    4. Test Adapter onvif camera v1.x.x
    • O
      oFbEQnpoLKKl6mbY5e13 @tombox last edited by
      @tombox
      2023-02-18 20:25:04.353  - info: host.iobroker iobroker url https://github.com/iobroker-community-adapters/ioBroker.onvif --host iobroker --debug
      2023-02-18 20:25:08.434  - info: host.iobroker iobroker install iobroker-community-adapters/ioBroker.onvif#740f0bc19978844bb1a20266ddfec06dd590bce7
      2023-02-18 20:25:09.652  - info: host.iobroker iobroker NPM version: 8.19.2
      2023-02-18 20:25:09.653  - info: host.iobroker iobroker Installing iobroker-community-adapters/ioBroker.onvif#740f0bc19978844bb1a20266ddfec06dd590bce7... (System call)
      2023-02-18 20:25:27.221  - info: host.iobroker iobroker npm WARN skipping integrity check for git dependency ssh://git@github.com/iobroker-community-adapters/ioBroker.onvif.git
      2023-02-18 20:25:30.073  - info: host.iobroker iobroker
      2023-02-18 20:25:30.078  - info: host.iobroker iobroker changed 1 package in 19s151 packages are looking for funding  run `npm fund` for details
      2023-02-18 20:25:30.205  - info: host.iobroker iobroker upload [1] onvif.admin /opt/iobroker/node_modules/iobroker.onvif/admin/jsonConfig.json jsonConfig.json application/json
      2023-02-18 20:25:30.598  - info: host.iobroker iobroker upload [0] onvif.admin /opt/iobroker/node_modules/iobroker.onvif/admin/onvif.png onvif.png image/png
      2023-02-18 20:25:30.649  - info: host.iobroker iobroker Update "system.adapter.onvif.0"
      2023-02-18 20:25:30.669  - info: host.iobroker stopInstance system.adapter.onvif.0 (force=false, process=true)
      2023-02-18 20:25:30.676  - info: host.iobroker stopInstance system.adapter.onvif.0 send kill signal
      2023-02-18 20:25:30.677  - info: onvif.0 (31474) Got terminate signal TERMINATE_YOURSELF
      2023-02-18 20:25:30.684  - info: onvif.0 (31474) terminating
      2023-02-18 20:25:30.686  - info: onvif.0 (31474) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2023-02-18 20:25:31.430  - info: host.iobroker instance system.adapter.onvif.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2023-02-18 20:25:31.697  - info: host.iobroker iobroker exit 0
      2023-02-18 20:25:33.901  - info: host.iobroker instance system.adapter.onvif.0 started with pid 31986
      2023-02-18 20:25:36.433  - info: onvif.0 (31986) Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
      2023-02-18 20:25:36.570  - info: onvif.0 (31986) starting. Version 1.0.0 (non-npm: iobroker-community-adapters/ioBroker.onvif#740f0bc19978844bb1a20266ddfec06dd590bce7) in /opt/iobroker/node_modules/iobroker.onvif, node: v16.18.1, js-controller: 4.0.24
      2023-02-18 20:25:36.650  - info: onvif.0 (31986) Found Adapter Device: onvif.0.192_168_0_157_8090 HighInfinity S53.0 192.168.0.157:8090
      2023-02-18 20:25:36.944  - info: onvif.0 (31986) Device successful initialized: 192.168.0.157:8090
      2023-02-18 20:25:36.958  - info: onvif.0 (31986) Found Adapter Device: onvif.0.192_168_0_134_8090 HighInfinity S53.0 192.168.0.134:8090
      2023-02-18 20:25:37.125  - info: onvif.0 (31986) Device successful initialized: 192.168.0.134:8090
      2023-02-18 20:25:37.129  - info: onvif.0 (31986) Start onvif discovery
      2023-02-18 20:25:37.220  - info: onvif.0 (31986) Discovery Reply from 192.168.0.157 (HiKam) (ipc) (http://192.168.0.157:8090/onvif/device_service) (urn:uuid:A030304)
      2023-02-18 20:25:37.221  - info: onvif.0 (31986) Skip device 192.168.0.157 because it is already configured via iobroker object. Delete the device under objects for reconfigure.
      2023-02-18 20:25:37.237  - info: onvif.0 (31986) Discovery Reply from 192.168.0.134 (HiKam) (ipc) (http://192.168.0.134:8090/onvif/device_service) (urn:uuid:A030693)
      2023-02-18 20:25:37.238  - info: onvif.0 (31986) Skip device 192.168.0.134 because it is already configured via iobroker object. Delete the device under objects for reconfigure.
