    3. Off Topic
    4. ! gelöst ! NUC Proxmox Bluetooth onboard
      woupi @Guest last edited by
      @dp20eic sagte in NUC Proxmox Bluetooth onboard:
      @woupi sagte in NUC Proxmox Bluetooth onboard:
      # lsusb
      # lspci
      Ist denn da Bluetooth zu finden, hast Du mal im Bios geschaut ob das angeschaltet ist?
      VG
      Bernd
      root@server:~# lsusb
      Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
      Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
      Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
      Bus 001 Device 002: ID 1a86:7523 QinHeng Electronics CH340 serial converter
      Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
      root@server:~#
      root@server:~# lspci
      00:00.0 Host bridge: Intel Corporation Device 9b71 (rev 0c)
      00:02.0 VGA compatible controller: Intel Corporation CometLake-U GT2 [UHD Graphi        cs] (rev 02)
      00:08.0 System peripheral: Intel Corporation Xeon E3-1200 v5/v6 / E3-1500 v5 / 6        th/7th/8th Gen Core Processor Gaussian Mixture Model
      00:12.0 Signal processing controller: Intel Corporation Comet Lake Thermal Subsy        tem
      00:14.0 USB controller: Intel Corporation Comet Lake PCH-LP USB 3.1 xHCI Host Co        ntroller
      00:14.2 RAM memory: Intel Corporation Comet Lake PCH-LP Shared SRAM
      00:15.0 Serial bus controller: Intel Corporation Serial IO I2C Host Controller
      00:15.2 Serial bus controller: Intel Corporation Comet Lake PCH-LP LPSS: I2C Con        troller #2
      00:16.0 Communication controller: Intel Corporation Comet Lake Management Engine        Interface
      00:17.0 SATA controller: Intel Corporation Comet Lake SATA AHCI Controller
      00:1c.0 PCI bridge: Intel Corporation Comet Lake PCI Express Root Port #5 (rev f        0)
      00:1d.0 PCI bridge: Intel Corporation Device 02b5 (rev f0)
      00:1f.0 ISA bridge: Intel Corporation Comet Lake PCH-LP LPC Premium Controller/e        SPI Controller
      00:1f.4 SMBus: Intel Corporation Comet Lake PCH-LP SMBus Host Controller
      00:1f.5 Serial bus controller: Intel Corporation Comet Lake SPI (flash) Controll        er
      00:1f.6 Ethernet controller: Intel Corporation Ethernet Connection (10) I219-V
      01:00.0 PCI bridge: Intel Corporation JHL7540 Thunderbolt 3 Bridge [Titan Ridge        2C 2018] (rev 06)
      02:00.0 PCI bridge: Intel Corporation JHL7540 Thunderbolt 3 Bridge [Titan Ridge        2C 2018] (rev 06)
      02:01.0 PCI bridge: Intel Corporation JHL7540 Thunderbolt 3 Bridge [Titan Ridge        2C 2018] (rev 06)
      02:02.0 PCI bridge: Intel Corporation JHL7540 Thunderbolt 3 Bridge [Titan Ridge        2C 2018] (rev 06)
      03:00.0 System peripheral: Intel Corporation JHL7540 Thunderbolt 3 NHI [Titan Ri        dge 2C 2018] (rev 06)
      39:00.0 USB controller: Intel Corporation JHL7540 Thunderbolt 3 USB Controller [        Titan Ridge 2C 2018] (rev 06)
      3a:00.0 SD Host controller: Genesys Logic, Inc GL9755 SD Host Controller
      root@server:~#
        woupi @Thomas Braun last edited by
        @thomas-braun sagte in NUC Proxmox Bluetooth onboard:
        zugriff habe ich über ssh mit Putty
        Worauf? Direkt auf den Host oder auf das virtuelle Zeuch?
