    4. Test Adapter onvif camera v1.x.x
      tombox @JB_Sullivan last edited by
      @jb_sullivan ja es ist 14.17 aber installier nochmal ich habe mal eine lib downgrade gemacht ob es jetzt geht
      • JB_Sullivan
        JB_Sullivan @tombox last edited by JB_Sullivan
        @tombox Wird gemacht
        EDIT: Ich weiß nicht ob ich die Änderung schon erwischt habe, aber auch mit der aktuellen Version geht es noch nicht.
        host.GLT(GLT)
        2023-02-18 21:23:35.680 info iobroker npm-rebuild: > canvas@2.7.0 install C:\iobroker\GLT\node_modules\canvas > node-pre-gyp install --fallback-to-build
        host.GLT(GLT)
        2023-02-18 21:23:35.679 info iobroker npm-rebuild:
        host.GLT(GLT)
        2023-02-18 21:23:19.841 info iobroker npm-rebuild: Rebuilding native modules ...
        host.GLT(GLT)
        2023-02-18 21:23:17.414 info iobroker rebuild
        host.GLT(GLT)
        2023-02-18 21:23:17.414 warn adapter "onvif" seems to be installed for a different version of Node.js. Trying to rebuild it... 2 attempt
        host.GLT(GLT)
        2023-02-18 21:23:17.414 info system.adapter.onvif.0 will be rebuilt
        host.GLT(GLT)
        2023-02-18 21:23:17.414 info Adapter system.adapter.onvif.0 needs rebuild and will be restarted afterwards.
        host.GLT(GLT)
        2023-02-18 21:23:17.414 error instance system.adapter.onvif.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        host.GLT(GLT)
        2023-02-18 21:23:17.414 error Caught by controller[0]: }
        host.GLT(GLT)
        2023-02-18 21:23:17.414 error Caught by controller[0]: ]
        host.GLT(GLT)
        2023-02-18 21:23:17.414 error Caught by controller[0]: 'C:\iobroker\GLT\node_modules\iobroker.onvif\main.js'
        host.GLT(GLT)
        2023-02-18 21:23:17.414 error Caught by controller[0]: 'C:\iobroker\GLT\node_modules\urllib\src\cjs\index.js',
        host.GLT(GLT)
        2023-02-18 21:23:17.414 error Caught by controller[0]: 'C:\iobroker\GLT\node_modules\urllib\src\cjs\HttpClient.js',
        host.GLT(GLT)
        2023-02-18 21:23:17.414 error Caught by controller[0]: 'C:\iobroker\GLT\node_modules\urllib\src\cjs\diagnosticsChannel.js',
        host.GLT(GLT)
        2023-02-18 21:23:17.413 error Caught by controller[0]: requireStack: [
        host.GLT(GLT)
        2023-02-18 21:23:17.413 error Caught by controller[0]: code: 'MODULE_NOT_FOUND',
        host.GLT(GLT)
        2023-02-18 21:23:17.413 error Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:952:19) {
        host.GLT(GLT)
        2023-02-18 21:23:17.413 error Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:769:14)
        host.GLT(GLT)
        2023-02-18 21:23:17.413 error Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:928:32)
        host.GLT(GLT)
        2023-02-18 21:23:17.413 error Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1092:10)
        host.GLT(GLT)
        2023-02-18 21:23:17.413 error Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:1063:30)
        host.GLT(GLT)
        2023-02-18 21:23:17.413 error Caught by controller[0]: at Object.<anonymous> (C:\iobroker\GLT\node_modules\urllib\src\cjs\diagnosticsChannel.js:7:47)
        host.GLT(GLT)
        2023-02-18 21:23:17.413 error Caught by controller[0]: at require (internal/modules/cjs/helpers.js:88:18)
        host.GLT(GLT)
        host.GLT(GLT)
        2023-02-18 21:23:17.413 error Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:725:27)
        host.GLT(GLT)
        2023-02-18 21:23:17.413 error Caught by controller[0]: at Function.Module._resolveFilename (internal/modules/cjs/loader.js:880:15)
        host.GLT(GLT)
        2023-02-18 21:23:17.413 error Caught by controller[0]: - C:\iobroker\GLT\node_modules\iobroker.onvif\main.js
        host.GLT(GLT)
        2023-02-18 21:23:17.413 error Caught by controller[0]: - C:\iobroker\GLT\node_modules\urllib\src\cjs\index.js
        host.GLT(GLT)
        2023-02-18 21:23:17.412 error Caught by controller[0]: - C:\iobroker\GLT\node_modules\urllib\src\cjs\HttpClient.js
        host.GLT(GLT)
        2023-02-18 21:23:17.412 error Caught by controller[0]: - C:\iobroker\GLT\node_modules\urllib\src\cjs\diagnosticsChannel.js
        host.GLT(GLT)
        2023-02-18 21:23:17.412 error Caught by controller[0]: Require stack:
        host.GLT(GLT)