      2023-02-18 20:25:37.686  - error: onvif.0 (31986) Discovery error Wrong SOAP message from 192.168.0.5:58473
      2023-02-18 20:25:37.687  - error: onvif.0 (31986) <?xml version="1.0" ?>
      <soap:Envelope   >
      	<soap:Header>
      		<wsa:Action>http://schemas.xmlsoap.org/ws/2005/04/discovery/ProbeMatches</wsa:Action>
      		<wsa:MessageID>urn:uuid:da131468-4ad0-4911-b2e4-764c9bcb389e</wsa:MessageID>
      		<wsa:RelatesTo>urn:uuid:324361d5-8467-c8b1-e6ab-0015f126a1ff</wsa:RelatesTo>
      		<wsa:To>http://schemas.xmlsoap.org/ws/2004/08/addressing/role/anonymous</wsa:To>
      		<wsd:AppSequence InstanceId="1375130137" MessageNumber="1"/>
      	</soap:Header>
      	<soap:Body>
      		<wsd:ProbeMatches/>
      	</soap:Body>
      </soap:Envelope>
      2023-02-18 20:25:37.885  - error: onvif.0 (31986) Discovery error Wrong SOAP message from 192.168.0.5:58473
      2023-02-18 20:25:37.886  - error: onvif.0 (31986) <?xml version="1.0" ?>
      <soap:Envelope   >
      	<soap:Header>
      	</soap:Header>
      	<soap:Body>
      		<wsd:ProbeMatches/>
      	</soap:Body>
      </soap:Envelope>
      2023-02-18 20:25:42.136  - error: onvif.0 (31986) Error during discovery: TypeError: Cannot read properties of undefined (reading 'endpointReference'),TypeError: Cannot read properties of undefined (reading 'endpointReference')
      2023-02-18 20:25:42.136  - info: onvif.0 (31986) Finished onvif discovery
      • O
        oFbEQnpoLKKl6mbY5e13 @tombox last edited by oFbEQnpoLKKl6mbY5e13
        @tombox
        Alle fehlenden Kameras hat der Adapter inzwischen gefunden, indem ich die Kameras mal neu gestartet habe.
        Eine manuelle Suche wurde bei mir nie ausgeführt. Zumindest habe ich nicht erkennen können, dass etwas passiert, wenn man die manuelle Suche ausführt.
        2023-02-18 20:43:07.096  - error: onvif.0 (847) 192.168.0.172:8090 Error getting livestream udp multi url: Error: ONVIF SOAP Fault: Specification of StreamType or Transport part in StreamSetup is not supported.
          tombox @oFbEQnpoLKKl6mbY5e13 last edited by
          @ofbeqnpolkkl6mby5e13
          Ist denn 192.168.0.5:58473 eine Kamera?
          Hast du die manuelle Suche auch in der korrekten IP range gemacht?
          • O
            @tombox
            Diese IP kannst du ignorieren. Das ist mein QNAP-NAS.
            Range hatte ich natürlich auf mein Netz angepasst.
              @ofbeqnpolkkl6mby5e13 Kannst ja nochmal im log check ob was bei manual search passiert
              • JB_Sullivan
                JB_Sullivan last edited by
                Ich habe auch mal versucht den Adapter zu installieren, was leider zu einem kleinen Desaster mutierte.
                Erst einmal sind und bleiben die beiden Such-Buttons in den Instanz Einstellungen ausgegraut.
                Alle manuellen Eintragungen sind Zielgenau (Name, PW, IP und Port) auf die Kameras ausgelegt. Man kann aber wie gesagt leider nicht suchen, weil die Buttons ohne Funktion sind.
                Im loggin wird jede Menge npm-rebuild durchgeführt, was aber letztendlich zu einem finalen Stop des Adapters führt.
                host.GLT(GLT)
                2023-02-18 21:00:00.129	info	instance system.adapter.dwd.0 started with pid 12580
                host.GLTGLT)
                2023-02-18 20:59:24.158	info	host.GLT(GLT) Rebuild for adapter system.adapter.onvif.0 not successful in 3 tries. Adapter will not be restarted again. Please execute "npm install --production" in adapter directory manually.
