    4. Fehler bei Installation i2c Adapter
      Thomas Braun Most Active @Chris_B last edited by
      @chris_b
      cd /opt/iobroker
      npm ls
      npm ls object-assign
        Chris_B @Thomas Braun last edited by
        @thomas-braun So sieht es aus:
        iobroker.inst@3.0.0 /opt/iobroker
        ├── @types/caseless@0.12.2 extraneous
        ├── @types/request@2.48.8 extraneous
        ├── @types/tough-cookie@4.0.2 extraneous
        ├── coffeescript@1.12.7 extraneous
        ├── iobroker.admin@6.3.5
        ├── iobroker.backitup@2.5.12
        ├── iobroker.cloud@4.3.0
        ├── iobroker.denon@1.13.4
        ├── iobroker.discovery@3.1.0
        ├── iobroker.email@1.1.4
        ├── iobroker.flot@1.11.0
        ├── iobroker.heos@1.10.0
        ├── iobroker.history@2.2.4
        ├── iobroker.homekit-controller@0.5.1
        ├── iobroker.hue@3.7.1
        ├── iobroker.info@1.9.19
        ├── iobroker.javascript@6.1.4
        ├── iobroker.js-controller@4.0.24
        ├── iobroker.netatmo@2.0.5
        ├── iobroker.ping@1.5.3
        ├── iobroker.rpi2@1.3.2
        ├── iobroker.simple-api@2.7.2
        ├── iobroker.socketio@4.2.0
        ├── iobroker.vis-hqwidgets@1.3.0
        ├── iobroker.vis@1.4.15
        ├── iobroker.web@4.3.0
        ├── iobroker.yahka@0.13.1
        ├── jsonata@1.8.6 extraneous
        ├── node-inspect@2.0.0 extraneous
        ├── picocolors@1.0.0 extraneous
        ├── suncalc2@1.8.1 extraneous
        ├── typescript@4.8.2 extraneous
        ├── virtual-tsc@0.6.2 extraneous
        └── wake_on_lan@1.0.0 extraneous
        └─┬ iobroker.homekit-controller@0.5.1
          └─┬ hap-controller@0.8.1
            └─┬ @abandonware/noble@1.9.2-15
              └─┬ @abandonware/bluetooth-hci-socket@0.5.3-8
                └─┬ @mapbox/node-pre-gyp@1.0.9
                  └─┬ npmlog@5.0.1
                    └─┬ gauge@3.0.2
                      └── object-assign@4.1.1
          Thomas Braun Most Active @Chris_B last edited by Thomas Braun
          @chris_b
          cd /opt/iobroker
          npm cache clear --force
          iobroker add i2c --debug
          Bitte immer vollständig aus der Konsole kopieren, inkl. log in prompt usw.
          C 2 Replies Last reply Reply Quote 0
            @thomas-braun Das löschen des Caches scheint auch nichts zu bringen.
            pi@raspberrypi4-iob:/opt/iobroker $ npm cache clear --force
            npm WARN using --force Recommended protections disabled.
            pi@raspberrypi4-iob:/opt/iobroker $ iobroker add i2c auto --debug
            NPM version: 8.19.3
            Installing iobroker.i2c@1.2.1... (System call)
            npm ERR! code 1
            npm ERR! path /opt/iobroker/node_modules/i2c-bus
            npm ERR! command failed
            npm ERR! command sh -c -- node-gyp rebuild
            npm ERR! node:internal/modules/cjs/loader:1024
            npm ERR!   throw err;
            npm ERR!   ^
            npm ERR!
