    4. Test Adapter LG ThinQ
      Lars0815 @Lucky_ESA last edited by
      @lucky_esa
      Auch mit Version 1.3 folgendes Problem:
      2022-12-04 20:14:53.138 - info: lg-thinq.0 (5400) Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
      2022-12-04 20:14:53.412 - info: lg-thinq.0 (5400) starting. Version 0.1.3 (non-npm: TA2k/ioBroker.lg-thinq#c1c688b5321605dcab49f244ebdf0f707fffad0a) in /opt/iobroker/node_modules/iobroker.lg-thinq, node: v16.18.0, js-controller: 4.0.23
      2022-12-04 20:14:53.497 - info: smartmeter.0 (7177) Received 7 values, 3 updated
      2022-12-04 20:14:54.900 - info: lg-thinq.0 (5400) Login successful
      2022-12-04 20:14:55.784 - info: lg-thinq.0 (5400) Found: 1 devices
      2022-12-04 20:14:56.094 - info: lg-thinq.0 (5400) createAirRemoteStates: Cannot found ControlDevice
      2022-12-04 20:14:56.362 - error: lg-thinq.0 (5400) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      2022-12-04 20:14:56.363 - error: lg-thinq.0 (5400) unhandled promise rejection: Cannot read properties of undefined (reading '0')
      2022-12-04 20:14:56.364 - error: lg-thinq.0 (5400) TypeError: Cannot read properties of undefined (reading '0')
      at LgThinq.getDeviceModelInfo (/opt/iobroker/node_modules/iobroker.lg-thinq/main.js:684:44)
      at async LgThinq.onReady (/opt/iobroker/node_modules/iobroker.lg-thinq/main.js:154:57)
      2022-12-04 20:14:56.365 - error: lg-thinq.0 (5400) Cannot read properties of undefined (reading '0')
      2022-12-04 20:14:56.371 - info: lg-thinq.0 (5400) terminating
      2022-12-04 20:14:56.373 - warn: lg-thinq.0 (5400) Terminated (UNCAUGHT_EXCEPTION): Without reason
      2022-12-04 20:14:57.116 - error: host.rpi4 instance system.adapter.lg-thinq.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
        tombox @Lars0815 last edited by
        @lars0815 kannst du mal den adapter in debug laufen lassen und den content nach
        Get Device Model Info
        posten
          Lucky_ESA Developer Most Active last edited by Lucky_ESA
          @lucky_esa sagte in Test Adapter LG ThinQ v0.0.1:
          modelJsonUri
          Wie bereits von mir beschrieben benötige ich den Inhalt vom Datenpunkt modelJsonUri. Du hast wahrscheinlich ein thinq1 Geräte was auf dem GIT nicht gefixt ist.
          Edit1: Issue auf GIT erstellt..Danke..
          Gruß//Lucky
            @lucky_esa Es hat aber bis zum letzten Update wunderbar funktioniert. 🤷‍♂️
              Lucky_ESA Developer Most Active @Lars0815 last edited by
              @lars0815 sagte in Test Adapter LG ThinQ v0.0.1:
              Ja, aber wie oben zu sehen, haben wir ein device 401 thinq2 hinzugefügt und du hast 401 thinq1. Das verursacht den Fehler.
              Du kannst vom GIT laden, diese Version sollte wieder funktionieren.
              Gruß//Lucky
                g.pitzer last edited by
                Ich bin soeben auf diesen Thread gestossen da ich zwei Klima Splitgeräte habe und diese steuern möchte. Leider habe ich auch thing1 Geräte welche nur gelesen und nicht gesteuert werden können.
                Meine Frage: Wird daran noch gearbeitet? Kann man das irgendwie unterstützen?
                Andere Frage welche nicht zum Thema passt, aber ich versuchs trotzdem: macht es Sinn mit der Klimaanlage bei einer PV mit Überschuss zu heizen und damit die Ölheizung zu entlassten?
                Danke und lg
                  Lucky_ESA Developer Most Active @g.pitzer last edited by
                  @g-pitzer Bist du sicher das du nichts steuern kannst? Es sollte ein Ordner "remote" vorhanden sein. Wenn dieser fehlt wird dein Account benötigt.
                  Deine zweite Frage kann ich dir leider nicht beantworten.
                  Gruß//Lucky
                    shellyrulestheworld @Lucky_ESA last edited by shellyrulestheworld
                    @lucky_esa said in Test Adapter LG ThinQ v0.0.1:
                    Wer nur thinq2 Geräte hat kann nun sein Intervall auf 60 Minuten ändern
                    Hallöchen,
                    vielen Dank erst mal für die tolle Arbeit. Gerade die WAMA erfolgreich gestartet.
                    Habe aber noch 2 Fragen:
                    1. Wer nur thinq2 Geräte hat kann nun sein Intervall auf 60 Minuten ändern
                      --> ist damit das Intervall im Adapter gemeint? Ich habe da aktuell 1 Minute drin.
                    2. wie pausiere ich den Waschgang richtig? Möchte bei PV Überschuss starten bzw. stoppen (pausieren)
                      Und wie lange kann ich pausieren, bis ich die WAMA wieder am Gerät einschalten muss? Inkl. Fernstart aktivieren?
