    4. Test Adapter zigbee2mqtt
      Aragon @Noosi last edited by Aragon
      @idlebit
      Guten Morgen,
      ich will auf zigbee2mqtt umsteigen habe Folgendes Problem mit dem Aqara presence detector FP1 RTCZCGQ11LM in Verbindung mit dem zigbee2mqtt Adapter.
      Bei Z2M bekomme ich folgende Warnung nach/während dem Koppeln.
      warning 2023-02-18 10:22:24zigbee-herdsman-converters:xiaomi:aqara_fp1: Unknown key 0x010c = 3
      Iobroker Protokoll:
      host.AndCom
      	2023-02-18 10:23:39.276	info	"system.adapter.zigbee2mqtt.0" disabled
      host.AndCom
      	2023-02-18 10:23:30.137	warn	Do not restart adapter system.adapter.zigbee2mqtt.0 because restart loop detected
      host.AndCom
      	2023-02-18 10:23:30.137	info	Restart adapter system.adapter.zigbee2mqtt.0 because enabled
      host.AndCom
      	2023-02-18 10:23:30.136	error	instance system.adapter.zigbee2mqtt.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
      zigbee2mqtt.0
      	2023-02-18 10:23:29.580	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
      zigbee2mqtt.0
      	2023-02-18 10:23:29.579	info	terminating
      zigbee2mqtt.0
      	2023-02-18 10:23:29.568	warn	Start try again in 1 seconds...
      zigbee2mqtt.0
      	2023-02-18 10:23:29.546	error	Cannot set properties of undefined (setting 'prop')
      zigbee2mqtt.0
      	2023-02-18 10:23:29.546	error	TypeError: Cannot set properties of undefined (setting 'prop') at createDeviceFromExposes (/opt/iobroker/node_modules/iobroker.zigbee2mqtt/lib/exposes.js:970:29) at DeviceController.createDeviceDefinitions (/opt/iobroker/node_modules/iobroker.zigbee2mqtt/lib/deviceController.js:30:39) at Zigbee2mqtt.messageParse (/opt/iobroker/node_modules/iobroker.zigbee2mqtt/main.js:154:40) at WebSocket.<anonymous> (/opt/iobroker/node_modules/iobroker.zigbee2mqtt/main.js:125:18) at WebSocket.emit (node:events:525:35) at Receiver.receiverOnMessage (/opt/iobroker/node_modules/ws/lib/websocket.js:1180:20) at Receiver.emit (node:events:513:28) at Receiver.dataMessage (/opt/iobroker/node_modules/ws/lib/receiver.js:541:14) at Receiver.getData (/opt/iobroker/node_modules/ws/lib/receiver.js:459:17) at Receiver.startLoop (/opt/iobroker/node_modules/ws/lib/receiver.js:158:22)
      zigbee2mqtt.0
      	2023-02-18 10:23:29.544	error	unhandled promise rejection: Cannot set properties of undefined (setting 'prop')
      zigbee2mqtt.0
      	2023-02-18 10:23:29.544	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      Der Z2M Adapter wird Rot, wenn ich den FP1 lösche, dann wird die Instanz wieder Grün.
      Fehler tritt mit Conbee2 und Zonoff Stick auf.
      Bitte um Hilfe, sonst lohnt sich der umstieg für mich nicht, habe mehrere FP1 im einsatz.
      IdleBit arteck 2 Replies Last reply Reply Quote 0
      • IdleBit
        IdleBit @Aragon last edited by
        @aragon
        Ich bin grad unterwegs, daher nur kurz und knapp.
        Hier kann ich so grundsätzlich nicht viel machen und muss auf zigbee2mqtt verweisen.
        Aber das der Adapter dann abstürzt ist nicht ok und das werde ich mir natürlich ansehen.
        @andre hattest du nicht auch den FP1 im Einsatz?
        A andre 2 Replies Last reply Reply Quote 0
          Aragon @IdleBit last edited by
          @idlebit Vielen Dank für die schnelle Antwort und deine Mühe
          IdleBit 1 Reply Last reply Reply Quote 0
            arteck Developer Most Active @Aragon last edited by
            @aragon sagte in Test Adapter zigbee2mqtt:
            aqara_fp1
            der hat noch ein paar probleme .. hab ich gerade festgestellt.. musst du abwarten
            • andre
              andre Developer @IdleBit last edited by andre
              @idlebit sagte in Test Adapter zigbee2mqtt:
              Ich hab den auch im Einsatz. Pairing war problemlos. Meldungen im Log habe ich nicht. Coordinator ist ein Sonoff ZBDongle-E.