            npm ERR! Error: Cannot find module 'object-assign'
            npm ERR! Require stack:
            npm ERR! - /usr/lib/node_modules/npm/node_modules/node-gyp/node_modules/gauge/render-template.js
            npm ERR! - /usr/lib/node_modules/npm/node_modules/node-gyp/node_modules/gauge/plumbing.js
            npm ERR! - /usr/lib/node_modules/npm/node_modules/node-gyp/node_modules/gauge/index.js
            npm ERR! - /usr/lib/node_modules/npm/node_modules/node-gyp/node_modules/npmlog/log.js
            npm ERR! - /usr/lib/node_modules/npm/node_modules/node-gyp/lib/node-gyp.js
            npm ERR! - /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js
            npm ERR!     at Function.Module._resolveFilename (node:internal/modules/cjs/loader:1021:15)
            npm ERR!     at Function.Module._load (node:internal/modules/cjs/loader:866:27)
            npm ERR!     at Module.require (node:internal/modules/cjs/loader:1093:19)
            npm ERR!     at require (node:internal/modules/cjs/helpers:108:18)
            npm ERR!     at Object.<anonymous> (/usr/lib/node_modules/npm/node_modules/node-gyp/node_modules/gauge/r    ender-template.js:4:20)
            npm ERR!     at Module._compile (node:internal/modules/cjs/loader:1191:14)
            npm ERR!     at Object.Module._extensions..js (node:internal/modules/cjs/loader:1245:10)
            npm ERR!     at Module.load (node:internal/modules/cjs/loader:1069:32)
            npm ERR!     at Function.Module._load (node:internal/modules/cjs/loader:904:12)
            npm ERR!     at Module.require (node:internal/modules/cjs/loader:1093:19) {
            npm ERR!   code: 'MODULE_NOT_FOUND',
            npm ERR!   requireStack: [
            npm ERR!     '/usr/lib/node_modules/npm/node_modules/node-gyp/node_modules/gauge/render-template.js',
            npm ERR!     '/usr/lib/node_modules/npm/node_modules/node-gyp/node_modules/gauge/plumbing.js',
            npm ERR!     '/usr/lib/node_modules/npm/node_modules/node-gyp/node_modules/gauge/index.js',
            npm ERR!     '/usr/lib/node_modules/npm/node_modules/node-gyp/node_modules/npmlog/log.js',
            npm ERR!     '/usr/lib/node_modules/npm/node_modules/node-gyp/lib/node-gyp.js',
            npm ERR!     '/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js'
            npm ERR!   ]
            npm ERR! }
            npm ERR!     /home/iobroker/.npm/_logs/2023-02-18T15_54_49_210Z-debug-0.log
            host.raspberrypi4-iob Cannot install iobroker.i2c@1.2.1: 1
              @thomas-braun Bemerkung dazu: Ich habe davor iobroker nicht gestoppt. Ist das korrekt?
                @chris_b
                apt policy npm node-gyp nodejs
                  @chris_b sagte in Fehler bei Installation i2c Adapter:
                  Das ist wurscht.
                    npm:
                      Installiert:           (keine)
                      Installationskandidat: 7.5.2+ds-2
                      Versionstabelle:
                         7.5.2+ds-2 500
                            500 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Packages
                    node-gyp:
                      Installationskandidat: 7.1.2-4
                      Versionstabelle:
                         7.1.2-4 500
                    nodejs:
                      Installiert:           16.19.1-deb-1nodesource1
                      Installationskandidat: 16.19.1-deb-1nodesource1
                      Versionstabelle:
                     *** 16.19.1-deb-1nodesource1 500
                            500 https://deb.nodesource.com/node_16.x bullseye/main armhf Packages
                            100 /var/lib/dpkg/status
                         12.22.12~dfsg-1~deb11u3 500
                      @chris_b
                        @thomas-braun Sorry, eigentlich war das bis auf die Kommandozeile und die Zeile danach vollständig. Hier nochmals mit den zusätzlichen 2 Zeilen:
                        pi@raspberrypi4-iob:~ $ apt policy npm node-gyp nodejs
                        npm:
                          Versionstabelle:
                             7.5.2+ds-2 500
                        node-gyp:
                          Versionstabelle:
                             7.1.2-4 500
                        nodejs:
                          Versionstabelle:
                          @chris_b
                          iob stop
                          sudo apt install --reinstall nodejs
                          iob start
                            Und die fehlten halt. Anhand der Zeilen kann man viel besser sehen wo du da wie unterwegs bist und ob das vollständig ist.