        Mach mal besser mit @dp20eic weiter, für Proxmox bin ich zu doof. 🙂
        Nein, nicht auf VM, direkt auf Proxmox, ist Debian.
          hcitool dev
          root@server:~# hcitool dev
          Devices:
          root@server:~# rfkill
          -bash: rfkill: command not found
          root@server:~#
          • wendy2702
            wendy2702 @woupi last edited by
            @woupi Wo und wie kopierst du die logs? Die sind ja immer abgeschnitten
              woupi @wendy2702 last edited by
              @wendy2702 sagte in NUC Proxmox Bluetooth onboard:
              strg +rechte Maustaste dann coppy,
              habe ich nicht gesehen, mach es nochmal
                woupi @woupi last edited by
                00:02.0 VGA compatible controller: Intel Corporation CometLake-U GT2 [UHD Graphics] (rev 02)
                00:08.0 System peripheral: Intel Corporation Xeon E3-1200 v5/v6 / E3-1500 v5 / 6th/7th/8th Gen Core Processor Gaussian Mixture Model
                00:12.0 Signal processing controller: Intel Corporation Comet Lake Thermal Subsytem
                00:14.0 USB controller: Intel Corporation Comet Lake PCH-LP USB 3.1 xHCI Host Controller
                00:15.2 Serial bus controller: Intel Corporation Comet Lake PCH-LP LPSS: I2C Controller #2
                00:1c.0 PCI bridge: Intel Corporation Comet Lake PCI Express Root Port #5 (rev f0)
                00:1f.0 ISA bridge: Intel Corporation Comet Lake PCH-LP LPC Premium Controller/eSPI Controller
                00:1f.5 Serial bus controller: Intel Corporation Comet Lake SPI (flash) Controller
                03:00.0 System peripheral: Intel Corporation JHL7540 Thunderbolt 3 NHI [Titan Ridge 2C 2018] (rev 06)
                39:00.0 USB controller: Intel Corporation JHL7540 Thunderbolt 3 USB Controller [Titan Ridge 2C 2018] (rev 06)
                root@server:~#
                • wendy2702
                  @woupi Ich sehe jetzt auf Anhieb kein Bluetooth Device. Ist das denn im BIOS aktiviert wie @dp20eic gefragt hat?
                    Ach ja, sorry, das habe ich übersehen.
                    Bios kann ich leider so nicht dran. ich bau den NUC morgen aus und häng den an einen Monitor und Tastatur.
                      woupi @woupi last edited by woupi
                      Guten Morgen,
                      ich habe heute morgen den NUC ausgebaut. So konnte ich den, mit Monitor und Tastatur versehen. Im Bios war tatsächlich Bluetooth deaktiviert. Das habe ich jetzt aktiviert. Anschließendes lsusb und lspci brachten aber leider keine neuen Ergebnisse:
                      Bus 001 Device 003: ID 8087:0026 Intel Corp.
                      root@server:~#
                      hcitool dev aber schon:
                      Devices:
                              hci0    08:71:90:56:38:C0
                      root@server:~#
                      Das ist ja schonmal gut.
                      Ich würde mich freuen, wenn Ihr mir weiter Helfen würdet.
                      Vielen Dank dafür schonmal und natürlich auch nochmal für gestern Abend.
                      VG
                      Sascha
                      W wendy2702 2 Replies Last reply Reply Quote 0
                        Ich habe gerade noch in Proxmox nachgesehen, da finde ich jetzt ein Unbekanntes Gerät was ich, über USB, durchreichen kann.
                        Reicht das schon?
                        VG
                        Sascha
                        PS.:
                        root@server:~# lsmod
                        btrtl                  24576  1 btusb
                        Das sollte der Treiber sein, wenn ich es richtig verstanden habe.
                        • wendy2702
                          Kann ich anhand deiner Infos nicht bestätigen:
                          Vorher:
                          Nachher:
                          Damit bist du jetzt an genau dieser Stelle aus dem Proxmox Forum:
                          Mit den Treibern musst du halt mal schauen.
                            Oh man, da habe ich bestimmt dreimal drauf geschaut und nicht gesehen, trotz neuer Brille, es nimmt leider alles ab, auch die Sehkraft.
                            Ja stimmt.
                            Ich habe den jetzt in der VM eingebunden und im iobroker den Adapter ble installiert. Jetzt warte ich mal bis der Hygrometer kommt und dann versuche ich ob ich eine Verbindung aufbauen kann.
                            • wendy2702
                              Kann ich Bestätigen 😀
                                A Former User @woupi last edited by
                                @woupi
                                Moin,
                                sorry, das ich mich erst jetzt einschalte, aber im Gegensatz zu meiner Frau und CPU, bin ich nur Single Task fähig 🙂
                                Freut mich, dass Du, mit kompetenter Hilfe, weitergekommen bist.