                host.GLTGLT)
                2023-02-18 20:59:24.158	error	host.GLT(GLT) instance system.adapter.onvif.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                host.GLTGLT)
                2023-02-18 20:59:24.158	error	host.GLT(GLT) Caught by controller[0]: }
                host.GLTGLT)
                2023-02-18 20:59:24.158	error	host.GLT(GLT) Caught by controller[0]: ]
                host.GLTGLT)
                2023-02-18 20:59:24.158	error	host.GLT(GLT) Caught by controller[0]: 'C:\\iobroker\\GLT\\node_modules\\iobroker.onvif\\main.js'
                host.GLTGLT)
                2023-02-18 20:59:24.158	error	host.GLT(GLT) Caught by controller[0]: 'C:\\iobroker\\GLT\\node_modules\\urllib\\src\\cjs\\index.js',
                host.GLTGLT)
                2023-02-18 20:59:24.157	error	host.GLT(GLT) Caught by controller[0]: 'C:\\iobroker\\GLT\\node_modules\\urllib\\src\\cjs\\HttpClient.js',
                host.GLTGLT)
                2023-02-18 20:59:24.157	error	host.GLT(GLT) Caught by controller[0]: 'C:\\iobroker\\GLT\\node_modules\\urllib\\src\\cjs\\diagnosticsChannel.js',
                host.GLTGLT)
                2023-02-18 20:59:24.157	error	host.GLT(GLT) Caught by controller[0]: requireStack: [
                host.GLTGLT)
                2023-02-18 20:59:24.157	error	host.GLT(GLT) Caught by controller[0]: code: 'MODULE_NOT_FOUND',
                host.GLTGLT)
                2023-02-18 20:59:24.157	error	host.GLT(GLT) Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:952:19) {
                host.GLTGLT)
                2023-02-18 20:59:24.157	error	host.GLT(GLT) Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:769:14)
                host.GLTGLT)
                2023-02-18 20:59:24.157	error	host.GLT(GLT) Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:928:32)
                host.GLTGLT)
                2023-02-18 20:59:24.157	error	host.GLT(GLT) Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1092:10)
                host.GLTGLT)
                2023-02-18 20:59:24.157	error	host.GLT(GLT) Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:1063:30)
                host.GLTGLT)
                2023-02-18 20:59:24.156	error	host.GLT(GLT) Caught by controller[0]: at Object.<anonymous> (C:\iobroker\GLT\node_modules\urllib\src\cjs\diagnosticsChannel.js:7:47)
                host.GLTGLT)
                2023-02-18 20:59:24.156	error	host.GLT(GLT) Caught by controller[0]: at require (internal/modules/cjs/helpers.js:88:18)
                host.GLTGLT)
                2023-02-18 20:59:24.156	error	host.GLT(GLT) Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:952:19)
                host.GLTGLT)
                2023-02-18 20:59:24.156	error	host.GLT(GLT) Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:725:27)
                host.GLTGLT)
                2023-02-18 20:59:24.156	error	host.GLT(GLT) Caught by controller[0]: at Function.Module._resolveFilename (internal/modules/cjs/loader.js:880:15)
                host.GLTGLT)
                2023-02-18 20:59:24.156	error	host.GLT(GLT) Caught by controller[0]: - C:\iobroker\GLT\node_modules\iobroker.onvif\main.js
                host.GLTGLT)
                2023-02-18 20:59:24.156	error	host.GLT(GLT) Caught by controller[0]: - C:\iobroker\GLT\node_modules\urllib\src\cjs\index.js
                host.GLTGLT)
                2023-02-18 20:59:24.156	error	host.GLT(GLT) Caught by controller[0]: - C:\iobroker\GLT\node_modules\urllib\src\cjs\HttpClient.js
                host.GLTGLT)
                2023-02-18 20:59:24.155	error	host.GLT(GLT) Caught by controller[0]: - C:\iobroker\GLT\node_modules\urllib\src\cjs\diagnosticsChannel.js
                host.GLTGLT)
                2023-02-18 20:59:24.155	error	host.GLT(GLT) Caught by controller[0]: Require stack:
                host.GLTGLT)
                2023-02-18 20:59:24.155	error	host.GLT(GLT) Caught by controller[0]: Error: Cannot find module 'diagnostics_channel'
                host.GLTGLT)
                host.GLTGLT)
                2023-02-18 20:59:24.155	error	host.GLT(GLT) Caught by controller[0]: ^
                host.GLTGLT)
                2023-02-18 20:59:24.155	error	host.GLT(GLT) Caught by controller[0]: throw err;
                host.GLTGLT)
                2023-02-18 20:59:24.154	error	host.GLT(GLT) Caught by controller[0]: internal/modules/cjs/loader.js:883