              Derzeit verwende ich nur den Datenpunkt "presence" über verschiedene scripte. Das tut zuverlässig, sonst hätte ich schon Probleme mit der Frau... 😉
              [EDIT] Mal bei zigbee2mqtt geschaut? Da scheint es Einschränkungen zu geben was Zigbee Channel und Firmware angeht...
              https://www.zigbee2mqtt.io/devices/RTCZCGQ11LM.html
              MfG,
              André
                arteck Developer Most Active @andre last edited by
                @andre ne du der macht allgemein noch probleme...
                da werden nicht alle exposes gezogen... hab mal ein Fix auf Github gestellt
                • IdleBit
                  IdleBit @arteck last edited by
                  @arteck Hast mal nen Link für mich?
                  • IdleBit
                    @aragon Kannst du mal aus dem Git installieren?
                    Jetzt sollte maximal "nur" noch ein Warning auftauchen, und wenn du auf Debug stellst sollte es noch mehr Infos über das Problem kommen...
                    Könntest Du mir die mal zu Verfügung stellen?
                    @toralt das könnte auch mit deinen Problem zusammenhängen also nen Versuch wert 😉
                      arteck Developer Most Active @IdleBit last edited by
                      @idlebit schau dir die exposes an
                      https://github.com/Koenkk/zigbee-herdsman-converters/blob/7e504f2e80beaf25b19372c3ea41585db5b9c1af/devices/xiaomi.js#L1770
                        Aragon @arteck last edited by
                        @idlebit
                        Ich hoffe ich habe alles richtig gemacht.
                        Hier die aktuelle Ausgabe im Protokoll. Die Instanz wird Rot.
                        host.AndCom
                        	2023-02-18 14:27:49.105	info	"system.adapter.zigbee2mqtt.0" disabled
                        host.AndCom
                        	2023-02-18 14:27:42.918	info	Restart adapter system.adapter.zigbee2mqtt.0 because enabled
                        host.AndCom
                        	2023-02-18 14:27:42.917	error	instance system.adapter.zigbee2mqtt.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                        mqtt.0
                        	2023-02-18 14:27:42.457	info	Server: Changed type of "mqtt.0.zigbee2mqtt.0x54ef4410006492a3" from "number" to "string"
                        zigbee2mqtt.0
                        	2023-02-18 14:27:42.360	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
                        zigbee2mqtt.0
                        	2023-02-18 14:27:42.358	info	terminating
                        zigbee2mqtt.0
                        	2023-02-18 14:27:42.350	debug	Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) }
                        zigbee2mqtt.0
                        	2023-02-18 14:27:42.318	warn	Start try again in 1 seconds...