                                Du solltest alle Schritte und Erkenntnisse mal kurz zusammenschreiben, kann sicherlich für das iobroker Wiki interessant sein, als Ergänzung zum iobroker auf Proxmox installieren.
                                Als Tip ob das jetzt schon unter der VM funktioniert, kannst Du mal versuchen irgend ein Bluetooth Gerät zu pairen.
                                Als Anhalt kann ich dir da bluetoothctl nennen, must Du evtl. in der VM noch nachinstallieren.
                                 16:46:35  dp20eic@ryzen-5  ~ 
                                $ bluetoothctl
                                Agent registered
                                [bluetooth]# ?
                                Invalid command in menu main: ?
                                Use "help" for a list of available commands in a menu.
                                Use "menu <submenu>" if you want to enter any submenu.
                                Use "back" if you want to return to menu main.
                                [bluetooth]# help
                                Menu main:
                                Available commands:
                                advertise                                         Advertise Options Submenu
                                monitor                                           Advertisement Monitor Options Submenu
                                scan                                              Scan Options Submenu
                                gatt                                              Generic Attribute Submenu
                                admin                                             Admin Policy Submenu
                                player                                            Media Player Submenu
                                endpoint                                          Media Endpoint Submenu
                                transport                                         Media Transport Submenu
                                list                                              List available controllers
                                show [ctrl]                                       Controller information
                                select <ctrl>                                     Select default controller
                                devices [Paired/Bonded/Trusted/Connected]         List available devices, with an optional property as the filter
                                system-alias <name>                               Set controller alias
                                reset-alias                                       Reset controller alias
                                power <on/off>                                    Set controller power
                                pairable <on/off>                                 Set controller pairable mode
                                discoverable <on/off>                             Set controller discoverable mode
                                discoverable-timeout [value]                      Set discoverable timeout
                                agent <on/off/capability>                         Enable/disable agent with given capability
                                default-agent                                     Set agent as the default one
                                advertise <on/off/type>                           Enable/disable advertising with given type
                                set-alias <alias>                                 Set device alias
                                scan <on/off/bredr/le>                            Scan for devices
                                info [dev]                                        Device information
                                pair [dev]                                        Pair with device
                                cancel-pairing [dev]                              Cancel pairing with device
                                trust [dev]                                       Trust device
                                untrust [dev]                                     Untrust device
                                block [dev]                                       Block device
                                unblock [dev]                                     Unblock device
                                remove <dev>                                      Remove device
                                connect <dev>                                     Connect device
                                disconnect [dev]                                  Disconnect device
                                menu <name>                                       Select submenu
                                version                                           Display version
                                quit                                              Quit program
                                exit                                              Quit program
                                help                                              Display help about this program
                                export                                            Print environment variables
                                [bluetooth]# devices
                                Device D4:6D:6D:E6:29:BC VWAGWOLOM0ZO
                                Device 14:3F:A6:67:91:B5 WH-1000XM4
                                Device F0:41:C8:31:46:6B BT HIFI AUDIO
                                Device DF:BB:70:6C:AC:F2 Nuimo_silbern
                                Device B8:27:EB:A3:AA:24 Moode Bluetooth
                                Device E8:0A:C0:3A:6B:FA Nuimo
                                [bluetooth]#
                                [bluetooth]# pairable
                                Missing on/off argument
                                [bluetooth]# pairable on
                                Changing pairable on succeeded
                                [bluetooth]# scan
                                Missing on/off/bredr/le argument
                                [bluetooth]# scan on
                                Discovery started
                                [CHG] Controller FC:77:74:87:56:44 Discovering: yes
                                [NEW] Device 5C:3F:61:A1:54:BC 5C-3F-61-A1-54-CC
                                [NEW] Device 54:D2:72:DB:B4:B9 Nuki_13DBB4AAAAA9
                                [DEL] Device 5C:3F:61:A1:54:BC 5C-3F-61-A1-54-CC
                                [DEL] Device 54:D2:72:DB:B4:B9 Nuki_13DBB4AAAAA9
                                VG
                                Bernd
                                  woupi @Guest last edited by woupi
                                  @woupi
                                  Moin,
                                  Vielen Dank, dass du dich meldest und auch ich bin nicht Multitasking fähig. Normalerweise bin ich auch von 6 bis 18:00 nicht zu Hause, bin bis einschließlich heute aber Arbeitsunfähig. Darum hatte ich überhaupt die Zeit so früh was zu machen.
