s-9DD255]  has invalid password(2703) or username(SH)
        2023-02-16 19:53:55.012  - warn: sonoff.0 (672) Client [shellyplug-s-9DD255]  has invalid password(2703) or username(SH)
        2023-02-16 19:54:59.181  - warn: sonoff.0 (672) Client [shellyplug-s-9DD255]  has invalid password(2703) or username(SH)
        2023-02-16 19:56:02.411  - warn: sonoff.0 (672) Client [shellyplug-s-9DD255]  has invalid password(2703) or username(SH)
        2023-02-16 19:56:57.165  - info: web.0 (1236) ==> Connected system.user.admin from ::ffff:192.168.178.77
        2023-02-16 19:56:58.535  - info: web.0 (1236) <== Disconnect system.user.admin from ::ffff:192.168.178.77
        2023-02-16 19:56:58.713  - warn: sonoff.0 (672) Client [shellyplug-s-9DD255]  has invalid password(2703) or username(SH)
        2023-02-16 19:56:58.830  - info: web.0 (1236) ==> Connected system.user.admin from ::ffff:192.168.178.77
        2023-02-16 19:57:05.360  - info: web.0 (1236) <== Disconnect system.user.admin from ::ffff:192.168.178.77 vis.0
        2023-02-16 19:58:02.664  - warn: sonoff.0 (672) Client [shellyplug-s-9DD255]  has invalid password(2703) or username(SH)
        2023-02-16 19:58:08.343  - info: javascript.0 (558) script.js.common.Eigene.Bewegungsmelder: Bewegungsmelder Flur_Mitte: Ausgelöst und alle Kriterien erfüllt, daher wird eingeschaltet.
        2023-02-16 19:59:01.311  - warn: sonoff.0 (672) Client [shellyplug-s-9DD255]  has invalid password(2703) or username(SH)
        2023-02-16 19:59:38.344  - info: javascript.0 (558) script.js.common.Eigene.Bewegungsmelder: Bewegungsmelder Flur_Mitte: Timer (90s) abgelaufen und alle Kriterien erfüllt, daher wird ausgeschaltet.
        2023-02-16 20:00:00.008  - info: javascript.0 (558) script.js.common.Eigene.Shelly-Verbräuche2: Shelly Verbrauch: Verbrauchswerte aktualisiert: 3 | Reboots korrigiert: 0 | Unveränderte Werte: 1
        2023-02-16 20:00:00.014  - info: javascript.0 (558) script.js.common.Eigene.Shelly-Verbräuche: Shelly Verbrauch: Verbrauchswerte aktualisiert: 1 | Reboots korrigiert: 0 | Unveränderte Werte: 8
        2023-02-16 20:00:00.016  - info: host.iobr instance system.adapter.ical.0 started with pid 9759
        2023-02-16 20:00:00.668  - warn: sonoff.0 (672) Client [shellyplug-s-9DD255]  has invalid password(2703) or username(SH)
        2023-02-16 20:00:01.553  - error: trashschedule.0 (1472) no events found in ical instance - check configuration and restart instance
        2023-02-16 20:00:05.000  - error: trashschedule.0 (1472) no events found in ical instance - check configuration and restart instance
        2023-02-16 20:00:07.082  - info: host.iobr instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
        iob diag has finished.
        Press any key for a summary
        Copy text starting here:
        		     v.2023-01-02
        Operatingsystem: 	Debian GNU/Linux 11 (bullseye)
        Installation: 		kvm
        Timezone: 		Europe/Berlin
        User-ID: 		0
        X-Server: 		false
        Pending OS-Updates: 	0
        Nodejs-Installation: 	/usr/bin/nodejs 	v16.19.0
        			/usr/bin/npm 		8.19.3
        			/usr/bin/npx 		8.19.3
        ioBroker Core: 		js-controller 		4.0.24
        			admin 			6.3.6
        ioBroker Status: 	iobroker is running on this host.
        Objects type: jsonl
        States  type: jsonl
        Status admin:
        Pending iob updates: 	0
        Objects: 		12397
        States: 		10682
        Size of iob-Database:
        24M	/opt/iobroker/iobroker-data/objects.jsonl
        8.9M	/opt/iobroker/iobroker-data/objects.json.migrated
        8.9M	/opt/iobroker/iobroker-data/objects.json.bak.migrated
        17M	/opt/iobroker/iobroker-data/states.jsonl
        1.5M	/opt/iobroker/iobroker-data/states.json.migrated
        1.5M	/opt/iobroker/iobroker-data/states.json.bak.migrated
          weisnix27 @Thomas Braun last edited by
          @thomas-braun said in Alexa findet keine Geräte mehr:
          @weisnix27
          Tauchen die Geräte denn überhaupt in der Alexa App auf?
          Genau darum geht es ja. Leider nein, im IOB sieht es gut aus, bei Alexa kommt nix
            Thomas Braun Most Active @weisnix27 last edited by Thomas Braun
            @weisnix27
            Meld einem Standard User an und lass den root in Ruhe.
            Mit Alexa App meinte ich auch die originale App oder die Amazon Webseite.
              bei Alexa kommt nix
              wie hast du denn alexa eingebunden?
              hast du eine Assistenten Lizenz?
                @thomas-braun sagte in Alexa findet keine Geräte mehr:
                @weisnix27
                Meld einem Standard User an und lass denn root in Ruhe.
                @weisnix27
                hat mit dem aktuellen Problem wahrscheinlich nichts zu tun, aber dann auch noch iobroker stoppen und den fixer aufrufen.
                Die Nutzung von root verbiegt die Rechte
                  weisnix27 @Homoran last edited by
                  @Homoran Nein, eine Assistenten Lizenz habe ich nicht, ich hatte das vor ein paar Jahren mal mit Alexa am Laufen, dass ich Datenpunkte schalten konnte.
                  Brauche ich die mittlerweile? Dann kaufe ich die natürlich. Das war ja mein Einwand im Ausgangspost, dass ich eventuell noch eine Lizenz brauche.
                  Ich habe Alexa ewig nicht zum Geräte steuern benutzt, andersherum kann ich aber vom iobroker schon meine Alexas ansteuern (lauter, leiser, an/aus beim FireTV)
                    meines Wissens nicht mehr oder weniger als früher.
                    Da ich keine fremden Frauen in meinem Haus dulde, muss das jemand anders beantworten.
                      @homoran Ich mag die auch nicht wirklich aber zum Radiohören und als Wecker okay... Ich will da eigentlich auch gar nicht mit sprechen, aber Frauchen möchte gerne zwei Sachen mit Sprache steuern. Sonst wäre ich da gar nicht dran gegangen.
                        weisnix27 @weisnix27 last edited by
                        @Homoran So es läuft, Fehler gefunden. Irgendwie hatte sich der iobroker Skill verabschiedet. Ich musste in der Alexa App den Skill neu connecten/aktivieren und direkt danach waren alle Geräte da.
                        1.5k
                        1337