                              pi@raspberrypi4-iob:~ $ iob stop
                              pi@raspberrypi4-iob:~ $ sudo apt install --reinstall nodejs
                              Paketlisten werden gelesen… Fertig
                              Abhängigkeitsbaum wird aufgebaut… Fertig
                              Statusinformationen werden eingelesen… Fertig
                              Die folgenden Pakete wurden automatisch installiert und werden nicht mehr benötigt:
                                bsdmainutils g++-8 geoip-database libbind9-161 libcroco3 libdns1104 libdns1110 libevent-2.1-6 libfl2
                                libgdk-pixbuf2.0-0 libgeoip1 libicu63 libisc1100 libisc1105 libisccc161 libisccfg163 libisl19
                                libjim0.77 libjsoncpp1 liblwres161 libmpdec2 libncursesw5 libperl5.28 libpython2-dev
                                libpython2-stdlib libpython2.7 libpython2.7-dev libpython2.7-minimal libpython2.7-stdlib
                                libpython3.7 libpython3.7-minimal libpython3.7-stdlib libstdc++-8-dev perl-modules-5.28 python2
                                python2-dev python2-minimal python2.7 python2.7-dev python2.7-minimal python3.7-minimal raspinfo
                                rpi.gpio-common usb.ids
                              Verwenden Sie »sudo apt autoremove«, um sie zu entfernen.
                              0 aktualisiert, 0 neu installiert, 1 erneut installiert, 0 zu entfernen und 0 nicht aktualisiert.
                              Es müssen 24.2 MB an Archiven heruntergeladen werden.
                              Nach dieser Operation werden 0 B Plattenplatz zusätzlich benutzt.
                              Holen:1 https://deb.nodesource.com/node_16.x bullseye/main armhf nodejs armhf 16.19.1-deb-1nodesource1 [24.2 MB]
                              Es wurden 24.2 MB in 2 s geholt (15.2 MB/s).
                              (Lese Datenbank ... 57038 Dateien und Verzeichnisse sind derzeit installiert.)
                              Vorbereitung zum Entpacken von .../nodejs_16.19.1-deb-1nodesource1_armhf.deb ...
                              Entpacken von nodejs (16.19.1-deb-1nodesource1) über (16.19.1-deb-1nodesource1) ...
                              nodejs (16.19.1-deb-1nodesource1) wird eingerichtet ...
                              Trigger für man-db (2.9.4-2) werden verarbeitet ...
                              pi@raspberrypi4-iob:~ $ iob start
                                @thomas-braun Und jetzt noch einmal über die Kommandozeile den i2c Adapter installieren versuchen?
                                  @chris_b
                                  Versuch nochmal
                                    @thomas-braun Irgend etwas ist mit dem Adapter nicht OK. Ich glaube nicht, dass es an meinem System liegt.
                                    pi@raspberrypi4-iob:~ $ iobroker add i2c --debug
                                    NPM version: 8.19.3
                                    npm ERR! code 1
                                    npm ERR!   throw err;
                                    npm ERR!   ^
                                    npm ERR!