                    Nutzt diese "Pause"-Funktion schon jemand in einem Blockly / Script?
                      Lucky_ESA Developer Most Active @shellyrulestheworld last edited by
                      @peterschatz
                      Zu 1: Lass auf 1 Minute stehen. Habe noch Probleme mit der MQTT Verbindung. Habe das bereits gefixt und es läuft bei mir 5 Wochen fehlerfrei. Es wird bald ein Update kommen.
                      Zu 2: Für Pause gibt es lg-thinq.0.deviceID.remote.WMStop aber das habe ich noch nie getestet. Versuche es einfach mal...True für Pause und erneut True für weiter. Ja, Fernstart muss manuell aktiviert sein.
                      Gruß//Lucky
                      JackDaniel 1 Reply Last reply Reply Quote 1
                        sudete @Lucky_ESA last edited by
                        lg-thinq.0.xxx.remote.WMStart
                        Hallo und vielen Dank für diesen super Lg ThinQ Adapter!
                        Meine Klimaanlage funktioniert prima mit dem Adapter...nachdem der Adapter nun auch Thinq2-201 Geräte voll unterstützen soll,
                        habe ich den Adapter mit meinem Signature-Waschtrockner probiert. Leider funktioniert die Remote Steuerung nur bedingt bzw. garnicht.
                        Folgende Prozedure habe ich getestet:
                        1.lg-thinq.0.xxx.remote.WMDownload_Select -> z.B.: EASYCARE_CS-STD
                        2.lg-thinq.0.xxx.remote.WMDownload -> ca 2s auf true
                        3.lg-thinq.0.xxx.remote.WMStart -> ca 2s auf true
                        dann geht
                        lg-thinq.0.xxx.remote.WMDownload_Select auf NOT_SELECTED
                        und ich bekomme eine Warning vom Adapter
                        Log Meldung: lg-thinq.0 2023-02-23 11:16:06.943 warn Datapoint WMDownload_Select is empty!
                        Der Waschtrockner schaltet aus.
                        hier noch ein paar Datenpunkt-Infos:
                        lg-thinq.0.xxx.remote.Favorite -> false
                        lg-thinq.0.xxx.remote.LastCourse -> NOT_SELECTED(0)
                        lg-thinq.0.xxx.langPackModelUri -> https://objectcontent.lgthinq.com/e3faf059-253d-4fd4-8678-2a152427b355?hdnts=exp=1689396157~hmac=35abf699a63466d6efa493dda438e93a5f39b882974b79f031d5a62300a9970c
                        lg-thinq.0.xxx.modelJsonUri -> https://objectcontent.lgthinq.com/4df5ecde-bf98-49d2-a562-4037df401c4e?hdnts=exp=1691553592~hmac=d711e49cb7702f9f49b5d09bd443e98f2099c83078b36703c453d3e51aa2f4a0
                        lg-thinq.0.xxx.deviceType -> 201
                        lg-thinq.0.xxx.platformType -> thinq2
                        Hat jemand eine Idee?
                        • JackDaniel
                          JackDaniel @Lucky_ESA last edited by
                          hust, mal nachgefragt wann "bald" eigentlich ist 🙂
                            Lucky_ESA Developer Most Active @JackDaniel last edited by
                            @jackdaniel Mach ich vielleicht heute noch
                            @sudete Hier habe ich leider ein Problem. Meine Annahme war, dass das Model 201 eine Waschmaschine ist Du hast aber eine Kombi und daher passt das alles nicht. Jetzt fehlt mir die Idee wie ich festellen kann, ob es eine WA oder Kombi ist. Wahrscheinlich müsste uns auch @tombox helfen da ich nur vermuten kann welche Werte an das Kombi-Gerät gesendet werden....Auwaia...
                            L T 2 Replies Last reply Reply Quote 0
                              Lucky_ESA Developer Most Active @Lucky_ESA last edited by
                              @sudete Hier habe ich leider ein Problem. Meine Annahme war, dass das Model 201 eine Waschmaschine ist Du hast aber eine Kombi und daher passt das alles nicht. Jetzt fehlt mir die Idee wie ich festellen kann, ob es eine WA oder Kombi ist. Wahrscheinlich müsste uns auch @tombox helfen da ich nur vermuten kann welche Werte an das Kombi-Gerät gesendet werden....Auwaia...Kannst du mal bitte auf debug stellen und mir das File zusenden github@luckyskills.de
                                tombox @Lucky_ESA last edited by
                                @JackDaniel @lucky_esa oder mal ein debug log via pn zusenden da sind auch alle infos drin
                                  Lucky_ESA Developer Most Active @JackDaniel last edited by Lucky_ESA
                                  @jackdaniel Habe es jetzt auf`m GIT
                                  @sudete Wie von tombox und mir beschrieben benötigen wir einen debuglog. Vielleicht finde ich dort eine Info womit ich erkennen kann, ob 201 WM oder 201 Kombi.
