    4. Neuer Adapter vCard
    Neuer Adapter vCard
    • bahnuhr
      hast du mal die json output aktualisiert.
      Dieser aktualisiert erst dann, wenn du fritzbox.json aktualisierst.
        jensus11 last edited by
        Das ist das Widget.
        [{"tpl":"tplTableBody","data":{"visibility-cond":"==","visibility-val":1,"static_value":"","table_oid":"vcard.0.Outputs.ReplacedPhoneNumbersCh5","colCount":"4","colWidth1":"60px","colWidth2":"60px","colWidth3":"15px","colName1":"Uhrzeit","colName2":"Rufnummer","colName3":"g/k","colAttr1":"date","colAttr2":"externalNumber","colAttr3":"callSymbolColor","colName5":"Dauer","colWidth5":"40px","colAttr5":"durationForm","visibility-groups-action":"hide","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"g_header_§3":true,"max_rows":"8","new_on_top":true,"hide_header":false,"detailed_wid":"","colName4":"Dauer","colAttr4":"durationForm","colWidth4":"20px","g_css_background":true,"g_css_border":false,"g_css_shadow_padding":false,"g_gestures":false,"show_scroll":false},"style":{"left":"585px","top":"66px","width":"513px","height":"181px","text-align":"center","font-size":"14px","z-index":"9","background":"","font-family":"","color":"white","background-color":"black"},"widgetSet":"basic"}]
        meintest du das so mit den Einstellungen (Hardcopy)?
         ![1024_bildschirmfoto_2017-01-21_um_14.34.35.png](/assets/uploads/files/1024_bildschirmfoto_2017-01-21_um_14.34.35.png)
        so wird es dargestellt.
         ![1024_bildschirmfoto_2017-01-21_um_14.43.17.png](/assets/uploads/files/1024_bildschirmfoto_2017-01-21_um_14.43.17.png)
        • bahnuhr
          hast du die Zeilen im vcard Adapter rausgenommen.
          Und hast du noch css Scripte drin (z.B. für tv Spielfilm)
            die Zeilen sind raus im vCard Adapter.
            CSS Script habe ich für tv Spielfilm am laufen.
            Meinst das stört? Kann man dann das CSS so einstellen, das es nur für den TV View genutzt wird?
            • bahnuhr
              ja das stört.
              Und genau diese Frage habe ich hier gestellt:
              http://forum.iobroker.net/viewtopic.php?f=21&t=4882
              Fazit:
              ich habe die css wieder raus genommen.
              Denn ohne diese sieht die tv widget auch ganz gut aus.
              mfg
                dadran hat es wirklich gelegen.
                Wie kann man denn jetzt beim TV Widget die Spaltenhöhe verringern?
                Jetzt ist die Übersicht schon arg groß.
                Hast du da was unternommen?
                • X
                  xADDRx last edited by
                  ich bekomme es einfach nicht hin, dass die Anrufe sauber dargestellt werden.
                  Hat jemand eine Idee?
                    @xADDRx:
                    Hat jemand eine Idee? `
                    Ja!
                    Frage 1: Was meinst du mit @xADDRx:
                    dass die Anrufe sauber dargestellt werden. ` ?
                    Frage 2: Hast du das Widget in der Größe verändert?
                    Rainer
                    • X
                      Hallo homoran
                      Am liebsten so:
                      Name Nummer Zeit
                      Xyz. 9098@8. 18:00 Uhr
                      Momentan wird alles durcheinander angezeigt.
                        @Homoran:
                        Frage 2: Hast du das Widget in der Größe verändert? `
                        • X
                          ja beim ersten mal habe ich die größe verändert….habe dann aber das widget wieder neu importiert und immer noch so.
                          jetzt habe ich etwas rum gespielt..es sieht etwas besser aus siehe foto.Nur bekomme ich die eigene Nummer (eigenes Amt) nicht nach oben.
                          Das obere durchgestrichene ist die verpasste Nummer, das untere die eigene.
                            @xADDRx:
                            ja beim ersten mal habe ich die größe verändert `
                            Dann musst du auch noch die Schriftgröße verkleinern.
                            Rainer
                            • X
                              Hallo Rainer,
                              danke für die schnelle Antwort. Das mit der Schriftgröße habe ich versucht nur bringt das nicht viel. Erst wenn ich die Breite verändere wird die eigene Nummer nach oben verlegt, leider nur viel zu weit rechts. Wie bekomme ich (rot markiert) die Nummer nach links? Ich habe schon alles verändert.?
                              Beni
                                @xADDRx:
                                Wie bekomme ich (rot markiert) die Nummer nach links? `
                                gar nicht.
                                Die Spalten sind zu schmal für deine Schriftgröße. Die externe Rufnummer hängt schon in der für die eigene Rufnummer gedachte spalte, dadurch ruscht die eigene Nummer eine Spalte weiter.
                                Rainer
                                • X
                                  ok danke, dann brauch ich nicht weiter suchen!
                                  Vielen Dank!
                                  PS:Kann man die auch nicht weglassen?
                                  Beni
                                    Ist das Widget für den vCard-Adapter gedacht??
                                    Ich denke das ist für den Fritzbox-Adapter.
                                    Ich musste da auch erst die Schriftgröße anpassen.
                                    Wo stellst du es denn dar?
                                    ist da vielleicht ein Vergrößerungsfaktor / Zeichengröße am Bildschirm >100% eingestellt?
                                    Rainer
                                    • X
                                      hab das Widget hier exportiert und bei mir importiert(https://iobroker.net:8080/vis/edit.html?Brati)
                                      Größe ist bei 100%.
                                        Brati last edited by
                                        @xADDRx:
                                        Größe ist bei 100%. `
                                        Kam mir doch gleich bekannt vor :), wollte gerade vom PC posten. Im Vcard sind die Spalten wie folgt eingestellt:
                                        Ich denke mal da ist der Fehler.
                                        Brati
                                          Jetzt mal Schritt für Schritt!
                                          Du benutzst den vCard Adapter (=Threadtitel!)? (ich nutze ihn nicht, kann dazu nichts sagen)
                                          Du benutzst für die Anzeige das Widget das für den Fritzbox-Adapter vorgesehen ist.
                                          Ich weiß nicht was und vor allem wie der vCard-Adapter ausgibt.
                                          @xADDRx:
                                          Wovon?
                                          und meine Frage:
                                          @Homoran:
                                          Wo stellst du es denn dar? `
                                          habe ich immer noch?
                                          Das Ganze bezog sich auf das Gerät, mit dem du dir den View anzeigen lässt.
                                          Rainer
                                            Post-Überschneidung 😄
                                            @Brati:
                                            Ich denke mal da ist der Fehler. `
                                            Ich auch.
                                            Ich setze den vCard Adapter aber selber nicht ein und kenne daher die Konfiguration nicht, benötige dazu die Info von dem Fragenden, bekomme nur auf meine Fragen keine brauchbaren Antworten. 😞
                                            Rainer
                                            128
                                            26246