        2023-02-18 21:23:17.412 error Caught by controller[0]: Error: Cannot find module 'diagnostics_channel'
        host.GLT(GLT)
        host.GLT(GLT)
        2023-02-18 21:23:17.412 error Caught by controller[0]: ^
        host.GLT(GLT)
        2023-02-18 21:23:17.412 error Caught by controller[0]: throw err;
        host.GLT(GLT)
        2023-02-18 21:23:17.412 error Caught by controller[0]: internal/modules/cjs/loader.js:883
        host.GLT(GLT)
        2023-02-18 21:23:15.834 info instance system.adapter.onvif.0 started with pid 4868
        host.GLT(GLT)
        2023-02-18 21:23:15.638 info iobroker npm-rebuild: exit 1
        host.GLT(GLT)
        2023-02-18 21:23:14.622 error iobroker npm-rebuild: Rebuilding native modules failed
          @jb_sullivan Sorry jetzt nochmal
          • JB_Sullivan
            @tombox Installation funktioniert jetzt ohne Fehler, aber es werden weder automatisch noch manuell Kameras (sind 6 Stück und ONVIF tauglich) gefunden und das obwohl ich sowohl IP als auch Port mäßig direkt "mit der Nase" darauf gestoßen haben.
            onvif.0
            8496	2023-02-18 21:28:40.820	info	Finished onvif discovery
            onvif.0
            8496	2023-02-18 21:28:35.813	info	Start onvif discovery
            onvif.0
            8496	2023-02-18 21:28:35.750	info	Done with cleaning
            onvif.0
            8496	2023-02-18 21:28:35.618	info	Clean old version devices
            onvif.0
            8496	2023-02-18 21:28:35.570	info	starting. Version 1.0.0 (non-npm: iobroker-community-adapters/ioBroker.onvif#bc7fea2c45037c4557f2e8ec88b760f393cc5378) in C:/iobroker/GLT/node_modules/iobroker.onvif, node: v14.16.0, js-controller: 4.0.24
              @jb_sullivan Wie sieht der log bei manual search aus.. gerne per pn da dort Passwörter enthalten sind
              • JB_Sullivan
                @tombox Kann ich hier auch öffentlich posten. Da passiert nichts mit Passwörtern. Er startet und finished sofort ohne weitere Aktionen.
                So sieht es in der Kamera aus, IP Benutzername und PW sind im Adapter natürlich richtig eingetragen - an der Stelle gleich ein Verbesserungsvorschlag. Ich habe mehrere Kameras mit unterschiedlichen Passwörtern. Entweder man muss zukünftig mehrere Instanzen anlegen, oder es gibt vielleicht zukünftig die Möglichkeit in den Instanz Einstellungen nach mehreren unterschiedlichen Benutzernamen/PW Kombinationen und Kameras zu suchen.
                onvif.0
                4456	2023-02-18 21:46:35.614	info	Finished onvif discovery
                onvif.0
                4456	2023-02-18 21:46:30.608	info	Start onvif discovery
                onvif.0
                4456	2023-02-18 21:46:30.490	info	starting. Version 1.0.0 (non-npm: iobroker-community-adapters/ioBroker.onvif#bc7fea2c45037c4557f2e8ec88b760f393cc5378) in C:/iobroker/GLT/node_modules/iobroker.onvif, node: v14.16.0, js-controller: 4.0.24
                onvif.0
                4456	2023-02-18 21:46:30.004	debug	Plugin sentry Initialize Plugin (enabled=true)
                onvif.0
                4456	2023-02-18 21:46:29.576	debug	States connected to redis: 127.0.0.1:9000
                onvif.0
                4456	2023-02-18 21:46:29.459	debug	States create User PubSub Client
                onvif.0
                4456	2023-02-18 21:46:29.458	debug	States create System PubSub Client
                onvif.0
                4456	2023-02-18 21:46:29.396	debug	Redis States: Use Redis connection: 127.0.0.1:9000
                onvif.0
                4456	2023-02-18 21:46:29.316	debug	Objects connected to redis: 127.0.0.1:9001
                onvif.0
                4456	2023-02-18 21:46:29.285	debug	Objects client initialize lua scripts
                onvif.0
                4456	2023-02-18 21:46:29.114	debug	Objects create User PubSub Client
                onvif.0
                4456	2023-02-18 21:46:29.113	debug	Objects create System PubSub Client
                onvif.0
                4456	2023-02-18 21:46:29.092	debug	Objects client ready ... initialize now
                onvif.0
                4456	2023-02-18 21:46:28.946	debug	Redis Objects: Use Redis connection: 127.0.0.1:9001
                  @jb_sullivan Das Passwort ist nur für den Suchvorgang relevant und muss nicht für alle Kameras stimmen.