                                    @lucky_esa Ich habe mal eine Log Datei erstellt..ich hoffe ihr könnt damit etwas anfangen.LG_log_sent.txt
                                      Lucky_ESA Developer Most Active @sudete last edited by
                                      @sudete Habe jetzt auf dem GIT deine Fehlermeldungen korrigiert. Am Wochenende versuche ich zu erraten was an die Cloud übergeben werden muss. Habe aber schon eine Vermutung allerdings gibt es 4 Möglichkeiten. Wenn es nicht funktioniert musst du uns als Mitglied in der APP aufnehmen. Dann musst du hoffen, dass @tombox mal Zeit hat.
                                      Funktioniert alles mit deiner Klimaanlage?
                                      Du hast da eine super Waschmaschine...Kann die auch Bügeln und Fensterputzen?
                                      Gruß//Lucky
                                        @sudete Bitte deine Waschmaschine einschalten und Fernzugriff aktivieren. Dann mal in den Datenpunkt
                                        lg-thinq.0.<nummerderwaschmaschine>.remote.sendJSON folgendes eintragen:
                                           "ctrlKey": "WMDownload",
                                           "command": "Set",
                                           "dataSetList": {
                                               "washerDryer": {
                                           		"courseDownloadType": "COURSEDATA",
                                           		"courseDownloadDataLength": 30,
                                           		"courseMainGplusBest": "BABYCARE_CS",
                                           		"smartCourseMainGplusBest": "BABY_CARE",
                                           		"autoDetergent": "AUTO_DETERGENT_OFF",
                                           		"gplusBestWash": "GPLUS_BEST_WASH_NO_SELECT",
                                           		"steam": "STEAM_OFF",
                                           		"downloadSlotNumber": 0,
                                           		"categoryNumber": 0,
                                           		"steamSoftener": "STEAMSOFTENER_OFF",
                                           		"soilWash": "SOILWASH_NORMAL",
                                           		"temp": "TEMP_60",
                                           		"rinse": "RINSE_NORMAL",
                                           		"spin": "SPIN_1000",
                                           		"dryLevel": "NO_DRYLEVEL",
                                           		"preWash": "PREWASH_ON",
                                           		"medicRinse": "MEDICRINSE_ON",
                                           		"proofing": "PROOFING_OFF",
                                           		"creaseCare": "CREASECARE_OFF",
                                           		"turboWash": "TURBOWASH_OFF",
                                           		"softener": "SOFTENER_OFF",
                                           		"detergent": "DETERGENT_OFF",
                                           		"initialBit": "INITIAL_BIT_OFF",
                                           		"childLock": "CHILDLOCK_OFF",
                                           		"remoteStart": "REMOTE_START_OFF",
                                           		"softenerRemaining": "SOFTENER_REMAING_NO",
                                           		"detergentRemaining": "DETERGENT_REMAINING_NO",
                                           		"detergentBox": "DETERGENT_BOX_OFF",
                                           		"miniPairing": "MINI_PAIRING_OFF",
                                           		"reserveTimeMinute": 0,
                                           		"stainCare": "BLOOD",
                                           		"courseType": "SmartCourse"
                                        Was passiert dann?
                                        Werden die Daten in deine Waschmaschine übernommen oder geht die WM auf END.
                                        Wenn die WM auf End geht dann neu einschalten und Fernzugriff aktivieren.
                                        Nach beiden Fällen dann bitte das eingeben:
                                           "ctrlKey": "WMStart",
                                           "command": "Set",
                                           "dataSetList": {
                                               "washerDryer": {
                                           		"temp": "TEMP_60",
                                        Was passiert?
                                        Gruß//Lucky
                                          @lucky_esa Vielen Dank erstmal für deine Mühen!
                                          Die Klimaanlage funktioniert prima...keine Probleme beim Einstellen von Betriebsarten, Gebläsestärke, Zirkulierrichtungen sowie Temperaturen. Alles kann über IoBroker gesteuert werden. Erst gab es Probleme bei der Io-Broker Programmierung wie alles implementiert werden muss...aber wenn man das verstanden hat, klappt es auch.
                                          Ja, mit der Waschmaschine bin ich bislang sehr Zufrieden...für das Bügeln gibt es das Programm "Knitterfrei" 😉 , hat ja bereits schon jede Waschmaschine :-)...und fürs Fensterputzen warte ich noch auf ein Programm-Update von LG sollte dann auch fuktionieren😀
                                          Jetzt fehlt halt noch eine IoBroker Implementierung, um die Waschmaschine über die Sonnenstrahlung zu schalten.
                                          Gruß Uwe
                                            @lucky_esa Ich habe das Senden über sendJSON probiert, doch leider ohne Erfolg.
                                            Im ersten Fall, reagiert die Waschmischine gar nicht, opitisch jedenfalls...es wird kein neues Programm bzw. das "Baby_Care" Programm eingestellt. Hier die Debug-Info: sendjson.log
                                            Im zweiten Fall startet die Maschine zwar den Waschgang, allerdings mit dem Initialprogramm "Koch-/Buntwäsche" und nicht mit "Baby-Care". Auch hier dei Debug Info: sendjson2.log
                                            Gruß Uwe
                                            908
                                            285024
