    5. [gelöst] Aufzählung gleicher Werte aus Datenpunkt
    • DJMarc75
      DJMarc75 @mickym last edited by
      @mickym bin grad am Testen 👍
      • mickym
        mickym Most Active @DJMarc75 last edited by mickym
        @djmarc75 sagte in Aufzählung gleicher Werte aus Datenpunkt:
        So und damit die Hässlichkeit des Puzzlen ganz zu Tage tritt hier noch die Ergänzung, wie man das ganze dann Auswerten kann. 😉
         <variables>
           <variable id="Q-{K{g^u8=SJ~bbJx1L2">neu</variable>
           <variable id="?+jUzr1AE!BT%ndErB?h">String</variable>
           <variable id="r2|O7xSSn}R]WP0Guw3#">Array</variable>
           <variable id="$-_m{u5(Dz83eo?3;{%[">Objekt</variable>
           <variable id="J?Di1B/ibZyz:%[nd_$1">Suche</variable>
         </variables>
         <block type="variables_set" id="2`xXRHf8dv/I7RRVQ9uP" x="-462" y="-187">
           <field name="VAR" id="Q-{K{g^u8=SJ~bbJx1L2">neu</field>
             <block type="text" id=":}kd79(jelVZP+`h)Q-G">
               <field name="TEXT">S.O.S</field>
             <block type="variables_set" id="//8bilRq!Q*Oo;YNFP0i">
               <field name="VAR" id="?+jUzr1AE!BT%ndErB?h">String</field>
                 <block type="text" id="b;/knyEwB)g{AZ|(e4U;">
                   <field name="TEXT">a,b,b,a,c,d,a,b,c</field>
                 <block type="variables_set" id="jgNS,;m/}/6kEs:32$23">
                   <field name="VAR" id="r2|O7xSSn}R]WP0Guw3#">Array</field>
                     <block type="lists_split" id="4VgevC}Aug,7,$``$e2~">
                       <mutation mode="SPLIT"></mutation>
                       <field name="MODE">SPLIT</field>
                       <value name="INPUT">
                         <block type="variables_get" id="3OkVXfnD1V1{15oC}j0#">
                       <value name="DELIM">
                         <shadow type="text" id="`^2^nlc|*0tZnVb/]MU0">
                           <field name="TEXT">,</field>
                     <block type="lists_setIndex" id="^1a;jzhbYsZ3.(=%^3:o">
                       <mutation at="false"></mutation>
                       <field name="WHERE">LAST</field>
                       <value name="LIST">
                         <block type="variables_get" id="Yc!NOY.mpz;*MQ4a.3cc">
                       <value name="TO">
                         <block type="variables_get" id="JN(3pS60Y)^Y=(.]j~4B">
                         <block type="debug" id="7Qj!rB9T*1u^?q*%grBj">
                           <value name="TEXT">
                             <shadow type="text" id="X9Y@-Dl7gm/@@A1LA|rJ">
                             <block type="variables_get" id="(swR*aLu~G@PD}zgOnL+">
                             <block type="variables_set" id="a75e#*Xc#m)nG`veslBd">
                               <field name="VAR" id="$-_m{u5(Dz83eo?3;{%[">Objekt</field>
                                 <block type="convert_jsonata" id="|P_BHOAk`P/_AfD`5I`Y">
                                   <value name="EXPRESSION">
                                     <shadow type="text" id=":Vas?]P#E6aU7]6b,~_q">
                                       <field name="TEXT">$distinct($).{$ : $map($$,function($v){$[$=$v]}) ~&gt; $count()}</field>
                                   <value name="TARGET">
                                     <block type="variables_get" id="5t:`o,RyQ=/bO+x?(-kv">
                                 <block type="debug" id="WJhIun5xunahKl@GICu}">
                                   <value name="TEXT">
                                     <shadow type="text" id="YQ7^n5qnxbu(/f6Uffd^">
                                     <block type="variables_get" id="-,0VHv#EdBGI4Upg~~ZA">
                                     <block type="variables_set" id="Hg9/:p^,/%Kf2tC;y-]W">
                                       <field name="VAR" id="J?Di1B/ibZyz:%[nd_$1">Suche</field>
                                         <block type="text" id="m;o(c)D=jz_JWVJv@X8E">
                                           <field name="TEXT">a</field>
                                         <block type="debug" id="O9J+UurMn7PA^TKo,BHw">
                                           <value name="TEXT">
                                             <shadow type="text" id="p.m1Jo/[,,D8:FMicn0U">
                                             <block type="text_join" id="q,:sJ5DPG[Unp42nmwf4">
                                               <mutation items="5"></mutation>
                                               <value name="ADD0">
                                                 <block type="text" id=":+E?yRv@7u8_xlN?;!|Y">