                                  mich auch.
                                  Das werde ich gerne versuchen.
                                  Habe ich gemacht und siehe da, es kommen reichlich Geräte 😀
                                  Discovery started
                                  [CHG] Controller 08:71:90:56:38:C0 Discovering: yes
                                  [NEW] Device 71:9C:11:D5:DF:26 71-9C-11-D5-DF-26
                                  [NEW] Device 40:D5:E8:8E:EF:95 40-D5-E8-8E-EF-95
                                  [NEW] Device CC:33:31:B5:A2:42 CC-33-31-B5-A2-42
                                  [NEW] Device 74:38:B7:D2:1F:71 74-38-B7-D2-1F-71
                                  [CHG] Device CC:33:31:B5:A2:42 TxPower: 0
                                  [CHG] Device CC:33:31:B5:A2:42 Name: Geberit AC PRO
                                  [CHG] Device CC:33:31:B5:A2:42 Alias: Geberit AC PRO
                                  [CHG] Device CC:33:31:B5:A2:42 ManufacturerData Key: 0x0100
                                  [CHG] Device CC:33:31:B5:A2:42 ManufacturerData Value:
                                    00 31 34 36 32 30                                .14620
                                  [CHG] Device CC:33:31:B5:A2:42 ManufacturerData Key: 0x3200
                                    34                                               4
                                  [CHG] Device 71:9C:11:D5:DF:26 RSSI: -87
                                  [CHG] Device 40:D5:E8:8E:EF:95 RSSI: -95
                                  [CHG] Device 74:38:B7:D2:1F:71 TxPower: 6
                                  [CHG] Device 74:38:B7:D2:1F:71 Appearance: 0x0200
                                  [CHG] Device 74:38:B7:D2:1F:71 Name: EOS850D_CBC374
                                  [CHG] Device 74:38:B7:D2:1F:71 Alias: EOS850D_CBC374
                                  [CHG] Device 71:9C:11:D5:DF:26 RSSI: -95
                                  [bluetooth]#
                                  Damit würde ich sagen, funktioniert.
                                  Vielen Dank für eure Hilfe.
                                  Ich werde am WE alles zusammenschreiben.
                                  Viel Falsch machen kann ich ja auch nicht, denn es steht ja alle hier drin, nur halt durcheinander und das ist für einen suchenden nicht gut, das musste ich die letzten Monate leider auch wieder feststellen.
                                  Wenn ich das habe, werde ich dann mal sehen was Du genau mit dem Wiki meinst, habe ich noch nicht gesehen, muss zu meiner Schade gestehen, habe ich auch noch nicht nach gesucht.
                                  Ich wünsche euch einen schönen Abend, ich bin dann ab morgen auch wieder arbeiten, dann ist es vorbei mit der Zeit für so schöne Dinge. 😖
                                  VG
                                  Sascha
                                    Ich habe mich jetzt auf die suche nach dem wiki gemacht.
                                    Ich habe dich bestimmt auch falsch verstanden, denn da gibt es keinen Punkt iobroker auf Proxmox.
                                    wendy2702 ? 2 Replies Last reply Reply Quote 0
                                    • wendy2702
                                      @woupi nimm einfach dass:
                                      https://www.iobroker.net/#de/documentation/install/proxmox.md
                                        Es ging darum, dass ich
                                        das, für ein Wiki zusammentragen sollte. Gut wenn jetzt mit wiki eine Dokumentation gemeint ist, komme ich damit, wenn ich es weiß, parat. Aber eintragen kann ich da doch nichts, oder?
                                        Irgendwie stehe ich auf dem Schlauch.
                                        • wendy2702
                                          @woupi schreibe es doch mal runter und poste es hier. Dann bekommen wir das auch in die Doku.
                                            @woupi
                                            Moin,
                                            ja ich meinte das, was @wendy2702 dir gezeigt hat, Danke dafür.
                                            Ja Du darfst da nichts eintragen, aber man kann einen Post machen und der Wiki Beauftragte, kann das dann sicherlich dort einfügen, den richtigen werden wir schon finden 🙂
                                            VG
                                            Bernd
                                            1.2k
                                            3784