                host.GLTGLT)
                2023-02-18 20:58:37.282	info	host.GLT(GLT) instance system.adapter.onvif.0 started with pid 2200
                host.GLTGLT)
                2023-02-18 20:58:37.099	info	host.GLT(GLT) iobroker npm-rebuild: exit 1
                host.GLTGLT)
                2023-02-18 20:58:36.074	error	host.GLT(GLT) iobroker npm-rebuild: Rebuilding native modules failed
                host.GLTGLT)
                2023-02-18 20:58:22.583	info	host.GLT(GLT) iobroker npm-rebuild: C:\iobroker\GLT\node_modules\@serialport\bindings>if not defined npm_config_node_gyp (node "C:\iobroker\GLT\nodejs\node_modules\npm\node_modules\npm-lifecycle\node-gyp-bin\\..\..\node_modules\node-gyp\bin\node-gyp.js" rebuild ) else (node "C:\iobroker\GLT\nodejs\node_modules\npm\node_modules\node-gyp\bin\node-gyp.js" rebuild )
                host.GLTGLT)
                2023-02-18 20:58:22.582	info	host.GLT(GLT) iobroker npm-rebuild:
                host.GLTGLT)
                2023-02-18 20:58:21.779	info	host.GLT(GLT) iobroker npm-rebuild: > prebuild-install --tag-prefix @serialport/bindings@ || node-gyp rebuild
                host.GLTGLT)
                2023-02-18 20:58:21.778	info	host.GLT(GLT) iobroker npm-rebuild: > @serialport/bindings@8.0.8 install C:\iobroker\GLT\node_modules\@serialport\bindings
                host.GLTGLT)
                2023-02-18 20:58:21.567	info	host.GLT(GLT) iobroker npm-rebuild: Thank you for using serialport! If you rely on this package, please consider supporting our open collective: > https://opencollective.com/serialport/donate
                host.GLTGLT)
                2023-02-18 20:58:21.392	info	host.GLT(GLT) iobroker npm-rebuild: > serialport@8.0.8 postinstall C:\iobroker\GLT\node_modules\serialport > node thank-you.js
                host.GLTGLT)
                2023-02-18 20:58:15.320	info	host.GLT(GLT) iobroker npm-rebuild: > node-gyp-build
                host.GLTGLT)
                2023-02-18 20:58:15.320	info	host.GLT(GLT) iobroker npm-rebuild: > @serialport/bindings-cpp@10.8.0 install C:\iobroker\GLT\node_modules\@serialport\bindings-cpp
                host.GLTGLT)
                2023-02-18 20:58:15.087	info	host.GLT(GLT) iobroker npm-rebuild: [canvas] Success: "C:\iobroker\GLT\node_modules\iobroker.mihome-vacuum\node_modules\canvas\build\Release\canvas.node" is installed via remote
                host.GLTGLT)
                2023-02-18 20:58:10.717	info	host.GLT(GLT) iobroker npm-rebuild: > canvas@2.11.0 install C:\iobroker\GLT\node_modules\iobroker.mihome-vacuum\node_modules\canvas > node-pre-gyp install --fallback-to-build --update-binary
                host.GLTGLT)
                2023-02-18 20:58:10.716	info	host.GLT(GLT) iobroker npm-rebuild:
                host.GLTGLT)
                2023-02-18 20:58:08.975	info	host.GLT(GLT) iobroker npm-rebuild: > esbuild@0.11.23 postinstall C:\iobroker\GLT\node_modules\esbuild > node install.js
                host.GLTGLT)
                2023-02-18 20:58:08.974	info	host.GLT(GLT) iobroker npm-rebuild:
                host.GLTGLT)
                2023-02-18 20:58:06.612	info	host.GLT(GLT) iobroker npm-rebuild: The object "system.certificates" was updated successfully.
                host.GLTGLT)
                2023-02-18 20:58:06.603	info	host.GLT(GLT) iobroker npm-rebuild: Update certificate defaultPublic
                host.GLTGLT)
                2023-02-18 20:58:06.602	info	host.GLT(GLT) iobroker npm-rebuild: The object "system.certificates" was updated successfully.
                host.GLTGLT)
                2023-02-18 20:58:06.592	info	host.GLT(GLT) iobroker npm-rebuild: { "defaultPrivate": "-----BEGIN RSA PRIVATE KEY-----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\r\nE7lHwOPOf0jUAVKR660cA/PVz+EENwQE4f/xAxx3unKWwxFOBaoy2w==\r\n-----END RSA PRIVATE KEY-----\r\n", "defaultPublic": "-----BEGIN