                                                   <field name="TEXT">Lied </field>
                                               <value name="ADD1">
                                                 <block type="variables_get" id="iiTxfl.#MUB;EfaFO/q;">
                                               <value name="ADD2">
                                                 <block type="text" id="JcTfv$r?$F7=m2$QWNgG">
                                                   <field name="TEXT"> wurde </field>
                                               <value name="ADD3">
                                                 <block type="convert_jsonata" id="^cI{f1Cedv)iL5xFEsa@">
                                                     <shadow type="text" id="XolzYVS:6f[}CY%{=CtN">
                                                       <field name="TEXT">*</field>
                                                     <block type="text_join" id="jZb*`=0yOdkQuGQPKyJ=">
                                                       <value name="ADD0">
                                                         <block type="text" id="kZDkEfIR!ngV#w|Mx=/J">
                                                           <field name="TEXT">$.'</field>
                                                       <value name="ADD1">
                                                         <block type="variables_get" id="e;xWF[am$/jUvuQxCb:[">
                                                       <value name="ADD2">
                                                         <block type="text" id="=l{vI?{uIxzWwOzn0Rll">
                                                           <field name="TEXT">'</field>
                                                     <block type="variables_get" id="KtR^h,d+F=uC4,3.tEZz">
                                               <value name="ADD4">
                                                 <block type="text" id="z8nN;k_ep!x_9cd^+BB!">
                                                   <field name="TEXT"> mal gespielt.</field>
        Für Leute, die solche Dinge mit einem anderen Logikmaschine umsetzen wollen:
               "id": "1b8a9b7ff23e2b72",
               "type": "comment",
               "z": "29617fbe487e9c69",
               "name": "Elemente in einem Array zählen und als Objekt ausgeben",
               "info": "",
               "x": 270,
               "y": 1720,
               "wires": []
               "id": "db03a7ae6baec159",
               "type": "inject",
               "name": "Array mit Liedern",
               "props": [
                       "p": "payload"
               "repeat": "",
               "crontab": "",
               "once": false,
               "onceDelay": 0.1,
               "topic": "",
               "payload": "[\"Schöne Maid, hast Du heut für mich Zeit\",\"Jump\",\"Jump\",\"Blauer Enzian\",\"Dancing Queen\",\"Yellow Submarine\",\"Blauer Enzian\",\"Jump\",\"Dancing Queen\",\"S.O.S\",\"Schöne Maid, hast Du heut für mich Zeit\"]",
               "payloadType": "json",
               "x": 180,
               "y": 1800,
               "wires": [
                       "eee0fd1bbc1c7591"
               "id": "eee0fd1bbc1c7591",
               "type": "change",
               "name": "",
               "rules": [
                       "t": "set",
                       "p": "payload",
                       "pt": "msg",
                       "to": "$distinct(payload).{$: $map($$.payload,function($v){$[$=$v]})~>$count()}",
                       "tot": "jsonata"
               "action": "",
               "property": "",
               "from": "",
               "to": "",
               "reg": false,
               "x": 390,
               "y": 1800,
               "wires": [
                       "db6b52e1b383fa3c",
                       "f9376b9bca6163b6"
               "info": "# Objekt mit Häufigkeit des Auftretens in Array\r\n\r\nmuss noch auf payload übertragen werden.\r\n\r\n`$distinct($).{$ : $map($$,function($v){$[$=$v]}) ~> $count()}`"
               "id": "db6b52e1b383fa3c",
               "type": "debug",
               "name": "Array-Analyse",
               "active": true,
               "tosidebar": true,
               "console": false,
               "tostatus": false,
               "complete": "payload",
               "targetType": "msg",
               "statusVal": "",
               "statusType": "auto",
               "x": 620,
               "y": 1800,
               "wires": []
               "id": "f9376b9bca6163b6",
               "type": "change",