                                    npm ERR!     at Object.<anonymous> (/usr/lib/node_modules/npm/node_modules/node-gyp/node_modules/gauge/render-template.js:4:20)
                                    npm ERR!   ]
                                    npm ERR! }
                                    npm ERR!     /home/iobroker/.npm/_logs/2023-02-18T16_18_11_324Z-debug-0.log
                                      Nö, der ist prima. Hab ich eben hier ganz sauber installiert:
                                      echad@chet:~ $ iobroker add i2c --debug
                                      NPM version: 9.4.0
                                      added 2 packages in 19s
                                      99 packages are looking for funding
                                        run `npm fund` for details
                                      host.chet install adapter i2c
                                      upload [4] i2c.admin /opt/iobroker/node_modules/iobroker.i2c/admin/build/index.css build/index.css text/css
                                      upload [3] i2c.admin /opt/iobroker/node_modules/iobroker.i2c/admin/build/index.js build/index.js application/javascript
                                      upload [2] i2c.admin /opt/iobroker/node_modules/iobroker.i2c/admin/i2c.png i2c.png image/png
                                      upload [1] i2c.admin /opt/iobroker/node_modules/iobroker.i2c/admin/index_m.html index_m.html text/html
                                      upload [0] i2c.admin /opt/iobroker/node_modules/iobroker.i2c/admin/style.css style.css text/css
                                      host.chet object system.adapter.i2c created/updated
                                      host.chet create instance i2c
                                      host.chet object system.adapter.i2c.0.alive created
                                      host.chet object system.adapter.i2c.0.connected created
                                      host.chet object system.adapter.i2c.0.compactMode created
                                      host.chet object system.adapter.i2c.0.cpu created
                                      host.chet object system.adapter.i2c.0.cputime created
                                      host.chet object system.adapter.i2c.0.memHeapUsed created
                                      host.chet object system.adapter.i2c.0.memHeapTotal created
                                      host.chet object system.adapter.i2c.0.memRss created
                                      host.chet object system.adapter.i2c.0.uptime created
                                      host.chet object system.adapter.i2c.0.inputCount created
                                      host.chet object system.adapter.i2c.0.outputCount created
                                      host.chet object system.adapter.i2c.0.eventLoopLag created
                                      host.chet object system.adapter.i2c.0.sigKill created
                                      host.chet object system.adapter.i2c.0.logLevel created
                                      host.chet object system.adapter.i2c.0 created
                                      echad@chet:~ $
                                        Was steht denn da so drin?
                                          @thomas-braun Das steht drin:
                                          pi@raspberrypi4-iob:/home/iobroker/.npm/_logs $ nano 2023-02-18T16_18_11_324Z-debug-0.log
                                            GNU nano 5.4                      2023-02-18T16_18_11_324Z-debug-0.log
                                          0 verbose cli /usr/bin/node /usr/bin/npm
                                          1 info using npm@8.19.3
                                          2 info using node@v16.19.1
                                          3 timing npm:load:whichnode Completed in 0ms
                                          4 timing config:load:defaults Completed in 5ms
                                          5 timing config:load:file:/usr/lib/node_modules/npm/npmrc Completed in 4ms
                                          6 timing config:load:builtin Completed in 4ms
                                          7 timing config:load:cli Completed in 6ms
                                          8 timing config:load:env Completed in 1ms
                                          9 timing config:load:file:/opt/iobroker/.npmrc Completed in 2ms
                                          10 timing config:load:project Completed in 5ms
                                          11 timing config:load:file:/home/iobroker/.npmrc Completed in 1ms
                                          12 timing config:load:user Completed in 1ms
                                          13 timing config:load:file:/usr/etc/npmrc Completed in 0ms
                                          14 timing config:load:global Completed in 0ms
                                          15 timing config:load:validate Completed in 1ms
                                          16 timing config:load:credentials Completed in 3ms
                                          17 timing config:load:setEnvs Completed in 3ms
                                          18 timing config:load Completed in 31ms
                                          19 timing npm:load:configload Completed in 32ms
                                          20 timing npm:load:mkdirpcache Completed in 3ms
                                          21 timing npm:load:mkdirplogs Completed in 0ms
                                          22 verbose title npm install iobroker.i2c@1.2.1
                                          23 verbose argv "install" "--save-exact" "iobroker.i2c@1.2.1"
                                          24 timing npm:load:setTitle Completed in 3ms
                                          25 timing config:load:flatten Completed in 9ms
                                          26 timing npm:load:display Completed in 11ms
                                          27 verbose logfile logs-max:10 dir:/home/iobroker/.npm/_logs
                                          28 verbose logfile /home/iobroker/.npm/_logs/2023-02-18T16_18_11_324Z-debug-0.log
                                            @chris_b
                                            Fällt mir nix gescheites zu ein.
                                            3391