CERTIFICATE-----\r\nMIIDeTCCAmGgAwIBAgIJAsGVlTS426PSMA0GCSqGSIb3DQEBCwUAMD4xETAPBgNV\r\nBAMTCGlvYnJva2VyMRYwFAYDVQQKEw1pb0Jyb2tlciBHbWJIMREwDwYDVQQLEwhp\r\nb2Jyb2tlcjAeFw0yMzAyMTgxOTU4MDZaFw0yNDAyMTgxOTU4MDZaMD4xETAPBgNV\r\nBAMTCEdMVChHTFQpMRYwFAYDVQQKEw1pb0Jyb2tlciBHbWJIMREwDwYDVQQLEwhp\r\nb2Jyb2tlcjCCASIwDQYJKoZIhvcNAQEBBQADggEPADCCAQoCggEBAK9BqI2/wqqT\r\nU/R3AMp9avjzfVcuvmRCJvAE9gfo4G9MbSmfYW4EP4twbKc9pmOrnHJqmTaaTZlq\r\n7P33MuROfPjSi1VAFYIAu7wQ5+59WCIFAKnxRPgqj7siXboWzhQbtilv4DO0WaOU\r\nCTiUH9GNZi7WFjqKBnVjJ24obccBBkcodoiwH4zIOKY97HZ0AqEhH1KcrYZzixF0\r\na4du5yJD302dSUw9dipq94nCGRy9aeYQcOYtfUmukMLc8ufpr5Vlbv9Y4cl0oG4X\r\nJDLPfbbIc2Nj2oYovjykvTBFSpP7ID1qgVCq4o6zOu+VxtSu29jg4HZNCNGLZBls\r\nYySpm5XZqXMCAwEAAaN6MHgwDAYDVR0TAQH/BAIwADAPBgNVHQ8BAf8EBQMDB7+A\r\nMA4GA1UdEQQHMAWCA0dMVDAdBgNVHQ4EFgQUe0mhbYcdZbI+ZTR1vXK/VN0YsAIw\r\nHQYDVR0lBBYwFAYIKwYBBQUHAwEGCCsGAQUFBwMCMAkGA1UdIwQCMAAwDQYJKoZI\r\nhvcNAQELBQADggEBABzclfMqpRQXStqlJYYJcxi5T1dzvvaARJ2nQV3OQtO5eVVa\r\nUjrBxSwgexoHkcys8pqrcWPmMPQ/Iwhpt0AakKqmINgZg7Bbk5B9oqjAojrwjZAa\r\nRxt/SICiU1YsCzsEkMxqQWLctrZjRVKpx53kle4lSMrcSYGw+LHPTrZPRXQARsRH\r\nz2NPxVtze4JmdmXfxptgkCeOm875daHkljllFtCPuHLMN7r7CRN43iPcUpGhl0mv\r\npdlFDM06Z7BvqmlOHK3sZUYeQd+q+BajEptuwjNfJuddbYSjql6T/G8x5AUz2qEe\r\n3Jg9aBJ/ghpUw4btIW4P+sF55mRi1/ieM8/JXWE=\r\n-----END CERTIFICATE-----\r\n" } Update certificate defaultPrivate
                host.GLTGLT)
                2023-02-18 20:58:05.323	info	host.GLT(GLT) iobroker npm-rebuild: object _design/system updated
                host.GLTGLT)
                2023-02-18 20:58:04.617	info	host.GLT(GLT) iobroker npm-rebuild: Successfully migrated 28427 objects to Redis Sets
                host.GLTGLT)
                2023-02-18 20:57:48.247	info	host.GLT(GLT) iobroker npm-rebuild: > iobroker.js-controller@4.0.24 install C:\iobroker\GLT\node_modules\iobroker.js-controller > node iobroker.js setup first
                host.GLTGLT)
                2023-02-18 20:57:48.156	info	host.GLT(GLT) iobroker npm-rebuild: NPM version: 6.14.11
                host.GLTGLT)
                2023-02-18 20:57:45.824	info	host.GLT(GLT) iobroker npm-rebuild: > iobroker.js-controller@4.0.24 preinstall C:\iobroker\GLT\node_modules\iobroker.js-controller > node lib/preinstallCheck.js
                host.GLTGLT)
                host.GLTGLT)
                2023-02-18 20:57:39.600	info	host.GLT(GLT) iobroker npm-rebuild: latest @types: 18, installed node: 14
                host.GLTGLT)
                2023-02-18 20:57:35.126	info	host.GLT(GLT) iobroker npm-rebuild: Installing NodeJS typings...
                host.GLTGLT)
                2023-02-18 20:57:34.882	info	host.GLT(GLT) iobroker npm-rebuild: > iobroker.javascript@6.2.0 postinstall C:\iobroker\GLT\node_modules\iobroker.javascript > node ./install/installTypings.js
                host.GLTGLT)
                host.GLTGLT)
                2023-02-18 20:57:34.174	info	host.GLT(GLT) iobroker npm-rebuild: [canvas] Success: "C:\iobroker\GLT\node_modules\iobroker.iot\node_modules\canvas\build\Release\canvas.node" is installed via remote
                host.GLTGLT)
                2023-02-18 20:57:30.101	info	host.GLT(GLT) iobroker npm-rebuild: > canvas@2.11.0 install C:\iobroker\GLT\node_modules\iobroker.iot\node_modules\canvas > node-pre-gyp install --fallback-to-build --update-binary
                host.GLTGLT)
                2023-02-18 20:57:28.883	info	host.GLT(GLT) iobroker npm-rebuild: [canvas] Success: "C:\iobroker\GLT\node_modules\iobroker.energiefluss\node_modules\canvas\build\Release\canvas.node" is installed via remote
                host.GLTGLT)
                2023-02-18 20:57:24.235	info	host.GLT(GLT) iobroker npm-rebuild: > canvas@2.11.0 install C:\iobroker\GLT\node_modules\iobroker.energiefluss\node_modules\canvas > node-pre-gyp install --fallback-to-build --update-binary
                host.GLTGLT)
                2023-02-18 20:57:24.234	info	host.GLT(GLT) iobroker npm-rebuild:
                host.GLTGLT)
                2023-02-18 20:57:20.695	info	host.GLT(GLT) iobroker npm-rebuild: Pass --update-binary to reinstall or --build-from-source to recompile
                host.GLTGLT)
                2023-02-18 20:57:20.694	info	host.GLT(GLT) iobroker npm-rebuild: [canvas] Success: "C:\iobroker\GLT\node_modules\canvas\build\Release\canvas.node" already installed
                host.GLTGLT)
                2023-02-18 20:57:19.857	info	host.GLT(GLT) iobroker npm-rebuild: > canvas@2.7.0 install C:\iobroker\GLT\node_modules\canvas > node-pre-gyp install --fallback-to-build
                host.GLTGLT)
                2023-02-18 20:57:19.856	info	host.GLT(GLT) iobroker npm-rebuild:
                host.GLTGLT)
                2023-02-18 20:57:05.068	info	host.GLT(GLT) iobroker npm-rebuild: Rebuilding native modules ...