               "name": "",
               "rules": [
                       "t": "set",
                       "p": "search",
                       "pt": "msg",
                       "to": "Schöne Maid, hast Du heut für mich Zeit",
                       "tot": "str"
               "action": "",
               "property": "",
               "from": "",
               "to": "",
               "reg": false,
               "x": 650,
               "y": 1860,
               "wires": [
                       "cda6bb4b435f80bb"
               "id": "cda6bb4b435f80bb",
               "type": "change",
               "name": "",
               "rules": [
                       "t": "set",
                       "p": "payload",
                       "pt": "msg",
                       "to": "payload.$sift(function($v,$k){$k = $$.search}).*",
                       "tot": "jsonata"
               "action": "",
               "property": "",
               "from": "",
               "to": "",
               "reg": false,
               "x": 870,
               "y": 1860,
               "wires": [
                       "251eea7ce5c8efe0"
               "id": "251eea7ce5c8efe0",
               "type": "debug",
               "name": "Suche Vorkommen von search ",
               "active": true,
               "tosidebar": true,
               "console": false,
               "tostatus": false,
               "statusVal": "",
               "x": 1130,
               "y": 1860,
               "wires": []
               "id": "4a0fb478973bae57",
               "type": "inject",
               "name": "Array mit Liedern und Ausgabe von search in einem",
               "props": [
                       "p": "payload"
                       "p": "search",
                       "v": "Dancing Queen",
                       "vt": "str"
               "repeat": "",
               "crontab": "",
               "once": false,
               "onceDelay": 0.1,
               "topic": "",
               "payload": "[\"Schöne Maid, hast Du heut für mich Zeit\",\"Jump\",\"Jump\",\"Blauer Enzian\",\"Dancing Queen\",\"Yellow Submarine\",\"Blauer Enzian\",\"Jump\",\"Dancing Queen\",\"S.O.S\",\"Schöne Maid, hast Du heut für mich Zeit\",\"Dancing Queen\",\"Dancing Queen\"]",
               "x": 290,
               "y": 1960,
               "wires": [
                       "48f9fec07b2dac6a"
               "id": "48f9fec07b2dac6a",
               "type": "change",
               "name": "",
               "rules": [
                       "t": "set",
                       "p": "payload",
                       "pt": "msg",
                       "to": "$distinct(payload).{$: $map($$.payload,function($v){$[$=$v]})~>$count()}.$sift(function($v,$k){$k = $$.search}).*",
                       "tot": "jsonata"
               "action": "",
               "property": "",
               "from": "",
               "to": "",
               "reg": false,
               "x": 610,
               "y": 1960,
               "wires": [
                       "969a1f62b4b01026"
               "id": "969a1f62b4b01026",
               "type": "debug",
               "name": "Vorkommen von search in Array",
               "active": true,
               "tosidebar": true,
               "console": false,
               "tostatus": false,
               "statusVal": "",
               "x": 850,
               "y": 1960,
               "wires": []
        Auch JS Programmierer können JSONATA nutzen, da das im Adapter enthalten ist:
        var titel = [
            "Jump",
            "Jump",
            "Blauer Enzian",
            "Dancing Queen",
            "Yellow Submarine",
            "Blauer Enzian",
            "Jump",
            "Dancing Queen",
            "S.O.S",
        var analyse = jsonataExpression(titel,'$distinct($).{"titel": $, "count" : $map($$,function($v){$[$=$v]}) ~> $count()}');
        console.log(analyse);
        var suche = "Dancing Queen";
        var ergebnis =  jsonataExpression(analyse,'$[titel="'+ suche +'"].count');
        console.log("Der Titel "+ suche + " ergab "+ ergebnis + " Treffer.");
        DJMarc75 2 Replies Last reply Reply Quote 0
        • DJMarc75
          @mickym sagte in Aufzählung gleicher Werte aus Datenpunkt:
          Ich lass das jetzt mal ne Weile laufen und mit Musiktitel befüllen um etwaige Sonderzeichenprobleme gänzlich auszuschliessen 🤓
          • DJMarc75
            DJMarc75 @mickym last edited by DJMarc75
            @mickym ob ich nochmals nachfragen darf wie ich nun aus
            [{"a":3},{"b":3} ...