                  Ich sehe im Log nicht das du auf den Button "Manuel Kamera suchen" drückst
                  • JB_Sullivan
                    @tombox sagte in Test Adapter onvif camera v1.0.0:
                    Drücke ich aber - der Button wird dann von blau zu grau und bleibt auch so lange grau bis ich das Fenster verlasse (getestete Wartezeit 15 min.)
                    Wenn ich bei manueller Suche die richtige IP und den richtigen Port eingebe, müsste es ja eigentlich relativ schnell einen Treffer geben - oder? Um dieses zu überprüfen gehe ich dann aus dem Instanz Fenster in das LOG Fenster - und da bekomme ich dann den LOG von oben.
                      @jb_sullivan
                      Es müsste im Log nach dem drücken des Buttons "Manuel Kamera suchen"
                      info Starting manual search
                      zu sehen sein und dann die einzelnen Versuche
                      Geht denn der "Kamera Suche starten" button kommt da im log "Starting discovery" ?
                      O JB_Sullivan 2 Replies Last reply Reply Quote 0
                      • O
                        oFbEQnpoLKKl6mbY5e13 @tombox last edited by
                        Kam bei mir nie.
                        • JB_Sullivan
                          Wenn das der gleiche Text ist wie "Start onvif discovery" - ja, der kommt - aber der Button Farbumschlag verhält sich analog zur manuellen Suche.
                          onvif.0
                          1728	2023-02-19 12:56:51.443	info	Finished onvif discovery
                          onvif.0
                          1728	2023-02-19 12:56:46.437	info	Start onvif discovery
                          onvif.0
                          1728	2023-02-19 12:56:46.273	info	starting. Version 1.0.0 (non-npm: iobroker-community-adapters/ioBroker.onvif#bc7fea2c45037c4557f2e8ec88b760f393cc5378) in C:/iobroker/GLT/node_modules/iobroker.onvif, node: v14.16.0, js-controller: 4.0.24
                          onvif.0
                          1728	2023-02-19 12:56:45.689	debug	Plugin sentry Initialize Plugin (enabled=true)
                          onvif.0
                          1728	2023-02-19 12:56:45.389	debug	States connected to redis: 127.0.0.1:9000
                          onvif.0
                          1728	2023-02-19 12:56:45.321	debug	States create User PubSub Client
                          onvif.0
                          1728	2023-02-19 12:56:45.320	debug	States create System PubSub Client
                          onvif.0
                          1728	2023-02-19 12:56:45.288	debug	Redis States: Use Redis connection: 127.0.0.1:9000
                          onvif.0
                          1728	2023-02-19 12:56:45.243	debug	Objects connected to redis: 127.0.0.1:9001
                          onvif.0
                          1728	2023-02-19 12:56:45.237	debug	Objects client initialize lua scripts
                          onvif.0
                          1728	2023-02-19 12:56:45.105	debug	Objects create User PubSub Client
                          onvif.0
                          1728	2023-02-19 12:56:45.104	debug	Objects create System PubSub Client
                          onvif.0
                          1728	2023-02-19 12:56:45.103	debug	Objects client ready ... initialize now
                          onvif.0
                          1728	2023-02-19 12:56:45.035	debug	Redis Objects: Use Redis connection: 127.0.0.1:9001
                            @jb_sullivan Nach Neuinstallation sollten jetzt auch die buttons gehen.
                            • JB_Sullivan
                              @tombox AH jetzt ja - eine Insel, besser gesagt eine Kamera - na dann wollen wir mal gucken ob er die anderen manuell auch noch findet - automatisch hat er jedenfalls nichts gefunden.