                  tombox @JB_Sullivan last edited by
                  @jb_sullivan Welch node version ist da installiert
                  • JB_Sullivan
                    14.16.0 - liegt vermutlich daran - oder?
                      @jb_sullivan ja es ist 14.17 aber installier nochmal ich habe mal eine lib downgrade gemacht ob es jetzt geht
                      • JB_Sullivan
                        JB_Sullivan @tombox last edited by JB_Sullivan
                        @tombox Wird gemacht
                        EDIT: Ich weiß nicht ob ich die Änderung schon erwischt habe, aber auch mit der aktuellen Version geht es noch nicht.
                        host.GLT(GLT)
                        2023-02-18 21:23:35.680 info iobroker npm-rebuild: > canvas@2.7.0 install C:\iobroker\GLT\node_modules\canvas > node-pre-gyp install --fallback-to-build
                        host.GLT(GLT)
                        2023-02-18 21:23:35.679 info iobroker npm-rebuild:
                        host.GLT(GLT)
                        2023-02-18 21:23:19.841 info iobroker npm-rebuild: Rebuilding native modules ...
                        host.GLT(GLT)
                        2023-02-18 21:23:17.414 info iobroker rebuild
                        host.GLT(GLT)
                        2023-02-18 21:23:17.414 warn adapter "onvif" seems to be installed for a different version of Node.js. Trying to rebuild it... 2 attempt
                        host.GLT(GLT)
                        2023-02-18 21:23:17.414 info system.adapter.onvif.0 will be rebuilt
                        host.GLT(GLT)
                        2023-02-18 21:23:17.414 info Adapter system.adapter.onvif.0 needs rebuild and will be restarted afterwards.
                        host.GLT(GLT)
                        2023-02-18 21:23:17.414 error instance system.adapter.onvif.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                        host.GLT(GLT)
                        2023-02-18 21:23:17.414 error Caught by controller[0]: }
                        host.GLT(GLT)
                        2023-02-18 21:23:17.414 error Caught by controller[0]: ]
                        host.GLT(GLT)
                        2023-02-18 21:23:17.414 error Caught by controller[0]: 'C:\iobroker\GLT\node_modules\iobroker.onvif\main.js'
                        host.GLT(GLT)
                        2023-02-18 21:23:17.414 error Caught by controller[0]: 'C:\iobroker\GLT\node_modules\urllib\src\cjs\index.js',
                        host.GLT(GLT)
                        2023-02-18 21:23:17.414 error Caught by controller[0]: 'C:\iobroker\GLT\node_modules\urllib\src\cjs\HttpClient.js',
                        host.GLT(GLT)
                        2023-02-18 21:23:17.414 error Caught by controller[0]: 'C:\iobroker\GLT\node_modules\urllib\src\cjs\diagnosticsChannel.js',
                        host.GLT(GLT)
                        2023-02-18 21:23:17.413 error Caught by controller[0]: requireStack: [
                        host.GLT(GLT)
                        2023-02-18 21:23:17.413 error Caught by controller[0]: code: 'MODULE_NOT_FOUND',
                        host.GLT(GLT)
                        2023-02-18 21:23:17.413 error Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:952:19) {
                        host.GLT(GLT)
                        2023-02-18 21:23:17.413 error Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:769:14)
                        host.GLT(GLT)
                        2023-02-18 21:23:17.413 error Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:928:32)
                        host.GLT(GLT)
                        2023-02-18 21:23:17.413 error Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1092:10)
                        host.GLT(GLT)
                        2023-02-18 21:23:17.413 error Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:1063:30)
                        host.GLT(GLT)
                        2023-02-18 21:23:17.413 error Caught by controller[0]: at Object.<anonymous> (C:\iobroker\GLT\node_modules\urllib\src\cjs\diagnosticsChannel.js:7:47)
                        host.GLT(GLT)
                        2023-02-18 21:23:17.413 error Caught by controller[0]: at require (internal/modules/cjs/helpers.js:88:18)