            ein
            [{"titel":"a","count":"3"},{"titel":"b","count":"3"} ...
            machen kann um das ganze dann schön in VIS darzustellen ?
            Ich bin da grad am verzweifeln 😷
            • mickym
              Ich machs mal nur quick and dirty - da die Objekte ja klar definiert sind.
              $.{"titel" : $keys(),"count": *}
               <variables>
               </variables>
                             <value name="LIST">
                             <value name="TO">
                                 <value name="TEXT">
                                         <value name="TEXT">
                                                 <value name="TEXT">
                                                     <value name="ADD0">
                                                     <value name="ADD1">
                                                     <value name="ADD2">
                                                     <value name="ADD3">
                                                             <value name="ADD0">
                                                             <value name="ADD1">
                                                             <value name="ADD2">
                                                     <value name="ADD4">
                                                   <block type="debug" id=":H{dp!-z:u5+|n#a8pok">
                                                     <value name="TEXT">
                                                       <shadow type="text" id="^Hd{-C)},fMch1=3eSN{">
                                                       <block type="variables_get" id="C^a!~n}WdvxU,qQ0Z+)T">
                                                       <block type="variables_set" id="-RRu#I@,}vQ,oH?)1byd">
                                                           <block type="convert_jsonata" id="Sm`R0amu|*s{$bCu-Q?q">
                                                               <shadow type="text" id="Fc]hsd]=^{M./kva.10B">
        <field name="TEXT">$.{"titel" : $keys(),"count": *}</field>
                                                               <block type="variables_get" id="i]m~P99c%8l]P]S?H-ia">
                                                           <block type="debug" id="$=K22lJ-lR2%5)A9G|n=">
                                                             <value name="TEXT">
                                                               <shadow type="text" id="-l`,3:x:].IKRb}63*48">
                                                               <block type="variables_get" id="jOvt)?3e4F{up+G+5_s/">
              DJMarc75 1 Reply Last reply Reply Quote 1
              • DJMarc75
                Du bisch der Wahnsinn 👍 👍 👍 👍
                • mickym
                  So wäre es eigentlich sauber:
                  $.{"titel" : $keys()[0],"count": $lookup($, $keys()[0])}
                  damit die Zuordnung eindeutig ist, wenn Dein Objekt mehrere Eigenschaften hätte-
                  • mickym
                    ein
                    Weißt Du das Problem ist - dass Du gefragt hast, wie man das umwandelt. Wenn Du sowas gleich gesagt hättest, dann hätte man die Objekte gleich so aufbauen können.
                    Ich ändere mal das Blockly noch ab - wie es sich dann gehört.
                    Also dann hätte man auch direkt im Blockly den 1. JSONATA Ausdruck entsprechend erstellt:
                    • DJMarc75
                      Asche auf mein Haupt. Aber mir ist ja nicht bewusst gewesen wie ich überhaupt eine Aufzählung hätte umsetzen können.
                      Umgesetzt und läuft wie ein Uhrwerk 💋 😂
                      • mickym
                        @djmarc75 Ich hab neben Deinen Puzzleteilchen hier noch Lösungen mit alternativen Logikmaschinen eingestellt, die auch JSONATA nutzen können.
                        Vielleicht lässt sich ja der eine oder andere doch noch von der Leistungsfähigkeit dieser Bibliothek überzeugen insbesondere, da per Default die Bibliothek im JS Adapter integriert ist. Die NodeRed Lösung passt natürlich nicht, aber ganz verkneifen konnte ich es mir nicht, da ich sowas dann auch in meiner eigenen Bibliothek sammle.
                        1234