                              Aber es geht jetzt schonmal auf manuell.......
                              • Wszene
                                Wszene last edited by
                                Vielen Dank für den Adapter
                                Install und hinzufügen der Kameras hat perfekt funktioniert
                                Und da habe ich doch gleich eine Frage
                                Ich habe meine Cams im Garten und würde diese gern vor dem Betreten deaktievieren
                                Also die Aufzeichnung und die Alamierung
                                Momentan mache ich es über die App aber es wäre schön wenn ich in der VIS einen Button hätte mit dem ich das machen könnte
                                Ist es möglich diese Option zu integrieren?
                                Danke im Voraus
                                Marcel
                                  tombox @Wszene last edited by
                                  @wszene ich sehe nicht das dies über onvif Protokoll möglich ist dann wäre das eher etwas individuell für jeden Hersteller
                                  Chris76e Wszene 2 Replies Last reply Reply Quote 0
                                  • Chris76e
                                    Chris76e @tombox last edited by
                                    @tombox
                                    Bei mir kommen einige Warnugen und errors beim starten der Instanz.
                                    Habe 4 Tapo C200.
                                    192.168.178.117:2020 No snapshot url available: Error: ONVIF SOAP Fault: {"value":"SOAP-ENV:Receiver","subcode":{"value":"ter:ActionNotSupported"}}
                                    	<?xml version="1.0" encoding="UTF-8"?> <soap:Envelope ><soap:Header><wsa:To>http://schemas.xmlsoap.org/ws/2004/08/addressing/role/anonymous</wsa:To><wsa:Action>http://schemas.xmlsoap.org/ws/2005/04/discovery/ProbeMatches</wsa:Action><wsa:MessageID>urn:uuid:315681d1-2e37-45ee-b407-9b9c26990de8</wsa:MessageID><wsa:RelatesTo>urn:uuid:5bf5e60a-86f3-cf75-a8b2-ab66a704fde6</wsa:RelatesTo><wsd:AppSequence InstanceId="1677084647" SequenceId="urn:uuid:38e8978f-b114-4596-8aba-06a03425c634" MessageNumber="149"/></soap:Header><soap:Body><wsd:ProbeMatches><wsd:ProbeMatch><wsa:EndpointReference><wsa:Address>urn:uuid:9e09e321-e4b7-4a6d-94a1-4a67070299b6</wsa:Address></wsa:EndpointReference><wsd:Types>wsdp:Device pub:Computer</wsd:Types><wsd:XAddrs>http://CamStation2:5357/9e09e321-e4b7-4a6d-94a1-4a67070299b6</wsd:XAddrs><wsd:MetadataVersion>2</wsd:MetadataVersion></wsd:ProbeMatch></wsd:ProbeMatches></soap:Body></soap:Envelope>
                                    debugLog.txt
                                    • Wszene
                                      Wszene @tombox last edited by
                                      Aha OK
                                      Das ist schade aber dann ist es leider so
                                        tombox @Chris76e last edited by
                                        @chris76e Ja genau das ist die Info das Tapes kein snapshot url anbieten also ein url wo man das aktuelle bild abgreifen kann. Das ist sehr ärgerlich. Es bietet nur video Urls. Für ein snapshot müsste man ffmpeg installieren und vom aktuellen stream ein screenshot erstellen
                                        Chris76e 1 Reply Last reply Reply Quote 0
                                        • Chris76e
                                          @tombox
                                          schade, dann bleibt es halt über MotionEye und ein script wegen der Bilder. Oder kann man den stream von Motioneye abfangen, weil da gibt es ne snapshot url?
                                            RandyAndy @tombox last edited by RandyAndy
                                            Den Datenpunkt nicht als Stream verwenden, da sonst die Festplatte zu hohe Last hat.
                                            Den Datenpunkt onvif.0.IP_PORT.snapshot ein String img src element zuordnen
                                            Den Datenpunkt onvif.0.IP_PORT.snapshot als HTML element in die vis einfügen mit folgendem Inhalt
                                            Irgenwie kann ich das nicht nachvollziehen was Du da machst.
                                            Die Kameras sind alle da, aber bei meinen Hikvisions bekomme ich einfach keine Bilder im VIS angezeigt.
                                            Kannst Du das bitte Schritt für Schritt erklären was da zu tun ist.
                                            Andreas
                                            341
                                            84808