                        host.GLT(GLT)
                        host.GLT(GLT)
                        2023-02-18 21:23:17.413 error Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:725:27)
                        host.GLT(GLT)
                        2023-02-18 21:23:17.413 error Caught by controller[0]: at Function.Module._resolveFilename (internal/modules/cjs/loader.js:880:15)
                        host.GLT(GLT)
                        2023-02-18 21:23:17.413 error Caught by controller[0]: - C:\iobroker\GLT\node_modules\iobroker.onvif\main.js
                        host.GLT(GLT)
                        2023-02-18 21:23:17.413 error Caught by controller[0]: - C:\iobroker\GLT\node_modules\urllib\src\cjs\index.js
                        host.GLT(GLT)
                        2023-02-18 21:23:17.412 error Caught by controller[0]: - C:\iobroker\GLT\node_modules\urllib\src\cjs\HttpClient.js
                        host.GLT(GLT)
                        2023-02-18 21:23:17.412 error Caught by controller[0]: - C:\iobroker\GLT\node_modules\urllib\src\cjs\diagnosticsChannel.js
                        host.GLT(GLT)
                        2023-02-18 21:23:17.412 error Caught by controller[0]: Require stack:
                        host.GLT(GLT)
                        2023-02-18 21:23:17.412 error Caught by controller[0]: Error: Cannot find module 'diagnostics_channel'
                        host.GLT(GLT)
                        host.GLT(GLT)
                        2023-02-18 21:23:17.412 error Caught by controller[0]: ^
                        host.GLT(GLT)
                        2023-02-18 21:23:17.412 error Caught by controller[0]: throw err;
                        host.GLT(GLT)
                        2023-02-18 21:23:17.412 error Caught by controller[0]: internal/modules/cjs/loader.js:883
                        host.GLT(GLT)
                        2023-02-18 21:23:15.834 info instance system.adapter.onvif.0 started with pid 4868
                        host.GLT(GLT)
                        2023-02-18 21:23:15.638 info iobroker npm-rebuild: exit 1
                        host.GLT(GLT)
                        2023-02-18 21:23:14.622 error iobroker npm-rebuild: Rebuilding native modules failed
                          @jb_sullivan Sorry jetzt nochmal
                          • JB_Sullivan
                            @tombox Installation funktioniert jetzt ohne Fehler, aber es werden weder automatisch noch manuell Kameras (sind 6 Stück und ONVIF tauglich) gefunden und das obwohl ich sowohl IP als auch Port mäßig direkt "mit der Nase" darauf gestoßen haben.
                            onvif.0
                            8496	2023-02-18 21:28:40.820	info	Finished onvif discovery
                            onvif.0
                            8496	2023-02-18 21:28:35.813	info	Start onvif discovery
                            onvif.0
                            8496	2023-02-18 21:28:35.750	info	Done with cleaning
                            onvif.0
                            8496	2023-02-18 21:28:35.618	info	Clean old version devices
                            onvif.0
                            8496	2023-02-18 21:28:35.570	info	starting. Version 1.0.0 (non-npm: iobroker-community-adapters/ioBroker.onvif#bc7fea2c45037c4557f2e8ec88b760f393cc5378) in C:/iobroker/GLT/node_modules/iobroker.onvif, node: v14.16.0, js-controller: 4.0.24
                              @jb_sullivan Wie sieht der log bei manual search aus.. gerne per pn da dort Passwörter enthalten sind
                              • JB_Sullivan
                                @tombox Kann ich hier auch öffentlich posten. Da passiert nichts mit Passwörtern. Er startet und finished sofort ohne weitere Aktionen.
                                So sieht es in der Kamera aus, IP Benutzername und PW sind im Adapter natürlich richtig eingetragen - an der Stelle gleich ein Verbesserungsvorschlag. Ich habe mehrere Kameras mit unterschiedlichen Passwörtern. Entweder man muss zukünftig mehrere Instanzen anlegen, oder es gibt vielleicht zukünftig die Möglichkeit in den Instanz Einstellungen nach mehreren unterschiedlichen Benutzernamen/PW Kombinationen und Kameras zu suchen.
