    3. Off Topic
    4. InfluxDB
    5. (gelöst) influxdb mir unbekannte Probleme
      Thomas Braun Most Active @woupi last edited by
      @woupi sagte in (gelöst) influxdb mir unbekannte Probleme:
          500 https://repos.influxdata.com/ubuntu impish/stable amd64 Packages
       1.6.7~rc0-1ubuntu0.22.04.1 500
          500 http://archive.ubuntu.com/ubuntu jammy-updates/universe amd64 Packages
      Das zeigt, dass das influx-Repository falsch angelegt ist.
      Die Releases müssen sich decken, also statt impish muss da beim influx-Repo jammy rein.
      Zeig mal das gesamte Setup deiner Repos:
      sudo apt update
        woupi @Thomas Braun last edited by
        sudo apt update
        Get:1 https://packages.grafana.com/oss/deb stable InRelease [5984 B]
        Hit:2 http://archive.ubuntu.com/ubuntu jammy InRelease
        Err:1 https://packages.grafana.com/oss/deb stable InRelease
          The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 9E439B102CF3C0C6
        Get:3 https://repos.influxdata.com/ubuntu impish InRelease [7020 B]
        Get:4 http://archive.ubuntu.com/ubuntu jammy-updates InRelease [119 kB]
        Err:3 https://repos.influxdata.com/ubuntu impish InRelease
          The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
        Get:5 http://archive.ubuntu.com/ubuntu jammy-security InRelease [110 kB]
        Get:6 http://archive.ubuntu.com/ubuntu jammy-updates/main amd64 Packages [898 kB]
        Get:7 http://archive.ubuntu.com/ubuntu jammy-updates/universe amd64 Packages [853 kB]
        Fetched 1987 kB in 1s (1333 kB/s)
        Reading package lists... Done
        Building dependency tree... Done
        10 packages can be upgraded. Run 'apt list --upgradable' to see them.
        W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://packages.grafana.com/oss/deb stable InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 9E439B102CF3C0C6
        W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://repos.influxdata.com/ubuntu impish InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
        W: Failed to fetch https://packages.grafana.com/oss/deb/dists/stable/InRelease  The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 9E439B102CF3C0C6
        W: Failed to fetch https://repos.influxdata.com/ubuntu/dists/impish/InRelease  The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
        W: Some index files failed to download. They have been ignored, or old ones used instead.
          @woupi
          Das ist genauso falsch wie ich es befürchtet hatte.
          https://forum.iobroker.net/topic/62040/linux-debian-grafana-repo-muss-aktualisiert-werden
          Vermutlich am einfachsten die beiden Repos für influxdb und grafana nochmal frisch neuanlegen. Dann passt das auch übereinander.
          W 2 Replies Last reply Reply Quote 0
            oh je, danke.
            Mal schauen wie das geht
              @thomas-braun sagte in (gelöst) influxdb mir unbekannte Probleme:
              @woupi
              sudo apt update
              Get:1 https://repos.influxdata.com/ubuntu impish InRelease [7020 B]
              Err:1 https://repos.influxdata.com/ubuntu impish InRelease
              Hit:3 http://archive.ubuntu.com/ubuntu jammy-updates InRelease
              Hit:4 http://archive.ubuntu.com/ubuntu jammy-security InRelease
              Fetched 7020 B in 0s (14.8 kB/s)
              W: An error occurred during the signature verification. The repository is not updated and the previous index files wi                                          ll be used. GPG error: https://repos.influxdata.com/ubuntu impish InRelease: The following signatures couldn't be ver                                          ified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
              W: Failed to fetch https://repos.influxdata.com/ubuntu/dists/impish/InRelease  The following signatures couldn't be v                                          erified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
              Habe ich gemacht, vielen Dank für die Anleitung, ich hoffe, dass das jetzt so richtig ist.
                Thomas Braun Most Active @woupi last edited by Thomas Braun
                Da in dem Output immer noch Fehler gemeldet werden kann es nicht richtig sein. Das influxdb-Repo ist noch falsch.
                Und das grafana-Repo hast du jetzt ganz rausgeworfen. Das solltest du nicht tun. Jedenfalls nicht ohne richtige Neuanlage.
                Bei beidem also nochmal ran.
                  woupi @Thomas Braun last edited by woupi
                  Sorry, dann doch lieber langsam, ich habe:
                  apt-key list | grep -i grafana | wc -l
                  Warning: apt-key is deprecated. Manage keyring files in trusted.gpg.d instead (see apt-key(8)).
                  0
                  apt-key list | grep -i influxdata | wc -l
                  0
                  Das ist doch 0, oder sehe ich das falsch?
                    @woupi
                    Das ist richtig, die ausgelaufenen Schlüssel sind nicht mehr im key ring drin.
                      @woupi
                      Ok, sorry, aber was heißt das?
                        Das du den Teil richtig gemacht hast, die Rückmeldung muss 0 lauten.
                        Die Anleitung ist aber noch länger.
                          ok, da bin ich ja schonmal froh.
                            @woupi
                            Weiter unten in dem Thread geht es auch im das influxdb-Repo, das muss auch angepackt werden.
                              @woupi
                              @woupi
                              Kurze Zwischenfrage, ich arbeite das gerade durch :
                              ls -lAh /etc/apt/sources.list.d/
                              -rw-r--r-- 1 root root   0 Feb 19 15:05 grafana.list
                              -rw-r--r-- 1 root root 117 Feb 19 15:24 influxdata.list
                              -rw-r--r-- 1 root root 102 Feb 19  2022 influxdb.list
                              Das ist doch nicht richtig, das da 2 influx.....list sind, oder ist das egal?
                              Und, direkt noch eine Frage, wie lösche ich die, welcher Befehl?
                                @woupi
                                sudo rm /etc/apt/sources list.d/influxdb.list
                                  @woupi
                                  Danke, rm habe ich gerade installiert, dachte es gäbe von Haus etwas.
                                  Dann werde ich die mal löschen und weiter machen.
                                  linux-package-signing-key-rotation
                                  habe ich schon durch
                                    Thomas Braun Most Active last edited by
                                    @woupi
                                    Wat? rm ist sowas von einem Basis-Befehl, dass muss nicht installiert werden.
                                    Was haste denn da jetzt getrieben?
                                      @woupi
                                      Ich habe es gerade noch mal gelesen, hast recht, das war installiert, ich hatte mich beim ersten mal vertippt und re statt rw geschrieben 😖
                                      W Thomas Braun 2 Replies Last reply Reply Quote 0
                                        woupi @woupi last edited by
                                        sind jetzt auch nur noch 2 da:
                                        -rw-r--r-- 1 root root 98 Feb 19 16:10 influxdb.list
                                          rm...
                                          Kopier die Befehle doch einfach in die Konsole und tipsel die nicht ab.
                                            Und es ist die falsche stehen geblieben. Du solltest doch die
                                            löschen.
                                            81.1k
                                            6700