                        zigbee2mqtt.0
                        	2023-02-18 14:27:42.304	debug	Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) }
                        zigbee2mqtt.0
                        	2023-02-18 14:27:42.291	error	Cannot set properties of undefined (setting 'prop')
                        zigbee2mqtt.0
                        	2023-02-18 14:27:42.290	error	TypeError: Cannot set properties of undefined (setting 'prop') at createDeviceFromExposes (/opt/iobroker/node_modules/iobroker.zigbee2mqtt/lib/exposes.js:970:29) at DeviceController.createDeviceDefinitions (/opt/iobroker/node_modules/iobroker.zigbee2mqtt/lib/deviceController.js:30:39) at Zigbee2mqtt.messageParse (/opt/iobroker/node_modules/iobroker.zigbee2mqtt/main.js:154:40) at WebSocket.<anonymous> (/opt/iobroker/node_modules/iobroker.zigbee2mqtt/main.js:125:18) at WebSocket.emit (node:events:525:35) at Receiver.receiverOnMessage (/opt/iobroker/node_modules/ws/lib/websocket.js:1180:20) at Receiver.emit (node:events:513:28) at Receiver.dataMessage (/opt/iobroker/node_modules/ws/lib/receiver.js:541:14) at Receiver.getData (/opt/iobroker/node_modules/ws/lib/receiver.js:459:17) at Receiver.startLoop (/opt/iobroker/node_modules/ws/lib/receiver.js:158:22)
                        zigbee2mqtt.0
                        	2023-02-18 14:27:42.289	error	unhandled promise rejection: Cannot set properties of undefined (setting 'prop')
                        zigbee2mqtt.0
                        	2023-02-18 14:27:42.288	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                        zigbee2mqtt.0
                        	2023-02-18 14:27:42.287	info	MQTT publish: topic 'zigbee2mqtt/bridge/event', payload '{"data":{"friendly_name":"0x54ef4410006492a3","ieee_address":"0x54ef4410006492a3","status":"started"},"type":"device_interview"}'
                        zigbee2mqtt.0
                        	2023-02-18 14:27:42.272	info	Starting interview of '0x54ef4410006492a3'
                        zigbee2mqtt.0
                        	2023-02-18 14:27:42.270	info	MQTT publish: topic 'zigbee2mqtt/bridge/event', payload '{"data":{"friendly_name":"0x54ef4410006492a3","ieee_address":"0x54ef4410006492a3"},"type":"device_joined"}'
                        zigbee2mqtt.0
                        	2023-02-18 14:27:42.264	error	Cannot set properties of undefined (setting 'prop')
                        zigbee2mqtt.0
                        	2023-02-18 14:27:42.264	error	TypeError: Cannot set properties of undefined (setting 'prop') at createDeviceFromExposes (/opt/iobroker/node_modules/iobroker.zigbee2mqtt/lib/exposes.js:970:29) at DeviceController.createDeviceDefinitions (/opt/iobroker/node_modules/iobroker.zigbee2mqtt/lib/deviceController.js:30:39) at Zigbee2mqtt.messageParse (/opt/iobroker/node_modules/iobroker.zigbee2mqtt/main.js:154:40) at WebSocket.<anonymous> (/opt/iobroker/node_modules/iobroker.zigbee2mqtt/main.js:125:18) at WebSocket.emit (node:events:525:35) at Receiver.receiverOnMessage (/opt/iobroker/node_modules/ws/lib/websocket.js:1180:20) at Receiver.emit (node:events:513:28) at Receiver.dataMessage (/opt/iobroker/node_modules/ws/lib/receiver.js:541:14) at Receiver.getData (/opt/iobroker/node_modules/ws/lib/receiver.js:459:17) at Receiver.startLoop (/opt/iobroker/node_modules/ws/lib/receiver.js:158:22)
                        zigbee2mqtt.0
                        	2023-02-18 14:27:42.261	error	unhandled promise rejection: Cannot set properties of undefined (setting 'prop')
                        zigbee2mqtt.0
                        	2023-02-18 14:27:42.260	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                        zigbee2mqtt.0
                        	2023-02-18 14:27:42.234	info	Device '0x54ef4410006492a3' joined
                        zigbee2mqtt.0
                        	2023-02-18 14:27:29.384	info	MQTT publish: topic 'zigbee2mqtt/bridge/response/permit_join', payload '{"data":{"time":254,"value":true},"status":"ok","transaction":"1t5n7-4"}'
                        • IdleBit
                          Das scheint aber nicht die aktuelle Version vom git zu sein.
                          Wie bist du vorgegangen?
                            @idlebit
                            Instanz entfernt
                            Expertenmodus eingeschaltet
                            auf die Katze geklickt
                            dann von Github geklickt
                            Adapter aus Liste ausgesucht und installiert
                            Anschließend Adapter installiert
                            • IdleBit
                              @aragon Entfernen musst du nichts, aber der Rest passt .. komisch ich prüfe ..
                                @idlebit
                                Mein Fehler hatte in den Einstellungen unter Repositories auf Beta stehen, umgestellt auf Stable.
                                Jetzt siehts anders aus, Instanz bleibt GRÜN.