                                onvif.0
                                4456	2023-02-18 21:46:35.614	info	Finished onvif discovery
                                onvif.0
                                4456	2023-02-18 21:46:30.608	info	Start onvif discovery
                                onvif.0
                                4456	2023-02-18 21:46:30.490	info	starting. Version 1.0.0 (non-npm: iobroker-community-adapters/ioBroker.onvif#bc7fea2c45037c4557f2e8ec88b760f393cc5378) in C:/iobroker/GLT/node_modules/iobroker.onvif, node: v14.16.0, js-controller: 4.0.24
                                onvif.0
                                4456	2023-02-18 21:46:30.004	debug	Plugin sentry Initialize Plugin (enabled=true)
                                onvif.0
                                4456	2023-02-18 21:46:29.576	debug	States connected to redis: 127.0.0.1:9000
                                onvif.0
                                4456	2023-02-18 21:46:29.459	debug	States create User PubSub Client
                                onvif.0
                                4456	2023-02-18 21:46:29.458	debug	States create System PubSub Client
                                onvif.0
                                4456	2023-02-18 21:46:29.396	debug	Redis States: Use Redis connection: 127.0.0.1:9000
                                onvif.0
                                4456	2023-02-18 21:46:29.316	debug	Objects connected to redis: 127.0.0.1:9001
                                onvif.0
                                4456	2023-02-18 21:46:29.285	debug	Objects client initialize lua scripts
                                onvif.0
                                4456	2023-02-18 21:46:29.114	debug	Objects create User PubSub Client
                                onvif.0
                                4456	2023-02-18 21:46:29.113	debug	Objects create System PubSub Client
                                onvif.0
                                4456	2023-02-18 21:46:29.092	debug	Objects client ready ... initialize now
                                onvif.0
                                4456	2023-02-18 21:46:28.946	debug	Redis Objects: Use Redis connection: 127.0.0.1:9001
                                  @jb_sullivan Das Passwort ist nur für den Suchvorgang relevant und muss nicht für alle Kameras stimmen.
                                  Ich sehe im Log nicht das du auf den Button "Manuel Kamera suchen" drückst
                                  • JB_Sullivan
                                    @tombox sagte in Test Adapter onvif camera v1.0.0:
                                    Drücke ich aber - der Button wird dann von blau zu grau und bleibt auch so lange grau bis ich das Fenster verlasse (getestete Wartezeit 15 min.)
                                    Wenn ich bei manueller Suche die richtige IP und den richtigen Port eingebe, müsste es ja eigentlich relativ schnell einen Treffer geben - oder? Um dieses zu überprüfen gehe ich dann aus dem Instanz Fenster in das LOG Fenster - und da bekomme ich dann den LOG von oben.
                                      @jb_sullivan
                                      Es müsste im Log nach dem drücken des Buttons "Manuel Kamera suchen"
                                      info Starting manual search
                                      zu sehen sein und dann die einzelnen Versuche
                                      Geht denn der "Kamera Suche starten" button kommt da im log "Starting discovery" ?
                                      O JB_Sullivan 2 Replies Last reply Reply Quote 0
                                      • O
                                        Kam bei mir nie.
                                        • JB_Sullivan
                                          Wenn das der gleiche Text ist wie "Start onvif discovery" - ja, der kommt - aber der Button Farbumschlag verhält sich analog zur manuellen Suche.
                                          onvif.0
                                          1728	2023-02-19 12:56:51.443	info	Finished onvif discovery
                                          onvif.0
                                          1728	2023-02-19 12:56:46.437	info	Start onvif discovery
                                          onvif.0
                                          1728	2023-02-19 12:56:46.273	info	starting. Version 1.0.0 (non-npm: iobroker-community-adapters/ioBroker.onvif#bc7fea2c45037c4557f2e8ec88b760f393cc5378) in C:/iobroker/GLT/node_modules/iobroker.onvif, node: v14.16.0, js-controller: 4.0.24
                                          onvif.0
                                          1728	2023-02-19 12:56:45.689	debug	Plugin sentry Initialize Plugin (enabled=true)
                                          onvif.0
                                          1728	2023-02-19 12:56:45.389	debug	States connected to redis: 127.0.0.1:9000
                                          onvif.0
                                          1728	2023-02-19 12:56:45.321	debug	States create User PubSub Client
                                          onvif.0
                                          1728	2023-02-19 12:56:45.320	debug	States create System PubSub Client
                                          onvif.0
                                          1728	2023-02-19 12:56:45.288	debug	Redis States: Use Redis connection: 127.0.0.1:9000
                                          onvif.0
                                          1728	2023-02-19 12:56:45.243	debug	Objects connected to redis: 127.0.0.1:9001
                                          onvif.0
                                          1728	2023-02-19 12:56:45.237	debug	Objects client initialize lua scripts
                                          onvif.0
                                          1728	2023-02-19 12:56:45.105	debug	Objects create User PubSub Client
                                          onvif.0
                                          1728	2023-02-19 12:56:45.104	debug	Objects create System PubSub Client
                                          onvif.0
                                          1728	2023-02-19 12:56:45.103	debug	Objects client ready ... initialize now
                                          onvif.0
                                          1728	2023-02-19 12:56:45.035	debug	Redis Objects: Use Redis connection: 127.0.0.1:9001
                                            @jb_sullivan Nach Neuinstallation sollten jetzt auch die buttons gehen.
                                            341
                                            84585