                                zigbee2mqtt.0
                                	2023-02-18 14:53:17.474	debug	{"date_code":"20210121","definition":{"description":"Aqara presence detector FP1","exposes":[{"access":5,"description":"Indicates whether the device detected presence","name":"presence","property":"presence","type":"binary","value_off":false,"value_on":true},{"access":1,"description":"Temperature of the device","name":"device_temperature","property":"device_temperature","type":"numeric","unit":"°C"},{"access":1,"description":"Number of power outages (since last pairing)","name":"power_outage_count","property":"power_outage_count","type":"numeric"},{"access":1,"description":"Presence events: \"enter\", \"leave\", \"left_enter\", \"right_leave\", \"right_enter\", \"left_leave\", \"approach\", \"away\"","name":"presence_event","property":"presence_event","type":"enum","values":["enter","leave","left_enter","right_leave","right_enter","left_leave","approach","away"]},{"access":7,"description":"Monitoring mode with or without considering right and left sides","name":"monitoring_mode","property":"monitoring_mode","type":"enum","values":["undirected","left_right"]},{"access":7,"description":"The distance at which the sensor detects approaching","name":"approach_distance","property":"approach_distance","type":"enum","values":["far","medium","near"]},{"access":7,"description":"Different sensitivities means different static human body recognition rate and response speed of occupied","name":"motion_sensitivity","property":"motion_sensitivity","type":"enum","values":["low","medium","high"]},{"access":2,"description":"Reset the status of no presence","name":"reset_nopresence_status","property":"reset_nopresence_status","type":"enum","values":[""]},{"access":1,"description":"Most recent region event. Event template is \"region_<REGION_ID>_<EVENT_TYPE>\", where <REGION_ID> is region number (1-10), <EVENT_TYPE> is one of \"enter\", \"leave\", \"occupied\", \"unoccupied\". \"enter\" / \"leave\" events are usually triggered first, followed by \"occupied\" / \"unoccupied\" after a couple of seconds.","name":"action","property":"action","type":"enum","values":["region_*_enter","region_*_leave","region_*_occupied","region_*_unoccupied"]},{"access":2,"description":"Definition of a new region to be added (or replace existing one). Creating or modifying a region requires you to define which zones of a 7x4 detection grid should be active for that zone. Regions can overlap, meaning that a zone can be defined in more than one region (eg. \"zone x = 1 & y = 1\" can be added to region 1 & 2). \"Zone x = 1 & y = 1\" is the nearest zone on the right (from sensor's perspective, along the detection path).","features":[{"access":2,"name":"region_id","property":"region_id","type":"numeric","value_max":10,"value_min":1},{"access":2,"item_type":{"features":[{"access":2,"name":"x","property":"x","type":"numeric","value_max":4,"value_min":1},{"access":2,"name":"y","property":"y","type":"numeric","value_max":7,"value_min":1}],"name":"zone_position","type":"composite"},"name":"zones","property":"zones","type":"list"}],"name":"region_upsert","property":"region_upsert","type":"composite"},{"access":2,"description":"Region definition to be deleted from the device.","features":[{"access":2,"name":"region_id","property":"region_id","type":"numeric","value_max":10,"value_min":1}],"name":"region_delete","property":"region_delete","type":"composite"},{"access":1,"description":"Link quality (signal strength)","name":"linkquality","property":"linkquality","type":"numeric","unit":"lqi","value_max":255,"value_min":0}],"model":"RTCZCGQ11LM","options":[{"access":2,"description":"Calibrates the device_temperature value (absolute offset), takes into effect on next report of device.","name":"device_temperature_calibration","property":"device_temperature_calibration","type":"numeric"}],"supports_ota":true,"vendor":"Xiaomi"},"disabled":false,"endpoints":{"1":{"bindings":[],"clusters":{"input":["genBasic","genIdentify","aqaraOpple"],"output":["genIdentify","genOta"]},"configured_reportings":[],"scenes":[]}},"friendly_name":"0x54ef4410006492a3","ieee_address":"0x54ef4410006492a3","interview_completed":false,"interviewing":false,"manufacturer":"aqara","model_id":"lumi.motion.ac01","network_address":58871,"power_source":"DC Source","software_build_id":"","supported":true,"type":"EndDevice"}
                                zigbee2mqtt.0
                                	2023-02-18 14:53:17.473	warn	Cannot 0x54ef4410006492a3 create Device from Exposes!
                                zigbee2mqtt.0
                                	2023-02-18 14:53:17.464	debug	Device: 0x54ef4410006492a3 not found, queue state in incStatsQueue!
                                zigbee2mqtt.0
                                	2023-02-18 14:53:17.463	debug	Device: 0x54ef4410006492a3 not found, queue state in incStatsQueue!
                                zigbee2mqtt.0
                                zigbee2mqtt.0
                                	2023-02-18 14:53:17.462	debug	Device: 0x54ef4410006492a3 not found, queue state in incStatsQueue!
                                zigbee2mqtt.0
                                zigbee2mqtt.0
                                	2023-02-18 14:53:17.461	debug	Device: 0x54ef4410006492a3 not found, queue state in incStatsQueue!
                                zigbee2mqtt.0
                                zigbee2mqtt.0
                                	2023-02-18 14:53:17.460	debug	Device: 0x54ef4410006492a3 not found, queue state in incStatsQueue!
                                zigbee2mqtt.0
                                zigbee2mqtt.0
                                	2023-02-18 14:53:17.459	debug	Device: 0x54ef4410006492a3 not found, queue state in incStatsQueue!
                                zigbee2mqtt.0
                                	2023-02-18 14:53:17.445	info	Starting interview of '0x54ef4410006492a3'
                                zigbee2mqtt.0
                                	2023-02-18 14:53:17.433	info	MQTT publish: topic 'zigbee2mqtt/bridge/event', payload '{"data":{"friendly_name":"0x54ef4410006492a3","ieee_address":"0x54ef4410006492a3"},"type":"device_joined"}'
                                zigbee2mqtt.0
                                	2023-02-18 14:53:17.428	debug	TypeError: Cannot set properties of undefined (setting 'prop')
                                  toralt @IdleBit last edited by
                                  @idlebit ich habs jetzt nicht ganz kapiert, habe aber auch 4 x FP1 im Einsatz. Ich habe nun auch mit der Katze via Github nochmal den Treiber installiert.
                                  Habe eben den 1.30.1 Container gestartet -> Läuft!
                                  Besten Dank!
                                  • IdleBit
                                    @aragon Konnte den Fehler eingrenzen...
                                    Dieser neuen State mach mir Probleme weil er eine Objekt in einen Objekt ist und das gab es meines Wissens vorher nicht. da muss ich nun mal grübeln wie ich das umsetzte.
                                                    "access": 2,
                                                    "description": "Definition of a new region to be added (or replace existing one). Creating or modifying a region requires you to define which zones of a 7x4 detection grid should be active for that zone. Regions can overlap, meaning that a zone can be defined in more than one region (eg. \"zone x = 1 & y = 1\" can be added to region 1 & 2). \"Zone x = 1 & y = 1\" is the nearest zone on the right (from sensor's perspective, along the detection path).",
                                                    "features": [
                                                            "access": 2,
                                                            "name": "region_id",
                                                            "property": "region_id",
                                                            "type": "numeric",
                                                            "value_max": 10,
                                                            "value_min": 1
                                                            "access": 2,
                                                            "item_type": {
        "features": [
        "access": 2,
        "name": "x",
        "property": "x",
        "type": "numeric",
        "value_max": 4,
        "value_min": 1
        "access": 2,
        "name": "y",
        "property": "y",
        "type": "numeric",
        "value_max": 7,
        "value_min": 1
        "name": "zone_position",
        "type": "composite"
                                                            "name": "zones",
                                                            "property": "zones",
                                                            "type": "list"
                                                    "name": "region_upsert",
                                                    "property": "region_upsert",
                                                    "type": "composite"
                                    A T 2 Replies Last reply Reply Quote 0
                                      @idlebit Okay vielen Dank für die Info und deine Mühe
                                        @idlebit ok, meine Aqaras FP1 sind jetzt alle 4 weg. Ansonsten scheint alles zu gehen.
                                        • IdleBit
                                          IdleBit last edited by IdleBit
                                          Testet jetzt mal von git, jetzt sollten die wieder angelegt werden allerdings erstmal ohne diesen neuen State.
                                          T A 2 Replies Last reply Reply Quote 1
                                            @idlebit Bester Mann! Sind wieder da!
                                            Vielen Dank!
                                            zigbee zigbee 3.0 zigbee2mqtt
                                            52
                                            526
                                            105664
